BLF6G15L-500H,112
BLF6G15L-500H,112
    AMPLEON(安谱隆)
    SOT539A
    RF Mosfet LDMOS (Dual), Common Source 50V 1.3A 1.45Ghz ~ 1.49GHz 16dB 65W SOT539A
BLF6G15L-500H,112 数据手册
BLF6G15L-500H; BLF6G15LS-500H Power LDMOS transistor Rev. 4 — 1 September Product data sheet 1. Product profile 1.1 General description A 500 W LDMOS RF power transistor for transmitter applications and industrial applications. The transistor is optimized for digital applications and can deliver 65 W average DVB-T at 1.5 GHz. The excellent ruggedness of this device makes it ideal for digital transmitter applications. Table 1. Test information RF performance at VDS = 50 V; IDq = 1.3 A. PL(AV) Gp D Mode of operation f IMD3 IMDshldr PAR (MHz) (W) (dB) (%) (dBc) (dBc) (dB) 2-tone, class-AB 1452 to 1492 250 15 34 24 - - DVB-T (8k OFDM) 1452 to 1492 65 16 19 - 32 [1] 9 [2] [1] Measured [dBc] with delta marker at 4.3 MHz from center frequency. [2] PAR (of output signal) at 0.01 % probability on CCDF; PAR of input signal = 9.5 dB at 0.01 % probability on CCDF. 1.2 Features and benefits        Easy power control Integrated ESD protection Excellent ruggedness High efficiency Excellent thermal stability Internally matched for ease of use Compliant to Directive 2002/95/EC, regarding Restriction of Hazardous Substances (RoHS) 1.3 Applications  Digital transmitter applications DVB at 1.5 GHz  Industrial applications at 1.5 GHz BLF6G15L-500H; BLF6G15LS-500H Power LDMOS transistor 2. Pinning information Table 2. Pinning Pin Description Simplified outline Graphic symbol BLF6G15L-500H (SOT539A) 1 drain1 2 drain2 3 gate1 4 gate2 5 1 2 1 5 3 3 4 5 4 [1] source 2 sym117 BLF6G15LS-500H (SOT539B) 1 drain1 2 drain2 3 gate1 4 gate2 5 1 1 2 5 3 3 4 5 4 [1] source 2 sym117 [1] Connected to flange. 3. Ordering information Table 3. Ordering information Type number Package Name Description Version BLF6G15L-500H - flanged balanced LDMOST ceramic package; 2 mounting holes; 4 leads SOT539A BLF6G15LS-500H - earless flanged balanced LDMOST ceramic package; 4 leads SOT539B 4. Limiting values Table 4. Limiting values In accordance with the Absolute Maximum Rating System (IEC 60134). BLF6G15L-500H_6G15LS-500H#4 Product data sheet Symbol Parameter Min Max Unit VDS drain-source voltage Conditions - 100 V VGS gate-source voltage 0.5 +13 V ID drain current - 45 A Tstg storage temperature 65 +150 C Tj junction temperature - 200 C All information provided in this document is subject to legal disclaimers. Rev. 4 — 1 September © Ampleon The Netherlands B.V. 2015. All rights reserved. 2 of 13 BLF6G15L-500H; BLF6G15LS-500H Power LDMOS transistor 5. Thermal characteristics Table 5. Symbol Thermal characteristics Parameter Conditions Rth(j-case) thermal resistance from junction to case Tcase = 85 C; PL = 65 W Typ Unit 0.18 K/W 6. Characteristics Table 6. DC characteristics Tj = 25 C; per section unless otherwise specified. Symbol Parameter Conditions Min Typ Max Unit 100 - - V VDS = 10 V; ID = 270 mA 1.4 1.8 2.4 V V(BR)DSS drain-source breakdown voltage VGS = 0 V; ID = 2.7 mA VGS(th) gate-source threshold voltage IDSS drain leakage current VGS = 0 V; VDS = 50 V - - 2.8 A IDSX drain cut-off current VGS = VGS(th) + 3.75 V; VDS = 10 V 38 42 - A IGSS gate leakage current VGS = 11 V; VDS = 0 V - - 280 nA gfs forward transconductance VDS = 10 V; ID = 270 mA 1.33 2.3 - S RDS(on) drain-source on-state resistance VGS = VGS(th) + 3.75 V; ID = 9.5 A - 100 193 m Table 7. RF characteristics RF characteristics in Ampleon class-AB production circuit, in frequency range 1452 MHz to 1492 MHz; Tcase = 25 C. Symbol Parameter Conditions Min Typ Max Unit DVB-T (8k OFDM), class-AB VDS drain-source voltage - 50 - V IDq quiescent drain current - 1.3 - A PL(AV) average output power - 65 - W Gp power gain 14.5 16 - dB D drain efficiency 16 19 - % IMDshldr intermodulation distortion shoulder [1] - 32 30 dBc PAR peak-to-average ratio [2] 8.5 9 - dB [1] Measured [dBc] with delta marker at 4.3 MHz from center frequency. [2] PAR (of output signal) at 0.01 % probability on CCDF; PAR of input signal = 9.5 dB at 0.01 % probability on CCDF. 6.1 Ruggedness in class-AB operation The BLF6G15L-500H and BLF6G15LS-500H are capable of withstanding a load mismatch corresponding to VSWR = 10 : 1 through all phases under the following conditions: VDS = 50 V; IDq = 1.3 A at rated power. BLF6G15L-500H_6G15LS-500H#4 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 4 — 1 September © Ampleon The Netherlands B.V. 2015. All rights reserved. 3 of 13 BLF6G15L-500H; BLF6G15LS-500H Power LDMOS transistor 7. Application information 7.1 Impedance information Table 8. Typical impedance Typical values per section unless otherwise specified. f ZS ZL MHz   1452 1.226  j2.663 2.137  j2.750 1472 1.375  j2.757 1.869  j2.378 1492 1.15  j2.735 1.817  j2.684 drain ZL gate ZS 001aaf059 Fig 1. Definition of transistor impedance 7.2 Graphs 7.2.1 2-Tone 001aao061 18 ηD Gp (dB) 16 ηD (%) 001aao062 18 40 Gp (dB) IMD3 (dBc) 16 30 0 -12 IMD3 14 Gp 12 10 0 100 200 20 14 10 12 0 300 400 PL(AV) (W) 0 Product data sheet 100 200 -48 300 400 PL(AV) (W) VDS = 50 V; IDq = 1.3 A; f = 1490 MHz. 2-Tone power gain and drain efficiency as function of average load power; typical values BLF6G15L-500H_6G15LS-500H#4 -24 -36 10 VDS = 50 V; IDq = 1.3 A; f = 1490 MHz. Fig 2. Gp Fig 3. 2-Tone power gain and third order intermodulation distortion as function of average load power; typical values All information provided in this document is subject to legal disclaimers. Rev. 4 — 1 September © Ampleon The Netherlands B.V. 2015. All rights reserved. 4 of 13 BLF6G15L-500H; BLF6G15LS-500H Power LDMOS transistor 7.2.2 DVB-T 001aao063 17 IMDshldr (dBc) Gp (dB) IMDshldr 16 001aao064 12 -5 40 ηD (%) ηD PAR (dB) -15 30 8 15 PAR -25 20 Gp 4 14 10 -35 13 0 100 0 -45 300 400 PL(AV) (W) 200 0 VDS = 50 V; IDq = 1.3 A; f = 1490 MHz. Fig 4. 001aao065 PAR (dB) 9 Fig 5. 23 DVB-T peak-to-average ratio and drain efficiency as function of average load power; typical values 001aao066 20 25 ηD (%) PAR 0 300 400 PL(AV) (W) 200 VDS = 50 V; IDq = 1.3 A; f = 1490 MHz. DVB-T power gain and intermodulation distortion shoulder as function of average load power; typical values 10 100 -10 IMDshldr (dBc) Gp (dB) Gp -20 15 8 21 -30 ηD 7 19 IMDshldr 10 -40 6 17 5 1400 1450 5 1400 15 1550 1500 f (MHz) VDS = 50 V; IDq = 1.3 A; PL(AV) = 65 W. DVB-T peak-to-average ratio and drain efficiency as function of frequency; typical values BLF6G15L-500H_6G15LS-500H#4 Product data sheet -50 1550 1500 f (MHz) VDS = 50 V; IDq = 1.3 A; PL(AV) = 65 W. Fig 6. 1450 Fig 7. DVB-T power gain and intermodulation distortion shoulder as a function of frequency; typical values All information provided in this document is subject to legal disclaimers. Rev. 4 — 1 September © Ampleon The Netherlands B.V. 2015. All rights reserved. 5 of 13 BLF6G15L-500H; BLF6G15LS-500H Power LDMOS transistor 7.2.3 Reliability 001aao067 106 Years 105 (1) (2) 104 (3) (4) 103 102 (5) (6) 10 (7) 1 0 5 10 15 20 lDS(DC) (A) TTF (0.1 % failure fraction). The reliability at pulsed conditions can be calculated as follows: TTF (0.1 %)  1 / . (1) Tj = 100 C (2) Tj = 120 C (3) Tj = 140 C (4) Tj = 146 C (5) Tj = 160 C (6) Tj = 180 C (7) Tj = 200 C Fig 8. BLF6G15L-500H_6G15LS-500H#4 Product data sheet BLF6G15LS-500H electromigration (IDS(DC), total device) All information provided in this document is subject to legal disclaimers. Rev. 4 — 1 September © Ampleon The Netherlands B.V. 2015. All rights reserved. 6 of 13 BLF6G15L-500H; BLF6G15LS-500H Power LDMOS transistor 7.3 Test circuit 5 mm C14 C16 R3 C19 C2 R1 C3 C6 C4 8 mm C1 Vds C5 25 mm 14 mm 17 mm 23 mm C12 C13 50 mm 5 mm C7 C15 C17 C11 C9 R2 C18 C8 C10 8 mm 14 mm 23 mm 5 mm 60 mm 60 mm 001aao068 Printed-Circuit Board (PCB): Rogers 4350; r = 3.66; thickness = 0.30 mm; thickness copper plating = 35 m. See Table 9 for list of components. Fig 9. Component layout for class-AB common source amplifier Table 9. List of components See Figure 9 for component layout. BLF6G15L-500H_6G15LS-500H#4 Product data sheet Component Description Value Remarks C1 electrolytic capacitor 470 F, 63 V Elco C2, C7, C16, C17 multilayer ceramic chip capacitor 10 F TDK C3, C8 multilayer ceramic chip capacitor 6.2 pF ATC800B C4, C5, C9, C10 multilayer ceramic chip capacitor 1.0 F 1206 10 % C6, C11 multilayer ceramic chip capacitor 10 nF 1205 10 % C12, C13 multilayer ceramic chip capacitor 22 pF ATC800B C18, C19 multilayer ceramic chip capacitor 22 pF ATC800B C15 electrolytic capacitor 470 F; 63 V R1, R2 SMD resistor 5R1  0805 R3 SMD resistor 470  (not fitted) 1206 All information provided in this document is subject to legal disclaimers. Rev. 4 — 1 September © Ampleon The Netherlands B.V. 2015. All rights reserved. 7 of 13 BLF6G15L-500H; BLF6G15LS-500H Power LDMOS transistor 8. Package outline Flanged balanced ceramic package; 2 mounting holes; 4 leads SOT539A D A F D1 U1 B q C w2 M C M H1 1 c 2 E1 p H U2 5 L 3 A E w1 M A M B M 4 w3 M b Q e 0 5 10 mm scale DIMENSIONS (millimetre dimensions are derived from the original inch dimensions) UNIT A mm 4.7 4.2 inches b c D D1 e E E1 11.81 0.18 31.55 31.52 9.50 13.72 11.56 0.10 30.94 30.96 9.30 9.53 9.27 F H H1 L 1.75 17.12 25.53 3.48 1.50 16.10 25.27 2.97 p Q q U1 3.30 3.05 2.26 2.01 35.56 U2 w1 41.28 10.29 0.25 41.02 10.03 w2 w3 0.51 0.25 0.185 0.465 0.007 1.242 1.241 0.374 0.375 0.069 0.674 1.005 0.137 0.130 0.089 1.625 0.405 1.400 0.010 0.020 0.010 0.540 0.165 0.455 0.004 1.218 1.219 0.366 0.365 0.059 0.634 0.995 0.117 0.120 0.079 1.615 0.395 Note 1. millimeter dimensions are derived from the original inch dimensions. 2. recommended screw pitch dimension of 1.52 inch (38.6 mm) based on M3 screw. OUTLINE VERSION REFERENCES IEC JEDEC EIAJ EUROPEAN PROJECTION ISSUE DATE 10-02-02 12-05-02 SOT539A Fig 10. Package outline SOT539A BLF6G15L-500H_6G15LS-500H#4 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 4 — 1 September © Ampleon The Netherlands B.V. 2015. All rights reserved. 8 of 13 BLF6G15L-500H; BLF6G15LS-500H Power LDMOS transistor Earless flanged balanced ceramic package; 4 leads SOT539B D A F 5 D1 D U1 H1 w2 1 c D 2 E1 U2 H E L 3 4 w3 b Q e 0 5 10 mm scale Dimensions Unit(1) w2 w3 0.25 0.25 max 0.185 0.465 0.007 1.242 1.241 0.374 0.375 0.069 0.674 1.005 0.137 0.089 1.275 0.405 inches nom 0.01 0.54 min 0.165 0.455 0.004 1.218 1.219 0.366 0.365 0.059 0.634 0.995 0.117 0.079 1.265 0.395 0.01 mm max nom min A b 4.7 11.81 c D D1 0.18 31.55 31.52 E E1 e 9.5 9.53 F H H1 L Q U1 U2 1.75 17.12 25.53 3.48 2.26 32.39 10.29 1.50 16.10 25.27 2.97 2.01 32.13 10.03 13.72 4.2 11.56 0.10 30.94 30.96 9.3 9.27 Note 1. millimeter dimensions are derived from the original inch dimensions. Outline version References IEC JEDEC JEITA sot539b_po European projection Issue date 12-05-02 13-05-24 SOT539B Fig 11. Package outline SOT539B BLF6G15L-500H_6G15LS-500H#4 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 4 — 1 September © Ampleon The Netherlands B.V. 2015. All rights reserved. 9 of 13 BLF6G15L-500H; BLF6G15LS-500H Power LDMOS transistor 9. Handling information CAUTION This device is sensitive to ElectroStatic Discharge (ESD). Observe precautions for handling electrostatic sensitive devices. Such precautions are described in the ANSI/ESD S20.20, IEC/ST 61340-5, JESD625-A or equivalent standards. 10. Abbreviations Table 10. Abbreviations Acronym Description CCDF Complementary Cumulative Distribution Function DVB-T Digital Video Broadcast - Terrestrial DVB Digital Video Broadcast ESD ElectroStatic Discharge LDMOS Laterally Diffused Metal-Oxide Semiconductor LDMOST Laterally Diffused Metal-Oxide Semiconductor Transistor OFDM Orthogonal Frequency Division Multiplexing PAR Peak-to-Average power Ratio RF Radio Frequency SMD Surface Mounted Device TTF Time To Failure VSWR Voltage Standing-Wave Ratio 11. Revision history Table 11. Revision history Document ID Release date BLF6G15L-500H_6G15LS-500H#4 20150901 Product data sheet Modifications: Data sheet status Change notice Supersedes - BLF6G15L-500H_6G15LS-500H v.3 • The format of this document has been redesigned to comply with the new identity guidelines of Ampleon. • Legal texts have been adapted to the new company name where appropriate. BLF6G15L-500H_6G15LS-500H v.3 20130712 Product data sheet - BLF6G15L-500H_6G15LS-500H v.2 BLF6G15L-500H_6G15LS-500H v.2 20110916 Product data sheet - BLF6G15L-500H_6G15LS-500H v.1 BLF6G15L-500H_6G15LS-500H v.1 20110511 Objective data sheet - BLF6G15L-500H_6G15LS-500H#4 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 4 — 1 September - © Ampleon The Netherlands B.V. 2015. All rights reserved. 10 of 13 BLF6G15L-500H; BLF6G15LS-500H Power LDMOS transistor 12. Legal information 12.1 Data sheet status Document status[1][2] Product status[3] Objective [short] data sheet Development This document contains data from the objective specification for product development. Preliminary [short] data sheet Qualification This document contains data from the preliminary specification. Product [short] data sheet Production This document contains the product specification. Definition [1] Please consult the most recently issued document before initiating or completing a design. [2] The term ‘short data sheet’ is explained in section “Definitions”. [3] The product status of device(s) described in this document may have changed since this document was published and may differ in case of multiple devices. The latest product status information is available on the Internet at URL http://www.ampleon.com. 12.2 Definitions Draft — The document is a draft version only. The content is still under internal review and subject to formal approval, which may result in modifications or additions. Ampleon does not give any representations or warranties as to the accuracy or completeness of information included herein and shall have no liability for the consequences of use of such information. Short data sheet — A short data sheet is an extract from a full data sheet with the same product type number(s) and title. A short data sheet is intended for quick reference only and should not be relied upon to contain detailed and full information. For detailed and full information see the relevant full data sheet, which is available on request via the local Ampleon sales office. In case of any inconsistency or conflict with the short data sheet, the full data sheet shall prevail. Product specification — The information and data provided in a Product data sheet shall define the specification of the product as agreed between Ampleon and its customer, unless Ampleon and customer have explicitly agreed otherwise in writing. In no event however, shall an agreement be valid in which the Ampleon product is deemed to offer functions and qualities beyond those described in the Product data sheet. 12.3 Disclaimers Limited warranty and liability — Information in this document is believed to be accurate and reliable. However, Ampleon does not give any representations or warranties, expressed or implied, as to the accuracy or completeness of such information and shall have no liability for the consequences of use of such information. Ampleon takes no responsibility for the content in this document if provided by an information source outside of Ampleon. In no event shall Ampleon be liable for any indirect, incidental, punitive, special or consequential damages (including - without limitation - lost profits, lost savings, business interruption, costs related to the removal or replacement of any products or rework charges) whether or not such damages are based on tort (including negligence), warranty, breach of contract or any other legal theory. Notwithstanding any damages that customer might incur for any reason whatsoever, Ampleon’ aggregate and cumulative liability towards customer for the products described herein shall be limited in accordance with the Terms and conditions of commercial sale of Ampleon. Right to make changes — Ampleon reserves the right to make changes to information published in this document, including without limitation specifications and product descriptions, at any time and without notice. This document supersedes and replaces all information supplied prior to the publication hereof. Suitability for use — Ampleon products are not designed, authorized or warranted to be suitable for use in life support, life-critical or safety-critical systems or equipment, nor in applications where failure or malfunction of an BLF6G15L-500H_6G15LS-500H#4 Product data sheet Ampleon product can reasonably be expected to result in personal injury, death or severe property or environmental damage. Ampleon and its suppliers accept no liability for inclusion and/or use of Ampleon products in such equipment or applications and therefore such inclusion and/or use is at the customer’s own risk. Applications — Applications that are described herein for any of these products are for illustrative purposes only. Ampleon makes no representation or warranty that such applications will be suitable for the specified use without further testing or modification. Customers are responsible for the design and operation of their applications and products using Ampleon products, and Ampleon accepts no liability for any assistance with applications or customer product design. It is customer’s sole responsibility to determine whether the Ampleon product is suitable and fit for the customer’s applications and products planned, as well as for the planned application and use of customer’s third party customer(s). Customers should provide appropriate design and operating safeguards to minimize the risks associated with their applications and products. Ampleon does not accept any liability related to any default, damage, costs or problem which is based on any weakness or default in the customer’s applications or products, or the application or use by customer’s third party customer(s). Customer is responsible for doing all necessary testing for the customer’s applications and products using Ampleon products in order to avoid a default of the applications and the products or of the application or use by customer’s third party customer(s). Ampleon does not accept any liability in this respect. Limiting values — Stress above one or more limiting values (as defined in the Absolute Maximum Ratings System of IEC 60134) will cause permanent damage to the device. Limiting values are stress ratings only and (proper) operation of the device at these or any other conditions above those given in the Recommended operating conditions section (if present) or the Characteristics sections of this document is not warranted. Constant or repeated exposure to limiting values will permanently and irreversibly affect the quality and reliability of the device. Terms and conditions of commercial sale — Ampleon products are sold subject to the general terms and conditions of commercial sale, as published at http://www.ampleon.com/terms, unless otherwise agreed in a valid written individual agreement. In case an individual agreement is concluded only the terms and conditions of the respective agreement shall apply. Ampleon hereby expressly objects to applying the customer’s general terms and conditions with regard to the purchase of Ampleon products by customer. No offer to sell or license — Nothing in this document may be interpreted or construed as an offer to sell products that is open for acceptance or the grant, conveyance or implication of any license under any copyrights, patents or other industrial or intellectual property rights. Export control — This document as well as the item(s) described herein may be subject to export control regulations. Export might require a prior authorization from competent authorities. All information provided in this document is subject to legal disclaimers. Rev. 4 — 1 September © Ampleon The Netherlands B.V. 2015. All rights reserved. 11 of 13 BLF6G15L-500H; BLF6G15LS-500H Power LDMOS transistor Non-automotive qualified products — Unless this data sheet expressly states that this specific Ampleon product is automotive qualified, the product is not suitable for automotive use. It is neither qualified nor tested in accordance with automotive testing or application requirements. Ampleon accepts no liability for inclusion and/or use of non-automotive qualified products in automotive equipment or applications. In the event that customer uses the product for design-in and use in automotive applications to automotive specifications and standards, customer (a) shall use the product without Ampleon’ warranty of the product for such automotive applications, use and specifications, and (b) whenever customer uses the product for automotive applications beyond Ampleon’ specifications such use shall be solely at customer’s own risk, and (c) customer fully indemnifies Ampleon for any liability, damages or failed product claims resulting from customer design and use of the product for automotive applications beyond Ampleon’ standard warranty and Ampleon’ product specifications. 12.4 Trademarks Notice: All referenced brands, product names, service names and trademarks are the property of their respective owners. Any reference or use of any ‘NXP’ trademark in this document or in or on the surface of Ampleon products does not result in any claim, liability or entitlement vis-à-vis the owner of this trademark. Ampleon is no longer part of the NXP group of companies and any reference to or use of the ‘NXP’ trademarks will be replaced by reference to or use of Ampleon’s own Any reference or use of any ‘NXP’ trademark in this document or in or on the surface of Ampleon products does not result in any claim, liability or entitlement vis-à-vis the owner of this trademark. Ampleon is no longer part of the NXP group of companies and any reference to or use of the ‘NXP’ trademarks will be replaced by reference to or use of Ampleon’s own trademarks. Translations — A non-English (translated) version of a document is for reference only. The English version shall prevail in case of any discrepancy between the translated and English versions. 13. Contact information For more information, please visit: http://www.ampleon.com BLF6G15L-500H_6G15LS-500H#4 Product data sheet For sales office addresses, please visit: http://www.ampleon.com/sales All information provided in this document is subject to legal disclaimers. Rev. 4 — 1 September © Ampleon The Netherlands B.V. 2015. All rights reserved. 12 of 13 BLF6G15L-500H; BLF6G15LS-500H Power LDMOS transistor 14. Contents 1 1.1 1.2 1.3 2 3 4 5 6 6.1 7 7.1 7.2 7.2.1 7.2.2 7.2.3 7.3 8 9 10 11 12 12.1 12.2 12.3 12.4 12.5 13 14 Product profile . . . . . . . . . . . . . . . . . . . . . . . . . . 1 General description . . . . . . . . . . . . . . . . . . . . . 1 Features and benefits . . . . . . . . . . . . . . . . . . . . 1 Applications . . . . . . . . . . . . . . . . . . . . . . . . . . . 1 Pinning information . . . . . . . . . . . . . . . . . . . . . . 2 Ordering information . . . . . . . . . . . . . . . . . . . . . 2 Limiting values. . . . . . . . . . . . . . . . . . . . . . . . . . 2 Thermal characteristics . . . . . . . . . . . . . . . . . . 3 Characteristics . . . . . . . . . . . . . . . . . . . . . . . . . . 3 Ruggedness in class-AB operation . . . . . . . . . 3 Application information. . . . . . . . . . . . . . . . . . . 4 Impedance information . . . . . . . . . . . . . . . . . . . 4 Graphs . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 4 2-Tone. . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 4 DVB-T . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 5 Reliability . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 6 Test circuit. . . . . . . . . . . . . . . . . . . . . . . . . . . . . 7 Package outline . . . . . . . . . . . . . . . . . . . . . . . . . 8 Handling information. . . . . . . . . . . . . . . . . . . . 10 Abbreviations . . . . . . . . . . . . . . . . . . . . . . . . . . 10 Revision history . . . . . . . . . . . . . . . . . . . . . . . . 10 Legal information. . . . . . . . . . . . . . . . . . . . . . . 11 Data sheet status . . . . . . . . . . . . . . . . . . . . . . 11 Definitions . . . . . . . . . . . . . . . . . . . . . . . . . . . . 11 Disclaimers . . . . . . . . . . . . . . . . . . . . . . . . . . . 11 Licenses . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 12 Trademarks. . . . . . . . . . . . . . . . . . . . . . . . . . . 12 Contact information. . . . . . . . . . . . . . . . . . . . . 12 Contents . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 13 Please be aware that important notices concerning this document and the product(s) described herein, have been included in section ‘Legal information’. © Ampleon The Netherlands B.V. 2015. All rights reserved. For more information, please visit: http://www.ampleon.com For sales office addresses, please visit: http://www.ampleon.com/sales Date of release: 1 September Document identifier: BLF6G15L-500H_6G15LS-500H#4
BLF6G15L-500H,112 价格&库存
很抱歉,暂时无法提供与“BLF6G15L-500H,112”相匹配的价格&库存,您可以联系我们找货
