BLF404,115
BLF404,115
    AMPLEON(安谱隆)
    SOT409A
    TRANSISTOR UHF PWR DMOS SOT409A
BLF404,115 数据手册
BLF404 UHF power MOS transistor Rev. 5 — 1 September 2015 Product data sheet IMPORTANT NOTICE Dear customer, As of December 7th, 2015 BL RF Power of NXP Semiconductors will operate as an independent company under the new trade name Ampleon, which will be used in future data sheets together with new contact details. In data sheets, where the previous Philips references is mentioned, please use the new links as shown below. http://www.philips.semiconductors.com use http://www.ampleon.com http://www.semiconductors.philips.com use http://www.ampleon.com (Internet) sales.addresses@www.semiconductors.philips.com use http://www.ampleon.com/sales The copyright notice at the bottom of each page (or elsewhere in the document, depending on the version) - © Koninklijke Philips Electronics N.V. (year). All rights reserved is replaced with: - © Ampleon B.V. (year). All rights reserved. If you have any questions related to the data sheet, please contact our nearest sales office (details via http://www.ampleon.com/sales). Thank you for your cooperation and understanding, Ampleon Philips Semiconductors Product specification UHF power MOS transistor BLF404 FEATURES PINNING - SOT409A • High power gain PIN • Easy power control 1, 8 source • Gold metallization 2, 3 gate • Good thermal stability 4, 5 source • Withstands full load mismatch 6, 7 drain DESCRIPTION • Designed for broadband operation. APPLICATIONS halfpage • Communication transmitters in the VHF/UHF range with a nominal supply voltage of 12.5 V. 8 5 d g DESCRIPTION MBB072 Silicon N-channel enhancement mode vertical D-MOS power transistor in an 8-lead SOT409A SMD package with a ceramic cap. 1 s 4 Top view MBK150 Fig.1 Simplified outline and symbol. QUICK REFERENCE DATA RF performance at Tmb ≤ 60 °C in a common source test circuit. MODE OF OPERATION CW class-AB f (MHz) VDS (V) PL (W) Gp (dB) ηD (%) 500 12.5 4 ≥10 ≥50 CAUTION This product is supplied in anti-static packing to prevent damage caused by electrostatic discharge during transport and handling. For further information, refer to Philips specs.: SNW-EQ-608, SNW-FQ-302A, and SNW-FQ-302B. 2003 Sep 26 2 Philips Semiconductors Product specification UHF power MOS transistor BLF404 LIMITING VALUES In accordance with the Absolute Maximum Rating System (IEC 60134). SYMBOL PARAMETER CONDITIONS MIN. MAX. UNIT VDS drain-source voltage − 40 V VGS gate-source voltage − ±20 V ID drain current (DC) Ptot total power dissipation Tstg Tj − 1.5 A − 8.3 W storage temperature −65 +150 °C junction temperature − 200 °C Tmb ≤ 85 °C THERMAL CHARACTERISTICS SYMBOL Rth j-mb PARAMETER CONDITIONS thermal resistance from junction to mounting base MGM522 10 handbook, halfpage ID (A) 1 (1) (2) 10−1 1 10 VDS (V) 102 (1) Current in this area may be limited by RDSon. (2) Tmb = 85 °C. Fig.2 DC SOAR. 2003 Sep 26 3 Tmb ≤ 85 °C, Ptot = 8.3 W VALUE UNIT 12.1 K/W Philips Semiconductors Product specification UHF power MOS transistor BLF404 CHARACTERISTICS Tj = 25 °C unless otherwise specified. SYMBOL PARAMETER CONDITIONS MIN. TYP. MAX. UNIT V(BR)DSS drain-source breakdown voltage VGS = 0; ID = 5 mA 40 − − V VGSth gate-source threshold voltage ID = 50 mA; VDS = 10 V 2 − 4.5 V IDSS drain-source leakage current VGS = 0; VDS = 12.5 V − − 0.5 mA IGSS gate-source leakage current VGS = ±20 V; VDS = 0 − − 1 µA IDSX on-state drain current VGS = 15 V; VDS = 10 V − 2.3 − A RDSon drain-source on-state resistance ID = 0.7 A; VGS = 15 V − 1.8 2.7 Ω gfs forward transconductance ID = 0.7 A; VDS = 10 V 200 270 − mS Cis input capacitance VGS = 0; VDS = 12.5 V; f = 1 MHz − 14 − pF Cos output capacitance VGS = 0; VDS = 12.5 V; f = 1 MHz − 17 − pF Crs feedback capacitance VGS = 0; VDS = 12.5 V; f = 1 MHz − 3 − pF VGS group indicator LIMITS (V) GROUP A LIMITS (V) GROUP MIN. MAX. 2.0 2.1 O MIN. MAX. 3.3 3.4 B 2.1 2.2 P 3.4 3.5 C 2.2 2.3 Q 3.5 3.6 D 2.3 2.4 R 3.6 3.7 E 2.4 2.5 S 3.7 3.8 F 2.5 2.6 T 3.8 3.9 G 2.6 2.7 U 3.9 4.0 H 2.7 2.8 V 4.0 4.1 J 2.8 2.9 W 4.1 4.2 K 2.9 3.0 X 4.2 4.3 L 3.0 3.1 Y 4.3 4.4 Z 4.4 4.5 M 3.1 3.2 N 3.2 3.3 2003 Sep 26 4 Philips Semiconductors Product specification UHF power MOS transistor BLF404 MRA254 25 handbook, halfpage T.C. (mV/K) ID (A) 15 2 5 1 −5 10 MRA249 3 handbook, halfpage 102 103 0 104 0 4 8 12 16 20 VGS (V) ID(mA) VDS = 10 V. VDS = 10 V; Tj = 25 °C. Fig.3 Temperature coefficient of gate-source voltage as a function of drain current; typical values. Fig.4 MRA246 MRA253 5 50 handbook, halfpage handbook, halfpage RDSon (Ω) C (pF) 4 40 3 30 2 20 1 10 0 0 Drain current as a function of gate-source voltage; typical values. 50 100 Tj (oC) 0 150 Cos Cis 0 4 8 12 16 VDS (V) ID = 0.7 A; VGS = 15 V. VGS = 0; f = 1 MHz; Tj = 25 °C. Fig.5 Drain-source on-state resistance as a function of junction temperature; typical values. 2003 Sep 26 Fig.6 5 Input and output capacitance as functions of drain-source voltage; typical values. Philips Semiconductors Product specification UHF power MOS transistor BLF404 MRA256 10 handbook, halfpage Crs (pF) 8 6 4 2 0 0 4 8 12 VDS (V) 16 VGS = 0; f = 1 MHz; Tj = 25 °C. Fig.7 Feedback capacitance as a function of drain-source voltage; typical values. APPLICATION INFORMATION RF performance at Tmb ≤ 60 °C in a common source test circuit with the device soldered on a printed-circuit board with through metallized holes. MODE OF OPERATION CW, class-AB f (MHz) VDS (V) IDQ (A) PL (W) Gp (dB) ηD (%) 500 12.5 50 4 ≥10 ≥50 typ. 11.5 typ. 55 Ruggedness in class-AB operation The BLF404 is capable of withstanding a load mismatch corresponding to VSWR = 10 : 1 through all phases under the following conditions: f = 500 MHz; VDS = 12.5 V; PL = 4 W; Tmb ≤ 60 °C. 2003 Sep 26 6 Philips Semiconductors Product specification UHF power MOS transistor BLF404 MGM520 20 Gp (dB) handbook, halfpage (%) 16 PL (W) 80 4 ηD 12 MGM521 6 100 ηD handbook, halfpage 60 Gp 40 8 2 20 4 0 0 0 2 4 0 0 6 PL (W) 200 400 PD (mW) CW, class-AB operation; f = 500 MHz; VDS = 12.5 V; IDQ = 50 mA; Tmb ≤ 60 °C. CW, class-AB operation; f = 500 MHz; VDS = 12.5 V; IDQ = 50 mA; Tmb ≤ 60 °C. Fig.8 Fig.9 Power gain and drain efficiency as functions of load power; typical values. 600 Load power as a function of drive power; typical values. +VD handbook, full pagewidth R3 R1 R4 R2 L1 C1 R6 C3 L2 C2 R5 C10 L8 input 50 Ω C5 L6 L3 L7 DUT C6 C7 C9 output 50 Ω C12 C13 MGM523 C8 Fig.10 Test circuit for class-AB operation at f = 500 MHz. 2003 Sep 26 L11 C11 L5 C4 L4 L10 L9 7 Philips Semiconductors Product specification UHF power MOS transistor BLF404 List of components; see Figs 10 and 11. COMPONENT DESCRIPTION VALUE DIMENSIONS C1 electrolytic capacitor 4.7 µF, 10 V C2, C3 multilayer ceramic chip capacitor 47 nF C4 multilayer ceramic chip capacitor; note 1 18 pF C5, C10 multilayer ceramic chip capacitor; note 1 180 pF C6, C11 multilayer ceramic chip capacitor; note 1 270 pF C7 multilayer ceramic chip capacitor; note 1 22 pF C8 multilayer ceramic chip capacitor; note 1 8.2 pF C9 multilayer ceramic chip capacitor; note 1 2.7 pF C12 multilayer ceramic chip capacitor; note 1 1.2 pF C13 multilayer ceramic chip capacitor; note 1 12 pF L1 2 turns 1 mm enamelled copper wire on a grade 4B1 Ferroxcube core ext. dia. = 4.2 mm int. dia. = 2 mm length = 6 mm L2 3 turns 1 mm enamelled copper wire int. dia. = 4.6 mm leads = 2 x 5 mm L3 bifilar coil lead dia. = 0.8 mm L4 bifilar coil lead dia. = 1 mm L5 stripline; note 2 50 Ω 8.8 × 2.38 mm L6 stripline; note 2 50 Ω 5.8 × 2.38 mm L7 stripline; note 2 50 Ω 6.8 × 2.38 mm L8 stripline; note 2 50 Ω 3.76 × 2.38 mm L9 stripline; note 2 50 Ω 5.8 × 2.38 mm L10 stripline; note 2 50 Ω 4.48 × 2.38 mm L11 stripline; note 2 50 Ω 3.13 × 2.38 mm R1, R2 SMD resistor 3.9 kΩ R3 metal film resistor 1 kΩ, 0.25 W R4 metal film resistor 22 Ω, 0.25 W R5 metal film resistor 10 kΩ, 0.25 W R6 potentiometer 10 kΩ CATALOGUE NO. Notes 1. American Technical Ceramics type 100A or capacitor of same quality. 2. The striplines are on a double copper-clad printed-circuit board, with DUROID dielectric (εr = 2.2); thickness 0.79 mm, thickness of the copper sheet 2 x 35 µm. 2003 Sep 26 8 Philips Semiconductors Product specification UHF power MOS transistor BLF404 56 handbook, full pagewidth 31 2 1 3 +VD R6 R1 R2 C1 R3 L1 R4 C2 C3 R5 L2 L3 L6 L7 C6 C4 C7 BLF404 C5 L5 C8 C10 L4 L8 L9 L10 L11 C11 C9 C12 C13 MGM524 Dimensions in mm. The components are situated on one side of the copper-clad printed-circuit board, the other side is unetched and serves as a ground plane. Earth connections from the component side to the ground plane are made by through metallization. Fig.11 Component layout for 500 MHz class-AB test circuit. 2003 Sep 26 9 Philips Semiconductors Product specification UHF power MOS transistor BLF404 MGM517 MGM518 0 8 handbook, halfpage ri (Ω) 16 handbook, halfpage xi (Ω) xi ZL (Ω) 6 −20 12 4 −40 8 RL −60 4 −80 600 0 2 XL ri 0 0 200 400 f (MHz) 0 200 400 f (MHz) 600 CW, class-AB operation; VDS = 12.5 V; ID = 50 mA; PL = 4 W; Tmb ≤ 60 °C. CW, class-AB operation; VDS = 12.5 V; ID = 50 mA; PL = 4 W; Tmb ≤ 60 °C. Fig.12 Input impedance as a function of frequency (series components); typical values. Fig.13 Load impedance as a function of frequency (series components); typical values. MGM519 30 handbook, halfpage Gp (dB) 20 10 0 0 200 400 f (MHz) 600 CW, class-AB operation; VDS = 12.5 V; IDQ = 50 mA; PL = 4 W; Tmb ≤ 60 °C. Fig.14 Power gain as a function of frequency (series components); typical values. 2003 Sep 26 10 Philips Semiconductors Product specification UHF power MOS transistor BLF404 MOUNTING RECOMMENDATIONS Both the metallized ground plate and the device leads contribute to the heat flow. It is recommended that the transistor be mounted on a grounded metallized area of the printed-circuit board. This area should be of maximum 0.8 mm thickness and include at least 12 x 0.5 diameter through metallized holes filled with solder. A thermal resistance Rth(mb-h) of 5 K/W can be achieved if heatsink compound is applied when the transistor is mounted on the printed-circuit board. handbook, full pagewidth 1.87 (2×) 0.60 (4×) 0.80 (2×) 0.50 (12×) 7.38 3.60 1.00 (8×) 1.00 (9×) 4.60 MGK390 Dimensions in mm. Fig.15 Reflow soldering footprint for SOT409A. 2003 Sep 26 11 Philips Semiconductors Product specification UHF power MOS transistor BLF404 BLF404 scattering parameters VDS = 12.5 V; ID = 50 mA; note 1. s11 f (MHz) s21 s12 s22 |s11| ∠Φ |s21| ∠Φ |s12| ∠Φ |s22| ∠Φ 5 1.00 −5.2 12.97 176.0 0.01 86.0 0.96 −6.0 10 0.99 −10.1 12.89 171.9 0.02 82.2 0.96 −12.0 20 0.98 −20.6 12.61 164.1 0.03 74.8 0.95 −23.5 30 0.96 −30.4 12.18 156.6 0.05 67.6 0.93 −34.7 40 0.93 −39.6 11.62 149.6 0.06 60.9 0.91 −45.1 50 0.89 −48.0 11.00 143.2 0.07 54.8 0.89 −54.7 60 0.86 −55.8 10.37 137.4 0.08 49.4 0.87 −63.5 70 0.83 −62.9 9.74 132.2 0.09 44.4 0.85 −71.4 80 0.80 −69.4 9.15 127.5 0.10 40.1 0.83 −78.5 90 0.78 −75.3 8.60 123.2 0.10 36.2 0.82 −84.8 100 0.75 −80.7 8.08 119.3 0.10 32.7 0.80 −90.5 125 0.71 −92.2 6.96 110.7 0.11 25.1 0.77 −102.6 150 0.68 −101.4 6.03 103.9 0.12 19.1 0.76 −111.9 175 0.66 −108.9 5.30 98.3 0.12 14.4 0.74 −119.2 200 0.64 −115.2 4.73 93.2 0.12 10.2 0.74 −125.1 250 0.63 −124.9 3.81 84.5 0.12 3.5 0.73 −134.1 300 0.64 −132.5 3.19 77.4 0.12 −1.8 0.74 −140.5 350 0.64 −138.6 2.70 71.2 0.11 −6.1 0.74 −145.3 400 0.66 −143.8 2.34 65.7 0.11 −9.7 0.75 −149.1 450 0.67 −148.4 2.03 60.5 0.10 −12.5 0.76 −152.4 500 0.69 −152.6 1.80 56.0 0.09 −15.1 0.78 −155.2 600 0.72 −160.2 1.44 47.7 0.08 −18.2 0.80 −159.9 700 0.75 −167.1 1.18 40.4 0.07 −18.6 0.82 −163.9 800 0.78 −173.6 0.99 34.4 0.05 −15.0 0.84 −167.5 900 0.81 −179.8 0.84 29.2 0.04 -6.0 0.86 −170.7 1000 0.83 174.3 0.73 25.1 0.04 9.9 0.88 −173.6 Note 1. For more extensive s-parameters see internet: http://www.semiconductors.philips.com/markets/communications/wirelesscommunications/broadcast 2003 Sep 26 12 Philips Semiconductors Product specification UHF power MOS transistor BLF404 PACKAGE OUTLINE Ceramic surface mounted package; 8 leads SOT409A D A D2 B c w2 B H1 8 5 L E2 H E A 1 4 e α w1 b Q1 0 2.5 5 mm scale DIMENSIONS (millimetre dimensions are derived from the original inch dimensions) UNIT A b c D D2 E E2 e H H1 L Q1 w1 w2 α mm 2.36 2.06 0.58 0.43 0.23 0.18 5.94 5.03 5.16 5.00 4.93 4.01 4.14 3.99 1.27 7.47 7.26 4.39 4.24 1.02 0.51 0.10 0.00 0.25 0.25 7° 0° inches 0.093 0.081 0.023 0.017 0.009 0.007 0.234 0.198 0.203 0.197 0.194 0.158 0.163 0.157 0.050 0.294 0.286 0.173 0.167 0.040 0.020 0.004 0.000 0.010 0.010 7° 0° OUTLINE VERSION REFERENCES IEC JEDEC EIAJ ISSUE DATE 98-01-27 SOT409A 2003 Sep 26 EUROPEAN PROJECTION 13 Philips Semiconductors Product specification UHF power MOS transistor BLF404 DATA SHEET STATUS LEVEL DATA SHEET STATUS(1) PRODUCT STATUS(2)(3) Development DEFINITION I Objective data II Preliminary data Qualification This data sheet contains data from the preliminary specification. Supplementary data will be published at a later date. Philips Semiconductors reserves the right to change the specification without notice, in order to improve the design and supply the best possible product. III Product data This data sheet contains data from the product specification. Philips Semiconductors reserves the right to make changes at any time in order to improve the design, manufacturing and supply. Relevant changes will be communicated via a Customer Product/Process Change Notification (CPCN). Production This data sheet contains data from the objective specification for product development. Philips Semiconductors reserves the right to change the specification in any manner without notice. Notes 1. Please consult the most recently issued data sheet before initiating or completing a design. 2. The product status of the device(s) described in this data sheet may have changed since this data sheet was published. The latest information is available on the Internet at URL http://www.semiconductors.philips.com. 3. For data sheets describing multiple type numbers, the highest-level product status determines the data sheet status. DEFINITIONS DISCLAIMERS Short-form specification  The data in a short-form specification is extracted from a full data sheet with the same type number and title. For detailed information see the relevant data sheet or data handbook. Life support applications  These products are not designed for use in life support appliances, devices, or systems where malfunction of these products can reasonably be expected to result in personal injury. Philips Semiconductors customers using or selling these products for use in such applications do so at their own risk and agree to fully indemnify Philips Semiconductors for any damages resulting from such application. Limiting values definition  Limiting values given are in accordance with the Absolute Maximum Rating System (IEC 60134). Stress above one or more of the limiting values may cause permanent damage to the device. These are stress ratings only and operation of the device at these or at any other conditions above those given in the Characteristics sections of the specification is not implied. Exposure to limiting values for extended periods may affect device reliability. Right to make changes  Philips Semiconductors reserves the right to make changes in the products including circuits, standard cells, and/or software described or contained herein in order to improve design and/or performance. When the product is in full production (status ‘Production’), relevant changes will be communicated via a Customer Product/Process Change Notification (CPCN). Philips Semiconductors assumes no responsibility or liability for the use of any of these products, conveys no licence or title under any patent, copyright, or mask work right to these products, and makes no representations or warranties that these products are free from patent, copyright, or mask work right infringement, unless otherwise specified. Application information  Applications that are described herein for any of these products are for illustrative purposes only. Philips Semiconductors make no representation or warranty that such applications will be suitable for the specified use without further testing or modification. 2003 Sep 26 14 Philips Semiconductors – a worldwide company Contact information For additional information please visit http://www.semiconductors.philips.com. Fax: +31 40 27 24825 For sales offices addresses send e-mail to: sales.addresses@www.semiconductors.philips.com. SCA75 © Koninklijke Philips Electronics N.V. 2003 All rights are reserved. Reproduction in whole or in part is prohibited without the prior written consent of the copyright owner. The information presented in this document does not form part of any quotation or contract, is believed to be accurate and reliable and may be changed without notice. No liability will be accepted by the publisher for any consequence of its use. Publication thereof does not convey nor imply any license under patent- or other industrial or intellectual property rights. Printed in The Netherlands 613524/04/pp15 Date of release: 2003 Sep 26 Document order number: 9397 750 11603
BLF404,115 价格&库存
很抱歉,暂时无法提供与“BLF404,115”相匹配的价格&库存,您可以联系我们找货
