BLF6G10LS-260PRN,1
BLF6G10LS-260PRN,1
    AMPLEON(安谱隆)
    SOT539B
    TRANS PWR LDMOS SOT539
BLF6G10LS-260PRN,1 数据手册
BLF6G10L-260PRN; BLF6G10LS-260PRN Power LDMOS transistor Rev. 3 — 1 September 2015 Product data sheet 1. Product profile 1.1 General description 260 W LDMOS power transistor for base station applications at frequencies from 700 MHz to 1000 MHz. Table 1. Typical performance Typical RF performance at Tcase = 25 C in a class-AB production test circuit. Mode of operation 2-carrier W-CDMA [1] f VDS PL(AV) Gp D ACPR (MHz) (V) (W) (dB) (%) (dBc) 920 to 960 28 40 22.0 26.5 39[1] Test signal: 3GPP test model 1; 1 to 64 DPCH; PAR = 7.5 dB at 0.01 % probability on CCDF per carrier; carrier spacing 5 MHz. CAUTION This device is sensitive to ElectroStatic Discharge (ESD). Therefore care should be taken during transport and handling. 1.2 Features and benefits  Typical 2-carrier W-CDMA performance at frequencies of 920 MHz and 960 MHz, a supply voltage of 28 V and an IDq of 1800 mA:  Average output power = 40 W  Power gain = 22.0 dB  Efficiency = 26.5 %  ACPR = 39 dBc  Easy power control  Integrated ESD protection  Excellent ruggedness  High efficiency  Excellent thermal stability  Designed for broadband operation (700 MHz to 1000 MHz)  Internally matched for ease of use  Compliant to Restriction of Hazardous Substances (RoHS) Directive 2002/95/EC BLF6G10L(S)-260PRN Power LDMOS transistor 1.3 Applications  RF power amplifiers for GSM, GSM EDGE, W-CDMA and CDMA base stations and multi carrier applications in the 700 MHz to 1000 MHz frequency range 2. Pinning information Table 2. Pinning Pin Description Simplified outline Graphic symbol BLF6G10L-260PRN (SOT539A) 1 drain1 2 drain2 3 gate1 4 gate2 5 source 1 2 1 5 3 3 4 5 4 [1] 2 sym117 BLF6G10LS-260PRN (SOT539B) 1 drain1 2 drain2 3 gate1 4 gate2 5 1 1 2 5 3 3 4 [1] source 5 4 2 sym117 [1] Connected to flange. 3. Ordering information Table 3. Ordering information Type number Package BLF6G10L-260PRN Name Description Version - flanged balanced LDMOST ceramic package; 2 mounting holes; 4 leads SOT539A BLF6G10LS-260PRN - BLF6G10L-260PRN_LS-260PRN#3 Product data sheet earless flanged balanced LDMOST ceramic package; SOT539B 4 leads All information provided in this document is subject to legal disclaimers. Rev. 3 — 1 September 2015 © Ampleon The Netherlands B.V. 2015. All rights reserved. 2 of 15 BLF6G10L(S)-260PRN Power LDMOS transistor 4. Limiting values Table 4. Limiting values In accordance with the Absolute Maximum Rating System (IEC 60134). Symbol Parameter Conditions Min Max Unit VDS drain-source voltage - 65 V VGS gate-source voltage 0.5 +13 V ID drain current - 64 A Tstg storage temperature 65 +150 C Tj junction temperature - 200 C 5. Thermal characteristics Table 5. Thermal characteristics Symbol Parameter Conditions Typ Unit Rth(j-case) thermal resistance from junction to case Tcase = 80 C; PL = 40 W 0.28 K/W 6. Characteristics Table 6. Characteristics Tj = 25 C; values per section unless otherwise specified. Symbol Parameter Conditions Min Typ Max Unit V(BR)DSS drain-source breakdown voltage VGS = 0 V; ID = 1.8 mA 65 - - V VGS(th) gate-source threshold voltage VDS = 10 V; ID = 180 mA 1.4 1.9 2.4 V VGSq gate-source quiescent voltage VDS = 28 V; ID = 1000 mA 1.45 2.1 2.55 V IDSS drain leakage current VGS = 0 V; VDS = 28 V - - 2.8 A IDSX drain cut-off current VGS = VGS(th) + 3.75 V; VDS = 10 V 24.1 30 - A IGSS gate leakage current VGS = 11 V; VDS = 0 V - - 280 nA gfs forward transconductance VDS = 10 V; ID = 9 A 7.02 12 - S RDS(on) drain-source on-state resistance VGS = VGS(th) + 3.75 V; ID = 6.3 A 0.053 0.1 0.165  7. Application information Table 7. 2-carrier W-CDMA Application information Class-AB production test circuit; PAR 7.5 dB at 0.01 % probability on CCDF; 3GPP test model 1; 1 to 64 DPCH; f1 = 917.5 MHz; f2 = 922.5 MHz; f3 = 957.5 MHz; f4 = 962.5 MHz; RF performance at VDS = 28 V; IDq = 1800 mA; Tcase = 25 C; unless otherwise specified. BLF6G10L-260PRN_LS-260PRN#3 Product data sheet Symbol Parameter PL(AV) average output power Conditions Gp power gain PL(AV) = 40 W All information provided in this document is subject to legal disclaimers. Rev. 3 — 1 September 2015 Min Typ Max Unit - 40 - W 19.8 22.0 - dB © Ampleon The Netherlands B.V. 2015. All rights reserved. 3 of 15 BLF6G10L(S)-260PRN Power LDMOS transistor Table 7. 2-carrier W-CDMA Application information …continued Class-AB production test circuit; PAR 7.5 dB at 0.01 % probability on CCDF; 3GPP test model 1; 1 to 64 DPCH; f1 = 917.5 MHz; f2 = 922.5 MHz; f3 = 957.5 MHz; f4 = 962.5 MHz; RF performance at VDS = 28 V; IDq = 1800 mA; Tcase = 25 C; unless otherwise specified. Symbol Parameter Conditions Min Typ RLin input return loss PL(AV) = 40 W - 10.0 6.0 Max dB Unit D drain efficiency PL(AV) = 40 W 25.0 26.5 - % ACPR adjacent channel power ratio PL(AV) = 40 W - 39 35 dBc Table 8. 1 carrier W-CDMA Application information Class-AB production test circuit; PAR 7.5 dB at 0.01 % probability on CCDF; 3 GPP test model 1; 1 to 64 DPCH; f1 = 960 MHz; RF performance at VDS = 28 V; Idq 1800 mA; Tcase = 25 C; unless otherwise specified. Symbol Parameter PAR0 Conditions output peak-to-average ratio Min PL(AV) = 125 W at 0.01 % 3.8 probability on CCDF Typ Max Unit 4.3 - dB 7.1 Ruggedness in class-AB operation The BLF6G10L-260PRN and BLF6G10L-260PRN are capable of withstanding a load mismatch corresponding to VSWR = 10 : 1 through all phases under the following conditions: VDS = 28 V; IDq = 1800 mA; PL = 260 W (CW); f = 920 MHz to 960 MHz. 7.2 Impedance information Table 9. Typical impedance per section IDq = 950 mA; main transistor VDS = 28 V f MHz ZS[1]  ZL[1]  920 0.7  j1.0 1.4 + j0.6 940 1.1  j1.3 1.2 + j0.5 960 1.0  j1.6 1.2 + j0.3 [1] ZS and ZL defined in Figure 1. drain ZL gate ZS 001aaf059 Fig 1. BLF6G10L-260PRN_LS-260PRN#3 Product data sheet Definition of transistor impedance All information provided in this document is subject to legal disclaimers. Rev. 3 — 1 September 2015 © Ampleon The Netherlands B.V. 2015. All rights reserved. 4 of 15 BLF6G10L(S)-260PRN Power LDMOS transistor 7.3 Typical powersweep 7.3.1 CW Gp (dB) 014aab123 23 70 60 22 ηD (%) (1) (2) 21 50 (3) (4) (5) 20 40 (6) 19 30 18 20 17 10 16 0 100 200 0 400 300 PL (W) (1) % efficiency at 960 MHz (2) % efficiency at 940 MHz (3) % efficiency at 920 MHz (4) dB gain at 940 MHz (5) dB gain at 920 MHz (6) dB gain at 960 MHz Fig 2. Typical continuous wave 1 (gain; efficiency versus PO) 014aab126 24 RLin (dB) 20 (1) 16 (2) 12 (3) 8 0 50 100 150 200 250 300 PL (W) 350 (1) dB return loss at 940 MHz (2) dB return loss at 920 MHz (3) dB return loss at 960 MHz Fig 3. BLF6G10L-260PRN_LS-260PRN#3 Product data sheet Typical continuous wave 2 (return loss versus PO) All information provided in this document is subject to legal disclaimers. Rev. 3 — 1 September 2015 © Ampleon The Netherlands B.V. 2015. All rights reserved. 5 of 15 BLF6G10L(S)-260PRN Power LDMOS transistor 7.3.2 IS95 014aab124 24.5 60 (1) Gp (dB) ηD (%) (2) (3) 22.5 014aab127 −30 ACPR1, ACPR2 (dBc) 12 PAR (dB) (1) (2) −40 10 (3) 40 −50 8 (4) (5) (4) −60 (6) 20.5 (5) 20 (7) (8) −70 18.5 0 50 0 150 100 6 −80 (6) (9) 0 40 80 2 160 120 PL (AV) 4 PL (AV) (1) % efficiency at 960 MHz (1) 885 kHz ACPR1, dBc at 960 MHz (2) % efficiency at 940 MHz (2) 885 kHz ACPR1, dBc at 940 MHz (3) % efficiency at 920 MHz (3) 885 kHz ACPR1, dBc at 920 MHz (4) dB gain at 940 MHz (4) PAR, dB at 940 MHz (5) dB gain at 920 MHz (5) PAR, dB at 920 MHz (6) dB gain at 960 MHz (6) PAR, dB at 960 MHz (7) 1980 kHz ACPR2, dBc at 940 MHz (8) 1980 kHz ACPR2, dBc 920 MHz (9) 1980 kHz ACPR2, dBc at 960 MHz a. Gain and efficiency versus PO b. ACPR1, ACPR2 and PAR versus PO IS95, PAR = 9.8 dB at 0.01% probability of the CCDF. Fig 4. Typical IS95 (gain; efficiency; ACPR1, ACPR2 and PAR versus PO) BLF6G10L-260PRN_LS-260PRN#3 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 3 — 1 September 2015 © Ampleon The Netherlands B.V. 2015. All rights reserved. 6 of 15 BLF6G10L(S)-260PRN Power LDMOS transistor 7.3.3 2C-WCDMA (5 MHz spacing) 014aab122 24.5 60 (1) Gp (dB) ηD (%) (2) (3) 22.5 (4) 014aab125 −20 ACPR1, ACPR2 (dBc) 10 (1) PAR (dB) (2) (3) −28 9 40 −36 (5) 8 (4) (5) (6) (6) −44 20.5 (7) 20 7 (8) (9) −52 18.5 0 50 0 150 100 −60 6 0 50 5 150 100 PL (AV) PL (AV) (1) % efficiency at 960 MHz (1) 5 MHz ACPR1, dBc at 960 MHz (2) % efficiency at 940 MHz (2) 5 MHz ACPR1, dBc at 940 MHz (3) % efficiency at 920 MHz (3) 5 MHz ACPR1, dBc at 920 MHz (4) dB gain at 940 MHz (4) PAR, dB at 920 MHz (5) dB gain at 920 MHz (5) PAR, dB at 940 MHz (6) dB gain at 960 MHz (6) PAR, dB at 960 MHz (7) 10 MHz ACPR2, dBc at 940 MHz (8) 10 MHz ACPR2, dBc 920 MHz (9) 10 MHz ACPR2, dBc at 960 MHz a. Gain and efficiency versus PO b. ACPR1, ACPR2 and PAR versus PO 3GPP, Test Model 1, 64 DPCH, PAR=7.5 dB at 0.01% probability per carrier. 5 MHz carrier spacing. Fig 5. Typical 2C-WCDMA (gain; efficiency; ACPR1, ACPR2 and PAR versus PO) BLF6G10L-260PRN_LS-260PRN#3 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 3 — 1 September 2015 © Ampleon The Netherlands B.V. 2015. All rights reserved. 7 of 15 BLF6G10L(S)-260PRN Power LDMOS transistor 8. Test information 8.1 Test circuit Figure 6 shows the PCB test circuit layout − C9 R3 + C7 + C13 C10 − BLF6G10L-260PRN Input Rev 01 C1 BLF6G10L-260PRN Output Rev 01 C11 C5 C14 C12 C4 R6 014aab129 The above layout shows the test circuit used to measure the devices in production. The RF Power and Base-Stations group can provide a more appropriate application demonstration for specific customer needs. Fig 6. Input and output test circuit PCBs’ 8.2 Bill of materials (B.O.M.) The following Bill of materials (Table 10) shows a list of all the components needed to build the RF test circuit. Table 10. Bill of materials Component Description Type Value Code number Remarks base plate see mechanical drawing. input PCB see PCB info. output PCB see PCB info. 15  bolt M2 brass (nickel plated) 15  washer M2 brass (nickel plated) 4  contact block 12  4 mm rubber O-ring Viton 17  1 mm conductive elastomer (“silver” rubber) Chomerics 35  1 mm (2x) BLF6G10L-260PRN_LS-260PRN#3 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 3 — 1 September 2015 brass (milled) CHO-SEAL 1273 © Ampleon The Netherlands B.V. 2015. All rights reserved. 8 of 15 BLF6G10L(S)-260PRN Power LDMOS transistor Table 10. Bill of materials …continued Component Description Type C4, C5, C9, C11, C12 multilayer ceramic chip capacitor ATC 800B Value Code number Remarks 100 pF multilayer ceramic chip capacitor C1, C10, C14 multilayer ceramic chip capacitor TDK 10 F C7, C13 electrolytic capacitor 470 F R3, R6 chip resistor Philips 0603 10  copper foil strip needed for tuning standard components: N-connector male 13N-50-057/1 Suhner N-connector female 23N-50-057/1 Suhner 4  bolt M3 12 mm chromium nickle steel 4  spring washer M3 chromium nickle steel DC-connector 8 pin male 8140-115 Souriau (Farnell) 2  DC-connector 2 pin male 8140-12 Souriau (Farnell) 2  bolt M3 30 mm chromium nickle steel 2  washer M3 chromium nickle steel solid copper wire (diam. 1 mm) 30 mm 0.75 mm2 silicon isolated flexible copper wire SIMX-F 4  cable isolator (diam. 3 mm) P/H30X15WE 1922.000.10134 4  cable isolator (diam. 2 mm) P/H20X10WE 1922.000.10033 BLF6G10L-260PRN_LS-260PRN#3 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 3 — 1 September 2015 © Ampleon The Netherlands B.V. 2015. All rights reserved. 9 of 15 BLF6G10L(S)-260PRN Power LDMOS transistor 9. Package outline Flanged balanced ceramic package; 2 mounting holes; 4 leads SOT539A D A F D1 U1 B q C w2 M C M H1 1 c 2 E1 p H U2 5 L 3 A E w1 M A M B M 4 w3 M b Q e 0 5 10 mm scale DIMENSIONS (millimetre dimensions are derived from the original inch dimensions) UNIT A mm 4.7 4.2 inches b c D D1 e E E1 11.81 0.18 31.55 31.52 9.50 13.72 11.56 0.10 30.94 30.96 9.30 9.53 9.27 F H H1 L 1.75 17.12 25.53 3.48 1.50 16.10 25.27 2.97 p Q q U1 3.30 3.05 2.26 2.01 35.56 U2 w1 41.28 10.29 0.25 41.02 10.03 w2 w3 0.51 0.25 0.185 0.465 0.007 1.242 1.241 0.374 0.375 0.069 0.674 1.005 0.137 0.130 0.089 1.625 0.405 1.400 0.010 0.020 0.010 0.540 0.165 0.455 0.004 1.218 1.219 0.366 0.365 0.059 0.634 0.995 0.117 0.120 0.079 1.615 0.395 Note 1. millimeter dimensions are derived from the original inch dimensions. 2. recommended screw pitch dimension of 1.52 inch (38.6 mm) based on M3 screw. OUTLINE VERSION REFERENCES IEC JEDEC EIAJ ISSUE DATE 10-02-02 12-05-02 SOT539A Fig 7. EUROPEAN PROJECTION Package outline SOT539A BLF6G10L-260PRN_LS-260PRN#3 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 3 — 1 September 2015 © Ampleon The Netherlands B.V. 2015. All rights reserved. 10 of 15 BLF6G10L(S)-260PRN Power LDMOS transistor Earless flanged balanced ceramic package; 4 leads SOT539B D A F 5 D1 D U1 H1 w2 1 c D 2 E1 U2 H E L 3 4 w3 b Q e 0 5 10 mm scale Dimensions Unit(1) w2 w3 0.25 0.25 max 0.185 0.465 0.007 1.242 1.241 0.374 0.375 0.069 0.674 1.005 0.137 0.089 1.275 0.405 inches nom 0.01 0.54 min 0.165 0.455 0.004 1.218 1.219 0.366 0.365 0.059 0.634 0.995 0.117 0.079 1.265 0.395 0.01 mm max nom min A b 4.7 11.81 c D D1 0.18 31.55 31.52 E E1 9.5 9.53 e F H H1 L Q U1 U2 1.75 17.12 25.53 3.48 2.26 32.39 10.29 1.50 16.10 25.27 2.97 2.01 32.13 10.03 13.72 4.2 11.56 0.10 30.94 30.96 9.3 9.27 Note 1. millimeter dimensions are derived from the original inch dimensions. Outline version References IEC JEDEC JEITA European projection Issue date 12-05-02 13-05-24 SOT539B Fig 8. sot539b_po Package outline SOT539B BLF6G10L-260PRN_LS-260PRN#3 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 3 — 1 September 2015 © Ampleon The Netherlands B.V. 2015. All rights reserved. 11 of 15 BLF6G10L(S)-260PRN Power LDMOS transistor 10. Abbreviations Table 11. Abbreviations Acronym Description 3GPP Third Generation Partnership Project CCDF Complementary Cumulative Distribution Function CDMA Code Division Multiple Access CW Continuous Wave DPCH Dedicated Physical CHannel EDGE Enhanced Data rates for GSM Evolution GSM Global System for Mobile communications LDMOS Laterally Diffused Metal-Oxide Semiconductor LDMOST Laterally Diffused Metal-Oxide Semiconductor Transistor PAR Peak-to-Average power Ratio RF Radio Frequency VSWR Voltage Standing-Wave Ratio W-CDMA Wideband Code Division Multiple Access 11. Revision history Table 12. Revision history Document ID Release date BLF6G10L-260PRN_LS-260PRN#3 20150901 Product data sheet - Modifications: Data sheet status Change notice Supersedes BLF6G10L-260PRN_LS-260PRN v.2 • The format of this document has been redesigned to comply with the new identity guidelines of Ampleon. • Legal texts have been adapted to the new company name where appropriate. BLF6G10L-260PRN_LS-260PRN v.2 20130712 Product data sheet - BLF6G10L-260PRN_LS-260PRN v.1 BLF6G10L-260PRN_LS-260PRN v.1 20100812 Product data sheet - - BLF6G10L-260PRN_LS-260PRN#3 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 3 — 1 September 2015 © Ampleon The Netherlands B.V. 2015. All rights reserved. 12 of 15 BLF6G10L(S)-260PRN Power LDMOS transistor 12. Legal information 12.1 Data sheet status Document status[1][2] Product status[3] Objective [short] data sheet Development This document contains data from the objective specification for product development. Preliminary [short] data sheet Qualification This document contains data from the preliminary specification. Product [short] data sheet Production This document contains the product specification. Definition [1] Please consult the most recently issued document before initiating or completing a design. [2] The term ‘short data sheet’ is explained in section “Definitions”. [3] The product status of device(s) described in this document may have changed since this document was published and may differ in case of multiple devices. The latest product status information is available on the Internet at URL http://www.ampleon.com. 12.2 Definitions Draft — The document is a draft version only. The content is still under internal review and subject to formal approval, which may result in modifications or additions. Ampleon does not give any representations or warranties as to the accuracy or completeness of information included herein and shall have no liability for the consequences of use of such information. Short data sheet — A short data sheet is an extract from a full data sheet with the same product type number(s) and title. A short data sheet is intended for quick reference only and should not be relied upon to contain detailed and full information. For detailed and full information see the relevant full data sheet, which is available on request via the local Ampleon sales office. In case of any inconsistency or conflict with the short data sheet, the full data sheet shall prevail. Product specification — The information and data provided in a Product data sheet shall define the specification of the product as agreed between Ampleon and its customer, unless Ampleon and customer have explicitly agreed otherwise in writing. In no event however, shall an agreement be valid in which the Ampleon product is deemed to offer functions and qualities beyond those described in the Product data sheet. 12.3 Disclaimers Limited warranty and liability — Information in this document is believed to be accurate and reliable. However, Ampleon does not give any representations or warranties, expressed or implied, as to the accuracy or completeness of such information and shall have no liability for the consequences of use of such information. Ampleon takes no responsibility for the content in this document if provided by an information source outside of Ampleon. In no event shall Ampleon be liable for any indirect, incidental, punitive, special or consequential damages (including - without limitation - lost profits, lost savings, business interruption, costs related to the removal or replacement of any products or rework charges) whether or not such damages are based on tort (including negligence), warranty, breach of contract or any other legal theory. Notwithstanding any damages that customer might incur for any reason whatsoever, Ampleon’ aggregate and cumulative liability towards customer for the products described herein shall be limited in accordance with the Terms and conditions of commercial sale of Ampleon. Right to make changes — Ampleon reserves the right to make changes to information published in this document, including without limitation specifications and product descriptions, at any time and without notice. This document supersedes and replaces all information supplied prior to the publication hereof. Suitability for use — Ampleon products are not designed, authorized or warranted to be suitable for use in life support, life-critical or safety-critical systems or equipment, nor in applications where failure or malfunction of an BLF6G10L-260PRN_LS-260PRN#3 Product data sheet Ampleon product can reasonably be expected to result in personal injury, death or severe property or environmental damage. Ampleon and its suppliers accept no liability for inclusion and/or use of Ampleon products in such equipment or applications and therefore such inclusion and/or use is at the customer’s own risk. Applications — Applications that are described herein for any of these products are for illustrative purposes only. Ampleon makes no representation or warranty that such applications will be suitable for the specified use without further testing or modification. Customers are responsible for the design and operation of their applications and products using Ampleon products, and Ampleon accepts no liability for any assistance with applications or customer product design. It is customer’s sole responsibility to determine whether the Ampleon product is suitable and fit for the customer’s applications and products planned, as well as for the planned application and use of customer’s third party customer(s). Customers should provide appropriate design and operating safeguards to minimize the risks associated with their applications and products. Ampleon does not accept any liability related to any default, damage, costs or problem which is based on any weakness or default in the customer’s applications or products, or the application or use by customer’s third party customer(s). Customer is responsible for doing all necessary testing for the customer’s applications and products using Ampleon products in order to avoid a default of the applications and the products or of the application or use by customer’s third party customer(s). Ampleon does not accept any liability in this respect. Limiting values — Stress above one or more limiting values (as defined in the Absolute Maximum Ratings System of IEC 60134) will cause permanent damage to the device. Limiting values are stress ratings only and (proper) operation of the device at these or any other conditions above those given in the Recommended operating conditions section (if present) or the Characteristics sections of this document is not warranted. Constant or repeated exposure to limiting values will permanently and irreversibly affect the quality and reliability of the device. Terms and conditions of commercial sale — Ampleon products are sold subject to the general terms and conditions of commercial sale, as published at http://www.ampleon.com/terms, unless otherwise agreed in a valid written individual agreement. In case an individual agreement is concluded only the terms and conditions of the respective agreement shall apply. Ampleon hereby expressly objects to applying the customer’s general terms and conditions with regard to the purchase of Ampleon products by customer. No offer to sell or license — Nothing in this document may be interpreted or construed as an offer to sell products that is open for acceptance or the grant, conveyance or implication of any license under any copyrights, patents or other industrial or intellectual property rights. Export control — This document as well as the item(s) described herein may be subject to export control regulations. Export might require a prior authorization from competent authorities. All information provided in this document is subject to legal disclaimers. Rev. 3 — 1 September 2015 © Ampleon The Netherlands B.V. 2015. All rights reserved. 13 of 15 BLF6G10L(S)-260PRN Power LDMOS transistor Non-automotive qualified products — Unless this data sheet expressly states that this specific Ampleon product is automotive qualified, the product is not suitable for automotive use. It is neither qualified nor tested in accordance with automotive testing or application requirements. Ampleon accepts no liability for inclusion and/or use of non-automotive qualified products in automotive equipment or applications. In the event that customer uses the product for design-in and use in automotive applications to automotive specifications and standards, customer (a) shall use the product without Ampleon’ warranty of the product for such automotive applications, use and specifications, and (b) whenever customer uses the product for automotive applications beyond Ampleon’ specifications such use shall be solely at customer’s own risk, and (c) customer fully indemnifies Ampleon for any liability, damages or failed product claims resulting from customer design and use of the product for automotive applications beyond Ampleon’ standard warranty and Ampleon’ product specifications. 12.4 Trademarks Notice: All referenced brands, product names, service names and trademarks are the property of their respective owners. Any reference or use of any ‘NXP’ trademark in this document or in or on the surface of Ampleon products does not result in any claim, liability or entitlement vis-à-vis the owner of this trademark. Ampleon is no longer part of the NXP group of companies and any reference to or use of the ‘NXP’ trademarks will be replaced by reference to or use of Ampleon’s own Any reference or use of any ‘NXP’ trademark in this document or in or on the surface of Ampleon products does not result in any claim, liability or entitlement vis-à-vis the owner of this trademark. Ampleon is no longer part of the NXP group of companies and any reference to or use of the ‘NXP’ trademarks will be replaced by reference to or use of Ampleon’s own trademarks. Translations — A non-English (translated) version of a document is for reference only. The English version shall prevail in case of any discrepancy between the translated and English versions. 13. Contact information For more information, please visit: http://www.ampleon.com BLF6G10L-260PRN_LS-260PRN#3 Product data sheet For sales office addresses, please visit: http://www.ampleon.com/sales All information provided in this document is subject to legal disclaimers. Rev. 3 — 1 September 2015 © Ampleon The Netherlands B.V. 2015. All rights reserved. 14 of 15 BLF6G10L(S)-260PRN Power LDMOS transistor 14. Contents 1 1.1 1.2 1.3 2 3 4 5 6 7 7.1 7.2 7.3 7.3.1 7.3.2 7.3.3 8 8.1 8.2 9 10 11 12 12.1 12.2 12.3 12.4 13 14 Product profile . . . . . . . . . . . . . . . . . . . . . . . . . . 1 General description . . . . . . . . . . . . . . . . . . . . . 1 Features and benefits . . . . . . . . . . . . . . . . . . . . 1 Applications . . . . . . . . . . . . . . . . . . . . . . . . . . . 2 Pinning information . . . . . . . . . . . . . . . . . . . . . . 2 Ordering information . . . . . . . . . . . . . . . . . . . . . 2 Limiting values. . . . . . . . . . . . . . . . . . . . . . . . . . 3 Thermal characteristics . . . . . . . . . . . . . . . . . . 3 Characteristics . . . . . . . . . . . . . . . . . . . . . . . . . . 3 Application information. . . . . . . . . . . . . . . . . . . 3 Ruggedness in class-AB operation . . . . . . . . . 4 Impedance information . . . . . . . . . . . . . . . . . . . 4 Typical powersweep . . . . . . . . . . . . . . . . . . . . . 5 CW . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 5 IS95 . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 6 2C-WCDMA (5 MHz spacing) . . . . . . . . . . . . . . 7 Test information . . . . . . . . . . . . . . . . . . . . . . . . . 8 Test circuit. . . . . . . . . . . . . . . . . . . . . . . . . . . . . 8 Bill of materials (B.O.M.) . . . . . . . . . . . . . . . . . 8 Package outline . . . . . . . . . . . . . . . . . . . . . . . . 10 Abbreviations . . . . . . . . . . . . . . . . . . . . . . . . . . 12 Revision history . . . . . . . . . . . . . . . . . . . . . . . . 12 Legal information. . . . . . . . . . . . . . . . . . . . . . . 13 Data sheet status . . . . . . . . . . . . . . . . . . . . . . 13 Definitions . . . . . . . . . . . . . . . . . . . . . . . . . . . . 13 Disclaimers . . . . . . . . . . . . . . . . . . . . . . . . . . . 13 Trademarks. . . . . . . . . . . . . . . . . . . . . . . . . . . 14 Contact information. . . . . . . . . . . . . . . . . . . . . 14 Contents . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 15 Please be aware that important notices concerning this document and the product(s) described herein, have been included in section ‘Legal information’. © Ampleon The Netherlands B.V. 2015. All rights reserved. For more information, please visit: http://www.ampleon.com For sales office addresses, please visit: http://www.ampleon.com/sales Date of release: 1 September 2015 Document identifier: BLF6G10L-260PRN_LS-260PRN#3
BLF6G10LS-260PRN,1 价格&库存
很抱歉,暂时无法提供与“BLF6G10LS-260PRN,1”相匹配的价格&库存,您可以联系我们找货
