BLF6H10LS-160,118
BLF6H10LS-160,118
    AMPLEON(安谱隆)
    SOT467B
    FET RF 104V 957.5MHZ
BLF6H10LS-160,118 数据手册
BLF6H10L-160; BLF6H10LS-160 Power LDMOS transistor Rev. 3 — 1 September 2015 Product data sheet 1. Product profile 1.1 General description A 160 W LDMOS RF power transistor for base station applications. The transistor can deliver 160 W from 729 MHz to 960 MHz. The excellent ruggedness and broadband performance of this device makes it ideal for base station applications. Table 1. Typical performance RF performance at VDS = 50 V in a common-source Class-AB test circuit. Test signal f (MHz) (mA) (V) (W) 2-carrier W-CDMA 960 600 50 38 [1] IDq VDS PL(AV) D ACPR (dB) (%) (dBc) 20 34 32[1] Gp Test signal: 3GPP test model 1; 64 DPCH; PAR = 8.4 dB at 0.01% probability on CCDF. 1.2 Features and benefits            Integrated ESD protection Excellent ruggedness High power gain High efficiency Excellent reliability Easy power control Low Rth providing excellent thermal stability Low output capacitance for wideband performance in Doherty applications Designed for low memory effects providing excellent digital pre-distortion capability No internal matching for broadband applications Compliant to Directive 2002/95/EC, regarding Restriction of Hazardous Substances (RoHS) 1.3 Applications  RF power applications for GSM, GSM EDGE, W-CDMA, CDMA base stations and multi carrier applications in the 729 MHz to 960 MHz frequency range BLF6H10L-160; BLF6H10LS-160 Power LDMOS transistor 2. Pinning information Table 2. Pinning Pin Description Simplified outline Graphic symbol BLF6H10L-160 (SOT467C) 1 drain 2 gate 3 source 1 1 [1] 3 2 3 2 sym112 BLF6H10LS-160 (SOT467B) 1 drain 2 gate 3 source 1 1 [1] 3 2 3 2 [1] sym112 Connected to flange. 3. Ordering information Table 3. Ordering information Type number Package BLF6H10L-160 Name Description Version - flanged ceramic package; 2 mounting holes; 2 leads SOT467C earless ceramic package; 2 leads SOT467B BLF6H10LS-160 - 4. Limiting values Table 4. Limiting values In accordance with the Absolute Maximum Rating System (IEC 60134). Symbol Parameter VDS Conditions Min Max Unit drain-source voltage - 104 V VGS gate-source voltage 0.5 +13 V Tstg storage temperature 65 +150 C Tj junction temperature - 200 C 5. Thermal characteristics Table 5. Symbol Rth(j-c) [1] Thermal characteristics Parameter Conditions thermal resistance from junction to case Tcase = 80 C; PL(AV) = 70 W [1] Typ Unit 0.95 K/W Rth(j-c) is measured under RF conditions. BLF6H10L-160_6H10LS-160#3 All information provided in this document is subject to legal disclaimers. Product data sheet Rev. 3 — 1 September 2015 © Ampleon The Netherlands B.V. 2015. All rights reserved. 2 of 12 BLF6H10L-160; BLF6H10LS-160 Power LDMOS transistor 6. Characteristics Table 6. DC characteristics Tj = 25 C unless otherwise specified. Symbol Parameter Conditions V(BR)DSS drain-source breakdown voltage VGS = 0 V; ID = 4.5 mA Min Typ Max Unit [1] 104 - - V [1] 1.4 1.7 2.4 V 1.4 A VGS(th) gate-source threshold voltage VDS = 10 V; ID = 450 mA IDSS drain leakage current VGS = 0 V; VDS = 28 V - - IDSX drain cut-off current VGS = VGSth + 3.75 V; VDS = 10 V - 20.47 - A IGSS gate leakage current VGS = 11 V; VDS = 0 V - - 140 nA gfs forward transconductance VDS = 10 V; ID = 135 mA [1] - 1.2 - S [1] - 0.2 -  RDS(on) [1] drain-source on-state resistance VGS = VGSth + 3.75 V; ID = 15.75 A ID is the drain current. Table 7. RF characteristics Test signal: 2-carrier W-CDMA; PAR = 8.5 dB at 0.01 % probability on the CCDF; carrier spacing 5 MHz; 3GPP test model 1; 1-64 DPCH; f1 = 952.5 MHz; f2 = 957.5 MHz; RF performance at VDS = 50 V; IDq = 600 mA; Tcase = 25 C; unless otherwise specified; in a class-AB production test circuit. Symbol Parameter Conditions Min Typ Max Unit Gp power gain PL(AV) = 38 W 18.8 20 - dB D drain efficiency PL(AV) = 38 W 29 34 - % RLin input return loss PL(AV) = 38 W - 12 6 dBc ACPR adjacent channel power ratio PL(AV) = 38 W - 32 27 dBc 7. Test information 7.1 Ruggedness in class-AB operation The BLF6H10L-160 and BLF6H10LS-160 are capable of withstanding a load mismatch corresponding to VSWR = 10 : 1 through all phases under the following conditions: VDS = 50 V; f = 860 MHz at rated power. 7.2 Impedance information Table 8. Typical impedance Simulated ZS and ZL test circuit impedances. f ZS ZL (MHz) () () 729 1.0 j0.8 3.1 + j1.7 760 1.0 j0.7 3.0 + j1.5 790 1.0 j0.7 2.8 + j1.4 820 1.0 j0.6 2.7 + j1.2 869 1.0 j0.5 2.5 + j1.0 BLF6H10L-160_6H10LS-160#3 All information provided in this document is subject to legal disclaimers. Product data sheet Rev. 3 — 1 September 2015 © Ampleon The Netherlands B.V. 2015. All rights reserved. 3 of 12 BLF6H10L-160; BLF6H10LS-160 Power LDMOS transistor Table 8. Typical impedance …continued Simulated ZS and ZL test circuit impedances. f ZS ZL (MHz) () () 881 1.0 j0.4 2.5 + j0.9 894 1.0 j0.4 2.4 + j0.8 920 1.0 j0.4 2.3 + j0.7 940 1.0 j0.4 2.3 + j0.6 960 1.0 j0.3 2.2 + j0.5 drain ZL gate ZS 001aaf059 Fig 1. Definition of transistor impedance 7.3 Test circuit information 95 mm 95 mm C4 C1 C9 + - R1 C5 C2 C8 80 mm C3 R2 C6 C10 + - C7 aaa-003623 See Table 9 for list of components. Fig 2. Component layout Table 9. List of components See Figure 2 for component layout. Component Description Value Remarks C1, C2, C3, C5, C6, C8 multilayer ceramic chip capacitor 47 pF ATC100B C4, C7 multilayer ceramic chip capacitor 1 F C9, C10 electrolytic capacitor 1000 F, 100 V R1, R2 chip resistor 9.1  BLF6H10L-160_6H10LS-160#3 All information provided in this document is subject to legal disclaimers. Product data sheet Rev. 3 — 1 September 2015 Murata Vishale Dale 0805 © Ampleon The Netherlands B.V. 2015. All rights reserved. 4 of 12 BLF6H10L-160; BLF6H10LS-160 Power LDMOS transistor 7.4 Graphical data 7.4.1 CW aaa-003624 21 Gp (dB) 60 ηD (%) ηD 20 50 19 40 18 30 17 20 Gp 16 0 40 80 120 160 PL (W) 10 200 VDS = 50 V; IDq = 600 mA; f = 960 MHz. Fig 3. Power gain and drain efficiency as function of load power; typical values 7.4.2 CW pulsed aaa-003625 21 Gp (dB) 65 ηD (%) ηD 20 55 19 45 18 35 Gp 17 16 0 50 100 150 200 PL (W) 25 15 250 VDS = 50 V; IDq = 600 mA; f = 960 MHz. Fig 4. Power gain and drain efficiency as function of load power; typical values BLF6H10L-160_6H10LS-160#3 All information provided in this document is subject to legal disclaimers. Product data sheet Rev. 3 — 1 September 2015 © Ampleon The Netherlands B.V. 2015. All rights reserved. 5 of 12 BLF6H10L-160; BLF6H10LS-160 Power LDMOS transistor 7.4.3 1-Carrier W-CDMA aaa-003631 20.5 Gp (dB) 45 ηD (%) 20.3 aaa-003632 -30 ACPR5M (dBc) ACPR5M -30 ACPR10M (dBc) 40 -35 -35 20.1 35 -40 -40 19.9 30 -45 -45 25 -50 20 -55 ηD Gp 19.7 19.5 15 25 35 45 55 PL (W) 65 Fig 5. -55 15 VDS = 50 V; IDq = 600 mA; f = 960 MHz. -50 ACPR10M 25 35 45 55 PL (W) 65 VDS = 50 V; IDq = 600 mA; f = 960 MHz. Power gain and drain efficiency as function of load power; typical values Fig 6. Adjacent channel power ratio (5 MHz) and Adjacent channel power ratio (10 MHz) as function of load power; typical values 7.4.4 2-carrier W-CDMA aaa-003633 20.2 Gp (dB) 45 ηD (%) 20 aaa-003634 -25 ACPR5M (dBc) 40 ηD ACPR5M -30 19.8 -30 35 -35 19.6 -35 ACPR10M 30 -40 Gp 19.4 20 15 25 35 45 55 PL (W) -40 25 19.2 -45 65 -45 15 VDS = 50 V; IDq = 600 mA; f1 = 952.5 MHz; f2 = 957.5 MHz. Fig 7. -25 ACPR10M (dBc) 25 35 45 55 PL (W) 65 VDS = 50 V; IDq = 600 mA; f1 = 952.5 MHz; f2 = 957.5 MHz. Power gain and drain efficiency as function of load power; typical values Fig 8. Adjacent channel power ratio (5 MHz) and Adjacent channel power ratio (10 MHz) as function of load power; typical values BLF6H10L-160_6H10LS-160#3 All information provided in this document is subject to legal disclaimers. Product data sheet Rev. 3 — 1 September 2015 © Ampleon The Netherlands B.V. 2015. All rights reserved. 6 of 12 BLF6H10L-160; BLF6H10LS-160 Power LDMOS transistor 8. Package outline Flanged ceramic package; 2 mounting holes; 2 leads SOT467C D A F 3 D1 U1 B q c C 1 E1 H U2 E A w1 M A M B M p 2 Q w2 M C M b 0 5 10 mm scale DIMENSIONS (millimetre dimensions are derived from the original inch dimensions) UNIT A b c D D1 E E1 F H p Q q U1 U2 w1 w2 mm 4.67 3.94 5.59 5.33 0.15 0.10 9.25 9.04 9.27 9.02 5.92 5.77 5.97 5.72 1.65 1.40 18.54 17.02 3.43 3.18 2.21 1.96 14.27 20.45 20.19 5.97 5.72 0.25 0.51 inch 0.184 0.220 0.006 0.155 0.210 0.004 0.364 0.365 0.356 0.355 0.233 0.227 0.235 0.065 0.225 0.055 0.73 0.67 0.135 0.087 0.805 0.235 0.562 0.010 0.020 0.125 0.077 0.795 0.225 OUTLINE VERSION REFERENCES IEC JEDEC EIAJ ISSUE DATE 99-12-28 12-05-02 SOT467C Fig 9. EUROPEAN PROJECTION Package outline SOT467C BLF6H10L-160_6H10LS-160#3 All information provided in this document is subject to legal disclaimers. Product data sheet Rev. 3 — 1 September 2015 © Ampleon The Netherlands B.V. 2015. All rights reserved. 7 of 12 BLF6H10L-160; BLF6H10LS-160 Power LDMOS transistor Earless ceramic package; 2 leads SOT467B D A F 3 D1 D U1 c 1 E1 U2 H E 2 w2 b A 0 5 mm scale Dimensions Unit(1) mm Q A b max 4.67 5.59 nom min 3.94 5.33 c D D1 E E1 0.15 9.25 9.27 5.92 5.97 0.10 9.04 9.02 5.77 5.72 F H Q U1 U2 1.65 18.29 2.21 9.78 5.97 1.40 17.27 1.96 9.53 5.72 w2 0.25 max 0.184 0.22 0.006 0.364 0.365 0.233 0.235 0.065 0.72 inches nom min 0.155 0.21 0.004 0.356 0.355 0.227 0.225 0.055 0.68 0.087 0.385 0.235 0.01 0.077 0.375 0.225 Note 1. millimeter dimensions are derived from the original inch dimensions. Outline version References IEC JEDEC JEITA sot467b_po European projection Issue date 11-08-18 12-05-01 SOT467B Fig 10. Package outline SOT467B BLF6H10L-160_6H10LS-160#3 All information provided in this document is subject to legal disclaimers. Product data sheet Rev. 3 — 1 September 2015 © Ampleon The Netherlands B.V. 2015. All rights reserved. 8 of 12 BLF6H10L-160; BLF6H10LS-160 Power LDMOS transistor 9. Handling information CAUTION This device is sensitive to ElectroStatic Discharge (ESD). Observe precautions for handling electrostatic sensitive devices. Such precautions are described in the ANSI/ESD S20.20, IEC/ST 61340-5, JESD625-A or equivalent standards. 10. Abbreviations Table 10. Abbreviations Acronym Description 3GPP 3rd Generation Partnership Project CDMA Code Division Multiple Access CCDF Complementary Cumulative Distribution Function DPCH Dedicated Physical CHannel EDGE Enhanced Data rates for GSM Evolution GSM Global System for Mobile Communications HF High Frequency LDMOS Laterally Diffused Metal-Oxide Semiconductor PAR Peak-to-Average Ratio VSWR Voltage Standing-Wave Ratio W-CDMA Wideband Code Division Multiple Access 11. Revision history Table 11. Revision history Document ID Release date Data sheet status Change notice Supersedes BLF6H10L-160_6H10LS-160#3 20150901 - Modifications: Product data sheet BLF6H10L-160_6H10LS-160 v.2 • The format of this document has been redesigned to comply with the new identity guidelines of Ampleon. • Legal texts have been adapted to the new company name where appropriate. BLF6H10L-160_6H10LS-160 v.2 20121212 Product data sheet - BLF6H10L-160_6H10LS-160 v.1 20120210 Objective data sheet - BLF6H10L-160_6H10LS-160#3 All information provided in this document is subject to legal disclaimers. Product data sheet Rev. 3 — 1 September 2015 BLF6H10L-160_6H10LS-160 v.1 - © Ampleon The Netherlands B.V. 2015. All rights reserved. 9 of 12 BLF6H10L-160; BLF6H10LS-160 Power LDMOS transistor 12. Legal information 12.1 Data sheet status Document status[1][2] Product status[3] Objective [short] data sheet Development This document contains data from the objective specification for product development. Preliminary [short] data sheet Qualification This document contains data from the preliminary specification. Product [short] data sheet Production This document contains the product specification. Definition [1] Please consult the most recently issued document before initiating or completing a design. [2] The term ‘short data sheet’ is explained in section “Definitions”. [3] The product status of device(s) described in this document may have changed since this document was published and may differ in case of multiple devices. The latest product status information is available on the Internet at URL http://www.ampleon.com. 12.2 Definitions Draft — The document is a draft version only. The content is still under internal review and subject to formal approval, which may result in modifications or additions. Ampleon does not give any representations or warranties as to the accuracy or completeness of information included herein and shall have no liability for the consequences of use of such information. Short data sheet — A short data sheet is an extract from a full data sheet with the same product type number(s) and title. A short data sheet is intended for quick reference only and should not be relied upon to contain detailed and full information. For detailed and full information see the relevant full data sheet, which is available on request via the local Ampleon sales office. In case of any inconsistency or conflict with the short data sheet, the full data sheet shall prevail. Product specification — The information and data provided in a Product data sheet shall define the specification of the product as agreed between Ampleon and its customer, unless Ampleon and customer have explicitly agreed otherwise in writing. In no event however, shall an agreement be valid in which the Ampleon product is deemed to offer functions and qualities beyond those described in the Product data sheet. 12.3 Disclaimers Limited warranty and liability — Information in this document is believed to be accurate and reliable. However, Ampleon does not give any representations or warranties, expressed or implied, as to the accuracy or completeness of such information and shall have no liability for the consequences of use of such information. Ampleon takes no responsibility for the content in this document if provided by an information source outside of Ampleon. In no event shall Ampleon be liable for any indirect, incidental, punitive, special or consequential damages (including - without limitation - lost profits, lost savings, business interruption, costs related to the removal or replacement of any products or rework charges) whether or not such damages are based on tort (including negligence), warranty, breach of contract or any other legal theory. Notwithstanding any damages that customer might incur for any reason whatsoever, Ampleon’ aggregate and cumulative liability towards customer for the products described herein shall be limited in accordance with the Terms and conditions of commercial sale of Ampleon. Right to make changes — Ampleon reserves the right to make changes to information published in this document, including without limitation specifications and product descriptions, at any time and without notice. This document supersedes and replaces all information supplied prior to the publication hereof. Suitability for use — Ampleon products are not designed, authorized or warranted to be suitable for use in life support, life-critical or safety-critical systems or equipment, nor in applications where failure or malfunction of an Ampleon product can reasonably be expected to result in personal injury, death or severe property or environmental damage. Ampleon and its suppliers accept no liability for inclusion and/or use of Ampleon products in such equipment or applications and therefore such inclusion and/or use is at the customer’s own risk. Applications — Applications that are described herein for any of these products are for illustrative purposes only. Ampleon makes no representation or warranty that such applications will be suitable for the specified use without further testing or modification. Customers are responsible for the design and operation of their applications and products using Ampleon products, and Ampleon accepts no liability for any assistance with applications or customer product design. It is customer’s sole responsibility to determine whether the Ampleon product is suitable and fit for the customer’s applications and products planned, as well as for the planned application and use of customer’s third party customer(s). Customers should provide appropriate design and operating safeguards to minimize the risks associated with their applications and products. Ampleon does not accept any liability related to any default, damage, costs or problem which is based on any weakness or default in the customer’s applications or products, or the application or use by customer’s third party customer(s). Customer is responsible for doing all necessary testing for the customer’s applications and products using Ampleon products in order to avoid a default of the applications and the products or of the application or use by customer’s third party customer(s). Ampleon does not accept any liability in this respect. Limiting values — Stress above one or more limiting values (as defined in the Absolute Maximum Ratings System of IEC 60134) will cause permanent damage to the device. Limiting values are stress ratings only and (proper) operation of the device at these or any other conditions above those given in the Recommended operating conditions section (if present) or the Characteristics sections of this document is not warranted. Constant or repeated exposure to limiting values will permanently and irreversibly affect the quality and reliability of the device. Terms and conditions of commercial sale — Ampleon products are sold subject to the general terms and conditions of commercial sale, as published at http://www.ampleon.com/terms, unless otherwise agreed in a valid written individual agreement. In case an individual agreement is concluded only the terms and conditions of the respective agreement shall apply. Ampleon hereby expressly objects to applying the customer’s general terms and conditions with regard to the purchase of Ampleon products by customer. No offer to sell or license — Nothing in this document may be interpreted or construed as an offer to sell products that is open for acceptance or the grant, conveyance or implication of any license under any copyrights, patents or other industrial or intellectual property rights. Export control — This document as well as the item(s) described herein may be subject to export control regulations. Export might require a prior authorization from competent authorities. BLF6H10L-160_6H10LS-160#3 All information provided in this document is subject to legal disclaimers. Product data sheet Rev. 3 — 1 September 2015 © Ampleon The Netherlands B.V. 2015. All rights reserved. 10 of 12 BLF6H10L-160; BLF6H10LS-160 Power LDMOS transistor Non-automotive qualified products — Unless this data sheet expressly states that this specific Ampleon product is automotive qualified, the product is not suitable for automotive use. It is neither qualified nor tested in accordance with automotive testing or application requirements. Ampleon accepts no liability for inclusion and/or use of non-automotive qualified products in automotive equipment or applications. In the event that customer uses the product for design-in and use in automotive applications to automotive specifications and standards, customer (a) shall use the product without Ampleon’ warranty of the product for such automotive applications, use and specifications, and (b) whenever customer uses the product for automotive applications beyond Ampleon’ specifications such use shall be solely at customer’s own risk, and (c) customer fully indemnifies Ampleon for any liability, damages or failed product claims resulting from customer design and use of the product for automotive applications beyond Ampleon’ standard warranty and Ampleon’ product specifications. 12.4 Trademarks Notice: All referenced brands, product names, service names and trademarks are the property of their respective owners. Any reference or use of any ‘NXP’ trademark in this document or in or on the surface of Ampleon products does not result in any claim, liability or entitlement vis-à-vis the owner of this trademark. Ampleon is no longer part of the NXP group of companies and any reference to or use of the ‘NXP’ trademarks will be replaced by reference to or use of Ampleon’s own Any reference or use of any ‘NXP’ trademark in this document or in or on the surface of Ampleon products does not result in any claim, liability or entitlement vis-à-vis the owner of this trademark. Ampleon is no longer part of the NXP group of companies and any reference to or use of the ‘NXP’ trademarks will be replaced by reference to or use of Ampleon’s own trademarks. Translations — A non-English (translated) version of a document is for reference only. The English version shall prevail in case of any discrepancy between the translated and English versions. 13. Contact information For more information, please visit: http://www.ampleon.com For sales office addresses, please visit: http://www.ampleon.com/sales BLF6H10L-160_6H10LS-160#3 All information provided in this document is subject to legal disclaimers. Product data sheet Rev. 3 — 1 September 2015 © Ampleon The Netherlands B.V. 2015. All rights reserved. 11 of 12 BLF6H10L-160; BLF6H10LS-160 Power LDMOS transistor 14. Contents 1 1.1 1.2 1.3 2 3 4 5 6 7 7.1 7.2 7.3 7.4 7.4.1 7.4.2 7.4.3 7.4.4 8 9 10 11 12 12.1 12.2 12.3 12.4 13 14 Product profile . . . . . . . . . . . . . . . . . . . . . . . . . . 1 General description . . . . . . . . . . . . . . . . . . . . . 1 Features and benefits . . . . . . . . . . . . . . . . . . . . 1 Applications . . . . . . . . . . . . . . . . . . . . . . . . . . . 1 Pinning information . . . . . . . . . . . . . . . . . . . . . . 2 Ordering information . . . . . . . . . . . . . . . . . . . . . 2 Limiting values. . . . . . . . . . . . . . . . . . . . . . . . . . 2 Thermal characteristics . . . . . . . . . . . . . . . . . . 2 Characteristics . . . . . . . . . . . . . . . . . . . . . . . . . . 3 Test information . . . . . . . . . . . . . . . . . . . . . . . . . 3 Ruggedness in class-AB operation . . . . . . . . . 3 Impedance information . . . . . . . . . . . . . . . . . . . 3 Test circuit information . . . . . . . . . . . . . . . . . . . 4 Graphical data . . . . . . . . . . . . . . . . . . . . . . . . . 5 CW . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 5 CW pulsed . . . . . . . . . . . . . . . . . . . . . . . . . . . . 5 1-Carrier W-CDMA . . . . . . . . . . . . . . . . . . . . . . 6 2-carrier W-CDMA . . . . . . . . . . . . . . . . . . . . . . 6 Package outline . . . . . . . . . . . . . . . . . . . . . . . . . 7 Handling information. . . . . . . . . . . . . . . . . . . . . 9 Abbreviations . . . . . . . . . . . . . . . . . . . . . . . . . . . 9 Revision history . . . . . . . . . . . . . . . . . . . . . . . . . 9 Legal information. . . . . . . . . . . . . . . . . . . . . . . 10 Data sheet status . . . . . . . . . . . . . . . . . . . . . . 10 Definitions . . . . . . . . . . . . . . . . . . . . . . . . . . . . 10 Disclaimers . . . . . . . . . . . . . . . . . . . . . . . . . . . 10 Trademarks. . . . . . . . . . . . . . . . . . . . . . . . . . . 11 Contact information. . . . . . . . . . . . . . . . . . . . . 11 Contents . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 12 Please be aware that important notices concerning this document and the product(s) described herein, have been included in section ‘Legal information’. © Ampleon The Netherlands B.V. 2015. All rights reserved. For more information, please visit: http://www.ampleon.com For sales office addresses, please visit: http://www.ampleon.com/sales Date of release: 1 September 2015 Document identifier: BLF6H10L-160_6H10LS-160#3
BLF6H10LS-160,118 价格&库存
很抱歉,暂时无法提供与“BLF6H10LS-160,118”相匹配的价格&库存,您可以联系我们找货
