BLA8G1011LS-300U
BLA8G1011LS-300U
    AMPLEON(安谱隆)
    SOT502B
    BLA8G1011LS-300U
BLA8G1011LS-300U 数据手册
BLA8G1011L(S)-300; BLA8G1011L(S)-300G Power LDMOS transistor Rev. 4 — 4 August 2016 Product data sheet 1. Product profile 1.1 General description 300 W LDMOS power transistor for avionics applications at frequencies from 1030 MHz to 1090 MHz. Table 1. Test information Typical RF performance at Tcase = 25 C in a class-AB production test circuit. Test signal pulsed RF f VDS PL Gp D tr tf (MHz) (V) (W) (dB) (%) (ns) (ns) 1060 32 300 16.5 56 14 5 1.2 Features and benefits         Easy power control Integrated ESD protection Enhanced ruggedness High efficiency Excellent thermal stability Designed for broadband operation (1030 MHz to 1090 MHz) Internally matched for ease of use Compliant to Directive 2002/95/EC, regarding Restriction of Hazardous Substances (RoHS) 1.3 Applications  Avionics transmitter applications in the 1030 MHz to 1090 MHz frequency range BLA8G1011L(S)-300(G) Power LDMOS transistor 2. Pinning information Table 2. Pinning Pin Description Simplified outline Graphic symbol BLA8G1011L-300 (SOT502A) 1 drain 2 gate 3 source 1 1 3 [1] 2 2 3 sym112 BLA8G1011LS-300 (SOT502B) 1 drain 2 gate 3 source 1 1 3 [1] 2 2 3 sym112 BLA8G1011L-300G (SOT502F) 1 drain 2 gate 3 source 1 1 [1] 3 2 3 2 sym112 BLA8G1011LS-300G (SOT502E) 1 drain 2 gate 3 source 1 1 [1] 2 3 2 3 sym112 [1] Connected to flange. 3. Ordering information Table 3. BLA8G1011L-300_LS-300_L-300G_LS-300G Product data sheet Ordering information Type number Package Name Description Version BLA8G1011L-300 - flanged ceramic package; 2 mounting holes; 2 leads SOT502A BLA8G1011LS-300 - earless flanged ceramic package; 2 leads SOT502B BLA8G1011L-300G - eared flanged ceramic package; 2 leads; 2 mounting holes SOT502F BLA8G1011LS-300G - earless flanged ceramic package; 2 leads SOT502E All information provided in this document is subject to legal disclaimers. Rev. 4 — 4 August 2016 © Ampleon Netherlands B.V. 2016. All rights reserved. 2 of 14 BLA8G1011L(S)-300(G) Power LDMOS transistor 4. Limiting values Table 4. Limiting values In accordance with the Absolute Maximum Rating System (IEC 60134). Symbol Parameter Conditions Min Max Unit VDS drain-source voltage - 65 V VGS gate-source voltage 0.5 +13 V Tstg storage temperature 65 +150 C - 225 C junction temperature Tj [1] [1] Continuous use at maximum temperature will affect the reliability, for details refer to the on-line MTF calculator. 5. Thermal characteristics Table 5. Thermal characteristics Symbol Parameter Zth(j-c) Conditions Typ transient thermal impedance from junction to Tcase = 25 C; tp = 10 s; case  = 10 % Unit 0.112 K/W 6. Characteristics Table 6. DC characteristics Tj = 25 C unless otherwise specified. Symbol Parameter Conditions V(BR)DSS drain-source breakdown voltage VGS = 0 V; ID = 4.5 mA Min Typ Max Unit 65 - - V VGS(th) gate-source threshold voltage VDS = 10 V; ID = 450 mA 1.5 1.8 2.3 V IDSS drain leakage current VGS = 0 V; VDS = 28 V - - 4.2 A IDSX drain cut-off current VGS = VGS(th) + 3.75 V; VDS = 10 V 67.9 82 - A IGSS gate leakage current VGS = 11 V; VDS = 0 V - - 420 nA gfs forward transconductance VDS = 10 V; ID = 450 mA 2.67 3.92 5.25 S RDS(on) drain-source on-state resistance VGS = VGS(th) + 3.75 V; ID = 15.75 A 0.008 0.04 0.079  Table 7. RF characteristics Test signal: pulsed RF; tp = 50 s;  = 2 %; VDS = 32 V; f = 1060 MHz; IDq = 150 mA; Tcase = 25 C; unless otherwise specified; in a class-AB production test circuit for straight leads. BLA8G1011L-300_LS-300_L-300G_LS-300G Product data sheet Symbol Parameter Conditions Min Typ Max Unit Gp power gain PL = 300 W 15 16.5 - dB RLin input return loss PL = 300 W - 16 11 dB D drain efficiency PL = 300 W 52 56 - % tr rise time PL = 300 W - 14 - ns tf fall time PL = 300 W - 5 - ns All information provided in this document is subject to legal disclaimers. Rev. 4 — 4 August 2016 © Ampleon Netherlands B.V. 2016. All rights reserved. 3 of 14 BLA8G1011L(S)-300(G) Power LDMOS transistor 7. Test information 7.1 Ruggedness in class-AB operation The BLA8G1011L-300, BLA8G1011LS-300, BLA8G1011L-300G and BLA8G1011LS-300G are enhanced rugged devices and are capable of withstanding a load mismatch corresponding to VSWR = 10 : 1 through all phases under the following conditions: tp = 50 s;  = 2 %; VDS = 32 V; IDq = 100 mA; PL = 300 W; f = 1030 MHz to 1090 MHz. 7.2 Impedance information Table 8. Typical impedance Typical values unless otherwise specified. f ZS ZL (MHz) () () 1000 2.84  j3.69 0.80  j1.00 1050 3.98  j3.26 0.62  j1.26 1100 5.22  j2.92 0.66  j1.17 drain ZL gate ZS 001aaf059 Fig 1. BLA8G1011L-300_LS-300_L-300G_LS-300G Product data sheet Definition of transistor impedance All information provided in this document is subject to legal disclaimers. Rev. 4 — 4 August 2016 © Ampleon Netherlands B.V. 2016. All rights reserved. 4 of 14 BLA8G1011L(S)-300(G) Power LDMOS transistor 7.3 Test circuit 70 mm 70 mm R3 C17 C5 C19 R1 C21 C3 C11 C14 C15 C22 C9 C1 C7 60 mm C8 C4 C6 C10 C12 C20 C13 C2 R2 C18 aaa-015867 Printed-Circuit Board (PCB): Rogers 4350B; r = 3.66; thickness = 0.765 mm; thickness copper plating = 35 m. See Table 9 for a list of components. Fig 2. Component layout Table 9. List of components See Figure 2 for component layout. BLA8G1011L-300_LS-300_L-300G_LS-300G Product data sheet Component Description Value C1, C4 multilayer ceramic chip capacitor 91 pF ATC: ATC100A910FT150XT C2, C3, C5 multilayer ceramic chip capacitor 39 pF ATC: ATC100B390FT500XTV C6 multilayer ceramic chip capacitor 1.5 pF ATC: ATC800B1R5BT500XTV C7 multilayer ceramic chip capacitor 3.3 pF ATC: ATC100B3R3BT500XTV C8 multilayer ceramic chip capacitor 2.4 pF ATC: ATC100B2R4BT500XTV C9, C10 multilayer ceramic chip capacitor 0.6 pF ATC: ATC100B0R6BT500XTV C11, C12 multilayer ceramic chip capacitor 2.7 pF ATC: ATC100B2R7BT500XTV C13, C14, C15 multilayer ceramic chip capacitor 0.1 F Murata: GRM31C5C1H104JA01K C17, C18, C19 multilayer ceramic chip capacitor 1 F Murata: GRM31MR71H105KA88L C20, C21 multilayer ceramic chip capacitor 4.7 F TDK: C5750X7R2A475K230KA C22 multilayer ceramic chip capacitor 4.7 F R1, R2 SMD resistor 9.1  Yageo: RC0805FR-079R1L R3 SMD resistor 0.01  Ohmite: LVK25R010FER All information provided in this document is subject to legal disclaimers. Rev. 4 — 4 August 2016 Remarks Murata: GRM32ER71H475KA88L © Ampleon Netherlands B.V. 2016. All rights reserved. 5 of 14 BLA8G1011L(S)-300(G) Power LDMOS transistor 7.4 Graphical data aaa-015756 500 aaa-015757 18 PL (W) Gp (dB) 400 17 300 (3) (2) (1) 16 200 (3) (2) (1) 15 100 0 14 0 2 4 6 8 10 12 Pi (W) 14 0 VDS = 32 V; IDq = 150 mA; tp = 50 s;  = 2 %. 50 100 200 250 300 350 PL (W) 400 VDS = 32 V; IDq = 150 mA; tp = 50 s;  = 2 %. (1) f = 1030 MHz (1) f = 1030 MHz (2) f = 1060 MHz (2) f = 1060 MHz (3) f = 1090 MHz (3) f = 1090 MHz Fig 3. 150 Output power as a function of input power; typical values Fig 4. Power gain as a function of output power; typical values aaa-015758 80 ηD (%) 60 40 (3) (2) (1) 20 0 0 50 100 150 200 250 300 350 PL (W) 400 VDS = 32 V; IDq = 150 mA; tp = 50 s;  = 2 %. (1) f = 1030 MHz (2) f = 1060 MHz (3) f = 1090 MHz Fig 5. Drain efficiency as a function of output power; typical values BLA8G1011L-300_LS-300_L-300G_LS-300G Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 4 — 4 August 2016 © Ampleon Netherlands B.V. 2016. All rights reserved. 6 of 14 BLA8G1011L(S)-300(G) Power LDMOS transistor 8. Package outline Flanged ceramic package; 2 mounting holes; 2 leads SOT502A D A F 3 D1 U1 B q c C 1 H L E1 p U2 E w1 M A M B M A 2 w2 M C M b 0 5 Q 10 mm scale DIMENSIONS (millimetre dimensions are derived from the original inch dimensions) UNIT A b c mm 4.72 3.43 12.83 12.57 0.15 0.08 inches 0.186 0.135 0.505 0.006 0.495 0.003 OUTLINE VERSION E E1 F H L p Q q U1 U2 w1 w2 20.02 19.96 19.61 19.66 9.50 9.30 9.53 9.25 1.14 0.89 19.94 18.92 5.33 4.32 3.38 3.12 1.70 1.45 27.94 34.16 33.91 9.91 9.65 0.25 0.51 0.788 0.786 0.772 0.774 0.374 0.375 0.366 0.364 0.067 1.100 0.057 1.345 1.335 0.390 0.380 0.01 0.02 D D1 0.045 0.785 0.210 0.133 0.035 0.745 0.170 0.123 REFERENCES IEC JEDEC JEITA ISSUE DATE 03-01-10 12-05-02 SOT502A Fig 6. EUROPEAN PROJECTION Package outline SOT502A BLA8G1011L-300_LS-300_L-300G_LS-300G Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 4 — 4 August 2016 © Ampleon Netherlands B.V. 2016. All rights reserved. 7 of 14 BLA8G1011L(S)-300(G) Power LDMOS transistor Earless flanged ceramic package; 2 leads SOT502B D A F 3 D D1 c U1 1 L H E1 U2 E 2 w2 M D M b 0 5 Q 10 mm scale DIMENSIONS (millimetre dimensions are derived from the original inch dimensions) UNIT A b c mm 4.72 3.43 12.83 12.57 0.15 0.08 inches 0.186 0.135 0.505 0.006 0.495 0.003 OUTLINE VERSION E E1 F H L Q U1 U2 w2 20.02 19.96 19.61 19.66 9.50 9.30 9.53 9.25 1.14 0.89 19.94 18.92 5.33 4.32 1.70 1.45 20.70 20.45 9.91 9.65 0.25 0.788 0.786 0.772 0.774 0.374 0.375 0.366 0.364 D D1 0.045 0.785 0.210 0.035 0.745 0.170 0.067 0.815 0.057 0.805 REFERENCES IEC JEDEC JEITA EUROPEAN PROJECTION ISSUE DATE 07-05-09 12-05-02 SOT502B Fig 7. 0.390 0.010 0.380 Package outline SOT502B BLA8G1011L-300_LS-300_L-300G_LS-300G Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 4 — 4 August 2016 © Ampleon Netherlands B.V. 2016. All rights reserved. 8 of 14 BLA8G1011L(S)-300(G) Power LDMOS transistor Earless flanged ceramic package; 2 leads SOT502E 0.3 mm gauge plane D Lp F A D1 y Q detail X U1 v B w2 b A c B X H U2 E E1 A θ 0 5 Dimensions Unit(1) mm 10 mm scale A max 4.72 nom min 3.43 b c 12.83 0.15 12.57 0.07 D D1 E E1 F H Lp Q U1 U2 v w2 y θ 20.02 19.96 9.53 9.53 1.14 14.3 1.38 0.195 20.70 9.91 0.25 0.25 0.15 7° 19.61 19.66 9.27 9.27 0.89 14.1 0.98 0.055 20.45 9.65 max 0.185 0.505 0.006 0.788 0.786 0.375 0.375 0.045 0.563 0.055 0.008 inches nom min 0.135 0.495 0.003 0.772 0.774 0.365 0.365 0.035 0.555 0.039 0.002 0° 0.815 0.390 0.010 0.010 0.006 7° 0.805 0.380 0° Note 1. Millimeter dimensions are derived from the original inch dimensions. Outline version References IEC JEDEC JEITA European projection Issue date 12-05-14 12-05-30 SOT502E Fig 8. sot502e_po Package outline SOT502E BLA8G1011L-300_LS-300_L-300G_LS-300G Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 4 — 4 August 2016 © Ampleon Netherlands B.V. 2016. All rights reserved. 9 of 14 BLA8G1011L(S)-300(G) Power LDMOS transistor Eared flanged ceramic package; 2 leads; 2 mounting holes SOT502F 0.3 mm gauge plane Lp D Q F A D1 y detail X U1 B q v H w2 b A c B X p U2 E E1 A θ w1 0 5 A B 10 mm scale Dimensions (mm are the original dimensions) Unit(1) mm A b c D D1 E1 F H Lp p Q 9.53 1.14 14.3 1.38 3.38 0.195 E max 4.70 12.83 0.15 20.02 19.96 9.53 nom min 3.43 12.57 0.07 19.61 19.66 9.27 q U1 U2 0.89 14.1 0.98 3.12 w1 w2 0.25 0.25 0.25 34.16 9.91 27.94 9.27 v 0.055 θ U1 7° 33.91 9.65 0.15 0° sot502f_po Outline version References IEC JEDEC JEITA Issue date 14-02-19 14-03-14 SOT502F Fig 9. European projection Package outline SOT502F BLA8G1011L-300_LS-300_L-300G_LS-300G Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 4 — 4 August 2016 © Ampleon Netherlands B.V. 2016. All rights reserved. 10 of 14 BLA8G1011L(S)-300(G) Power LDMOS transistor 9. Handling information CAUTION This device is sensitive to ElectroStatic Discharge (ESD). Observe precautions for handling electrostatic sensitive devices. Such precautions are described in the ANSI/ESD S20.20, IEC/ST 61340-5, JESD625-A or equivalent standards. 10. Abbreviations Table 10. Abbreviations Acronym Description ESD ElectroStatic Discharge LDMOS Laterally Diffused Metal-Oxide Semiconductor MTF Median Time to Failure SMD Surface Mounted Device VSWR Voltage Standing-Wave Ratio 11. Revision history Table 11. Revision history Document ID Release date Data sheet status BLA8G1011L-300_LS-300_L-300G 20160804 _LS-300G v.4 Modifications: • Change notice Supersedes Product data sheet BLA8G1011L-300_LS-300 _L-300G_LS-300G v.3 Table 9 on page 5: row 4 to row 7, value units corrected from nF to pF BLA8G1011L-300_LS-300_L-300G 20150901 _LS-300G v.3 Product data sheet BLA8G1011L-300_LS-300 _L-300G_LS-300G v.2 BLA8G1011L-300_LS-300_L-300G 20150126 _LS-300G v.2 Product data sheet BLA8G1011L-300_LS-300 _L-300G_LS-300G v.1 BLA8G1011L-300_LS-300_L-300G 20140929 _LS-300G v.1 Objective data sheet - BLA8G1011L-300_LS-300_L-300G_LS-300G Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 4 — 4 August 2016 © Ampleon Netherlands B.V. 2016. All rights reserved. 11 of 14 BLA8G1011L(S)-300(G) Power LDMOS transistor 12. Legal information 12.1 Data sheet status Document status[1][2] Product status[3] Definition Objective [short] data sheet Development This document contains data from the objective specification for product development. Preliminary [short] data sheet Qualification This document contains data from the preliminary specification. Product [short] data sheet Production This document contains the product specification. [1] Please consult the most recently issued document before initiating or completing a design. [2] The term ‘short data sheet’ is explained in section “Definitions”. [3] The product status of device(s) described in this document may have changed since this document was published and may differ in case of multiple devices. The latest product status information is available on the Internet at URL http://www.ampleon.com. 12.2 Definitions Draft — The document is a draft version only. The content is still under internal review and subject to formal approval, which may result in modifications or additions. Ampleon does not give any representations or warranties as to the accuracy or completeness of information included herein and shall have no liability for the consequences of use of such information. Short data sheet — A short data sheet is an extract from a full data sheet with the same product type number(s) and title. A short data sheet is intended for quick reference only and should not be relied upon to contain detailed and full information. For detailed and full information see the relevant full data sheet, which is available on request via the local Ampleon sales office. In case of any inconsistency or conflict with the short data sheet, the full data sheet shall prevail. Product specification — The information and data provided in a Product data sheet shall define the specification of the product as agreed between Ampleon and its customer, unless Ampleon and customer have explicitly agreed otherwise in writing. In no event however, shall an agreement be valid in which the Ampleon product is deemed to offer functions and qualities beyond those described in the Product data sheet. 12.3 Disclaimers Limited warranty and liability — Information in this document is believed to be accurate and reliable. However, Ampleon does not give any representations or warranties, expressed or implied, as to the accuracy or completeness of such information and shall have no liability for the consequences of use of such information. Ampleon takes no responsibility for the content in this document if provided by an information source outside of Ampleon. In no event shall Ampleon be liable for any indirect, incidental, punitive, special or consequential damages (including - without limitation - lost profits, lost savings, business interruption, costs related to the removal or replacement of any products or rework charges) whether or not such damages are based on tort (including negligence), warranty, breach of contract or any other legal theory. Notwithstanding any damages that customer might incur for any reason whatsoever, Ampleon’s aggregate and cumulative liability towards customer for the products described herein shall be limited in accordance with the Terms and conditions of commercial sale of Ampleon. Right to make changes — Ampleon reserves the right to make changes to information published in this document, including without limitation specifications and product descriptions, at any time and without notice. This document supersedes and replaces all information supplied prior to the publication hereof. Suitability for use — Ampleon products are not designed, authorized or warranted to be suitable for use in life support, life-critical or safety-critical systems or equipment, nor in applications where failure or malfunction of an BLA8G1011L-300_LS-300_L-300G_LS-300G Product data sheet Ampleon product can reasonably be expected to result in personal injury, death or severe property or environmental damage. Ampleon and its suppliers accept no liability for inclusion and/or use of Ampleon products in such equipment or applications and therefore such inclusion and/or use is at the customer’s own risk. Applications — Applications that are described herein for any of these products are for illustrative purposes only. Ampleon makes no representation or warranty that such applications will be suitable for the specified use without further testing or modification. Customers are responsible for the design and operation of their applications and products using Ampleon products, and Ampleon accepts no liability for any assistance with applications or customer product design. It is customer’s sole responsibility to determine whether the Ampleon product is suitable and fit for the customer’s applications and products planned, as well as for the planned application and use of customer’s third party customer(s). Customers should provide appropriate design and operating safeguards to minimize the risks associated with their applications and products. Ampleon does not accept any liability related to any default, damage, costs or problem which is based on any weakness or default in the customer’s applications or products, or the application or use by customer’s third party customer(s). Customer is responsible for doing all necessary testing for the customer’s applications and products using Ampleon products in order to avoid a default of the applications and the products or of the application or use by customer’s third party customer(s). Ampleon does not accept any liability in this respect. Limiting values — Stress above one or more limiting values (as defined in the Absolute Maximum Ratings System of IEC 60134) will cause permanent damage to the device. Limiting values are stress ratings only and (proper) operation of the device at these or any other conditions above those given in the Recommended operating conditions section (if present) or the Characteristics sections of this document is not warranted. Constant or repeated exposure to limiting values will permanently and irreversibly affect the quality and reliability of the device. Terms and conditions of commercial sale — Ampleon products are sold subject to the general terms and conditions of commercial sale, as published at http://www.ampleon.com/terms, unless otherwise agreed in a valid written individual agreement. In case an individual agreement is concluded only the terms and conditions of the respective agreement shall apply. Ampleon hereby expressly objects to applying the customer’s general terms and conditions with regard to the purchase of Ampleon products by customer. No offer to sell or license — Nothing in this document may be interpreted or construed as an offer to sell products that is open for acceptance or the grant, conveyance or implication of any license under any copyrights, patents or other industrial or intellectual property rights. Export control — This document as well as the item(s) described herein may be subject to export control regulations. Export might require a prior authorization from competent authorities. All information provided in this document is subject to legal disclaimers. Rev. 4 — 4 August 2016 © Ampleon Netherlands B.V. 2016. All rights reserved. 12 of 14 BLA8G1011L(S)-300(G) Power LDMOS transistor Non-automotive qualified products — Unless this data sheet expressly states that this specific Ampleon product is automotive qualified, the product is not suitable for automotive use. It is neither qualified nor tested in accordance with automotive testing or application requirements. Ampleon accepts no liability for inclusion and/or use of non-automotive qualified products in automotive equipment or applications. In the event that customer uses the product for design-in and use in automotive applications to automotive specifications and standards, customer (a) shall use the product without Ampleon’s warranty of the product for such automotive applications, use and specifications, and (b) whenever customer uses the product for automotive applications beyond Ampleon’s specifications such use shall be solely at customer’s own risk, and (c) customer fully indemnifies Ampleon for any liability, damages or failed product claims resulting from customer design and use of the product for automotive applications beyond Ampleon’s standard warranty and Ampleon’s product specifications. Translations — A non-English (translated) version of a document is for reference only. The English version shall prevail in case of any discrepancy between the translated and English versions. 12.4 Trademarks Notice: All referenced brands, product names, service names and trademarks are the property of their respective owners. Any reference or use of any ‘NXP’ trademark in this document or in or on the surface of Ampleon products does not result in any claim, liability or entitlement vis-à-vis the owner of this trademark. Ampleon is no longer part of the NXP group of companies and any reference to or use of the ‘NXP’ trademarks will be replaced by reference to or use of Ampleon’s own trademarks. 13. Contact information For more information, please visit: http://www.ampleon.com For sales office addresses, please visit: http://www.ampleon.com/sales BLA8G1011L-300_LS-300_L-300G_LS-300G Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 4 — 4 August 2016 © Ampleon Netherlands B.V. 2016. All rights reserved. 13 of 14 BLA8G1011L(S)-300(G) Power LDMOS transistor 14. Contents 1 1.1 1.2 1.3 2 3 4 5 6 7 7.1 7.2 7.3 7.4 8 9 10 11 12 12.1 12.2 12.3 12.4 13 14 Product profile . . . . . . . . . . . . . . . . . . . . . . . . . . 1 General description . . . . . . . . . . . . . . . . . . . . . 1 Features and benefits . . . . . . . . . . . . . . . . . . . . 1 Applications . . . . . . . . . . . . . . . . . . . . . . . . . . . 1 Pinning information . . . . . . . . . . . . . . . . . . . . . . 2 Ordering information . . . . . . . . . . . . . . . . . . . . . 2 Limiting values. . . . . . . . . . . . . . . . . . . . . . . . . . 3 Thermal characteristics . . . . . . . . . . . . . . . . . . 3 Characteristics . . . . . . . . . . . . . . . . . . . . . . . . . . 3 Test information . . . . . . . . . . . . . . . . . . . . . . . . . 4 Ruggedness in class-AB operation . . . . . . . . . 4 Impedance information . . . . . . . . . . . . . . . . . . . 4 Test circuit. . . . . . . . . . . . . . . . . . . . . . . . . . . . . 5 Graphical data . . . . . . . . . . . . . . . . . . . . . . . . . 6 Package outline . . . . . . . . . . . . . . . . . . . . . . . . . 7 Handling information. . . . . . . . . . . . . . . . . . . . 11 Abbreviations . . . . . . . . . . . . . . . . . . . . . . . . . . 11 Revision history . . . . . . . . . . . . . . . . . . . . . . . . 11 Legal information. . . . . . . . . . . . . . . . . . . . . . . 12 Data sheet status . . . . . . . . . . . . . . . . . . . . . . 12 Definitions . . . . . . . . . . . . . . . . . . . . . . . . . . . . 12 Disclaimers . . . . . . . . . . . . . . . . . . . . . . . . . . . 12 Trademarks. . . . . . . . . . . . . . . . . . . . . . . . . . . 13 Contact information. . . . . . . . . . . . . . . . . . . . . 13 Contents . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 14 Please be aware that important notices concerning this document and the product(s) described herein, have been included in section ‘Legal information’. © Ampleon Netherlands B.V. 2016. All rights reserved. For more information, please visit: http://www.ampleon.com For sales office addresses, please visit: http://www.ampleon.com/sales Date of release: 4 August 2016 Document identifier: BLA8G1011L-300_LS-300_L-300G_LS-300G
BLA8G1011LS-300U
1. 物料型号:型号为STM32F103C8T6,是一款基于ARM Cortex-M3内核的32位微控制器。
2. 器件简介:该器件是意法半导体生产的高性能微控制器,具有多种通信接口和外设,适用于多种嵌入式应用。
3. 引脚分配:该器件共有48个引脚,包括电源引脚、地引脚、I/O引脚等,具体分配需参考引脚图。
4. 参数特性:工作电压2.0V至3.6V,工作频率72MHz,内置64KB Flash和20KB RAM。
5. 功能详解:包括GPIO、ADC、定时器、通信接口(UART、SPI、I2C)等模块的详细介绍。
6. 应用信息:适用于工业控制、医疗设备、消费电子等多种应用场景。
BLA8G1011LS-300U 价格&库存
很抱歉,暂时无法提供与“BLA8G1011LS-300U”相匹配的价格&库存,您可以联系我们找货
