BLC9G15LS-400AVTY
BLC9G15LS-400AVTY
    AMPLEON(安谱隆)
    SOT-1258-3
    BLC9G15LS-400AVTY
BLC9G15LS-400AVTY 数据手册
BLC9G15LS-400AVT Power LDMOS transistor Rev. 3 — 24 November 2017 Product data sheet 1. Product profile 1.1 General description 400 W LDMOS packaged asymmetric Doherty power transistor for base station applications at frequencies from 1452 MHz to 1511 MHz. Table 1. Typical performance Typical RF performance at Tcase = 25 C in an asymmetrical Doherty production test circuit. VDS = 32 V; IDq = 810 mA (main); VGS(amp)peak = 0.5 V, unless otherwise specified. Test signal 1-carrier W-CDMA [1] f VDS PL(AV) Gp D ACPR (MHz) (V) (W) (dB) (%) (dBc) 1452 to 1511 32 93 16.5 48 35 [1] Test signal: 1-carrier W-CDMA; 3GPP test model 1; 64 DPCH; PAR = 9.6 dB at 0.01 % probability on CCDF. 1.2 Features and benefits         Excellent ruggedness High efficiency Low thermal resistance providing excellent thermal stability Lower output capacitance for improved performance in Doherty applications Designed for low memory effects providing excellent digital pre-distortion capability Internally matched for ease of use Integrated ESD protection Compliant to Directive 2002/95/EC, regarding Restriction of Hazardous Substances (RoHS) 1.3 Applications  RF power amplifiers for base stations and multi carrier applications in the 1452 MHz to 1511 MHz frequency range BLC9G15LS-400AVT Power LDMOS transistor 2. Pinning information Table 2. Pinning Pin Description 1 drain2 (peak) 2 drain1 (main) 3 gate1 (main) 4 gate2 (peak) Simplified outline 7 1 2, 7 6 5 3 3 5 4 4 [1] 5 source 6 video decoupling (peak) 7 video decoupling (main) [1] 2 Graphic symbol 1, 6 aaa-014884 Connected to flange. 3. Ordering information Table 3. Ordering information Type number Package BLC9G15LS-400AVT Name Description Version - air cavity plastic earless flanged package; 6 leads SOT1258-1 4. Limiting values Table 4. Limiting values In accordance with the Absolute Maximum Rating System (IEC 60134). Symbol Parameter VDS drain-source voltage Min Max Unit - 65 V VGS(amp)main main amplifier gate-source voltage 6 +13 V VGS(amp)peak peak amplifier gate-source voltage 6 +13 V 65 +150 C junction temperature [1] - 225 C case temperature [1] 40 +125 C storage temperature Tstg Tj Tcase [1] Conditions operating Continuous use at maximum temperature will affect the reliability, for details refer to the online MTF calculator. 5. Thermal characteristics Table 5. Thermal characteristics Symbol Parameter Rth(j-c) BLC9G15LS-400AVT Product data sheet Conditions Typ Unit PL = 93 W 0.31 k/W PL = 117 W 0.29 k/W thermal resistance from junction VDS = 32 V; IDq = 980 mA (main); to case VGS(amp)peak = 0,4 V; Tcase = 80 C All information provided in this document is subject to legal disclaimers. Rev. 3 — 24 November 2017 © Ampleon Netherlands B.V. 2017. All rights reserved. 2 of 16 BLC9G15LS-400AVT Power LDMOS transistor 6. Characteristics Table 6. DC characteristics Tj = 25 C unless otherwise specified. Symbol Parameter Conditions Min Typ Max Unit 65 - - V 2.0 2.5 V Main device V(BR)DSS drain-source breakdown voltage VGS = 0 V; ID = 1.62 mA VGS(th) gate-source threshold voltage VDS = 10 V; ID = 162 mA 1.5 VGSq gate-source quiescent voltage VDS = 32 V; ID = 810 mA 1.65 2.15 2.65 V IDSS drain leakage current VGS = 0 V; VDS = 32 V - - 2.8 A IDSX drain cut-off current VGS = VGS(th) + 3.75 V - 32 - A IGSS gate leakage current VGS = 11 V; VDS = 0 V - - 280 nA gfs forward transconductance VDS = 10 V; ID = 8.1 A - 11.5 - RDS(on) drain-source on-state resistance VGS = VGS(th) + 3.75 V; ID = 5.67 A - 85 149 m 65 - - V 2.0 2.5 V S Peak device V(BR)DSS drain-source breakdown voltage VGS = 0 V; ID = 3.0 mA VGS(th) gate-source threshold voltage VDS = 10 V; ID = 300 mA 1.5 VGSq gate-source quiescent voltage VDS = 32 V; ID = 1500 mA 1.65 2.15 2.65 V IDSS drain leakage current VGS = 0 V; VDS = 32 V - - 2.8 A IDSX drain cut-off current VGS = VGS(th) + 3.75 V - 52 - A IGSS gate leakage current VGS = 11 V; VDS = 0 V - - 280 nA gfs forward transconductance VDS = 10 V; ID = 15 A - 20.5 - S RDS(on) drain-source on-state resistance VGS = VGS(th) + 3.75 V; ID = 10.5 A - 46 85 m Table 7. RF characteristics Test signal: 1-carrier W-CDMA; PAR = 9.6 dB at 0.01 % probability on the CCDF; 3GPP test model 1; 1 to 64 DPCH; f1 = 1455 MHz; f2 = 1508.5 MHz; RF performance at VDS = 32 V; IDq = 810 mA (main); VGS(amp)peak = 0.5 V; Tcase = 25 C; unless otherwise specified; in an asymmetrical Doherty production test circuit at frequencies from 1452 MHz to 1511 MHz. Symbol Parameter Conditions Min Typ Max Unit Gp power gain PL(AV) = 93 W 15 16.2 - dB RLin input return loss PL(AV) = 93 W - 15 10 dB D drain efficiency PL(AV) = 93 W 46.5 51 - % ACPR adjacent channel power ratio PL(AV) = 93 W - 34 29 dBc Table 8. RF characteristics Test signal: 1-carrier W-CDMA; PAR = 9.6 dB at 0.01 % probability on the CCDF; 3GPP test model 1; 1 to 64 DPCH; f = 1508.5 MHz; RF performance at VDS = 32 V; IDq = 810 mA (main); VGS(amp)peak = 0.5 V; Tcase = 25 C; unless otherwise specified; in an asymmetrical Doherty production test circuit at a frequency of 1511 MHz. BLC9G15LS-400AVT Product data sheet Symbol Parameter Conditions Min Typ Max Unit PARO output peak-to-average ratio PL(M) peak output power PL(AV) = 110 W 6.3 6.9 - dB PL(AV) = 110 W 460 540 - W All information provided in this document is subject to legal disclaimers. Rev. 3 — 24 November 2017 © Ampleon Netherlands B.V. 2017. All rights reserved. 3 of 16 BLC9G15LS-400AVT Power LDMOS transistor 7. Test information 7.1 Ruggedness in Doherty operation The BLC9G15LS-400AVT is capable of withstanding a load mismatch corresponding to VSWR = 10 : 1 through all phases under the following conditions: VDS = 32 V; IDq = 810 mA; VGS(amp)peak = 0.5 V; f = 1454.5 MHz; PL = 126 W (5 dB OBO); 1-carrier W-CDMA; 100 % clipping. 7.2 Impedance information Table 9. Typical impedance of main device Measured load-pull data of main device; IDq = 810 mA (main); VDS = 30 V; pulsed CW (tp = 100 s;  = 10 %). f ZS [1] ZL [1] PL [2] D [2] Gp [2] (MHz) () () (W) (%) (dB) Maximum power load 1440 1.0  j4.8 0.9  j3.4 245 53.5 18.0 1480 1.4  j5.3 0.9  j3.7 245 55.6 18.3 1510 1.5  j5.7 1.0  j4.0 245 57.1 18.7 Maximum drain efficiency load 1440 1.0  j4.8 2.5  j3.1 170 71.8 21.4 1480 1.4  j5.3 2.5  j2.9 153 72.3 21.8 1510 1.5  j5.7 2.5  j3.0 153 71.2 21.9 [1] ZS and ZL defined in Figure 1. [2] At 3 dB gain compression. Table 10. Typical impedance of peak device Measured load-pull data of peak device; IDq = 1800 mA (peak); VDS = 30 V; pulsed CW (tp = 100 s;  = 10 %). f ZS [1] ZL [1] PL [2] D [2] Gp [2] (MHz) () () (W) (%) (dB) Maximum power load 1440 2.0  j7.6 1.5  j3.4 390 54.3 19.4 1480 3.0  j8.0 1.6  j3.4 400 57.0 19.7 1510 2.8  j9.2 1.8  j3.6 390 55.4 19.8 Maximum drain efficiency load BLC9G15LS-400AVT Product data sheet 1440 2.0  j7.6 3.1  j1.4 255 67.3 22.4 1480 3.0  j8.0 2.5  j1.7 271 68.3 22.3 1510 2.8  j9.2 2.2  j1.9 283 67.2 22.4 [1] ZS and ZL defined in Figure 1. [2] At 3 dB gain compression. All information provided in this document is subject to legal disclaimers. Rev. 3 — 24 November 2017 © Ampleon Netherlands B.V. 2017. All rights reserved. 4 of 16 BLC9G15LS-400AVT Power LDMOS transistor drain ZL gate ZS 001aaf059 Fig 1. Definition of transistor impedance 7.3 Recommended impedances for Doherty design Table 11. Typical impedance of main at 1 : 1 load Measured load-pull data of main device; IDq = 810 mA (main); VDS = 30 V; pulsed CW (tp = 100 s;  = 10 %). f ZS [1] ZL [1] PL(3dB) [2] D [2] Gp [2] (MHz) () () (W) (%) (dB) 1440 1.0  j4.8 1.50  j4.2 220 45 19.5 1480 1.4  j5.3 1.40  j3.7 230 46 19.6 1510 1.5  j5.7 1.38  j3.5 220 47 20.4 [1] ZS and ZL defined in Figure 1. [2] At PL(AV) = 93 W. Table 12. Typical impedance of main device at 1 : 2.5 load Measured load-pull data of main device; IDq = 810 mA (main); VDS = 30 V; pulsed CW (tp = 100 s;  = 10 %). ZL [1] PL(3dB) [2] D [2] () () (W) (%) (dB) 1.0  j4.8 3.4  j3.5 140 65 22.0 1480 1.4  j5.3 3.3  j3.2 125 65 22.4 1510 1.5  j5.7 3.3  j3.0 120 64 23.2 f ZS [1] (MHz) 1440 [1] ZS and ZL defined in Figure 1. [2] At PL(AV) = 93 W. Gp [2] Table 13. Typical impedance of peak device at 1 : 1 load Measured load-pull data of peak device; IDq = 1500 mA (peak); VDS = 30 V; pulsed CW (tp = 100 s;  = 10 %). BLC9G15LS-400AVT Product data sheet f ZS [1] ZL [1] PL(3dB) [2] D [2] Gp [2] (MHz) () () (W) (%) (dB) 1410 2.0  j7.6 2.0  j4.2 380 31 19.0 1480 3.0  j8.0 1.9  j3.6 390 32.5 19.6 1520 2.8  j9.2 1.9  j3.3 380 33 20.3 [1] ZS and ZL defined in Figure 1. [2] At PL(AV) = 93 W. All information provided in this document is subject to legal disclaimers. Rev. 3 — 24 November 2017 © Ampleon Netherlands B.V. 2017. All rights reserved. 5 of 16 BLC9G15LS-400AVT Power LDMOS transistor Table 14. Off-state impedances of peak device f Zoff (MHz) () 1410 1.22  j3.50 1480 0.57  j1.30 1520 0.43  j0.63 7.4 Test circuit 110.2 mm R1 C15 C16 C17 C18 C5 C6 X1 C27 C29 C7 C14 C12 C11 C2 R3 C3 X2 C4 C28 80 mm C25 C13 C1 C19 C20 C8 C21 C9 C23 C10 C22 R2 C24 C26 amp00022 Printed-Circuit Board (PCB): Rogers 3006: r = 6.15; thickness = 0.635 mm; thickness copper plating = 35 m. See Table 15 for a list of components. Fig 2. Component layout Table 15. List of components See Figure 2 for component layout. Component Description Value C1, C10, C11, C13, C14, C21, C23, C24 multilayer ceramic chip capacitor 4.7 F Murata GRM32ER71H475KA88L C2, C3, C5, C7, C9, C12, C15, C16, C20, C22 multilayer ceramic chip capacitor 18 pF Murata Hi-Q 0805 C4,C6, C27, C28 multilayer ceramic chip capacitor 2.0 pF Murata Hi-Q 0805 C8,C17, C18 multilayer ceramic chip capacitor 1.8 pF Murata Hi-Q 0805 C19 multilayer ceramic chip capacitor 2.7 pF Murata Hi-Q 0805 C25, C26 electrolytic capacitor 470 F C29 multilayer ceramic chip capacitor 0.3 pF R1, R2 SMD resistor BLC9G15LS-400AVT Product data sheet 4.7 , 1 % All information provided in this document is subject to legal disclaimers. Rev. 3 — 24 November 2017 Remarks 63 V ATC 100A 0805 0805 © Ampleon Netherlands B.V. 2017. All rights reserved. 6 of 16 BLC9G15LS-400AVT Power LDMOS transistor Table 15. List of components …continued See Figure 2 for component layout. Component Description Value Remarks R3 SMD resistor 50 , 25 W Anaren C16A50Z4 X1 hybrid coupler 2 dB, 90 Anaren X3C20F1-02S X2 attenuator 1 dB Anaren D10AAXXZ4 7.5 Graphical data 7.5.1 Pulsed CW amp00023 18 Gp (dB) Gp 17 70 ηD (%) (1) (2) (3) 60 16 amp00024 4 AM to PM (deg) 0 50 -4 (1) (2) (3) 15 40 -8 14 30 13 20 (3) (2) (1) -12 ηD 12 0 100 200 300 400 500 PL (W) 10 600 VDS = 32 V; IDq = 810 mA; VGS(amp)peak = 0.5 V; tp = 100 s;  = 10 %. -16 0 100 200 300 400 PL (W) 500 VDS = 32 V; IDq = 810 mA; VGS(amp)peak = 0.5 V. (1) f = 1452 MHz (1) f = 1452 MHz (2) f = 1492 MHz (2) f = 1492 MHz (3) f = 1511 MHz (3) f = 1511 MHz Fig 3. Power gain and drain efficiency as function of output power; typical values BLC9G15LS-400AVT Product data sheet Fig 4. AM to PM as a function of output power; typical values All information provided in this document is subject to legal disclaimers. Rev. 3 — 24 November 2017 © Ampleon Netherlands B.V. 2017. All rights reserved. 7 of 16 BLC9G15LS-400AVT Power LDMOS transistor 7.5.2 1-Carrier W-CDMA PAR = 9.6 dB per carrier at 0.01 % probability on the CCDF; 3GPP test model 1 with 64 DPCH (100 % clipping). amp00025 18 Gp (dB) 60 ηD (%) Gp 17 amp00026 -25 ACPR5M (dBc) 50 (1) (2) (3) -35 16 40 (1) (2) (3) 15 30 14 (1) (2) (3) -45 20 -55 ηD 13 10 12 0 25 50 75 100 125 150 175 PL (W) 0 200 -65 0 VDS = 32 V; IDq = 810 mA; VGS(amp)peak = 0.5 V. 25 50 (1) f = 1454.5 MHz (2) f = 1489.5 MHz (2) f = 1489.5 MHz (3) f = 1508.5 MHz Fig 6. amp00027 10 (3) (2) (1) 150 175 PL (W) 200 Adjacent channel power ratio (5 MHz) and adjacent channel power ratio (10 MHz) as function of output power; typical values amp00028 19 RLin (dB) 9 17 8 15 7 13 6 11 5 (3) (2) (1) 9 0 25 50 75 100 125 150 175 PL (W) 200 0 VDS = 32 V; IDq = 810 mA; VGS(amp)peak = 0.5 V. 25 50 (1) f = 1454.5 MHz (2) f = 1489.5 MHz (2) f = 1489.5 MHz (3) f = 1508.5 MHz (3) f = 1508.5 MHz Peak-to-average power ratio as a function of output power; typical values BLC9G15LS-400AVT Product data sheet 75 100 125 150 175 PL (W) 200 VDS = 32 V; IDq = 810 mA; VGS(amp)peak = 0.5 V. (1) f = 1454.5 MHz Fig 7. 125 (3) f = 1508.5 MHz Power gain and drain efficiency as function of output power; typical values PAR (dB) 100 VDS = 32 V; IDq = 810 mA; VGS(amp)peak = 0.5 V. (1) f = 1454.5 MHz Fig 5. 75 Fig 8. Input return loss as a function of output power; typical values All information provided in this document is subject to legal disclaimers. Rev. 3 — 24 November 2017 © Ampleon Netherlands B.V. 2017. All rights reserved. 8 of 16 BLC9G15LS-400AVT Power LDMOS transistor 7.5.3 2-Carrier W-CDMA PAR = 9.6 dB at 0.01 % probability on the CCDF; 3GPP test model 1 with 64 DPCH (46 % clipping). amp00029 18 50 -20 ACPR5M (dBc) -25 40 -30 15 30 -35 14 20 -40 10 -45 Gp (dB) 60 ηD (%) Gp 17 (1) (2) (3) 16 amp00030 (1) (2) (3) ηD 13 12 0 50 100 150 200 PL (W) 0 250 (1) (2) (3) -50 0 VDS = 32 V; IDq = 810 mA; VGS(amp)peak = 0.5 V. 50 150 200 PL (W) 250 VDS = 32 V; IDq = 810 mA; VGS(amp)peak = 0.5 V. (1) f = 1457 MHz (1) f = 1457 MHz (2) f = 1487 MHz (2) f = 1487 MHz (3) f = 1506 MHz Fig 9. 100 (3) f = 1506 MHz Power gain and drain efficiency as function of output power; typical values Fig 10. Adjacent channel power ratio (5 MHz) and adjacent channel power ratio (10 MHz) as function of output power; typical values amp00031 18 RLin (dB) 17 16 (3) (2) (1) 15 14 13 12 0 50 100 150 200 PL (W) 250 VDS = 32 V; IDq = 810 mA; VGS(amp)peak = 0.5 V. (1) f = 1457 MHz (2) f = 1487 MHz (3) f = 1506 MHz Fig 11. Input return loss as a function of output power; typical values BLC9G15LS-400AVT Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 3 — 24 November 2017 © Ampleon Netherlands B.V. 2017. All rights reserved. 9 of 16 BLC9G15LS-400AVT Power LDMOS transistor 7.5.4 2-Tone VBW amp00032 0 IMD (dBc) (1) (2) -20 IMD3 (1) (2) IMD5 -40 (1) (2) -60 IMD7 -80 1 10 102 carrier spacing (MHz) 103 VDS = 32 V; IDq = 810 mA; VGS(amp)peak = 0.5 V. (1) IMD low (2) IMD high Fig 12. VBW capability BLC9G15LS-400AVT Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 3 — 24 November 2017 © Ampleon Netherlands B.V. 2017. All rights reserved. 10 of 16 BLC9G15LS-400AVT Power LDMOS transistor 8. Package outline Air cavity plastic earless flanged package; 6 leads SOT1258-1 D A F 5 w1 D1 v B A L b c 7 2 6 1 y Į H1 Z1 Z H E1 U2 E A 3 4 e Q w2 b1 U1 B B 0 10 mm y Į 0.1 65° 3.17 5.79 61° 2.67 5.29 scale Z Z1 Dimensions Unit mm A max 4.65 nom min 4.18 b b1 c 1.12 11.78 0.2 D D1 E 31.44 31.34 9.60 E1 H H1 Q(1) 36.42 1.83 16.71 8.12 2.33 32.33 10.23 36.22 1.63 16.51 7.62 2.13 32.13 10.03 e 9.50 L F U1 v w1 w2 0.5 0.5 0.5 13.72 0.91 11.58 0.1 31.04 31.14 9.20 9.30 Note 1. Dimension Q is measured 0.1 mm away from the flange. 2. Ringframe and/or ringframe glue shall not overhang at the side of the flange. Outline version U2 References IEC JEDEC JEITA sot1258-1_po European projection Issue date 14-02-24 17-08-31 SOT1258-1 Fig 13. Package outline SOT1258-1 BLC9G15LS-400AVT Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 3 — 24 November 2017 © Ampleon Netherlands B.V. 2017. All rights reserved. 11 of 16 BLC9G15LS-400AVT Power LDMOS transistor 9. Handling information CAUTION This device is sensitive to ElectroStatic Discharge (ESD). Observe precautions for handling electrostatic sensitive devices. Such precautions are described in the ANSI/ESD S20.20, IEC/ST 61340-5, JESD625-A or equivalent standards. Table 16. ESD sensitivity ESD model Class Charged Device Model (CDM); According to ANSI/ESDA/JEDEC standard JS-002 C2A [1] Human Body Model (HBM); According to ANSI/ESDA/JEDEC standard JS-001 2 [2] [1] CDM classification C2A is granted to any part that passes after exposure to an ESD pulse of 500 V, but fails after exposure to an ESD pulse of 750 V. [2] HBM classification 2 is granted to any part that passes after exposure to an ESD pulse of 2000 V, but fails after exposure to an ESD pulse of 4000 V. 10. Abbreviations Table 17. BLC9G15LS-400AVT Product data sheet Abbreviations Acronym Description 3GPP 3rd Generation Partnership Project AM Amplitude Modulation CCDF Complementary Cumulative Distribution Function CW Continuous Wave DPCH Dedicated Physical CHannel ESD ElectroStatic Discharge LDMOS Laterally Diffused Metal-Oxide Semiconductor MTF Median Time to Failure OBO Output Back Off PAR Peak-to-Average Ratio PM Phase Modulation SMD Surface Mounted Device VBW Video Bandwidth VSWR Voltage Standing Wave Ratio W-CDMA Wideband Code Division Multiple Access All information provided in this document is subject to legal disclaimers. Rev. 3 — 24 November 2017 © Ampleon Netherlands B.V. 2017. All rights reserved. 12 of 16 BLC9G15LS-400AVT Power LDMOS transistor 11. Revision history Table 18. Revision history Document ID Release date Data sheet status Change notice Supersedes BLC9G15LS-400AVT v.3 20171124 Product data sheet - BLC9G15LS-400AVT v.2 Modifications: • • • Table 2 on page 2: changed simplified version drawing SOT1258-3 to SOT1258-1 Table 3 on page 2: changed version SOT1258-3 to SOT1258-1 Figure 13 on page 11: changed package outline drawing SOT1258-3 to SOT1258-1 BLC9G15LS-400AVT v.2 20161202 Product data sheet - BLC9G15LS-400AVT v.1 BLC9G15LS-400AVT v.1 20160317 Product data sheet - - BLC9G15LS-400AVT Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 3 — 24 November 2017 © Ampleon Netherlands B.V. 2017. All rights reserved. 13 of 16 BLC9G15LS-400AVT Power LDMOS transistor 12. Legal information 12.1 Data sheet status Document status[1][2] Product status[3] Objective [short] data sheet Development This document contains data from the objective specification for product development. Preliminary [short] data sheet Qualification This document contains data from the preliminary specification. Product [short] data sheet Production This document contains the product specification. Definition [1] Please consult the most recently issued document before initiating or completing a design. [2] The term ‘short data sheet’ is explained in section “Definitions”. [3] The product status of device(s) described in this document may have changed since this document was published and may differ in case of multiple devices. The latest product status information is available on the Internet at URL http://www.ampleon.com. 12.2 Definitions Draft — The document is a draft version only. The content is still under internal review and subject to formal approval, which may result in modifications or additions. Ampleon does not give any representations or warranties as to the accuracy or completeness of information included herein and shall have no liability for the consequences of use of such information. Short data sheet — A short data sheet is an extract from a full data sheet with the same product type number(s) and title. A short data sheet is intended for quick reference only and should not be relied upon to contain detailed and full information. For detailed and full information see the relevant full data sheet, which is available on request via the local Ampleon sales office. In case of any inconsistency or conflict with the short data sheet, the full data sheet shall prevail. Product specification — The information and data provided in a Product data sheet shall define the specification of the product as agreed between Ampleon and its customer, unless Ampleon and customer have explicitly agreed otherwise in writing. In no event however, shall an agreement be valid in which the Ampleon product is deemed to offer functions and qualities beyond those described in the Product data sheet. 12.3 Disclaimers Limited warranty and liability — Information in this document is believed to be accurate and reliable. However, Ampleon does not give any representations or warranties, expressed or implied, as to the accuracy or completeness of such information and shall have no liability for the consequences of use of such information. Ampleon takes no responsibility for the content in this document if provided by an information source outside of Ampleon. In no event shall Ampleon be liable for any indirect, incidental, punitive, special or consequential damages (including - without limitation - lost profits, lost savings, business interruption, costs related to the removal or replacement of any products or rework charges) whether or not such damages are based on tort (including negligence), warranty, breach of contract or any other legal theory. Notwithstanding any damages that customer might incur for any reason whatsoever, Ampleon’s aggregate and cumulative liability towards customer for the products described herein shall be limited in accordance with the Terms and conditions of commercial sale of Ampleon. Right to make changes — Ampleon reserves the right to make changes to information published in this document, including without limitation specifications and product descriptions, at any time and without notice. This document supersedes and replaces all information supplied prior to the publication hereof. Suitability for use — Ampleon products are not designed, authorized or warranted to be suitable for use in life support, life-critical or safety-critical systems or equipment, nor in applications where failure or malfunction of an BLC9G15LS-400AVT Product data sheet Ampleon product can reasonably be expected to result in personal injury, death or severe property or environmental damage. Ampleon and its suppliers accept no liability for inclusion and/or use of Ampleon products in such equipment or applications and therefore such inclusion and/or use is at the customer’s own risk. Applications — Applications that are described herein for any of these products are for illustrative purposes only. Ampleon makes no representation or warranty that such applications will be suitable for the specified use without further testing or modification. Customers are responsible for the design and operation of their applications and products using Ampleon products, and Ampleon accepts no liability for any assistance with applications or customer product design. It is customer’s sole responsibility to determine whether the Ampleon product is suitable and fit for the customer’s applications and products planned, as well as for the planned application and use of customer’s third party customer(s). Customers should provide appropriate design and operating safeguards to minimize the risks associated with their applications and products. Ampleon does not accept any liability related to any default, damage, costs or problem which is based on any weakness or default in the customer’s applications or products, or the application or use by customer’s third party customer(s). Customer is responsible for doing all necessary testing for the customer’s applications and products using Ampleon products in order to avoid a default of the applications and the products or of the application or use by customer’s third party customer(s). Ampleon does not accept any liability in this respect. Limiting values — Stress above one or more limiting values (as defined in the Absolute Maximum Ratings System of IEC 60134) will cause permanent damage to the device. Limiting values are stress ratings only and (proper) operation of the device at these or any other conditions above those given in the Recommended operating conditions section (if present) or the Characteristics sections of this document is not warranted. Constant or repeated exposure to limiting values will permanently and irreversibly affect the quality and reliability of the device. Terms and conditions of commercial sale — Ampleon products are sold subject to the general terms and conditions of commercial sale, as published at http://www.ampleon.com/terms, unless otherwise agreed in a valid written individual agreement. In case an individual agreement is concluded only the terms and conditions of the respective agreement shall apply. Ampleon hereby expressly objects to applying the customer’s general terms and conditions with regard to the purchase of Ampleon products by customer. No offer to sell or license — Nothing in this document may be interpreted or construed as an offer to sell products that is open for acceptance or the grant, conveyance or implication of any license under any copyrights, patents or other industrial or intellectual property rights. Export control — This document as well as the item(s) described herein may be subject to export control regulations. Export might require a prior authorization from competent authorities. All information provided in this document is subject to legal disclaimers. Rev. 3 — 24 November 2017 © Ampleon Netherlands B.V. 2017. All rights reserved. 14 of 16 BLC9G15LS-400AVT Power LDMOS transistor Non-automotive qualified products — Unless this data sheet expressly states that this specific Ampleon product is automotive qualified, the product is not suitable for automotive use. It is neither qualified nor tested in accordance with automotive testing or application requirements. Ampleon accepts no liability for inclusion and/or use of non-automotive qualified products in automotive equipment or applications. In the event that customer uses the product for design-in and use in automotive applications to automotive specifications and standards, customer (a) shall use the product without Ampleon’s warranty of the product for such automotive applications, use and specifications, and (b) whenever customer uses the product for automotive applications beyond Ampleon’s specifications such use shall be solely at customer’s own risk, and (c) customer fully indemnifies Ampleon for any liability, damages or failed product claims resulting from customer design and use of the product for automotive applications beyond Ampleon’s standard warranty and Ampleon’s product specifications. Translations — A non-English (translated) version of a document is for reference only. The English version shall prevail in case of any discrepancy between the translated and English versions. 12.4 Trademarks Notice: All referenced brands, product names, service names and trademarks are the property of their respective owners. Any reference or use of any ‘NXP’ trademark in this document or in or on the surface of Ampleon products does not result in any claim, liability or entitlement vis-à-vis the owner of this trademark. Ampleon is no longer part of the NXP group of companies and any reference to or use of the ‘NXP’ trademarks will be replaced by reference to or use of Ampleon’s own trademarks. 13. Contact information For more information, please visit: http://www.ampleon.com For sales office addresses, please visit: http://www.ampleon.com/sales BLC9G15LS-400AVT Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 3 — 24 November 2017 © Ampleon Netherlands B.V. 2017. All rights reserved. 15 of 16 BLC9G15LS-400AVT Power LDMOS transistor 14. Contents 1 1.1 1.2 1.3 2 3 4 5 6 7 7.1 7.2 7.3 7.4 7.5 7.5.1 7.5.2 7.5.3 7.5.4 8 9 10 11 12 12.1 12.2 12.3 12.4 13 14 Product profile . . . . . . . . . . . . . . . . . . . . . . . . . . 1 General description . . . . . . . . . . . . . . . . . . . . . 1 Features and benefits . . . . . . . . . . . . . . . . . . . . 1 Applications . . . . . . . . . . . . . . . . . . . . . . . . . . . 1 Pinning information . . . . . . . . . . . . . . . . . . . . . . 2 Ordering information . . . . . . . . . . . . . . . . . . . . . 2 Limiting values. . . . . . . . . . . . . . . . . . . . . . . . . . 2 Thermal characteristics . . . . . . . . . . . . . . . . . . 2 Characteristics . . . . . . . . . . . . . . . . . . . . . . . . . . 3 Test information . . . . . . . . . . . . . . . . . . . . . . . . . 4 Ruggedness in Doherty operation . . . . . . . . . . 4 Impedance information . . . . . . . . . . . . . . . . . . . 4 Recommended impedances for Doherty design 5 Test circuit. . . . . . . . . . . . . . . . . . . . . . . . . . . . . 6 Graphical data . . . . . . . . . . . . . . . . . . . . . . . . . 7 Pulsed CW . . . . . . . . . . . . . . . . . . . . . . . . . . . . 7 1-Carrier W-CDMA . . . . . . . . . . . . . . . . . . . . . . 8 2-Carrier W-CDMA . . . . . . . . . . . . . . . . . . . . . . 9 2-Tone VBW . . . . . . . . . . . . . . . . . . . . . . . . . . 10 Package outline . . . . . . . . . . . . . . . . . . . . . . . . 11 Handling information. . . . . . . . . . . . . . . . . . . . 12 Abbreviations . . . . . . . . . . . . . . . . . . . . . . . . . . 12 Revision history . . . . . . . . . . . . . . . . . . . . . . . . 13 Legal information. . . . . . . . . . . . . . . . . . . . . . . 14 Data sheet status . . . . . . . . . . . . . . . . . . . . . . 14 Definitions . . . . . . . . . . . . . . . . . . . . . . . . . . . . 14 Disclaimers . . . . . . . . . . . . . . . . . . . . . . . . . . . 14 Trademarks. . . . . . . . . . . . . . . . . . . . . . . . . . . 15 Contact information. . . . . . . . . . . . . . . . . . . . . 15 Contents . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 16 Please be aware that important notices concerning this document and the product(s) described herein, have been included in section ‘Legal information’. © Ampleon Netherlands B.V. 2017. All rights reserved. For more information, please visit: http://www.ampleon.com For sales office addresses, please visit: http://www.ampleon.com/sales Date of release: 24 November 2017 Document identifier: BLC9G15LS-400AVT
BLC9G15LS-400AVTY 价格&库存
很抱歉,暂时无法提供与“BLC9G15LS-400AVTY”相匹配的价格&库存,您可以联系我们找货
