BLF6G38S-25,118
BLF6G38S-25,118
    AMPLEON(安谱隆)
    SOT608B
    TRANSISTOR PWR LDMOS SOT608B
BLF6G38S-25,118 数据手册
BLF6G38-25; BLF6G38S-25 WiMAX power LDMOS transistor Rev. 4 — 1 September 2015 Product data sheet 1. Product profile 1.1 General description 25 W LDMOS power transistor for base station applications at frequencies from 3400 MHz to 3800 MHz. Table 1. Typical performance Typical RF performance at Tcase = 25 C in a class-AB production test circuit. Mode of operation 1-carrier N-CDMA[1] f VDS PL(AV) Gp D ACPR885k ACPR1980k (MHz) (V) (W) (dB) (%) (dBc) (dBc) 3400 to 3600 28 4.5 15 24 45[2] 61[2] [1] Single carrier IS-95 with pilot, paging, sync and 6 traffic channels (Walsh codes 8 - 13). PAR = 9.7 dB at 0.01 % probability on the CCDF. Channel bandwidth is 1.2288 MHz. [2] Measured within 30 kHz bandwidth. 1.2 Features and benefits  Typical 1-carrier N-CDMA performance (single carrier IS-95 with pilot, paging, sync and 6 traffic channels [Walsh codes 8 - 13]. PAR = 9.7 dB at 0.01 % probability on the CCDF. Channel bandwidth is 1.2288 MHz) at a frequency of 3400 MHz, 3500 MHz and 3600 MHz, a supply voltage of 28 V and an IDq of 225 mA:  Average output power = 4.5 W  Power gain = 15 dB  Drain efficiency = 24 %  ACPR885k = 45 dBc in 30 kHz bandwidth  Easy power control  Integrated ESD protection  Excellent ruggedness  High efficiency  Excellent thermal stability  Designed for broadband operation (3400 MHz to 3800 MHz)  Internally matched for ease of use  Compliant to Directive 2002/95/EC, regarding Restriction of Hazardous Substances (RoHS) 1.3 Applications  RF power amplifiers for base stations and multicarrier applications in the 3400 MHz to 3800 MHz frequency range BLF6G38-25; BLF6G38S-25 WiMAX power LDMOS transistor 2. Pinning information Table 2. Pinning Pin Description Simplified outline Graphic symbol BLF6G38-25 (SOT608A) 1 drain 2 gate 3 source 1 1 [1] 2 3 3 2 sym112 BLF6G38S-25 (SOT608B) 1 drain 2 gate 3 source 1 1 [1] 3 2 3 2 sym112 [1] Connected to flange. 3. Ordering information Table 3. Ordering information Type number Package Name Description Version BLF6G38-25 - flanged ceramic package; 2 mounting holes; 2 leads SOT608A BLF6G38S-25 - ceramic earless flanged package; 2 leads SOT608B 4. Limiting values Table 4. Limiting values In accordance with the Absolute Maximum Rating System (IEC 60134). Symbol Parameter VDS Conditions Min Max Unit drain-source voltage - 65 V VGS gate-source voltage 0.5 +13 V ID drain current - 8.2 A Tstg storage temperature 65 +150 C Tj junction temperature - 200 C 5. Thermal characteristics BLF6G38-25_BLF6G38S-25#4 Product data sheet Table 5. Thermal characteristics Symbol Parameter Conditions Type Rth(j-case) thermal resistance from junction to case Tcase = 80 C; PL = 25 W BLF6G38-25 1.8 - K/W BLF6G38S-25 1.8 - K/W All information provided in this document is subject to legal disclaimers. Rev. 4 — 1 September 2015 Typ Max Unit © Ampleon The Netherlands B.V. 2015. All rights reserved. 2 of 14 BLF6G38-25; BLF6G38S-25 WiMAX power LDMOS transistor 6. Characteristics Table 6. Characteristics Tj = 25 C unless otherwise specified. Symbol Parameter Conditions Min Typ Max Unit V(BR)DSS drain-source breakdown voltage VGS = 0 V; ID = 0.4 mA 65 - - V VGS(th) gate-source threshold voltage VDS = 10 V; ID = 40 mA 1.4 2 2.4 V IDSS drain leakage current VGS = 0 V; VDS = 28 V - - 1.5 A IDSX drain cut-off current VGS = VGS(th) + 3.75 V; VDS = 10 V 6 8.2 - A IGSS gate leakage current VGS = +11 V; VDS = 0 V - - 150 nA gfs forward transconductance VDS = 10 V; ID = 1.4 A - 2.8 - S RDS(on) drain-source on-state resistance VGS = VGS(th) + 3.75 V; ID = 1.4 A - 0.37 0.58  Crs feedback capacitance VGS = 0 V; VDS = 28 V; f = 1 MHz - 0.59 - pF 7. Application information Table 7. Application information Mode of operation: 1-carrier N-CDMA; single carrier IS-95 with pilot, paging, sync and 6 traffic channels (Walsh codes 8 - 13); PAR = 9.7 dB at 0.01 % probability on the CCDF; channel bandwidth is 1.2288 MHz; f1 = 3400 MHz; f2 = 3500 MHz; f3 = 3600 MHz; RF performance at VDS = 28 V; IDq = 225 mA; Tcase = 25 C; unless otherwise specified, in a class-AB production circuit. Symbol Parameter Conditions Min Typ Max Unit Gp power gain PL(AV) = 4.5 W 12.5 15 RLin input return loss PL(AV) = 4.5 W D drain efficiency PL(AV) = 4.5 W ACPR885k adjacent channel power ratio (885 kHz) PL(AV) = 4.5 W [1] PL(AV) = 4.5 W [1] - ACPR1980k adjacent channel power ratio (1980 kHz) [1] - dB - 10 - dB 22 24 % - 45 40 dBc 61 56 dBc - Measured within 30 kHz bandwidth. 7.1 Ruggedness in class-AB operation The BLF6G38-25 and BLF6G38S-25 are capable of withstanding a load mismatch corresponding to VSWR = 10 : 1 through all phases under the following conditions: VDS = 28 V; IDq = 225 mA; PL = PL(1dB); f = 3600 MHz. BLF6G38-25_BLF6G38S-25#4 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 4 — 1 September 2015 © Ampleon The Netherlands B.V. 2015. All rights reserved. 3 of 14 BLF6G38-25; BLF6G38S-25 WiMAX power LDMOS transistor 7.2 Ampleon WiMAX signal 7.2.1 WiMAX signal description frame duration = 5 ms; bandwidth = 10 MHz; sequency = 1 frame; frequency band = WCS; sampling rate = 11.2 MHz; n = 8 / 7; G = Tg / Tb = 1 / 8; FFT = 1024; zone type = PUSC;  = 97.7 %; number of symbols = 46; number of subchannels = 30; PAR = 9.5 dB. Preamble: 1 symbol  30 subchannels; PL = PL(nom) + 3.86 dB Table 8. Frame structure Frame contents Modulation technique Data length Zone 0 FCH 2 symbols  4 subchannels QPSK1/2 3 Zone 0 data 2 symbols  26 subchannels 64QAM3/4 692 Zone 0 data 44 symbols  30 subchannels 64QAM3/4 10000 7.2.2 Graphs 001aah594 30 EVM (%) 001aah595 18 48 ηD (%) Gp (dB) 24 16 36 Gp 18 14 24 12 12 12 (1) (2) (3) 6 0 10−1 ηD 1 10 10−1 102 10 PL (W) f = 3400 MHz (2) f = 3500 MHz (3) f = 3600 MHz Fig 1. EVM as function of load power; typical values BLF6G38-25_BLF6G38S-25#4 Product data sheet 0 102 10 PL(AV) (W) VDS = 28 V; IDq = 225 mA; f = 3500 MHz; OFDMA signal; frame duration = 5 ms; bandwidth = 10 MHz; frequency band = WCS; n = 28 / 25; G = 1 / 8; FFT = 1024; zone type = PUSC; number of symbols = 46; number of subchannels = 30. VDS = 28 V; IDq = 225 mA; OFDMA signal; frame duration = 5 ms; bandwidth = 10 MHz; frequency band = WCS; n = 28 / 25; G = 1 / 8; FFT = 1024; zone type = PUSC; number of symbols = 46; number of subchannels = 30. (1) 1 Fig 2. Power gain and drain efficiency as functions of average load power; typical values All information provided in this document is subject to legal disclaimers. Rev. 4 — 1 September 2015 © Ampleon The Netherlands B.V. 2015. All rights reserved. 4 of 14 BLF6G38-25; BLF6G38S-25 WiMAX power LDMOS transistor 001aah596 −17 ACPR10M ACPR (dBc) −29 −41 −53 (2) (1) ACPR20M (1) (2) ACPR30M (2) (1) −65 10−1 1 102 10 PL(AV) (W) VDS = 28 V; IDq = 225 mA; f = 3500 MHz; OFDMA signal; frame duration = 5 ms; bandwidth = 10 MHz; frequency band = WCS; n = 28 / 25; G = 1 / 8; FFT = 1024; zone type = PUSC; number of symbols = 46; number of subchannels = 30. (1) Low frequency component (2) High frequency component Fig 3. Adjacent channel power ratio as function of average load power; typical values 7.3 Single carrier N-CDMA broadband performance at 9 W average 7.3.1 Graphs 001aah597 17 27 ηD (%) Gp (dB) 26 16 Gp 15 001aah598 −40 (1) (2) ACPR (dBc) −50 (1) (2) 25 ηD ACPR1500k 24 14 ACPR885k (2) (1) −60 ACPR1980k 23 13 12 3400 3450 3500 22 3600 3550 −70 3400 3450 3500 f (MHz) 3550 3600 f (MHz) PL(AV) = 4.5 W. VDS = 28 V; IDq = 350 mA; PL(AV) = 4.5 W; single carrier N-CDMA; PAR = 9.7 dB at 0.01 % probability; IBW = 30 kHz. (1) Low frequency component (2) High frequency component Fig 4. Power gain and drain efficiency as functions of frequency; typical values BLF6G38-25_BLF6G38S-25#4 Product data sheet Fig 5. Adjacent channel power ratio as function of frequency; typical values All information provided in this document is subject to legal disclaimers. Rev. 4 — 1 September 2015 © Ampleon The Netherlands B.V. 2015. All rights reserved. 5 of 14 BLF6G38-25; BLF6G38S-25 WiMAX power LDMOS transistor 001aah599 18 48 ηD (%) Gp (dB) 16 001aah600 −30 ACPR885k ACPR (dBc) −40 ACPR1500k 36 Gp (2) (1) −50 14 ACPR1980k (1) (2) 24 (2) (1) −60 12 12 ηD 10 10−1 1 0 102 10 −70 −80 10−1 1 102 10 PL (W) PL (W) VDS = 28 V; IDq = 225 mA; f = 3500 MHz; single carrier N-CDMA; PAR = 9.7 dB at 0.01 % probability; channel bandwidth = 1.23 MHz; IBW = 30 kHz. VDS = 28 V; IDq = 225 mA; f = 3500 MHz; single carrier N-CDMA; PAR = 9.7 dB at 0.01 % probability; channel bandwidth = 1.23 MHz; IBW = 30 kHz. (1) Low frequency component (2) High frequency component Fig 6. Power gain and drain efficiency as functions of load power; typical values Fig 7. 001aah601 18 Gp (dB) Adjacent channel power ratio as function of average load power; typical values 001aah602 0.8 (3) (2) (1) Pi (W) (2) (1) (3) 16 0.6 14 0.4 12 0.2 10 10−1 1 0 10−1 102 10 PL (W) VDS = 28 V; IDq = 225 mA; single carrier N-CDMA; PAR = 9.7 dB at 0.01 % probability; channel bandwidth = 1.23 MHz; IBW = 30 kHz. (1) f = 3400 MHz (1) f = 3400 MHz (2) f = 3500 MHz (2) f = 3500 MHz (3) f = 3600 MHz (3) f = 3600 MHz Power gain as function of load power; typical values BLF6G38-25_BLF6G38S-25#4 Product data sheet 102 10 PL (W) VDS = 28 V; IDq = 225 mA; single carrier N-CDMA; PAR = 9.7 dB at 0.01 % probability; channel bandwidth = 1.23 MHz; IBW = 30 kHz. Fig 8. 1 Fig 9. Input power as function of load power; typical values All information provided in this document is subject to legal disclaimers. Rev. 4 — 1 September 2015 © Ampleon The Netherlands B.V. 2015. All rights reserved. 6 of 14 BLF6G38-25; BLF6G38S-25 WiMAX power LDMOS transistor 8. Test information C16 C17 VGG VDD R3 C14 C12 L1 R1 C8 C6 C18 C20 C19 C10 C4 C2 C1 C21 C3 C5 C11 R2 C9 C7 BLF6G38-25 OUTPUT REV1 3.4 - 3.6 GHz C13 C15 001aah603 Striplines are on a double copper-clad Taconic RF35 Printed-Circuit Board (PCB) with r = 3.5 and thickness = 0.76 mm. See Table 9 for list of components. Fig 10. Component layout for 3400 MHz to 3600 MHz test circuit Table 9. List of components (see Figure 10) Component Description Value Remarks C1 multilayer ceramic chip capacitor 22 pF ATC 100A or equivalent C2, C3 multilayer ceramic chip capacitor 3 pF ATC 100A or equivalent C4, C5, C6, C7, C8, C9, C18 multilayer ceramic chip capacitor 10 pF ATC 100A or equivalent C10, C11 multilayer ceramic chip capacitor 24 pF ATC 100A or equivalent C12, C13 multilayer ceramic chip capacitor 4.7 F; 50 V TDK C4532X7R1H475M or equivalent C14, C15 multilayer ceramic chip capacitor 1 nF ATC 700A or equivalent C16, C17 multilayer ceramic chip capacitor 100 nF Vishay VJ1206Y104KXB or equivalent C19 multilayer ceramic chip capacitor 10 F; 50 V TDK C5750X7R1H106M or equivalent C20 electrolytic capacitor C21 multilayer ceramic chip capacitor 10 pF BLF6G38-25_BLF6G38S-25#4 Product data sheet 470 F; 63 V ATC 100B or equivalent All information provided in this document is subject to legal disclaimers. Rev. 4 — 1 September 2015 © Ampleon The Netherlands B.V. 2015. All rights reserved. 7 of 14 BLF6G38-25; BLF6G38S-25 WiMAX power LDMOS transistor Table 9. List of components (see Figure 10) …continued Component Description Value Remarks L1 ferrite SMD bead - Ferroxcube BDS3/3/4.6-4S2 or equivalent R1, R2 SMD resistor 20  SMD 1206 R3 SMD resistor 9.1  SMD 1206 Table 10. Measured test circuit impedances f ZS ZL MHz   3400 14.65 + j29.87 13.46 + j3.58 3450 14.16 + j28.69 13.56 + j4.12 3500 14.56 + j30.52 13.76 + j4.74 3550 17.49 + j30.11 13.97 + j5.41 3600 15.50 + j29.36 14.16 + j5.95 drain ZL gate ZS 001aag189 Fig 11. Definition of transistor impedance BLF6G38-25_BLF6G38S-25#4 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 4 — 1 September 2015 © Ampleon The Netherlands B.V. 2015. All rights reserved. 8 of 14 BLF6G38-25; BLF6G38S-25 WiMAX power LDMOS transistor 9. Package outline Flanged ceramic package; 2 mounting holes; 2 leads SOT608A D A F 3 A w2 D1 A B C U1 q w2 B H c C A B C 1 p U2 E1 w3 A E B 2 w1 A B b C Q 0 5 10 mm scale Dimensions (millimetre dimensions are derived from the original inch dimensions) Unit mm A b c D D1 E E1 F H p Q q U1 U2 w1 w2 w3 max 4.62 7.24 0.15 10.21 10.29 10.21 10.29 1.14 15.37 3.30 1.70 20.45 9.91 0.25 0.25 0.25 nom 15.24 min 3.76 6.99 0.10 10.01 10.03 10.01 10.03 0.89 15.11 2.92 1.45 20.19 9.65 sot608a_po Outline version References IEC JEDEC JEITA European projection Issue date 09-08-26 13-01-29 SOT608A Fig 12. Package outline SOT608A BLF6G38-25_BLF6G38S-25#4 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 4 — 1 September 2015 © Ampleon The Netherlands B.V. 2015. All rights reserved. 9 of 14 BLF6G38-25; BLF6G38S-25 WiMAX power LDMOS transistor Ceramic earless flanged package; 2 leads SOT608B D A F 3 A w2 D1 U1 A B C C c 1 U2 H E E1 2 B w2 w1 A B A B C b C Q 0 5 mm scale Dimensions (millimetre dimensions are derived from the original inch dimensions) Unit mm A b c D D1 E E1 F H Q U1 U2 w1 w2 max 4.62 7.24 0.15 10.21 10.29 10.21 10.29 1.14 15.37 1.70 10.24 10.24 0.25 0.25 nom min 3.76 6.99 0.10 10.01 10.03 10.01 10.03 0.89 15.11 1.45 9.98 9.98 sot608b_po Outline version References IEC JEDEC JEITA European projection Issue date 09-08-26 13-01-29 SOT608B Fig 13. Package outline SOT608B BLF6G38-25_BLF6G38S-25#4 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 4 — 1 September 2015 © Ampleon The Netherlands B.V. 2015. All rights reserved. 10 of 14 BLF6G38-25; BLF6G38S-25 WiMAX power LDMOS transistor 10. Abbreviations Table 11. Abbreviations Acronym Description CCDF Complementary Cumulative Distribution Function CW Continuous Wave ESD ElectroStatic Discharge EVM Error Vector Magnitude FCH Frame Control Header FFT Fast Fourier Transform IBW Instantaneous BandWidth IS-95 Interim Standard 95 LDMOS Laterally Diffused Metal-Oxide Semiconductor N-CDMA Narrowband Code Division Multiple Access OFDMA Orthogonal Frequency Division Multiple Access PAR Peak-to-Average power Ratio PUSC Partial Usage of SubChannels RF Radio Frequency QAM Quadrature Amplitude Modulation QPSK Quadrature Phase Shift Keying SMD Surface Mounted Device VSWR Voltage Standing-Wave Ratio WCS Wireless Communications Service WiMAX Worldwide Interoperability for Microwave Access 11. Revision history Table 12. Revision history Document ID Release date Data sheet status Change notice Supersedes BLF6G38-25_BLF6G38S-25#4 20150901 - Modifications: Product data sheet BLF6G38-25_BLF6G38S-25 v.3 • The format of this document has been redesigned to comply with the new identity guidelines of Ampleon. • Legal texts have been adapted to the new company name where appropriate. BLF6G38-25_BLF6G38S-25 v.3 20130311 Product data sheet - BLF6G38-25_BLF6G38S-25_2 BLF6G38-25_BLF6G38S-25_2 20081223 Product data sheet - BLF6G38-25_BLF6G38S-25_1 BLF6G38-25_BLF6G38S-25_1 20080218 Preliminary data sheet - - BLF6G38-25_BLF6G38S-25#4 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 4 — 1 September 2015 © Ampleon The Netherlands B.V. 2015. All rights reserved. 11 of 14 BLF6G38-25; BLF6G38S-25 WiMAX power LDMOS transistor 12. Legal information 12.1 Data sheet status Document status[1][2] Product status[3] Objective [short] data sheet Development This document contains data from the objective specification for product development. Preliminary [short] data sheet Qualification This document contains data from the preliminary specification. Product [short] data sheet Production This document contains the product specification. Definition [1] Please consult the most recently issued document before initiating or completing a design. [2] The term ‘short data sheet’ is explained in section “Definitions”. [3] The product status of device(s) described in this document may have changed since this document was published and may differ in case of multiple devices. The latest product status information is available on the Internet at URL http://www.ampleon.com. 12.2 Definitions Draft — The document is a draft version only. The content is still under internal review and subject to formal approval, which may result in modifications or additions. Ampleon does not give any representations or warranties as to the accuracy or completeness of information included herein and shall have no liability for the consequences of use of such information. Short data sheet — A short data sheet is an extract from a full data sheet with the same product type number(s) and title. A short data sheet is intended for quick reference only and should not be relied upon to contain detailed and full information. For detailed and full information see the relevant full data sheet, which is available on request via the local Ampleon sales office. In case of any inconsistency or conflict with the short data sheet, the full data sheet shall prevail. Product specification — The information and data provided in a Product data sheet shall define the specification of the product as agreed between Ampleon and its customer, unless Ampleon and customer have explicitly agreed otherwise in writing. In no event however, shall an agreement be valid in which the Ampleon product is deemed to offer functions and qualities beyond those described in the Product data sheet. 12.3 Disclaimers Limited warranty and liability — Information in this document is believed to be accurate and reliable. However, Ampleon does not give any representations or warranties, expressed or implied, as to the accuracy or completeness of such information and shall have no liability for the consequences of use of such information. Ampleon takes no responsibility for the content in this document if provided by an information source outside of Ampleon. In no event shall Ampleon be liable for any indirect, incidental, punitive, special or consequential damages (including - without limitation - lost profits, lost savings, business interruption, costs related to the removal or replacement of any products or rework charges) whether or not such damages are based on tort (including negligence), warranty, breach of contract or any other legal theory. Notwithstanding any damages that customer might incur for any reason whatsoever, Ampleon’ aggregate and cumulative liability towards customer for the products described herein shall be limited in accordance with the Terms and conditions of commercial sale of Ampleon. Right to make changes — Ampleon reserves the right to make changes to information published in this document, including without limitation specifications and product descriptions, at any time and without notice. This document supersedes and replaces all information supplied prior to the publication hereof. Suitability for use — Ampleon products are not designed, authorized or warranted to be suitable for use in life support, life-critical or safety-critical systems or equipment, nor in applications where failure or malfunction of an BLF6G38-25_BLF6G38S-25#4 Product data sheet Ampleon product can reasonably be expected to result in personal injury, death or severe property or environmental damage. Ampleon and its suppliers accept no liability for inclusion and/or use of Ampleon products in such equipment or applications and therefore such inclusion and/or use is at the customer’s own risk. Applications — Applications that are described herein for any of these products are for illustrative purposes only. Ampleon makes no representation or warranty that such applications will be suitable for the specified use without further testing or modification. Customers are responsible for the design and operation of their applications and products using Ampleon products, and Ampleon accepts no liability for any assistance with applications or customer product design. It is customer’s sole responsibility to determine whether the Ampleon product is suitable and fit for the customer’s applications and products planned, as well as for the planned application and use of customer’s third party customer(s). Customers should provide appropriate design and operating safeguards to minimize the risks associated with their applications and products. Ampleon does not accept any liability related to any default, damage, costs or problem which is based on any weakness or default in the customer’s applications or products, or the application or use by customer’s third party customer(s). Customer is responsible for doing all necessary testing for the customer’s applications and products using Ampleon products in order to avoid a default of the applications and the products or of the application or use by customer’s third party customer(s). Ampleon does not accept any liability in this respect. Limiting values — Stress above one or more limiting values (as defined in the Absolute Maximum Ratings System of IEC 60134) will cause permanent damage to the device. Limiting values are stress ratings only and (proper) operation of the device at these or any other conditions above those given in the Recommended operating conditions section (if present) or the Characteristics sections of this document is not warranted. Constant or repeated exposure to limiting values will permanently and irreversibly affect the quality and reliability of the device. Terms and conditions of commercial sale — Ampleon products are sold subject to the general terms and conditions of commercial sale, as published at http://www.ampleon.com/terms, unless otherwise agreed in a valid written individual agreement. In case an individual agreement is concluded only the terms and conditions of the respective agreement shall apply. Ampleon hereby expressly objects to applying the customer’s general terms and conditions with regard to the purchase of Ampleon products by customer. No offer to sell or license — Nothing in this document may be interpreted or construed as an offer to sell products that is open for acceptance or the grant, conveyance or implication of any license under any copyrights, patents or other industrial or intellectual property rights. Export control — This document as well as the item(s) described herein may be subject to export control regulations. Export might require a prior authorization from competent authorities. All information provided in this document is subject to legal disclaimers. Rev. 4 — 1 September 2015 © Ampleon The Netherlands B.V. 2015. All rights reserved. 12 of 14 BLF6G38-25; BLF6G38S-25 WiMAX power LDMOS transistor Non-automotive qualified products — Unless this data sheet expressly states that this specific Ampleon product is automotive qualified, the product is not suitable for automotive use. It is neither qualified nor tested in accordance with automotive testing or application requirements. Ampleon accepts no liability for inclusion and/or use of non-automotive qualified products in automotive equipment or applications. In the event that customer uses the product for design-in and use in automotive applications to automotive specifications and standards, customer (a) shall use the product without Ampleon’ warranty of the product for such automotive applications, use and specifications, and (b) whenever customer uses the product for automotive applications beyond Ampleon’ specifications such use shall be solely at customer’s own risk, and (c) customer fully indemnifies Ampleon for any liability, damages or failed product claims resulting from customer design and use of the product for automotive applications beyond Ampleon’ standard warranty and Ampleon’ product specifications. 12.4 Trademarks Notice: All referenced brands, product names, service names and trademarks are the property of their respective owners. Any reference or use of any ‘NXP’ trademark in this document or in or on the surface of Ampleon products does not result in any claim, liability or entitlement vis-à-vis the owner of this trademark. Ampleon is no longer part of the NXP group of companies and any reference to or use of the ‘NXP’ trademarks will be replaced by reference to or use of Ampleon’s own Any reference or use of any ‘NXP’ trademark in this document or in or on the surface of Ampleon products does not result in any claim, liability or entitlement vis-à-vis the owner of this trademark. Ampleon is no longer part of the NXP group of companies and any reference to or use of the ‘NXP’ trademarks will be replaced by reference to or use of Ampleon’s own trademarks. Translations — A non-English (translated) version of a document is for reference only. The English version shall prevail in case of any discrepancy between the translated and English versions. 13. Contact information For more information, please visit: http://www.ampleon.com BLF6G38-25_BLF6G38S-25#4 Product data sheet For sales office addresses, please visit: http://www.ampleon.com/sales All information provided in this document is subject to legal disclaimers. Rev. 4 — 1 September 2015 © Ampleon The Netherlands B.V. 2015. All rights reserved. 13 of 14 BLF6G38-25; BLF6G38S-25 WiMAX power LDMOS transistor 14. Contents 1 1.1 1.2 1.3 2 3 4 5 6 7 7.1 7.2 7.2.1 7.2.2 7.3 7.3.1 8 9 10 11 12 12.1 12.2 12.3 12.4 13 14 Product profile . . . . . . . . . . . . . . . . . . . . . . . . . . 1 General description . . . . . . . . . . . . . . . . . . . . . 1 Features and benefits . . . . . . . . . . . . . . . . . . . . 1 Applications . . . . . . . . . . . . . . . . . . . . . . . . . . . 1 Pinning information . . . . . . . . . . . . . . . . . . . . . . 2 Ordering information . . . . . . . . . . . . . . . . . . . . . 2 Limiting values. . . . . . . . . . . . . . . . . . . . . . . . . . 2 Thermal characteristics . . . . . . . . . . . . . . . . . . 2 Characteristics . . . . . . . . . . . . . . . . . . . . . . . . . . 3 Application information. . . . . . . . . . . . . . . . . . . 3 Ruggedness in class-AB operation . . . . . . . . . 3 Ampleon WiMAX signal . . . . . . . . . . . . . . . . . . 4 WiMAX signal description . . . . . . . . . . . . . . . . . 4 Graphs . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 4 Single carrier N-CDMA broadband performance at 9 W average . . . . . . . . . . . . . . . . . . . . . . . . . 5 Graphs . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 5 Test information . . . . . . . . . . . . . . . . . . . . . . . . . 7 Package outline . . . . . . . . . . . . . . . . . . . . . . . . . 9 Abbreviations . . . . . . . . . . . . . . . . . . . . . . . . . . 11 Revision history . . . . . . . . . . . . . . . . . . . . . . . . 11 Legal information. . . . . . . . . . . . . . . . . . . . . . . 12 Data sheet status . . . . . . . . . . . . . . . . . . . . . . 12 Definitions . . . . . . . . . . . . . . . . . . . . . . . . . . . . 12 Disclaimers . . . . . . . . . . . . . . . . . . . . . . . . . . . 12 Trademarks. . . . . . . . . . . . . . . . . . . . . . . . . . . 13 Contact information. . . . . . . . . . . . . . . . . . . . . 13 Contents . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 14 Please be aware that important notices concerning this document and the product(s) described herein, have been included in section ‘Legal information’. © Ampleon The Netherlands B.V. 2015. All rights reserved. For more information, please visit: http://www.ampleon.com For sales office addresses, please visit: http://www.ampleon.com/sales Date of release: 1 September 2015 Document identifier: BLF6G38-25_BLF6G38S-25#4
BLF6G38S-25,118
物料型号: - BLF6G38-25 - BLF6G38S-25
器件简介: - 这是一种25瓦LDMOS功率晶体管,适用于3400 MHz至3800 MHz频率范围内的基站应用。
引脚分配: - BLF6G38-25 (SOT608A):1-漏极,2-栅极,3-源极 - BLF6G38S-25 (SOT608B):1-漏极,2-栅极,3-源极
参数特性: - 工作频率范围:3400 MHz至3800 MHz - 典型1载波N-CDMA性能:在3400 MHz、3500 MHz和3600 MHz频率下,28V供电电压和225 mA的IDq时,平均输出功率为4.5 W,功率增益为15 dB,漏极效率为24%,ACPR885k在30 kHz带宽内为-45 dBc。
功能详解: - 设计用于宽带操作,内部匹配以便于使用。 - 符合有害物质限制指令2002/95/EC(RoHS)。
应用信息: - 适用于3400 MHz至3800 MHz频率范围内的基站射频功率放大器和多载波应用。
封装信息: - BLF6G38-25:带法兰的陶瓷封装;2个安装孔;2个引脚,SOT608A。 - BLF6G38S-25:无耳法兰陶瓷封装;2个引脚,SOT608B。
BLF6G38S-25,118 价格&库存
很抱歉,暂时无法提供与“BLF6G38S-25,118”相匹配的价格&库存,您可以联系我们找货
