BLF10M6135U
BLF10M6135U
    AMPLEON(安谱隆)
    SOT502A
    IC TRANS LDMOS 135W SOT502A
BLF10M6135U 数据手册
BLF10M6135; BLF10M6LS135 Power LDMOS transistor Rev. 2 — 1 September 2015 Product data sheet 1. Product profile 1.1 General description 135 W LDMOS power transistor for industrial applications at frequencies from 700 MHz to 1000 MHz. Table 1. Typical performance Typical RF performance at Tcase = 25 C in a class-AB production test circuit. Test signal 2-carrier W-CDMA [1] f VDS PL(AV) Gp D ACPR (MHz) (V) (W) (dB) (%) (dBc) 869 to 894 28 26.5 21.0 28.0 39[1] Test signal: 3GPP; test model 1; 64 DPCH; PAR = 7.5 dB at 0.01 % probability on CCDF per carrier; carrier spacing 5 MHz. 1.2 Features and benefits         Easy power control Integrated ESD protection Enhanced ruggedness High efficiency Excellent thermal stability Designed for broadband operation (700 MHz to 1000 MHz) Internally matched for ease of use Compliant to Directive 2002/95/EC, regarding restriction of hazardous substances (RoHS) 1.3 Applications  RF power amplifiers for ISM applications in the 700 MHz to 1000 MHz frequency range BLF10M6135; BLF10M6LS135 Power LDMOS transistor 2. Pinning information Table 2. Pinning Pin Description Simplified outline Graphic symbol BLF10M6135 (SOT502A) 1 drain 2 gate 3 source 1 1 [1] 3 2 2 3 sym112 BLF10M6LS135 (SOT502B) 1 drain 2 gate 3 source 1 1 [1] 3 2 2 3 sym112 [1] Connected to flange. 3. Ordering information Table 3. Ordering information Type number Package Name Description Version BLF10M6135 - flanged ceramic package; 2 mounting holes; 2 leads SOT502A BLF10M6LS135 - earless flanged ceramic package; 2 leads SOT502B 4. Limiting values Table 4. Limiting values In accordance with the Absolute Maximum Rating System (IEC 60134). Symbol Parameter VDS Min Max Unit drain-source voltage - 65 V VGS gate-source voltage 0.5 +13 V Tstg storage temperature 65 +150 C Tj junction temperature - 225 C [1] Conditions [1] Continuous use at maximum temperature will affect reliability. 5. Thermal characteristics Table 5. Symbol Thermal characteristics Parameter Conditions Rth(j-case) thermal resistance from Tcase = 80 C; PL = 25 W junction to case BLF10M6135_BLF10M6LS135#2 All information provided in this document is subject to legal disclaimers. Product data sheet Rev. 2 — 1 September 2015 Type Typ Unit BLF10M6135 0.68 K/W BLF10M6LS135 0.56 K/W © Ampleon The Netherlands B.V. 2015. All rights reserved. 2 of 12 BLF10M6135; BLF10M6LS135 Power LDMOS transistor 6. Characteristics Table 6. DC characteristics Tj = 25 C unless otherwise specified. Symbol Parameter V(BR)DSS drain-source breakdown voltage Conditions Min Typ Max Unit VGS = 0 V; ID = 0.8 mA 65 - - V VGS(th) gate-source threshold voltage VDS = 10 V; ID = 180 mA 1.4 1.9 2.4 V VGSq gate-source quiescent voltage VDS = 28 V; ID = 950 mA 1.6 2.1 2.6 V IDSS drain leakage current VGS = 0 V; VDS = 28 V - - 3 A IDSX drain cut-off current VGS = VGS(th) + 3.75 V; VDS = 10 V 24 32 - A IGSS gate leakage current VGS = 11 V; VDS = 0 V - - 300 nA gfs forward transconductance VDS = 10 V; ID = 9 A 7 13 - S RDS(on) drain-source on-state resistance VGS = VGS(th) + 3.75 V; ID = 6.3 A - 0.1 -  Table 7. AC characteristics Tj = 25 C unless otherwise specified. Symbol Parameter Conditions Min Typ Max Unit Crs feedback capacitance VGS = 0 V; VDS = 28 V; f = 1 MHz - 2.0 - pF Table 8. RF characteristics Test signal: 2-carrier W-CDMA; PAR 7.5 dB at 0.01 % probability on CCDF; 3GPP test model 1; 1-64 DPCH; f1 = 871.5 MHz; f2 = 876.5 MHz; f3 = 886.5 MHz; f4 = 891.5 MHz; RF performance at VDS = 28 V; IDq = 950 mA; Tcase = 25 C; unless otherwise specified; in a class-AB production test circuit. Symbol Parameter Conditions Min Typ Max Unit Gp power gain PL(AV) = 26.5 W 20.0 21.0 - dB RLin input return loss PL(AV) = 26.5 W - 10.0 6.5 dB D drain efficiency PL(AV) = 26.5 W 26.0 28.0 - % ACPR adjacent channel power ratio PL(AV) = 26.5 W - 39 36.5 dBc 7. Test information 7.1 Ruggedness in class-AB operation The BLF10M6135 and BLF10M6LS135 are capable of withstanding a load mismatch corresponding to VSWR = 10 : 1 through all phases under the following conditions: VDS = 28 V; IDq = 950 mA; PL = 135 W; f = 894 MHz. BLF10M6135_BLF10M6LS135#2 All information provided in this document is subject to legal disclaimers. Product data sheet Rev. 2 — 1 September 2015 © Ampleon The Netherlands B.V. 2015. All rights reserved. 3 of 12 BLF10M6135; BLF10M6LS135 Power LDMOS transistor 7.2 Test circuit information VGG VDD C8 C3 R1 C9 C10 C11 C18 C20 R3 L1 C4 R2 C6 input 50 Ω C1 output 50 Ω C17 C2 C16 C7 C5 C12 C13 C14 C15 C19 001aah869 The drawing is not to scale. Fig 1. Test circuit for operation at 800 MHz C18 C8 C9 C20 L1 R1 R3 C10 C11 Q1 C4 C3 C6 R2 C17 C1 C2 C5 C7 C19 C16 C14 C15 C12 C13 IN 800 -1000 MHz V1.0 OUT 800 -1000 MHz V1.0 001aah870 The striplines are on a double copper-clad Taconic RF35 Printed-Circuit Board (PCB) with r = 3.5 and thickness = 0.76 mm. See Table 9 for list of components. The drawing is not to scale. Fig 2. Component layout BLF10M6135_BLF10M6LS135#2 All information provided in this document is subject to legal disclaimers. Product data sheet Rev. 2 — 1 September 2015 © Ampleon The Netherlands B.V. 2015. All rights reserved. 4 of 12 BLF10M6135; BLF10M6LS135 Power LDMOS transistor Table 9. List of components See Figure 1 and Figure 2. Component Description Value Remarks C1, C3, C10, C14, C17 multilayer ceramic chip capacitor 68 pF [1] solder vertically C2, C4, C5 multilayer ceramic chip capacitor 8.2 pF [1] solder vertically C6, C7 multilayer ceramic chip capacitor 10 pF [1] solder vertically C8, C9, C12, C13 electrolytic capacitor C11, C15 multilayer ceramic chip capacitor 4.7 F, 50 V [2] C16 multilayer ceramic chip capacitor 3.0 pF [1] C18, C19, C20 electrolytic capacitor L1 ferrite SMD bead Q1 BLF10M6135 R1, R2, R3 SMD resistor 100 nF Vishay or capacitor of same quality solder vertically 220 F, 63 V Ferroxcube BDS 3/3/4.6-4S2 or equivalent 9.1 , 0.1 W [1] American Technical Ceramics type 100B or capacitor of same quality. [2] TDK or capacitor of same quality. 7.3 Graphical data 7.3.1 1-Tone CW 001aah864 24 75 ηD (%) Gp (dB) 60 23 22 45 Gp 30 21 ηD 15 20 19 0 40 80 0 160 120 PL (W) VDS = 28 V; IDq = 950 mA; f = 881 MHz. Fig 3. Power gain and drain efficiency as function of output power; typical values BLF10M6135_BLF10M6LS135#2 All information provided in this document is subject to legal disclaimers. Product data sheet Rev. 2 — 1 September 2015 © Ampleon The Netherlands B.V. 2015. All rights reserved. 5 of 12 BLF10M6135; BLF10M6LS135 Power LDMOS transistor 7.3.2 2-Tone CW 001aah865 23 60 ηD (%) Gp (dB) 22 IMD (dBc) 45 −30 30 −40 Gp 001aah866 −20 IMD3 IMD5 21 IMD7 ηD 20 15 19 0 25 −60 0 75 100 PL(PEP) (W) 50 −50 VDS = 28 V; IDq = 950 mA; f = 881 MHz ( 100 kHz). Fig 4. Power gain and drain efficiency as function of peak envelope power load power; typical values 0 25 50 75 100 PL(PEP) (W) VDS = 28 V; IDq = 950 mA; f = 881 MHz ( 100 kHz). Fig 5. Intermodulation distortion as a function of peak envelope power load power; typical values 7.3.3 2-Carrier W-CDMA 001aah867 24 50 ηD (%) Gp (dB) 23 40 22 30 001aah868 −20 ACPR (dBc) −30 Gp 20 21 −40 ηD 10 20 19 0 0 12 24 36 48 60 PL(AV) (W) −50 Power gain and drain efficiency as function of average output power; typical values 20 40 60 PL(AV) (W) VDS = 28 V; IDq = 950 mA; f1 = 881 MHz; f2 = 886 MHz; carrier spacing 5 MHz. Fig 6. 0 VDS = 28 V; IDq = 950 mA; f1 = 881 MHz; f2 = 886 MHz; carrier spacing 5 MHz. Fig 7. Adjacent power channel ratio as a function of average output power; typical values BLF10M6135_BLF10M6LS135#2 All information provided in this document is subject to legal disclaimers. Product data sheet Rev. 2 — 1 September 2015 © Ampleon The Netherlands B.V. 2015. All rights reserved. 6 of 12 BLF10M6135; BLF10M6LS135 Power LDMOS transistor 8. Package outline Flanged ceramic package; 2 mounting holes; 2 leads SOT502A D A F 3 D1 U1 B q c C 1 H L E1 p U2 E w1 M A M B M A 2 w2 M C M b 0 5 Q 10 mm scale DIMENSIONS (millimetre dimensions are derived from the original inch dimensions) UNIT A b c mm 4.72 3.43 12.83 12.57 0.15 0.08 inches 0.186 0.135 0.505 0.006 0.495 0.003 OUTLINE VERSION D E E1 F H L p Q q U1 U2 w1 w2 20.02 19.96 19.61 19.66 9.50 9.30 9.53 9.25 1.14 0.89 19.94 18.92 5.33 4.32 3.38 3.12 1.70 1.45 27.94 34.16 33.91 9.91 9.65 0.25 0.51 0.788 0.786 0.772 0.774 0.374 0.375 0.366 0.364 0.067 1.100 0.057 1.345 1.335 0.390 0.380 0.01 0.02 D1 0.045 0.785 0.035 0.745 0.210 0.133 0.170 0.123 REFERENCES IEC JEDEC JEITA ISSUE DATE 03-01-10 12-05-02 SOT502A Fig 8. EUROPEAN PROJECTION Package outline SOT502A BLF10M6135_BLF10M6LS135#2 All information provided in this document is subject to legal disclaimers. Product data sheet Rev. 2 — 1 September 2015 © Ampleon The Netherlands B.V. 2015. All rights reserved. 7 of 12 BLF10M6135; BLF10M6LS135 Power LDMOS transistor Earless flanged ceramic package; 2 leads SOT502B D A F 3 D D1 c U1 1 L H E1 U2 E 2 w2 M D M b 0 5 Q 10 mm scale DIMENSIONS (millimetre dimensions are derived from the original inch dimensions) UNIT A b c mm 4.72 3.43 12.83 12.57 0.15 0.08 inches 0.186 0.135 0.505 0.006 0.495 0.003 OUTLINE VERSION D E E1 F H L Q U1 U2 w2 20.02 19.96 19.61 19.66 9.50 9.30 9.53 9.25 1.14 0.89 19.94 18.92 5.33 4.32 1.70 1.45 20.70 20.45 9.91 9.65 0.25 0.788 0.786 0.772 0.774 0.374 0.375 0.366 0.364 0.045 0.785 0.035 0.745 0.210 0.170 0.067 0.815 0.057 0.805 D1 REFERENCES IEC JEDEC JEITA EUROPEAN PROJECTION ISSUE DATE 07-05-09 12-05-02 SOT502B Fig 9. 0.390 0.010 0.380 Package outline SOT502B BLF10M6135_BLF10M6LS135#2 All information provided in this document is subject to legal disclaimers. Product data sheet Rev. 2 — 1 September 2015 © Ampleon The Netherlands B.V. 2015. All rights reserved. 8 of 12 BLF10M6135; BLF10M6LS135 Power LDMOS transistor 9. Handling information CAUTION This device is sensitive to ElectroStatic Discharge (ESD). Observe precautions for handling electrostatic sensitive devices. Such precautions are described in the ANSI/ESD S20.20, IEC/ST 61340-5, JESD625-A or equivalent standards. 10. Abbreviations Table 10. Abbreviations Acronym Description 3GPP 3rd Generation Partnership Project CCDF Complementary Cumulative Distribution Function CW Continuous Wave DPCH Dedicated Physical CHannel ESD ElectroStatic Discharge ISM Industrial, Scientific and Medical LDMOS Laterally Diffused Metal-Oxide Semiconductor PAR Peak-to-Average Ratio SMD Surface Mounted Device VSWR Voltage Standing-Wave Ratio W-CDMA Wideband Code Division Multiple Access 11. Revision history Table 11. Revision history Document ID Release date Data sheet status Change notice Supersedes BLF10M6135_BLF10M6LS135#2 20150901 Product data sheet - BLF10M6135_BLF10 M6LS135 v.1 Modifications: BLF10M6135_BLF10M6LS135 v.1 • The format of this document has been redesigned to comply with the new identity guidelines of Ampleon. • Legal texts have been adapted to the new company name where appropriate. 20140624 Product data sheet BLF10M6135_BLF10M6LS135#2 All information provided in this document is subject to legal disclaimers. Product data sheet Rev. 2 — 1 September 2015 - - © Ampleon The Netherlands B.V. 2015. All rights reserved. 9 of 12 BLF10M6135; BLF10M6LS135 Power LDMOS transistor 12. Legal information 12.1 Data sheet status Document status[1][2] Product status[3] Objective [short] data sheet Development This document contains data from the objective specification for product development. Preliminary [short] data sheet Qualification This document contains data from the preliminary specification. Product [short] data sheet Production This document contains the product specification. Definition [1] Please consult the most recently issued document before initiating or completing a design. [2] The term ‘short data sheet’ is explained in section “Definitions”. [3] The product status of device(s) described in this document may have changed since this document was published and may differ in case of multiple devices. The latest product status information is available on the Internet at URL http://www.ampleon.com. 12.2 Definitions Draft — The document is a draft version only. The content is still under internal review and subject to formal approval, which may result in modifications or additions. Ampleon does not give any representations or warranties as to the accuracy or completeness of information included herein and shall have no liability for the consequences of use of such information. Short data sheet — A short data sheet is an extract from a full data sheet with the same product type number(s) and title. A short data sheet is intended for quick reference only and should not be relied upon to contain detailed and full information. For detailed and full information see the relevant full data sheet, which is available on request via the local Ampleon sales office. In case of any inconsistency or conflict with the short data sheet, the full data sheet shall prevail. Product specification — The information and data provided in a Product data sheet shall define the specification of the product as agreed between Ampleon and its customer, unless Ampleon and customer have explicitly agreed otherwise in writing. In no event however, shall an agreement be valid in which the Ampleon product is deemed to offer functions and qualities beyond those described in the Product data sheet. 12.3 Disclaimers Limited warranty and liability — Information in this document is believed to be accurate and reliable. However, Ampleon does not give any representations or warranties, expressed or implied, as to the accuracy or completeness of such information and shall have no liability for the consequences of use of such information. Ampleon takes no responsibility for the content in this document if provided by an information source outside of Ampleon. In no event shall Ampleon be liable for any indirect, incidental, punitive, special or consequential damages (including - without limitation - lost profits, lost savings, business interruption, costs related to the removal or replacement of any products or rework charges) whether or not such damages are based on tort (including negligence), warranty, breach of contract or any other legal theory. Notwithstanding any damages that customer might incur for any reason whatsoever, Ampleon’ aggregate and cumulative liability towards customer for the products described herein shall be limited in accordance with the Terms and conditions of commercial sale of Ampleon. Right to make changes — Ampleon reserves the right to make changes to information published in this document, including without limitation specifications and product descriptions, at any time and without notice. This document supersedes and replaces all information supplied prior to the publication hereof. Suitability for use — Ampleon products are not designed, authorized or warranted to be suitable for use in life support, life-critical or safety-critical systems or equipment, nor in applications where failure or malfunction of an Ampleon product can reasonably be expected to result in personal injury, death or severe property or environmental damage. Ampleon and its suppliers accept no liability for inclusion and/or use of Ampleon products in such equipment or applications and therefore such inclusion and/or use is at the customer’s own risk. Applications — Applications that are described herein for any of these products are for illustrative purposes only. Ampleon makes no representation or warranty that such applications will be suitable for the specified use without further testing or modification. Customers are responsible for the design and operation of their applications and products using Ampleon products, and Ampleon accepts no liability for any assistance with applications or customer product design. It is customer’s sole responsibility to determine whether the Ampleon product is suitable and fit for the customer’s applications and products planned, as well as for the planned application and use of customer’s third party customer(s). Customers should provide appropriate design and operating safeguards to minimize the risks associated with their applications and products. Ampleon does not accept any liability related to any default, damage, costs or problem which is based on any weakness or default in the customer’s applications or products, or the application or use by customer’s third party customer(s). Customer is responsible for doing all necessary testing for the customer’s applications and products using Ampleon products in order to avoid a default of the applications and the products or of the application or use by customer’s third party customer(s). Ampleon does not accept any liability in this respect. Limiting values — Stress above one or more limiting values (as defined in the Absolute Maximum Ratings System of IEC 60134) will cause permanent damage to the device. Limiting values are stress ratings only and (proper) operation of the device at these or any other conditions above those given in the Recommended operating conditions section (if present) or the Characteristics sections of this document is not warranted. Constant or repeated exposure to limiting values will permanently and irreversibly affect the quality and reliability of the device. Terms and conditions of commercial sale — Ampleon products are sold subject to the general terms and conditions of commercial sale, as published at http://www.ampleon.com/terms, unless otherwise agreed in a valid written individual agreement. In case an individual agreement is concluded only the terms and conditions of the respective agreement shall apply. Ampleon hereby expressly objects to applying the customer’s general terms and conditions with regard to the purchase of Ampleon products by customer. No offer to sell or license — Nothing in this document may be interpreted or construed as an offer to sell products that is open for acceptance or the grant, conveyance or implication of any license under any copyrights, patents or other industrial or intellectual property rights. Export control — This document as well as the item(s) described herein may be subject to export control regulations. Export might require a prior authorization from competent authorities. BLF10M6135_BLF10M6LS135#2 All information provided in this document is subject to legal disclaimers. Product data sheet Rev. 2 — 1 September 2015 © Ampleon The Netherlands B.V. 2015. All rights reserved. 10 of 12 BLF10M6135; BLF10M6LS135 Power LDMOS transistor Non-automotive qualified products — Unless this data sheet expressly states that this specific Ampleon product is automotive qualified, the product is not suitable for automotive use. It is neither qualified nor tested in accordance with automotive testing or application requirements. Ampleon accepts no liability for inclusion and/or use of non-automotive qualified products in automotive equipment or applications. In the event that customer uses the product for design-in and use in automotive applications to automotive specifications and standards, customer (a) shall use the product without Ampleon’ warranty of the product for such automotive applications, use and specifications, and (b) whenever customer uses the product for automotive applications beyond Ampleon’ specifications such use shall be solely at customer’s own risk, and (c) customer fully indemnifies Ampleon for any liability, damages or failed product claims resulting from customer design and use of the product for automotive applications beyond Ampleon’ standard warranty and Ampleon’ product specifications. 12.4 Trademarks Notice: All referenced brands, product names, service names and trademarks are the property of their respective owners. Any reference or use of any ‘NXP’ trademark in this document or in or on the surface of Ampleon products does not result in any claim, liability or entitlement vis-à-vis the owner of this trademark. Ampleon is no longer part of the NXP group of companies and any reference to or use of the ‘NXP’ trademarks will be replaced by reference to or use of Ampleon’s own Any reference or use of any ‘NXP’ trademark in this document or in or on the surface of Ampleon products does not result in any claim, liability or entitlement vis-à-vis the owner of this trademark. Ampleon is no longer part of the NXP group of companies and any reference to or use of the ‘NXP’ trademarks will be replaced by reference to or use of Ampleon’s own trademarks. Translations — A non-English (translated) version of a document is for reference only. The English version shall prevail in case of any discrepancy between the translated and English versions. 13. Contact information For more information, please visit: http://www.ampleon.com For sales office addresses, please visit: http://www.ampleon.com/sales BLF10M6135_BLF10M6LS135#2 All information provided in this document is subject to legal disclaimers. Product data sheet Rev. 2 — 1 September 2015 © Ampleon The Netherlands B.V. 2015. All rights reserved. 11 of 12 BLF10M6135; BLF10M6LS135 Power LDMOS transistor 14. Contents 1 1.1 1.2 1.3 2 3 4 5 6 7 7.1 7.2 7.3 7.3.1 7.3.2 7.3.3 8 9 10 11 12 12.1 12.2 12.3 12.4 13 14 Product profile . . . . . . . . . . . . . . . . . . . . . . . . . . 1 General description . . . . . . . . . . . . . . . . . . . . . 1 Features and benefits . . . . . . . . . . . . . . . . . . . . 1 Applications . . . . . . . . . . . . . . . . . . . . . . . . . . . 1 Pinning information . . . . . . . . . . . . . . . . . . . . . . 2 Ordering information . . . . . . . . . . . . . . . . . . . . . 2 Limiting values. . . . . . . . . . . . . . . . . . . . . . . . . . 2 Thermal characteristics . . . . . . . . . . . . . . . . . . 2 Characteristics . . . . . . . . . . . . . . . . . . . . . . . . . . 3 Test information . . . . . . . . . . . . . . . . . . . . . . . . . 3 Ruggedness in class-AB operation . . . . . . . . . 3 Test circuit information . . . . . . . . . . . . . . . . . . . 4 Graphical data . . . . . . . . . . . . . . . . . . . . . . . . . 5 1-Tone CW . . . . . . . . . . . . . . . . . . . . . . . . . . . . 5 2-Tone CW . . . . . . . . . . . . . . . . . . . . . . . . . . . . 6 2-Carrier W-CDMA . . . . . . . . . . . . . . . . . . . . . . 6 Package outline . . . . . . . . . . . . . . . . . . . . . . . . . 7 Handling information. . . . . . . . . . . . . . . . . . . . . 9 Abbreviations . . . . . . . . . . . . . . . . . . . . . . . . . . . 9 Revision history . . . . . . . . . . . . . . . . . . . . . . . . . 9 Legal information. . . . . . . . . . . . . . . . . . . . . . . 10 Data sheet status . . . . . . . . . . . . . . . . . . . . . . 10 Definitions . . . . . . . . . . . . . . . . . . . . . . . . . . . . 10 Disclaimers . . . . . . . . . . . . . . . . . . . . . . . . . . . 10 Trademarks. . . . . . . . . . . . . . . . . . . . . . . . . . . 11 Contact information. . . . . . . . . . . . . . . . . . . . . 11 Contents . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 12 Please be aware that important notices concerning this document and the product(s) described herein, have been included in section ‘Legal information’. © Ampleon The Netherlands B.V. 2015. All rights reserved. For more information, please visit: http://www.ampleon.com For sales office addresses, please visit: http://www.ampleon.com/sales Date of release: 1 September 2015 Document identifier: BLF10M6135_BLF10M6LS135#2
BLF10M6135U 价格&库存
很抱歉,暂时无法提供与“BLF10M6135U”相匹配的价格&库存,您可以联系我们找货
