BLF246B,112
BLF246B,112
    AMPLEON(安谱隆)
    SOT-161A
    TRANSISTOR RF DMOS SOT161A
BLF246B,112 数据手册
BLF246B VHF push-pull power MOS transistor Rev. 8 — 1 September 2015 Product data sheet IMPORTANT NOTICE Dear customer, As of December 7th, 2015 BL RF Power of NXP Semiconductors will operate as an independent company under the new trade name Ampleon, which will be used in future data sheets together with new contact details. In data sheets, where the previous Philips references is mentioned, please use the new links as shown below. http://www.philips.semiconductors.com use http://www.ampleon.com http://www.semiconductors.philips.com use http://www.ampleon.com (Internet) sales.addresses@www.semiconductors.philips.com use http://www.ampleon.com/sales The copyright notice at the bottom of each page (or elsewhere in the document, depending on the version) - © Koninklijke Philips Electronics N.V. (year). All rights reserved is replaced with: - © Ampleon B.V. (year). All rights reserved. If you have any questions related to the data sheet, please contact our nearest sales office (details via http://www.ampleon.com/sales). Thank you for your cooperation and understanding, Ampleon Philips Semiconductors Product specification VHF push-pull power MOS transistor FEATURES BLF246B PIN CONFIGURATION • High power gain • Easy power control • Good thermal stability • Gold metallization ensures excellent reliability. 2 handbook, halfpage 4 6 8 d2 g2 APPLICATIONS s g1 d1 Large signal applications in the VHF frequency range. 1 3 5 7 Top view MBB157 MBC826 DESCRIPTION Dual silicon N-channel enhancement mode vertical D-MOS push-pull transistor encapsulated in an 8-lead SOT161A balanced flange package with a ceramic cap. All leads are isolated from the flange. PINNING - SOT161A PIN Fig.1 Simplified outline and symbol. CAUTION This product is supplied in anti-static packing to prevent damage caused by electrostatic discharge during transport and handling. For further information, refer to Philips specs.: SNW-EQ-608, SNW-FQ-302A, and SNW-FQ-302B. DESCRIPTION 1 source 2 source 3 drain 1 4 gate 1 5 drain 2 6 gate 2 7 source 8 source WARNING Product and environmental safety - toxic materials This product contains beryllium oxide. The product is entirely safe provided that the BeO disc is not damaged. All persons who handle, use or dispose of this product should be aware of its nature and of the necessary safety precautions. After use, dispose of as chemical or special waste according to the regulations applying at the location of the user. It must never be thrown out with the general or domestic waste. QUICK REFERENCE DATA RF performance at Th = 25 °C in a push-pull common source test circuit. MODE OF OPERATION CW, class-AB 2003 Aug 04 f (MHz) VDS (V) PL (W) Gp (dB) ηD (%) 175 28 60 >14 >55 2 Philips Semiconductors Product specification VHF push-pull power MOS transistor BLF246B LIMITING VALUES In accordance with the Absolute Maximum Rating System (IEC 60134). SYMBOL PARAMETER CONDITIONS MIN. MAX. UNIT Per transistor section unless otherwise specified VDS drain-source voltage − 65 V VGS gate-source voltage − ±20 V ID drain current (DC) − 8 A Ptot total power dissipation Tmb ≤ 25 °C total device; both sections equally loaded − 130 W Tstg storage temperature −65 +150 °C Tj junction temperature − 200 °C THERMAL CHARACTERISTICS SYMBOL PARAMETER CONDITIONS VALUE UNIT Rth j-mb thermal resistance from junction to mounting base total device; both sections equally loaded 1.35 K/W Rth mb-h thermal resistance from mounting base total device; both sections equally to heatsink loaded 0.25 K/W MRA932 MGR738 handbook, 50 halfpage 160 handbook, halfpage ID (A) Ptot (W) 10 120 (2) (1) (2) 80 (1) 1 40 10−1 1 10 VDS (V) 0 102 0 40 80 160 Th (°C) (1) Current in this area may be limited by RDSon. (2) Tmb = 25 °C. (1) Continuous operation. (2) Short-time operation during mismatch. Total device; both sections equally loaded. Total device; both sections equally loaded. Fig.2 DC SOAR. 2003 Aug 04 120 Fig.3 Power derating curves. 3 Philips Semiconductors Product specification VHF push-pull power MOS transistor BLF246B CHARACTERISTICS Tj = 25 °C unless otherwise specified. SYMBOL PARAMETER CONDITIONS MIN. TYP. MAX. UNIT Per transistor section V(BR)DSS drain-source breakdown voltage VGS = 0; ID = 10 mA − 65 − V IDSS drain-source leakage current VGS = 0; VDS = 28 V − − 2 mA IGSS gate-source leakage current VGS = ±20 V; VDS = 0 − − 1 µA VGSth gate-source threshold voltage ID = 10 mA; VDS = 10 V 2 − 4.5 V gfs forward transconductance ID = 1.5 A; VDS = 10 V 1.2 1.8 − S RDSon drain-source on-state resistance ID = 1.5 A; VGS = 10 V − 0.4 0.75 Ω IDSX on-state drain current VGS = 10 V; VDS = 10 V − 10 − A Cis input capacitance VGS = 0; VDS = 28 V; f = 1 MHz − 125 − pF Cos output capacitance VGS = 0; VDS = 28 V; f = 1 MHz − 75 − pF Crs feedback capacitance VGS = 0; VDS = 28 V; f = 1 MHz − 11 − pF VGS group indicator LIMITS (V) GROUP LIMITS (V) GROUP MIN. MAX. A 2.0 2.1 MIN. MAX. O 3.3 3.4 B 2.1 2.2 P 3.4 3.5 C 2.2 2.3 Q 3.5 3.6 D 2.3 2.4 R 3.6 3.7 E 2.4 2.5 S 3.7 3.8 F 2.5 2.6 T 3.8 3.9 G 2.6 2.7 U 3.9 4.0 H 2.7 2.8 V 4.0 4.1 J 2.8 2.9 W 4.1 4.2 K 2.9 3.0 X 4.2 4.3 L 3.0 3.1 Y 4.3 4.4 M 3.1 3.2 Z 4.4 4.5 N 3.2 3.3 2003 Aug 04 4 Philips Semiconductors Product specification VHF push-pull power MOS transistor BLF246B MGR739 6 MGR740 12 handbook, halfpage handbook, halfpage T.C. (mV/K) 4 Tj = 25 °C ID (A) 2 125 °C 8 0 −2 4 −4 −6 10 102 103 ID (mA) 0 104 0 10 20 VGS (V) VDS = 10 V. VDS = 10 V. Fig.4 Temperature coefficient of gate-source voltage as a function of drain current; typical values per section. Fig.5 MGR741 Drain current as a function of gate-source voltage; typical values per section. MGR742 240 0.8 handbook, halfpage handbook, halfpage RDSon C (pF) (Ω) 0.6 180 0.4 120 0.2 60 Cis Cos 0 0 0 40 80 120 160 0 10 Tj (°C) VGS = 10 V; ID = 1.5 A. VGS = 0; f = 1 MHz. Fig.6 Fig.7 Drain-source on-state resistance as a function of junction temperature; typical values per section. 2003 Aug 04 5 20 30 VDS (V) 40 Input and output capacitance as functions of drain-source voltage; typical values per section. Philips Semiconductors Product specification VHF push-pull power MOS transistor BLF246B MGR743 24 handbook, halfpage Crs (pF) 18 12 6 0 0 10 20 30 VDS (V) 40 VGS = 0; f = 1 MHz. Fig.8 Feedback capacitance as a function of drain-source voltage; typical values per section. APPLICATION INFORMATION RF performance in CW operation in a push-pull, common source, class-B circuit. Th = 25 °C; Rth mb-h = 0.25 K/W; unless otherwise specified. MODE OF OPERATION CW, class-B f (MHz) VDS (V) IDQ (mA) PL (W) Gp (dB) ηD (%) 175 28 2 × 50 60 >14 >55 typ. 19 typ. 65 Ruggedness in class-B operation The BLF246B is capable of withstanding a load mismatch corresponding to VSWR = 50 : 1 through all phases under the following conditions: VDS = 28 V; f = 175 MHz at rated output power. 2003 Aug 04 6 Philips Semiconductors Product specification VHF push-pull power MOS transistor BLF246B MGR745 MGR744 25 100 handbook, halfpage Gp (dB) 100 handbook, halfpage ηD (%) Gp PL (W) 20 80 80 15 60 60 10 40 40 5 20 20 0 0 ηD 0 0 20 40 60 PL (W) 80 0 0.5 1.0 1.5 2.0 2.5 PIN (W) Class-B operation; VDS = 28 V; IDQ = 2 × 50 mA; ZL = 4.6 + j5 Ω; f = 175 MHz. Class-B operation; VDS = 28 V; IDQ = 2 × 50 mA; ZL = 4.6 + j5 Ω; f = 175 MHz. Fig.9 Fig.10 Load power as a function of input power; typical values per section. Power gain and efficiency as a function of load power; typical values per section. 2003 Aug 04 7 Philips Semiconductors Product specification VHF push-pull power MOS transistor BLF246B +VD handbook, full pagewidth R5 R3 C11 +VG C12 C7 C13 C8 L12 C14 R7 C15 R1 L13 L1 50 Ω input C1 L4 L6 L8 L10 L16 L18 L20 C25 L23 L2 C3 C4 C5 C6 C21 C22 C23 C2 L3 L5 L7 L9 L11 L17 L19 L14 C16 R2 C17 C10 R8 L15 C18 C9 C19 C20 +VG R4 R6 +VD MGR749 f = 175 MHz. Fig.11 Test circuit for class-B operation. 2003 Aug 04 L22 8 L21 C24 C26 L24 50 Ω output Philips Semiconductors Product specification VHF push-pull power MOS transistor BLF246B List of components class-B test circuit (see Figs 11 and 12) COMPONENT DESCRIPTION VALUE DIMENSIONS CATALOGUE No. C1, C2, C25, C26 multilayer ceramic chip capacitor; note 1 91 pF C3 film dielectric trimmer 4 to 40 pF C4 multilayer ceramic chip capacitor; note 1 180 pF C5, C22, C24 film dielectric trimmer C6 multilayer ceramic chip capacitor; note 2 100 pF C7, C9, C12, C14, C17, C19 multilayer ceramic chip capacitor; note 1 100 nF C8, C10 multilayer ceramic chip capacitor; note 1 680 pF C11, C20 multilayer ceramic chip capacitor 10 nF C13, C18 electrolytic capacitor 10 µF, 63 V C15, C16, C21 multilayer ceramic chip capacitor; note 1 82 pF C23 multilayer ceramic chip capacitor; note 1 33 pF 2222 809 08002 5 to 60 pF 2222 809 08003 2222 852 47104 2222 852 47103 L1, L3, L22, L24 stripline; note 3 55 Ω 111 × 2.5 mm L2, L23 semi-rigid cable 50 Ω length 111 mm ext. dia 2.2 mm L4, L5 stripline; note 3 50 Ω 38 × 2.8 mm L6, L7 stripline; note 3 50 Ω 9 × 2.8 mm L8, L9 stripline; note 3 50 Ω 8 × 2.8 mm L10, L11 stripline; note 3 50 Ω 11 × 2.8 mm L12, L15 grade 3B Ferroxcube wideband HF choke L13, L14 4 turns enamelled 1 mm copper wire 50 nH length 6.5 mm int. dia. 4 mm leads 2 × 5 mm L16, L17 stripline; note 3 50 Ω 16 × 2.8 mm L18, L19 stripline; note 3 50 Ω 25 × 2.8 mm L20, L21 stripline; note 3 50 Ω 3 × 2.8 mm R1, R2 metal film resistor 0.4 W, 10 Ω R3, R4 10 turns potentiometer 50 kΩ R5, R6 metal film resistor 0.4 W, 205 kΩ R7, R8 metal film resistor 1 W, 21.5 Ω 4312 020 36642 Notes 1. American Technical Ceramics (ATC) capacitor, type 100B or other capacitor of the same quality. 2. American Technical Ceramics (ATC) capacitor, type 100A or other capacitor of the same quality. 3. The striplines are on a double copper-clad printed-circuit board with epoxy glass dielectric (εr = 4.5); thickness 1⁄ inch. The other side of the board is fully metallized and used as a ground plane. The ground planes on each side 16 of the board are connected together by means of copper straps and hollow rivets. 2003 Aug 04 9 Philips Semiconductors Product specification VHF push-pull power MOS transistor BLF246B 200 handbook, full pagewidth rivet rivet strap strap strap strap rivet rivet 110 strap strap strap strap rivet rivet +VG +VD L22 L12 C11 C13 C14 C12 R7 L1 + L2 C15 C7 C8 R1 C1 C3 C2 L8 L9 L13 C21 L16 L17 C22 L14 L6 L7 L4 C4 L5 C5 R2 C10 C9 C6 L10 L11 L20 C23 C25 C26 L18 L19 C24 L21 C16 R3 C17 L15 C19 C20 C18 L23 + L24 L3 +VG +VD MGR750 Dimensions in mm. The circuit and components are situated on one side of the PTFE fibre-glass board, the other side being fully metallized, to serve as a ground plane. Earth connections are made by means of copper straps and hollow rivets for a direct contact between upper and lower sheets. Fig.12 Component layout for 175 MHz class-B test circuit. 2003 Aug 04 10 Philips Semiconductors Product specification VHF push-pull power MOS transistor BLF246B MGR746 MGR747 10 15 handbook, halfpage handbook, halfpage Zi (Ω) ZL (Ω) ri 5 RL 10 XL 0 5 xi −5 0 0 100 200 300 400 0 100 200 300 f (MHz) 400 f (MHz) Class-B operation; VDS = 28 V; IDQ = 2 × 50 mA; RGS = 10 Ω; PL = 60 W (total device). Class-B operation; VDS = 28 V; IDQ = 2 × 50 mA; RGS = 10 Ω; PL = 60 W (total device). Fig.13 Input impedance as a function of frequency (series components); typical values per section. Fig.14 Load impedance as a function of frequency (series components); typical values per section. MGR748 25 handbook, halfpage Gp (dB) 20 15 handbook, halfpage 10 5 Zi ZL MBA379 0 0 100 200 300 400 f (MHz) Class-B operation; VDS = 28 V; IDQ = 2 × 50 mA; RGS = 10 Ω; PL = 60 W (total device). Fig.16 Power gain as a function of frequency; typical values per section. Fig.15 Definition of MOS impedance. 2003 Aug 04 11 Philips Semiconductors Product specification VHF push-pull power MOS transistor BLF246B PACKAGE OUTLINE Flanged ceramic package; 2 mounting holes; 8 leads SOT161A D A F D1 U1 B q C H1 w2 M C M c b 2 H 4 6 8 E1 U2 1 A 3 5 7 E w1 M A M B M p Q w3 M b1 e1 e 0 5 10 mm scale DIMENSIONS (millimetre dimensions are derived from the original inch dimensions) UNIT A b b1 mm 7.27 6.47 2.93 2.66 2.04 1.77 inches c D D1 E E1 e 0.18 10.22 10.21 10.21 10.21 3.80 0.10 10.00 9.94 10.00 9.94 F e1 3.50 H H1 p Q q U1 U2 w1 2.70 16.81 12.83 3.33 4.32 24.97 10.34 18.42 0.25 2.08 16.21 12.57 3.07 4.06 24.71 10.08 w2 w3 0.51 0.25 0.286 0.115 0.080 0.007 0.402 0.402 0.402 0.402 0.106 0.662 0.505 0.131 0.170 0.983 0.407 0.150 0.138 0.725 0.010 0.020 0.010 0.255 0.105 0.070 0.004 0.394 0.391 0.394 0.391 0.082 0.638 0.495 0.121 0.160 0.973 0.397 OUTLINE VERSION REFERENCES IEC JEDEC EIAJ ISSUE DATE 99-03-29 99-10-04 SOT161A 2003 Aug 04 EUROPEAN PROJECTION 12 Philips Semiconductors Product specification VHF push-pull power MOS transistor BLF246B DATA SHEET STATUS LEVEL DATA SHEET STATUS(1) PRODUCT STATUS(2)(3) Development DEFINITION I Objective data II Preliminary data Qualification This data sheet contains data from the preliminary specification. Supplementary data will be published at a later date. Philips Semiconductors reserves the right to change the specification without notice, in order to improve the design and supply the best possible product. III Product data This data sheet contains data from the product specification. Philips Semiconductors reserves the right to make changes at any time in order to improve the design, manufacturing and supply. Relevant changes will be communicated via a Customer Product/Process Change Notification (CPCN). Production This data sheet contains data from the objective specification for product development. Philips Semiconductors reserves the right to change the specification in any manner without notice. Notes 1. Please consult the most recently issued data sheet before initiating or completing a design. 2. The product status of the device(s) described in this data sheet may have changed since this data sheet was published. The latest information is available on the Internet at URL http://www.semiconductors.philips.com. 3. For data sheets describing multiple type numbers, the highest-level product status determines the data sheet status. DEFINITIONS DISCLAIMERS Short-form specification  The data in a short-form specification is extracted from a full data sheet with the same type number and title. For detailed information see the relevant data sheet or data handbook. Life support applications  These products are not designed for use in life support appliances, devices, or systems where malfunction of these products can reasonably be expected to result in personal injury. Philips Semiconductors customers using or selling these products for use in such applications do so at their own risk and agree to fully indemnify Philips Semiconductors for any damages resulting from such application. Limiting values definition  Limiting values given are in accordance with the Absolute Maximum Rating System (IEC 60134). Stress above one or more of the limiting values may cause permanent damage to the device. These are stress ratings only and operation of the device at these or at any other conditions above those given in the Characteristics sections of the specification is not implied. Exposure to limiting values for extended periods may affect device reliability. Right to make changes  Philips Semiconductors reserves the right to make changes in the products including circuits, standard cells, and/or software described or contained herein in order to improve design and/or performance. When the product is in full production (status ‘Production’), relevant changes will be communicated via a Customer Product/Process Change Notification (CPCN). Philips Semiconductors assumes no responsibility or liability for the use of any of these products, conveys no licence or title under any patent, copyright, or mask work right to these products, and makes no representations or warranties that these products are free from patent, copyright, or mask work right infringement, unless otherwise specified. Application information  Applications that are described herein for any of these products are for illustrative purposes only. Philips Semiconductors make no representation or warranty that such applications will be suitable for the specified use without further testing or modification. 2003 Aug 04 13 Philips Semiconductors – a worldwide company Contact information For additional information please visit http://www.semiconductors.philips.com. Fax: +31 40 27 24825 For sales offices addresses send e-mail to: sales.addresses@www.semiconductors.philips.com. SCA75 © Koninklijke Philips Electronics N.V. 2003 All rights are reserved. Reproduction in whole or in part is prohibited without the prior written consent of the copyright owner. The information presented in this document does not form part of any quotation or contract, is believed to be accurate and reliable and may be changed without notice. No liability will be accepted by the publisher for any consequence of its use. Publication thereof does not convey nor imply any license under patent- or other industrial or intellectual property rights. Printed in The Netherlands 613524/07/pp14 Date of release: 2003 Aug 04 Document order number: 9397 750 11598
BLF246B,112 价格&库存
很抱歉,暂时无法提供与“BLF246B,112”相匹配的价格&库存,您可以联系我们找货
