BLF1046,112
BLF1046,112
    AMPLEON(安谱隆)
    SOT467C
    TRANSISTOR RF LDMOS SOT467C
BLF1046,112 数据手册
BLF1046 UHF power LDMOS transistor Rev. 8 — 1 September 2015 Product data sheet IMPORTANT NOTICE Dear customer, As of December 7th, 2015 BL RF Power of NXP Semiconductors will operate as an independent company under the new trade name Ampleon, which will be used in future data sheets together with new contact details. In data sheets, where the previous Philips references is mentioned, please use the new links as shown below. http://www.philips.semiconductors.com use http://www.ampleon.com http://www.semiconductors.philips.com use http://www.ampleon.com (Internet) sales.addresses@www.semiconductors.philips.com use http://www.ampleon.com/sales The copyright notice at the bottom of each page (or elsewhere in the document, depending on the version) - © Koninklijke Philips Electronics N.V. (year). All rights reserved is replaced with: - © Ampleon B.V. (year). All rights reserved. If you have any questions related to the data sheet, please contact our nearest sales office (details via http://www.ampleon.com/sales). Thank you for your cooperation and understanding, Ampleon Philips Semiconductors Product specification UHF power LDMOS transistor BLF1046 FEATURES PINNING - SOT467C • High power gain PIN DESCRIPTION • Easy power control 1 drain • Excellent ruggedness 2 gate • Source on underside eliminates DC isolators, reducing common mode inductance 3 source, connected to flange • Designed for broadband operation (HF to 1 GHz). 1 APPLICATIONS • Communication transmitter applications in the UHF frequency range. 3 2 DESCRIPTION Top view Silicon N-channel enhancement mode lateral D-MOS transistor encapsulated in a 2-lead flange package (SOT467C) with a ceramic cap. The common source is connected to the mounting flange. MBK584 Fig.1 Simplified outline. QUICK REFERENCE DATA RF performance at Th = 25 °C in the common source broadband test circuit. f (MHz) VDS (V) PL (W) Gp (dB) ηD (%) dim (dBc) CW, class-AB (2-tone) f1 = 960; f2 = 960.1 26 45 (PEP) >14 >35 ≤−26 CW, class-AB (1-tone) 960 26 45 >14 >46 − MIN. MAX. UNIT MODE OF OPERATION LIMITING VALUES In accordance with the Absolute Maximum Rating System (IEC 60134). SYMBOL PARAMETER VDS drain-source voltage − 65 V VGS gate-source voltage − ±20 V ID drain current (DC) − 4.5 A Tstg storage temperature −65 +150 °C Tj junction temperature − 200 °C CAUTION This product is supplied in anti-static packing to prevent damage caused by electrostatic discharge during transport and handling. For further information, refer to Philips specs.: SNW-EQ-608, SNW-FQ-302A and SNW-FQ-302B. 2000 Dec 20 2 Philips Semiconductors Product specification UHF power LDMOS transistor BLF1046 THERMAL CHARACTERISTICS SYMBOL Rth j-h PARAMETER CONDITIONS VALUE UNIT thermal resistance from junction to heatsink Th = 25 °C; Pdis = 97 W; note 1 1.87 K/W Note 1. Determined under specified RF operating conditions, based on maximum peak junction temperature. CHARACTERISTICS Tj = 25 °C unless otherwise specified. SYMBOL PARAMETER CONDITIONS MIN. TYP. MAX. UNIT V(BR)DSS drain-source breakdown voltage VGS = 0; ID = 0.7 mA 65 − − V VGSth gate-source threshold voltage VDS = 10 V; ID = 70 mA 4 − 5 V IDSS drain-source leakage current VGS = 0; VDS = 26 V − − 1 µA IDSX drain cut-off current VGS = VGSth + 9 V; VDS = 10 V 12.5 − − A IGSS gate leakage current VGS = ±20 V; VDS = 0 − − 125 nA gfs forward transconductance VDS = 10 V; ID = 3.5 A − 2 − S RDSon drain-source on-state resistance VGS = VGSth + 9 V; ID = 3.5 A − 300 − mΩ Cis input capacitance VGS = 0; VDS = 26 V; f = 1 MHz − 46 − pF Cos output capacitance VGS = 0; VDS = 26 V; f = 1 MHz − 37 − pF Crs feedback capacitance VGS = 0; VDS = 26 V; f = 1 MHz − 1.5 − pF APPLICATION INFORMATION RF performance in the common source class-AB broadband test circuit. Th = 25 °C; Rth j-h = 1.87 K/W, unless otherwise specified. f (MHz) VDS (V) IDQ (mA) PL (W) Gp (dB) ηD (%) dim (dBc) CW, class-AB (2-tone) f1 = 960; f2 = 960.1 26 300 45 (PEP) >14 >35 ≤−26 CW, class-AB (1-tone) 960 26 300 45 >14 >46 − MODE OF OPERATION Ruggedness in class-AB operation The BLF1046 is capable of withstanding a load mismatch corresponding to VSWR = 10 : 1 through all phases under the following conditions: VDS = 26 V; f = 960 MHz at rated load power. Tuning Procedure For high gain and efficiency: In CW mode (PD = 1 W; f = 960 MHz) tune C2 and C16 (see Figs. 13 and 14) until IRL < −15 dB, then adjust C6 and C8 for high gain until Gp > 14 dB at PL = 50 W. For linear mode: Tune for high gain and efficiency mode, then apply two tone signal (f1 = 960 MHz; f2 = 960.1 MHz) at PL = 45 W (PEP) and tune first C2 and then C6 and C8 for lowest d3 (below −28 dBc). 2000 Dec 20 3 Philips Semiconductors Product specification UHF power LDMOS transistor MLD455 20 handbook, halfpage Gp Gp (dB) ηD MLD456 20 80 80 handbook, halfpage ηD (%) PAE 15 BLF1046 ηD (%) Gp Gp (dB) 15 60 60 ηD 10 40 10 40 5 20 5 20 0 0 0 0 40 20 PL (W) 60 0 0 40 20 60 PL (W) VDS = 26 V; IDQ = 330 mA; Th ≤ 25 °C; f = 960 MHz; tuned for high efficiency; see tuning procedure. VDS = 26 V; IDQ = 330 mA; Th ≤ 25 °C; f = 960 MHz; tuned for high linearity; see tuning procedure Fig.2 Fig.3 Power gain and drain efficiency as functions of load power; typical values. MLD457 20 Gp (dB) (3) 15 d3 (dB) −20 60 (1) MLD458 handbook, halfpage ηD (%) (2) Power gain and drain efficiency as functions of load power; typical values. 0 80 handbook, halfpage 80 (1) 10 (2) −40 40 (3) ηD 5 0 0 10 20 30 20 −60 0 −80 50 40 PL (PEP) (W) (3) IDQ = 400 mA. Fig.5 Power gain and drain efficiency as functions of peak envelope power; typical values. 2000 Dec 20 10 20 30 50 40 PL (PEP) (W) VDS = 26 V; Th ≤ 25 °C; f1 = 960 MHz; f2 = 960.1 MHz; tuned for high linearity; see tuning procedure. (1) IDQ = 240 mA. (2) IDQ = 300 mA. (3) IDQ = 400 mA. VDS = 26 V; Th ≤ 25 °C; f1 = 960 MHz; f2 = 960.1 MHz; tuned for high linearity; see tuning procedure. (1) IDQ = 240 mA. (2) IDQ = 300 mA. Fig.4 0 4 Third order intermodulation distortion as a function of peak envelope load power; typical values. Philips Semiconductors Product specification UHF power LDMOS transistor BLF1046 MLD459 0 MLD460 0 handbook, halfpage handbook, halfpage d5 (dBc) d7 (dBc) −20 −20 −40 −40 (1) (3) (1) (2) −60 (3) −60 (2) −80 −80 50 40 PL (PEP) (W) VDS = 26 V; Th ≤ 25 °C; f1 = 960 MHz; f2 = 960.1 MHz; tuned for high linearity; see tuning procedure. (1) IDQ = 240 mA. (2) IDQ = 300 mA. (3) IDQ = 400 mA. VDS = 26 V; Th ≤ 25 °C; f1 = 960 MHz; f2 = 960.1 MHz; tuned for high linearity; see tuning procedure. (1) IDQ = 240 mA. (2) IDQ = 300 mA. (3) IDQ = 400 mA. Fig.6 Fig.7 0 10 20 30 Fifth order intermodulation distortion as a function of peak envelope load power; typical values. MLD461 10 0 10 20 30 50 40 PL (PEP) (W) Seventh order intermodulation distortion as a function of peak envelope load power; typical values. MLD462 20 40 handbook, halfpage handbook, halfpage EVM (%) η Gp (dB) peak (%) Gp 8 15 30 6 η 10 20 4 5 rms 2 EVM (%) EVM 0 0 4 0 8 12 16 4 8 12 20 16 PL (W) VDS = 26 V; IDQ = 300 mA; Th ≤ 25 °C; f = 960 MHz; tuned for high linearity; see tuning procedure. VDS = 26 V; IDQ = 300 mA; Th ≤ 25 °C; f = 960 MHz; tuned for high linearity; see tuning procedure. Error vector magnitude (EVM) / EDGE 8PSK as a functions of load power; typical values. 2000 Dec 20 0 0 20 PL (W) Fig.8 10 Fig.9 5 EDGE 8PSK EVM, gain and efficiency as functions of load power; typical values. Philips Semiconductors Product specification UHF power LDMOS transistor BLF1046 MLD463 0 MLD464 20 handbook, halfpage handbook, halfpage ACPR (dBc) (dB) −20 15 −40 10 200 KHz 80 ηD (%) Gp Gp 60 ηD 40 250 KHz −60 −80 0 4 8 20 5 400 KHz 12 16 0 850 20 PL (W) 900 950 f (MHz) 0 1000 VDS = 26 V; IDQ = 300 mA; Th ≤ 25 °C; f = 960 MHz; tuned for high linearity; see tuning procedure. Measured EDGE channel bandwidth 270 kHz and adjacent channels bandwidth 30 kHz. VDS = 28 V; IDQ = 300 mA; PL = 45 W (PEP); Th ≤ 25 °C; tuned for high linearity; see tuning procedure Measured in broadband test circuit; see Figs. 15 and 16. Fig.10 EDGE 8PSK adjacent channel power as a function of load power; typical values. Fig.11 Power gain and drain efficiency as functions of frequency; typical values. MLD465 0 handbook, halfpage dim (dBc) −20 d3 −40 d5 d7 −60 −80 850 900 950 f (MHz) 1000 VDS = 28 V; IDQ = 300 mA; PL = 45 W (PEP); Th ≤ 25 °C; tuned for high linearity; see tuning procedure Measured in broadband test circuit; see Figs. 15 and 16. Fig.12 Intermodulation distortion as a function of frequency; typical values. 2000 Dec 20 6 Philips Semiconductors Product specification UHF power LDMOS transistor BLF1046 MLD468 4 handbook, halfpage Zi (Ω) RL ZL (Ω) 2 2 ri 0 0 xi −2 −4 840 MLD469 4 handbook, halfpage XL −2 880 920 f (MHz) −4 840 960 880 920 f (MHz) 960 VDS = 26 V; IDQ = 300 mA; PL = 45 W; Th ≤ 25 °C; tuned for high linearity; see tuning procedure. VDS = 26 V; IDQ = 300 mA; PL = 45 W; Th ≤ 25 °C; tuned for high linearity; see tuning procedure. Fig.13 Optimal source impedance as a function of frequency (series components); typical values. Fig.14 Optimal load impedance as a function of frequency (series components); typical values. 2000 Dec 20 7 Philips Semiconductors Product specification UHF power LDMOS transistor BLF1046 R5 VDS (26 V) R1 handbook, full pagewidth C14 C15 R2 C13 F1 R3 C11 C9 C10 L2 R4 C5 C3 L6 L1 L8 L3 50 Ω input L4 C1 C7 L9 50 Ω output L7 L5 C8 C2 C16 MLD466 C6 C4 Fig.15 Class-AB broadband test circuit at f = 800 to 1000 MHz. + 26 V ground IDQ adjustment handbook, full pagewidth R1 C13 R5 R2 F1 C9 R4 input C11 C12 R3 C10 C14 C15 output L1 L2 C3 C1 C5 C7 G TR D C4 C16 C8 C2 C6 39 mm MLD467 Dimensions in mm. The components are situated on one side of the copper-clad printed-circuit board with Teflon dielectric (εr = 2.2), thickness 0.79 mm. The other side is unetched and serves as a ground plane. Fig.16 Component layout for 800 to 1000 MHz class-AB broadband test circuit. 2000 Dec 20 8 Philips Semiconductors Product specification UHF power LDMOS transistor BLF1046 List of components (see Figs 15 and 16) COMPONENT DESCRIPTION VALUE C1, C7 multilayer ceramic chip capacitor; note 1 33 pF C2, C6 Tekelec variable capacitor C3, C4 multilayer ceramic chip capacitor; note 1 13 pF DIMENSIONS CATALOGUE NO. 0.8 to 8.2 pF C5 multilayer ceramic chip capacitor; note 1 7.5 pF C8, C16 Tekelec variable capacitor C9, C11 multilayer ceramic chip capacitor; note 1 33 pF C10, C12 multilayer ceramic chip capacitor; note 1 150 pF C13, C14 multilayer ceramic chip capacitor 33 nF C15 electrolytic capacitor 47 µF; 63 V F1 Ferroxcube chip-bead 8DS3/3/8/9-4S2 L1 5 turns enamelled 0.6 mm copper wire int. dia. = 4 mm; length = 5 mm L2 2 turns enamelled 0.6 mm copper wire int. dia. = 4 mm; length = 1.6 mm L3 stripline; note 2 50 Ω 16 × 2.36 mm L4 stripline; note 2 42.5 Ω 16 × 3.1 mm L5 stripline; note 2 14.3 Ω 6 × 12 mm L6 stripline; note 2 20.2 Ω 3 × 8 mm L7 stripline; note 2 14.3 Ω 14 × 12 mm L8 stripline; note 2 40 Ω 17 × 3.4 mm L9 stripline; note 2 50 Ω 7 × 2.36 mm R1, R5 metal film resistor 10 kΩ, 0.6 W R2 variable resistor 10 kΩ R3 metal film resistor 1 kΩ, 0.6 W R4 metal film resistor 10 Ω, 0.6 W 0.5 to 4.6 pF 4330 030 36301 Notes 1. American Technical Ceramics type 100B or capacitor of same quality. 2. The striplines are on a double copper-clad printed-circuit board with Teflon dielectric (εr = 2.2); thickness 0.79 mm. 2000 Dec 20 9 Philips Semiconductors Product specification UHF power LDMOS transistor BLF1046 PACKAGE OUTLINE Flanged LDMOST ceramic package; 2 mounting holes; 2 leads SOT467C D A F 3 D1 U1 B q c C 1 E1 H U2 E A w1 M A M B M p 2 Q w2 M C M b 0 5 10 mm scale DIMENSIONS (millimetre dimensions are derived from the original inch dimensions) UNIT A b c D D1 E E1 F H p Q q U1 U2 w1 w2 mm 4.67 3.94 5.59 5.33 0.15 0.10 9.25 9.04 9.27 9.02 5.92 5.77 5.97 5.72 1.65 1.40 18.54 17.02 3.43 3.18 2.21 1.96 14.27 20.45 20.19 5.97 5.72 0.25 0.51 inch 0.184 0.220 0.006 0.155 0.210 0.004 0.364 0.365 0.356 0.355 0.233 0.227 0.235 0.065 0.225 0.055 0.73 0.67 0.135 0.087 0.805 0.235 0.562 0.010 0.020 0.125 0.077 0.795 0.225 OUTLINE VERSION REFERENCES IEC JEDEC EIAJ ISSUE DATE 99-12-06 99-12-28 SOT467C 2000 Dec 20 EUROPEAN PROJECTION 10 Philips Semiconductors Product specification UHF power LDMOS transistor BLF1046 DATA SHEET STATUS DATA SHEET STATUS PRODUCT STATUS DEFINITIONS (1) Objective specification Development This data sheet contains the design target or goal specifications for product development. Specification may change in any manner without notice. Preliminary specification Qualification This data sheet contains preliminary data, and supplementary data will be published at a later date. Philips Semiconductors reserves the right to make changes at any time without notice in order to improve design and supply the best possible product. Product specification Production This data sheet contains final specifications. Philips Semiconductors reserves the right to make changes at any time without notice in order to improve design and supply the best possible product. Note 1. Please consult the most recently issued data sheet before initiating or completing a design. DEFINITIONS DISCLAIMERS Short-form specification  The data in a short-form specification is extracted from a full data sheet with the same type number and title. For detailed information see the relevant data sheet or data handbook. Life support applications  These products are not designed for use in life support appliances, devices, or systems where malfunction of these products can reasonably be expected to result in personal injury. Philips Semiconductors customers using or selling these products for use in such applications do so at their own risk and agree to fully indemnify Philips Semiconductors for any damages resulting from such application. Limiting values definition  Limiting values given are in accordance with the Absolute Maximum Rating System (IEC 60134). Stress above one or more of the limiting values may cause permanent damage to the device. These are stress ratings only and operation of the device at these or at any other conditions above those given in the Characteristics sections of the specification is not implied. Exposure to limiting values for extended periods may affect device reliability. Right to make changes  Philips Semiconductors reserves the right to make changes, without notice, in the products, including circuits, standard cells, and/or software, described or contained herein in order to improve design and/or performance. Philips Semiconductors assumes no responsibility or liability for the use of any of these products, conveys no licence or title under any patent, copyright, or mask work right to these products, and makes no representations or warranties that these products are free from patent, copyright, or mask work right infringement, unless otherwise specified Application information  Applications that are described herein for any of these products are for illustrative purposes only. Philips Semiconductors make no representation or warranty that such applications will be suitable for the specified use without further testing or modification. 2000 Dec 20 11 Philips Semiconductors – a worldwide company Argentina: see South America Australia: 3 Figtree Drive, HOMEBUSH, NSW 2140, Tel. +61 2 9704 8141, Fax. +61 2 9704 8139 Austria: Computerstr. 6, A-1101 WIEN, P.O. Box 213, Tel. +43 1 60 101 1248, Fax. +43 1 60 101 1210 Belarus: Hotel Minsk Business Center, Bld. 3, r. 1211, Volodarski Str. 6, 220050 MINSK, Tel. +375 172 20 0733, Fax. +375 172 20 0773 Belgium: see The Netherlands Brazil: see South America Bulgaria: Philips Bulgaria Ltd., Energoproject, 15th floor, 51 James Bourchier Blvd., 1407 SOFIA, Tel. +359 2 68 9211, Fax. +359 2 68 9102 Canada: PHILIPS SEMICONDUCTORS/COMPONENTS, Tel. +1 800 234 7381, Fax. +1 800 943 0087 China/Hong Kong: 501 Hong Kong Industrial Technology Centre, 72 Tat Chee Avenue, Kowloon Tong, HONG KONG, Tel. +852 2319 7888, Fax. +852 2319 7700 Colombia: see South America Czech Republic: see Austria Denmark: Sydhavnsgade 23, 1780 COPENHAGEN V, Tel. +45 33 29 3333, Fax. +45 33 29 3905 Finland: Sinikalliontie 3, FIN-02630 ESPOO, Tel. +358 9 615 800, Fax. +358 9 6158 0920 France: 51 Rue Carnot, BP317, 92156 SURESNES Cedex, Tel. +33 1 4099 6161, Fax. +33 1 4099 6427 Germany: Hammerbrookstraße 69, D-20097 HAMBURG, Tel. +49 40 2353 60, Fax. +49 40 2353 6300 Hungary: see Austria India: Philips INDIA Ltd, Band Box Building, 2nd floor, 254-D, Dr. Annie Besant Road, Worli, MUMBAI 400 025, Tel. +91 22 493 8541, Fax. +91 22 493 0966 Indonesia: PT Philips Development Corporation, Semiconductors Division, Gedung Philips, Jl. Buncit Raya Kav.99-100, JAKARTA 12510, Tel. +62 21 794 0040 ext. 2501, Fax. +62 21 794 0080 Ireland: Newstead, Clonskeagh, DUBLIN 14, Tel. +353 1 7640 000, Fax. +353 1 7640 200 Israel: RAPAC Electronics, 7 Kehilat Saloniki St, PO Box 18053, TEL AVIV 61180, Tel. +972 3 645 0444, Fax. +972 3 649 1007 Italy: PHILIPS SEMICONDUCTORS, Via Casati, 23 - 20052 MONZA (MI), Tel. +39 039 203 6838, Fax +39 039 203 6800 Japan: Philips Bldg 13-37, Kohnan 2-chome, Minato-ku, TOKYO 108-8507, Tel. +81 3 3740 5130, Fax. +81 3 3740 5057 Korea: Philips House, 260-199 Itaewon-dong, Yongsan-ku, SEOUL, Tel. +82 2 709 1412, Fax. +82 2 709 1415 Malaysia: No. 76 Jalan Universiti, 46200 PETALING JAYA, SELANGOR, Tel. +60 3 750 5214, Fax. +60 3 757 4880 Mexico: 5900 Gateway East, Suite 200, EL PASO, TEXAS 79905, Tel. +9-5 800 234 7381, Fax +9-5 800 943 0087 Middle East: see Italy Netherlands: Postbus 90050, 5600 PB EINDHOVEN, Bldg. VB, Tel. +31 40 27 82785, Fax. +31 40 27 88399 New Zealand: 2 Wagener Place, C.P.O. Box 1041, AUCKLAND, Tel. +64 9 849 4160, Fax. +64 9 849 7811 Norway: Box 1, Manglerud 0612, OSLO, Tel. +47 22 74 8000, Fax. +47 22 74 8341 Pakistan: see Singapore Philippines: Philips Semiconductors Philippines Inc., 106 Valero St. Salcedo Village, P.O. Box 2108 MCC, MAKATI, Metro MANILA, Tel. +63 2 816 6380, Fax. +63 2 817 3474 Poland: Al.Jerozolimskie 195 B, 02-222 WARSAW, Tel. +48 22 5710 000, Fax. +48 22 5710 001 Portugal: see Spain Romania: see Italy Russia: Philips Russia, Ul. Usatcheva 35A, 119048 MOSCOW, Tel. +7 095 755 6918, Fax. +7 095 755 6919 Singapore: Lorong 1, Toa Payoh, SINGAPORE 319762, Tel. +65 350 2538, Fax. +65 251 6500 Slovakia: see Austria Slovenia: see Italy South Africa: S.A. PHILIPS Pty Ltd., 195-215 Main Road Martindale, 2092 JOHANNESBURG, P.O. Box 58088 Newville 2114, Tel. +27 11 471 5401, Fax. +27 11 471 5398 South America: Al. Vicente Pinzon, 173, 6th floor, 04547-130 SÃO PAULO, SP, Brazil, Tel. +55 11 821 2333, Fax. +55 11 821 2382 Spain: Balmes 22, 08007 BARCELONA, Tel. +34 93 301 6312, Fax. +34 93 301 4107 Sweden: Kottbygatan 7, Akalla, S-16485 STOCKHOLM, Tel. +46 8 5985 2000, Fax. +46 8 5985 2745 Switzerland: Allmendstrasse 140, CH-8027 ZÜRICH, Tel. +41 1 488 2741 Fax. +41 1 488 3263 Taiwan: Philips Semiconductors, 5F, No. 96, Chien Kuo N. Rd., Sec. 1, TAIPEI, Taiwan Tel. +886 2 2134 2451, Fax. +886 2 2134 2874 Thailand: PHILIPS ELECTRONICS (THAILAND) Ltd., 60/14 MOO 11, Bangna Trad Road KM. 3, Bagna, BANGKOK 10260, Tel. +66 2 361 7910, Fax. +66 2 398 3447 Turkey: Yukari Dudullu, Org. San. Blg., 2.Cad. Nr. 28 81260 Umraniye, ISTANBUL, Tel. +90 216 522 1500, Fax. +90 216 522 1813 Ukraine: PHILIPS UKRAINE, 4 Patrice Lumumba str., Building B, Floor 7, 252042 KIEV, Tel. +380 44 264 2776, Fax. +380 44 268 0461 United Kingdom: Philips Semiconductors Ltd., 276 Bath Road, Hayes, MIDDLESEX UB3 5BX, Tel. +44 208 730 5000, Fax. +44 208 754 8421 United States: 811 East Arques Avenue, SUNNYVALE, CA 94088-3409, Tel. +1 800 234 7381, Fax. +1 800 943 0087 Uruguay: see South America Vietnam: see Singapore Yugoslavia: PHILIPS, Trg N. Pasica 5/v, 11000 BEOGRAD, Tel. +381 11 3341 299, Fax.+381 11 3342 553 For all other countries apply to: Philips Semiconductors, Marketing Communications, Building BE-p, P.O. Box 218, 5600 MD EINDHOVEN, The Netherlands, Fax. +31 40 27 24825 Internet: http://www.semiconductors.philips.com SCA 70 © Philips Electronics N.V. 2000 All rights are reserved. Reproduction in whole or in part is prohibited without the prior written consent of the copyright owner. The information presented in this document does not form part of any quotation or contract, is believed to be accurate and reliable and may be changed without notice. No liability will be accepted by the publisher for any consequence of its use. Publication thereof does not convey nor imply any license under patent- or other industrial or intellectual property rights. Printed in The Netherlands 613524/07/pp12 Date of release: 2000 Dec 20 Document order number: 9397 750 07658
BLF1046,112 价格&库存
很抱歉,暂时无法提供与“BLF1046,112”相匹配的价格&库存,您可以联系我们找货
