BLA1011-2,112
BLA1011-2,112
    AMPLEON(安谱隆)
    SOT538A
    TRANS LDMOS NCH 75V SOT538A
BLA1011-2,112 数据手册
BLA1011-2 Avionics LDMOS transistor Rev. 7 — 1 September 2015 Product data sheet 1. Product profile 1.1 General description Silicon N-channel enhancement mode LDMOS transistor encapsulated in a 2-lead flangeless package (SOT538A) with a ceramic cap. The common source is connected to the mounting base. Table 1. Typical performance RF performance at Th = 25 °C in a common source test circuit. Mode of operation Pulsed class-AB; tp = 50 s;  = 2% f VDS PL Gp (MHz) (V) (W) (dB) 1030 to 1090 36 2 >16 CAUTION This device is sensitive to ElectroStatic Discharge (ESD). Therefore care should be taken during transport and handling. 1.2 Features and benefits  High power gain  Easy power control  Excellent ruggedness  Source on mounting base eliminates DC isolators, reducing common mode inductance. 1.3 Applications  Avionics applications in the 1030 to 1090 MHz frequency range. 2. Pinning information Table 2. Pinning Pin Description 1 drain 2 gate 3 source, connected to mounting base Simplified outline Graphic symbol 1 1 3 2 3 sym112 2 BLA1011-2 Avionics LDMOS transistor 3. Ordering information Table 3. Ordering information Type number BLA1011-2 Package Name Description Version - ceramic surface mounted package; 2 leads SOT538A 4. Limiting values Table 4. Limiting values In accordance with the Absolute Maximum Rating System (IEC 60134). Symbol Parameter Conditions Min Max Unit VDS drain-source voltage - 75 V VGS gate-source voltage - 15 V ID drain current (DC) - 2.2 A Ptot total power dissipation 10 W Tstg storage temperature -65 +150 C Tj junction temperature - 200 C Th  25 C 5. Thermal characteristics Table 5. Thermal characteristics Symbol Parameter Conditions Zth(j-mb) thermal impedance from junction to mounting base Rth(mb-h) thermal resistance from mounting base to heatsink Typ Unit [1] 1 K/W [2] 6.5 K/W [1] Thermal impedance is determined under RF operating conditions with pulsed bias and Th = 25 C. [2] Typical value for mounting on PCB with 32 0.4 mm thermal vias with 20 m tin plating and thermal compound between PCB and heatsink. 6. Characteristics Table 6. Characteristics Tj = 25 C unless otherwise specified. BLA1011-2#7 Product data sheet Symbol Parameter Conditions Min Typ Max Unit V(BR)DSS drain-source breakdown voltage VGS = 0; ID = 0.2 mA 75 - - V VGSth gate-source threshold voltage VDS = 10 V; ID = 20 mA 2 - 5 V IDSS drain-source leakage current VGS = 0; VDS = 26 V - - 0.1 mA IDSX on-state drain current VGS = VGSth + 9 V; VDS = 10 V 2.8 - - A IGSS gate leakage current VGS = 15 V; VDS =0 - - 40 nA All information provided in this document is subject to legal disclaimers. Rev. 7 — 1 September 2015 © Ampleon The Netherlands B.V. 2015. All rights reserved. 2 of 10 BLA1011-2 Avionics LDMOS transistor Table 6. Characteristics …continued Tj = 25 C unless otherwise specified. Symbol Parameter gfs Conditions Min Typ Max Unit forward transconductance VDS = 10 V; ID = 0.75 A - 0.5 - S RDSon drain-source on-state resistance VGS = 10 V; ID = 0.75 A - 1.2 -  Cis input capacitance VGS = 0 V; VDS = 26 V; f = 1 MHz - 11 - pF Cos output capacitance VGS = 0 V; VDS = 26 V; f = 1 MHz - 9 - pF Crs feedback capacitance VGS = 0 V; VDS = 26 V; f = 1 MHz - 0.5 - pF 7. Application information Table 7. RF performance in a common source class-AB circuit Th = 25 C; Rth mb-h = 6.5 K/W unless otherwise specified. Mode of operation f VDS IDQ PL Gp tr tf Pulse droop (MHz) (V) (mA) (W) (dB) (ns) (ns) (dB) Pulsed class-AB; tp = 50 s;  = 2% 1030 to 1090 36 50 2 >16
BLA1011-2,112
物料型号:BLA1011-2
器件简介: - 这是一款硅N通道增强型LDMOS晶体管,封装在无耳片的2引脚SOT538A陶瓷封装中,共源连接到安装底座。
引脚分配: - 引脚1:漏极(Drain) - 引脚2:栅极(Gate) - 引脚3:源极(Source),连接到安装底座
参数特性: - 工作频率范围:1030至1090 MHz - 脉冲类AB模式下的典型射频性能:在25°C时,输出功率(PL)大于16 dBm,功耗(Ptot)不超过10W - 极限值:漏源电压(Vps)不超过75V,栅源电压(VGs)±15V,直流漏电流(lp)不超过2.2A
功能详解: - 高功率增益 - 出色的鲁棒性,能在所有工作条件下承受VSWR=5:1的负载不匹配 - 易于控制的电源
应用信息: - 适用于1030至1090 MHz频率范围内的航空电子应用
封装信息: - 封装类型:SOT538A,表面贴装陶瓷封装,2引脚
BLA1011-2,112 价格&库存
很抱歉,暂时无法提供与“BLA1011-2,112”相匹配的价格&库存,您可以联系我们找货
