BLF3G21-30,112
BLF3G21-30,112
    AMPLEON(安谱隆)
    SOT467C
    BASESTATION DVR 2.2GHZ SOT467C
BLF3G21-30,112 数据手册
BLF3G21-30 UHF power LDMOS transistor Rev. 2 — 1 September 2015 Product data sheet 1. Product profile 1.1 General description 30 W LDMOS power transistor for base station applications at frequencies from HF to 2200 MHz. Table 1. Typical class-AB RF performance IDq = 450 mA; Th = 25 C in a common source test circuit. f PL Gp D IMD3 PL(1dB) (MHz) (W) (dB) (%) (dB) (W) CW 2000 36 12.5 43 - 36 Two-tone 2000 30 13.5 35 26 - 0.1 to 10 13.8 - < 50 - Mode of operation Table 2. Typical class-A RF performance IDq = 1 A; Th = 25 C in a modified PHS test fixture. Mode of operation PHS D ACPR600 (dB) (%) (dBc) 16 20 75 f PL(AV) Gp (MHz) (W) 1880 to 1920 9 CAUTION This device is sensitive to ElectroStatic Discharge (ESD). Therefore care should be taken during transport and handling. 1.2 Features  Excellent back-off linearity  Typical PHS performance at a supply voltage of 26 V and IDq of 1 A:  Average output power = 9 W  Gain = 16 dB (typ)  Efficiency = 20 %  ACPR600 = 75 dBc  Easy power control  Excellent ruggedness  High power gain  Excellent thermal stability  Designed for broadband operation (HF to 2200 MHz) BLF3G21-30 UHF power LDMOS transistor  No internal matching for broadband operation  ESD protection 1.3 Applications  RF power amplifiers for GSM, PHS, EDGE, CDMA and W-CDMA base stations and multicarrier applications in the HF to 2200 MHz frequency range  Broadcast drivers 2. Pinning information Table 3. Pinning Pin Description 1 drain 2 gate 3 source Simplified outline Symbol 1 1 [1] 3 2 3 2 [1] sym112 Connected to flange 3. Ordering information Table 4. Ordering information Type number Package Name Description Version BLF3G21-30 - flanged LDMOST ceramic package; 2 mounting holes; 2 leads SOT467C 4. Limiting values Table 5. Limiting values In accordance with the Absolute Maximum Rating System (IEC 60134). BLF3G21-30#2 Product data sheet Symbol Parameter Min Max Unit VDS drain-source voltage Conditions - 65 V VGS gate-source voltage - 15 V ID drain current - 4.5 A Tstg storage temperature 65 +150 C Tj junction temperature - 200 C All information provided in this document is subject to legal disclaimers. Rev. 2 — 1 September 2015 © Ampleon The Netherlands B.V. 2015. All rights reserved. 2 of 13 BLF3G21-30 UHF power LDMOS transistor 5. Thermal characteristics Table 6. Thermal characteristics Symbol Parameter Conditions Typ Unit Rth(j-c) thermal resistance from junction to case Th = 25 C; PL(AV) = 15 W [1] Rth(j-h) thermal resistance from junction to heatsink Th = 25 C; PL(AV) = 15 W [2] [1] Thermal resistance is determined under specified RF operating conditions [2] Depending on mounting condition in application 1.6 K/W 2.1 K/W 6. Characteristics Table 7. Characteristics Tj = 25 C unless otherwise specified. Symbol Parameter Conditions Min Typ Max Unit V(BR)DSS drain-source breakdown voltage VGS = 0 V; ID = 0.7 mA 65 - - V VGS(th) gate-source threshold voltage VDS = 10 V; ID = 70 mA 2.0 - 3.0 V IDSS drain leakage current VGS = 0 V; VDS = 28 V - - 5 A IDSX drain cut-off current VGS = VGS(th) + 9 V; VDS = 10 V 9 - - A IGSS gate leakage current VGS = 15 V; VDS = 0 V - - 11 nA gfs transfer conductance VDS = 10 V; ID = 2.5 A - 3 - S RDS(on) drain-source on-state resistance VGS = VGS(th) + 9 V; ID = 2.5 A - 0.3 -  Crs feedback capacitance VGS = 0 V; VDS = 28 V; f = 1 MHz - 1.7 - pF Max Unit 7. Application information Table 8. Application information VDS = 26 V; Th = 25 C unless otherwise specified. Symbol Parameter Conditions Min Typ Mode of operation: Two-tone CW (100 kHz tone spacing); f = 2000 MHz; IDq = 450 mA Gp power gain PL(PEP) = 30 W 12.5 13.5 - dB RLin input return loss PL(PEP) = 30 W - 16 11 dB D drain efficiency PL(PEP) = 30 W 32 35.0 - % IMD3 third order intermodulation distortion PL(PEP) = 30 W - 26 23 dBc PL(PEP) < 10 W - < 50 - dBc Mode of operation: one-tone CW; f = 2000 MHz; IDq = 450 mA Gp power gain PL = PL(1dB) = 36 W - 12.5 - dB D drain efficiency PL = PL(1dB) = 36 W - 43 - % Mode of operation: PHS; f = 1900 MHz; IDq = 1 A BLF3G21-30#2 Product data sheet Gp power gain PL(AV) = 9 W - 16 - dB D drain efficiency PL(AV) = 9 W - 20 - % All information provided in this document is subject to legal disclaimers. Rev. 2 — 1 September 2015 © Ampleon The Netherlands B.V. 2015. All rights reserved. 3 of 13 BLF3G21-30 UHF power LDMOS transistor 7.1 Ruggedness in class-AB operation The BLF3G21-30 is capable of withstanding a load mismatch corresponding to VSWR = 10 : 1 through all phases under the following conditions: VDS = 26 V; f = 2200 MHz at rated load power. 001aaf790 15 001aaf791 50 ηd (%) Gp (dB) 13 40 11 30 9 20 7 10 5 10−1 1 0 10−1 102 10 1 PL (W) VDS = 26 V; IDq = 450 mA; Th = 25 C; f = 2000 MHz Fig 1. Power gain as function of CW load power; typical values 001aaf792 15 Gp (dB) 102 10 PL (W) 50 ηd (%) Gp 13 40 11 30 VDS = 26 V; IDq = 450 mA; Th = 25 C; f = 2000 MHz Fig 2. Drain efficiency as function of CW load power; typical values 001aaf793 0 IMD (dBc) −20 −40 20 9 IMD3 −60 7 10 ηD IMD5 IMD7 5 10−1 0 1 102 10 −80 10−1 VDS = 26 V; IDq = 450 mA; Th 25 C; f1 = 2000 MHz; f2 = 2000.1 MHz Product data sheet 102 10 VDS = 26 V; IDq = 450 mA; Th 25 C; f1 = 2000 MHz; f2 = 2000.1 MHz Fig 3. Two-tone power gain and drain efficiency as functions of peak envelope load power; typical values BLF3G21-30#2 1 PL(PEP) (W) PL(PEP) (W) Fig 4. Two-tone intermodulation distortion as function of peak envelope load power; typical values All information provided in this document is subject to legal disclaimers. Rev. 2 — 1 September 2015 © Ampleon The Netherlands B.V. 2015. All rights reserved. 4 of 13 BLF3G21-30 UHF power LDMOS transistor 001aaf794 −10 001aaf795 102 Coss (1) C (pF) ACPR (dB) −50 Ciss 10 (2) (3) Crss −90 (6) (7) (4) −130 −1.0 1 (5) 10−1 −0.5 0 0.5 Δf (MHz) 0 1.0 10 20 30 40 50 VDS (V) (1) 192 kHz channel bandwidth (2) ACPR300 at 192 kHz bandwidth (3) +ACPR300 at 192 kHz bandwidth (4) ACPR600 at 192 kHz bandwidth (5) +ACPR600 at 192 kHz bandwidth (6) ACPR900 at 192 kHz bandwidth (7) +ACPR900 at 192 kHz bandwidth VDS = 26 V; IDq = 1000 mA; Th  25 C; fc = 1900 MHz; PL(AV) = 9 W Fig 5. ACPR performance under PHS conditions, measured in application board Fig 6. Ciss, Crss and Coss as functions of drain supply voltage; typical values 001aaf796 5 Zi (Ω) 001aaf797 6 ZL (Ω) 4 2 RL 3 Xi 2 −2 XL 1 Ri 0 1.8 1.9 2.0 2.1 2.2 −6 1.8 f (GHz) Fig 7. Input impedance as function of frequency (series components); typical values Product data sheet 2.0 2.1 2.2 f (GHz) VDS = 26 V; IDq = 450 mA; PL = 45 W; Th  25 C BLF3G21-30#2 1.9 VDS = 26 V; IDq = 450 mA; PL = 45 W; Th  25 C Fig 8. Load impedance as function of frequency (series components); typical values All information provided in this document is subject to legal disclaimers. Rev. 2 — 1 September 2015 © Ampleon The Netherlands B.V. 2015. All rights reserved. 5 of 13 xxxx xxxxxxxxxxxxxxxxxxxxxxxxxxxxxx x xxxxxxxxxxxxxx xxxxxxxxxx xxx xxxxxx xxxxxxxxxxxxxxxxxxxxxxx xxxxxxxxxxxxxxxxxxxxxx xxxxx xxxxxx xx xxxxxxxxxxxxxxxxxxxxxxxxxxxxx xxxxxxxxxxxxxxxxxxxxxx xxxxxxxxxxx xxxxxxx xxxxxxxxxxxxxxxxxxx xxxxxxxxxxxxxxxx xxxxxxxxxxxxxx xxxxxx xx xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx xxxxxxxxxxxxxxxxxxxxxxxx xxxxxxx xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx xxxxxxxxxxx xxxxx x x 8. Test information BLF3G21-30#2 Product data sheet Rev. 2 — 1 September 2015 All information provided in this document is subject to legal disclaimers. F1 R2 Vdd R1 C11 Vgate C12 C13 C15 C14 C16 C6 C5 L12 L4 C10 50 Ω input L10 C1 C9 L14 L1 L2 L3 C2 L5 L9 L6 C4 C7 L7 L8 L13 L15 L16 50 Ω output C8 001aaf798 BLF3G21-30 UHF power LDMOS transistor 6 of 13 © Ampleon The Netherlands B.V. 2015. All rights reserved. Fig 9. Class-AB test circuit for 2 GHz L11 BLF3G21-30 UHF power LDMOS transistor 50 mm 50 mm 60 mm PH98072 IN PH98073 OUT C15 C11 F1 C6 C16 C12 + R1 R2 C5 50 Ω input C13 C14 C10 C1 C2 C9 C4 PH98072 IN C7 50 Ω output C8 PH98073 OUT 001aaf799 The components are situated on one side of the copper-clad Printed-Circuit Board (PCB) with Teflon dielectric (r = 6.15); thickness = 0.64 mm. The other side is unetched and serves as a ground plane. See Table 9 for a list of components. Fig 10. Component layout for 2 GHz class-AB test circuit BLF3G21-30#2 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 2 — 1 September 2015 © Ampleon The Netherlands B.V. 2015. All rights reserved. 7 of 13 BLF3G21-30 UHF power LDMOS transistor Table 9. List of components (see Figure 9 and Figure 10) Component Description Value C1, C9 multilayer ceramic chip capacitor C2, C4, C7, C8 Tekelec variable capacitor; type 37271 C5, C10 multilayer ceramic chip capacitor C6, C13, C14, C15 tantalum SMD capacitor [2] Dimensions Catalogue No. 11 pF 0.6 pF to 4.5 pF [1] 12 pF 4.5 F; 50 V [2] 1 nF C11 multilayer ceramic chip capacitor C12 multilayer ceramic chip capacitor 100 nF 2222 581 16641 C16 electrolytic capacitor 100 F; 63 V 2222 037 58101 F1 ferrite SMD bead 8DS3/3/8/9-4S2 L1 stripline [3] 50  13 mm  0.9 mm L2 stripline [3] 50  2 mm  0.9 mm L3 stripline [3] 34.3  15 mm  1.7 mm stripline [3] 50  37 mm  0.9 mm L4, L12 L5 stripline [3] 34.3  6 mm  1.7 mm L6 stripline [3] 23.6  13 mm  2.9 mm L7 stripline [3] 5.6  6 mm  15.8 mm stripline [3] 3.5  6 mm  26 mm L8 L9 stripline [3] 31.9  12 mm  1.9 mm L10 stripline [3] 24.9  7.4 mm  2.7 mm L11 stripline [3] 50  3 mm  0.9 mm stripline [3] 50  4.15 mm  0.9 mm L14 stripline [3] 26.3  2.5 mm  2.5 mm L15 stripline [3] 50  2.8 mm  0.9 mm L16 stripline [3] 50  14 mm  0.9 mm R1, R2 metal film resistor L13 [1] 10 ; 0.6 W 4330 030 36301 2322 156 11009 American Technical Ceramics type 100B or capacitor of same quality [2] American Technical Ceramics type 100A or capacitor of same quality [3] The striplines are on a double copper-clad Printed-Circuit Board (PCB) with Teflon dielectric (r = 6.15); thickness = 0.64 mm BLF3G21-30#2 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 2 — 1 September 2015 © Ampleon The Netherlands B.V. 2015. All rights reserved. 8 of 13 BLF3G21-30 UHF power LDMOS transistor 9. Package outline Flanged ceramic package; 2 mounting holes; 2 leads SOT467C D A F 3 D1 U1 B q c C 1 H E1 U2 E A w1 M A M B M p 2 Q w2 M C M b 0 5 10 mm scale DIMENSIONS (millimetre dimensions are derived from the original inch dimensions) UNIT A b c D D1 E E1 F H p Q q U1 U2 w1 w2 mm 4.67 3.94 5.59 5.33 0.15 0.10 9.25 9.04 9.27 9.02 5.92 5.77 5.97 5.72 1.65 1.40 18.54 17.02 3.43 3.18 2.21 1.96 14.27 20.45 20.19 5.97 5.72 0.25 0.51 inch 0.184 0.220 0.006 0.155 0.210 0.004 0.364 0.365 0.356 0.355 0.233 0.227 0.235 0.065 0.225 0.055 0.73 0.67 0.135 0.087 0.805 0.235 0.562 0.010 0.020 0.125 0.077 0.795 0.225 OUTLINE VERSION REFERENCES IEC JEDEC EIAJ EUROPEAN PROJECTION ISSUE DATE 99-12-28 12-05-02 SOT467C Fig 11. Package outline SOT467C BLF3G21-30#2 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 2 — 1 September 2015 © Ampleon The Netherlands B.V. 2015. All rights reserved. 9 of 13 BLF3G21-30 UHF power LDMOS transistor 10. Abbreviations Table 10. Abbreviations Acronym Description CDMA Code Division Multiple Access EDGE Enhanced Data rates for the GSM Evolution GSM Global System for Mobile communications HF High Frequency LDMOS Laterally Diffused Metal Oxide Semiconductor LDMOST Laterally Diffused Metal-Oxide Semiconductor Transistor PHS Personal HandyPhone System RF Radio Frequency SMD Surface-Mount Device UHF Ultra High Frequency VSWR Voltage Standing-Wave Ratio W-CDMA Wideband Code Division Multiple Access 11. Revision history Table 11. Revision history Document ID Release date Data sheet status Change notice Supersedes BLF3G21-30#2 20150901 Product data sheet - BLF3G21-30_1 Modifications: BLF3G21-30_1 BLF3G21-30#2 Product data sheet • The format of this document has been redesigned to comply with the new identity guidelines of Ampleon. • Legal texts have been adapted to the new company name where appropriate. 20070214 Product data sheet - All information provided in this document is subject to legal disclaimers. Rev. 2 — 1 September 2015 - © Ampleon The Netherlands B.V. 2015. All rights reserved. 10 of 13 BLF3G21-30 UHF power LDMOS transistor 12. Legal information 12.1 Data sheet status Document status[1][2] Product status[3] Objective [short] data sheet Development This document contains data from the objective specification for product development. Preliminary [short] data sheet Qualification This document contains data from the preliminary specification. Product [short] data sheet Production This document contains the product specification. Definition [1] Please consult the most recently issued document before initiating or completing a design. [2] The term ‘short data sheet’ is explained in section “Definitions”. [3] The product status of device(s) described in this document may have changed since this document was published and may differ in case of multiple devices. The latest product status information is available on the Internet at URL http://www.ampleon.com. 12.2 Definitions Draft — The document is a draft version only. The content is still under internal review and subject to formal approval, which may result in modifications or additions. Ampleon does not give any representations or warranties as to the accuracy or completeness of information included herein and shall have no liability for the consequences of use of such information. Short data sheet — A short data sheet is an extract from a full data sheet with the same product type number(s) and title. A short data sheet is intended for quick reference only and should not be relied upon to contain detailed and full information. For detailed and full information see the relevant full data sheet, which is available on request via the local Ampleon sales office. In case of any inconsistency or conflict with the short data sheet, the full data sheet shall prevail. Product specification — The information and data provided in a Product data sheet shall define the specification of the product as agreed between Ampleon and its customer, unless Ampleon and customer have explicitly agreed otherwise in writing. In no event however, shall an agreement be valid in which the Ampleon product is deemed to offer functions and qualities beyond those described in the Product data sheet. 12.3 Disclaimers Limited warranty and liability — Information in this document is believed to be accurate and reliable. However, Ampleon does not give any representations or warranties, expressed or implied, as to the accuracy or completeness of such information and shall have no liability for the consequences of use of such information. Ampleon takes no responsibility for the content in this document if provided by an information source outside of Ampleon. In no event shall Ampleon be liable for any indirect, incidental, punitive, special or consequential damages (including - without limitation - lost profits, lost savings, business interruption, costs related to the removal or replacement of any products or rework charges) whether or not such damages are based on tort (including negligence), warranty, breach of contract or any other legal theory. Notwithstanding any damages that customer might incur for any reason whatsoever, Ampleon’ aggregate and cumulative liability towards customer for the products described herein shall be limited in accordance with the Terms and conditions of commercial sale of Ampleon. Right to make changes — Ampleon reserves the right to make changes to information published in this document, including without limitation specifications and product descriptions, at any time and without notice. This document supersedes and replaces all information supplied prior to the publication hereof. Suitability for use — Ampleon products are not designed, authorized or warranted to be suitable for use in life support, life-critical or safety-critical systems or equipment, nor in applications where failure or malfunction of an BLF3G21-30#2 Product data sheet Ampleon product can reasonably be expected to result in personal injury, death or severe property or environmental damage. Ampleon and its suppliers accept no liability for inclusion and/or use of Ampleon products in such equipment or applications and therefore such inclusion and/or use is at the customer’s own risk. Applications — Applications that are described herein for any of these products are for illustrative purposes only. Ampleon makes no representation or warranty that such applications will be suitable for the specified use without further testing or modification. Customers are responsible for the design and operation of their applications and products using Ampleon products, and Ampleon accepts no liability for any assistance with applications or customer product design. It is customer’s sole responsibility to determine whether the Ampleon product is suitable and fit for the customer’s applications and products planned, as well as for the planned application and use of customer’s third party customer(s). Customers should provide appropriate design and operating safeguards to minimize the risks associated with their applications and products. Ampleon does not accept any liability related to any default, damage, costs or problem which is based on any weakness or default in the customer’s applications or products, or the application or use by customer’s third party customer(s). Customer is responsible for doing all necessary testing for the customer’s applications and products using Ampleon products in order to avoid a default of the applications and the products or of the application or use by customer’s third party customer(s). Ampleon does not accept any liability in this respect. Limiting values — Stress above one or more limiting values (as defined in the Absolute Maximum Ratings System of IEC 60134) will cause permanent damage to the device. Limiting values are stress ratings only and (proper) operation of the device at these or any other conditions above those given in the Recommended operating conditions section (if present) or the Characteristics sections of this document is not warranted. Constant or repeated exposure to limiting values will permanently and irreversibly affect the quality and reliability of the device. Terms and conditions of commercial sale — Ampleon products are sold subject to the general terms and conditions of commercial sale, as published at http://www.ampleon.com/terms, unless otherwise agreed in a valid written individual agreement. In case an individual agreement is concluded only the terms and conditions of the respective agreement shall apply. Ampleon hereby expressly objects to applying the customer’s general terms and conditions with regard to the purchase of Ampleon products by customer. No offer to sell or license — Nothing in this document may be interpreted or construed as an offer to sell products that is open for acceptance or the grant, conveyance or implication of any license under any copyrights, patents or other industrial or intellectual property rights. Export control — This document as well as the item(s) described herein may be subject to export control regulations. Export might require a prior authorization from competent authorities. All information provided in this document is subject to legal disclaimers. Rev. 2 — 1 September 2015 © Ampleon The Netherlands B.V. 2015. All rights reserved. 11 of 13 BLF3G21-30 UHF power LDMOS transistor Non-automotive qualified products — Unless this data sheet expressly states that this specific Ampleon product is automotive qualified, the product is not suitable for automotive use. It is neither qualified nor tested in accordance with automotive testing or application requirements. Ampleon accepts no liability for inclusion and/or use of non-automotive qualified products in automotive equipment or applications. In the event that customer uses the product for design-in and use in automotive applications to automotive specifications and standards, customer (a) shall use the product without Ampleon’ warranty of the product for such automotive applications, use and specifications, and (b) whenever customer uses the product for automotive applications beyond Ampleon’ specifications such use shall be solely at customer’s own risk, and (c) customer fully indemnifies Ampleon for any liability, damages or failed product claims resulting from customer design and use of the product for automotive applications beyond Ampleon’ standard warranty and Ampleon’ product specifications. 12.4 Trademarks Notice: All referenced brands, product names, service names and trademarks are the property of their respective owners. Any reference or use of any ‘NXP’ trademark in this document or in or on the surface of Ampleon products does not result in any claim, liability or entitlement vis-à-vis the owner of this trademark. Ampleon is no longer part of the NXP group of companies and any reference to or use of the ‘NXP’ trademarks will be replaced by reference to or use of Ampleon’s own Any reference or use of any ‘NXP’ trademark in this document or in or on the surface of Ampleon products does not result in any claim, liability or entitlement vis-à-vis the owner of this trademark. Ampleon is no longer part of the NXP group of companies and any reference to or use of the ‘NXP’ trademarks will be replaced by reference to or use of Ampleon’s own trademarks. 13. Contact information For more information, please visit: http://www.ampleon.com BLF3G21-30#2 Product data sheet For sales office addresses, please visit: http://www.ampleon.com/sales All information provided in this document is subject to legal disclaimers. Rev. 2 — 1 September 2015 © Ampleon The Netherlands B.V. 2015. All rights reserved. 12 of 13 BLF3G21-30 UHF power LDMOS transistor 14. Contents 1 1.1 1.2 1.3 2 3 4 5 6 7 7.1 8 9 10 11 12 12.1 12.2 12.3 12.4 13 14 Product profile . . . . . . . . . . . . . . . . . . . . . . . . . . 1 General description . . . . . . . . . . . . . . . . . . . . . 1 Features . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 1 Applications . . . . . . . . . . . . . . . . . . . . . . . . . . . 2 Pinning information . . . . . . . . . . . . . . . . . . . . . . 2 Ordering information . . . . . . . . . . . . . . . . . . . . . 2 Limiting values. . . . . . . . . . . . . . . . . . . . . . . . . . 2 Thermal characteristics . . . . . . . . . . . . . . . . . . 3 Characteristics . . . . . . . . . . . . . . . . . . . . . . . . . . 3 Application information. . . . . . . . . . . . . . . . . . . 3 Ruggedness in class-AB operation . . . . . . . . . 4 Test information . . . . . . . . . . . . . . . . . . . . . . . . . 6 Package outline . . . . . . . . . . . . . . . . . . . . . . . . . 9 Abbreviations . . . . . . . . . . . . . . . . . . . . . . . . . . 10 Revision history . . . . . . . . . . . . . . . . . . . . . . . . 10 Legal information. . . . . . . . . . . . . . . . . . . . . . . 11 Data sheet status . . . . . . . . . . . . . . . . . . . . . . 11 Definitions . . . . . . . . . . . . . . . . . . . . . . . . . . . . 11 Disclaimers . . . . . . . . . . . . . . . . . . . . . . . . . . . 11 Trademarks. . . . . . . . . . . . . . . . . . . . . . . . . . . 12 Contact information. . . . . . . . . . . . . . . . . . . . . 12 Contents . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 13 Please be aware that important notices concerning this document and the product(s) described herein, have been included in section ‘Legal information’. © Ampleon The Netherlands B.V. 2015. All rights reserved. For more information, please visit: http://www.ampleon.com For sales office addresses, please visit: http://www.ampleon.com/sales Date of release: 1 September 2015 Document identifier: BLF3G21-30#2
BLF3G21-30,112 价格&库存
很抱歉,暂时无法提供与“BLF3G21-30,112”相匹配的价格&库存,您可以联系我们找货
