BLF861A,112
BLF861A,112
    AMPLEON(安谱隆)
    SOT540A
    TRANSISTOR RF LDMOS SOT540A
BLF861A,112 数据手册
BLF861A UHF power LDMOS transistor Rev. 3 — 1 September 2015 Product data sheet IMPORTANT NOTICE Dear customer, As of December 7th, 2015 BL RF Power of NXP Semiconductors will operate as an independent company under the new trade name Ampleon, which will be used in future data sheets together with new contact details. In data sheets, where the previous Philips references is mentioned, please use the new links as shown below. http://www.philips.semiconductors.com use http://www.ampleon.com http://www.semiconductors.philips.com use http://www.ampleon.com (Internet) sales.addresses@www.semiconductors.philips.com use http://www.ampleon.com/sales The copyright notice at the bottom of each page (or elsewhere in the document, depending on the version) - © Koninklijke Philips Electronics N.V. (year). All rights reserved is replaced with: - © Ampleon B.V. (year). All rights reserved. If you have any questions related to the data sheet, please contact our nearest sales office (details via http://www.ampleon.com/sales). Thank you for your cooperation and understanding, Ampleon Philips Semiconductors Product specification UHF power LDMOS transistor BLF861A FEATURES PINNING - SOT540A • High power gain PIN DESCRIPTION • Easy power control 1 drain 1 • Excellent ruggedness 2 drain 2 • Designed to withstand abrupt load mismatch errors 3 gate 1 • Source on underside eliminates DC isolators; reducing common mode inductance 4 gate 2 5 source connected to flange • Designed for broadband operation (UHF band) • Internal input and output matching for high gain and optimum broadband operation. 1 2 APPLICATIONS • Communication transmitter applications in the UHF frequency range. 5 3 4 Top view DESCRIPTION Silicon N-channel enhancement mode lateral D-MOS push-pull transistor in a SOT540A package with ceramic cap. The common source is connected to the mounting flange. MBK777 Fig.1 Simplified outline. QUICK REFERENCE DATA RF performance at Th = 25 °C in a common source 860 MHz test circuit. f (MHz) VDS (V) PL (W) Gp (dB) ηD (%) ∆Gp (dB) 860 32 150 >13.5 typ. 14.5 >50 ≤1 860 (ch 69) 32 >150 typ. 170 (peak sync) >14 >40 note 1 MIN. MAX. UNIT MODE OF OPERATION CW, class-AB PAL BG (TV); class-AB Note 1. Sync compression: input sync ≥ 33%; output sync 27%. LIMITING VALUES In accordance with the Absolute Maximum Rating System (IEC 60134). SYMBOL PARAMETER CONDITIONS VDS drain-source voltage − 65 V VGS gate-source voltage − ±15 V ID drain current (DC) − 18 A Ptot total power dissipation − 318 W Tstg storage temperature −65 +150 °C Tj junction temperature − 200 °C 2001 Feb 09 Tmb ≤ 25 °C 2 Philips Semiconductors Product specification UHF power LDMOS transistor BLF861A THERMAL CHARACTERISTICS SYMBOL PARAMETER CONDITIONS Rth j-mb thermal resistance from junction to mounting base Rth mb-h thermal resistance from mounting base to heatsink Tmb = 25 °C; Ptot = 318 W VALUE UNIT 0.55 K/W 0.2 K/W CHARACTERISTICS Tj = 25 °C; per section; unless otherwise specified. SYMBOL PARAMETER CONDITIONS MIN. TYP. MAX. UNIT V(BR)DSS drain-source breakdown voltage VGS = 0; ID = 1.5 mA 65 − − V VGSth gate-source threshold voltage VDS = 10 V; ID = 150 mA 4 − 5.5 V IDSS drain-source leakage current VGS = 0; VDS = 32 V − − 2.2 µA IDSX drain cut-off current VGS = VGSth + 9 V; VDS = 10 V 18 − − A IGSS gate leakage current VGS = ±15 V; VDS = 0 − − 25 nA gfs forward transconductance VDS = 10 V; ID = 4 A − 4 − S RDSon drain-source on-state resistance VGS = VGSth + 9 V; ID = 4 A − 160 − mΩ Ciss input capacitance VGS = 0; VDS = 32 V; f = 1 MHz − 82 − pF Coss output capacitance VGS = 0; VDS = 32 V; f = 1 MHz (1) − 40 − pF 6 − pF Crss feedback capacitance VGS = 0; VDS = 32 V; f = 1 MHz Note 1. Capacitance values without internal matching. MLD510 100 Coss handbook, halfpage (pF) 80 60 40 20 0 10 0 20 30 40 50 VDS (V) VGS = 0; f = 1 MHz; Tj = 25 °C. Fig.2 Output capacitance as a function of drain-source voltage; typical values per section. 2001 Feb 09 3 (1) (1) − Philips Semiconductors Product specification UHF power LDMOS transistor BLF861A APPLICATION INFORMATION RF performance in a common source 860 MHz test circuit. Th = 25 °C; Rth mb-h = 0.15 K/W; unless otherwise specified. f (MHz) VDS (V) IDQ (A) PL (W) Gp (dB) ηD (%) dIm (dBc) ∆Gp (dB) 860 32 1 150 >13.5 typ. 14.5 >50 − ≤1 f1 = 860 f1 = 860.1 32 1 150 (PEP) >14 >40 ≤−25 − 860 (ch 69) 32 1 > 150 typ. 170 (peak sync) >14 >40 − note 1 MODE OF OPERATION CW; class-AB 2-tone; class-AB PAL BG (TV); class-AB Note 1. Sync compression: input sync ≥ 33%; output sync 27% measured in an 860 MHz test circuit. Ruggedness in class-AB operation The BLF861A is capable of withstanding a load mismatch corresponding to VSWR = 10 : 1 through all phases under the following conditions: VDS = 32 V; f = 860 MHz at rated load power. The BLF861A is an improved version of the BLF861 on ruggedness and is capable to withstand abrupt source or load mismatch errors under the nominal power condition. MCD871 12 MCD872 10 handbook, halfpage handbook, halfpage zi (Ω) ZL (Ω) xi RL 5 8 4 0 ri XL 0 400 500 600 700 −5 400 800 900 f (MHz) 500 600 700 CW, class-AB operation; VDS = 32 V; IDQ = 1 A; PL = 170 W (total device); Th = 25 °C. CW, class-AB operation; VDS = 32 V; IDQ = 1 A; PL = 170 W (total device); Th = 25 °C. Fig.3 Fig.4 Input impedance as a function of frequency (series components); typical push-pull values. 2001 Feb 09 4 800 900 f (MHz) Load impedance as a function of frequency (series components); typical push-pull values. Philips Semiconductors Product specification UHF power LDMOS transistor MLD514 20 handbook, halfpage Gp (dB) BLF861A 80 ηD (%) Gp dim (dBc) 60 −20 10 40 −40 5 20 −60 15 MLD515 0 handbook, halfpage d3 ηD 0 0 100 d5 −80 0 200 300 PL (PEP) (W) Th = 25 °C; VDS = 32 V; IDQ = 1 A. 2-tone: f1 = 860 MHz (−6 dB); f2 = 860.1 MHz (−6 dB) measured in an 860 MHz test circuit. Fig.5 Fig.6 MLD516 20 80 ηD (%) Gp (dB) Gp 15 60 ηD 10 40 5 20 0 0 50 100 150 0 250 200 PL (W) Th = 25 °C; VDS = 32 V; IDQ = 1 A; CW, class-AB; f = 860 MHz; measured in an 860 MHz test circuit. Fig.7 Power gain and drain efficiency as functions of load power; typical values. 2001 Feb 09 100 200 300 PL (PEP) (W) Th = 25 °C; VDS = 32 V; IDQ = 1 A. 2-tone: f1 = 860 MHz (−6 dB); f2 = 860.1 MHz (−6 dB) measured in an 860 MHz test circuit. Power gain and drain efficiency as functions of peak envelope load power; typical values. handbook, halfpage 0 5 Intermodulation distortion as a function of peak envelope output power; typical values. This text is here in white to force landscape pages to be rotated correctly when browsing through the pdf in the Acrobat reader.This text is here in _white to force landscape pages to be rotated correctly when browsing through the pdf in the Acrobat reader.This text is here inThis text is here in white to force landscape pages to be rotated correctly when browsing through the pdf in the Acrobat reader. white to force landscape pages to be ... +VS C19 C26 C18 L7 L1 6 C16 L13 L3 C9 50 Ω input C24 L11 L5 R5 C1 L18 L9 R3 R4 B1 C4 C2 C5 C6 C3 R1 C7 C8 C10 L 19 C14 C17 L2 L6 L14 L12 L8 L15 C20 C21 L17 B2 C11 C12 C13 L4 R6 Philips Semiconductors +Vbias UHF power LDMOS transistor handbook, full pagewidth 2001 Feb 09 R2 L16 C22 C15 C25 50 Ω output C23 MCD876 L10 Product specification BLF861A Fig.8 Class-AB common source broadband test circuit. Philips Semiconductors Product specification UHF power LDMOS transistor BLF861A List of components class-AB broadband test circuit (see Figs 8 and 9) COMPONENT DESCRIPTION VALUE C1 multilayer ceramic chip capacitor; note 1 20 pF C2 multilayer ceramic chip capacitor; note 1 4.3 pF DIMENSIONS C3, C6, C9 tekelec trimmer 0.6 to 4.5 pF C4 multilayer ceramic chip capacitor; note 1 9.1 pF C5 multilayer ceramic chip capacitor; note 1 10 pF C7 multilayer ceramic chip capacitor; note 1 5.1 pF C8 multilayer ceramic chip capacitor; note 1 13 pF C10, C11 multilayer ceramic chip capacitor; note 2 8.2 pF C12, C13 multilayer ceramic chip capacitor; note 2 6.8 pF C14 multilayer ceramic chip capacitor; note 3 1 pF C15 multilayer ceramic chip capacitor; note 3 20 pF C16, C17 multilayer ceramic chip capacitor 1 nF C18 multilayer ceramic chip capacitor 100 nF C19, C26 multilayer ceramic chip capacitor 100 µF C20, C21, C22, C23 multilayer ceramic chip capacitor; note 2 100 pF C24 electrolytic capacitor 1000 µF C25 multilayer ceramic chip capacitor 1 µF L1, L2 stripline; note 4 30.6 × 2.4 mm L3, L4 stripline; note 4 28 × 2.4 mm L5, L6 stripline; note 4 10 × 5 mm L7, L8 stripline; note 4 20 × 10 mm L9, L10 stripline; note 4 5.5 × 15 mm L11, L12 stripline; note 4 10 × 10 mm L13, L14 stripline; note 4 15 × 5 mm L15, L16 stripline; note 4 48.5 × 2.4 mm L17 stripline; note 4 10 × 2.4 mm L18 ferrite L19 wire inductor (hairpin) B1 semi rigid coax balun UT70-25 Z = 25 Ω ±1.5 Ω 70 mm B2 semi rigid coax balun UT70-25 Z = 25 Ω ±1.5 Ω 48.5 mm 2001 Feb 09 2222 595 16754 length = 17 mm 7 CATALOGUE No. Philips Semiconductors Product specification UHF power LDMOS transistor COMPONENT BLF861A DESCRIPTION VALUE R1 resistor 33 Ω R2 resistor 1 kΩ R3 resistor 100 kΩ R4 resistor 100 Ω R5, R6 SMD resistor 3.9 Ω DIMENSIONS CATALOGUE No. Notes 1. American Technical Ceramics type 100A or capacitor of same quality. 2. American Technical Ceramics type 180R or capacitor of same quality. 3. American Technical Ceramics type 100B or capacitor of same quality. 4. The striplines are on a double copper-clad printed-circuit board: Rogers 5880 (εr = 2.2); thickness 0.79 mm. 2001 Feb 09 8 Philips Semiconductors Product specification UHF power LDMOS transistor BLF861A 95 handbook, full pagewidth 95 80 +Vbias +VS C26 C18 C19 R2 R4 C16 C1 C17 R6 2.5 C8 C5 C2 C4 C3 R1 C6 C7 C9 C10 C11 L19 L18 8 15 10 B1 BLF861 R5 R3 B2 C20 C14 C21 C22 C12 C13 C25 C15 C23 C24 2.5 MCD877 Dimensions in mm. The components are situated on one side of the Rogers 5880 printed-circuit board, the other side is unetched and serves as a ground plane. Earth connections from the component side to the ground plane are made by through-metallization. Fig.9 Printed-circuit board and component layout for class-AB broadband test circuit. 2001 Feb 09 9 Philips Semiconductors Product specification UHF power LDMOS transistor MLD511 16 handbook, halfpage 80 (dB) (%) 12 60 MLD512 250 handbook, halfpage Po sync ηD Gp Gp BLF861A (W) 200 150 ηD 100 8 40 50 4 400 500 600 700 0 400 20 800 900 f (MHz) 500 600 700 800 900 f (MHz) Th = 25 °C; VCE = 32 V; IDQ = 1 A; PAL BG signal (TV); sync compression: input 33%, output 27%; measured in broadband test circuit. Th = 25 °C; VCE = 32 V; IDQ = 1 A; PAL BG signal (TV); sync compression: input 33%, output 27%; measured in broadband test circuit. Fig.10 Power gain and drain efficiency as functions of frequency; typical values. Fig.11 Peak envelope sync power as a function of frequency; typical values. MLD513 16 handbook, halfpage Gp Gp (dB) 80 ηD (%) 60 12 ηD 8 4 400 40 500 600 700 20 800 900 f (MHz) Th = 25 °C; VDS = 32 V; IDQ = 1 A; CW, class-AB operation; PL = 150 W; measured in broadband test circuit. Fig.12 Power gain and drain efficiency as functions of frequency; typical values. 2001 Feb 09 10 Philips Semiconductors Product specification UHF power LDMOS transistor BLF861A PACKAGE OUTLINE Flanged balanced LDMOST ceramic package; 2 mounting holes; 4 leads SOT540A D A F D1 U1 B q C w2 M C M H1 1 H c 2 E1 p U2 5 3 A E w1 M A M B M 4 w3 M b Q e 0 5 10 mm scale DIMENSIONS (millimetre dimensions are derived from the original inch dimensions) UNIT A b c mm 5.77 5.00 8.51 8.26 0.15 0.10 inches D D1 e E E1 22.05 22.05 10.26 10.31 10.21 21.64 21.64 10.06 10.01 F H 1.78 1.52 H1 15.75 18.72 14.73 18.47 p Q q U1 U2 w1 w2 w3 3.38 3.12 2.72 2.46 27.94 34.16 33.91 9.91 9.65 0.25 0.51 0.25 0.227 0.335 0.006 0.868 0.868 0.404 0.406 0.070 0.620 0.737 0.133 0.107 1.345 0.390 1.100 0.010 0.020 0.010 0.402 0.197 0.325 0.004 0.852 0.852 0.396 0.394 0.060 0.580 0.727 0.123 0.097 1.335 0.380 OUTLINE VERSION REFERENCES IEC JEDEC EIAJ ISSUE DATE 99-08-27 99-12-28 SOT540A 2001 Feb 09 EUROPEAN PROJECTION 11 Philips Semiconductors Product specification UHF power LDMOS transistor BLF861A DATA SHEET STATUS DATA SHEET STATUS PRODUCT STATUS DEFINITIONS (1) Objective specification Development This data sheet contains the design target or goal specifications for product development. Specification may change in any manner without notice. Preliminary specification Qualification This data sheet contains preliminary data, and supplementary data will be published at a later date. Philips Semiconductors reserves the right to make changes at any time without notice in order to improve design and supply the best possible product. Product specification Production This data sheet contains final specifications. Philips Semiconductors reserves the right to make changes at any time without notice in order to improve design and supply the best possible product. Note 1. Please consult the most recently issued data sheet before initiating or completing a design. DEFINITIONS DISCLAIMERS Short-form specification  The data in a short-form specification is extracted from a full data sheet with the same type number and title. For detailed information see the relevant data sheet or data handbook. Life support applications  These products are not designed for use in life support appliances, devices, or systems where malfunction of these products can reasonably be expected to result in personal injury. Philips Semiconductors customers using or selling these products for use in such applications do so at their own risk and agree to fully indemnify Philips Semiconductors for any damages resulting from such application. Limiting values definition  Limiting values given are in accordance with the Absolute Maximum Rating System (IEC 60134). Stress above one or more of the limiting values may cause permanent damage to the device. These are stress ratings only and operation of the device at these or at any other conditions above those given in the Characteristics sections of the specification is not implied. Exposure to limiting values for extended periods may affect device reliability. Right to make changes  Philips Semiconductors reserves the right to make changes, without notice, in the products, including circuits, standard cells, and/or software, described or contained herein in order to improve design and/or performance. Philips Semiconductors assumes no responsibility or liability for the use of any of these products, conveys no licence or title under any patent, copyright, or mask work right to these products, and makes no representations or warranties that these products are free from patent, copyright, or mask work right infringement, unless otherwise specified. Application information  Applications that are described herein for any of these products are for illustrative purposes only. Philips Semiconductors make no representation or warranty that such applications will be suitable for the specified use without further testing or modification. CAUTION This product is supplied in anti-static packing to prevent damage caused by electrostatic discharge during transport and handling. For further information, refer to Philips specs.: SNW-EQ-608, SNW-FQ-302A and SNW-FQ-302B. 2001 Feb 09 12 Philips Semiconductors Product specification UHF power LDMOS transistor BLF861A NOTES 2001 Feb 09 13 Philips Semiconductors Product specification UHF power LDMOS transistor BLF861A NOTES 2001 Feb 09 14 Philips Semiconductors Product specification UHF power LDMOS transistor BLF861A NOTES 2001 Feb 09 15 Philips Semiconductors – a worldwide company Argentina: see South America Australia: 3 Figtree Drive, HOMEBUSH, NSW 2140, Tel. +61 2 9704 8141, Fax. +61 2 9704 8139 Austria: Computerstr. 6, A-1101 WIEN, P.O. Box 213, Tel. +43 1 60 101 1248, Fax. +43 1 60 101 1210 Belarus: Hotel Minsk Business Center, Bld. 3, r. 1211, Volodarski Str. 6, 220050 MINSK, Tel. +375 172 20 0733, Fax. +375 172 20 0773 Belgium: see The Netherlands Brazil: see South America Bulgaria: Philips Bulgaria Ltd., Energoproject, 15th floor, 51 James Bourchier Blvd., 1407 SOFIA, Tel. +359 2 68 9211, Fax. +359 2 68 9102 Canada: PHILIPS SEMICONDUCTORS/COMPONENTS, Tel. +1 800 234 7381, Fax. +1 800 943 0087 China/Hong Kong: 501 Hong Kong Industrial Technology Centre, 72 Tat Chee Avenue, Kowloon Tong, HONG KONG, Tel. +852 2319 7888, Fax. +852 2319 7700 Colombia: see South America Czech Republic: see Austria Denmark: Sydhavnsgade 23, 1780 COPENHAGEN V, Tel. +45 33 29 3333, Fax. +45 33 29 3905 Finland: Sinikalliontie 3, FIN-02630 ESPOO, Tel. +358 9 615 800, Fax. +358 9 6158 0920 France: 51 Rue Carnot, BP317, 92156 SURESNES Cedex, Tel. +33 1 4099 6161, Fax. +33 1 4099 6427 Germany: Hammerbrookstraße 69, D-20097 HAMBURG, Tel. +49 40 2353 60, Fax. +49 40 2353 6300 Hungary: Philips Hungary Ltd., H-1119 Budapest, Fehervari ut 84/A, Tel: +36 1 382 1700, Fax: +36 1 382 1800 India: Philips INDIA Ltd, Band Box Building, 2nd floor, 254-D, Dr. Annie Besant Road, Worli, MUMBAI 400 025, Tel. +91 22 493 8541, Fax. +91 22 493 0966 Indonesia: PT Philips Development Corporation, Semiconductors Division, Gedung Philips, Jl. Buncit Raya Kav.99-100, JAKARTA 12510, Tel. +62 21 794 0040 ext. 2501, Fax. +62 21 794 0080 Ireland: Newstead, Clonskeagh, DUBLIN 14, Tel. +353 1 7640 000, Fax. +353 1 7640 200 Israel: RAPAC Electronics, 7 Kehilat Saloniki St, PO Box 18053, TEL AVIV 61180, Tel. +972 3 645 0444, Fax. +972 3 649 1007 Italy: PHILIPS SEMICONDUCTORS, Via Casati, 23 - 20052 MONZA (MI), Tel. +39 039 203 6838, Fax +39 039 203 6800 Japan: Philips Bldg 13-37, Kohnan 2-chome, Minato-ku, TOKYO 108-8507, Tel. +81 3 3740 5130, Fax. +81 3 3740 5057 Korea: Philips House, 260-199 Itaewon-dong, Yongsan-ku, SEOUL, Tel. +82 2 709 1412, Fax. +82 2 709 1415 Malaysia: No. 76 Jalan Universiti, 46200 PETALING JAYA, SELANGOR, Tel. +60 3 750 5214, Fax. +60 3 757 4880 Mexico: 5900 Gateway East, Suite 200, EL PASO, TEXAS 79905, Tel. +9-5 800 234 7381, Fax +9-5 800 943 0087 Middle East: see Italy Netherlands: Postbus 90050, 5600 PB EINDHOVEN, Bldg. VB, Tel. +31 40 27 82785, Fax. +31 40 27 88399 New Zealand: 2 Wagener Place, C.P.O. Box 1041, AUCKLAND, Tel. +64 9 849 4160, Fax. +64 9 849 7811 Norway: Box 1, Manglerud 0612, OSLO, Tel. +47 22 74 8000, Fax. +47 22 74 8341 Pakistan: see Singapore Philippines: Philips Semiconductors Philippines Inc., 106 Valero St. Salcedo Village, P.O. Box 2108 MCC, MAKATI, Metro MANILA, Tel. +63 2 816 6380, Fax. +63 2 817 3474 Poland: Al.Jerozolimskie 195 B, 02-222 WARSAW, Tel. +48 22 5710 000, Fax. +48 22 5710 001 Portugal: see Spain Romania: see Italy Russia: Philips Russia, Ul. Usatcheva 35A, 119048 MOSCOW, Tel. +7 095 755 6918, Fax. +7 095 755 6919 Singapore: Lorong 1, Toa Payoh, SINGAPORE 319762, Tel. +65 350 2538, Fax. +65 251 6500 Slovakia: see Austria Slovenia: see Italy South Africa: S.A. PHILIPS Pty Ltd., 195-215 Main Road Martindale, 2092 JOHANNESBURG, P.O. Box 58088 Newville 2114, Tel. +27 11 471 5401, Fax. +27 11 471 5398 South America: Al. Vicente Pinzon, 173, 6th floor, 04547-130 SÃO PAULO, SP, Brazil, Tel. +55 11 821 2333, Fax. +55 11 821 2382 Spain: Balmes 22, 08007 BARCELONA, Tel. +34 93 301 6312, Fax. +34 93 301 4107 Sweden: Kottbygatan 7, Akalla, S-16485 STOCKHOLM, Tel. +46 8 5985 2000, Fax. +46 8 5985 2745 Switzerland: Allmendstrasse 140, CH-8027 ZÜRICH, Tel. +41 1 488 2741 Fax. +41 1 488 3263 Taiwan: Philips Semiconductors, 5F, No. 96, Chien Kuo N. Rd., Sec. 1, TAIPEI, Taiwan Tel. +886 2 2134 2451, Fax. +886 2 2134 2874 Thailand: PHILIPS ELECTRONICS (THAILAND) Ltd., 60/14 MOO 11, Bangna Trad Road KM. 3, Bagna, BANGKOK 10260, Tel. +66 2 361 7910, Fax. +66 2 398 3447 Turkey: Yukari Dudullu, Org. San. Blg., 2.Cad. Nr. 28 81260 Umraniye, ISTANBUL, Tel. +90 216 522 1500, Fax. +90 216 522 1813 Ukraine: PHILIPS UKRAINE, 4 Patrice Lumumba str., Building B, Floor 7, 252042 KIEV, Tel. +380 44 264 2776, Fax. +380 44 268 0461 United Kingdom: Philips Semiconductors Ltd., 276 Bath Road, Hayes, MIDDLESEX UB3 5BX, Tel. +44 208 730 5000, Fax. +44 208 754 8421 United States: 811 East Arques Avenue, SUNNYVALE, CA 94088-3409, Tel. +1 800 234 7381, Fax. +1 800 943 0087 Uruguay: see South America Vietnam: see Singapore Yugoslavia: PHILIPS, Trg N. Pasica 5/v, 11000 BEOGRAD, Tel. +381 11 3341 299, Fax.+381 11 3342 553 For all other countries apply to: Philips Semiconductors, Marketing Communications, Building BE-p, P.O. Box 218, 5600 MD EINDHOVEN, The Netherlands, Fax. +31 40 27 24825 Internet: http://www.semiconductors.philips.com SCA 71 © Philips Electronics N.V. 2001 All rights are reserved. Reproduction in whole or in part is prohibited without the prior written consent of the copyright owner. The information presented in this document does not form part of any quotation or contract, is believed to be accurate and reliable and may be changed without notice. No liability will be accepted by the publisher for any consequence of its use. Publication thereof does not convey nor imply any license under patent- or other industrial or intellectual property rights. Printed in The Netherlands 613524/02/pp16 Date of release: 2001 Feb 09 Document order number: 9397 750 07753
BLF861A,112 价格&库存
很抱歉,暂时无法提供与“BLF861A,112”相匹配的价格&库存,您可以联系我们找货
