BLP05H675XRY
BLP05H675XRY
    AMPLEON(安谱隆)
    SOT-1223-2
    BLP05H675XRY
BLP05H675XRY 数据手册
BLP05H675XR; BLP05H675XRG Power LDMOS transistor Rev. 4 — 1 September 2016 Product data sheet 1. Product profile 1.1 General description A 75 W extremely rugged LDMOS power transistor for broadcast and industrial applications in the HF to 600 MHz band. Table 1. Application information Test signal pulsed RF f VDS PL Gp D (MHz) (V) (W) (dB) (%) 108 50 75 27 75 1.2 Features and benefits        Easy power control Integrated double sided ESD protection Excellent ruggedness High efficiency Excellent thermal stability Designed for broadband operation (HF to 600 MHz) Compliant to Directive 2002/95/EC, regarding Restriction of Hazardous Substances (RoHS) 1.3 Applications  Industrial, scientific and medical applications  Broadcast transmitter applications BLP05H675XR; BLP05H675XRG Power LDMOS transistor 2. Pinning information Table 2. Pinning Pin Description Simplified outline Graphic symbol BLP05H675XR (SOT1223-2) 1 gate 2 2 gate 1 3 drain 1 4 drain 2 5 4 4 3 1 pin 1 index 5 2 [1] source 1 2 3 aaa-003574 BLP05H675XRG (SOT1224-2) 1 gate 2 2 gate 1 3 drain 1 4 drain 2 5 4 3 4 1 pin 1 index [1] source 5 2 1 2 3 aaa-003574 [1] Connected to flange. 3. Ordering information Table 3. Ordering information Type number Package Name Description Version BLP05H675XR HSOP4F plastic, heatsink small outline package; 4 leads (flat) SOT1223-2 BLP05H675XRG HSOP4F plastic, heatsink small outline package; 4 leads SOT1224-2 4. Limiting values Table 4. Limiting values In accordance with the Absolute Maximum Rating System (IEC 60134). Symbol Parameter VDS Min Max Unit drain-source voltage - 135 V VGS gate-source voltage 6 +11 V Tstg storage temperature 65 +150 C - 225 C Tj [1] BLP05H675XR_H675XRG Product data sheet Conditions junction temperature [1] Continuous use at maximum temperature will affect the reliability, for details refer to the online MTF calculator. All information provided in this document is subject to legal disclaimers. Rev. 4 — 1 September 2016 © Ampleon Netherlands B.V. 2016. All rights reserved. 2 of 16 BLP05H675XR; BLP05H675XRG Power LDMOS transistor 5. Thermal characteristics Table 5. Thermal characteristics Symbol Parameter Conditions Tj = 115 C Rth(j-c) thermal resistance from junction to case Zth(j-c) transient thermal impedance from junction Tj = 150 C; tp = 100 s; to case  = 20 % [1] Typ Unit [1][2] 1.09 K/W [3] 0.37 K/W Tj is the junction temperature. [2] Rth(j-c) is measured under RF conditions. [3] See Figure 1. aaa-020036 1.2 Zth(j-c) (K/W) 1 (7) (6) (5) (4) (3) (2) (1) 0.8 0.6 0.4 0.2 0 10-7 10-6 10-5 10-4 10-3 10-2 10-1 tp (s) 1 (1)  = 1 % (2)  = 2 % (3)  = 5 % (4)  = 10 % (5)  = 20 % (6)  = 50 % (7)  = 100 % (DC) Fig 1. Transient thermal impedance from junction to case as a function of pulse duration 6. Characteristics Table 6. DC characteristics Tj = 25 C; per section unless otherwise specified. Symbol Parameter Conditions Min Typ Max Unit 135 - - V VDS = 10 V; ID = 25 mA 1.25 1.8 2.25 V V(BR)DSS drain-source breakdown voltage VGS = 0 V; ID = 0.25 mA BLP05H675XR_H675XRG Product data sheet VGS(th) gate-source threshold voltage VGSq gate-source quiescent voltage VDS = 50 V; ID = 10 mA - 1.7 - V IDSS drain leakage current VGS = 0 V; VDS = 50 V - - 1.4 A All information provided in this document is subject to legal disclaimers. Rev. 4 — 1 September 2016 © Ampleon Netherlands B.V. 2016. All rights reserved. 3 of 16 BLP05H675XR; BLP05H675XRG Power LDMOS transistor Table 6. DC characteristics …continued Tj = 25 C; per section unless otherwise specified. Symbol Parameter Conditions Min Typ Max Unit IDSX drain cut-off current VGS = VGS(th) + 3.75 V; VDS = 10 V - 3.6 - A IGSS gate leakage current VGS = 11 V; VDS = 0 V - - 140 nA RDS(on) drain-source on-state resistance VGS = VGS(th) + 3.75 V; ID = 875 mA - 1.6 -  Table 7. AC characteristics Tj = 25 C; per section unless otherwise specified. Symbol Parameter Conditions Min Typ Max Unit Crs feedback capacitance VGS = 0 V; VDS = 50 V; f = 1 MHz - 0.25 - pF Ciss input capacitance VGS = 0 V; VDS = 50 V; f = 1 MHz - 31 - pF Coss output capacitance VGS = 0 V; VDS = 50 V; f = 1 MHz - 11 - pF Table 8. RF characteristics Test signal: pulsed RF; tp = 100 s;  = 20 %; f = 108 MHz; RF performance at VDS = 50 V; IDq = 20 mA; Tcase = 25 C; unless otherwise specified; in a class-AB production test circuit. Symbol Parameter Conditions Min Typ Max Unit Gp power gain PL = 75 W 25.5 27 - dB RLin input return loss PL = 75 W - 15 - dB D drain efficiency PL = 75 W 72 75 - % aaa-020037 60 Coss (pF) 50 40 30 20 10 0 0 10 20 30 40 50 VDS (V) 60 VGS = 0 V; f = 1 MHz. Fig 2. BLP05H675XR_H675XRG Product data sheet Output capacitance as a function of drain-source voltage; typical values per section All information provided in this document is subject to legal disclaimers. Rev. 4 — 1 September 2016 © Ampleon Netherlands B.V. 2016. All rights reserved. 4 of 16 BLP05H675XR; BLP05H675XRG Power LDMOS transistor 7. Test information 7.1 Ruggedness in class-AB operation The BLP05H675XR and BLP05H675XRG are capable of withstanding a load mismatch corresponding to VSWR > 65 : 1 through all phases under the following conditions: VDS = 50 V; IDq = 20 mA; PL = 75 W pulsed; f = 108 MHz. 7.2 Impedance information drain 1 gate 1 Zi ZL gate 2 drain 2 001aan207 Fig 3. Definition of transistor impedance Table 9. Typical push-pull impedance Simulated Zi and ZL device impedance; impedance info at VDS = 50 V and PL = 75 W. f Zi ZL (MHz) () () 108 29.6  j143.4 51.1 + j11.7 7.3 UIS avalanche energy Table 10. Typical avalanche data per section Tamb = 25 C; typical test data; test jig without water cooling. IAS EAS (A) (J) 2 0.13 2.5 0.1 3 0.08 For information see application note AN10273. BLP05H675XR_H675XRG Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 4 — 1 September 2016 © Ampleon Netherlands B.V. 2016. All rights reserved. 5 of 16 BLP05H675XR; BLP05H675XRG Power LDMOS transistor aaa-020038 200 EAS (mJ) 160 120 80 40 0 1.5 Fig 4. BLP05H675XR_H675XRG Product data sheet 1.75 2 2.25 2.5 2.75 3 3.25 IAS (A) 3.5 Non-repetitive avalanche energy as a function of single pulse avalanche current; typical values All information provided in this document is subject to legal disclaimers. Rev. 4 — 1 September 2016 © Ampleon Netherlands B.V. 2016. All rights reserved. 6 of 16 BLP05H675XR; BLP05H675XRG Power LDMOS transistor 7.4 Test circuit 200 mm C15 R5 R1 C5 L2 R2 C11 L1 C12 C6 R3 C13 R4 80 mm C1 C7 C2 C10 C3 C8 C4 C9 C14 aaa-020039 Printed-Circuit Board (PCB): RF-35; r = 3.5 F/m; thickness = 0.765 mm; thickness copper plating = 35 m. See Table 11 for a list of components. Fig 5. Component layout for class-AB production test circuit Table 11. List of components For test circuit see Figure 5. BLP05H675XR_H675XRG Product data sheet Component Description Value Remarks C1, C7 multilayer ceramic chip capacitor 470 pF ATC 800B C2 multilayer ceramic chip capacitor 82 pF ATC 800B C3 multilayer ceramic chip capacitor 270 pF ATC 800B C4 multilayer ceramic chip capacitor 22 pF ATC 800B C5 multilayer ceramic chip capacitor 1 F, 50 V GRM32RR71H105KA01L C6, C13 multilayer ceramic chip capacitor 820 pF ATC 800B C8, C9 multilayer ceramic chip capacitor 36 pF ATC 100A C10 multilayer ceramic chip capacitor 18 pF ATC 800B C11 multilayer ceramic chip capacitor 4.7 F, 100 V C5750X7RA475KT/A C12 multilayer ceramic chip capacitor 100 nF GRM188R72A104KA35D C14 multilayer ceramic chip capacitor 15 pF ATC 800B C15 electrolytic capacitor 2200 F, 63 V Vishay L1 wire inductor 169 nH Coilcraft:132-12SMG L2 wire inductor 90 nH Coilcraft:132-9SMG R1, R2 resistor 10  SMD 1206 All information provided in this document is subject to legal disclaimers. Rev. 4 — 1 September 2016 © Ampleon Netherlands B.V. 2016. All rights reserved. 7 of 16 BLP05H675XR; BLP05H675XRG Power LDMOS transistor Table 11. List of components …continued For test circuit see Figure 5. Component Description Value Remarks R3 resistor 4.64 k SMD 0805 R4 shunt resistor 10 m Ohmite: FC4L110R010FER R5 resistor 7.5 , 0.6 W SMD 1206 7.5 Graphical data The following figures are measured in a class-AB production test circuit. 7.5.1 1-Tone CW pulsed aaa-020040 30 Gp (dB) 90 ηD (%) ηD 28 aaa-020041 54 PL (dBm) 52 Ideal PL 70 (2) 50 (1) PL 26 48 50 Gp 24 46 30 44 22 0 20 40 60 80 PL (W) 42 10 100 16 VDS = 50 V; IDq = 20 mA; f = 108 MHz; tp = 100 s;  = 20 %. 18 20 22 24 26 Pi (dBm) VDS = 50 V; IDq = 20 mA; f = 108 MHz; tp = 100 s;  = 20 %. (1) PL(1dB) = 48.8 dBm (75.6 W) at Pi = 21.6 dBm (2) PL(3dB) = 49.25 dBm (83.5 W) at Pi = 24.2 dBm Fig 6. Power gain and drain efficiency as function of output power; typical values BLP05H675XR_H675XRG Product data sheet Fig 7. Output power as a function of input power; typical values All information provided in this document is subject to legal disclaimers. Rev. 4 — 1 September 2016 © Ampleon Netherlands B.V. 2016. All rights reserved. 8 of 16 BLP05H675XR; BLP05H675XRG Power LDMOS transistor aaa-020042 32 Gp (dB) aaa-020043 80 ηD (%) 30 60 28 40 (6) (5) (4) (3) (2) (1) 26 (1) (2) (3) (4) (5) (6) 20 24 0 0 20 40 60 80 PL (W) 100 0 VDS = 50 V; f = 108 MHz; tp = 100 s;  = 20 %. 20 (1) IDq = 20 mA (2) IDq = 50 mA (2) IDq = 50 mA (3) IDq = 100 mA (3) IDq = 100 mA (4) IDq = 200 mA (4) IDq = 200 mA (5) IDq = 300 mA (5) IDq = 300 mA (6) IDq = 400 mA (6) IDq = 400 mA Power gain as a function of output power; typical values BLP05H675XR_H675XRG Product data sheet 60 80 PL (W) 100 VDS = 50 V; f = 108 MHz; tp = 100 s;  = 20 %. (1) IDq = 20 mA Fig 8. 40 Fig 9. Drain efficiency as a function of output power; typical values All information provided in this document is subject to legal disclaimers. Rev. 4 — 1 September 2016 © Ampleon Netherlands B.V. 2016. All rights reserved. 9 of 16 BLP05H675XR; BLP05H675XRG Power LDMOS transistor aaa-020044 30 Gp (dB) aaa-020045 90 ηD (%) (7) (6) (4) (5) (3) (2) (1) 28 70 26 50 (1) (2) 24 (4) (3) (5) 30 (6) 22 (7) 20 10 0 20 40 60 80 PL (W) 100 IDq = 20 mA; f = 108 MHz; tp = 100 s;  = 20 %. 0 20 (1) VDS = 50 V (2) VDS = 45 V (2) VDS = 45 V (3) VDS = 40 V (3) VDS = 40 V (4) VDS = 35 V (4) VDS = 35 V (5) VDS = 30 V (5) VDS = 30 V (6) VDS = 25 V (6) VDS = 25 V (7) VDS = 20 V (7) VDS = 20 V BLP05H675XR_H675XRG Product data sheet 60 80 PL (W) 100 IDq = 20 mA; f = 108 MHz; tp = 100 s;  = 20 %. (1) VDS = 50 V Fig 10. Power gain as a function of output power; typical values 40 Fig 11. Drain efficiency as a function of output power; typical values All information provided in this document is subject to legal disclaimers. Rev. 4 — 1 September 2016 © Ampleon Netherlands B.V. 2016. All rights reserved. 10 of 16 BLP05H675XR; BLP05H675XRG Power LDMOS transistor 8. Package outline HSOP4F: plastic, heatsink small outline package; 4 leads(flat) SOT1223-2 D E X c B D3 A E3 y v HE A D1 D2 b w 4 B 3 F (4x) (8x) METAL PROTRUSIONS (SOURCE) e4 (2x) e3 (2x) E2 E1 A A2 A1 pin 1 index Q1 detail X 1 2 e1 (2x) e2 (2x) e Q1 0 Unit mm max nom min A A1 3.9 0.2 0.1 0 A2 b c scale D(1) D1 D2 D3 E(1) E1 E2 E3 e e1 e2 e3 e4 3.65 3.90 0.27 20.62 19.00 16.05 20.44 10.01 8.18 5.89 9.83 3.60 3.85 0.22 20.57 18.95 16.00 20.39 9.96 8.13 5.84 9.78 8.85 8.45 9.55 2.97 4.07 3.55 3.80 0.17 20.52 18.90 15.95 20.34 9.91 8.08 5.79 9.73 Note 1. Package body dimensions “D and “E do not include mold and metal protrusions. Allowable protrusion is 0.25 mm per side. 2. Lead width dimension “b does not include dambar protrusions. Allowable dambar protrusion is 0.25 mm in total per lead. Outline version References IEC JEDEC JEITA w 1.62 1.57 0.25 0.25 1.52 10 mm Dimensions (mm are the original dimensions) v European projection F y 0.1 HE 16.16 0.4 15.96 15.76 sot1223-2_po Issue date 15-01-12 15-06-04 SOT1223-2 Fig 12. Package outline SOT1223-2 (HSOP4F) BLP05H675XR_H675XRG Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 4 — 1 September 2016 © Ampleon Netherlands B.V. 2016. All rights reserved. 11 of 16 BLP05H675XR; BLP05H675XRG Power LDMOS transistor HSOP4: plastic, heatsink small outline package; 4 leads SOT1224-2 D X E c D3 B E3 y A v HE A D1 D2 b w 4 e4 (2x) 3 B (8x) METAL PROTRUSIONS (SOURCE) e3 Q (2x) E2 E1 A2 A (A3) A1 A4 pin 1 index Lp 1 2 θ H detail X e1 (2x) e2 (2x) e HE 0 Lp Q v w 13.5 1.10 2.07 13.2 0.95 2.02 0.25 0.25 12.9 0.80 1.97 10 mm scale y θ 0.1 7° 3° 0° Dimensions (mm are the original dimensions) Unit mm max nom min A A1 3.9 0.2 0.1 0 A2 A3 A4 b D(1) c D1 D2 D3 E(1) E1 E2 E3 e e1 e2 e4 3.65 0.06 3.90 0.27 20.62 19.00 16.05 20.44 10.01 8.18 5.89 9.83 0 3.60 0.35 3.85 0.22 20.57 18.95 16.00 20.39 9.96 8.13 5.84 9.78 8.85 8.45 9.55 2.97 4.07 -0.02 3.80 0.17 20.52 18.90 15.95 20.34 9.91 8.08 5.79 9.73 3.55 Note 1. Package body dimensions “D and “E do not include mold and metal protrusions. Allowable protrusion is 0.25 mm per side. 2. Lead width dimension “b does not include dambar protrusions. Allowable dambar protrusion is 0.25 mm in total per lead. 3. Dimension A4 is measured with respect to bottom of the heatsink DATUM H. Positive value means that the bottom of the heatsink is higher than the bottom of the lead. Outline version e3 References IEC JEDEC JEITA European projection sot1224-2_po Issue date 15-01-13 15-06-04 SOT1224-2 Fig 13. Package outline SOT1224-2 (HSOP4F) BLP05H675XR_H675XRG Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 4 — 1 September 2016 © Ampleon Netherlands B.V. 2016. All rights reserved. 12 of 16 BLP05H675XR; BLP05H675XRG Power LDMOS transistor 9. Handling information CAUTION This device is sensitive to ElectroStatic Discharge (ESD). Observe precautions for handling electrostatic sensitive devices. Such precautions are described in the ANSI/ESD S20.20, IEC/ST 61340-5, JESD625-A or equivalent standards. 10. Abbreviations Table 12. Abbreviations Acronym Description CW Continuous Wave ESD ElectroStatic Discharge HF High Frequency LDMOS Laterally Diffused Metal-Oxide Semiconductor MTF Median Time to Failure SMD Surface Mounted Device UIS Unclamped Inductive Switching VSWR Voltage Standing-Wave Ratio 11. Revision history Table 13. Revision history Document ID Release date BLP05H675XR_H675XRG v.4 20160901 Modifications: Data sheet status Change notice Supersedes Product data sheet - BLP05H675XR v.3 • The document now describes both the straight lead and gull-wing versions of this product: BLP05H675XR and BLP05H675XRG respectively • • • • Table 2 on page 2: added BLP05H675XRG data Table 3 on page 2: added BLP05H675XRG data Section 7.1 on page 5: added BLP05H675XRG Figure 13 on page 12: added figure SOT1224-2 BLP05H675XR v.3 20160122 Product data sheet - BLP05H675XR#2 BLP05H675XR#2 20150901 Objective data sheet - BLP05H675XR v.1 BLP05H675XR v.1 20150518 Objective data sheet - - BLP05H675XR_H675XRG Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 4 — 1 September 2016 © Ampleon Netherlands B.V. 2016. All rights reserved. 13 of 16 BLP05H675XR; BLP05H675XRG Power LDMOS transistor 12. Legal information 12.1 Data sheet status Document status[1][2] Product status[3] Definition Objective [short] data sheet Development This document contains data from the objective specification for product development. Preliminary [short] data sheet Qualification This document contains data from the preliminary specification. Product [short] data sheet Production This document contains the product specification. [1] Please consult the most recently issued document before initiating or completing a design. [2] The term ‘short data sheet’ is explained in section “Definitions”. [3] The product status of device(s) described in this document may have changed since this document was published and may differ in case of multiple devices. The latest product status information is available on the Internet at URL http://www.ampleon.com. 12.2 Definitions Draft — The document is a draft version only. The content is still under internal review and subject to formal approval, which may result in modifications or additions. Ampleon does not give any representations or warranties as to the accuracy or completeness of information included herein and shall have no liability for the consequences of use of such information. Short data sheet — A short data sheet is an extract from a full data sheet with the same product type number(s) and title. A short data sheet is intended for quick reference only and should not be relied upon to contain detailed and full information. For detailed and full information see the relevant full data sheet, which is available on request via the local Ampleon sales office. In case of any inconsistency or conflict with the short data sheet, the full data sheet shall prevail. Product specification — The information and data provided in a Product data sheet shall define the specification of the product as agreed between Ampleon and its customer, unless Ampleon and customer have explicitly agreed otherwise in writing. In no event however, shall an agreement be valid in which the Ampleon product is deemed to offer functions and qualities beyond those described in the Product data sheet. 12.3 Disclaimers Limited warranty and liability — Information in this document is believed to be accurate and reliable. However, Ampleon does not give any representations or warranties, expressed or implied, as to the accuracy or completeness of such information and shall have no liability for the consequences of use of such information. Ampleon takes no responsibility for the content in this document if provided by an information source outside of Ampleon. In no event shall Ampleon be liable for any indirect, incidental, punitive, special or consequential damages (including - without limitation - lost profits, lost savings, business interruption, costs related to the removal or replacement of any products or rework charges) whether or not such damages are based on tort (including negligence), warranty, breach of contract or any other legal theory. Notwithstanding any damages that customer might incur for any reason whatsoever, Ampleon’s aggregate and cumulative liability towards customer for the products described herein shall be limited in accordance with the Terms and conditions of commercial sale of Ampleon. Right to make changes — Ampleon reserves the right to make changes to information published in this document, including without limitation specifications and product descriptions, at any time and without notice. This document supersedes and replaces all information supplied prior to the publication hereof. Suitability for use — Ampleon products are not designed, authorized or warranted to be suitable for use in life support, life-critical or safety-critical systems or equipment, nor in applications where failure or malfunction of an BLP05H675XR_H675XRG Product data sheet Ampleon product can reasonably be expected to result in personal injury, death or severe property or environmental damage. Ampleon and its suppliers accept no liability for inclusion and/or use of Ampleon products in such equipment or applications and therefore such inclusion and/or use is at the customer’s own risk. Applications — Applications that are described herein for any of these products are for illustrative purposes only. Ampleon makes no representation or warranty that such applications will be suitable for the specified use without further testing or modification. Customers are responsible for the design and operation of their applications and products using Ampleon products, and Ampleon accepts no liability for any assistance with applications or customer product design. It is customer’s sole responsibility to determine whether the Ampleon product is suitable and fit for the customer’s applications and products planned, as well as for the planned application and use of customer’s third party customer(s). Customers should provide appropriate design and operating safeguards to minimize the risks associated with their applications and products. Ampleon does not accept any liability related to any default, damage, costs or problem which is based on any weakness or default in the customer’s applications or products, or the application or use by customer’s third party customer(s). Customer is responsible for doing all necessary testing for the customer’s applications and products using Ampleon products in order to avoid a default of the applications and the products or of the application or use by customer’s third party customer(s). Ampleon does not accept any liability in this respect. Limiting values — Stress above one or more limiting values (as defined in the Absolute Maximum Ratings System of IEC 60134) will cause permanent damage to the device. Limiting values are stress ratings only and (proper) operation of the device at these or any other conditions above those given in the Recommended operating conditions section (if present) or the Characteristics sections of this document is not warranted. Constant or repeated exposure to limiting values will permanently and irreversibly affect the quality and reliability of the device. Terms and conditions of commercial sale — Ampleon products are sold subject to the general terms and conditions of commercial sale, as published at http://www.ampleon.com/terms, unless otherwise agreed in a valid written individual agreement. In case an individual agreement is concluded only the terms and conditions of the respective agreement shall apply. Ampleon hereby expressly objects to applying the customer’s general terms and conditions with regard to the purchase of Ampleon products by customer. No offer to sell or license — Nothing in this document may be interpreted or construed as an offer to sell products that is open for acceptance or the grant, conveyance or implication of any license under any copyrights, patents or other industrial or intellectual property rights. Export control — This document as well as the item(s) described herein may be subject to export control regulations. Export might require a prior authorization from competent authorities. All information provided in this document is subject to legal disclaimers. Rev. 4 — 1 September 2016 © Ampleon Netherlands B.V. 2016. All rights reserved. 14 of 16 BLP05H675XR; BLP05H675XRG Power LDMOS transistor Non-automotive qualified products — Unless this data sheet expressly states that this specific Ampleon product is automotive qualified, the product is not suitable for automotive use. It is neither qualified nor tested in accordance with automotive testing or application requirements. Ampleon accepts no liability for inclusion and/or use of non-automotive qualified products in automotive equipment or applications. In the event that customer uses the product for design-in and use in automotive applications to automotive specifications and standards, customer (a) shall use the product without Ampleon’ warranty of the product for such automotive applications, use and specifications, and (b) whenever customer uses the product for automotive applications beyond Ampleon’ specifications such use shall be solely at customer’s own risk, and (c) customer fully indemnifies Ampleon for any liability, damages or failed product claims resulting from customer design and use of the product for automotive applications beyond Ampleon’ standard warranty and Ampleon’ product specifications. Translations — A non-English (translated) version of a document is for reference only. The English version shall prevail in case of any discrepancy between the translated and English versions. 12.4 Trademarks Notice: All referenced brands, product names, service names and trademarks are the property of their respective owners. Any reference or use of any ‘NXP’ trademark in this document or in or on the surface of Ampleon products does not result in any claim, liability or entitlement vis-à-vis the owner of this trademark. Ampleon is no longer part of the NXP group of companies and any reference to or use of the ‘NXP’ trademarks will be replaced by reference to or use of Ampleon’s own trademarks. 13. Contact information For more information, please visit: http://www.ampleon.com For sales office addresses, please visit: http://www.ampleon.com/sales BLP05H675XR_H675XRG Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 4 — 1 September 2016 © Ampleon Netherlands B.V. 2016. All rights reserved. 15 of 16 BLP05H675XR; BLP05H675XRG Power LDMOS transistor 14. Contents 1 1.1 1.2 1.3 2 3 4 5 6 7 7.1 7.2 7.3 7.4 7.5 7.5.1 8 9 10 11 12 12.1 12.2 12.3 12.4 13 14 Product profile . . . . . . . . . . . . . . . . . . . . . . . . . . 1 General description . . . . . . . . . . . . . . . . . . . . . 1 Features and benefits . . . . . . . . . . . . . . . . . . . . 1 Applications . . . . . . . . . . . . . . . . . . . . . . . . . . . 1 Pinning information . . . . . . . . . . . . . . . . . . . . . . 2 Ordering information . . . . . . . . . . . . . . . . . . . . . 2 Limiting values. . . . . . . . . . . . . . . . . . . . . . . . . . 2 Thermal characteristics . . . . . . . . . . . . . . . . . . 3 Characteristics . . . . . . . . . . . . . . . . . . . . . . . . . . 3 Test information . . . . . . . . . . . . . . . . . . . . . . . . . 5 Ruggedness in class-AB operation . . . . . . . . . 5 Impedance information . . . . . . . . . . . . . . . . . . . 5 UIS avalanche energy . . . . . . . . . . . . . . . . . . . 5 Test circuit. . . . . . . . . . . . . . . . . . . . . . . . . . . . . 7 Graphical data . . . . . . . . . . . . . . . . . . . . . . . . . 8 1-Tone CW pulsed . . . . . . . . . . . . . . . . . . . . . . 8 Package outline . . . . . . . . . . . . . . . . . . . . . . . . 11 Handling information. . . . . . . . . . . . . . . . . . . . 13 Abbreviations . . . . . . . . . . . . . . . . . . . . . . . . . . 13 Revision history . . . . . . . . . . . . . . . . . . . . . . . . 13 Legal information. . . . . . . . . . . . . . . . . . . . . . . 14 Data sheet status . . . . . . . . . . . . . . . . . . . . . . 14 Definitions . . . . . . . . . . . . . . . . . . . . . . . . . . . . 14 Disclaimers . . . . . . . . . . . . . . . . . . . . . . . . . . . 14 Trademarks. . . . . . . . . . . . . . . . . . . . . . . . . . . 15 Contact information. . . . . . . . . . . . . . . . . . . . . 15 Contents . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 16 Please be aware that important notices concerning this document and the product(s) described herein, have been included in section ‘Legal information’. © Ampleon Netherlands B.V. 2016. All rights reserved. For more information, please visit: http://www.ampleon.com For sales office addresses, please visit: http://www.ampleon.com/sales Date of release: 1 September 2016 Document identifier: BLP05H675XR_H675XRG
BLP05H675XRY 价格&库存
很抱歉,暂时无法提供与“BLP05H675XRY”相匹配的价格&库存,您可以联系我们找货
