BLF8G22LS-205VU
BLF8G22LS-205VU
    AMPLEON(安谱隆)
    SOT-1239B
    BLF8G22LS-205VU
BLF8G22LS-205VU 数据手册
BLF8G22LS-205V Power LDMOS transistor Rev. 2 — 1 September 2015 Product data sheet 1. Product profile 1.1 General description 205 W LDMOS power transistor with improved video bandwidth for base station applications at frequencies from 2100 MHz to 2200 MHz. Table 1. Typical performance Typical RF performance at Tcase = 25 C in a common source class-AB production test circuit. Test signal 1-carrier W-CDMA [1] f IDq VDS PL(AV) Gp D ACPR5M (MHz) (mA) (V) (W) (dB) (%) (dBc) 2110 to 2170 1500 28 50 18.3 32.5 32 [1] Test signal: 3GPP test model 1; 64 DPCH; PAR = 7.2 dB at 0.01 % probability on CCDF. 1.2 Features and benefits          Excellent ruggedness High efficiency Low thermal resistance providing excellent thermal stability Designed for broadband operation Lower output capacitance for improved performance in Doherty applications Designed for low memory effects providing excellent pre-distortability Internally matched for ease of use Integrated ESD protection Compliant to Directive 2002/95/EC, regarding Restriction of Hazardous Substances (RoHS) 1.3 Applications  RF power amplifiers for base stations and multi carrier applications in the 2100 MHz to 2200 MHz frequency range BLF8G22LS-205V Power LDMOS transistor 2. Pinning information Table 2. Pinning Pin Description 1 drain 2 gate 3 source 4 decoupling lead 5 decoupling lead 6 n.c. 7 n.c. [1] Simplified outline 4 Graphic symbol 1 5 1 4,5 6,7 [1] 2 3 3 aaa-003619 2 6 7 Connected to flange. 3. Ordering information Table 3. Ordering information Type number Package Name Description Version BLF8G22LS-205V - SOT1239B earless flanged LDMOST ceramic package; 6 leads 4. Limiting values Table 4. Limiting values In accordance with the Absolute Maximum Rating System (IEC 60134). Symbol Parameter Conditions Min Max Unit VDS drain-source voltage - 65 V VGS gate-source voltage 0.5 +13 V Tstg storage temperature 65 +150 C - 225 C junction temperature Tj [1] [1] Continuous use at maximum temperature will affect the reliability, for details refer to the on-line MTF calculator. 5. Thermal characteristics Table 5. BLF8G22LS-205V Product data sheet Thermal characteristics Symbol Parameter Conditions Typ Unit Rth(j-c) thermal resistance from junction to case Tcase = 80 C; PL = 56 W; VDS = 28 V; IDq = 1200 mA 0.26 K/W All information provided in this document is subject to legal disclaimers. Rev. 2 — 1 September 2015 © Ampleon Netherlands B.V. 2016. All rights reserved. 2 of 13 BLF8G22LS-205V Power LDMOS transistor 6. Characteristics Table 6. DC characteristics Tj = 25 C, unless otherwise specified. Symbol Parameter Conditions V(BR)DSS drain-source breakdown voltage VGS = 0 V; ID = 3.3 mA Min Typ Max Unit 65 - - V VGS(th) gate-source threshold voltage VDS = 10 V; ID = 330 mA 1.5 1.9 2.3 V VGSq gate-source quiescent voltage VDS = 28 V; ID = 1650 mA 1.7 2.1 2.5 V IDSS drain leakage current VGS = 0 V; VDS = 28 V - - 3.6 A IDSX drain cut-off current VGS = VGS(th) + 3.75 V; VDS = 10 V - 60 - A IGSS gate leakage current VGS = 11 V; VDS = 0 V - - 360 nA gfs forward transconductance VDS = 10 V; ID = 330 mA - 2.9 - S RDS(on) drain-source on-state resistance VGS = VGS(th) + 3.75 V; ID = 11.6 A - 0.04 -  Table 7. RF characteristics Test signal: 1-carrier W-CDMA; PAR = 7.2 dB at 0.01 % probability on CCDF; 3GPP test model 1; 64 DPCH; f1 = 2110 MHz; f2 = 2170 MHz; RF performance at VDS = 28 V; IDq = 1200 mA; Tcase = 25 C; unless otherwise specified; in a production circuit. Symbol Parameter Conditions Min Typ Max Unit Gp power gain PL(AV) = 50.1 W 17.1 18.3 - dB D drain efficiency PL(AV) = 50.1 W 27.5 32.5 - % RLin input return loss PL(AV) = 50.1 W - 10 6 dB ACPR adjacent channel power ratio PL(AV) = 50.1 W - 30 25 dBc 7. Test information 7.1 Ruggedness in Doherty operation The BLF8G22LS-205V is capable of withstanding a load mismatch corresponding to VSWR = 10 : 1 through all phases under the following conditions: VDS = 28 V; IDq = 1200 mA; PL = 140 W (W-CDMA); f = 2110 MHz. BLF8G22LS-205V Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 2 — 1 September 2015 © Ampleon Netherlands B.V. 2016. All rights reserved. 3 of 13 BLF8G22LS-205V Power LDMOS transistor 7.2 Impedance information Table 8. Typical impedance Measured load-pull data; IDq = 1800 mA; VDS = 28 V; typical values unless otherwise specified. f ZS [1] ZL[1] PL [2] D [2] Gp [2] (MHz) () () (W) (%) (dB) Maximum power load 2110 1.80  j4.05 1.2  j2.75 56.00 56.61 15.57 2140 2.24  j5.00 1.2  j2.75 55.95 55.85 15.71 2170 2.90  j4.50 1.2  j2.75 55.88 56.05 16.03 Maximum drain efficiency load 2110 1.80  j4.05 1.60  j1.34 54.08 65.84 18.12 2140 2.24  j5.00 1.52  j1.57 54.38 64.88 18.06 2170 2.90  j4.50 1.41  j1.77 54.58 64.24 18.08 [1] ZS and ZL defined in Figure 1. [2] at 3 dB gain compression drain ZL gate ZS 001aaf059 Fig 1. Definition of transistor impedance 7.3 VBW in a class-AB operation The BLF8G22LS-205V shows 110 MHz (typical) video bandwidth in class-AB test circuit in 2140 MHz at VDS = 28 V; IDq = 1500 mA. BLF8G22LS-205V Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 2 — 1 September 2015 © Ampleon Netherlands B.V. 2016. All rights reserved. 4 of 13 BLF8G22LS-205V Power LDMOS transistor 7.4 Test circuit 50 mm C7 R1 C3 50 mm C9 C4 C13 C10 C14 C1 C17 C2 60 mm C12 C8 R2 C5 C11 C6 C15 C18 C16 aaa-019313 Printed-Circuit Board (PCB): Rogers RO4350B; thickness = 0.76 mm. See Table 9 for a list of components. Fig 2. Component layout for test circuit Table 9. List of components See Figure 2 for component layout. Component BLF8G22LS-205V Product data sheet Description Value C1, C2, C3, C4, C5, C6 multilayer ceramic chip capacitor 20 pF C7, C8, C9, C10, C11, C12, C14, C16 multilayer ceramic chip capacitor 10 F, 50 V C13, C15 multilayer ceramic chip capacitor 1 F, 50 v C17, C18 electrolytic capacitor 2200 F, 63 V R1, R2 chip resistor 5.1  All information provided in this document is subject to legal disclaimers. Rev. 2 — 1 September 2015 Remarks © Ampleon Netherlands B.V. 2016. All rights reserved. 5 of 13 BLF8G22LS-205V Power LDMOS transistor 7.5 Graphical data 7.5.1 Pulsed CW aaa-019314 21 Gp (dB) 60 ηD (%) Gp 19 50 (1) (1) (2) (2) (3) (3) 17 40 15 30 13 20 ηD 11 10 9 0 39 41 43 45 47 49 51 53 PL (dBm) 55 VDS = 28 V; IDq = 1200 mA. (1) f = 2110 MHz (2) f = 2140 MHz (3) f = 2170 MHz Fig 3. Power gain and drain efficiency as function of output power; typical values 7.5.2 CW aaa-019315 21 Gp (dB) 60 ηD (%) Gp 19 50 (1) (1) (2) (2) (3) (3) 17 40 15 30 13 20 ηD 11 10 9 0 39 41 43 45 47 49 51 53 PL (dBm) 55 VDS = 28 V; IDq = 1200 mA. (1) f = 2110 MHz (2) f = 2140 MHz (3) f = 2170 MHz Fig 4. BLF8G22LS-205V Product data sheet Power gain and drain efficiency as function of output power; typical values All information provided in this document is subject to legal disclaimers. Rev. 2 — 1 September 2015 © Ampleon Netherlands B.V. 2016. All rights reserved. 6 of 13 BLF8G22LS-205V Power LDMOS transistor 7.5.3 1-Carrier W-CDMA aaa-019316 21 45 Gp (dB) 20 40 Gp (3) aaa-019317 -30 ACPR5M (dBc) -32.5 ηD (%) (2) -35 19 35 (1) (2) (3) (1) -37.5 18 30 17 -40 (1) (2) (3) ηD 25 16 -42.5 20 51 51.5 52 52.5 53 53.5 PL (dBm) -45 54 51 VDS = 28 V; IDq = 1200 mA. 51.5 52.5 53 53.5 PL (dBm) 54 VDS = 28 V; IDq = 1200 mA. (1) f = 2110 MHz (1) f = 2110 MHz (2) f = 2140 MHz (2) f = 2140 MHz (3) f = 2170 MHz (3) f = 2170 MHz Fig 5. 52 Power gain and drain efficiency as function of output power; typical values Fig 6. Adjacent channel power ratio (5 MHz) as a function of output power; typical values aaa-019318 8 PAR (dBc) 7 (1) (2) (3) 6 5 4 3 2 51 51.5 52 52.5 53 53.5 PL (dBm) 54 VDS = 28 V; IDq = 1200 mA. (1) f = 2110 MHz (2) f = 2140 MHz (3) f = 2170 MHz Fig 7. Peak-to-average ratio as a function of output power; typical values BLF8G22LS-205V Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 2 — 1 September 2015 © Ampleon Netherlands B.V. 2016. All rights reserved. 7 of 13 BLF8G22LS-205V Power LDMOS transistor 7.5.4 2-Tone VBW aaa-019319 0 IMD (dBc) (1) (2) -20 IMD3 (1) (2) -40 IMD5 IMD7 (1) (2) -60 -80 1 10 102 carrier spacing (MHz) 103 VDS = 28 V; IDq = 1200 mA. (1) low (2) high Fig 8. BLF8G22LS-205V Product data sheet VBW capability in class-AB test circuit All information provided in this document is subject to legal disclaimers. Rev. 2 — 1 September 2015 © Ampleon Netherlands B.V. 2016. All rights reserved. 8 of 13 BLF8G22LS-205V Power LDMOS transistor 8. Package outline Earless flanged LDMOST ceramic package; 6 leads SOT1239B D F A 3 L D1 D c U1 4 1 5 α H U2 Z Z1 6 2 b 7 w2 b1 0 E E1 5 D Q 10 mm scale Dimensions Unit(1) mm A max 4.75 nom min 3.45 b b1 c D D1 E 1.83 12.83 0.20 20.02 19.96 9.53 F E1 9.53 H L 1.14 19.94 3.56 Q U1 U2 w2 1.70 20.70 9.91 Z Z1 α 4.60 9.53 64° 4.32 8.71 60° 0.51 1.57 12.57 0.12 19.61 19.66 9.27 9.25 0.89 18.92 3.30 1.45 20.45 9.65 max 0.187 0.072 0.505 0.008 0.788 0.786 0.375 0.375 0.045 0.785 0.140 0.067 0.815 0.390 0.181 0.375 64° 0.02 inches nom min 0.136 0.062 0.495 0.005 0.772 0.774 0.365 0.364 0.035 0.745 0.130 0.057 0.805 0.380 0.170 0.343 60° Note 1. Millimeter dimensions are derived from the original inch dimensions. Outline version References IEC JEDEC JEITA Issue date 13-07-09 13-10-28 SOT1239B Fig 9. sot1239b_po European projection Package outline SOT1239B BLF8G22LS-205V Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 2 — 1 September 2015 © Ampleon Netherlands B.V. 2016. All rights reserved. 9 of 13 BLF8G22LS-205V Power LDMOS transistor 9. Handling information CAUTION This device is sensitive to ElectroStatic Discharge (ESD). Observe precautions for handling electrostatic sensitive devices. Such precautions are described in the ANSI/ESD S20.20, IEC/ST 61340-5, JESD625-A or equivalent standards. 10. Abbreviations Table 10. Abbreviations Acronym Description 3GPP 3rd Partnership Project CW Continuous Wave CCDF Complementary Cumulative Distribution Function DPCH Dedicated Physical CHannel ESD ElectroStatic Discharge LDMOS Laterally Diffused Metal-Oxide Semiconductor LDMOST Laterally Diffused Metal-Oxide Semiconductor Transistor MTF Median Time to Failure PAR Peak-to-Average Ratio VBW Video BandWidth VSWR Voltage Standing Wave Ratio W-CDMA Wideband Code Division Multiple Access 11. Revision history Table 11. Revision history Document ID Release date Data sheet status Change notice Supersedes BLF8G22LS-205V v.2 20150901 - Modifications: BLF8G22LS-205V v.1 BLF8G22LS-205V Product data sheet Product data sheet BLF8G22LS-205V v.1 • The format of this document has been redesigned to comply with the new identity guidelines of Ampleon • Legal texts have been adapted to the new company name where appropriate 20150901 Product data sheet - All information provided in this document is subject to legal disclaimers. Rev. 2 — 1 September 2015 - © Ampleon Netherlands B.V. 2016. All rights reserved. 10 of 13 BLF8G22LS-205V Power LDMOS transistor 12. Legal information 12.1 Data sheet status Document status[1][2] Product status[3] Definition Objective [short] data sheet Development This document contains data from the objective specification for product development. Preliminary [short] data sheet Qualification This document contains data from the preliminary specification. Product [short] data sheet Production This document contains the product specification. [1] Please consult the most recently issued document before initiating or completing a design. [2] The term ‘short data sheet’ is explained in section “Definitions”. [3] The product status of device(s) described in this document may have changed since this document was published and may differ in case of multiple devices. The latest product status information is available on the Internet at URL http://www.ampleon.com. 12.2 Definitions Draft — The document is a draft version only. The content is still under internal review and subject to formal approval, which may result in modifications or additions. Ampleon does not give any representations or warranties as to the accuracy or completeness of information included herein and shall have no liability for the consequences of use of such information. Short data sheet — A short data sheet is an extract from a full data sheet with the same product type number(s) and title. A short data sheet is intended for quick reference only and should not be relied upon to contain detailed and full information. For detailed and full information see the relevant full data sheet, which is available on request via the local Ampleon sales office. In case of any inconsistency or conflict with the short data sheet, the full data sheet shall prevail. Product specification — The information and data provided in a Product data sheet shall define the specification of the product as agreed between Ampleon and its customer, unless Ampleon and customer have explicitly agreed otherwise in writing. In no event however, shall an agreement be valid in which the Ampleon product is deemed to offer functions and qualities beyond those described in the Product data sheet. 12.3 Disclaimers Limited warranty and liability — Information in this document is believed to be accurate and reliable. However, Ampleon does not give any representations or warranties, expressed or implied, as to the accuracy or completeness of such information and shall have no liability for the consequences of use of such information. Ampleon takes no responsibility for the content in this document if provided by an information source outside of Ampleon. In no event shall Ampleon be liable for any indirect, incidental, punitive, special or consequential damages (including - without limitation - lost profits, lost savings, business interruption, costs related to the removal or replacement of any products or rework charges) whether or not such damages are based on tort (including negligence), warranty, breach of contract or any other legal theory. Notwithstanding any damages that customer might incur for any reason whatsoever, Ampleon’s aggregate and cumulative liability towards customer for the products described herein shall be limited in accordance with the Terms and conditions of commercial sale of Ampleon. Right to make changes — Ampleon reserves the right to make changes to information published in this document, including without limitation specifications and product descriptions, at any time and without notice. This document supersedes and replaces all information supplied prior to the publication hereof. Suitability for use — Ampleon products are not designed, authorized or warranted to be suitable for use in life support, life-critical or safety-critical systems or equipment, nor in applications where failure or malfunction of an BLF8G22LS-205V Product data sheet Ampleon product can reasonably be expected to result in personal injury, death or severe property or environmental damage. Ampleon and its suppliers accept no liability for inclusion and/or use of Ampleon products in such equipment or applications and therefore such inclusion and/or use is at the customer’s own risk. Applications — Applications that are described herein for any of these products are for illustrative purposes only. Ampleon makes no representation or warranty that such applications will be suitable for the specified use without further testing or modification. Customers are responsible for the design and operation of their applications and products using Ampleon products, and Ampleon accepts no liability for any assistance with applications or customer product design. It is customer’s sole responsibility to determine whether the Ampleon product is suitable and fit for the customer’s applications and products planned, as well as for the planned application and use of customer’s third party customer(s). Customers should provide appropriate design and operating safeguards to minimize the risks associated with their applications and products. Ampleon does not accept any liability related to any default, damage, costs or problem which is based on any weakness or default in the customer’s applications or products, or the application or use by customer’s third party customer(s). Customer is responsible for doing all necessary testing for the customer’s applications and products using Ampleon products in order to avoid a default of the applications and the products or of the application or use by customer’s third party customer(s). Ampleon does not accept any liability in this respect. Limiting values — Stress above one or more limiting values (as defined in the Absolute Maximum Ratings System of IEC 60134) will cause permanent damage to the device. Limiting values are stress ratings only and (proper) operation of the device at these or any other conditions above those given in the Recommended operating conditions section (if present) or the Characteristics sections of this document is not warranted. Constant or repeated exposure to limiting values will permanently and irreversibly affect the quality and reliability of the device. Terms and conditions of commercial sale — Ampleon products are sold subject to the general terms and conditions of commercial sale, as published at http://www.ampleon.com/terms, unless otherwise agreed in a valid written individual agreement. In case an individual agreement is concluded only the terms and conditions of the respective agreement shall apply. Ampleon hereby expressly objects to applying the customer’s general terms and conditions with regard to the purchase of Ampleon products by customer. No offer to sell or license — Nothing in this document may be interpreted or construed as an offer to sell products that is open for acceptance or the grant, conveyance or implication of any license under any copyrights, patents or other industrial or intellectual property rights. Export control — This document as well as the item(s) described herein may be subject to export control regulations. Export might require a prior authorization from competent authorities. All information provided in this document is subject to legal disclaimers. Rev. 2 — 1 September 2015 © Ampleon Netherlands B.V. 2016. All rights reserved. 11 of 13 BLF8G22LS-205V Power LDMOS transistor Non-automotive qualified products — Unless this data sheet expressly states that this specific Ampleon product is automotive qualified, the product is not suitable for automotive use. It is neither qualified nor tested in accordance with automotive testing or application requirements. Ampleon accepts no liability for inclusion and/or use of non-automotive qualified products in automotive equipment or applications. In the event that customer uses the product for design-in and use in automotive applications to automotive specifications and standards, customer (a) shall use the product without Ampleon’ warranty of the product for such automotive applications, use and specifications, and (b) whenever customer uses the product for automotive applications beyond Ampleon’ specifications such use shall be solely at customer’s own risk, and (c) customer fully indemnifies Ampleon for any liability, damages or failed product claims resulting from customer design and use of the product for automotive applications beyond Ampleon’ standard warranty and Ampleon’ product specifications. Translations — A non-English (translated) version of a document is for reference only. The English version shall prevail in case of any discrepancy between the translated and English versions. 12.4 Trademarks Notice: All referenced brands, product names, service names and trademarks are the property of their respective owners. Any reference or use of any ‘NXP’ trademark in this document or in or on the surface of Ampleon products does not result in any claim, liability or entitlement vis-à-vis the owner of this trademark. Ampleon is no longer part of the NXP group of companies and any reference to or use of the ‘NXP’ trademarks will be replaced by reference to or use of Ampleon’s own trademarks. 13. Contact information For more information, please visit: http://www.ampleon.com For sales office addresses, please visit: http://www.ampleon.com/sales BLF8G22LS-205V Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 2 — 1 September 2015 © Ampleon Netherlands B.V. 2016. All rights reserved. 12 of 13 BLF8G22LS-205V Power LDMOS transistor 14. Contents 1 1.1 1.2 1.3 2 3 4 5 6 7 7.1 7.2 7.3 7.4 7.5 7.5.1 7.5.2 7.5.3 7.5.4 8 9 10 11 12 12.1 12.2 12.3 12.4 13 14 Product profile . . . . . . . . . . . . . . . . . . . . . . . . . . 1 General description . . . . . . . . . . . . . . . . . . . . . 1 Features and benefits . . . . . . . . . . . . . . . . . . . . 1 Applications . . . . . . . . . . . . . . . . . . . . . . . . . . . 1 Pinning information . . . . . . . . . . . . . . . . . . . . . . 2 Ordering information . . . . . . . . . . . . . . . . . . . . . 2 Limiting values. . . . . . . . . . . . . . . . . . . . . . . . . . 2 Thermal characteristics . . . . . . . . . . . . . . . . . . 2 Characteristics . . . . . . . . . . . . . . . . . . . . . . . . . . 3 Test information . . . . . . . . . . . . . . . . . . . . . . . . . 3 Ruggedness in Doherty operation . . . . . . . . . . 3 Impedance information . . . . . . . . . . . . . . . . . . . 4 VBW in a class-AB operation . . . . . . . . . . . . . . 4 Test circuit. . . . . . . . . . . . . . . . . . . . . . . . . . . . . 5 Graphical data . . . . . . . . . . . . . . . . . . . . . . . . . 6 Pulsed CW . . . . . . . . . . . . . . . . . . . . . . . . . . . . 6 CW . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 6 1-Carrier W-CDMA . . . . . . . . . . . . . . . . . . . . . . 7 2-Tone VBW . . . . . . . . . . . . . . . . . . . . . . . . . . . 8 Package outline . . . . . . . . . . . . . . . . . . . . . . . . . 9 Handling information. . . . . . . . . . . . . . . . . . . . 10 Abbreviations . . . . . . . . . . . . . . . . . . . . . . . . . . 10 Revision history . . . . . . . . . . . . . . . . . . . . . . . . 10 Legal information. . . . . . . . . . . . . . . . . . . . . . . 11 Data sheet status . . . . . . . . . . . . . . . . . . . . . . 11 Definitions . . . . . . . . . . . . . . . . . . . . . . . . . . . . 11 Disclaimers . . . . . . . . . . . . . . . . . . . . . . . . . . . 11 Trademarks. . . . . . . . . . . . . . . . . . . . . . . . . . . 12 Contact information. . . . . . . . . . . . . . . . . . . . . 12 Contents . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 13 Please be aware that important notices concerning this document and the product(s) described herein, have been included in section ‘Legal information’. © Ampleon Netherlands B.V. 2016. All rights reserved. For more information, please visit: http://www.ampleon.com For sales office addresses, please visit: http://www.ampleon.com/sales Date of release: 1 September 2015 Document identifier: BLF8G22LS-205V
BLF8G22LS-205VU 价格&库存
很抱歉,暂时无法提供与“BLF8G22LS-205VU”相匹配的价格&库存,您可以联系我们找货
