BLF6G13LS-250P,112
BLF6G13LS-250P,112
    AMPLEON(安谱隆)
    SOT-1121B
    RF FET LDMOS 100V 17DB SOT1121B
BLF6G13LS-250P,112 数据手册
BLF6G13L-250P; BLF6G13LS-250P(G) Power LDMOS transistor Rev. 5. — 1 September 2015 Product data sheet 1. Product profile 1.1 General description 250 W LDMOS power transistor intended for CW applications at a frequency of 1.3 GHz. Table 1. Test information Typical RF performance at Tcase = 25 C; IDq = 100 mA; in a class-AB production test circuit. Test signal CW f VDS PL(1dB) Gp D (GHz) (V) (W) (dB) (%) 1.3 50 250 17 56 1.2 Features and benefits        Easy power control Integrated ESD protection Excellent ruggedness High efficiency Excellent thermal stability Internally matched for ease of use Compliant to Directive 2002/95/EC, regarding Restriction of Hazardous Substances (RoHS) 1.3 Applications  Industrial, scientific and medical applications BLF6G13L(S)-250P(G) Power LDMOS transistor 2. Pinning information Table 2. Pinning Pin Description Simplified outline Graphic symbol BLF6G13L-250P (SOT1121A) 1 drain1 2 drain2 3 gate1 4 gate2 5 1 1 2 3 [1] source 5 3 5 4 4 2 sym117 BLF6G13LS-250P (SOT1121B) 1 drain1 2 drain2 3 gate1 4 gate2 5 1 1 2 3 4 5 5 4 [1] source 3 2 sym117 BLF6G13LS-250PG (SOT1121E) 1 drain1 2 drain2 3 gate1 4 gate2 5 source [1] 1 2 3 4 1 5 3 5 4 2 sym117 [1] Connected to flange. 3. Ordering information Table 3. Ordering information Type number Package Name Description BLF6G13L-250P_LS-250P_LS-250PG#5 Product data sheet Version BLF6G13L-250P - flanged LDMOST ceramic package; 2 mounting holes; SOT1121A 4 leads BLF6G13LS-250P - earless flanged LDMOST ceramic package; 4 leads SOT1121B BLF6G13LS-250PG - earless flanged LDMOST ceramic package; 4 leads SOT1121E All information provided in this document is subject to legal disclaimers. Rev. 5 — 1 September 2015 © Ampleon The Netherlands B.V. 2015. All rights reserved. 2 of 15 BLF6G13L(S)-250P(G) Power LDMOS transistor 4. Limiting values Table 4. Limiting values In accordance with the Absolute Maximum Rating System (IEC 60134). Symbol Parameter Min Max Unit VDS drain-source voltage - 100 V VGS gate-source voltage 0.5 +13 V Tstg storage temperature 65 +150 C - 225 C junction temperature Tj [1] [1] Continuous use at maximum temperature will affect the reliability, for details refer to the on-line MTF calculator. 5. Thermal characteristics Table 5. Thermal characteristics Symbol Parameter Rth(j-c) thermal resistance from junction to case Conditions Typ Unit Tcase = 85 C; PL = 250 W 0.26 K/W 6. Characteristics Table 6. DC characteristics Tj = 25 C; per section unless otherwise specified. Symbol Parameter Conditions V(BR)DSS drain-source breakdown voltage VGS = 0 V; ID = 1.4 mA Min Typ Max Unit 100 - - V VGS(th) gate-source threshold voltage VDS = 10 V; ID = 235 mA 1.4 1.8 2.4 V IDSS drain leakage current VGS = 0 V; VDS = 50 V - - 1.4 A IDSX drain cut-off current VGS = VGS(th) + 3.75 V; VDS = 10 V - 21 - A IGSS gate leakage current VGS = 11 V; VDS = 0 V - - 240 nA gfs forward transconductance VDS = 10 V; ID = 120 mA - 1 - S RDS(on) drain-source on-state resistance VGS = VGS(th) + 3.75 V; ID = 4.75 A - 200 - m Table 7. RF characteristics Test signal: CW; f = 1.3 GHz; RF performance at VDS = 50 V; IDq = 100 mA; Tcase = 25 C; unless otherwise specified, in a class-AB production test circuit. BLF6G13L-250P_LS-250P_LS-250PG#5 Product data sheet Symbol Parameter Conditions Min Typ Max Unit VDS drain-source voltage PL = 250 W - - 50 V Gp power gain PL = 250 W 15 17 - dB RLin input return loss PL = 250 W - 30 20 dB D drain efficiency PL = 250 W 52 56 - % All information provided in this document is subject to legal disclaimers. Rev. 5 — 1 September 2015 © Ampleon The Netherlands B.V. 2015. All rights reserved. 3 of 15 BLF6G13L(S)-250P(G) Power LDMOS transistor 7. Application information 7.1 Ruggedness in class-AB operation The BLF6G13L-250P, BLF6G13LS-250P and BLF6G13LS-250PG are capable of withstanding a load mismatch corresponding to VSWR = 5 : 1 through all phases under the following conditions: VDS = 50 V; IDq = 100 mA; PL = 250 W; f = 1.3 GHz. 7.2 Impedance information Table 8. Typical impedance Typical values valid per section unless otherwise specified. f ZS ZL optimized for Gp ZL optimized for D (MHz) () () () 1200 3.03  j8.15 2.03  j0.25 1.46  j0.47 1300 4.06  j9.52 1.67  j0.92 1.19  j0.95 1400 7.00  j9.61 1.50  j1.48 1.22  j1.49 drain 1 gate 1 ZS ZL gate 2 drain 2 Fig 1. 001aak544 Definition of transistor impedance 7.3 Circuit information Table 9. List of components For application circuit see Figure 2. Component BLF6G13L-250P_LS-250P_LS-250PG#5 Product data sheet Description Value Remarks C1, C2 multilayer ceramic chip capacitor 1.9 pF [1] C3, C4 multilayer ceramic chip capacitor 4.7 pF [1] C5 multilayer ceramic chip capacitor 10 pF [1] C6, C7, C8, C9, C10, C11, C38, C39 multilayer ceramic chip capacitor 56 pF [1] C12, C13 multilayer ceramic chip capacitor 100 pF [2] C14, C15, C32, C34 multilayer ceramic chip capacitor 1 nF [2] C16, C17 electrolytic capacitor 10 F, 50 V 220 X5R C20, C21, C22, C23 multilayer ceramic chip capacitor 3.0 pF [1] C40, C41 multilayer ceramic chip capacitor 2.4 pF [1] C42, C43, C44, C45 multilayer ceramic chip capacitor 2.7 pF [1] C24 multilayer ceramic chip capacitor 0.8 pF [1] C25 multilayer ceramic chip capacitor 0.6 pF [1] All information provided in this document is subject to legal disclaimers. Rev. 5 — 1 September 2015 © Ampleon The Netherlands B.V. 2015. All rights reserved. 4 of 15 BLF6G13L(S)-250P(G) Power LDMOS transistor Table 9. List of components …continued For application circuit see Figure 2. Component Description Value Remarks C26, C27, c28, C29, C30, C31, C33, C35 multilayer ceramic chip capacitor 100 pF [1] C36, C37 multilayer ceramic chip capacitor 20 nF [3] C46, C47 electrolytic capacitor 100 F, 63 V R1, R2 SMD resistor 0603 5.1  SR1 COAX 25  UT-141C-25-TP SR2 COAX 35  UT-141C-35-TP [1] American Technical Ceramics type 800B or capacitor of same quality. [2] American Technical Ceramics type 100B or capacitor of same quality. [3] American Technical Ceramics type 200B or capacitor of same quality. C39 C46 C37 C14 C12 C40 C17 C11 C6 C7 C8 C9 C34 C35 SR2 C31 C20 C2 C3 C21 C23 C22 C24 C30 C29 C25 C28 C27 C1 C10 C16 C44 R1 C4 C5 C42 C32 R2 C26 C41 C43 C45 SR1 C13 C15 C33 C36 C47 6.600 mm C38 4.200 mm 2.700 mm 4.300 mm 2.800 mm 1.500 mm 001aan872 Printed-Circuit Board (PCB): Duroid 4350B; r = 3.48; thickness = 0.762 mm; thickness copper plating = 35 m. See Table 9 for a list of components. Fig 2. BLF6G13L-250P_LS-250P_LS-250PG#5 Product data sheet Component layout for application circuit All information provided in this document is subject to legal disclaimers. Rev. 5 — 1 September 2015 © Ampleon The Netherlands B.V. 2015. All rights reserved. 5 of 15 BLF6G13L(S)-250P(G) Power LDMOS transistor 7.4 Graphical data 7.4.1 CW 001aan868 19 Gp Gp (dB) 60 ηD (%) 45 16 ηD 30 13 10 0 50 100 150 200 250 15 300 350 PL (W) VDS = 50 V; IDq = 100 mA. Fig 3. Power gain and drain efficiency as function of output power; typical values 7.4.2 2-Carrier CW 001aan869 19 60 Gp Gp (dB) ηD (%) 16 45 ηD 13 30 10 0 100 15 300 200 PL (W) VDS = 50 V; IDq = 100 mA; carrier spacing = 100 kHz. Fig 4. BLF6G13L-250P_LS-250P_LS-250PG#5 Product data sheet Power gain and drain efficiency as function of output power; typical values All information provided in this document is subject to legal disclaimers. Rev. 5 — 1 September 2015 © Ampleon The Netherlands B.V. 2015. All rights reserved. 6 of 15 BLF6G13L(S)-250P(G) Power LDMOS transistor 001aan870 21 001aan871 -10 IMD3 (dBc) Gp (dB) -20 18 -30 (8) (7) (6) (5) (4) (3) (2) (1) 15 (1) (2) (3) (4) (5) (6) (7) (8) -40 -50 12 -60 0 50 100 150 200 250 PL (W) 0 50 (1) IDq = 100 mA (1) IDq = 100 mA (2) IDq = 300 mA (2) IDq = 300 mA (3) IDq = 500 mA (3) IDq = 500 mA (4) IDq = 700 mA (4) IDq = 700 mA (5) IDq = 900 mA (5) IDq = 900 mA (6) IDq = 1100 mA (6) IDq = 1100 mA (7) IDq = 1300 mA (7) IDq = 1300 mA (8) IDq = 1500 mA (8) IDq = 1500 mA Power gain as a function of output power; typical values BLF6G13L-250P_LS-250P_LS-250PG#5 Product data sheet 150 200 250 PL (W) VDS = 50 V; f = 1300 MHz; carrier spacing = 100 kHz. VDS = 50 V; f = 1300 MHz; carrier spacing = 100 kHz. Fig 5. 100 Fig 6. Third order intermodulation distortion as a function of output power; typical values All information provided in this document is subject to legal disclaimers. Rev. 5 — 1 September 2015 © Ampleon The Netherlands B.V. 2015. All rights reserved. 7 of 15 BLF6G13L(S)-250P(G) Power LDMOS transistor 8. Test information 8.1 Reliability 001aao402 105 Years (1) (2) (3) (4) (5) 104 103 102 10 1 0 2 4 6 8 10 12 IDS(DC) (A) MTTF (Years) The reliability at pulsed conditions can be calculated as follows: MTTF x 1 / . (1) Tj = 130 C (2) Tj = 140 C (3) Tj = 150 C (4) Tj = 160 C (5) Tj = 170 C Fig 7. BLF6G13L-250P_LS-250P_LS-250PG#5 Product data sheet Electromigration (IDS(DC), total device) All information provided in this document is subject to legal disclaimers. Rev. 5 — 1 September 2015 © Ampleon The Netherlands B.V. 2015. All rights reserved. 8 of 15 BLF6G13L(S)-250P(G) Power LDMOS transistor 9. Package outline Flanged LDMOST ceramic package; 2 mounting holes; 4 leads SOT1121A D A F D1 U1 B q C H1 c 1 2 p U2 H E1 E 5 A w1 3 A B 4 b w2 C Q e 0 5 Dimensions Unit(1) mm 10 mm scale A max 4.75 nom min 3.45 b c D D1 3.94 0.18 20.02 19.96 3.68 0.10 19.61 19.66 E e E1 F H H1 p Q(2) 9.53 9.53 1.14 19.94 12.83 3.38 1.70 9.27 9.27 0.89 18.92 12.57 3.12 1.45 q U1 U2 max 0.187 0.155 0.007 0.788 0.786 0.375 0.375 0.045 0.785 0.505 0.133 0.067 inches nom 0.35 min 0.136 0.145 0.004 0.772 0.774 0.365 0.365 0.035 0.745 0.495 0.123 0.057 33.91 9.65 1.345 0.39 0.01 0.02 1.1 1.335 0.38 Note 1. millimeter dimensions are derived from the original inch dimensions. 2. dimension is measured 0.030 inch (0.76 mm) from the body. Outline version References IEC JEDEC JEITA sot1121a_po European projection Issue date 09-10-12 10-02-02 SOT1121A Fig 8. w2 0.25 0.51 27.94 8.89 w1 34.16 9.91 Package outline SOT1121A BLF6G13L-250P_LS-250P_LS-250PG#5 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 5 — 1 September 2015 © Ampleon The Netherlands B.V. 2015. All rights reserved. 9 of 15 BLF6G13L(S)-250P(G) Power LDMOS transistor Earless flanged ceramic package; 4 leads SOT1121B D A F 5 D1 D U1 w2 H1 1 H c D 2 U2 E1 3 E 4 b y w3 e Q 0 5 10 mm scale Dimensions Unit(1) mm A max 4.75 nom min 3.45 b 3.94 c D D1 E e E1 F H H1 Q U1 U2 w2 w3 9.53 9.53 1.14 19.94 12.83 1.70 20.70 9.91 0.51 0.25 0.18 20.02 19.96 y 0.10 8.89 3.68 0.08 19.61 19.66 9.27 9.27 0.89 18.92 12.57 1.45 20.45 9.65 max 0.187 0.155 0.007 0.788 0.786 0.375 0.375 0.045 0.785 0.505 0.067 0.815 0.39 0.02 0.01 0.004 0.35 inches nom min 0.136 0.145 0.003 0.772 0.774 0.365 0.365 0.035 0.745 0.495 0.057 0.805 0.38 Note 1. millimeter dimensions are derived from the original inch dimensions. 2. dimension is measured 0.030 inch (0.76 mm) from the body. Outline version References IEC JEDEC JEITA European projection Issue date 12-06-07 15-07-21 SOT1121B Fig 9. sot1121b_po Package outline SOT1121B BLF6G13L-250P_LS-250P_LS-250PG#5 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 5 — 1 September 2015 © Ampleon The Netherlands B.V. 2015. All rights reserved. 10 of 15 BLF6G13L(S)-250P(G) Power LDMOS transistor Earless flanged LDMOST ceramic package; 4 leads SOT1121E 0.3 mm gauge plane D Lp A F 5 D1 y Q detail X U1 v B c H1 A X 1 H 2 E1 U2 3 E 4 A w2 b B α e 0 5 Dimensions Unit(1) mm 10 mm scale A b c D D1 e E E1 F H H1 Lp Q U1 U2 v w2 y max 4.75 3.94 0.18 20.02 19.96 9.53 9.53 1.14 14.3 12.83 1.38 0.050 20.70 9.91 0.25 0.25 0.10 8.89 nom min 3.45 3.68 0.08 19.61 19.66 9.27 9.27 0.89 14.1 12.57 0.98 -0.050 20.45 9.65 α 7° 0° max 0.187 0.155 0.007 0.788 0.786 0.375 0.375 0.045 0.563 0.505 0.055 -0.002 0.815 0.39 0.01 0.01 0.004 7° 0.35 inches nom 0° min 0.136 0.145 0.003 0.772 0.774 0.365 0.365 0.035 0.555 0.495 0.039 -0.002 0.805 0.38 Note 1. Millimeter dimensions are derived from the original inch dimensions. Outline version References IEC JEDEC JEITA sot1121e_po European projection Issue date 14-06-12 14-06-23 SOT1121E Fig 10. Package outline SOT1121E BLF6G13L-250P_LS-250P_LS-250PG#5 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 5 — 1 September 2015 © Ampleon The Netherlands B.V. 2015. All rights reserved. 11 of 15 BLF6G13L(S)-250P(G) Power LDMOS transistor 10. Handling information CAUTION This device is sensitive to ElectroStatic Discharge (ESD). Observe precautions for handling electrostatic sensitive devices. Such precautions are described in the ANSI/ESD S20.20, IEC/ST 61340-5, JESD625-A or equivalent standards. 11. Abbreviations Table 10. Abbreviations Acronym Description CW Continuous Wave ESD ElectroStatic Discharge LDMOS Laterally Diffused Metal-Oxide Semiconductor LDMOST Laterally Diffused Metal-Oxide Semiconductor Transistor MTF Median Time to Failure MTTF Mean Time to Failure SMD Surface-Mounted Device VSWR Voltage Standing-Wave Ratio 12. Revision history Table 11. Revision history Document ID Release date Data sheet status Change notice Supersedes BLF6G13L-250P_LS-250P_LS-250PG#5 20150901 Product data sheet - BLF6G13L-250P_ 6G13LS-250P v.4 Modifications: • The format of this document has been redesigned to comply with the new identity guidelines of Ampleon. • Legal texts have been adapted to the new company name where appropriate. BLF6G13L-250P_LS-250P_LS-250PG v.4 Product data sheet - BLF6G13L-250P_ 6G13LS-250P v.3 BLF6G13L-250P_6G13LS-250P v.3 20111014 Product data sheet - BLF6G13L-250P_ 6G13LS-250P v.2 BLF6G13L-250P_6G13LS-250P v.2 20110321 Objective data sheet - BLF6G13L-250P_ 6G13LS-250P v.1 BLF6G13L-250P_6G13LS-250P v.1 20101102 Objective data sheet - - BLF6G13L-250P_LS-250P_LS-250PG#5 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 5 — 1 September 2015 © Ampleon The Netherlands B.V. 2015. All rights reserved. 12 of 15 BLF6G13L(S)-250P(G) Power LDMOS transistor 13. Legal information 13.1 Data sheet status Document status[1][2] Product status[3] Objective [short] data sheet Development This document contains data from the objective specification for product development. Preliminary [short] data sheet Qualification This document contains data from the preliminary specification. Product [short] data sheet Production This document contains the product specification. Definition [1] Please consult the most recently issued document before initiating or completing a design. [2] The term ‘short data sheet’ is explained in section “Definitions”. [3] The product status of device(s) described in this document may have changed since this document was published and may differ in case of multiple devices. The latest product status information is available on the Internet at URL http://www.ampleon.com. 13.2 Definitions Draft — The document is a draft version only. The content is still under internal review and subject to formal approval, which may result in modifications or additions. Ampleon does not give any representations or warranties as to the accuracy or completeness of information included herein and shall have no liability for the consequences of use of such information. Short data sheet — A short data sheet is an extract from a full data sheet with the same product type number(s) and title. A short data sheet is intended for quick reference only and should not be relied upon to contain detailed and full information. For detailed and full information see the relevant full data sheet, which is available on request via the local Ampleon sales office. In case of any inconsistency or conflict with the short data sheet, the full data sheet shall prevail. Product specification — The information and data provided in a Product data sheet shall define the specification of the product as agreed between Ampleon and its customer, unless Ampleon and customer have explicitly agreed otherwise in writing. In no event however, shall an agreement be valid in which the Ampleon product is deemed to offer functions and qualities beyond those described in the Product data sheet. 13.3 Disclaimers Limited warranty and liability — Information in this document is believed to be accurate and reliable. However, Ampleon does not give any representations or warranties, expressed or implied, as to the accuracy or completeness of such information and shall have no liability for the consequences of use of such information. Ampleon takes no responsibility for the content in this document if provided by an information source outside of Ampleon. In no event shall Ampleon be liable for any indirect, incidental, punitive, special or consequential damages (including - without limitation - lost profits, lost savings, business interruption, costs related to the removal or replacement of any products or rework charges) whether or not such damages are based on tort (including negligence), warranty, breach of contract or any other legal theory. Notwithstanding any damages that customer might incur for any reason whatsoever, Ampleon’ aggregate and cumulative liability towards customer for the products described herein shall be limited in accordance with the Terms and conditions of commercial sale of Ampleon. Right to make changes — Ampleon reserves the right to make changes to information published in this document, including without limitation specifications and product descriptions, at any time and without notice. This document supersedes and replaces all information supplied prior to the publication hereof. Suitability for use — Ampleon products are not designed, authorized or warranted to be suitable for use in life support, life-critical or safety-critical systems or equipment, nor in applications where failure or malfunction of an BLF6G13L-250P_LS-250P_LS-250PG#5 Product data sheet Ampleon product can reasonably be expected to result in personal injury, death or severe property or environmental damage. Ampleon and its suppliers accept no liability for inclusion and/or use of Ampleon products in such equipment or applications and therefore such inclusion and/or use is at the customer’s own risk. Applications — Applications that are described herein for any of these products are for illustrative purposes only. Ampleon makes no representation or warranty that such applications will be suitable for the specified use without further testing or modification. Customers are responsible for the design and operation of their applications and products using Ampleon products, and Ampleon accepts no liability for any assistance with applications or customer product design. It is customer’s sole responsibility to determine whether the Ampleon product is suitable and fit for the customer’s applications and products planned, as well as for the planned application and use of customer’s third party customer(s). Customers should provide appropriate design and operating safeguards to minimize the risks associated with their applications and products. Ampleon does not accept any liability related to any default, damage, costs or problem which is based on any weakness or default in the customer’s applications or products, or the application or use by customer’s third party customer(s). Customer is responsible for doing all necessary testing for the customer’s applications and products using Ampleon products in order to avoid a default of the applications and the products or of the application or use by customer’s third party customer(s). Ampleon does not accept any liability in this respect. Limiting values — Stress above one or more limiting values (as defined in the Absolute Maximum Ratings System of IEC 60134) will cause permanent damage to the device. Limiting values are stress ratings only and (proper) operation of the device at these or any other conditions above those given in the Recommended operating conditions section (if present) or the Characteristics sections of this document is not warranted. Constant or repeated exposure to limiting values will permanently and irreversibly affect the quality and reliability of the device. Terms and conditions of commercial sale — Ampleon products are sold subject to the general terms and conditions of commercial sale, as published at http://www.ampleon.com/terms, unless otherwise agreed in a valid written individual agreement. In case an individual agreement is concluded only the terms and conditions of the respective agreement shall apply. Ampleon hereby expressly objects to applying the customer’s general terms and conditions with regard to the purchase of Ampleon products by customer. No offer to sell or license — Nothing in this document may be interpreted or construed as an offer to sell products that is open for acceptance or the grant, conveyance or implication of any license under any copyrights, patents or other industrial or intellectual property rights. Export control — This document as well as the item(s) described herein may be subject to export control regulations. Export might require a prior authorization from competent authorities. All information provided in this document is subject to legal disclaimers. Rev. 5 — 1 September 2015 © Ampleon The Netherlands B.V. 2015. All rights reserved. 13 of 15 BLF6G13L(S)-250P(G) Power LDMOS transistor Non-automotive qualified products — Unless this data sheet expressly states that this specific Ampleon product is automotive qualified, the product is not suitable for automotive use. It is neither qualified nor tested in accordance with automotive testing or application requirements. Ampleon accepts no liability for inclusion and/or use of non-automotive qualified products in automotive equipment or applications. In the event that customer uses the product for design-in and use in automotive applications to automotive specifications and standards, customer (a) shall use the product without Ampleon’ warranty of the product for such automotive applications, use and specifications, and (b) whenever customer uses the product for automotive applications beyond Ampleon’ specifications such use shall be solely at customer’s own risk, and (c) customer fully indemnifies Ampleon for any liability, damages or failed product claims resulting from customer design and use of the product for automotive applications beyond Ampleon’ standard warranty and Ampleon’ product specifications. 13.4 Trademarks Notice: All referenced brands, product names, service names and trademarks are the property of their respective owners. Any reference or use of any ‘NXP’ trademark in this document or in or on the surface of Ampleon products does not result in any claim, liability or entitlement vis-à-vis the owner of this trademark. Ampleon is no longer part of the NXP group of companies and any reference to or use of the ‘NXP’ trademarks will be replaced by reference to or use of Ampleon’s own Any reference or use of any ‘NXP’ trademark in this document or in or on the surface of Ampleon products does not result in any claim, liability or entitlement vis-à-vis the owner of this trademark. Ampleon is no longer part of the NXP group of companies and any reference to or use of the ‘NXP’ trademarks will be replaced by reference to or use of Ampleon’s own trademarks. Translations — A non-English (translated) version of a document is for reference only. The English version shall prevail in case of any discrepancy between the translated and English versions. 14. Contact information For more information, please visit: http://www.ampleon.com BLF6G13L-250P_LS-250P_LS-250PG#5 Product data sheet For sales office addresses, please visit: http://www.ampleon.com/sales All information provided in this document is subject to legal disclaimers. Rev. 5 — 1 September 2015 © Ampleon The Netherlands B.V. 2015. All rights reserved. 14 of 15 BLF6G13L(S)-250P(G) Power LDMOS transistor 15. Contents 1 1.1 1.2 1.3 2 3 4 5 6 7 7.1 7.2 7.3 7.4 7.4.1 7.4.2 8 8.1 9 10 11 12 13 13.1 13.2 13.3 13.4 14 15 Product profile . . . . . . . . . . . . . . . . . . . . . . . . . . 1 General description . . . . . . . . . . . . . . . . . . . . . 1 Features and benefits . . . . . . . . . . . . . . . . . . . . 1 Applications . . . . . . . . . . . . . . . . . . . . . . . . . . . 1 Pinning information . . . . . . . . . . . . . . . . . . . . . . 2 Ordering information . . . . . . . . . . . . . . . . . . . . . 2 Limiting values. . . . . . . . . . . . . . . . . . . . . . . . . . 3 Thermal characteristics . . . . . . . . . . . . . . . . . . 3 Characteristics . . . . . . . . . . . . . . . . . . . . . . . . . . 3 Application information. . . . . . . . . . . . . . . . . . . 4 Ruggedness in class-AB operation . . . . . . . . . 4 Impedance information . . . . . . . . . . . . . . . . . . . 4 Circuit information. . . . . . . . . . . . . . . . . . . . . . . 4 Graphical data . . . . . . . . . . . . . . . . . . . . . . . . . 6 CW . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 6 2-Carrier CW . . . . . . . . . . . . . . . . . . . . . . . . . . 6 Test information . . . . . . . . . . . . . . . . . . . . . . . . . 8 Reliability . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 8 Package outline . . . . . . . . . . . . . . . . . . . . . . . . . 9 Handling information. . . . . . . . . . . . . . . . . . . . 12 Abbreviations . . . . . . . . . . . . . . . . . . . . . . . . . . 12 Revision history . . . . . . . . . . . . . . . . . . . . . . . . 12 Legal information. . . . . . . . . . . . . . . . . . . . . . . 13 Data sheet status . . . . . . . . . . . . . . . . . . . . . . 13 Definitions . . . . . . . . . . . . . . . . . . . . . . . . . . . . 13 Disclaimers . . . . . . . . . . . . . . . . . . . . . . . . . . . 13 Trademarks. . . . . . . . . . . . . . . . . . . . . . . . . . . 14 Contact information. . . . . . . . . . . . . . . . . . . . . 14 Contents . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 15 Please be aware that important notices concerning this document and the product(s) described herein, have been included in section ‘Legal information’. © Ampleon The Netherlands B.V. 2015. All rights reserved. For more information, please visit: http://www.ampleon.com For sales office addresses, please visit: http://www.ampleon.com/sales Date of release: 1 September 2015 Document identifier: BLF6G13L-250P_LS-250P_LS-250PG#5
BLF6G13LS-250P,112 价格&库存
很抱歉,暂时无法提供与“BLF6G13LS-250P,112”相匹配的价格&库存,您可以联系我们找货
