BLA1011-200,112
BLA1011-200,112
    AMPLEON(安谱隆)
    SOT502A
    TRANS LDMOS NCH 75V SOT502A
BLA1011-200,112 数据手册
BLA1011-200; BLA1011S-200 Avionics LDMOS transistor Rev. 9 — 1 September 2015 Product data sheet 1. Product profile 1.1 General description 200 W LDMOS avionics power transistor for transmitter applications at frequencies from 1 030 MHz to 1 090 MHz. Table 1. Typical performance RF performance at Th = 25 C in a common source class-AB test circuit; IDq = 150 mA; typical values. Mode of operation Conditions VDS (V) PL (W) Gp (dB) D (%) tr  (ns) tf (ns) Pulsed class-AB: 1 030 MHz to 1 090 MHz tp = 50 s;  = 2 % 36 200 15 50 35 6 tp = 128 s;  = 2 % 36 250 14 50 35 6 tp = 340 s;  = 1 % 36 250 14 50 35 6 CAUTION This device is sensitive to ElectroStatic Discharge (ESD). Therefore care should be taken during transport and handling. 1.2 Features  Typical pulsed class-AB performance at a frequencies from 1 030 MHz to 1 090 MHz, a supply voltage of 36 V and an IDq of 150 mA:  Load power  200 W  Gain  13 dB  Efficiency  45 %  Rise time  50 ns  Fall time  50 ns  High power gain  Easy power control  Excellent ruggedness  Source on mounting flange eliminates DC isolators, reducing common mode inductance 1.3 Applications  Avionics transmitter applications in the 1030 MHz to 1 090 MHz frequency range. BLA1011-200; BLA1011S-200 Avionics LDMOS transistor 2. Pinning information Table 2. Pinning Pin Description Simplified outline Symbol BLA1011-200 (SOT502A) 1 drain 2 gate 3 1 1 3 [1] source 2 2 3 sym039 BLA1011S-200 (SOT502B) 1 drain 2 gate 3 1 1 3 [1] source 2 2 3 sym039 [1] Connected to flange 3. Ordering information Table 3. Ordering information Type number Package Name Description Version BLA1011-200 - flanged LDMOST ceramic package; 2 mounting holes; 2 leads SOT502A BLA1011S-200 - earless flanged LDMOST ceramic package; 2 leads SOT502B 4. Limiting values 4.1 Limiting values Table 4. Limiting values In accordance with the Absolute Maximum Rating System (IEC 60134). Symbol Parameter Conditions Min Max Unit VDS drain-source voltage - 75 V VGS gate-source voltage - 22 V Ptot total power dissipation - 700 W Tstg storage temperature 65 +150 C Tj junction temperature - 200 C Th  25 C; tp = 50 s;  = 2 % BLA1011-200; BLA1011S-200#9 All information provided in this document is subject to legal disclaimers. Product data sheet Rev. 9 — 1 September 2015 © Ampleon The Netherlands B.V. 2015. All rights reserved. 2 of 14 BLA1011-200; BLA1011S-200 Avionics LDMOS transistor 5. Thermal characteristics Table 5. Thermal characteristics Symbol Parameter Zth(j-h) thermal impedance from junction to heatsink Th = 25 C [1] Conditions [1] Typ Unit 0.15 K/W Thermal resistance is determined under RF operating conditions; tp = 50 s,  = 10 %. 6. Characteristics Table 6. Characteristics Tj = 25 C unless otherwise specified Symbol Parameter Conditions V(BR)DSS drain-source breakdown voltage VGS = 0 V; ID = 3 mA Min Typ Max Unit 75 - - V VGS(th) gate-source threshold voltage VDS = 10 V; ID = 300 mA 4 - 5 V IDSS drain leakage current VGS = 0 V; VDS = 36 V - - 1 A IDSX drain cut-off current VGS = VGS(th) + 9 V; VDS = 10 V 45 - - A IGSS gate leakage current VGS = 20 V; VDS = 0 V - - 1 A gfs transfer conductance VDS = 10 V; ID = 10 A - 9 - S RDS(on) drain-source on-state resistance VGS = 9 V; ID = 10 A - 60 - m 7. Application information Table 7. Application information RF performance in a common source pulsed class-AB circuit; (tp = 50 s;  = 2 %); f = 1030 MHz and 1090 MHz; Th = 25 C; Zth(mb-h) = 0.15 K/W; IDq = 150 mA; unless otherwise specified. Symbol Parameter Conditions Min Typ Max Unit VDS drain-source voltage - 36 - V PL load power tp = 50 s;  = 2 % - 200 Gp power gain PL = 200 W 13 - dB D drain efficiency tp = 50 s;  = 2 % 45 - % tr rise time - - 50 ns tf fall time - - 50 ns W 7.1 Ruggedness in class-AB operation The BLA1011-200 and BLA1011S-200 are capable of withstanding a load mismatch corresponding to VSWR = 5 : 1 through all phases under the following conditions: VDS = 36 V; f = 1030 MHz to 1090 MHz at rated load power. BLA1011-200; BLA1011S-200#9 All information provided in this document is subject to legal disclaimers. Product data sheet Rev. 9 — 1 September 2015 © Ampleon The Netherlands B.V. 2015. All rights reserved. 3 of 14 BLA1011-200; BLA1011S-200 Avionics LDMOS transistor mgw033 20 Gp (dB) 80 ηD (%) Gp mgw034 250 PL (W) 200 15 60 10 40 150 ηD 100 5 20 50 0 0 50 100 150 0 200 250 PL (W) 0 0 VDS = 36 V; IDq = 150 mA; f = 1060 MHz; tp = 50 s; =2% Fig 1. Power gain and drain efficiency as functions of load power; typical values mgw035 20 Gp (dB) 2 4 6 PD (W) 8 VDS = 36 V; IDq = 150 mA; f = 1060 MHz; tp = 50 s; =2% Fig 2. Load power as a function of drive power; typical values mgw036 250 IDq = 1.5 A 200 16 20 Gp (dB) PL (W) 16 150 mA Gp 12 150 8 100 4 50 PL 8 4 0 0 0 50 100 150 200 250 PL (W) Power gain as a function of load power; typical values 0 0 1 2 3 4 5 VGS (V) VDS = 36 V; f = 1060 MHz; tp = 50 s;  = 2 % Fig 3. 12 VDS = 36 V; IDq = 150 mA; Pi = 5.5 W; f = 1060 MHz; tp = 50 s;  = 2 % Fig 4. Load power and power gain as functions of gate-source voltage; typical values BLA1011-200; BLA1011S-200#9 All information provided in this document is subject to legal disclaimers. Product data sheet Rev. 9 — 1 September 2015 © Ampleon The Netherlands B.V. 2015. All rights reserved. 4 of 14 BLA1011-200; BLA1011S-200 Avionics LDMOS transistor mgw037 20 Gp (dB) Zi (W) ηD (%) Gp mgw038 5 80 xi 4 15 60 ri 3 ηD 10 40 2 5 20 1 0 1020 1040 1060 1080 0 1020 0 1100 f (MHz) VDS = 36 V; IDq = 150 mA; PL = 200 W; tp = 50 s; =2% Fig 5. 1040 1060 1080 1100 f (MHz) VDS = 36 V; IDq = 150 mA; PL = 200 W; tp = 50 s; =2% Power gain and drain efficiency a functions of frequency; typical values Fig 6. Input Impedance as a function of frequency (series components); typical values mgw039 4 ZL (W) 2 RL 0 XL −2 −4 1020 1040 1060 1080 1100 f (MHz) VDS = 36 V; IDq = 150 mA; PL = 200 W; tp = 50 s;  = 2 % Fig 7. Load impedance as a function of frequency (series components); typical values BLA1011-200; BLA1011S-200#9 All information provided in this document is subject to legal disclaimers. Product data sheet Rev. 9 — 1 September 2015 © Ampleon The Netherlands B.V. 2015. All rights reserved. 5 of 14 BLA1011-200; BLA1011S-200 Avionics LDMOS transistor 8. Test information 40 40 60 C6 + C10 C5 + R2 C9 C4 C3 R1 C11 C8 L1 C7 C1 C2 mgw032 Dimensions in mm. The components are situated on one side of the copper-clad Duroid Printed-Circuit Board (PCB) with r = 6.2 and thickness 0.64 mm. The other side is unetched and serves as a ground plane. See Table 8 for list of components. Fig 8. Component layout for 1030 MHz to 1090 MHz test circuit BLA1011-200; BLA1011S-200#9 All information provided in this document is subject to legal disclaimers. Product data sheet Rev. 9 — 1 September 2015 © Ampleon The Netherlands B.V. 2015. All rights reserved. 6 of 14 BLA1011-200; BLA1011S-200 Avionics LDMOS transistor Table 8. List of components (see Figure 8) Component Description Value C1 multilayer ceramic chip capacitor [1] C2 multilayer ceramic chip capacitor [2] 4.3 pF C3 multilayer ceramic chip capacitor [1] 11 pF multilayer ceramic chip capacitor [1] 62 pF C5 multilayer ceramic chip capacitor [1] 100 pF C6 electrolytic capacitor C8 multilayer ceramic chip capacitor [2] 20 pF multilayer ceramic chip capacitor [1] 47 pF C10 multilayer ceramic chip capacitor [3] 1.2 nF C11 electrolytic capacitor L1 -shaped enamelled 1 mm copper wire R1 metal film resistor 301  R2 SMD 0508 resistor 18  C4, C7 C9 39 pF 47 F; 20 V 47 F; 63V length = 38 mm [1] American Technical Ceramics type 100A or capacitor of same quality. [2] American Technical Ceramics type 100B or capacitor of same quality. [3] American Technical Ceramics type 700 or capacitor of same quality. BLA1011-200; BLA1011S-200#9 All information provided in this document is subject to legal disclaimers. Product data sheet Rev. 9 — 1 September 2015 Dimensions © Ampleon The Netherlands B.V. 2015. All rights reserved. 7 of 14 BLA1011-200; BLA1011S-200 Avionics LDMOS transistor 9. Package outline Flanged ceramic package; 2 mounting holes; 2 leads SOT502A D A F 3 D1 U1 B q c C 1 H L E1 p U2 E w1 M A M B M A 2 w2 M C M b 0 5 Q 10 mm scale DIMENSIONS (millimetre dimensions are derived from the original inch dimensions) UNIT A b c mm 4.72 3.43 12.83 12.57 0.15 0.08 inches 0.186 0.135 0.505 0.006 0.495 0.003 OUTLINE VERSION E E1 F H L p Q q U1 U2 w1 w2 20.02 19.96 19.61 19.66 9.50 9.30 9.53 9.25 1.14 0.89 19.94 18.92 5.33 4.32 3.38 3.12 1.70 1.45 27.94 34.16 33.91 9.91 9.65 0.25 0.51 0.788 0.786 0.772 0.774 0.374 0.375 0.366 0.364 0.067 1.100 0.057 1.345 1.335 0.390 0.380 0.01 0.02 D D1 0.045 0.785 0.035 0.745 0.210 0.133 0.170 0.123 REFERENCES IEC JEDEC JEITA ISSUE DATE 03-01-10 12-05-02 SOT502A Fig 9. EUROPEAN PROJECTION Package outline SOT502A BLA1011-200; BLA1011S-200#9 All information provided in this document is subject to legal disclaimers. Product data sheet Rev. 9 — 1 September 2015 © Ampleon The Netherlands B.V. 2015. All rights reserved. 8 of 14 BLA1011-200; BLA1011S-200 Avionics LDMOS transistor Earless flanged ceramic package; 2 leads SOT502B D A F 3 D D1 c U1 1 L H E1 U2 E 2 w2 M D M b 0 5 Q 10 mm scale DIMENSIONS (millimetre dimensions are derived from the original inch dimensions) UNIT A b c mm 4.72 3.43 12.83 12.57 0.15 0.08 inches 0.186 0.135 0.505 0.006 0.495 0.003 OUTLINE VERSION E E1 F H L Q U1 U2 w2 20.02 19.96 19.61 19.66 9.50 9.30 9.53 9.25 1.14 0.89 19.94 18.92 5.33 4.32 1.70 1.45 20.70 20.45 9.91 9.65 0.25 0.788 0.786 0.772 0.774 0.374 0.375 0.366 0.364 0.045 0.785 0.035 0.745 0.210 0.170 0.067 0.815 0.057 0.805 D D1 REFERENCES IEC JEDEC JEITA 0.390 0.010 0.380 EUROPEAN PROJECTION ISSUE DATE 07-05-09 12-05-02 SOT502B Fig 10. Package outline SOT502B BLA1011-200; BLA1011S-200#9 All information provided in this document is subject to legal disclaimers. Product data sheet Rev. 9 — 1 September 2015 © Ampleon The Netherlands B.V. 2015. All rights reserved. 9 of 14 BLA1011-200; BLA1011S-200 Avionics LDMOS transistor 10. Abbreviations Table 9. Abbreviations Acronym Description IDq quiescent drain current LDMOS Laterally Diffused Metal Oxide Semiconductor RF Radio Frequency SMD Surface Mount Device VSWR Voltage Standing Wave Ratio BLA1011-200; BLA1011S-200#9 All information provided in this document is subject to legal disclaimers. Product data sheet Rev. 9 — 1 September 2015 © Ampleon The Netherlands B.V. 2015. All rights reserved. 10 of 14 BLA1011-200; BLA1011S-200 Avionics LDMOS transistor 11. Revision history Table 10. Revision history Document ID Release date BLA1011-200_BLA1 20150901 011S-200#9 Modifications: Data sheet status Change notice Doc. number Supersedes Product data sheet - BLA1011-200_8 - • The format of this document has been redesigned to comply with the new identity guidelines of Ampleon. • Legal texts have been adapted to the new company name where appropriate. BLA1011-200_BLA1 20051026 011S-200_8 Product data sheet - - BLA1011-200_7 BLA1011-200_7 20031111 Product specification - 9397 750 12246 BLA1011-200_6 BLA1011-200_6 20020318 Product specification - 9397 750 09414 BLA1011-200_5 BLA1011-200_5 20010515 Product specification - 9397 750 08376 BLA1011-200_4 BLA1011-200_4 20010417 Product specification - 9397 750 08139 BLA1011-200_N_3 BLA1011-200_N_3 20010302 Product specification - 9397 750 08109 BLA1011-200_N_2 BLA1011-200_N_2 20001201 Product specification - 9397 750 07638 BLA1011-200_N_1 BLA1011-200_N_1 20000906 Product specification - 9397 750 07326 - BLA1011-200; BLA1011S-200#9 All information provided in this document is subject to legal disclaimers. Product data sheet Rev. 9 — 1 September 2015 © Ampleon The Netherlands B.V. 2015. All rights reserved. 11 of 14 BLA1011-200; BLA1011S-200 Avionics LDMOS transistor 12. Legal information 12.1 Data sheet status Document status[1][2] Product status[3] Objective [short] data sheet Development This document contains data from the objective specification for product development. Preliminary [short] data sheet Qualification This document contains data from the preliminary specification. Product [short] data sheet Production This document contains the product specification. Definition [1] Please consult the most recently issued document before initiating or completing a design. [2] The term ‘short data sheet’ is explained in section “Definitions”. [3] The product status of device(s) described in this document may have changed since this document was published and may differ in case of multiple devices. The latest product status information is available on the Internet at URL http://www.ampleon.com. 12.2 Definitions Draft — The document is a draft version only. The content is still under internal review and subject to formal approval, which may result in modifications or additions. Ampleon does not give any representations or warranties as to the accuracy or completeness of information included herein and shall have no liability for the consequences of use of such information. Short data sheet — A short data sheet is an extract from a full data sheet with the same product type number(s) and title. A short data sheet is intended for quick reference only and should not be relied upon to contain detailed and full information. For detailed and full information see the relevant full data sheet, which is available on request via the local Ampleon sales office. In case of any inconsistency or conflict with the short data sheet, the full data sheet shall prevail. Product specification — The information and data provided in a Product data sheet shall define the specification of the product as agreed between Ampleon and its customer, unless Ampleon and customer have explicitly agreed otherwise in writing. In no event however, shall an agreement be valid in which the Ampleon product is deemed to offer functions and qualities beyond those described in the Product data sheet. 12.3 Disclaimers Limited warranty and liability — Information in this document is believed to be accurate and reliable. However, Ampleon does not give any representations or warranties, expressed or implied, as to the accuracy or completeness of such information and shall have no liability for the consequences of use of such information. Ampleon takes no responsibility for the content in this document if provided by an information source outside of Ampleon. In no event shall Ampleon be liable for any indirect, incidental, punitive, special or consequential damages (including - without limitation - lost profits, lost savings, business interruption, costs related to the removal or replacement of any products or rework charges) whether or not such damages are based on tort (including negligence), warranty, breach of contract or any other legal theory. Notwithstanding any damages that customer might incur for any reason whatsoever, Ampleon’ aggregate and cumulative liability towards customer for the products described herein shall be limited in accordance with the Terms and conditions of commercial sale of Ampleon. Right to make changes — Ampleon reserves the right to make changes to information published in this document, including without limitation specifications and product descriptions, at any time and without notice. This document supersedes and replaces all information supplied prior to the publication hereof. Suitability for use — Ampleon products are not designed, authorized or warranted to be suitable for use in life support, life-critical or safety-critical systems or equipment, nor in applications where failure or malfunction of an Ampleon product can reasonably be expected to result in personal injury, death or severe property or environmental damage. Ampleon and its suppliers accept no liability for inclusion and/or use of Ampleon products in such equipment or applications and therefore such inclusion and/or use is at the customer’s own risk. Applications — Applications that are described herein for any of these products are for illustrative purposes only. Ampleon makes no representation or warranty that such applications will be suitable for the specified use without further testing or modification. Customers are responsible for the design and operation of their applications and products using Ampleon products, and Ampleon accepts no liability for any assistance with applications or customer product design. It is customer’s sole responsibility to determine whether the Ampleon product is suitable and fit for the customer’s applications and products planned, as well as for the planned application and use of customer’s third party customer(s). Customers should provide appropriate design and operating safeguards to minimize the risks associated with their applications and products. Ampleon does not accept any liability related to any default, damage, costs or problem which is based on any weakness or default in the customer’s applications or products, or the application or use by customer’s third party customer(s). Customer is responsible for doing all necessary testing for the customer’s applications and products using Ampleon products in order to avoid a default of the applications and the products or of the application or use by customer’s third party customer(s). Ampleon does not accept any liability in this respect. Limiting values — Stress above one or more limiting values (as defined in the Absolute Maximum Ratings System of IEC 60134) will cause permanent damage to the device. Limiting values are stress ratings only and (proper) operation of the device at these or any other conditions above those given in the Recommended operating conditions section (if present) or the Characteristics sections of this document is not warranted. Constant or repeated exposure to limiting values will permanently and irreversibly affect the quality and reliability of the device. Terms and conditions of commercial sale — Ampleon products are sold subject to the general terms and conditions of commercial sale, as published at http://www.ampleon.com/terms, unless otherwise agreed in a valid written individual agreement. In case an individual agreement is concluded only the terms and conditions of the respective agreement shall apply. Ampleon hereby expressly objects to applying the customer’s general terms and conditions with regard to the purchase of Ampleon products by customer. No offer to sell or license — Nothing in this document may be interpreted or construed as an offer to sell products that is open for acceptance or the grant, conveyance or implication of any license under any copyrights, patents or other industrial or intellectual property rights. Export control — This document as well as the item(s) described herein may be subject to export control regulations. Export might require a prior authorization from competent authorities. BLA1011-200; BLA1011S-200#9 All information provided in this document is subject to legal disclaimers. Product data sheet Rev. 9 — 1 September 2015 © Ampleon The Netherlands B.V. 2015. All rights reserved. 12 of 14 BLA1011-200; BLA1011S-200 Avionics LDMOS transistor Non-automotive qualified products — Unless this data sheet expressly states that this specific Ampleon product is automotive qualified, the product is not suitable for automotive use. It is neither qualified nor tested in accordance with automotive testing or application requirements. Ampleon accepts no liability for inclusion and/or use of non-automotive qualified products in automotive equipment or applications. In the event that customer uses the product for design-in and use in automotive applications to automotive specifications and standards, customer (a) shall use the product without Ampleon’ warranty of the product for such automotive applications, use and specifications, and (b) whenever customer uses the product for automotive applications beyond Ampleon’ specifications such use shall be solely at customer’s own risk, and (c) customer fully indemnifies Ampleon for any liability, damages or failed product claims resulting from customer design and use of the product for automotive applications beyond Ampleon’ standard warranty and Ampleon’ product specifications. 12.4 Trademarks Notice: All referenced brands, product names, service names and trademarks are the property of their respective owners. Any reference or use of any ‘NXP’ trademark in this document or in or on the surface of Ampleon products does not result in any claim, liability or entitlement vis-à-vis the owner of this trademark. Ampleon is no longer part of the NXP group of companies and any reference to or use of the ‘NXP’ trademarks will be replaced by reference to or use of Ampleon’s own Any reference or use of any ‘NXP’ trademark in this document or in or on the surface of Ampleon products does not result in any claim, liability or entitlement vis-à-vis the owner of this trademark. Ampleon is no longer part of the NXP group of companies and any reference to or use of the ‘NXP’ trademarks will be replaced by reference to or use of Ampleon’s own trademarks. Translations — A non-English (translated) version of a document is for reference only. The English version shall prevail in case of any discrepancy between the translated and English versions. 13. Contact information For more information, please visit: http://www.ampleon.com For sales office addresses, please visit: http://www.ampleon.com/sales BLA1011-200; BLA1011S-200#9 All information provided in this document is subject to legal disclaimers. Product data sheet Rev. 9 — 1 September 2015 © Ampleon The Netherlands B.V. 2015. All rights reserved. 13 of 14 BLA1011-200; BLA1011S-200 Avionics LDMOS transistor 14. Contents 1 1.1 1.2 1.3 2 3 4 5 6 7 7.1 8 9 10 11 12 13 14 15 16 14 Product profile . . . . . . . . . . . . . . . . . . . . . . . . . . 1 General description . . . . . . . . . . . . . . . . . . . . . 1 Features . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 1 Applications . . . . . . . . . . . . . . . . . . . . . . . . . . . 1 Pinning information . . . . . . . . . . . . . . . . . . . . . . 2 Ordering information . . . . . . . . . . . . . . . . . . . . . 2 Limiting values. . . . . . . . . . . . . . . . . . . . . . . . . . 2 Thermal characteristics . . . . . . . . . . . . . . . . . . 3 Characteristics . . . . . . . . . . . . . . . . . . . . . . . . . . 3 Application information. . . . . . . . . . . . . . . . . . . 3 Ruggedness in class-AB operation . . . . . . . . . 3 Test information . . . . . . . . . . . . . . . . . . . . . . . . . 6 Package outline . . . . . . . . . . . . . . . . . . . . . . . . . 8 Abbreviations . . . . . . . . . . . . . . . . . . . . . . . . . . 10 Revision history . . . . . . . . . . . . . . . . . . . . . . . . 11 Data sheet status . . . . . . . . . . . . . . . . . . . . . . . 12 Definitions . . . . . . . . . . . . . . . . . . . . . . . . . . . . 12 Disclaimers. . . . . . . . . . . . . . . . . . . . . . . . . . . . 12 Trademarks. . . . . . . . . . . . . . . . . . . . . . . . . . . . 13 Contact information . . . . . . . . . . . . . . . . . . . . 13 Contents . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 14 Please be aware that important notices concerning this document and the product(s) described herein, have been included in section ‘Legal information’. © Ampleon The Netherlands B.V. 2015. All rights reserved. For more information, please visit: http://www.ampleon.com For sales office addresses, please visit: http://www.ampleon.com/sales Date of release: 1 September 2015 Document identifier: BLA1011-200; BLA1011S-200#9
BLA1011-200,112 价格&库存
很抱歉,暂时无法提供与“BLA1011-200,112”相匹配的价格&库存,您可以联系我们找货
