BLP8G27-10Z
BLP8G27-10Z
    AMPLEON(安谱隆)
    HVSON16
    BLP8G27-10Z
BLP8G27-10Z 数据手册
BLP8G27-10 Power LDMOS transistor Rev. 2 — 1 September 2015 Product data sheet 1. Product profile 1.1 General description 10 W plastic LDMOS power transistor for base station applications at frequencies from 700 MHz to 2700 MHz. Table 1. Application performance (multiple frequencies) Typical RF performance at Tcase = 25 C; IDq = 110 mA; in a class-AB application circuit. Test signal Pulsed CW 2-carrier W-CDMA [1] [1] f IDq VDS PL(AV) Gp D ACPR5M (MHz) (mA) (V) (dBm) (dB) (%) (dBc) 2700 110 28 33 17 19 - 2700 110 28 33 17 22 47.3 Test signal: 2-carrier W-CDMA; carrier spacing = 5 MHz. PAR = 8.4 dB at 0.01 % probability on CCDF. 1.2 Features and benefits        High efficiency Excellent ruggedness Designed for broadband operation Excellent thermal stability High power gain Integrated ESD protection Compliant to Directive 2002/95/EC, regarding Restriction of Hazardous Substances (RoHS) 1.3 Applications       CDMA W-CDMA GSM EDGE MC-GSM LTE WiMAX BLP8G27-10 Power LDMOS transistor 2. Pinning information Table 2. Pinning Pin Description 1, 2, 7, 8, 9, 10, 15, 16 n.c. 3, 4, 5, 6 gate 11, 12, 13, 14 drain exposed die-pad source Graphic symbol [1] Simplified outline 16 9 11, 12 3, 4 [2] exposed die-pad 5, 6 1 8 Transparent top view [1] To be used in single ended applications only. [2] Connected to flange. 13, 14 aaa-017947 3. Ordering information Table 3. Ordering information Type number Package Name BLP8G27-10 Description Version HVSON16 plastic thermal enhanced very thin small outline SOT1371-1 package; no leads;16 terminals; body 4  6  0.85 mm 4. Limiting values Table 4. Limiting values In accordance with the Absolute Maximum Rating System (IEC 60134). Symbol Parameter VDS Conditions Min Max Unit drain-source voltage - 65 V VGS gate-source voltage 0.5 +13 V Tstg storage temperature 65 +150 C Tj junction temperature - 225 C 5. Thermal characteristics Table 5. Thermal characteristics Symbol Parameter Rth(j-c) BLP8G27-10 Product data sheet Conditions thermal resistance from junction to case Tcase = 80 C; PL = 2 W All information provided in this document is subject to legal disclaimers. Rev. 2 — 1 September 2015 Typ Unit 3.2 K/W © Ampleon Netherlands B.V. 2015. All rights reserved. 2 of 12 BLP8G27-10 Power LDMOS transistor 6. Characteristics Table 6. DC characteristics Tj = 25 C; unless otherwise specified. Symbol Parameter Conditions Min Typ Max Unit V(BR)DSS drain-source breakdown voltage VGS = 0 V; ID = 0.18 mA 65 - - V VGS(th) gate-source threshold voltage VDS = 10 V; ID = 18 mA 1.5 1.9 2.3 V IDSS drain leakage current VGS = 0 V; VDS = 28 V 1.4 - +1.4 A IDSX drain cut-off current VGS = VGS(th) + 3.75 V - 3.2 - A IGSS gate leakage current VGS = 11 V; VDS = 0 V - - 140 nA gfs forward transconductance VDS = 10 V; ID = 18 mA - 160 - mS RDS(on) drain-source on-state resistance VGS = VGS(th) + 3.75 V; VDS = 10 V; ID = 630 mA - 1000 - m Table 7. RF characteristics A derivative functional RF test is performed in production. The performance as mentioned below is verified by design and characterization in an NXP class-AB application board. Test signal: pulsed CW;  = 10%; tp = 100 s; VDS = 28 V; IDq = 110 mA; Tcase = 25 C; f = 2140 MHz BLP8G27-10 Product data sheet Symbol Parameter Conditions Min Typ Max Unit Gp power gain PL(AV) = 2 W 16 17 - dB D drain efficiency PL(AV) = 2 W 17 19 - % PL(1dB) output power at 1 dB gain compression 10 - - W All information provided in this document is subject to legal disclaimers. Rev. 2 — 1 September 2015 © Ampleon Netherlands B.V. 2015. All rights reserved. 3 of 12 BLP8G27-10 Power LDMOS transistor 7. Application information 7.1 Application circuit C3 C1 R2 C1 C4 C3 R1 C2 C4 C8 C9 C3 C3 Q1 C6 C9 C5 BLP8G27-10 20R04350B C4 C7 2.6G aaa-019287 Printed-Circuit Board (PCB): Rogers RO4350B; r = 3.5; thickness = 0.508 mm; thickness copper plating = 35 m. See Table 8 for list of components. Fig 1. Component layout Table 8. List of components See Figure 1 for component layout. BLP8G27-10 Product data sheet Component Description Value Remarks C1 multilayer ceramic chip capacitor 10 F Murata C2 multilayer ceramic chip capacitor 1 F Murata C3 multilayer ceramic chip capacitor 15 pF ATC 600F C4 multilayer ceramic chip capacitor 2 pF ATC 600F C5 multilayer ceramic chip capacitor 1.3 pF ATC 600F C6 multilayer ceramic chip capacitor 0.5 pF ATC 600F C7 multilayer ceramic chip capacitor 1.8 pF ATC 600F C8 multilayer ceramic chip capacitor 0.3 pF ATC 600F C9 multilayer ceramic chip capacitor 0.9 pF ATC 600F R1 chip resistor 5.1  R2 chip resistor 0 Q1 transistor - All information provided in this document is subject to legal disclaimers. Rev. 2 — 1 September 2015 BLP8G27-10 © Ampleon Netherlands B.V. 2015. All rights reserved. 4 of 12 BLP8G27-10 Power LDMOS transistor 7.2 Graphical data 7.2.1 Pulsed CW aaa-017912 20 Gp (dB) 60 ηD (%) Gp 16 (1) (1) (2) (2) (3) (3) 12 8 ηD aaa-017913 20 60 Gp (dB) ηD (%) 50 18 40 16 30 14 20 12 10 10 50 Gp (1) (1) (2) (2) (3) (3) 40 30 ηD 4 0 0 4 8 12 16 20 PL (W) 24 20 10 0 VDS = 28 V; IDq = 110 mA; Tcase = 25 C;  = 10 %; tp = 100 s. 4 8 (1) IDq = 90 mA (2) f = 2600 MHz (2) IDq = 110 mA (3) f = 2700 MHz (3) IDq = 130 mA Power gain and drain efficiency as function of output power; typical values Fig 3. 20 PL (W) 24 Power gain and drain efficiency as function of output power; typical values aaa-017914 20 60 Gp Gp (dB) 16 VDS = 28 V; Tcase = 25 C; f = 2600 MHz;  = 10 %; tp = 100 s. (1) f = 2500 MHz Fig 2. 12 ηD (%) 16 50 (1) (1) (2) (2) (3) (3) 12 40 8 30 ηD 4 20 0 10 0 4 8 12 16 20 PL (W) 24 VDS = 28 V; IDq = 110 mA; f = 2600 MHz;  = 10 %; tp = 100 s. (1) Tcase = 37 C (2) Tcase = +25 C (3) Tcase = +85 C Fig 4. Power gain and drain efficiency as function of output power; typical values BLP8G27-10 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 2 — 1 September 2015 © Ampleon Netherlands B.V. 2015. All rights reserved. 5 of 12 BLP8G27-10 Power LDMOS transistor 7.2.2 2-Carrier W-CDMA aaa-017915 20 50 ηD (%) Gp (dB) 18 40 Gp 16 30 14 (1) (2) (3) ηD (1) (2) (3) 20 12 10 10 0 0 1 2 3 4 5 6 7 PL (W) 8 VDS = 28 V; IDq = 110 mA; Tcase = 25 C; carrier spacing = 5 MHz; 46 % clipping; PAR = 8.4 dB at 0.01 % probability on CCDF. (1) f = 2500 MHz (2) f = 2600 MHz (3) f = 2700 MHz Fig 5. Power gain and drain efficiency as function of output power; typical values aaa-017916 0 ACPR5M (dBc) -10 -20 -20 -30 -30 -40 -40 (1) (2) (3) -50 aaa-017917 0 ACPR5M (dBc) -10 (3) (2) (1) -50 -60 -60 0 1 2 3 4 5 6 7 PL(AV) (W) 8 0 VDS = 28 V; IDq = 110 mA; Tcase = 25 C; carrier spacing = 5 MHz; 46 % clipping; PAR = 8.4 dB at 0.01 % probability on CCDF. 2 (1) Tcase = 37 C (2) f = 2600 MHz (2) Tcase = +25 C (3) f = 2700 MHz (3) Tcase = +85 C Adjacent channel power ratio (5 MHz) as a function of average output power; typical values BLP8G27-10 Product data sheet 6 8 PL(AV) (W) 10 VDS = 28 V; IDq = 110 mA; f = 2600 MHz; carrier spacing = 5 MHz; 46 % clipping; PAR = 8.4 dB at 0.01 % probability on CCDF. (1) f = 2500 MHz Fig 6. 4 Fig 7. Adjacent channel power ratio (5 MHz) as a function of average output power; typical values All information provided in this document is subject to legal disclaimers. Rev. 2 — 1 September 2015 © Ampleon Netherlands B.V. 2015. All rights reserved. 6 of 12 BLP8G27-10 Power LDMOS transistor 8. Test information 8.1 Ruggedness in class-AB operation The BLP8G27-10 is capable of withstanding a load mismatch corresponding to VSWR = 10 : 1 through all phases under the following conditions: VDS = 28 V; IDq = 110 mA; PL = 2 W; frequency from 700 MHz to 2700 MHz. BLP8G27-10 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 2 — 1 September 2015 © Ampleon Netherlands B.V. 2015. All rights reserved. 7 of 12 BLP8G27-10 Power LDMOS transistor 9. Package outline HVSON16: plastic thermal enhanced very thin small outline package; no leads; 16 terminals; body 4 x 6 x 0.85 mm SOT1371-1 X D B A A E A1 C detail X e3 terminal 1 index area e2 e1 terminal 1 index area v w b 1/2 e C A B C C y1 C e 1 y 8 L k Eh 16 9 Dh 0 5 mm scale Dimensions (mm are the original dimensions) Unit mm A A1 b max 1.00 0.05 0.35 nom 0.85 0.03 0.30 min 0.80 0.00 0.25 C D(1) Dh E(1) Eh e e1 e2 e3 L k v 0.2 6.1 6.0 5.9 5.2 5.1 5.0 4.1 4.0 3.9 2.0 1.9 1.8 0.8 0.65 4.0 5.3 0.5 0.4 0.3 0.70 0.65 0.60 0.1 w y 0.05 0.05 Note 1. Plastic or metal protrusions of 0.075 mm maximum per side are not included. Outline version SOT1371-1 Fig 8. References IEC JEDEC JEITA y1 0.1 sot1371-1_po European projection Issue date 14-05-19 14-08-26 MO-229 Package outline SOT1371-1 (HVSON16) BLP8G27-10 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 2 — 1 September 2015 © Ampleon Netherlands B.V. 2015. All rights reserved. 8 of 12 BLP8G27-10 Power LDMOS transistor 10. Handling information CAUTION This device is sensitive to ElectroStatic Discharge (ESD). Observe precautions for handling electrostatic sensitive devices. Such precautions are described in the ANSI/ESD S20.20, IEC/ST 61340-5, JESD625-A or equivalent standards. 11. Abbreviations Table 9. Abbreviations Acronym Description CCDF Complementary Cumulative Distribution Function CDMA Code Division Multiple Access CW Continuous Wave EDGE Enhanced Data rates for GSM Evolution ESD ElectroStatic Discharge GSM Global System for Mobile Communication LDMOS Laterally Diffused Metal-Oxide Semiconductor LTE Long Term Evolution MC-GSM Multi Carrier GSM PAR Peak-to-Average Ratio VSWR Voltage Standing-Wave Ratio W-CDMA Wideband Code Division Multiple Access WiMAX Worldwide Interoperability for Microwave Access 12. Revision history Table 10. Revision history Document ID Release date Data sheet status Change notice Supersedes BLP8G27-10 v.2 20150901 Product data sheet - BLP8G27-10 v.1 Modifications: BLP8G27-10 v.1 BLP8G27-10 Product data sheet • The format of this document has been redesigned to comply with the new identity guidelines of Ampleon • Legal texts have been adapted to the new company name where appropriate 20150824 Product data sheet - All information provided in this document is subject to legal disclaimers. Rev. 2 — 1 September 2015 - © Ampleon Netherlands B.V. 2015. All rights reserved. 9 of 12 BLP8G27-10 Power LDMOS transistor 13. Legal information 13.1 Data sheet status Document status[1][2] Product status[3] Definition Objective [short] data sheet Development This document contains data from the objective specification for product development. Preliminary [short] data sheet Qualification This document contains data from the preliminary specification. Product [short] data sheet Production This document contains the product specification. [1] Please consult the most recently issued document before initiating or completing a design. [2] The term ‘short data sheet’ is explained in section “Definitions”. [3] The product status of device(s) described in this document may have changed since this document was published and may differ in case of multiple devices. The latest product status information is available on the Internet at URL http://www.ampleon.com. 13.2 Definitions Draft — The document is a draft version only. The content is still under internal review and subject to formal approval, which may result in modifications or additions. Ampleon does not give any representations or warranties as to the accuracy or completeness of information included herein and shall have no liability for the consequences of use of such information. Short data sheet — A short data sheet is an extract from a full data sheet with the same product type number(s) and title. A short data sheet is intended for quick reference only and should not be relied upon to contain detailed and full information. For detailed and full information see the relevant full data sheet, which is available on request via the local Ampleon sales office. In case of any inconsistency or conflict with the short data sheet, the full data sheet shall prevail. Product specification — The information and data provided in a Product data sheet shall define the specification of the product as agreed between Ampleon and its customer, unless Ampleon and customer have explicitly agreed otherwise in writing. In no event however, shall an agreement be valid in which the Ampleon product is deemed to offer functions and qualities beyond those described in the Product data sheet. 13.3 Disclaimers Limited warranty and liability — Information in this document is believed to be accurate and reliable. However, Ampleon does not give any representations or warranties, expressed or implied, as to the accuracy or completeness of such information and shall have no liability for the consequences of use of such information. Ampleon takes no responsibility for the content in this document if provided by an information source outside of Ampleon. In no event shall Ampleon be liable for any indirect, incidental, punitive, special or consequential damages (including - without limitation - lost profits, lost savings, business interruption, costs related to the removal or replacement of any products or rework charges) whether or not such damages are based on tort (including negligence), warranty, breach of contract or any other legal theory. Notwithstanding any damages that customer might incur for any reason whatsoever, Ampleon’s aggregate and cumulative liability towards customer for the products described herein shall be limited in accordance with the Terms and conditions of commercial sale of Ampleon. Right to make changes — Ampleon reserves the right to make changes to information published in this document, including without limitation specifications and product descriptions, at any time and without notice. This document supersedes and replaces all information supplied prior to the publication hereof. Suitability for use — Ampleon products are not designed, authorized or warranted to be suitable for use in life support, life-critical or safety-critical systems or equipment, nor in applications where failure or malfunction of an BLP8G27-10 Product data sheet Ampleon product can reasonably be expected to result in personal injury, death or severe property or environmental damage. Ampleon and its suppliers accept no liability for inclusion and/or use of Ampleon products in such equipment or applications and therefore such inclusion and/or use is at the customer’s own risk. Applications — Applications that are described herein for any of these products are for illustrative purposes only. Ampleon makes no representation or warranty that such applications will be suitable for the specified use without further testing or modification. Customers are responsible for the design and operation of their applications and products using Ampleon products, and Ampleon accepts no liability for any assistance with applications or customer product design. It is customer’s sole responsibility to determine whether the Ampleon product is suitable and fit for the customer’s applications and products planned, as well as for the planned application and use of customer’s third party customer(s). Customers should provide appropriate design and operating safeguards to minimize the risks associated with their applications and products. Ampleon does not accept any liability related to any default, damage, costs or problem which is based on any weakness or default in the customer’s applications or products, or the application or use by customer’s third party customer(s). Customer is responsible for doing all necessary testing for the customer’s applications and products using Ampleon products in order to avoid a default of the applications and the products or of the application or use by customer’s third party customer(s). Ampleon does not accept any liability in this respect. Limiting values — Stress above one or more limiting values (as defined in the Absolute Maximum Ratings System of IEC 60134) will cause permanent damage to the device. Limiting values are stress ratings only and (proper) operation of the device at these or any other conditions above those given in the Recommended operating conditions section (if present) or the Characteristics sections of this document is not warranted. Constant or repeated exposure to limiting values will permanently and irreversibly affect the quality and reliability of the device. Terms and conditions of commercial sale — Ampleon products are sold subject to the general terms and conditions of commercial sale, as published at http://www.ampleon.com/terms, unless otherwise agreed in a valid written individual agreement. In case an individual agreement is concluded only the terms and conditions of the respective agreement shall apply. Ampleon hereby expressly objects to applying the customer’s general terms and conditions with regard to the purchase of Ampleon products by customer. No offer to sell or license — Nothing in this document may be interpreted or construed as an offer to sell products that is open for acceptance or the grant, conveyance or implication of any license under any copyrights, patents or other industrial or intellectual property rights. Export control — This document as well as the item(s) described herein may be subject to export control regulations. Export might require a prior authorization from competent authorities. All information provided in this document is subject to legal disclaimers. Rev. 2 — 1 September 2015 © Ampleon Netherlands B.V. 2015. All rights reserved. 10 of 12 BLP8G27-10 Power LDMOS transistor Non-automotive qualified products — Unless this data sheet expressly states that this specific Ampleon product is automotive qualified, the product is not suitable for automotive use. It is neither qualified nor tested in accordance with automotive testing or application requirements. Ampleon accepts no liability for inclusion and/or use of non-automotive qualified products in automotive equipment or applications. In the event that customer uses the product for design-in and use in automotive applications to automotive specifications and standards, customer (a) shall use the product without Ampleon’ warranty of the product for such automotive applications, use and specifications, and (b) whenever customer uses the product for automotive applications beyond Ampleon’ specifications such use shall be solely at customer’s own risk, and (c) customer fully indemnifies Ampleon for any liability, damages or failed product claims resulting from customer design and use of the product for automotive applications beyond Ampleon’ standard warranty and Ampleon’ product specifications. Translations — A non-English (translated) version of a document is for reference only. The English version shall prevail in case of any discrepancy between the translated and English versions. 13.4 Trademarks Notice: All referenced brands, product names, service names and trademarks are the property of their respective owners. Any reference or use of any ‘NXP’ trademark in this document or in or on the surface of Ampleon products does not result in any claim, liability or entitlement vis-à-vis the owner of this trademark. Ampleon is no longer part of the NXP group of companies and any reference to or use of the ‘NXP’ trademarks will be replaced by reference to or use of Ampleon’s own trademarks. 14. Contact information For more information, please visit: http://www.ampleon.com For sales office addresses, please visit: http://www.ampleon.com/sales BLP8G27-10 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 2 — 1 September 2015 © Ampleon Netherlands B.V. 2015. All rights reserved. 11 of 12 BLP8G27-10 Power LDMOS transistor 15. Contents 1 1.1 1.2 1.3 2 3 4 5 6 7 7.1 7.2 7.2.1 7.2.2 8 8.1 9 10 11 12 13 13.1 13.2 13.3 13.4 14 15 Product profile . . . . . . . . . . . . . . . . . . . . . . . . . . 1 General description . . . . . . . . . . . . . . . . . . . . . 1 Features and benefits . . . . . . . . . . . . . . . . . . . . 1 Applications . . . . . . . . . . . . . . . . . . . . . . . . . . . 1 Pinning information . . . . . . . . . . . . . . . . . . . . . . 2 Ordering information . . . . . . . . . . . . . . . . . . . . . 2 Limiting values. . . . . . . . . . . . . . . . . . . . . . . . . . 2 Thermal characteristics . . . . . . . . . . . . . . . . . . 2 Characteristics . . . . . . . . . . . . . . . . . . . . . . . . . . 3 Application information. . . . . . . . . . . . . . . . . . . 4 Application circuit . . . . . . . . . . . . . . . . . . . . . . . 4 Graphical data . . . . . . . . . . . . . . . . . . . . . . . . . 5 Pulsed CW . . . . . . . . . . . . . . . . . . . . . . . . . . . . 5 2-Carrier W-CDMA . . . . . . . . . . . . . . . . . . . . . . 6 Test information . . . . . . . . . . . . . . . . . . . . . . . . . 7 Ruggedness in class-AB operation . . . . . . . . . 7 Package outline . . . . . . . . . . . . . . . . . . . . . . . . . 8 Handling information. . . . . . . . . . . . . . . . . . . . . 9 Abbreviations . . . . . . . . . . . . . . . . . . . . . . . . . . . 9 Revision history . . . . . . . . . . . . . . . . . . . . . . . . . 9 Legal information. . . . . . . . . . . . . . . . . . . . . . . 10 Data sheet status . . . . . . . . . . . . . . . . . . . . . . 10 Definitions . . . . . . . . . . . . . . . . . . . . . . . . . . . . 10 Disclaimers . . . . . . . . . . . . . . . . . . . . . . . . . . . 10 Trademarks. . . . . . . . . . . . . . . . . . . . . . . . . . . 11 Contact information. . . . . . . . . . . . . . . . . . . . . 11 Contents . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 12 Please be aware that important notices concerning this document and the product(s) described herein, have been included in section ‘Legal information’. © Ampleon Netherlands B.V. 2015. All rights reserved. For more information, please visit: http://www.ampleon.com For sales office addresses, please visit: http://www.ampleon.com/sales Date of release: 1 September 2015 Document identifier: BLP8G27-10
BLP8G27-10Z 价格&库存
很抱歉,暂时无法提供与“BLP8G27-10Z”相匹配的价格&库存,您可以联系我们找货
