BLP8G21S-160PV
Power LDMOS transistor
Rev. 5 — 28 September 2015
Product data sheet
1. Product profile
1.1 General description
160 W LDMOS transistor for base station applications at frequencies from 1880 MHz to
2025 MHz.
Table 1.
Typical performance
Typical RF performance per section at Tcase = 25 C in a common source class-AB production test
circuit.
Test signal
2-carrier W-CDMA
[1]
f
IDq
VDS
PL(AV)
Gp
D
ACPR
(MHz)
(mA)
(V)
(W)
(dB)
(dBc)
1880 to 1920
600
28
31
30 [1]
Test signal: 3GPP test model 1; 64 DPCH; PAR = 8.4 dB at 0.01 % probability on CCDF;
carrier spacing = 5 MHz.
1.2 Features and benefits
Designed for broadband operation (1880 MHz to 2025 MHz)
Decoupling leads to enable improved video bandwidth
Excellent ruggedness
High efficiency
Excellent thermal stability
Internally matched for ease of use
High power gain
Integrated ESD protection
Compliant to Directive 2002/95/EC, regarding Restriction of Hazardous Substances
(RoHS)
1.3 Applications
RF power amplifiers for base station and multi-carrier applications in the 1880 MHz to
2025 MHz frequency range
BLP8G21S-160PV
2. Pinning information
Table 2.
Pinning
Pin
Description
1, 2
gate
3, 6
decoupling lead
4, 5
drain
7
source
Simplified outline
6
5
4
Graphic symbol
3
4
3
2
[1]
7
1
1
6
2
5
aaa-008888
[1]
Connected to flange.
3. Ordering information
Table 3.
Type number
Package
Name
Description
Version
BLP8G21S-160PV HSOP6F plastic, heatsink small outline package; 6 leads (flat)
SOT1221-2
4. Limiting values
Table 4.
Limiting values
In accordance with the Absolute Maximum Rating System (IEC 60134).
Symbol
Parameter
VDS
drain-source voltage
VGS
gate-source voltage
Tstg
storage temperature
Min
[1]
junction temperature
Tj
[1]
Conditions
Max
Unit
65
V
0.5
+13
V
65
+150
C
225
C
Continuous use at maximum temperature will affect the reliability, for details refer to the on-line MTF
calculator.
5. Thermal characteristics
Table 5.
Symbol
Parameter
Rth(j-case) thermal resistance from junction to case
BLP8G21S-160PV
Product data sheet
Conditions
Typ
Tcase = 80 C; PL = 80 W
0.356 K/W
All information provided in this document is subject to legal disclaimers.
Unit
© Ampleon Netherlands B.V. 2016. All rights reserved.
2 of 11
BLP8G21S-160PV
6. Characteristics
Table 6.
DC characteristics
Tj = 25 C per section, unless otherwise specified.
Symbol Parameter
Conditions
Min
V(BR)DSS drain-source breakdown voltage VGS = 0 V; ID = 1.14 mA
Typ
Max
Unit
65
V
VGS(th)
gate-source threshold voltage
VDS = 10 V; ID = 114 mA
1.5
1.9
2.3
V
VGSq
gate-source quiescent voltage
VDS = 28 V; ID = 684 mA
1.7
2.1
2.5
V
IDSS
drain leakage current
VGS = 0 V; VDS = 28 V
1.4
A
IDSX
drain cut-off current
VGS = VGS(th) + 3.75 V;
VDS = 10 V
20.4
A
IGSS
gate leakage current
VGS = 11 V; VDS = 0 V
140
nA
gfs
forward transconductance
1.0
S
RDS(on)
drain-source on-state resistance VGS = VGS(th) + 3.75 V;
ID = 3.99 A
0.1
Table 7.
RF characteristics
Test signal: 2-carrier W-CDMA; PAR = 8.4 dB at 0.01 % probability on CCDF;
carrier spacing = 5 MHz; 3GPP test model 1; 64 DPCH; f1 = 1882.5 MHz; f2 = 1887.5 MHz;
f3 = 1912.5 MHz; f4 = 1917.5 MHz; RF performance per section at VDS = 28 V; IDq = 600 mA;
Tcase = 25 C; unless otherwise specified; in a class-AB production test circuit.
Symbol
Parameter
Conditions
Min
Typ
Max
Unit
Gp
power gain
PL(AV) = 20 W
16.3
17.5
dB
D
drain efficiency
PL(AV) = 20 W
26
31
RLin
input return loss
PL(AV) = 20 W
10
6
dB
ACPR
adjacent channel power ratio
PL(AV) = 20 W
30
25
dBc
7. Application information
7.1 Ruggedness in class-AB operation
The BLP8G21S-160PV is capable of withstanding a load mismatch corresponding to
VSWR = 10 : 1 through all phases under the following conditions: per section; VDS = 28 V;
IDq = 600 mA; PL = 80 W (CW); f = 1880 MHz.
7.2 Impedance information
Table 8.
Typical impedance
Measured per section load-pull data; IDq = 600 mA; VDS = 28 V. Typical values unless otherwise
specified.
ZS [1]
f
(MHz)
1880
2.353 j8.430
2.508 j8.375
1920
3.032 j9.435
2.407 j8.091
2025
6.435 j13.55
2.148 j7.389
[1]
BLP8G21S-160PV
Product data sheet
ZL [1]
ZS and ZL defined in Figure 1.
3 of 11
BLP8G21S-160PV
drain
ZL
gate
ZS
001aaf059
Fig 1.
Definition of transistor impedance
7.3 Test circuit
110.4 mm
C4
C1
C2
R1
C3
C1
C2
C3
C1
C1
60 mm
C1
C1
C2
R1
C2
C1
C3
C1
C3
C4
aaa-010369
Printed-Circuit Board (PCB): Rogers RO4350B; thickness = 0.76 mm.
See Table 9 for list of components.
Fig 2.
Component layout for test circuit
Table 9.
List of components
For test circuit, see Figure 2.
BLP8G21S-160PV
Product data sheet
Component
Description
Value
Remarks
C1
multilayer ceramic chip capacitor
30 pF
ATC800B
C2
2.2 F
Murata
Murata
C3
10 F
C4
electrolytic capacitor
1000 F, 63 V
R1
chip resistor
5.1
Vishay Dale SMD 0805
4 of 11
BLP8G21S-160PV
7.4 Graphical data
7.4.1 Pulsed CW
aaa-010401
19
Gp
(dB)
(1)
(1)
(2)
(2)
17
16
ηD
15
aaa-010402
5
ηD
Gp
18
60
RLin
(dB)
50
-5
30
-10
10
-20
(2)
(1)
14
13
60
80
PL (W)
-25
VDS = 28 V; IDq = 600 mA.
80
PL (W)
100
(1) f = 1880 MHz
(1) f = 1880 MHz
(2) f = 1920 MHz
(2) f = 1920 MHz
Fig 3.
60
Power gain and drain efficiency as function of
output power; typical values per section
Fig 4.
Input return loss as a function of output
7.4.2 CW
aaa-010403
19
Gp
(dB)
aaa-010404
-4
ηD
Gp
18
60
RLin
(dB)
50
-8
17
40
(1)
(1)
(2)
(2)
16
30
-12
(1)
15
ηD
-16
14
(2)
10
13
60
80
PL (W)
-20
10
(1) f = 1880 MHz
(2) f = 1920 MHz
(2) f = 1920 MHz
BLP8G21S-160PV
Product data sheet
40
50
60
70
PL (W)
80
(1) f = 1880 MHz
Fig 5.
30
Fig 6.
5 of 11
BLP8G21S-160PV
7.4.3 2-Carrier W-CDMA
aaa-010405
Gp
(dB)
19
18
Gp
(1)
(1)
(2)
(2)
17
16
ηD
15
5
10
15
30
PL (W)
aaa-010406
-15
ACPR5M
(dBc)
ηD
40
-20
35
-25
30
-30
25
-35
35
(1)
(2)
5
10
15
25
30
PL (W)
35
(1) f = 1885 MHz
(1) f = 1885 MHz
(2) f = 1915 MHz
(2) f = 1915 MHz
Fig 7.
Fig 8.
Adjacent channel power ratio (5 MHz) as a
function of output power; typical values per
section
aaa-010407
-6
RLin
(dB)
-10
-14
(2)
-18
(1)
-22
10
15
30
PL (W)
35
(1) f = 1885 MHz
(2) f = 1915 MHz
Fig 9.
Input return loss as a function of output power; typical values per section
BLP8G21S-160PV
Product data sheet
6 of 11
BLP8G21S-160PV
8. Package outline
HSOP6F: plastic, heatsink small outline package; 6 leads(flat)
SOT1221-2
D
E
X
c
B
D3
A
E3
y
v
HE
A
D1
D2
e1
e3
e2
b1 (2x)
b2 (2x)
6
5
4
w
B
w
B
3
(8x) METAL
PROTRUSIONS (SOURCE)
e7
(2x)
F (6x)
e6
(2x)
E2
E1
A
A2
A1
pin 1 index
Q1
detail X
2
b (2x)
1
e4 (2x)
w
B
e5 (2x)
e6
e
10 mm
scale
Dimensions (mm are the original dimensions)
Unit
mm
max
nom
min
A
A1
3.9
0.2
0.1
A2
b
b1
b2
D(1)
c
D1
D2
D3
E(1)
E1
e7
F
HE
Q1
16.16 1.62
2.97 4.07 0.4 15.96 1.57
15.76 1.52
E2
E3
e
3.65 4.05 3.55 0.50 0.27 20.62 19.00 16.05 20.44 10.01 8.18 5.89 9.83
3.60 4.00 3.50 0.45 0.22 20.57 18.95 16.00 20.39 9.96 8.13 5.84 9.78 8.0
3.55 3.95 3.45 0.40 0.17 20.52 18.90 15.95 20.34 9.91 8.08 5.79 9.73
v
w
0.25 0.25
e1
e2
e3
14.5
6.5
4.0
e4
Outline
version
SOT1221-2
IEC
JEDEC
JEITA
European
projection
e5
8.45 9.55
Note
1. Package body dimensions “D and “E do not include mold and metal protrusions. Allowable protrusion is 0.25 mm per side.
2. Lead width dimensions “b, “ b1 and “ b2 do not include dambar protrusions. Allowable dambar protrusion is 0.25 mm in total per lead.
References
y
0.1
sot1221-2_po
Issue date
15-01-12
15-06-08
Fig 10. Package outline SOT1221-2 (HSOP6F)
BLP8G21S-160PV
Product data sheet
7 of 11
BLP8G21S-160PV
9. Handling information
CAUTION
This device is sensitive to ElectroStatic Discharge (ESD). Observe precautions for handling
electrostatic sensitive devices.
Such precautions are described in the ANSI/ESD S20.20, IEC/ST 61340-5, JESD625-A or
equivalent standards.
10. Abbreviations
Table 10.
Abbreviations
Acronym
Description
3GPP
3rd Generation Partnership Project
CCDF
Complementary Cumulative Distribution Function
CW
Continuous Wave
DPCH
Dedicated Physical CHannel
ESD
LDMOS
Laterally Diffused Metal Oxide Semiconductor
MTF
Median Time to Failure
PAR
Peak-to-Average Ratio
SMD
Surface Mounted Device
VSWR
Voltage Standing Wave Ratio
W-CDMA
Wideband Code Division Multiple Access
11. Revision history
Table 11.
Revision history
Document ID
Release date
Data sheet status
Change notice
Supersedes
BLP8G21S-160PV v.5
20150928
Product data sheet
BLP8G21S-160PV#4
Modifications
BLP8G21S-160PV#4
Modifications:
Table 3 on page 2: package outline version changed from SOT1221-1 to SOT1221-2
Figure 10 on page 7: package outline version changed from SOT1221-1 to SOT1221-2
20150901
Product data sheet
BLP8G21S-160PV v.3
The format of this document has been redesigned to comply with the new identity
guidelines of Ampleon
Legal texts have been adapted to the new company name where appropriate
BLP8G21S-160PV v.3
20140701
Product data sheet
BLP8G21S-160PV v.2
BLP8G21S-160PV v.2
20131219
Objective data sheet
BLP8G21S-160PV v.1
BLP8G21S-160PV v.1
20130808
BLP8G21S-160PV
Product data sheet
8 of 11
BLP8G21S-160PV
12. Legal information
12.1 Data sheet status
Document status[1][2]
Product status[3]
Definition
Objective [short] data sheet
Development
This document contains data from the objective specification for product development.
Preliminary [short] data sheet
Qualification
This document contains data from the preliminary specification.
Product [short] data sheet
Production
This document contains the product specification.
[1]
Please consult the most recently issued document before initiating or completing a design.
[2]
The term ‘short data sheet’ is explained in section “Definitions”.
[3]
The product status of device(s) described in this document may have changed since this document was published and may differ in case of multiple devices. The latest product status
information is available on the Internet at URL http://www.ampleon.com.
12.2 Definitions
Draft — The document is a draft version only. The content is still under
internal review and subject to formal approval, which may result in
modifications or additions. Ampleon does not give any representations or
warranties as to the accuracy or completeness of information included herein
and shall have no liability for the consequences of use of such information.
Short data sheet — A short data sheet is an extract from a full data sheet
with the same product type number(s) and title. A short data sheet is intended
for quick reference only and should not be relied upon to contain detailed and
full information. For detailed and full information see the relevant full data
sheet, which is available on request via the local Ampleon sales office. In
case of any inconsistency or conflict with the short data sheet, the full data
sheet shall prevail.
Product specification — The information and data provided in a Product
data sheet shall define the specification of the product as agreed between
Ampleon and its customer, unless Ampleon and customer have explicitly
agreed otherwise in writing. In no event however, shall an agreement be valid
in which the Ampleon product is deemed to offer functions and qualities
beyond those described in the Product data sheet.
12.3 Disclaimers
Limited warranty and liability — Information in this document is believed to
be accurate and reliable. However, Ampleon does not give any
representations or warranties, expressed or implied, as to the accuracy or
completeness of such information and shall have no liability for the
consequences of use of such information. Ampleon takes no responsibility for
the content in this document if provided by an information source outside of
Ampleon.
In no event shall Ampleon be liable for any indirect, incidental, punitive,
special or consequential damages (including - without limitation - lost profits,
lost savings, business interruption, costs related to the removal or
replacement of any products or rework charges) whether or not such
damages are based on tort (including negligence), warranty, breach of
contract or any other legal theory.
Notwithstanding any damages that customer might incur for any reason
whatsoever, Ampleon’s aggregate and cumulative liability towards customer
for the products described herein shall be limited in accordance with the
Terms and conditions of commercial sale of Ampleon.
Right to make changes — Ampleon reserves the right to make changes to
information published in this document, including without limitation
specifications and product descriptions, at any time and without notice. This
document supersedes and replaces all information supplied prior to the
publication hereof.
Suitability for use — Ampleon products are not designed, authorized or
warranted to be suitable for use in life support, life-critical or safety-critical
systems or equipment, nor in applications where failure or malfunction of an
BLP8G21S-160PV
Product data sheet
Ampleon product can reasonably be expected to result in personal injury,
death or severe property or environmental damage. Ampleon and its
suppliers accept no liability for inclusion and/or use of Ampleon products in
such equipment or applications and therefore such inclusion and/or use is at
the customer’s own risk.
Applications — Applications that are described herein for any of these
products are for illustrative purposes only. Ampleon makes no representation
or warranty that such applications will be suitable for the specified use without
further testing or modification.
Customers are responsible for the design and operation of their applications
and products using Ampleon products, and Ampleon accepts no liability for
any assistance with applications or customer product design. It is customer’s
sole responsibility to determine whether the Ampleon product is suitable and
fit for the customer’s applications and products planned, as well as for the
planned application and use of customer’s third party customer(s). Customers
should provide appropriate design and operating safeguards to minimize the
risks associated with their applications and products.
Ampleon does not accept any liability related to any default, damage, costs or
problem which is based on any weakness or default in the customer’s
applications or products, or the application or use by customer’s third party
customer(s). Customer is responsible for doing all necessary testing for the
customer’s applications and products using Ampleon products in order to
avoid a default of the applications and the products or of the application or
use by customer’s third party customer(s). Ampleon does not accept any
liability in this respect.
Limiting values — Stress above one or more limiting values (as defined in
the Absolute Maximum Ratings System of IEC 60134) will cause permanent
damage to the device. Limiting values are stress ratings only and (proper)
operation of the device at these or any other conditions above those given in
the Recommended operating conditions section (if present) or the
Characteristics sections of this document is not warranted. Constant or
repeated exposure to limiting values will permanently and irreversibly affect
the quality and reliability of the device.
Terms and conditions of commercial sale — Ampleon products are sold
subject to the general terms and conditions of commercial sale, as published
at http://www.ampleon.com/terms, unless otherwise agreed in a valid written
individual agreement. In case an individual agreement is concluded only the
terms and conditions of the respective agreement shall apply. Ampleon
hereby expressly objects to applying the customer’s general terms and
conditions with regard to the purchase of Ampleon products by customer.
No offer to sell or license — Nothing in this document may be interpreted or
construed as an offer to sell products that is open for acceptance or the grant,
conveyance or implication of any license under any copyrights, patents or
other industrial or intellectual property rights.
Export control — This document as well as the item(s) described herein
may be subject to export control regulations. Export might require a prior
authorization from competent authorities.
9 of 11
BLP8G21S-160PV
Non-automotive qualified products — Unless this data sheet expressly
states that this specific Ampleon product is automotive qualified, the product
is not suitable for automotive use. It is neither qualified nor tested in
accordance with automotive testing or application requirements. Ampleon
accepts no liability for inclusion and/or use of non-automotive qualified
products in automotive equipment or applications.
In the event that customer uses the product for design-in and use in
automotive applications to automotive specifications and standards, customer
(a) shall use the product without Ampleon’ warranty of the product for such
automotive applications, use and specifications, and (b) whenever customer
uses the product for automotive applications beyond Ampleon’ specifications
such use shall be solely at customer’s own risk, and (c) customer fully
indemnifies Ampleon for any liability, damages or failed product claims
resulting from customer design and use of the product for automotive
applications beyond Ampleon’ standard warranty and Ampleon’ product
specifications.
Translations — A non-English (translated) version of a document is for
reference only. The English version shall prevail in case of any discrepancy
between the translated and English versions.
12.4 Trademarks
Notice: All referenced brands, product names, service names and trademarks
are the property of their respective owners.
Any reference or use of any ‘NXP’ trademark in this document or in or on the
surface of Ampleon products does not result in any claim, liability or
entitlement vis-à-vis the owner of this trademark. Ampleon is no longer part of
the NXP group of companies and any reference to or use of the ‘NXP’
trademarks will be replaced by reference to or use of Ampleon’s own
trademarks.
13. Contact information
For more information, please visit: http://www.ampleon.com
For sales office addresses, please visit: http://www.ampleon.com/sales
BLP8G21S-160PV
Product data sheet
10 of 11
BLP8G21S-160PV
14. Contents
1
1.1
1.2
1.3
2
3
4
5
6
7
7.1
7.2
7.3
7.4
7.4.1
7.4.2
7.4.3
8
9
10
11
12
12.1
12.2
12.3
12.4
13
14
Product profile . . . . . . . . . . . . . . . . . . . . . . . . . . 1
General description . . . . . . . . . . . . . . . . . . . . . 1
Features and benefits . . . . . . . . . . . . . . . . . . . . 1
Applications . . . . . . . . . . . . . . . . . . . . . . . . . . . 1
Pinning information . . . . . . . . . . . . . . . . . . . . . . 2
Ordering information . . . . . . . . . . . . . . . . . . . . . 2
Limiting values. . . . . . . . . . . . . . . . . . . . . . . . . . 2
Thermal characteristics . . . . . . . . . . . . . . . . . . 2
Characteristics . . . . . . . . . . . . . . . . . . . . . . . . . . 3
Application information. . . . . . . . . . . . . . . . . . . 3
Ruggedness in class-AB operation . . . . . . . . . 3
Impedance information . . . . . . . . . . . . . . . . . . . 3
Test circuit. . . . . . . . . . . . . . . . . . . . . . . . . . . . . 4
Graphical data . . . . . . . . . . . . . . . . . . . . . . . . . 5
Pulsed CW . . . . . . . . . . . . . . . . . . . . . . . . . . . . 5
CW . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 5
2-Carrier W-CDMA . . . . . . . . . . . . . . . . . . . . . . 6
Package outline . . . . . . . . . . . . . . . . . . . . . . . . . 7
Handling information. . . . . . . . . . . . . . . . . . . . . 8
Abbreviations . . . . . . . . . . . . . . . . . . . . . . . . . . . 8
Revision history . . . . . . . . . . . . . . . . . . . . . . . . . 8
Legal information. . . . . . . . . . . . . . . . . . . . . . . . 9
Data sheet status . . . . . . . . . . . . . . . . . . . . . . . 9
Definitions . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 9
Disclaimers . . . . . . . . . . . . . . . . . . . . . . . . . . . . 9
Trademarks. . . . . . . . . . . . . . . . . . . . . . . . . . . 10
Contact information. . . . . . . . . . . . . . . . . . . . . 10
Contents . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 11
Please be aware that important notices concerning this document and the product(s)
described herein, have been included in section ‘Legal information’.
Date of release: 28 September 2015
Document identifier: BLP8G21S-160PV
