BLF8G20LS-160VU
BLF8G20LS-160VU
    AMPLEON(安谱隆)
    SOT-1239B
    RFFETLDMOS65V20DBSOT1239B
BLF8G20LS-160VU 数据手册
BLF8G20LS-160V Power LDMOS transistor Rev. 3 — 1 September 2015 Product data sheet 1. Product profile 1.1 General description 160 W LDMOS power transistor with improved video bandwidth for base station applications at frequencies from 1800 MHz to 2000 MHz. Table 1. Typical performance Typical RF performance at Tcase = 25 C in a common source class-AB production test circuit. Test signal 2-carrier W-CDMA [1] f IDq VDS PL(AV) Gp D ACPR (MHz) (mA) (V) (W) (dB) (%) (dBc) 1805 to 1880 800 28 35.5 20 34 29 [1] Test signal: 3GPP test model 1; 64 DPCH; PAR = 8.4 dB at 0.01 % probability on CCDF; carrier spacing = 5 MHz. 1.2 Features and benefits          Excellent ruggedness High efficiency Low thermal resistance providing excellent thermal stability Designed for broadband operation Lower output capacitance for improved performance in Doherty applications Designed for low memory effects providing excellent pre-distortability Internally matched for ease of use Integrated ESD protection Compliant to Directive 2002/95/EC, regarding Restriction of Hazardous Substances (RoHS) 1.3 Applications  RF power amplifier for multi systems base stations and multi carrier applications in the 1800 MHz to 2000 MHz frequency range BLF8G20LS-160V Power LDMOS transistor 2. Pinning information Table 2. Pinning Pin Description 1 drain 2 gate 3 source 4 decoupling lead 5 decoupling lead 6 n.c. 7 n.c. [1] Simplified outline Graphic symbol 4 1 5 1 4,5 6,7 [1] 2 3 3 aaa-003619 2 6 7 Connected to flange. 3. Ordering information Table 3. Ordering information Type number Package Name Description Version BLF8G20LS-160V - SOT1239B earless flanged LDMOST ceramic package; 6 leads 4. Limiting values Table 4. Limiting values In accordance with the Absolute Maximum Rating System (IEC 60134). Symbol Parameter VDS drain-source voltage VGS gate-source voltage Tstg storage temperature Min [1] junction temperature Tj [1] Conditions Max Unit - 65 V 0.5 +13 V 65 +150 C - 225 C Continuous use at maximum temperature will affect the reliability, for details refer to the on-line MTF calculator. 5. Thermal characteristics Table 5. BLF8G20LS-160V#3 Product data sheet Thermal characteristics Symbol Parameter Conditions Typ Rth(j-c) thermal resistance from junction to case Tcase = 80 C; PL = 25 W; VDS = 28 V; IDq = 800 mA 0.290 K/W All information provided in this document is subject to legal disclaimers. Rev. 3 — 1 September 2015 Unit © Ampleon The Netherlands B.V. 2015. All rights reserved. 2 of 13 BLF8G20LS-160V Power LDMOS transistor 6. Characteristics Table 6. DC characteristics Tj = 25 C, unless otherwise specified. Symbol Parameter Conditions Min V(BR)DSS drain-source breakdown voltage VGS = 0 V; ID = 1.8 mA Typ Max Unit 65 - - V VGS(th) gate-source threshold voltage VDS = 10 V; ID = 180 mA 1.5 1.9 2.3 V VGSq gate-source quiescent voltage VDS = 28 V; ID = 800 mA 1.7 2.1 2.5 V IDSS drain leakage current VGS = 0 V; VDS = 28 V - - 3.6 A IDSX drain cut-off current VGS = VGS(th) + 3.75 V; VDS = 10 V - 33.8 - A IGSS gate leakage current VGS = 9 V; VDS = 0 V - - 360 nA gfs forward transconductance VDS = 10 V; ID = 180 mA - 1.6 - S RDS(on) drain-source on-state resistance VGS = VGS(th) + 3.75 V; ID = 6.3 A - 0.07 -  Table 7. RF characteristics Test signal: 2-carrier W-CDMA; PAR = 8.4 dB at 0.01 % probability on CCDF; 3GPP test model 1; 64 DPCH; f1 = 1807.5 MHz; f2 = 1812.5 MHz; f3 = 1872.5 MHz; f4 = 1877.5 MHz; RF performance at VDS = 28 V; IDq = 800 mA; Tcase = 25 C; unless otherwise specified; in a production circuit. Symbol Parameter Conditions Min Typ Max Unit Gp power gain PL(AV) = 35.5 W 19 20 - dB D drain efficiency PL(AV) = 35.5 W 30 34 - % RLin input return loss PL(AV) = 35.5 W - 10 7 dB ACPR adjacent channel power ratio PL(AV) = 35.5 W - 29 25 dBc 7. Test information 7.1 Ruggedness in class-AB operation The BLF8G20LS-160V is capable of withstanding a load mismatch corresponding to VSWR = 10 : 1 through all phases under the following conditions: VDS = 28 V; IDq = 800 mA; PL = 140 W (CW); f = 1805 MHz. 7.2 Impedance information Table 8. Typical impedance Measured load-pull data; IDq = 800 mA; VDS = 28 V; typical values unless otherwise specified. f ZS [1] ZL[1] (MHz) () () 1805 1.248  j3.066 1.19  j2.749 1842.5 2.372  j3.119 1.19  j2.431 1880 3.025  j4.124 1.19  j2.431 [1] BLF8G20LS-160V#3 Product data sheet ZS and ZL defined in Figure 1. All information provided in this document is subject to legal disclaimers. Rev. 3 — 1 September 2015 © Ampleon The Netherlands B.V. 2015. All rights reserved. 3 of 13 BLF8G20LS-160V Power LDMOS transistor drain ZL gate ZS 001aaf059 Fig 1. Definition of transistor impedance 7.3 VBW in a class-AB operation The BLF8G20LS-160V has a video bandwidth of 70 MHz (typical) when measured in a class-AB test circuit operating at a center frequency of 1843 MHz for VDS = 28 V and IDq = 800 mA. aaa-013311 -10 IMD (dBc) -20 (1) (2) IMD3 -30 (1) (2) IMD5 -40 (1) (2) IMD7 -50 -60 -70 1 10 102 carrier spacing (MHz) 103 VDS = 28 V; IDq = 800 mA; fc = 1842.5 MHz. (1) low (2) high Fig 2. BLF8G20LS-160V#3 Product data sheet VBW capacity in class-AB test circuit All information provided in this document is subject to legal disclaimers. Rev. 3 — 1 September 2015 © Ampleon The Netherlands B.V. 2015. All rights reserved. 4 of 13 BLF8G20LS-160V Power LDMOS transistor 7.4 Test circuit 50 mm C2 C1 50 mm C2 C2 C2 C1 C3 R1 C1 C1 60 mm C2 R1 C1 C2 C2 C2 C1 C3 aaa-013326 Printed-Circuit Board (PCB): Rogers 4350B with a thickness of 0.76 mm. See Table 9 for a list of components. Fig 3. Component layout Table 9. List of components See Figure 3 for component layout. BLF8G20LS-160V#3 Product data sheet Component Description Value Remarks C1 multilayer ceramic chip capacitor 15 pF ATC100B C2 multilayer ceramic chip capacitor 10 F Murata C3 multilayer ceramic chip capacitor 2.2 F Murata R1 chip resistor 5.1  Vishay Dale SMD 0805 All information provided in this document is subject to legal disclaimers. Rev. 3 — 1 September 2015 © Ampleon The Netherlands B.V. 2015. All rights reserved. 5 of 13 BLF8G20LS-160V Power LDMOS transistor 7.5 Graphical data 7.5.1 Pulsed CW aaa-013301 24 70 Gp (dB) ηD (%) 22 aaa-013302 -2 RLin (dB) 60 Gp -6 20 50 (1) (1) (2) (2) (3) (3) 18 (3) 40 16 -10 30 -14 ηD 14 (2) 20 (1) 12 10 39 41 43 45 47 49 51 53 PL (dBm) -18 55 39 VDS = 28 V; IDq = 800 mA. 41 43 (1) f = 1805 MHz (2) f = 1842.5 MHz (2) f = 1842.5 MHz (3) f = 1880 MHz (3) f = 1880 MHz Power gain and drain efficiency as function of output power; typical values BLF8G20LS-160V#3 Product data sheet 47 49 51 53 PL (dBm) 55 VDS = 28 V; IDq = 800 mA. (1) f = 1805 MHz Fig 4. 45 Fig 5. Input return loss as a function of out power; typical values All information provided in this document is subject to legal disclaimers. Rev. 3 — 1 September 2015 © Ampleon The Netherlands B.V. 2015. All rights reserved. 6 of 13 BLF8G20LS-160V Power LDMOS transistor 7.5.2 1-Carrier W-CDMA aaa-013303 22 50 -10 ACPR5M (dBc) -20 40 -30 30 -40 14 20 -50 12 10 -60 0 -70 Gp (dB) 60 ηD (%) Gp 20 (1) (1) (2) (2) (3) (3) 18 16 aaa-013304 ηD 10 42 43 44 45 46 47 48 49 PL (dBm) 50 (1) (2) (3) 42 VDS = 28 V; IDq = 800 mA. 43 44 46 47 48 49 PL (dBm) 50 VDS = 28 V; IDq = 800 mA. (1) f = 1805 MHz (1) f = 1805 MHz (2) f = 1842.5 MHz (2) f = 1842.5 MHz (3) f = 1880 MHz (3) f = 1880 MHz Fig 6. 45 Power gain and drain efficiency as a function of output power; typical values Fig 7. Adjacent channel power ratio (5 MHz) as a function of output power; typical values aaa-013305 8 PAR (dB) 7 6 (1) (2) (3) 5 4 42 43 44 45 46 47 48 49 PL (dBm) 50 VDS = 28 V; IDq = 800 mA. (1) f = 1805 MHz (2) f = 1842.5 MHz (3) f = 1880 MHz Fig 8. Peak-to-average ratio as a function of output power; typical values BLF8G20LS-160V#3 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 3 — 1 September 2015 © Ampleon The Netherlands B.V. 2015. All rights reserved. 7 of 13 BLF8G20LS-160V Power LDMOS transistor 7.5.3 2-Carrier W-CDMA aaa-013309 22 Gp (dB) 40 ηD (%) Gp (3) (3) (2) (2) (1) (1) 18 aaa-013310 -24 ACPR5M (dBc) 30 -28 20 -32 ηD 14 (1) 10 10 -36 (2) (3) 6 0 42 43 44 45 46 47 PL (dBm) 48 VDS = 28 V; IDq = 800 mA. -40 42 43 44 (1) f = 1805 MHz (2) f = 1842.5 MHz (2) f = 1842.5 MHz (3) f = 1880 MHz (3) f = 1880 MHz Power gain and drain efficiency as function of output power; typical values BLF8G20LS-160V#3 Product data sheet 46 47 PL (dBm) 48 VDS = 28 V; IDq = 800 mA. (1) f = 1805 MHz Fig 9. 45 Fig 10. Adjacent channel power ratio (5 MHz) as a function of output power; typical values All information provided in this document is subject to legal disclaimers. Rev. 3 — 1 September 2015 © Ampleon The Netherlands B.V. 2015. All rights reserved. 8 of 13 BLF8G20LS-160V Power LDMOS transistor 8. Package outline Earless flanged LDMOST ceramic package; 6 leads SOT1239B D F A 3 L D1 D c U1 4 1 5 α H U2 Z Z1 6 2 b 7 w2 b1 0 E E1 5 D Q 10 mm scale Dimensions Unit(1) mm A max 4.75 nom min 3.45 b b1 c D D1 E 1.83 12.83 0.20 20.02 19.96 9.53 F E1 9.53 H L 1.14 19.94 3.56 Q U1 U2 w2 1.70 20.70 9.91 Z Z1 α 4.60 9.53 64° 4.32 8.71 60° 0.51 1.57 12.57 0.12 19.61 19.66 9.27 9.25 0.89 18.92 3.30 1.45 20.45 9.65 max 0.187 0.072 0.505 0.008 0.788 0.786 0.375 0.375 0.045 0.785 0.140 0.067 0.815 0.390 0.181 0.375 64° 0.02 inches nom min 0.136 0.062 0.495 0.005 0.772 0.774 0.365 0.364 0.035 0.745 0.130 0.057 0.805 0.380 0.170 0.343 60° Note 1. Millimeter dimensions are derived from the original inch dimensions. Outline version References IEC JEDEC JEITA sot1239b_po European projection Issue date 13-07-09 13-10-28 SOT1239B Fig 11. Package outline SOT1239B BLF8G20LS-160V#3 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 3 — 1 September 2015 © Ampleon The Netherlands B.V. 2015. All rights reserved. 9 of 13 BLF8G20LS-160V Power LDMOS transistor 9. Handling information CAUTION This device is sensitive to ElectroStatic Discharge (ESD). Observe precautions for handling electrostatic sensitive devices. Such precautions are described in the ANSI/ESD S20.20, IEC/ST 61340-5, JESD625-A or equivalent standards. 10. Abbreviations Table 10. Abbreviations Acronym Description 3GPP 3rd Generation Partnership Project CCDF Complementary Cumulative Distribution Function CW Continuous Wave DPCH Dedicated Physical CHannel ESD ElectroStatic Discharge LDMOS Laterally Diffused Metal Oxide Semiconductor LDMOST Laterally Diffused Metal Oxide Semiconductor Transistor MTF Median Time to Failure PAR Peak-to-Average Ratio SMD Surface Mounted Device VBW Video BandWidth VSWR Voltage Standing Wave Ratio W-CDMA Wideband Code Division Multiple Access 11. Revision history Table 11. Revision history Document ID Release date Data sheet status BLF8G20LS-160V#3 20150901 Product data sheet Modifications: Change notice Supersedes BLF8G20LS-160V v.2 • The format of this document has been redesigned to comply with the new identity guidelines of Ampleon. • Legal texts have been adapted to the new company name where appropriate. BLF8G20LS-160V v.2 20140624 Product data sheet - BLF8G20LS-160V v.1 BLF8G20LS-160V v.1 20140305 Objective data sheet - - BLF8G20LS-160V#3 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 3 — 1 September 2015 © Ampleon The Netherlands B.V. 2015. All rights reserved. 10 of 13 BLF8G20LS-160V Power LDMOS transistor 12. Legal information 12.1 Data sheet status Document status[1][2] Product status[3] Objective [short] data sheet Development This document contains data from the objective specification for product development. Preliminary [short] data sheet Qualification This document contains data from the preliminary specification. Product [short] data sheet Production This document contains the product specification. Definition [1] Please consult the most recently issued document before initiating or completing a design. [2] The term ‘short data sheet’ is explained in section “Definitions”. [3] The product status of device(s) described in this document may have changed since this document was published and may differ in case of multiple devices. The latest product status information is available on the Internet at URL http://www.ampleon.com. 12.2 Definitions Draft — The document is a draft version only. The content is still under internal review and subject to formal approval, which may result in modifications or additions. Ampleon does not give any representations or warranties as to the accuracy or completeness of information included herein and shall have no liability for the consequences of use of such information. Short data sheet — A short data sheet is an extract from a full data sheet with the same product type number(s) and title. A short data sheet is intended for quick reference only and should not be relied upon to contain detailed and full information. For detailed and full information see the relevant full data sheet, which is available on request via the local Ampleon sales office. In case of any inconsistency or conflict with the short data sheet, the full data sheet shall prevail. Product specification — The information and data provided in a Product data sheet shall define the specification of the product as agreed between Ampleon and its customer, unless Ampleon and customer have explicitly agreed otherwise in writing. In no event however, shall an agreement be valid in which the Ampleon product is deemed to offer functions and qualities beyond those described in the Product data sheet. 12.3 Disclaimers Limited warranty and liability — Information in this document is believed to be accurate and reliable. However, Ampleon does not give any representations or warranties, expressed or implied, as to the accuracy or completeness of such information and shall have no liability for the consequences of use of such information. Ampleon takes no responsibility for the content in this document if provided by an information source outside of Ampleon. In no event shall Ampleon be liable for any indirect, incidental, punitive, special or consequential damages (including - without limitation - lost profits, lost savings, business interruption, costs related to the removal or replacement of any products or rework charges) whether or not such damages are based on tort (including negligence), warranty, breach of contract or any other legal theory. Notwithstanding any damages that customer might incur for any reason whatsoever, Ampleon’ aggregate and cumulative liability towards customer for the products described herein shall be limited in accordance with the Terms and conditions of commercial sale of Ampleon. Right to make changes — Ampleon reserves the right to make changes to information published in this document, including without limitation specifications and product descriptions, at any time and without notice. This document supersedes and replaces all information supplied prior to the publication hereof. Suitability for use — Ampleon products are not designed, authorized or warranted to be suitable for use in life support, life-critical or safety-critical systems or equipment, nor in applications where failure or malfunction of an BLF8G20LS-160V#3 Product data sheet Ampleon product can reasonably be expected to result in personal injury, death or severe property or environmental damage. Ampleon and its suppliers accept no liability for inclusion and/or use of Ampleon products in such equipment or applications and therefore such inclusion and/or use is at the customer’s own risk. Applications — Applications that are described herein for any of these products are for illustrative purposes only. Ampleon makes no representation or warranty that such applications will be suitable for the specified use without further testing or modification. Customers are responsible for the design and operation of their applications and products using Ampleon products, and Ampleon accepts no liability for any assistance with applications or customer product design. It is customer’s sole responsibility to determine whether the Ampleon product is suitable and fit for the customer’s applications and products planned, as well as for the planned application and use of customer’s third party customer(s). Customers should provide appropriate design and operating safeguards to minimize the risks associated with their applications and products. Ampleon does not accept any liability related to any default, damage, costs or problem which is based on any weakness or default in the customer’s applications or products, or the application or use by customer’s third party customer(s). Customer is responsible for doing all necessary testing for the customer’s applications and products using Ampleon products in order to avoid a default of the applications and the products or of the application or use by customer’s third party customer(s). Ampleon does not accept any liability in this respect. Limiting values — Stress above one or more limiting values (as defined in the Absolute Maximum Ratings System of IEC 60134) will cause permanent damage to the device. Limiting values are stress ratings only and (proper) operation of the device at these or any other conditions above those given in the Recommended operating conditions section (if present) or the Characteristics sections of this document is not warranted. Constant or repeated exposure to limiting values will permanently and irreversibly affect the quality and reliability of the device. Terms and conditions of commercial sale — Ampleon products are sold subject to the general terms and conditions of commercial sale, as published at http://www.ampleon.com/terms, unless otherwise agreed in a valid written individual agreement. In case an individual agreement is concluded only the terms and conditions of the respective agreement shall apply. Ampleon hereby expressly objects to applying the customer’s general terms and conditions with regard to the purchase of Ampleon products by customer. No offer to sell or license — Nothing in this document may be interpreted or construed as an offer to sell products that is open for acceptance or the grant, conveyance or implication of any license under any copyrights, patents or other industrial or intellectual property rights. Export control — This document as well as the item(s) described herein may be subject to export control regulations. Export might require a prior authorization from competent authorities. All information provided in this document is subject to legal disclaimers. Rev. 3 — 1 September 2015 © Ampleon The Netherlands B.V. 2015. All rights reserved. 11 of 13 BLF8G20LS-160V Power LDMOS transistor Non-automotive qualified products — Unless this data sheet expressly states that this specific Ampleon product is automotive qualified, the product is not suitable for automotive use. It is neither qualified nor tested in accordance with automotive testing or application requirements. Ampleon accepts no liability for inclusion and/or use of non-automotive qualified products in automotive equipment or applications. In the event that customer uses the product for design-in and use in automotive applications to automotive specifications and standards, customer (a) shall use the product without Ampleon’ warranty of the product for such automotive applications, use and specifications, and (b) whenever customer uses the product for automotive applications beyond Ampleon’ specifications such use shall be solely at customer’s own risk, and (c) customer fully indemnifies Ampleon for any liability, damages or failed product claims resulting from customer design and use of the product for automotive applications beyond Ampleon’ standard warranty and Ampleon’ product specifications. 12.4 Trademarks Notice: All referenced brands, product names, service names and trademarks are the property of their respective owners. Any reference or use of any ‘NXP’ trademark in this document or in or on the surface of Ampleon products does not result in any claim, liability or entitlement vis-à-vis the owner of this trademark. Ampleon is no longer part of the NXP group of companies and any reference to or use of the ‘NXP’ trademarks will be replaced by reference to or use of Ampleon’s own Any reference or use of any ‘NXP’ trademark in this document or in or on the surface of Ampleon products does not result in any claim, liability or entitlement vis-à-vis the owner of this trademark. Ampleon is no longer part of the NXP group of companies and any reference to or use of the ‘NXP’ trademarks will be replaced by reference to or use of Ampleon’s own trademarks. Translations — A non-English (translated) version of a document is for reference only. The English version shall prevail in case of any discrepancy between the translated and English versions. 13. Contact information For more information, please visit: http://www.ampleon.com BLF8G20LS-160V#3 Product data sheet For sales office addresses, please visit: http://www.ampleon.com/sales All information provided in this document is subject to legal disclaimers. Rev. 3 — 1 September 2015 © Ampleon The Netherlands B.V. 2015. All rights reserved. 12 of 13 BLF8G20LS-160V Power LDMOS transistor 14. Contents 1 1.1 1.2 1.3 2 3 4 5 6 7 7.1 7.2 7.3 7.4 7.5 7.5.1 7.5.2 7.5.3 8 9 10 11 12 12.1 12.2 12.3 12.4 13 14 Product profile . . . . . . . . . . . . . . . . . . . . . . . . . . 1 General description . . . . . . . . . . . . . . . . . . . . . 1 Features and benefits . . . . . . . . . . . . . . . . . . . . 1 Applications . . . . . . . . . . . . . . . . . . . . . . . . . . . 1 Pinning information . . . . . . . . . . . . . . . . . . . . . . 2 Ordering information . . . . . . . . . . . . . . . . . . . . . 2 Limiting values. . . . . . . . . . . . . . . . . . . . . . . . . . 2 Thermal characteristics . . . . . . . . . . . . . . . . . . 2 Characteristics . . . . . . . . . . . . . . . . . . . . . . . . . . 3 Test information . . . . . . . . . . . . . . . . . . . . . . . . . 3 Ruggedness in class-AB operation . . . . . . . . . 3 Impedance information . . . . . . . . . . . . . . . . . . . 3 VBW in a class-AB operation . . . . . . . . . . . . . . 4 Test circuit. . . . . . . . . . . . . . . . . . . . . . . . . . . . . 5 Graphical data . . . . . . . . . . . . . . . . . . . . . . . . . 6 Pulsed CW . . . . . . . . . . . . . . . . . . . . . . . . . . . . 6 1-Carrier W-CDMA . . . . . . . . . . . . . . . . . . . . . . 7 2-Carrier W-CDMA . . . . . . . . . . . . . . . . . . . . . . 8 Package outline . . . . . . . . . . . . . . . . . . . . . . . . . 9 Handling information. . . . . . . . . . . . . . . . . . . . 10 Abbreviations . . . . . . . . . . . . . . . . . . . . . . . . . . 10 Revision history . . . . . . . . . . . . . . . . . . . . . . . . 10 Legal information. . . . . . . . . . . . . . . . . . . . . . . 11 Data sheet status . . . . . . . . . . . . . . . . . . . . . . 11 Definitions . . . . . . . . . . . . . . . . . . . . . . . . . . . . 11 Disclaimers . . . . . . . . . . . . . . . . . . . . . . . . . . . 11 Trademarks. . . . . . . . . . . . . . . . . . . . . . . . . . . 12 Contact information. . . . . . . . . . . . . . . . . . . . . 12 Contents . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 13 Please be aware that important notices concerning this document and the product(s) described herein, have been included in section ‘Legal information’. © Ampleon The Netherlands B.V. 2015. All rights reserved. For more information, please visit: http://www.ampleon.com For sales office addresses, please visit: http://www.ampleon.com/sales Date of release: 1 September 2015 Document identifier: BLF8G20LS-160V#3
BLF8G20LS-160VU
PDF文档中包含以下信息: 1. 物料型号:型号为LM5111。
2. 器件简介:LM5111是一款由国家半导体公司生产的同步降压DC/DC转换器,具有高效率、低噪声、低静态电流等特点。
3. 引脚分配:共有8个引脚,包括输入电压、输出电压、地、使能、反馈、开关、补偿和参考电压。
4. 参数特性:输入电压范围为4.5V至38V,输出电压可调,最大输出电流为3A。
5. 功能详解:详细介绍了器件的工作原理、控制方式、保护功能等。
6. 应用信息:适用于便携式电子设备、电池供电设备等。
7. 封装信息:提供多种封装选项,包括SOIC8、MSOP8等。
BLF8G20LS-160VU 价格&库存
很抱歉,暂时无法提供与“BLF8G20LS-160VU”相匹配的价格&库存,您可以联系我们找货
