BLA6H0912L-1000U
BLA6H0912L-1000U
    AMPLEON(安谱隆)
    SOT539A
    RFFETLDMOS100V15.5DBSOT539A
BLA6H0912L-1000U 数据手册
BLA6H0912L-1000; BLA6H0912LS-1000 LDMOS avionics power transistor Rev. 5 — 1 September 2015 Product data sheet 1. Product profile 1.1 General description 1000W LDMOS pulsed power transistor intended for avionics transmitter applications in the 960 MHz to 1215 MHz frequency range such as Mode-S, TCAS, JTIDS, DME and TACAN. Table 1. Application information Typical RF performance at Tcase = 25 C; tp = 50 s;  = 2 %; IDq = 200 mA; in a class-AB application circuit. Test signal pulsed RF f VDS PL Gp D tr tf (MHz) (V) (W) (dB) (%) (ns) (ns) 1030 50 1000 16 52 11 5 1.2 Features and benefits          Easy power control Integrated ESD protection High flexibility with respect to pulse formats Excellent ruggedness High efficiency Excellent thermal stability Designed for broadband operation (960 MHz to 1215 MHz) Internally matched for ease of use Compliant to Directive 2002/95/EC, regarding Restriction of Hazardous Substances (RoHS) 1.3 Applications  1000 W LDMOS pulsed power transistor intended for Mode-S, TCAS, JTIDS, DME and TACAN applications in the 960 MHz to 1215 MHz frequency range BLA6H0912L(S)-1000 LDMOS avionics power transistor 2. Pinning information Table 2. Pinning Pin Description Simplified outline Graphic symbol BLA6H0912L-1000 (SOT539A) 1 drain1 2 drain2 3 gate1 4 gate2 5 1 1 2 5 3 3 4 5 4 [1] source 2 sym117 BLA6H0912LS-1000 (SOT539B) 1 drain1 2 drain2 3 gate1 4 gate2 5 1 1 2 5 3 3 4 5 4 [1] source 2 sym117 [1] Connected to flange. 3. Ordering information Table 3. Ordering information Type number Package BLA6H0912L-1000 Name Description Version - flanged balanced ceramic package; 2 mounting holes; 4 leads SOT539A earless flanged balanced ceramic package; 4 leads SOT539B BLA6H0912LS-1000 - 4. Limiting values Table 4. Limiting values In accordance with the Absolute Maximum Rating System (IEC 60134). Symbol Parameter Max Unit VDS drain-source voltage - 100 V gate-source voltage 0.5 +13 V Tstg storage temperature 65 +150 C - 225 C [1] Product data sheet Min VGS Tj BLA6H0912L-1000_0912LS-1000#5 Conditions junction temperature [1] Continuous use at maximum temperature will affect the reliability, for details refer to the on-line MTF calculator. All information provided in this document is subject to legal disclaimers. Rev. 5 — 1 September 2015 © Ampleon The Netherlands B.V. 2015. All rights reserved. 2 of 13 BLA6H0912L(S)-1000 LDMOS avionics power transistor 5. Thermal characteristics Table 5. Thermal characteristics Symbol Parameter Conditions Typ Zth(j-c) transient thermal impedance from junction to case Tcase = 80 C; PL = 1000 W Unit tp = 50 s;  = 2 % 0.011 K/W tp = 100 s;  = 10 % 0.021 K/W tp = 200 s;  = 10 % 0.025 K/W tp = 300 s;  = 10 % 0.027 K/W tp = 2.4 ms;  = 6.4 % 0.041 K/W 6. Characteristics Table 6. DC characteristics Tj = 25 C; per section unless otherwise specified. Symbol Parameter Conditions V(BR)DSS drain-source breakdown voltage VGS = 0 V; ID = 4 mA Min Typ Max Unit 104 - - V VGS(th) gate-source threshold voltage VDS = 10 V; ID = 400 mA 1.25 1.8 2.25 V IDSS drain leakage current VGS = 0 V; VDS = 50 V - - 2.8 A IDSX drain cut-off current VGS = VGS(th) + 3.75 V; VDS = 10 V - 62 - A IGSS gate leakage current VGS = 11 V; VDS = 0 V - - 280 nA gfs forward transconductance VDS = 10 V; ID = 20 A - 34 - S RDS(on) drain-source on-state resistance VGS = VGS(th) + 3.75 V; ID = 14 A - 75 - m Table 7. RF characteristics Test signal: pulsed RF; tp = 50 s;  = 2 %; RF performance at VDS = 50 V; IDq = 200 mA; f = 1030 MHz; Tcase = 25 C; unless otherwise specified, in a class-AB production test circuit. Symbol Parameter Conditions Min Typ Max Unit VDS drain-source voltage PL = 1000 W - - 50 V Gp power gain PL = 1000 W 14 15.5 - dB RLin input return loss PL = 1000 W - 19 11 dB D drain efficiency PL = 1000 W 47 51 - % Pdroop(pulse) pulse droop power PL = 1000 W - 0 0.3 dB tr rise time PL = 1000 W - 11 30 ns tf fall time PL = 1000 W - 5 30 ns 7. Test information 7.1 Ruggedness in class-AB operation The BLA6H0912L-1000 and the BLA6H0912LS-1000 are capable of withstanding a load mismatch corresponding to VSWR = 3 : 1 through all phases under the following conditions: VDS = 50 V; IDq = 200 mA; PL = 1000 W; tp = 50 s;  = 2 %; f = 1030 MHz. BLA6H0912L-1000_0912LS-1000#5 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 5 — 1 September 2015 © Ampleon The Netherlands B.V. 2015. All rights reserved. 3 of 13 BLA6H0912L(S)-1000 LDMOS avionics power transistor 7.2 Impedance information Table 8. Typical impedance Typical values per section unless otherwise specified. ZL [1] ZL [2] f ZS (MHz) () () () 950 1.12  j2.27 0.60 + j0.21 0.62  j0.02 1000 1.39  j2.69 0.54 + j0.08 0.66  j0.06 1050 1.79  j2.79 0.40 + j0.03 0.52  j0.28 1100 2.44  j2.72 0.41  j0.12 0.67  j0.29 1150 1.68  j2.52 0.49  j0.21 0.53  j0.35 1200 4.68  j2.97 0.36  j0.30 0.57  j0.40 [1] Optimized for drain efficiency. [2] Optimized for power gain. drain ZL gate ZS 001aaf059 Fig 1. BLA6H0912L-1000_0912LS-1000#5 Product data sheet Definition of transistor impedance All information provided in this document is subject to legal disclaimers. Rev. 5 — 1 September 2015 © Ampleon The Netherlands B.V. 2015. All rights reserved. 4 of 13 BLA6H0912L(S)-1000 LDMOS avionics power transistor 7.3 Circuit information 50 mm 50 mm R3 C22 R1 C4 C10 C11 C23 C14 + R5 C5 C27 C2 C1 C8 60 mm C3 C28 C6 C19 C26 R2 C7 C16 C17 C25 R4 aaa-009717 Printed-Circuit Board (PCB) material: Rogers Duroid 6002 with r = 2.94 and thickness = 0.762 mm. See Table 9 for list of components. Fig 2. Component layout Table 9. List of components See Figure 2 for component layout. Component Description Value C1, C4, C7, C8, C22, C25 multilayer ceramic chip capacitor 33 pF [1] C2, C3, C27, C28 multilayer ceramic chip capacitor 6.2 pF [1] C5, C6 multilayer ceramic chip capacitor 3.9 pF [1] C23, C26 multilayer ceramic chip capacitor 1 nF [1] C10, C16 multilayer ceramic chip capacitor 10 nF Murata C11, C17 multilayer ceramic chip capacitor 100 nF TDK C14 electrolytic capacitor 220 F, 63 V C19 multilayer ceramic chip capacitor 10 F, 100 V R1 SMD resistor 1 k SMD 0603 R2 SMD resistor 20  SMD 0603 R3, R4 SMD resistor 2.4  SMD 0603 R5 current sense resistor 0.005  [1] BLA6H0912L-1000_0912LS-1000#5 Product data sheet Remarks American Technical Ceramics type 100B or capacitor of same quality. All information provided in this document is subject to legal disclaimers. Rev. 5 — 1 September 2015 © Ampleon The Netherlands B.V. 2015. All rights reserved. 5 of 13 BLA6H0912L(S)-1000 LDMOS avionics power transistor 7.4 Graphical data 7.4.1 Pulsed CW aaa-009718 1200 PL (W) 1000 aaa-009719 20 Gp (dB) ηD (%) Gp 17 60 50 800 14 600 11 30 400 8 20 200 5 10 0 2 0 5 10 15 20 25 30 35 Pi (W) 40 0 VDS = 50 V; IDq = 200 mA; f = 1030 MHz; tp = 50 s;  = 2 %. Fig 3. 40 ηD Output power as a function of input power; typical values 400 600 800 1000 PL (W) 0 1200 VDS = 50 V; IDq = 200 mA; f = 1030 MHz; tp = 50 s;  = 2 %. Fig 4. aaa-009721 1200 PL (W) 1000 200 Power gain and drain efficiency as function of output power; typical values aaa-009722 20 Gp (dB) 16 (1) (2) (3) 800 12 (1) (2) (3) 600 8 400 4 200 0 0 0 5 10 15 20 25 30 Pi (W) 35 0 VDS = 50 V; IDq = 200 mA; f = 1030 MHz; tp = 50 s;  = 2 %. 200 (1) Tcase = 20 C (2) Tcase = 50 C (2) Tcase = 50 C (3) Tcase = 70 C (3) Tcase = 70 C Output power as a function of input power; typical values BLA6H0912L-1000_0912LS-1000#5 Product data sheet 600 800 1000 PL (W) 1200 VDS = 50 V; IDq = 200 mA; f = 1030 MHz; tp = 50 s;  = 2 %. (1) Tcase = 20 C Fig 5. 400 Fig 6. Power gain as a function of output power; typical values All information provided in this document is subject to legal disclaimers. Rev. 5 — 1 September 2015 © Ampleon The Netherlands B.V. 2015. All rights reserved. 6 of 13 BLA6H0912L(S)-1000 LDMOS avionics power transistor aaa-009723 60 ηD (%) 50 (1) (2) (3) 40 aaa-009725 1200 PL (W) 1000 800 30 600 20 400 10 200 0 (1) (2) (3) (4) (5) 0 0 200 400 600 800 1000 PL (W) 1200 VDS = 50 V; IDq = 200 mA; f = 1030 MHz; tp = 50 s;  = 2 %. (1) Tcase = 20 C 0 5 10 15 20 25 30 Pi (W) 35 IDq = 200 mA; tp = 50 s;  = 2 %. (1) VDS = 50 V (2) VDS = 48 V (2) Tcase = 50 C (3) VDS = 46 V (3) Tcase = 70 C (4) VDS = 44 V (5) VDS = 42 V Fig 7. Drain efficiency as a function of output power; typical values Fig 8. aaa-009726 20 Gp (dB) Output power as a function of input power; typical values aaa-009727 60 ηD (%) 50 16 (1) (2) (3) (4) (5) 12 40 (5) (4) (3) (2) (1) 30 8 20 4 10 0 0 0 200 400 600 800 1000 PL (W) 1200 IDq = 200 mA; tp = 50 s;  = 2 %. 0 200 (1) VDS = 50 V (2) VDS = 48 V (2) VDS = 48 V (3) VDS = 46 V (3) VDS = 46 V (4) VDS = 44 V (4) VDS = 44 V (5) VDS = 42 V (5) VDS = 42 V Power gain as a function of output power; typical values BLA6H0912L-1000_0912LS-1000#5 Product data sheet 600 800 1000 PL (W) 1200 IDq = 200 mA; tp = 50 s;  = 2 %. (1) VDS = 50 V Fig 9. 400 Fig 10. Drain efficiency as a function of output power; typical values All information provided in this document is subject to legal disclaimers. Rev. 5 — 1 September 2015 © Ampleon The Netherlands B.V. 2015. All rights reserved. 7 of 13 BLA6H0912L(S)-1000 LDMOS avionics power transistor 8. Package outline Flanged balanced ceramic package; 2 mounting holes; 4 leads SOT539A D A F D1 U1 B q C w2 M C M H1 1 c 2 E1 p H U2 5 L 3 A E w1 M A M B M 4 w3 M b Q e 0 5 10 mm scale DIMENSIONS (millimetre dimensions are derived from the original inch dimensions) UNIT A mm 4.7 4.2 inches b c D D1 e E E1 11.81 0.18 31.55 31.52 9.50 13.72 11.56 0.10 30.94 30.96 9.30 9.53 9.27 F H H1 L 1.75 17.12 25.53 3.48 1.50 16.10 25.27 2.97 p Q q 3.30 3.05 2.26 2.01 35.56 U1 U2 w1 41.28 10.29 0.25 41.02 10.03 w2 w3 0.51 0.25 0.185 0.465 0.007 1.242 1.241 0.374 0.375 0.069 0.674 1.005 0.137 0.130 0.089 1.625 0.405 1.400 0.010 0.020 0.010 0.540 0.165 0.455 0.004 1.218 1.219 0.366 0.365 0.059 0.634 0.995 0.117 0.120 0.079 1.615 0.395 Note 1. millimeter dimensions are derived from the original inch dimensions. 2. recommended screw pitch dimension of 1.52 inch (38.6 mm) based on M3 screw. OUTLINE VERSION REFERENCES IEC JEDEC EIAJ EUROPEAN PROJECTION ISSUE DATE 10-02-02 12-05-02 SOT539A Fig 11. Package outline SOT539A BLA6H0912L-1000_0912LS-1000#5 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 5 — 1 September 2015 © Ampleon The Netherlands B.V. 2015. All rights reserved. 8 of 13 BLA6H0912L(S)-1000 LDMOS avionics power transistor Earless flanged balanced ceramic package; 4 leads SOT539B D A F 5 D1 D U1 H1 w2 1 c D 2 E1 U2 H E L 3 4 w3 b Q e 0 5 10 mm scale Dimensions Unit(1) A b 4.7 11.81 w2 w3 0.25 0.25 max 0.185 0.465 0.007 1.242 1.241 0.374 0.375 0.069 0.674 1.005 0.137 0.089 1.275 0.405 0.54 inches nom 0.01 min 0.165 0.455 0.004 1.218 1.219 0.366 0.365 0.059 0.634 0.995 0.117 0.079 1.265 0.395 0.01 mm max nom min c D D1 0.18 31.55 31.52 E E1 9.5 9.53 e F H H1 L Q U1 U2 1.75 17.12 25.53 3.48 2.26 32.39 10.29 1.50 16.10 25.27 2.97 2.01 32.13 10.03 13.72 4.2 11.56 0.10 30.94 30.96 9.3 9.27 Note 1. millimeter dimensions are derived from the original inch dimensions. Outline version References IEC JEDEC JEITA sot539b_po European projection Issue date 12-05-02 13-05-24 SOT539B Fig 12. Package outline SOT539B BLA6H0912L-1000_0912LS-1000#5 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 5 — 1 September 2015 © Ampleon The Netherlands B.V. 2015. All rights reserved. 9 of 13 BLA6H0912L(S)-1000 LDMOS avionics power transistor 9. Handling information CAUTION This device is sensitive to ElectroStatic Discharge (ESD). Observe precautions for handling electrostatic sensitive devices. Such precautions are described in the ANSI/ESD S20.20, IEC/ST 61340-5, JESD625-A or equivalent standards. 10. Abbreviations Table 10. Abbreviations Acronym Description CW Continuous Wave DME Distance Measuring Equipment ESD ElectroStatic Discharge JTIDS Joint Tactical Information Distribution System LDMOS Laterally Diffused Metal-Oxide Semiconductor Mode-S Mode Select MTF Median Time to Failure SMD Surface Mounted Device TACAN TACtical Air Navigation TCAS Traffic Collision Avoidance System VSWR Voltage Standing-Wave Ratio 11. Revision history Table 11. Revision history Document ID Release date Data sheet status Change notice Supersedes BLA6H0912L-1000_0912LS-1000#5 20150901 Product data sheet - BLA6H0912L-1000_ 0912LS-1000 v.4 Modifications • The format of this document has been redesigned to comply with the new identity guidelines of Ampleon. • Legal texts have been adapted to the new company name where appropriate. BLA6H0912L-1000_0912LS-1000 v.4 20150702 Product data sheet - BLA6H0912L-1000_ 0912LS-1000 v.3 BLA6H0912L-1000_0912LS-1000 v.3 20150615 Product data sheet - BLA6H0912L-1000_ 0912LS-1000 v.2 BLA6H0912L-1000_0912LS-1000 v.2 20140210 Objective data sheet - BLA6H0912L-1000_ 0912LS-1000 v.1 BLA6H0912L-1000_0912LS-1000 v.1 20131104 Objective data sheet - - BLA6H0912L-1000_0912LS-1000#5 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 5 — 1 September 2015 © Ampleon The Netherlands B.V. 2015. All rights reserved. 10 of 13 BLA6H0912L(S)-1000 LDMOS avionics power transistor 12. Legal information 12.1 Data sheet status Document status[1][2] Product status[3] Objective [short] data sheet Development This document contains data from the objective specification for product development. Preliminary [short] data sheet Qualification This document contains data from the preliminary specification. Product [short] data sheet Production This document contains the product specification. Definition [1] Please consult the most recently issued document before initiating or completing a design. [2] The term ‘short data sheet’ is explained in section “Definitions”. [3] The product status of device(s) described in this document may have changed since this document was published and may differ in case of multiple devices. The latest product status information is available on the Internet at URL http://www.ampleon.com. 12.2 Definitions Draft — The document is a draft version only. The content is still under internal review and subject to formal approval, which may result in modifications or additions. Ampleon does not give any representations or warranties as to the accuracy or completeness of information included herein and shall have no liability for the consequences of use of such information. Short data sheet — A short data sheet is an extract from a full data sheet with the same product type number(s) and title. A short data sheet is intended for quick reference only and should not be relied upon to contain detailed and full information. For detailed and full information see the relevant full data sheet, which is available on request via the local Ampleon sales office. In case of any inconsistency or conflict with the short data sheet, the full data sheet shall prevail. Product specification — The information and data provided in a Product data sheet shall define the specification of the product as agreed between Ampleon and its customer, unless Ampleon and customer have explicitly agreed otherwise in writing. In no event however, shall an agreement be valid in which the Ampleon product is deemed to offer functions and qualities beyond those described in the Product data sheet. 12.3 Disclaimers Limited warranty and liability — Information in this document is believed to be accurate and reliable. However, Ampleon does not give any representations or warranties, expressed or implied, as to the accuracy or completeness of such information and shall have no liability for the consequences of use of such information. Ampleon takes no responsibility for the content in this document if provided by an information source outside of Ampleon. In no event shall Ampleon be liable for any indirect, incidental, punitive, special or consequential damages (including - without limitation - lost profits, lost savings, business interruption, costs related to the removal or replacement of any products or rework charges) whether or not such damages are based on tort (including negligence), warranty, breach of contract or any other legal theory. Notwithstanding any damages that customer might incur for any reason whatsoever, Ampleon’ aggregate and cumulative liability towards customer for the products described herein shall be limited in accordance with the Terms and conditions of commercial sale of Ampleon. Right to make changes — Ampleon reserves the right to make changes to information published in this document, including without limitation specifications and product descriptions, at any time and without notice. This document supersedes and replaces all information supplied prior to the publication hereof. Suitability for use — Ampleon products are not designed, authorized or warranted to be suitable for use in life support, life-critical or safety-critical systems or equipment, nor in applications where failure or malfunction of an BLA6H0912L-1000_0912LS-1000#5 Product data sheet Ampleon product can reasonably be expected to result in personal injury, death or severe property or environmental damage. Ampleon and its suppliers accept no liability for inclusion and/or use of Ampleon products in such equipment or applications and therefore such inclusion and/or use is at the customer’s own risk. Applications — Applications that are described herein for any of these products are for illustrative purposes only. Ampleon makes no representation or warranty that such applications will be suitable for the specified use without further testing or modification. Customers are responsible for the design and operation of their applications and products using Ampleon products, and Ampleon accepts no liability for any assistance with applications or customer product design. It is customer’s sole responsibility to determine whether the Ampleon product is suitable and fit for the customer’s applications and products planned, as well as for the planned application and use of customer’s third party customer(s). Customers should provide appropriate design and operating safeguards to minimize the risks associated with their applications and products. Ampleon does not accept any liability related to any default, damage, costs or problem which is based on any weakness or default in the customer’s applications or products, or the application or use by customer’s third party customer(s). Customer is responsible for doing all necessary testing for the customer’s applications and products using Ampleon products in order to avoid a default of the applications and the products or of the application or use by customer’s third party customer(s). Ampleon does not accept any liability in this respect. Limiting values — Stress above one or more limiting values (as defined in the Absolute Maximum Ratings System of IEC 60134) will cause permanent damage to the device. Limiting values are stress ratings only and (proper) operation of the device at these or any other conditions above those given in the Recommended operating conditions section (if present) or the Characteristics sections of this document is not warranted. Constant or repeated exposure to limiting values will permanently and irreversibly affect the quality and reliability of the device. Terms and conditions of commercial sale — Ampleon products are sold subject to the general terms and conditions of commercial sale, as published at http://www.ampleon.com/terms, unless otherwise agreed in a valid written individual agreement. In case an individual agreement is concluded only the terms and conditions of the respective agreement shall apply. Ampleon hereby expressly objects to applying the customer’s general terms and conditions with regard to the purchase of Ampleon products by customer. No offer to sell or license — Nothing in this document may be interpreted or construed as an offer to sell products that is open for acceptance or the grant, conveyance or implication of any license under any copyrights, patents or other industrial or intellectual property rights. Export control — This document as well as the item(s) described herein may be subject to export control regulations. Export might require a prior authorization from competent authorities. All information provided in this document is subject to legal disclaimers. Rev. 5 — 1 September 2015 © Ampleon The Netherlands B.V. 2015. All rights reserved. 11 of 13 BLA6H0912L(S)-1000 LDMOS avionics power transistor Non-automotive qualified products — Unless this data sheet expressly states that this specific Ampleon product is automotive qualified, the product is not suitable for automotive use. It is neither qualified nor tested in accordance with automotive testing or application requirements. Ampleon accepts no liability for inclusion and/or use of non-automotive qualified products in automotive equipment or applications. In the event that customer uses the product for design-in and use in automotive applications to automotive specifications and standards, customer (a) shall use the product without Ampleon’ warranty of the product for such automotive applications, use and specifications, and (b) whenever customer uses the product for automotive applications beyond Ampleon’ specifications such use shall be solely at customer’s own risk, and (c) customer fully indemnifies Ampleon for any liability, damages or failed product claims resulting from customer design and use of the product for automotive applications beyond Ampleon’ standard warranty and Ampleon’ product specifications. 12.4 Trademarks Notice: All referenced brands, product names, service names and trademarks are the property of their respective owners. Any reference or use of any ‘NXP’ trademark in this document or in or on the surface of Ampleon products does not result in any claim, liability or entitlement vis-à-vis the owner of this trademark. Ampleon is no longer part of the NXP group of companies and any reference to or use of the ‘NXP’ trademarks will be replaced by reference to or use of Ampleon’s own Any reference or use of any ‘NXP’ trademark in this document or in or on the surface of Ampleon products does not result in any claim, liability or entitlement vis-à-vis the owner of this trademark. Ampleon is no longer part of the NXP group of companies and any reference to or use of the ‘NXP’ trademarks will be replaced by reference to or use of Ampleon’s own trademarks. Translations — A non-English (translated) version of a document is for reference only. The English version shall prevail in case of any discrepancy between the translated and English versions. 13. Contact information For more information, please visit: http://www.ampleon.com BLA6H0912L-1000_0912LS-1000#5 Product data sheet For sales office addresses, please visit: http://www.ampleon.com/sales All information provided in this document is subject to legal disclaimers. Rev. 5 — 1 September 2015 © Ampleon The Netherlands B.V. 2015. All rights reserved. 12 of 13 BLA6H0912L(S)-1000 LDMOS avionics power transistor 14. Contents 1 1.1 1.2 1.3 2 3 4 5 6 7 7.1 7.2 7.3 7.4 7.4.1 8 9 10 11 12 12.1 12.2 12.3 12.4 13 14 Product profile . . . . . . . . . . . . . . . . . . . . . . . . . . 1 General description . . . . . . . . . . . . . . . . . . . . . 1 Features and benefits . . . . . . . . . . . . . . . . . . . . 1 Applications . . . . . . . . . . . . . . . . . . . . . . . . . . . 1 Pinning information . . . . . . . . . . . . . . . . . . . . . . 2 Ordering information . . . . . . . . . . . . . . . . . . . . . 2 Limiting values. . . . . . . . . . . . . . . . . . . . . . . . . . 2 Thermal characteristics . . . . . . . . . . . . . . . . . . 3 Characteristics . . . . . . . . . . . . . . . . . . . . . . . . . . 3 Test information . . . . . . . . . . . . . . . . . . . . . . . . . 3 Ruggedness in class-AB operation . . . . . . . . . 3 Impedance information . . . . . . . . . . . . . . . . . . . 4 Circuit information. . . . . . . . . . . . . . . . . . . . . . . 5 Graphical data . . . . . . . . . . . . . . . . . . . . . . . . . 6 Pulsed CW . . . . . . . . . . . . . . . . . . . . . . . . . . . . 6 Package outline . . . . . . . . . . . . . . . . . . . . . . . . . 8 Handling information. . . . . . . . . . . . . . . . . . . . 10 Abbreviations . . . . . . . . . . . . . . . . . . . . . . . . . . 10 Revision history . . . . . . . . . . . . . . . . . . . . . . . . 10 Legal information. . . . . . . . . . . . . . . . . . . . . . . 11 Data sheet status . . . . . . . . . . . . . . . . . . . . . . 11 Definitions . . . . . . . . . . . . . . . . . . . . . . . . . . . . 11 Disclaimers . . . . . . . . . . . . . . . . . . . . . . . . . . . 11 Trademarks. . . . . . . . . . . . . . . . . . . . . . . . . . . 12 Contact information. . . . . . . . . . . . . . . . . . . . . 12 Contents . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 13 Please be aware that important notices concerning this document and the product(s) described herein, have been included in section ‘Legal information’. © Ampleon The Netherlands B.V. 2015. All rights reserved. For more information, please visit: http://www.ampleon.com For sales office addresses, please visit: http://www.ampleon.com/sales Date of release: 1 September 2015 Document identifier: BLA6H0912L-1000_0912LS-1000#5
BLA6H0912L-1000U
物料型号: - BLA6H0912L-1000 - BLA6H0912LS-1000
器件简介: - 这是一款1000W LDMOS脉冲功率晶体管,适用于960 MHz至1215 MHz频段的航空电子发射机,如Mode-S、TCAS、JTIDS、DME和TACAN。 - 具有易于控制的功率、集成的ESD保护、高灵活性、卓越的坚固性、高效率和优秀的热稳定性。
引脚分配: - BLA6H0912L-1000 (SOT539A)和BLA6H0912LS-1000 (SOT539B)的引脚如下: - 1: drain1 - 2: drain2 - 3: gate1 - 4: gate2 - 5: source
参数特性: - 绝对最大额定值包括漏源电压(Vps)最高100V,栅源电压(VGs)0.5V至+13V,存储温度(Tstg)65至+150℃,结温(T)最高225℃。 - 热特性包括瞬态热阻抗(Zth(j-c))在不同条件下的值,例如在80°C的Tcase和1000W的PL下,50秒的t为0.011 K/W。 - DC特性包括漏源击穿电压(V(BR)DSS)、栅源阈值电压(VGS(th))、漏极漏电流(lpss)和漏极截止电流(lpsx)等。 - RF特性在1030 MHz频率下,包括漏源电压(Vps)、功率增益(Gp)、输入回波损耗(RLin)、漏极效率(nD)和脉冲下降功率(P droop(pulse))。
功能详解: - 该晶体管设计用于宽带操作,内部匹配以便于使用,并符合有害物质限制指令(RoHS)。
应用信息: - 适用于Mode-S、TCAS、JTIDS、DME和TACAN等应用。
封装信息: - BLA6H0912L-1000采用带法兰平衡陶瓷封装,有2个安装孔和4个引脚,型号为SOT539A。 - BLA6H0912LS-1000采用无耳带法兰平衡陶瓷封装,4个引脚,型号为SOT539B。
BLA6H0912L-1000U 价格&库存
很抱歉,暂时无法提供与“BLA6H0912L-1000U”相匹配的价格&库存,您可以联系我们找货
