BLC8G27LS-60AV;
BLC8G27LS-60AVH
Power LDMOS transistor
Rev. 4 — 2 December 2016
Product data sheet
1. Product profile
1.1 General description
60 W LDMOS packaged asymmetrical Doherty power transistor for base station
applications at frequencies from 2300 MHz to 2690 MHz.
Table 1.
Typical performance
Typical RF performance at Tcase = 25 C in the Doherty demo board.
f
VDS
PL(AV)
Gp
D
ACPR
(MHz)
(V)
(W)
(dB)
(dBc)
1-carrier W-CDMA
2496 to 2690
28
7
15.2
47
30 [1]
IS-95
2300 to 2400
26
7
13.6
48
30 [1]
Test signal
[1]
Test signal: 3GPP test model 1; 1 to 64 DPCH; PAR = 7.2 dB at 0.01 % probability on CCDF.
1.2 Features and benefits
Excellent ruggedness
High efficiency
Low thermal resistance providing excellent thermal stability
Decoupling leads to enable improved video bandwidth
Lower output capacitance for improved performance in Doherty applications
Designed for low memory effects providing excellent pre-distortability
Internally matched for ease of use
Integrated ESD protection
Compliant to Directive 2002/95/EC, regarding Restriction of Hazardous Substances
(RoHS)
1.3 Applications
RF power amplifier for LTE base stations and multi carrier applications in the
2300 MHz to 2690 MHz frequency range
BLC8G27LS-60AV(H)
2. Pinning information
Table 2.
Pinning
Pin
Description
Simplified outline
Graphic symbol
BLC8G27LS-60AV (SOT1275-3)
1
drain1 (main)
2
drain2 (peak)
3
gate1 (main)
4
gate2 (peak)
5
1
2
6
1, 5
3
7
5
video decoupling (main)
6
video decoupling (peak)
7
source
7
4
3
4
2, 6
[1]
aaa-007731
BLC8G27LS-60AVH (SOT1275-1)
1
drain1 (main)
2
drain2 (peak)
3
gate1 (main)
4
gate2 (peak)
5
6
1, 5
3
6
[1]
2
7
5
7
1
7
4
3
4
2, 6
[1]
source
aaa-007731
Connected to flange.
3. Ordering information
Table 3.
Type number
Package
Name
Description
Version
BLC8G27LS-60AV
air cavity plastic earless flanged package; 6 leads
SOT1275-3
BLC8G27LS-60AVH
SOT1275-1
4. Limiting values
Table 4.
Limiting values
In accordance with the Absolute Maximum Rating System (IEC 60134).
Symbol
Parameter
VDS
Min
Max
Unit
drain-source voltage
65
V
VGS
gate-source voltage
0.5
+13
V
Tstg
storage temperature
65
+150
C
225
C
Tj
[1]
Conditions
junction temperature
[1]
Continuous use at maximum temperature will affect the reliability, for details refer to the online MTF
calculator.
BLC8G27LS-60AV_27LS-60AVH
All information provided in this document is subject to legal disclaimers.
Product data sheet
© Ampleon Netherlands B.V. 2016. All rights reserved.
2 of 16
BLC8G27LS-60AV(H)
5. Thermal characteristics
Table 5.
Symbol
Parameter
Conditions
Rth(j-case) thermal resistance from junction to case
Typ
Unit
PL = 7 W
1.84
K/W
PL = 16 W
1.25
K/W
Tcase = 80 C; IDq = 100 mA;
VGS(amp) peak = 1 V
6. Characteristics
Table 6.
DC characteristics
Tj = 25 C unless otherwise specified.
Symbol
Parameter
Conditions
Min
Typ
Max
Unit
Main device
V(BR)DSS
drain-source breakdown voltage
VGS = 0 V; ID = 0.18 mA
65.25
V
VGS(th)
gate-source threshold voltage
VDS = 10 V; ID = 18 mA
1.45
1.9
2.35
V
VGSq
gate-source quiescent voltage
VDS = 28 V; ID = 108 mA
1.75
2.2
2.65
V
IDSS
drain leakage current
VGS = 0 V; VDS = 28 V
1.2
A
IDSX
drain cut-off current
VGS = VGS(th) + 3.75 V; VDS = 10 V
3.2
A
IGSS
gate leakage current
VGS = 11 V; VDS = 0 V
120
nA
gfs
forward transconductance
0.16
S
RDS(on)
drain-source on-state resistance
VGS = VGS(th) + 3.75 V; ID = 0.63 A
792
1260
m
65.25
V
Peak device
V(BR)DSS
VGS = 0 V; ID = 0.4 mA
VGS(th)
VDS = 10 V; ID = 40 mA
1.45
1.9
2.35
V
VGSq
VDS = 28 V; ID = 240 mA
1.45
1.9
2.35
V
IDSS
1.2
A
IDSX
7.0
A
IGSS
120
nA
gfs
0.4
S
RDS(on)
VGS = VGS(th) + 3.75 V; ID = 1.4 A
356
573
m
Table 7.
RF characteristics
Test signal: 1-carrier W-CDMA; PAR = 7.2 dB at 0.01 % probability on the CCDF;
3GPP test model 1; 1 to 64 DPCH; f1 = 2496 MHz; f2 = 2690 MHz; RF performance at VDS = 28 V;
IDq = 100 mA (main); VGS(amp)peak = 0.5 V; Tcase = 25 C; unless otherwise specified; in an
asymmetrical Doherty production test circuit at frequencies from 2496 MHz to 2690 MHz.
Symbol
Parameter
Conditions
Min
Typ
Max
Unit
Gp
power gain
PL(AV) = 7 W
13.8
15
dB
RLin
input return loss
PL(AV) = 7 W
10
7
dB
D
drain efficiency
PL(AV) = 7 W
40
44
ACPR
adjacent channel power ratio
PL(AV) = 7 W
28
23
dBc
Product data sheet
3 of 16
BLC8G27LS-60AV(H)
Table 8.
RF characteristics
Test signal: pulsed CW; tp = 100 s; = 10 %; f = 2690 MHz; RF performance at VDS = 28 V;
Symbol
Parameter
Conditions
PL(3dB)
output power at 3 dB gain compression
Min
Typ
Max
Unit
42
50
W
7. Test information
7.1 Ruggedness in Doherty operation
The BLC8G27LS-60AV and BLC8G27LS-60AVH are capable of withstanding a load
mismatch corresponding to a VSWR = 10 : 1 through all phases under the following
conditions: VDS = 28 V; IDq = 100 mA (main); VGS(amp)peak = 0.5 V; PL = 20 W (CW);
f = 2496 MHz.
7.2 Impedance information
Table 9.
Typical impedance of main device
Measured load-pull data of main device; IDq = 100 mA (main); VDS = 28 V.
f
ZS [1]
ZL [1]
PL [2]
D [2]
Gp [2]
(MHz)
(W)
(dB)
Maximum power load
2496
6.3 j11.2
18.4 j12.7
23
60
18.8
2600
8.9 j12.3
17.5 j12.4
23
58
19.1
2690
10.7 j9.5
16.0 j12.5
22
56
19.4
Maximum drain efficiency load
2496
6.3 j11.2
28.0 j0.0
17
67.0
20.9
2600
8.9 j12.3
24.4 j1.7
16
65.5
21.2
2690
10.7 j9.5
19.4 j0.0
17
64.5
21.3
[1]
ZS and ZL defined in Figure 1.
[2]
at 3 dB gain compression.
Table 10. Typical impedance of peak device
Measured load-pull data of peak device; IDq = 240 mA (peak); VDS = 28 V.
f
ZS [1]
ZL [1]
PL [2]
D [2]
Gp [2]
(MHz)
(W)
(dB)
17.6
Maximum power load
2496
4.5 j9.9
5.8 j9.8
51
55.9
2600
4.7 j9.8
6.0 j9.7
51
56.9
18.3
2690
2.5 j5.3
6.6 j10.4
52
57.0
17.8
Product data sheet
4 of 16
BLC8G27LS-60AV(H)
Table 10. Typical impedance of peak device …continued
f
ZS [1]
ZL [1]
PL [2]
D [2]
Gp [2]
(MHz)
(W)
(dB)
2496
4.5 j9.9
11.6 j5.8
36.5
64.1
20.3
2600
4.7 j9.8
10.2 j4.6
34.4
63.3
20.7
2690
2.5 j5.3
9.1 j4.9
35.1
62.3
20.5
[1]
[2]
drain
ZL
gate
ZS
001aaf059
Fig 1.
Definition of transistor impedance
7.3 Recommended impedances for Doherty design
Table 11. Typical impedance of main device at 1 : 1 load
f
ZS [1]
ZL [1]
PL [2]
D [3]
Gp [3]
(MHz)
(dBm)
(dB)
2496
6.3 j11.2
25.0 j9.2
43.2
37.0
20.0
2600
8.9 j12.3
21.5 j7.6
43.2
37.3
20.2
2690
10.7 j9.5
20.7 j8.8
43.2
37.1
20.2
[1]
[2]
[3]
at PL(AV) = 38.5 dBm.
Table 12. Typical impedance of main device at 1 : 2.5 load
f
ZS [1]
ZL [1]
PL [2]
D [3]
Gp [3]
(MHz)
(dBm)
(dB)
2496
6.3 j11.2
24.5 j17.8
40.0
52.0
22.0
2600
8.9 j12.3
18.0 j11.5
40.2
51.5
22.2
2690
10.7 j9.5
16.9 j8.2
40.6
52.1
22.0
[1]
[2]
[3]
Product data sheet
5 of 16
BLC8G27LS-60AV(H)
7.4 VBW in Doherty operation
The BLC8G27LS-60AV and BLC8G27LS-60AVH show 100 MHz (typical) video bandwidth
in Doherty demo board in 2600 MHz at VDS = 28 V; IDq = 100 mA and
VGS(amp)peak = 0.5 V.
7.5 Test circuit
40 mm
40 mm
C18
C11
C2
C14
C13
C1
C20
R1
C5
C8
R3
C10
C9
76 mm
C6
C19
C7
C3
C16
R2
C12
C4
C15
C17
aaa-019652
Printed-Circuit Board (PCB): Rogers RO4350B; r = 3.5; thickness = 0.508 mm;
thickness copper plating = 35 m.
See Table 13 for a list of components.
Fig 2.
Component layout
Table 13. List of components
See Figure 2 for component layout.
Component
Description
Value
Remarks
C1, C2, C3, C4, C5, C6, multilayer ceramic chip capacitor
C7
10 pF
[1]
C8, C9
0.2 pF
[1]
ATC 600F
electrolytic capacitor
11 pF
[1]
ATC 600F
C11, C12, C13, C14,
C15, C16
10 F, 50 V
[2]
Murata
C17, C18
1000 F, 100 V
C10
Product data sheet
ATC 600F
6 of 16
BLC8G27LS-60AV(H)
Table 13. List of components …continued
Component
Description
Value
C19, C20
1 F, 50 V
R1, R2
resistor
5.1
SMD 0805
R3
resistor
50
SMD 0805
[1]
American Technical Ceramics type 600F or capacitor of same quality
[2]
Murata or capacitor of same quality
Remarks
[2]
Murata
7.6 Graphical data
7.6.1 CW
aaa-019644
Gp
(dB)
60
ηD
ηD
18
50
(1)
(2)
16
40
(1)
(2)
14
30
Gp
12
10
38
40
42
44
46
48
50
PL (dBm)
52
VDS = 28 V; IDq = 100 mA (main device); VGS(amp)peak = 0.6 V.
(1) f = 2496 MHz
(2) f = 2690 MHz
Fig 3.
Power gain and drain efficiency as function of output power; typical values
Product data sheet
7 of 16
BLC8G27LS-60AV(H)
7.6.2 Pulsed CW
aaa-019645
Gp
(dB)
RLin
(dB)
60
16
aaa-019646
25
ηD
ηD
18
70
(2)
15
14
(1)
40
(1)
(1)
(2)
(2)
10
Gp
12
30
10
5
10
37
39
41
43
45
47
49
51
PL (dBm)
38
40
42
46
48
50
PL (dBm)
52
(1) f = 2496 MHz
(1) f = 2496 MHz
(2) f = 2690 MHz
(2) f = 2690 MHz
Fig 4.
44
Fig 5.
Input return loss as a function of output
7.6.3 1-Carrier W-CDMA
aaa-019647
Gp
(dB)
ηD
18
55
16
50
aaa-019648
10
PAR
(dB)
8
(1)
6
(2)
(1)
(1)
(2)
(2)
14
45
4
12
40
10
35
8
2
30
39
40
41
42
43
PL (dBm)
39
41
42
43
PL (dBm)
44
(1) f = 2496 MHz
(1) f = 2496 MHz
(2) f = 2690 MHz
Fig 6.
40
(2) f = 2690 MHz
Fig 7.
Peak-to-average power ratio as a function of
Product data sheet
8 of 16
BLC8G27LS-60AV(H)
aaa-019649
30
RLin
(dB)
25
aaa-019650
ACPR5M
(dBc)
-10
-20
(2)
15
(2)
-30
(1)
(1)
10
-40
5
-50
39
40
41
42
43
PL (dBm)
44
39
40
42
43
PL (dBm)
44
(1) f = 2496 MHz
(1) f = 2496 MHz
(2) f = 2690 MHz
(2) f = 2690 MHz
Fig 8.
41
Fig 9.
Adjacent channel power ratio (5 MHz) as a
7.6.4 2-Tone VBW
aaa-019651
-10
IMD
(dBc)
-20
(1)
(2)
IMD3
-30
(1)
(2)
IMD5
-40
(1)
(2)
-50
IMD7
-60
-70
1
10
carrier spacing (MHz)
102
VDS = 28 V; IDq = 100 mA (main device); VGS(amp)peak = 0.6 V; fc = 2600 MHz.
(1) IMD low
(2) IMD high
Fig 10. VBW capability in Doherty demo board
Product data sheet
9 of 16
BLC8G27LS-60AV(H)
8. Package outline
Air cavity plastic earless flanged package; 6 leads
SOT1275-3
K
D
X
A
F
7
w1
D1
B
detail X
L
b1
v
B
U1
A
c
H1
5
1
2
6
y
Į
Z1
Z
H
U2
E1
E
A
3
4
w2
b
B
Q
e
10 mm
K
y
v
W1
W2
0.24
0.1
0.5
0.5
0.5
scale
Dimensions
Unit
mm
A
max 4.01
nom
min 3.40
b
3.94
b1
c
D
D1
1.14 0.178 20.42 20.37
E
E1
9.8
9.75
e
H1
L
Q(1)
U1
U2
Z
Z1
Į
1.14 19.53
12.8
25.5
1.68
20.7
9.91
3.17
5.79
65°
0.94 19.33
12.6
25.2
1.45
20.5
9.70
2.67
5.29
61°
F
H
8.89
3.68
0.89 0.127 20.12 20.17
9.5
9.55
Note
1. Dimension Q is measured 0.1 mm away from the flange.
2. Ringframe and/or ringframe glue shall not overhang at the side of the flange.
Outline
version
References
IEC
JEDEC
JEITA
sot1275-3_po
European
projection
Issue date
15-04-02
16-11-15
SOT1275-3
Fig 11. Package outline SOT1275-3
Product data sheet
10 of 16
BLC8G27LS-60AV(H)
SOT1275-1
D
F
A
7
w1
D1
B
L
U1
b1
v
B
A
c
H1
5
1
2
6
Į
Z1
Z
U2
H
E1
E
A
3
4
b
e
Q
w2
B
5
10 mm
v
w1
w2
0.5
0.5
0.5
Z
Z1
Į
scale
Dimensions
Unit
mm
A
max 4.01
nom
min 3.40
b
b1
3.94
1.14
c
D
D1
E
0.178 20.42 20.37 9.80
E1
e
9.75
F
H
H1
L
Q(1)
U1
1.14 19.53 12.80 25.40 1.68
20.70 9.91 3.17
5.79
65°
0.94 19.33 12.60 25.20 1.45
20.50 9.70 2.67
5.29
61°
8.89
3.68
0.89
0.127 20.12 20.17 9.50
9.55
Note
Outline
version
U2
References
IEC
JEDEC
JEITA
sot1275-1_po
European
projection
Issue date
15-04-01
16-11-15
SOT1275-1
Fig 12. Package outline SOT1275-1
Product data sheet
11 of 16
BLC8G27LS-60AV(H)
9. Handling information
CAUTION
This device is sensitive to ElectroStatic Discharge (ESD). Observe precautions for handling
electrostatic sensitive devices.
Such precautions are described in the ANSI/ESD S20.20, IEC/ST 61340-5, JESD625-A or
equivalent standards.
Table 14.
ESD sensitivity
ESD model
Class
Charged Device Model (CDM); According to ANSI/ESDA/JEDEC standard JS-002
C2A [1]
Human Body Model (HBM); According to ANSI/ESDA/JEDEC standard JS-001
0B [2]
[1]
CDM classification C2A is granted to any part that passes after exposure to an ESD pulse of 500 V, but fails
after exposure to an ESD pulse of 750 V.
[2]
HBM classification 0B is granted to any part that passes after exposure to an ESD pulse of 125 V, but fails
after exposure to an ESD pulse of 250 V.
10. Abbreviations
Table 15.
Abbreviations
Acronym
Description
3GPP
3rd Generation Partnership Project
CCDF
Complementary Cumulative Distribution Function
CW
Continuous Wave
DPCH
Dedicated Physical CHannel
ESD
IS-95
Interim Standard 95
LDMOS
Laterally Diffused Metal-Oxide Semiconductor
LTE
Long Term Evolution
MTF
Median Time to Failure
PAR
Peak-to-Average Ratio
SMD
Surface Mounted Device
VBW
Video BandWidth
VSWR
Voltage Standing Wave Ratio
W-CDMA
Wideband Code Division Multiple Access
Product data sheet
12 of 16
BLC8G27LS-60AV(H)
11. Revision history
Table 16.
Revision history
Document ID
Release date
Data sheet status
Change notice Supersedes
BLC8G27LS-60AV_27LS-60AVH v.4
20161202
Product data sheet
Modifications:
BLC8G27LS-60AV_27LS-60AVH v.3
BLC8G27LS-60AV_27LS60AVH v.3
Figure 11 on page 10: updated package outline drawing SOT1275-3
Figure 12 on page 11: updated package outline drawing SOT1275-1
Section 9 on page 12: updated Handling information
20160408
Product data sheet
BLC8G27LS-60AV_27LS60AVH v.2
BLC8G27LS-60AV_27LS-60AVH v.2
20151027
Product data sheet
BLC8G27LS-60AV v.1
BLC8G27LS-60AV v.1
20150330
Objective data sheet
Product data sheet
13 of 16
BLC8G27LS-60AV(H)
12. Legal information
12.1 Data sheet status
Document status[1][2]
Product status[3]
Definition
Objective [short] data sheet
Development
This document contains data from the objective specification for product development.
Preliminary [short] data sheet
Qualification
This document contains data from the preliminary specification.
Product [short] data sheet
Production
This document contains the product specification.
[1]
Please consult the most recently issued document before initiating or completing a design.
[2]
The term ‘short data sheet’ is explained in section “Definitions”.
[3]
The product status of device(s) described in this document may have changed since this document was published and may differ in case of multiple devices. The latest product status
information is available on the Internet at URL http://www.ampleon.com.
12.2 Definitions
Draft — The document is a draft version only. The content is still under
internal review and subject to formal approval, which may result in
modifications or additions. Ampleon does not give any representations or
warranties as to the accuracy or completeness of information included herein
and shall have no liability for the consequences of use of such information.
Short data sheet — A short data sheet is an extract from a full data sheet
with the same product type number(s) and title. A short data sheet is intended
for quick reference only and should not be relied upon to contain detailed and
full information. For detailed and full information see the relevant full data
sheet, which is available on request via the local Ampleon sales office. In
case of any inconsistency or conflict with the short data sheet, the full data
sheet shall prevail.
Product specification — The information and data provided in a Product
data sheet shall define the specification of the product as agreed between
Ampleon and its customer, unless Ampleon and customer have explicitly
agreed otherwise in writing. In no event however, shall an agreement be valid
in which the Ampleon product is deemed to offer functions and qualities
beyond those described in the Product data sheet.
12.3 Disclaimers
Limited warranty and liability — Information in this document is believed to
be accurate and reliable. However, Ampleon does not give any
representations or warranties, expressed or implied, as to the accuracy or
completeness of such information and shall have no liability for the
consequences of use of such information. Ampleon takes no responsibility for
the content in this document if provided by an information source outside of
Ampleon.
In no event shall Ampleon be liable for any indirect, incidental, punitive,
special or consequential damages (including - without limitation - lost profits,
lost savings, business interruption, costs related to the removal or
replacement of any products or rework charges) whether or not such
damages are based on tort (including negligence), warranty, breach of
contract or any other legal theory.
Notwithstanding any damages that customer might incur for any reason
whatsoever, Ampleon’s aggregate and cumulative liability towards customer
for the products described herein shall be limited in accordance with the
Terms and conditions of commercial sale of Ampleon.
Right to make changes — Ampleon reserves the right to make changes to
information published in this document, including without limitation
specifications and product descriptions, at any time and without notice. This
document supersedes and replaces all information supplied prior to the
publication hereof.
Suitability for use — Ampleon products are not designed, authorized or
warranted to be suitable for use in life support, life-critical or safety-critical
systems or equipment, nor in applications where failure or malfunction of an
Ampleon product can reasonably be expected to result in personal injury,
death or severe property or environmental damage. Ampleon and its
suppliers accept no liability for inclusion and/or use of Ampleon products in
such equipment or applications and therefore such inclusion and/or use is at
the customer’s own risk.
Applications — Applications that are described herein for any of these
products are for illustrative purposes only. Ampleon makes no representation
or warranty that such applications will be suitable for the specified use without
further testing or modification.
Customers are responsible for the design and operation of their applications
and products using Ampleon products, and Ampleon accepts no liability for
any assistance with applications or customer product design. It is customer’s
sole responsibility to determine whether the Ampleon product is suitable and
fit for the customer’s applications and products planned, as well as for the
planned application and use of customer’s third party customer(s). Customers
should provide appropriate design and operating safeguards to minimize the
risks associated with their applications and products.
Ampleon does not accept any liability related to any default, damage, costs or
problem which is based on any weakness or default in the customer’s
applications or products, or the application or use by customer’s third party
customer(s). Customer is responsible for doing all necessary testing for the
customer’s applications and products using Ampleon products in order to
avoid a default of the applications and the products or of the application or
use by customer’s third party customer(s). Ampleon does not accept any
liability in this respect.
Limiting values — Stress above one or more limiting values (as defined in
the Absolute Maximum Ratings System of IEC 60134) will cause permanent
damage to the device. Limiting values are stress ratings only and (proper)
operation of the device at these or any other conditions above those given in
the Recommended operating conditions section (if present) or the
Characteristics sections of this document is not warranted. Constant or
repeated exposure to limiting values will permanently and irreversibly affect
the quality and reliability of the device.
Terms and conditions of commercial sale — Ampleon products are sold
subject to the general terms and conditions of commercial sale, as published
at http://www.ampleon.com/terms, unless otherwise agreed in a valid written
individual agreement. In case an individual agreement is concluded only the
terms and conditions of the respective agreement shall apply. Ampleon
hereby expressly objects to applying the customer’s general terms and
conditions with regard to the purchase of Ampleon products by customer.
No offer to sell or license — Nothing in this document may be interpreted or
construed as an offer to sell products that is open for acceptance or the grant,
conveyance or implication of any license under any copyrights, patents or
other industrial or intellectual property rights.
Export control — This document as well as the item(s) described herein
may be subject to export control regulations. Export might require a prior
authorization from competent authorities.
Product data sheet
14 of 16
BLC8G27LS-60AV(H)
Non-automotive qualified products — Unless this data sheet expressly
states that this specific Ampleon product is automotive qualified, the product
is not suitable for automotive use. It is neither qualified nor tested in
accordance with automotive testing or application requirements. Ampleon
accepts no liability for inclusion and/or use of non-automotive qualified
products in automotive equipment or applications.
In the event that customer uses the product for design-in and use in
automotive applications to automotive specifications and standards, customer
(a) shall use the product without Ampleon’ warranty of the product for such
automotive applications, use and specifications, and (b) whenever customer
uses the product for automotive applications beyond Ampleon’ specifications
such use shall be solely at customer’s own risk, and (c) customer fully
indemnifies Ampleon for any liability, damages or failed product claims
resulting from customer design and use of the product for automotive
applications beyond Ampleon’ standard warranty and Ampleon’ product
specifications.
Translations — A non-English (translated) version of a document is for
reference only. The English version shall prevail in case of any discrepancy
between the translated and English versions.
12.4 Trademarks
Notice: All referenced brands, product names, service names and trademarks
are the property of their respective owners.
Any reference or use of any ‘NXP’ trademark in this document or in or on the
surface of Ampleon products does not result in any claim, liability or
entitlement vis-à-vis the owner of this trademark. Ampleon is no longer part of
the NXP group of companies and any reference to or use of the ‘NXP’
trademarks will be replaced by reference to or use of Ampleon’s own
trademarks.
13. Contact information
For more information, please visit: http://www.ampleon.com
For sales office addresses, please visit: http://www.ampleon.com/sales
Product data sheet
15 of 16
BLC8G27LS-60AV(H)
14. Contents
1
1.1
1.2
1.3
2
3
4
5
6
7
7.1
7.2
7.3
7.4
7.5
7.6
7.6.1
7.6.2
7.6.3
7.6.4
8
9
10
11
12
12.1
12.2
12.3
12.4
13
14
Product profile . . . . . . . . . . . . . . . . . . . . . . . . . . 1
General description . . . . . . . . . . . . . . . . . . . . . 1
Features and benefits . . . . . . . . . . . . . . . . . . . . 1
Applications . . . . . . . . . . . . . . . . . . . . . . . . . . . 1
Pinning information . . . . . . . . . . . . . . . . . . . . . . 2
Ordering information . . . . . . . . . . . . . . . . . . . . . 2
Limiting values. . . . . . . . . . . . . . . . . . . . . . . . . . 2
Thermal characteristics . . . . . . . . . . . . . . . . . . 3
Characteristics . . . . . . . . . . . . . . . . . . . . . . . . . . 3
Test information . . . . . . . . . . . . . . . . . . . . . . . . . 4
Ruggedness in Doherty operation . . . . . . . . . . 4
Impedance information . . . . . . . . . . . . . . . . . . . 4
Recommended impedances for Doherty design 5
VBW in Doherty operation . . . . . . . . . . . . . . . . 6
Test circuit. . . . . . . . . . . . . . . . . . . . . . . . . . . . . 6
Graphical data . . . . . . . . . . . . . . . . . . . . . . . . . 7
CW . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 7
Pulsed CW . . . . . . . . . . . . . . . . . . . . . . . . . . . . 8
1-Carrier W-CDMA . . . . . . . . . . . . . . . . . . . . . . 8
2-Tone VBW . . . . . . . . . . . . . . . . . . . . . . . . . . . 9
Package outline . . . . . . . . . . . . . . . . . . . . . . . . 10
Handling information. . . . . . . . . . . . . . . . . . . . 12
Abbreviations . . . . . . . . . . . . . . . . . . . . . . . . . . 12
Revision history . . . . . . . . . . . . . . . . . . . . . . . . 13
Legal information. . . . . . . . . . . . . . . . . . . . . . . 14
Data sheet status . . . . . . . . . . . . . . . . . . . . . . 14
Definitions . . . . . . . . . . . . . . . . . . . . . . . . . . . . 14
Disclaimers . . . . . . . . . . . . . . . . . . . . . . . . . . . 14
Trademarks. . . . . . . . . . . . . . . . . . . . . . . . . . . 15
Contact information. . . . . . . . . . . . . . . . . . . . . 15
Contents . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 16
Please be aware that important notices concerning this document and the product(s)
described herein, have been included in section ‘Legal information’.
Date of release: 2 December 2016
Document identifier: BLC8G27LS-60AV_27LS-60AVH
