BLF1721M8LS200U
BLF1721M8LS200U
    AMPLEON(安谱隆)
    SOT502B
    BLF1721M8LS200U
BLF1721M8LS200U 数据手册
BLF1721M8LS200 Power LDMOS transistor Rev. 1 — 22 January 2016 Product data sheet 1. Product profile 1.1 General description 200 W LDMOS power transistor for various applications such as Industrial, Scientific and Medical (ISM) and industrial heating at frequencies from 1700 MHz to 2100 MHz. Table 1. Typical performance Typical RF performance at Tcase = 25 C; VDS = 28 V; IDq = 1600 mA; in a class-AB demo circuit. Test signal CW RF pulsed RF [1] [3] f PL(1dB) Gp [1] D [1] IMD3 [2] (MHz) (W) (dB) (%) (dBc) 1700 to 1950 223.5 14.9 49.5 35.4 1900 to 2100 215.1 15.3 44.8 26.9 1700 to 1950 276.0 15.2 55.8 - 1900 to 2100 262.4 15.6 49.5 - at 1 dB compression. [2] at VDS = 28 V; IDq = 1600 mA; 2-tones; carrier spacing 5 MHz. [3] tp = 100 s;  = 10 %. 1.2 Features and benefits          Excellent ruggedness High efficiency Low thermal resistance providing excellent thermal stability Designed for broadband operation Lower output capacitance for improved performance in Doherty applications Designed for low memory effects providing excellent pre-distortability Internally matched for ease of use Integrated ESD protection Compliant to Directive 2002/95/EC, regarding Restriction of Hazardous Substances (RoHS) 1.3 Applications  RF power amplifiers for pulsed and CW applications in the 1700 MHz to 2100 MHz frequency range such as ISM and industrial heating BLF1721M8LS200 Power LDMOS transistor 2. Pinning information Table 2. Pinning Pin Description 1 drain 2 gate 3 source Simplified outline Graphic symbol 1 1 3 [1] 2 2 3 sym112 [1] Connected to flange. 3. Ordering information Table 3. Ordering information Type number Package Name Description Version BLF1721M8LS200 - earless flanged ceramic package; 2 leads SOT502B 4. Limiting values Table 4. Limiting values In accordance with the Absolute Maximum Rating System (IEC 60134). Symbol Parameter Conditions Min Max Unit VDS drain-source voltage - 65 V VGS gate-source voltage 0.5 +13 V Tstg storage temperature 65 +150 C Tj junction temperature - 225 C [1] Continuous use at maximum temperature will affect the reliability, for details refer to the on-line MTF calculator. 5. Thermal characteristics Table 5. Thermal characteristics Symbol Parameter Rth(j-c) BLF1721M8LS200 Product data sheet thermal resistance from junction to case Conditions Typ Tcase = 80 C; PL = 55 W (CW); VDS = 28 V; IDq = 2000 mA 0.263 K/W All information provided in this document is subject to legal disclaimers. Rev. 1 — 22 January 2016 Unit © Ampleon Netherlands B.V. 2016. All rights reserved. 2 of 14 BLF1721M8LS200 Power LDMOS transistor 6. Characteristics Table 6. DC characteristics Tj = 25 C unless otherwise specified. Symbol Parameter Conditions V(BR)DSS drain-source breakdown voltage VGS = 0 V; ID = 3.3 mA Min Typ 65 - Max Unit - V VGS(th) gate-source threshold voltage VDS = 10 V; ID = 330 mA 1.55 1.77 2.25 V IDSS drain leakage current VGS = 0 V; VDS = 28 V - - 4.2 A IDSX drain cut-off current VGS = VGS(th) + 3.75 V; VDS = 10 V - 60 - A IGSS gate leakage current VGS = 11 V; VDS = 0 V - - 420 nA gfs forward transconductance VDS = 10 V; ID = 330 mA - 2.2 - S RDS(on) drain-source on-state resistance VGS = VGS(th) + 3.75 V; ID = 11.55 A - 45 - m Table 7. RF characteristics Test signal: 2-carrier W-CDMA; PAR = 8.4 dB at 0.01 % probability on the CCDF; 3GPP test model 1; 1 to 64 DPCH; f1 = 2112.5 MHz; f2 = 2117.5 MHz; f3 = 2162.5 MHz; f4 = 2167.5 MHz; RF performance at VDS = 28 V; IDq = 2000 mA; Tcase = 25 C; unless otherwise specified; in a class-AB production test circuit. Symbol Parameter Conditions Min Typ Max Unit Gp power gain PL(AV) = 55 W 18 19 - dB D drain efficiency PL(AV) = 55 W 23 28.5 - % RLin input return loss PL(AV) = 55 W - 17 6 dB ACPR5M adjacent channel power ratio (5 MHz) PL(AV) = 55 W - 30 25 dBc 7. Test information 7.1 Ruggedness in class-AB operation The BLF1721M8LS200 is capable of withstanding a load mismatch corresponding to VSWR = 10 : 1 through all phases under the following conditions: VDS = 28 V; IDq = 1600 mA; PL = 200 W (CW); f = 2110 MHz. 7.2 Impedance information Table 8. Typical impedance information Measured load pull data. Typical values unless otherwise specified. ZS and ZL defined in Figure 1. BLF1721M8LS200 Product data sheet f ZS ZL (MHz) () () 1700 0.7  j2.0 2.1  j2.1 1800 0.7  j2.1 2.4  j2.4 1900 0.7  j2.4 2.8  j2.3 2000 0.6  j2.9 3.7  j1.9 2100 0.8  j3.9 4.2  j1.9 All information provided in this document is subject to legal disclaimers. Rev. 1 — 22 January 2016 © Ampleon Netherlands B.V. 2016. All rights reserved. 3 of 14 BLF1721M8LS200 Power LDMOS transistor drain ZL gate ZS 001aaf059 Fig 1. Definition of transistor impedance 7.3 Test circuit 40 mm 40 mm J2 Q2 J1 C15 C2 C4 R1 C6 C3 C5 C9 R3 R2 R4 J3 C11 C13 C10 C12 Q1 C14 C7 76.2 mm C16 C1 C8 C21 C19 C17 C18 C20 C22 aaa-020086 Printed-Circuit Board (PCB): Rogers RO3003; r = 3.0; thickness = 0.76 mm. See Table 9 for list of components. Fig 2. Component layout for test circuit for 1700 MHz to 1950 MHz Table 9. List of components For test circuit, see Figure 2. Component BLF1721M8LS200 Product data sheet Description Value Remarks C1, C6 multilayer ceramic chip capacitor 27 pF ATC: ATC600F270 C2 multilayer ceramic chip capacitor 10 F, 10 V Murata: GRM21BR61A106KE19L C3 multilayer ceramic chip capacitor 100 nF, 100 V All information provided in this document is subject to legal disclaimers. Rev. 1 — 22 January 2016 © Ampleon Netherlands B.V. 2016. All rights reserved. 4 of 14 BLF1721M8LS200 Power LDMOS transistor Table 9. List of components …continued For test circuit, see Figure 2. BLF1721M8LS200 Product data sheet Component Description Value Remarks C4 multilayer ceramic chip capacitor 10 nF, 50 V Multicomp: U0805W103K1HRN-P4 C5 multilayer ceramic chip capacitor 240 pF Passive Plus: 0805N C7, C8 multilayer ceramic chip capacitor 3.3 pF Passive Plus: 1111N C9, C22 electrolytic capacitor C10, C17 multilayer ceramic chip capacitor 10 pF ATC: ATC100B100 C11, C18 multilayer ceramic chip capacitor 330 pF Passive Plus: 1111N C12, C19 multilayer ceramic chip capacitor 0.01 F, 250 V TDK: C3225C0G2E103J160AA C13, C20 multilayer ceramic chip capacitor 0.1 F, 250 V Murata: GRM32DR72E104KW01L 220 F, 50 V C14, C15, C21 multilayer ceramic chip capacitor 10 F, 100 V TDK: C5750X7S2A106M C16 Passive Plus: 1111N multilayer ceramic chip capacitor 33 pF, C23 multilayer ceramic chip capacitor - J1, J2 power connector - J3 header connector 2 pin, 2.54 mm Sullins: GBC02SFBN-M30 Q1 transistor - BLF1721M8LS200 Q2 PNP transistor - NXP: BC857B R1 resistor 9.1  SMD 0805 R2 resistor 5 SMD 0805 R3, R4 resistor 0.005 , 1 % Susumu: RL7520WT-R005-F All information provided in this document is subject to legal disclaimers. Rev. 1 — 22 January 2016 © Ampleon Netherlands B.V. 2016. All rights reserved. 5 of 14 BLF1721M8LS200 Power LDMOS transistor 40 mm 40 mm J2 Q2 J1 C20 C9 R1 C2 C4 R3 J3 C12 C16 C10 C3 C5 R2 Q1 C14 C7 76.2 mm R4 C6 C18 C21 C1 C19 C8 C15 C11 C13 C17 C22 aaa-020087 Printed-Circuit Board (PCB): Rogers RO3003; r = 3.0; thickness = 0.76 mm. See Table 10 for list of components. Fig 3. Component layout for test circuit for 1900 MHz to 2100 MHz Table 10. List of components For test circuit, see Figure 3. Component Description Value C1, C6 multilayer ceramic chip capacitor 27 pF ATC: ATC600F270 C2 multilayer ceramic chip capacitor 10 F, 10 V Murata: GRM21BR61A106KE19L C3 multilayer ceramic chip capacitor 100 nF, 100 V C4 multilayer ceramic chip capacitor 10 nF, 50 V Multicomp: U0805W103K1HRN-P4 C5 multilayer ceramic chip capacitor 240 pF Passive Plus: 0805N C7, C8 multilayer ceramic chip capacitor 2.7 pF ATC: ATC100B 220 F, 50 V C9, C22 electrolytic capacitor C10, C11 multilayer ceramic chip capacitor 10 pF ATC: ATC100B100 C12, C13 multilayer ceramic chip capacitor 330 pF Passive Plus: 1111N C14, C15 multilayer ceramic chip capacitor 0.01 F, 250 V TDK: C3225C0G2E103J160AA C16, C17 multilayer ceramic chip capacitor 0.1 F, 250 V Murata: GRM32DR72E104KW01L C18, C19, C20 multilayer ceramic chip capacitor 10 F, 100 V BLF1721M8LS200 Product data sheet Remarks All information provided in this document is subject to legal disclaimers. Rev. 1 — 22 January 2016 TDK: C5750X7S2A106M © Ampleon Netherlands B.V. 2016. All rights reserved. 6 of 14 BLF1721M8LS200 Power LDMOS transistor Table 10. List of components …continued For test circuit, see Figure 3. Component Description Value Remarks C21 multilayer ceramic chip capacitor 33 pF, J1, J2 power connector - J3 header connector 2 pin, 0.1 inch Sullins: GBC02SFBN-M30 Q1 transistor - BLF1721M8LS200 Q2 PNP transistor - NXP: BC857B Passive Plus: 1111N R1 resistor 9.1  SMD 0805 R2 resistor 5 SMD 0805 R3, R4 resistor 0.005 , 1 % Susumu: RL7520WT-R005-F 7.4 Graphical data 7.4.1 1700 MHz to 1950 MHz aaa-018019 18 Gp (dB) 70 Gp 16 (1) (1) (2) (2) (3) (3) 14 12 10 ηD 8 6 46 48 50 52 54 PL (dBm) aaa-018020 18 ηD (%) Gp (dB) ηD (%) Gp 60 16 50 14 40 12 30 10 20 20 8 10 10 6 56 50 (1) (1) (2) (2) (3) (3) 30 0 46 VDS = 28 V; IDq = 1600 mA; tp = 100 s;  = 10 %. 48 (2) f = 1800 MHz (2) f = 1800 MHz (3) f = 1900 MHz (3) f = 1900 MHz BLF1721M8LS200 Product data sheet 50 52 54 PL (dBm) 56 VDS = 28 V; IDq = 1600 mA. (1) f = 1700 MHz Power gain and drain efficiency as function of output power; typical values 40 ηD (1) f = 1700 MHz Fig 4. 60 Fig 5. Power gain and drain efficiency as function of output power; typical values All information provided in this document is subject to legal disclaimers. Rev. 1 — 22 January 2016 © Ampleon Netherlands B.V. 2016. All rights reserved. 7 of 14 BLF1721M8LS200 Power LDMOS transistor aaa-018021 0 IMD3 (dBc) -12 -24 IMD3 low (1) (2) (3) -36 (1) (2) (3) -48 IMD3 high -60 35 39 43 47 51 PL (dBm) 55 VDS = 28 V; IDq = 1600 mA; CW; 2-tones; carrier spacing 5 MHz. (1) f = 1700 MHz (2) f = 1800 MHz (3) f = 1900 MHz Fig 6. Third-order intermodulation distortion as a function of output power; typical values 7.4.2 1900 MHz to 2100 MHz aaa-018022 18 Gp (dB) 60 Gp 16 Gp (dB) 50 (1) (1) (2) (2) (3) (3) 14 aaa-018023 18 ηD (%) ηD (%) Gp 16 40 (1) (1) (2) (2) (3) (3) 40 14 12 30 30 ηD ηD 10 20 8 10 6 0 46 48 50 52 54 PL (dBm) 12 20 10 10 8 56 0 46 VDS = 28 V; IDq = 1600 mA; tp = 100 s;  = 10 %. 48 (1) f = 1900 MHz (2) f = 2000 MHz (2) f = 2000 MHz (3) f = 2100 MHz (3) f = 2100 MHz Power gain and drain efficiency as function of output power; typical values BLF1721M8LS200 Product data sheet 50 52 PL (dBm) 54 VDS = 28 V; IDq = 1600 mA. (1) f = 1900 MHz Fig 7. 50 Fig 8. Power gain and drain efficiency as function of output power; typical values All information provided in this document is subject to legal disclaimers. Rev. 1 — 22 January 2016 © Ampleon Netherlands B.V. 2016. All rights reserved. 8 of 14 BLF1721M8LS200 Power LDMOS transistor aaa-018024 0 IMD3 (dBc) -12 -24 IMD3 low (1) (2) (3) -36 (1) (2) (3) -48 IMD3 high -60 35 39 43 47 51 PL (dBm) 55 VDS = 28 V; IDq = 1600 mA; CW; 2-tones; carrier spacing 5 MHz. (1) f = 1900 MHz (2) f = 2000 MHz (3) f = 2100 MHz Fig 9. Third-order intermodulation distortion as a function of output power; typical values BLF1721M8LS200 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 1 — 22 January 2016 © Ampleon Netherlands B.V. 2016. All rights reserved. 9 of 14 BLF1721M8LS200 Power LDMOS transistor 8. Package outline Earless flanged ceramic package; 2 leads SOT502B D A F 3 D D1 c U1 1 L H E1 U2 E 2 w2 M D M b 0 5 Q 10 mm scale DIMENSIONS (millimetre dimensions are derived from the original inch dimensions) UNIT A b c mm 4.72 3.43 12.83 12.57 0.15 0.08 inches 0.186 0.135 0.505 0.006 0.495 0.003 OUTLINE VERSION E E1 F H L Q U1 U2 w2 20.02 19.96 19.61 19.66 9.50 9.30 9.53 9.25 1.14 0.89 19.94 18.92 5.33 4.32 1.70 1.45 20.70 20.45 9.91 9.65 0.25 0.788 0.786 0.772 0.774 0.374 0.375 0.366 0.364 D D1 0.045 0.785 0.210 0.035 0.745 0.170 0.067 0.815 0.057 0.805 REFERENCES IEC JEDEC JEITA 0.390 0.010 0.380 EUROPEAN PROJECTION ISSUE DATE 07-05-09 12-05-02 SOT502B Fig 10. Package outline SOT502B BLF1721M8LS200 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 1 — 22 January 2016 © Ampleon Netherlands B.V. 2016. All rights reserved. 10 of 14 BLF1721M8LS200 Power LDMOS transistor 9. Handling information CAUTION This device is sensitive to ElectroStatic Discharge (ESD). Observe precautions for handling electrostatic sensitive devices. Such precautions are described in the ANSI/ESD S20.20, IEC/ST 61340-5, JESD625-A or equivalent standards. 10. Abbreviations Table 11. Abbreviations Acronym Description 3GPP 3rd Generation Partnership Project CCDF Complementary Cumulative Distribution Function CW Continuous Wave DPCH Dedicated Physical CHannel LDMOS Laterally Diffused Metal Oxide Semiconductor MTF Median Time to Failure PAR Peak-to-Average Ratio SMD Surface Mounted Device VSWR Voltage Standing Wave Ratio W-CDMA Wideband Code Division Multiple Access 11. Revision history Table 12. Revision history Document ID Release date Data sheet status Change notice Supersedes BLF1721M8LS200 v.1 20160122 Product data sheet - - BLF1721M8LS200 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 1 — 22 January 2016 © Ampleon Netherlands B.V. 2016. All rights reserved. 11 of 14 BLF1721M8LS200 Power LDMOS transistor 12. Legal information 12.1 Data sheet status Document status[1][2] Product status[3] Definition Objective [short] data sheet Development This document contains data from the objective specification for product development. Preliminary [short] data sheet Qualification This document contains data from the preliminary specification. Product [short] data sheet Production This document contains the product specification. [1] Please consult the most recently issued document before initiating or completing a design. [2] The term ‘short data sheet’ is explained in section “Definitions”. [3] The product status of device(s) described in this document may have changed since this document was published and may differ in case of multiple devices. The latest product status information is available on the Internet at URL http://www.ampleon.com. 12.2 Definitions Draft — The document is a draft version only. The content is still under internal review and subject to formal approval, which may result in modifications or additions. Ampleon does not give any representations or warranties as to the accuracy or completeness of information included herein and shall have no liability for the consequences of use of such information. Short data sheet — A short data sheet is an extract from a full data sheet with the same product type number(s) and title. A short data sheet is intended for quick reference only and should not be relied upon to contain detailed and full information. For detailed and full information see the relevant full data sheet, which is available on request via the local Ampleon sales office. In case of any inconsistency or conflict with the short data sheet, the full data sheet shall prevail. Product specification — The information and data provided in a Product data sheet shall define the specification of the product as agreed between Ampleon and its customer, unless Ampleon and customer have explicitly agreed otherwise in writing. In no event however, shall an agreement be valid in which the Ampleon product is deemed to offer functions and qualities beyond those described in the Product data sheet. 12.3 Disclaimers Limited warranty and liability — Information in this document is believed to be accurate and reliable. However, Ampleon does not give any representations or warranties, expressed or implied, as to the accuracy or completeness of such information and shall have no liability for the consequences of use of such information. Ampleon takes no responsibility for the content in this document if provided by an information source outside of Ampleon. In no event shall Ampleon be liable for any indirect, incidental, punitive, special or consequential damages (including - without limitation - lost profits, lost savings, business interruption, costs related to the removal or replacement of any products or rework charges) whether or not such damages are based on tort (including negligence), warranty, breach of contract or any other legal theory. Notwithstanding any damages that customer might incur for any reason whatsoever, Ampleon’s aggregate and cumulative liability towards customer for the products described herein shall be limited in accordance with the Terms and conditions of commercial sale of Ampleon. Right to make changes — Ampleon reserves the right to make changes to information published in this document, including without limitation specifications and product descriptions, at any time and without notice. This document supersedes and replaces all information supplied prior to the publication hereof. Suitability for use — Ampleon products are not designed, authorized or warranted to be suitable for use in life support, life-critical or safety-critical systems or equipment, nor in applications where failure or malfunction of an BLF1721M8LS200 Product data sheet Ampleon product can reasonably be expected to result in personal injury, death or severe property or environmental damage. Ampleon and its suppliers accept no liability for inclusion and/or use of Ampleon products in such equipment or applications and therefore such inclusion and/or use is at the customer’s own risk. Applications — Applications that are described herein for any of these products are for illustrative purposes only. Ampleon makes no representation or warranty that such applications will be suitable for the specified use without further testing or modification. Customers are responsible for the design and operation of their applications and products using Ampleon products, and Ampleon accepts no liability for any assistance with applications or customer product design. It is customer’s sole responsibility to determine whether the Ampleon product is suitable and fit for the customer’s applications and products planned, as well as for the planned application and use of customer’s third party customer(s). Customers should provide appropriate design and operating safeguards to minimize the risks associated with their applications and products. Ampleon does not accept any liability related to any default, damage, costs or problem which is based on any weakness or default in the customer’s applications or products, or the application or use by customer’s third party customer(s). Customer is responsible for doing all necessary testing for the customer’s applications and products using Ampleon products in order to avoid a default of the applications and the products or of the application or use by customer’s third party customer(s). Ampleon does not accept any liability in this respect. Limiting values — Stress above one or more limiting values (as defined in the Absolute Maximum Ratings System of IEC 60134) will cause permanent damage to the device. Limiting values are stress ratings only and (proper) operation of the device at these or any other conditions above those given in the Recommended operating conditions section (if present) or the Characteristics sections of this document is not warranted. Constant or repeated exposure to limiting values will permanently and irreversibly affect the quality and reliability of the device. Terms and conditions of commercial sale — Ampleon products are sold subject to the general terms and conditions of commercial sale, as published at http://www.ampleon.com/terms, unless otherwise agreed in a valid written individual agreement. In case an individual agreement is concluded only the terms and conditions of the respective agreement shall apply. Ampleon hereby expressly objects to applying the customer’s general terms and conditions with regard to the purchase of Ampleon products by customer. No offer to sell or license — Nothing in this document may be interpreted or construed as an offer to sell products that is open for acceptance or the grant, conveyance or implication of any license under any copyrights, patents or other industrial or intellectual property rights. Export control — This document as well as the item(s) described herein may be subject to export control regulations. Export might require a prior authorization from competent authorities. All information provided in this document is subject to legal disclaimers. Rev. 1 — 22 January 2016 © Ampleon Netherlands B.V. 2016. All rights reserved. 12 of 14 BLF1721M8LS200 Power LDMOS transistor Non-automotive qualified products — Unless this data sheet expressly states that this specific Ampleon product is automotive qualified, the product is not suitable for automotive use. It is neither qualified nor tested in accordance with automotive testing or application requirements. Ampleon accepts no liability for inclusion and/or use of non-automotive qualified products in automotive equipment or applications. In the event that customer uses the product for design-in and use in automotive applications to automotive specifications and standards, customer (a) shall use the product without Ampleon’ warranty of the product for such automotive applications, use and specifications, and (b) whenever customer uses the product for automotive applications beyond Ampleon’ specifications such use shall be solely at customer’s own risk, and (c) customer fully indemnifies Ampleon for any liability, damages or failed product claims resulting from customer design and use of the product for automotive applications beyond Ampleon’ standard warranty and Ampleon’ product specifications. Translations — A non-English (translated) version of a document is for reference only. The English version shall prevail in case of any discrepancy between the translated and English versions. 12.4 Trademarks Notice: All referenced brands, product names, service names and trademarks are the property of their respective owners. Any reference or use of any ‘NXP’ trademark in this document or in or on the surface of Ampleon products does not result in any claim, liability or entitlement vis-à-vis the owner of this trademark. Ampleon is no longer part of the NXP group of companies and any reference to or use of the ‘NXP’ trademarks will be replaced by reference to or use of Ampleon’s own trademarks. 13. Contact information For more information, please visit: http://www.ampleon.com For sales office addresses, please visit: http://www.ampleon.com/sales BLF1721M8LS200 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 1 — 22 January 2016 © Ampleon Netherlands B.V. 2016. All rights reserved. 13 of 14 BLF1721M8LS200 Power LDMOS transistor 14. Contents 1 1.1 1.2 1.3 2 3 4 5 6 7 7.1 7.2 7.3 7.4 7.4.1 7.4.2 8 9 10 11 12 12.1 12.2 12.3 12.4 13 14 Product profile . . . . . . . . . . . . . . . . . . . . . . . . . . 1 General description . . . . . . . . . . . . . . . . . . . . . 1 Features and benefits . . . . . . . . . . . . . . . . . . . . 1 Applications . . . . . . . . . . . . . . . . . . . . . . . . . . . 1 Pinning information . . . . . . . . . . . . . . . . . . . . . . 2 Ordering information . . . . . . . . . . . . . . . . . . . . . 2 Limiting values. . . . . . . . . . . . . . . . . . . . . . . . . . 2 Thermal characteristics . . . . . . . . . . . . . . . . . . 2 Characteristics . . . . . . . . . . . . . . . . . . . . . . . . . . 3 Test information . . . . . . . . . . . . . . . . . . . . . . . . . 3 Ruggedness in class-AB operation . . . . . . . . . 3 Impedance information . . . . . . . . . . . . . . . . . . . 3 Test circuit. . . . . . . . . . . . . . . . . . . . . . . . . . . . . 4 Graphical data . . . . . . . . . . . . . . . . . . . . . . . . . 7 1700 MHz to 1950 MHz . . . . . . . . . . . . . . . . . . 7 1900 MHz to 2100 MHz . . . . . . . . . . . . . . . . . . 8 Package outline . . . . . . . . . . . . . . . . . . . . . . . . 10 Handling information. . . . . . . . . . . . . . . . . . . . 11 Abbreviations . . . . . . . . . . . . . . . . . . . . . . . . . . 11 Revision history . . . . . . . . . . . . . . . . . . . . . . . . 11 Legal information. . . . . . . . . . . . . . . . . . . . . . . 12 Data sheet status . . . . . . . . . . . . . . . . . . . . . . 12 Definitions . . . . . . . . . . . . . . . . . . . . . . . . . . . . 12 Disclaimers . . . . . . . . . . . . . . . . . . . . . . . . . . . 12 Trademarks. . . . . . . . . . . . . . . . . . . . . . . . . . . 13 Contact information. . . . . . . . . . . . . . . . . . . . . 13 Contents . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 14 Please be aware that important notices concerning this document and the product(s) described herein, have been included in section ‘Legal information’. © Ampleon Netherlands B.V. 2016. All rights reserved. For more information, please visit: http://www.ampleon.com For sales office addresses, please visit: http://www.ampleon.com/sales Date of release: 22 January 2016 Document identifier: BLF1721M8LS200
BLF1721M8LS200U 价格&库存
很抱歉,暂时无法提供与“BLF1721M8LS200U”相匹配的价格&库存,您可以联系我们找货
