BLF7G24LS-100,112
BLF7G24LS-100,112
    AMPLEON(安谱隆)
    SOT502B
    BLF7G24LS-100,112
BLF7G24LS-100,112 数据手册
BLF7G24L-100; BLF7G24LS-100 Power LDMOS transistor Rev. 5 — 1 September 2015 Product data sheet 1. Product profile 1.1 General description 100 W LDMOS power transistor for base station applications at frequencies from 2300 MHz to 2400 MHz. Table 1. Typical performance Typical RF performance at Tcase = 25 C in a common source class-AB production test circuit. IDq VDS PL(AV) Gp D ACPR885k ACPR5M (MHz) (mA) (V) (W) (dB) (%) (dBc) (dBc) IS-95 2300 to 2400 900 28 20 18 27 46[1] - 1 carrier W-CDMA 2300 to 2400 900 28 30 18.7 33 - 40[2] Mode of operation f [1] Single carrier IS-95 with pilot, paging, sync and 6 traffic channels (Walsh codes 8 - 13). PAR = 9.7 dB at 0.01 % probability on the CCDF. Channel bandwidth is 1.2288 MHz. [2] 3GPP; test model 1; 64 DPCH; PAR = 7.2 dB at 0.01 % probability on CCDF. Channel bandwidth is 3.84 MHz. 1.2 Features and benefits        Excellent ruggedness High efficiency Low Rth providing excellent thermal stability Designed for low memory effects providing excellent digital pre-distortion capability Internally matched for ease of use Integrated ESD protection Compliant to Restriction of Hazardous Substances (RoHS) Directive 2002/95/EC 1.3 Applications  RF power amplifiers for base stations and multi carrier applications in the 2300 MHz to 2400 MHz frequency range BLF7G24L-100; BLF7G24LS-100 Power LDMOS transistor 2. Pinning information Table 2. Pinning Pin Description Simplified outline Graphic symbol BLF7G24L-100 (SOT502A) 1 drain 2 gate 3 source 1 1 3 [1] 2 2 3 sym112 BLF7G24LS-100 (SOT502B) 1 drain 2 gate 3 source 1 1 3 [1] 2 2 3 sym112 [1] Connected to flange. 3. Ordering information Table 3. Ordering information Type number Package Name Description Version BLF7G24L-100 - flanged LDMOST ceramic package; 2 mounting holes; 2 leads SOT502A BLF7G24LS-100 - earless flanged LDMOST ceramic package; 2 leads SOT502B 4. Limiting values Table 4. Limiting values In accordance with the Absolute Maximum Rating System (IEC 60134). Symbol Parameter Min Max Unit VDS drain-source voltage Conditions - 65 V VGS gate-source voltage 0.5 +13 V ID drain current - 28 A Tstg storage temperature 65 +150 C Tj junction temperature - 200 C 5. Thermal characteristics Table 5. Thermal characteristics Symbol Parameter Conditions Typ Unit Rth(j-c) thermal resistance from junction to case Tcase = 80 C; PL = 100 W 0.3 K/W BLF7G24L-100_7G24LS-100#5 All information provided in this document is subject to legal disclaimers. Product data sheet Rev. 5 — 1 September 2015 © Ampleon The Netherlands B.V. 2015. All rights reserved. 2 of 14 BLF7G24L-100; BLF7G24LS-100 Power LDMOS transistor 6. Characteristics Table 6. Characteristics Tj = 25 C unless otherwise specified. Symbol Parameter Conditions Min Typ Max Unit V(BR)DSS drain-source breakdown voltage VGS = 0 V; ID = 1 mA 65 - - V VGS(th) gate-source threshold voltage VDS = 10 V; ID = 150 mA 1.5 1.8 2.3 V IDSS drain leakage current VGS = 0 V; VDS = 28 V - - 5 A IDSX drain cut-off current VGS = VGS(th) + 3.75 V; VDS = 10 V 25.1 29 - A IGSS gate leakage current VGS = 11 V; VDS = 0 V - - 500 nA gfs forward transconductance VDS = 10 V; ID = 5.35 A - 10.5 - S RDS(on) drain-source on-state resistance VGS = VGS(th) + 3.75 V; ID = 5.25 A - 0.1  - 7. Test information Remark: All testing performed in a class-AB production test circuit. Table 7. Functional test information Mode of operation: 1-carrier N-CDMA, single carrier IS-95 with pilot, paging, sync and 6 traffic channels (Walsh codes 8 - 13). PAR = 9.7 dB at 0.01 % probability on the CCDF, channel bandwidth is 1.2288 MHz; f1 = 2300 MHz; f2 = 2400 MHz; RF performance at VDS = 28 V; IDq = 900 mA; Tcase = 25 C; unless otherwise specified. Symbol Parameter Conditions Min Typ Max Unit PL(AV) average output power - 20 - W Gp power gain 17.3 18 - dB RLin input return loss - 14 - dB D drain efficiency 22 27 % ACPR885k adjacent channel power ratio (885 kHz) - 46 40 - dBc 7.1 Ruggedness in class-AB operation The BLF7G24L-100 and BLF7G24LS-100 are capable of withstanding a load mismatch corresponding to VSWR = 10 : 1 through all phases under the following conditions: VDS = 28 V; IDq = 900 mA; PL = 100 W (CW); f = 2300 MHz. BLF7G24L-100_7G24LS-100#5 All information provided in this document is subject to legal disclaimers. Product data sheet Rev. 5 — 1 September 2015 © Ampleon The Netherlands B.V. 2015. All rights reserved. 3 of 14 BLF7G24L-100; BLF7G24LS-100 Power LDMOS transistor 7.2 Single carrier IS-95 Single carrier IS-95 with pilot, paging, sync and 6 traffic channels (Walsh codes 8 - 13). PAR = 9.7 dB at 0.01 % probability on the CCDF. Channel bandwidth is 1.2288 MHz. 001aan495 19.5 ηD (%) (2) Gp (dB) 001aan496 50 (1) 40 (2) (1) 18.5 30 20 17.5 10 0 16.5 0 20 40 60 80 0 20 40 60 PL (W) VDS = 28 V; IDq = 900 mA. VDS = 28 V; IDq = 900 mA. (1) f = 2300 MHz (1) f = 2300 MHz (2) f = 2400 MHz Fig 1. 80 PL (W) (2) f = 2400 MHz Single carrier IS-95 power gain as a function of load power; typical values Fig 2. 001aan497 -20 APCR885k (dBc) Single carrier IS-95 drain efficiency as a function of load power; typical values 001aan498 -30 APCR1980k (dBc) -30 -40 (2) -40 -50 (2) (1) (1) -50 -60 -60 -70 -70 0 20 40 60 PL (W) -80 80 VDS = 28 V; IDq = 900 mA. 0 20 60 PL (W) 80 VDS = 28 V; IDq = 900 mA. (1) f = 2300 MHz (1) f = 2300 MHz (2) f = 2400 MHz (2) f = 2400 MHz Fig 3. 40 Single carrier IS-95 ACPR at 885 kHz as a function of load power; typical values Fig 4. Single carrier IS-95 ACPR at 1980 kHz as a function of load power; typical values BLF7G24L-100_7G24LS-100#5 All information provided in this document is subject to legal disclaimers. Product data sheet Rev. 5 — 1 September 2015 © Ampleon The Netherlands B.V. 2015. All rights reserved. 4 of 14 BLF7G24L-100; BLF7G24LS-100 Power LDMOS transistor 001aan499 12 001aan500 200 PL(M) (W) PAR (dB) (1) 160 (2) 8 120 (1) 80 4 (2) 40 0 0 0 20 40 60 80 0 20 40 PL (W) 80 PL (W) VDS = 28 V; IDq = 900 mA. VDS = 28 V; IDq = 900 mA. (1) f = 2300 MHz (1) f = 2300 MHz (2) f = 2400 MHz (2) f = 2400 MHz Fig 5. 60 Single carrier IS-95 peak-to-average power ratio as a function of load power; typical values Fig 6. Single carrier IS-95 peak power as a function of load power; typical values BLF7G24L-100_7G24LS-100#5 All information provided in this document is subject to legal disclaimers. Product data sheet Rev. 5 — 1 September 2015 © Ampleon The Netherlands B.V. 2015. All rights reserved. 5 of 14 BLF7G24L-100; BLF7G24LS-100 Power LDMOS transistor 7.3 Pulsed CW 001aan501 19.5 ηD (%) (2) Gp (dB) 001aan502 60 50 (2) (1) 18.5 (1) 40 30 17.5 20 10 16.5 0 40 80 120 160 0 40 80 PL (W) 160 PL (W) VDS = 28 V; IDq = 900 mA. VDS = 28 V; IDq = 900 mA. (1) f = 2300 MHz (1) f = 2300 MHz (2) f = 2400 MHz (2) f = 2400 MHz Fig 7. 120 Pulsed CW power gain as a function of load power; typical values Fig 8. Pulsed CW drain efficiency as a function of load power; typical values BLF7G24L-100_7G24LS-100#5 All information provided in this document is subject to legal disclaimers. Product data sheet Rev. 5 — 1 September 2015 © Ampleon The Netherlands B.V. 2015. All rights reserved. 6 of 14 BLF7G24L-100; BLF7G24LS-100 Power LDMOS transistor 7.4 Single carrier W-CDMA 3GPP; test model 1; 64 DPCH; PAR = 7.2 dB at 0.01 % probability on CCDF. Channel bandwidth is 3.84 MHz. 001aan503 19.5 001aan504 60 ηD (%) Gp (dB) 50 (2) 18.5 40 (1) (1) (2) 30 17.5 20 10 16.5 0 20 40 60 80 100 PL (W) 0 VDS = 28 V; IDq = 900 mA. 40 60 80 100 PL (W) VDS = 28 V; IDq = 900 mA. (1) f = 2300 MHz (1) f = 2300 MHz (2) f = 2400 MHz Fig 9. 20 (2) f = 2400 MHz Single carrier W-CDMA power gain as a function of load power; typical values 001aan505 −10 Fig 10. Single carrier W-CDMA drain efficiency as a function of load power; typical values APCR5M (dBc) APCR10M (dBc) −20 −30 −30 001aan506 −20 −40 (2) (2) (1) −40 −50 (1) −50 −60 −60 0 20 40 60 80 100 PL (W) VDS = 28 V; IDq = 900 mA. −70 0 20 40 60 80 100 PL (W) VDS = 28 V; IDq = 900 mA. (1) f = 2300 MHz (1) f = 2300 MHz (2) f = 2400 MHz (2) f = 2400 MHz Fig 11. Single carrier W-CDMA ACPR at 5 MHz as a function of load power; typical values Fig 12. Single carrier W-CDMA ACPR at 10 MHz as a function of load power; typical values BLF7G24L-100_7G24LS-100#5 All information provided in this document is subject to legal disclaimers. Product data sheet Rev. 5 — 1 September 2015 © Ampleon The Netherlands B.V. 2015. All rights reserved. 7 of 14 BLF7G24L-100; BLF7G24LS-100 Power LDMOS transistor 001aan507 8 001aan508 250 PL(M) (W) PAR (dB) 200 6 (1) (1) 150 (2) (2) 4 100 2 50 0 0 0 20 40 60 80 100 PL (W) VDS = 28 V; IDq = 900 mA. 0 20 40 60 80 100 PL (W) VDS = 28 V; IDq = 900 mA. (1) f = 2300 MHz (1) f = 2300 MHz (2) f = 2400 MHz (2) f = 2400 MHz Fig 13. Single carrier W-CDMA peak-to-average power ratio as a function of load power; typical values Fig 14. Single carrier W-CDMA peak output power as a function of load power; typical values BLF7G24L-100_7G24LS-100#5 All information provided in this document is subject to legal disclaimers. Product data sheet Rev. 5 — 1 September 2015 © Ampleon The Netherlands B.V. 2015. All rights reserved. 8 of 14 BLF7G24L-100; BLF7G24LS-100 Power LDMOS transistor 8. Package outline Flanged ceramic package; 2 mounting holes; 2 leads SOT502A D A F 3 D1 U1 B q c C 1 H L E1 p U2 E w1 M A M B M A 2 w2 M C M b 0 5 Q 10 mm scale DIMENSIONS (millimetre dimensions are derived from the original inch dimensions) UNIT A b c mm 4.72 3.43 12.83 12.57 0.15 0.08 inches 0.186 0.135 0.505 0.006 0.495 0.003 OUTLINE VERSION D E E1 F H L p Q q U1 U2 w1 w2 20.02 19.96 19.61 19.66 9.50 9.30 9.53 9.25 1.14 0.89 19.94 18.92 5.33 4.32 3.38 3.12 1.70 1.45 27.94 34.16 33.91 9.91 9.65 0.25 0.51 0.788 0.786 0.772 0.774 0.374 0.375 0.366 0.364 0.067 1.100 0.057 1.345 1.335 0.390 0.380 0.01 0.02 D1 0.045 0.785 0.035 0.745 0.210 0.133 0.170 0.123 REFERENCES IEC JEDEC JEITA EUROPEAN PROJECTION ISSUE DATE 03-01-10 12-05-02 SOT502A Fig 15. Package outline SOT502A BLF7G24L-100_7G24LS-100#5 All information provided in this document is subject to legal disclaimers. Product data sheet Rev. 5 — 1 September 2015 © Ampleon The Netherlands B.V. 2015. All rights reserved. 9 of 14 BLF7G24L-100; BLF7G24LS-100 Power LDMOS transistor Earless flanged ceramic package; 2 leads SOT502B D A F 3 D D1 c U1 1 L H E1 U2 E 2 w2 M D M b 0 5 Q 10 mm scale DIMENSIONS (millimetre dimensions are derived from the original inch dimensions) UNIT A b c mm 4.72 3.43 12.83 12.57 0.15 0.08 inches 0.186 0.135 0.505 0.006 0.495 0.003 OUTLINE VERSION D E E1 F H L Q U1 U2 w2 20.02 19.96 19.61 19.66 9.50 9.30 9.53 9.25 1.14 0.89 19.94 18.92 5.33 4.32 1.70 1.45 20.70 20.45 9.91 9.65 0.25 0.788 0.786 0.772 0.774 0.374 0.375 0.366 0.364 0.045 0.785 0.035 0.745 0.210 0.170 0.067 0.815 0.057 0.805 D1 REFERENCES IEC JEDEC JEITA 0.390 0.010 0.380 EUROPEAN PROJECTION ISSUE DATE 07-05-09 12-05-02 SOT502B Fig 16. Package outline SOT502B BLF7G24L-100_7G24LS-100#5 All information provided in this document is subject to legal disclaimers. Product data sheet Rev. 5 — 1 September 2015 © Ampleon The Netherlands B.V. 2015. All rights reserved. 10 of 14 BLF7G24L-100; BLF7G24LS-100 Power LDMOS transistor 9. Abbreviations Table 8. Abbreviations Acronym Description 3GPP Third Generation Partnership Project CCDF Complementary Cumulative Distribution Function CW Continuous Wave DPCH Dedicated Physical CHannel IS-95 Interim Standard 95 ESD ElectroStatic Discharge LDMOS Laterally Diffused Metal Oxide Semiconductor LDMOST Laterally Diffused Metal Oxide Semiconductor Transistor N-CDMA Narrowband Code Division Multiple Access PAR Peak-to-Average power Ratio RF Radio Frequency VSWR Voltage Standing Wave Ratio W-CDMA Wideband Code Division Multiple Access 10. Revision history Table 9. Revision history Document ID Release date Data sheet status BLF7G24L-100_7G24LS-100 v.5 20150901 Modifications: Product data sheet Change notice Supersedes - BLF7G24L-100_7G24LS-100 v.4 • The format of this document has been redesigned to comply with the new identity guidelines of Ampleon. • Legal texts have been adapted to the new company name where appropriate. BLF7G24L-100_7G24LS-100 v.4 20110722 Product data sheet - BLF7G24L-100_7G24LS-100 v.3 BLF7G24L-100_7G24LS-100 v.3 20110405 Preliminary data sheet - BLF7G24L-100_7G24LS-100 v.2 BLF7G24L-100_7G24LS-100 v.2 20100714 Objective data sheet - BLF7G24L-100_7G24LS-100 v.1 BLF7G24L-100_7G24LS-100 v.1 20100414 Objective data sheet - - BLF7G24L-100_7G24LS-100#5 All information provided in this document is subject to legal disclaimers. Product data sheet Rev. 5 — 1 September 2015 © Ampleon The Netherlands B.V. 2015. All rights reserved. 11 of 14 BLF7G24L-100; BLF7G24LS-100 Power LDMOS transistor 11. Legal information 11.1 Data sheet status Document status[1][2] Product status[3] Objective [short] data sheet Development This document contains data from the objective specification for product development. Preliminary [short] data sheet Qualification This document contains data from the preliminary specification. Product [short] data sheet Production This document contains the product specification. Definition [1] Please consult the most recently issued document before initiating or completing a design. [2] The term ‘short data sheet’ is explained in section “Definitions”. [3] The product status of device(s) described in this document may have changed since this document was published and may differ in case of multiple devices. The latest product status information is available on the Internet at URL http://www.ampleon.com. 11.2 Definitions Draft — The document is a draft version only. The content is still under internal review and subject to formal approval, which may result in modifications or additions. Ampleon does not give any representations or warranties as to the accuracy or completeness of information included herein and shall have no liability for the consequences of use of such information. Short data sheet — A short data sheet is an extract from a full data sheet with the same product type number(s) and title. A short data sheet is intended for quick reference only and should not be relied upon to contain detailed and full information. For detailed and full information see the relevant full data sheet, which is available on request via the local Ampleon sales office. In case of any inconsistency or conflict with the short data sheet, the full data sheet shall prevail. Product specification — The information and data provided in a Product data sheet shall define the specification of the product as agreed between Ampleon and its customer, unless Ampleon and customer have explicitly agreed otherwise in writing. In no event however, shall an agreement be valid in which the Ampleon product is deemed to offer functions and qualities beyond those described in the Product data sheet. 11.3 Disclaimers Limited warranty and liability — Information in this document is believed to be accurate and reliable. However, Ampleon does not give any representations or warranties, expressed or implied, as to the accuracy or completeness of such information and shall have no liability for the consequences of use of such information. Ampleon takes no responsibility for the content in this document if provided by an information source outside of Ampleon. In no event shall Ampleon be liable for any indirect, incidental, punitive, special or consequential damages (including - without limitation - lost profits, lost savings, business interruption, costs related to the removal or replacement of any products or rework charges) whether or not such damages are based on tort (including negligence), warranty, breach of contract or any other legal theory. Notwithstanding any damages that customer might incur for any reason whatsoever, Ampleon’ aggregate and cumulative liability towards customer for the products described herein shall be limited in accordance with the Terms and conditions of commercial sale of Ampleon. Right to make changes — Ampleon reserves the right to make changes to information published in this document, including without limitation specifications and product descriptions, at any time and without notice. This document supersedes and replaces all information supplied prior to the publication hereof. Suitability for use — Ampleon products are not designed, authorized or warranted to be suitable for use in life support, life-critical or safety-critical systems or equipment, nor in applications where failure or malfunction of an Ampleon product can reasonably be expected to result in personal injury, death or severe property or environmental damage. Ampleon and its suppliers accept no liability for inclusion and/or use of Ampleon products in such equipment or applications and therefore such inclusion and/or use is at the customer’s own risk. Applications — Applications that are described herein for any of these products are for illustrative purposes only. Ampleon makes no representation or warranty that such applications will be suitable for the specified use without further testing or modification. Customers are responsible for the design and operation of their applications and products using Ampleon products, and Ampleon accepts no liability for any assistance with applications or customer product design. It is customer’s sole responsibility to determine whether the Ampleon product is suitable and fit for the customer’s applications and products planned, as well as for the planned application and use of customer’s third party customer(s). Customers should provide appropriate design and operating safeguards to minimize the risks associated with their applications and products. Ampleon does not accept any liability related to any default, damage, costs or problem which is based on any weakness or default in the customer’s applications or products, or the application or use by customer’s third party customer(s). Customer is responsible for doing all necessary testing for the customer’s applications and products using Ampleon products in order to avoid a default of the applications and the products or of the application or use by customer’s third party customer(s). Ampleon does not accept any liability in this respect. Limiting values — Stress above one or more limiting values (as defined in the Absolute Maximum Ratings System of IEC 60134) will cause permanent damage to the device. Limiting values are stress ratings only and (proper) operation of the device at these or any other conditions above those given in the Recommended operating conditions section (if present) or the Characteristics sections of this document is not warranted. Constant or repeated exposure to limiting values will permanently and irreversibly affect the quality and reliability of the device. Terms and conditions of commercial sale — Ampleon products are sold subject to the general terms and conditions of commercial sale, as published at http://www.ampleon.com/terms, unless otherwise agreed in a valid written individual agreement. In case an individual agreement is concluded only the terms and conditions of the respective agreement shall apply. Ampleon hereby expressly objects to applying the customer’s general terms and conditions with regard to the purchase of Ampleon products by customer. No offer to sell or license — Nothing in this document may be interpreted or construed as an offer to sell products that is open for acceptance or the grant, conveyance or implication of any license under any copyrights, patents or other industrial or intellectual property rights. Export control — This document as well as the item(s) described herein may be subject to export control regulations. Export might require a prior authorization from competent authorities. BLF7G24L-100_7G24LS-100#5 All information provided in this document is subject to legal disclaimers. Product data sheet Rev. 5 — 1 September 2015 © Ampleon The Netherlands B.V. 2015. All rights reserved. 12 of 14 BLF7G24L-100; BLF7G24LS-100 Power LDMOS transistor Non-automotive qualified products — Unless this data sheet expressly states that this specific Ampleon product is automotive qualified, the product is not suitable for automotive use. It is neither qualified nor tested in accordance with automotive testing or application requirements. Ampleon accepts no liability for inclusion and/or use of non-automotive qualified products in automotive equipment or applications. In the event that customer uses the product for design-in and use in automotive applications to automotive specifications and standards, customer (a) shall use the product without Ampleon’ warranty of the product for such automotive applications, use and specifications, and (b) whenever customer uses the product for automotive applications beyond Ampleon’ specifications such use shall be solely at customer’s own risk, and (c) customer fully indemnifies Ampleon for any liability, damages or failed product claims resulting from customer design and use of the product for automotive applications beyond Ampleon’ standard warranty and Ampleon’ product specifications. 11.4 Trademarks Notice: All referenced brands, product names, service names and trademarks are the property of their respective owners. Any reference or use of any ‘NXP’ trademark in this document or in or on the surface of Ampleon products does not result in any claim, liability or entitlement vis-à-vis the owner of this trademark. Ampleon is no longer part of the NXP group of companies and any reference to or use of the ‘NXP’ trademarks will be replaced by reference to or use of Ampleon’s own Any reference or use of any ‘NXP’ trademark in this document or in or on the surface of Ampleon products does not result in any claim, liability or entitlement vis-à-vis the owner of this trademark. Ampleon is no longer part of the NXP group of companies and any reference to or use of the ‘NXP’ trademarks will be replaced by reference to or use of Ampleon’s own trademarks. 12. Contact information For more information, please visit: http://www.ampleon.com For sales office addresses, please visit: http://www.ampleon.com/sales BLF7G24L-100_7G24LS-100#5 All information provided in this document is subject to legal disclaimers. Product data sheet Rev. 5 — 1 September 2015 © Ampleon The Netherlands B.V. 2015. All rights reserved. 13 of 14 BLF7G24L-100; BLF7G24LS-100 Power LDMOS transistor 13. Contents 1 1.1 1.2 1.3 2 3 4 5 6 7 7.1 7.2 7.3 7.4 8 9 10 11 11.1 11.2 11.3 11.4 12 13 Product profile . . . . . . . . . . . . . . . . . . . . . . . . . . 1 General description . . . . . . . . . . . . . . . . . . . . . 1 Features and benefits . . . . . . . . . . . . . . . . . . . . 1 Applications . . . . . . . . . . . . . . . . . . . . . . . . . . . 1 Pinning information . . . . . . . . . . . . . . . . . . . . . . 2 Ordering information . . . . . . . . . . . . . . . . . . . . . 2 Limiting values. . . . . . . . . . . . . . . . . . . . . . . . . . 2 Thermal characteristics . . . . . . . . . . . . . . . . . . 2 Characteristics . . . . . . . . . . . . . . . . . . . . . . . . . . 3 Test information . . . . . . . . . . . . . . . . . . . . . . . . . 3 Ruggedness in class-AB operation . . . . . . . . . 3 Single carrier IS-95 . . . . . . . . . . . . . . . . . . . . . . 4 Pulsed CW . . . . . . . . . . . . . . . . . . . . . . . . . . . . 6 Single carrier W-CDMA. . . . . . . . . . . . . . . . . . . 7 Package outline . . . . . . . . . . . . . . . . . . . . . . . . . 9 Abbreviations . . . . . . . . . . . . . . . . . . . . . . . . . . 11 Revision history . . . . . . . . . . . . . . . . . . . . . . . . 11 Legal information. . . . . . . . . . . . . . . . . . . . . . . 12 Data sheet status . . . . . . . . . . . . . . . . . . . . . . 12 Definitions . . . . . . . . . . . . . . . . . . . . . . . . . . . . 12 Disclaimers . . . . . . . . . . . . . . . . . . . . . . . . . . . 12 Trademarks. . . . . . . . . . . . . . . . . . . . . . . . . . . 13 Contact information. . . . . . . . . . . . . . . . . . . . . 13 Contents . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 14 Please be aware that important notices concerning this document and the product(s) described herein, have been included in section ‘Legal information’. © Ampleon The Netherlands B.V. 2015. All rights reserved. For more information, please visit: http://www.ampleon.com For sales office addresses, please visit: http://www.ampleon.com/sales Date of release: 1 September 2015 Document identifier: BLF7G24L-100_7G24LS-100#5
BLF7G24LS-100,112 价格&库存
很抱歉,暂时无法提供与“BLF7G24LS-100,112”相匹配的价格&库存,您可以联系我们找货
