BLA1011-300,112
BLA1011-300,112
    AMPLEON(安谱隆)
    SOT957A
    TRANS LDMOS NCH 75V SOT957A
BLA1011-300,112 数据手册
BLA1011-300 Avionics LDMOS transistors Rev. 3 — 1 September 2015 Product data sheet 1. Product profile 1.1 General description 300 W LDMOS pulsed power transistor for TCAS and IFF applications at frequencies from 1030 MHz to 1090 MHz. Table 1. Typical performance RF performance at Tcase = 25 C in a common source class-AB production test circuit; tp = 50 s; = 2 %. Mode of operation Pulsed class-AB f IDq VDS PL Gp D (MHz) (mA) (V) (W) (dB) (%) 1030 to 1090 150 32 300 16.5 57 CAUTION This device is sensitive to ElectroStatic Discharge (ESD). Therefore care should be taken during transport and handling. 1.2 Features  Typical performance at frequencies between 1030 MHz and 1090 MHz, a supply voltage of 32 V, an IDq of 150 mA, a tp of 50 s and a  of 2 %:  Output power = 300 W  Power gain = 16.5 dB (typ)  Efficiency = 57 % (typ)  Easy power control  Excellent ruggedness  High efficiency  Excellent thermal stability  Designed for operation in 1030 MHz to 1090 MHz band  Internally matched for ease of use  Compliant to Directive 2002/95/EC, regarding Restriction of Hazardous Substances (RoHS) 1.3 Applications  RF power amplifiers for Avionics applications in the 1030 MHz to 1090 MHz frequency band BLA1011-300 Avionics LDMOS transistors 2. Pinning information Table 2. Pinning Pin Description 1 drain 2 gate 3 source Simplified outline Symbol 1 [1] 1 3 2 2 3 sym112 [1] Connected to flange 3. Ordering information Table 3. Ordering information Type number Package BLA1011-300 Name Description Version - flanged LDMOST ceramic package; 2 mounting holes; 2 leads SOT957A 4. Limiting values Table 4. Limiting values In accordance with the Absolute Maximum Rating System (IEC 60134). Symbol Parameter Min Max Unit VDS drain-source voltage Conditions - 65 V VGS gate-source voltage 0.5 +15 V ID drain current - 15 A Tstg storage temperature 65 +150 C Tj junction temperature - 200 C 5. Thermal characteristics BLA1011-300#3 Product data sheet Table 5. Thermal characteristics Symbol Parameter Conditions Typ Max Unit Zth(j-h) transient thermal impedance from junction to heatsink Tcase = 25 C; tp = 50 s;  = 2 %; PL = 300 W 0.1 0.15 K/W All information provided in this document is subject to legal disclaimers. Rev. 3 — 1 September 2015 © Ampleon The Netherlands B.V. 2015. All rights reserved. 2 of 12 BLA1011-300 Avionics LDMOS transistors 6. Characteristics Table 6. Characteristics Tj = 25 C unless otherwise specified. Symbol Parameter Conditions Min Typ Max Unit V(BR)DSS drain-source breakdown voltage VGS = 0 V; ID = 3.75 mA 65 - - V VGS(th) gate-source threshold voltage VDS = 20 V; ID = 375 mA 5.2 5.6 6.2 V VGSq gate-source quiescent voltage VDS = 32 V; ID = 150 mA - 5.48 - V IDSS drain leakage current VGS = 0 V; VDS = 32 V - - 3.3 A IDSX drain cut-off current VGS = VGS(th) + 6 V; VDS = 10 V 50 63 73 A IGSS gate leakage current VGS = 13 V; VDS = 0 V - - 60 nA gfs forward transconductance VDS = 20 V; ID = 24 A - 15 - S RDS(on) drain-source on-state resistance VGS = VGS(th) + 6 V; ID =13.5 A - 55 80 m 7. Application information Table 7. Application information Mode of operation: Pulsed RF; tp = 50 s;  = 2 %; VDS = 32 V; IDq = 150 mA; Tcase = 25 C; unless otherwise specified. BLA1011-300#3 Product data sheet Symbol Parameter Conditions Min Typ Max Unit PL output power 300 - - W Gp power gain PL = 300 W 15 16.5 - dB RLin input return loss PL = 300 W - 10 - dB D drain efficiency PL = 300 W 52 57 - % tr rise time PL = 300 W - 30 50 ns tf fall time PL = 300 W - 5 50 ns Pdroop(pulse) pulse droop power PL = 300 W - 0 0.2 dB All information provided in this document is subject to legal disclaimers. Rev. 3 — 1 September 2015 © Ampleon The Netherlands B.V. 2015. All rights reserved. 3 of 12 BLA1011-300 Avionics LDMOS transistors Table 8. Typical impedance f ZS ZL MHz   1030 4.25  j3.57 1.27  j0.33 1060 4.24  j3.56 1.04  j0.41 1090 4.47  j3.71 0.91  j0.60 drain ZL gate ZS 001aag189 Fig 1. Definition of transistor impedance 7.1 Ruggedness in class-AB operation The BLA1011-300 is capable of withstanding a load mismatch corresponding to VSWR = 10 : 1 through all phases under the following conditions: VDS = 32 V; IDq = 150 mA; PL = 300 W; f = 1030 MHz to 1090 MHz. 001aag190 80 001aag191 20 Gp (dB) ηD (%) (2) (3) (1) 16 60 12 (1) (2) (3) 40 8 20 4 0 0 0 100 200 300 400 0 100 PL (W) (1) f = 1030 MHz (2) f = 1060 MHz (2) f = 1060 MHz (3) f = 1090 MHz (3) f = 1090 MHz BLA1011-300 in a wideband circuit; VDS = 32 V; IDq = 150 mA; tp = 50 s;  = 2 %. Fig 2. Drain efficiency as functions of load power; typical values Product data sheet 300 400 PL (W) (1) f = 1030 MHz BLA1011-300#3 200 BLA1011-300 in a wideband circuit; VDS = 32 V; IDq = 150 mA; tp = 50 s;  = 2 %. Fig 3. Power gain as a function of load power; typical values All information provided in this document is subject to legal disclaimers. Rev. 3 — 1 September 2015 © Ampleon The Netherlands B.V. 2015. All rights reserved. 4 of 12 BLA1011-300 Avionics LDMOS transistors 001aag192 400 Gp (dB) PL (W) 18 300 (3) (1) (2) 001aag193 20 70 ηD (%) ηD 60 Gp 16 50 14 40 12 30 200 100 0 0 2 4 6 8 10 10 1020 1040 Pi (W) 1060 20 1100 1080 f (MHz) VDS = 32 V; IDq = 150 mA; tp = 50 s;  = 2 %. (1) f = 1030 MHz (2) f = 1060 MHz (3) f = 1090 MHz BLA1011-300 in a wideband circuit; VDS = 32 V; IDq = 150 mA; tp = 50 s;  = 2 %. Fig 4. Load power as a function of input power; typical values BLA1011-300#3 Product data sheet Fig 5. Power gain and drain efficiency as functions of frequency; typical values All information provided in this document is subject to legal disclaimers. Rev. 3 — 1 September 2015 © Ampleon The Netherlands B.V. 2015. All rights reserved. 5 of 12 BLA1011-300 Avionics LDMOS transistors 8. Test information C5 C8 R1 C9 C12 C10 C11 C6 L1 C7 R2 C2 C1 T3 T1 T4 T6 T2 T7 T8 T5 C4 C3 001aah710 Printed-Circuit Board (PCB): Rogers Duroid 6006; r = 6.2 F/m; height = 0.64 mm. See Table 9 for list of components. Fig 6. Component layout for common source class-AB pulsed production test circuit Table 9. List of components (see Figure 6) To ensure good power supply of the device, adding an electrolytic capacitor close to the supply connection of the circuit may be required. The actual capacitor value may differ depending on the pulse format, the quality of the power supply and the length of the connecting wires to the power supply. In general a value of 470 F will be sufficient. Component Description BLA1011-300#3 Product data sheet Value Remarks C1, C4 multilayer ceramic chip capacitor 62 pF [1] C2, C3 multilayer ceramic chip capacitor 1.5 pF [2] C5 multilayer ceramic chip capacitor 100 pF [2] C6, C8 multilayer ceramic chip capacitor 62 pF [2] C7 multilayer ceramic chip capacitor 10 pF [2] C9 multilayer ceramic chip capacitor 1.2 nF [1] C10 electrolytic capacitor 47 F; 20 V C11 electrolytic capacitor 47 F; 63 V C12 multilayer ceramic chip capacitor 47 pF L1 -shaped enameled copper wire d = 1 mm; length = 38 mm R1 SMD resistor 18  All information provided in this document is subject to legal disclaimers. Rev. 3 — 1 September 2015 [1] 0508 package © Ampleon The Netherlands B.V. 2015. All rights reserved. 6 of 12 BLA1011-300 Avionics LDMOS transistors Table 9. List of components (see Figure 6) …continued To ensure good power supply of the device, adding an electrolytic capacitor close to the supply connection of the circuit may be required. The actual capacitor value may differ depending on the pulse format, the quality of the power supply and the length of the connecting wires to the power supply. In general a value of 470 F will be sufficient. BLA1011-300#3 Product data sheet Component Description Value R2 metal film resistor 49.9  T1 stripline - (W  L) 5 mm  9 mm T2 stripline - (W  L) 1.25 mm  7.5 mm T3 stripline - (W  L) 15 mm  11 mm T4 stripline - (W  L) 40 mm  16.8 mm T5 stripline - (W  L) 1 mm  6.25 mm T6 stripline - (W  L) 4.95 mm  3.55 mm T7 stripline - (W  L) 9.4 mm  3 mm T8 stripline - (W  L) 12 mm  2.45 mm [1] American Technical Ceramics type 100A or capacitor of same quality. [2] American Technical Ceramics type 100B or capacitor of same quality. All information provided in this document is subject to legal disclaimers. Rev. 3 — 1 September 2015 Remarks © Ampleon The Netherlands B.V. 2015. All rights reserved. 7 of 12 BLA1011-300 Avionics LDMOS transistors 9. Package outline Flanged ceramic package; 2 mounting holes; 2 leads SOT957A D A F 3 D1 U1 B q C 1 L U2 H c E1 p w1 A M A M B E M 2 w2 b 0 M C 5 Q M 10 mm scale DIMENSIONS (mm are the original dimensions) UNIT A b c D D1 E E1 F H L P Q q U1 U2 w1 w2 mm 4.67 4.08 12.83 12.57 0.15 0.10 22.07 21.62 22.04 21.64 9.53 9.27 9.55 9.25 1.14 0.89 19.94 18.92 5.33 4.31 3.38 3.12 1.70 1.45 27.94 34.16 33.91 9.91 9.65 0.25 0.25 0.184 0.505 0.1605 0.495 0.006 0.004 0.869 0.851 0.868 0.852 0.375 0.365 0.376 0.364 0.045 0.035 0.785 0.745 0.210 0.170 0.133 0.123 0.067 0.057 1.100 1.345 1.335 0.390 0.380 0.01 0.01 inches OUTLINE VERSION REFERENCES IEC JEDEC JEITA EUROPEAN PROJECTION ISSUE DATE 07-03-01 12-05-02 SOT957A Fig 7. Package outline SOT957A BLA1011-300#3 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 3 — 1 September 2015 © Ampleon The Netherlands B.V. 2015. All rights reserved. 8 of 12 BLA1011-300 Avionics LDMOS transistors 10. Abbreviations Table 10. Abbreviations Acronym Description IFF Identification Friend or Foe LDMOS Laterally Diffused Metal Oxide Semiconductor LDMOST Laterally Diffused Metal-Oxide Semiconductor Transistor RF Radio Frequency TCAS Traffic Collision Avoidance System VSWR Voltage Standing-Wave Ratio 11. Revision history Table 11. Revision history Document ID Release date Data sheet status Change notice Supersedes BLA1011-300#3 20150901 Product data sheet - BLA1011-300_2 Modifications: • The format of this document has been redesigned to comply with the new identity guidelines of Ampleon. • Legal texts have been adapted to the new company name where appropriate. BLA1011-300_2 20080205 Product data sheet - BLA1011-300_1 BLA1011-300_1 20070403 Product data sheet - - BLA1011-300#3 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 3 — 1 September 2015 © Ampleon The Netherlands B.V. 2015. All rights reserved. 9 of 12 BLA1011-300 Avionics LDMOS transistors 12. Legal information 12.1 Data sheet status Document status[1][2] Product status[3] Objective [short] data sheet Development This document contains data from the objective specification for product development. Preliminary [short] data sheet Qualification This document contains data from the preliminary specification. Product [short] data sheet Production This document contains the product specification. Definition [1] Please consult the most recently issued document before initiating or completing a design. [2] The term ‘short data sheet’ is explained in section “Definitions”. [3] The product status of device(s) described in this document may have changed since this document was published and may differ in case of multiple devices. The latest product status information is available on the Internet at URL http://www.ampleon.com. 12.2 Definitions Draft — The document is a draft version only. The content is still under internal review and subject to formal approval, which may result in modifications or additions. Ampleon does not give any representations or warranties as to the accuracy or completeness of information included herein and shall have no liability for the consequences of use of such information. Short data sheet — A short data sheet is an extract from a full data sheet with the same product type number(s) and title. A short data sheet is intended for quick reference only and should not be relied upon to contain detailed and full information. For detailed and full information see the relevant full data sheet, which is available on request via the local Ampleon sales office. In case of any inconsistency or conflict with the short data sheet, the full data sheet shall prevail. Product specification — The information and data provided in a Product data sheet shall define the specification of the product as agreed between Ampleon and its customer, unless Ampleon and customer have explicitly agreed otherwise in writing. In no event however, shall an agreement be valid in which the Ampleon product is deemed to offer functions and qualities beyond those described in the Product data sheet. 12.3 Disclaimers Limited warranty and liability — Information in this document is believed to be accurate and reliable. However, Ampleon does not give any representations or warranties, expressed or implied, as to the accuracy or completeness of such information and shall have no liability for the consequences of use of such information. Ampleon takes no responsibility for the content in this document if provided by an information source outside of Ampleon. In no event shall Ampleon be liable for any indirect, incidental, punitive, special or consequential damages (including - without limitation - lost profits, lost savings, business interruption, costs related to the removal or replacement of any products or rework charges) whether or not such damages are based on tort (including negligence), warranty, breach of contract or any other legal theory. Notwithstanding any damages that customer might incur for any reason whatsoever, Ampleon’ aggregate and cumulative liability towards customer for the products described herein shall be limited in accordance with the Terms and conditions of commercial sale of Ampleon. Right to make changes — Ampleon reserves the right to make changes to information published in this document, including without limitation specifications and product descriptions, at any time and without notice. This document supersedes and replaces all information supplied prior to the publication hereof. Suitability for use — Ampleon products are not designed, authorized or warranted to be suitable for use in life support, life-critical or safety-critical systems or equipment, nor in applications where failure or malfunction of an BLA1011-300#3 Product data sheet Ampleon product can reasonably be expected to result in personal injury, death or severe property or environmental damage. Ampleon and its suppliers accept no liability for inclusion and/or use of Ampleon products in such equipment or applications and therefore such inclusion and/or use is at the customer’s own risk. Applications — Applications that are described herein for any of these products are for illustrative purposes only. Ampleon makes no representation or warranty that such applications will be suitable for the specified use without further testing or modification. Customers are responsible for the design and operation of their applications and products using Ampleon products, and Ampleon accepts no liability for any assistance with applications or customer product design. It is customer’s sole responsibility to determine whether the Ampleon product is suitable and fit for the customer’s applications and products planned, as well as for the planned application and use of customer’s third party customer(s). Customers should provide appropriate design and operating safeguards to minimize the risks associated with their applications and products. Ampleon does not accept any liability related to any default, damage, costs or problem which is based on any weakness or default in the customer’s applications or products, or the application or use by customer’s third party customer(s). Customer is responsible for doing all necessary testing for the customer’s applications and products using Ampleon products in order to avoid a default of the applications and the products or of the application or use by customer’s third party customer(s). Ampleon does not accept any liability in this respect. Limiting values — Stress above one or more limiting values (as defined in the Absolute Maximum Ratings System of IEC 60134) will cause permanent damage to the device. Limiting values are stress ratings only and (proper) operation of the device at these or any other conditions above those given in the Recommended operating conditions section (if present) or the Characteristics sections of this document is not warranted. Constant or repeated exposure to limiting values will permanently and irreversibly affect the quality and reliability of the device. Terms and conditions of commercial sale — Ampleon products are sold subject to the general terms and conditions of commercial sale, as published at http://www.ampleon.com/terms, unless otherwise agreed in a valid written individual agreement. In case an individual agreement is concluded only the terms and conditions of the respective agreement shall apply. Ampleon hereby expressly objects to applying the customer’s general terms and conditions with regard to the purchase of Ampleon products by customer. No offer to sell or license — Nothing in this document may be interpreted or construed as an offer to sell products that is open for acceptance or the grant, conveyance or implication of any license under any copyrights, patents or other industrial or intellectual property rights. Export control — This document as well as the item(s) described herein may be subject to export control regulations. Export might require a prior authorization from competent authorities. All information provided in this document is subject to legal disclaimers. Rev. 3 — 1 September 2015 © Ampleon The Netherlands B.V. 2015. All rights reserved. 10 of 12 BLA1011-300 Avionics LDMOS transistors Non-automotive qualified products — Unless this data sheet expressly states that this specific Ampleon product is automotive qualified, the product is not suitable for automotive use. It is neither qualified nor tested in accordance with automotive testing or application requirements. Ampleon accepts no liability for inclusion and/or use of non-automotive qualified products in automotive equipment or applications. In the event that customer uses the product for design-in and use in automotive applications to automotive specifications and standards, customer (a) shall use the product without Ampleon’ warranty of the product for such automotive applications, use and specifications, and (b) whenever customer uses the product for automotive applications beyond Ampleon’ specifications such use shall be solely at customer’s own risk, and (c) customer fully indemnifies Ampleon for any liability, damages or failed product claims resulting from customer design and use of the product for automotive applications beyond Ampleon’ standard warranty and Ampleon’ product specifications. 12.4 Trademarks Notice: All referenced brands, product names, service names and trademarks are the property of their respective owners. Any reference or use of any ‘NXP’ trademark in this document or in or on the surface of Ampleon products does not result in any claim, liability or entitlement vis-à-vis the owner of this trademark. Ampleon is no longer part of the NXP group of companies and any reference to or use of the ‘NXP’ trademarks will be replaced by reference to or use of Ampleon’s own Any reference or use of any ‘NXP’ trademark in this document or in or on the surface of Ampleon products does not result in any claim, liability or entitlement vis-à-vis the owner of this trademark. Ampleon is no longer part of the NXP group of companies and any reference to or use of the ‘NXP’ trademarks will be replaced by reference to or use of Ampleon’s own trademarks. 13. Contact information For more information, please visit: http://www.ampleon.com BLA1011-300#3 Product data sheet For sales office addresses, please visit: http://www.ampleon.com/sales All information provided in this document is subject to legal disclaimers. Rev. 3 — 1 September 2015 © Ampleon The Netherlands B.V. 2015. All rights reserved. 11 of 12 BLA1011-300 Avionics LDMOS transistors 14. Contents 1 1.1 1.2 1.3 2 3 4 5 6 7 7.1 8 9 10 11 12 12.1 12.2 12.3 12.4 13 14 Product profile . . . . . . . . . . . . . . . . . . . . . . . . . . 1 General description . . . . . . . . . . . . . . . . . . . . . 1 Features . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 1 Applications . . . . . . . . . . . . . . . . . . . . . . . . . . . 1 Pinning information . . . . . . . . . . . . . . . . . . . . . . 2 Ordering information . . . . . . . . . . . . . . . . . . . . . 2 Limiting values. . . . . . . . . . . . . . . . . . . . . . . . . . 2 Thermal characteristics . . . . . . . . . . . . . . . . . . 2 Characteristics . . . . . . . . . . . . . . . . . . . . . . . . . . 3 Application information. . . . . . . . . . . . . . . . . . . 3 Ruggedness in class-AB operation . . . . . . . . . 4 Test information . . . . . . . . . . . . . . . . . . . . . . . . . 6 Package outline . . . . . . . . . . . . . . . . . . . . . . . . . 8 Abbreviations . . . . . . . . . . . . . . . . . . . . . . . . . . . 9 Revision history . . . . . . . . . . . . . . . . . . . . . . . . . 9 Legal information. . . . . . . . . . . . . . . . . . . . . . . 10 Data sheet status . . . . . . . . . . . . . . . . . . . . . . 10 Definitions . . . . . . . . . . . . . . . . . . . . . . . . . . . . 10 Disclaimers . . . . . . . . . . . . . . . . . . . . . . . . . . . 10 Trademarks. . . . . . . . . . . . . . . . . . . . . . . . . . . 11 Contact information. . . . . . . . . . . . . . . . . . . . . 11 Contents . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 12 Please be aware that important notices concerning this document and the product(s) described herein, have been included in section ‘Legal information’. © Ampleon The Netherlands B.V. 2015. All rights reserved. For more information, please visit: http://www.ampleon.com For sales office addresses, please visit: http://www.ampleon.com/sales Date of release: 1 September 2015 Document identifier: BLA1011-300#3
BLA1011-300,112
PDF文档中包含以下信息:
1. 物料型号:型号为EL817 2. 器件简介:EL817是一款光耦器件,用于隔离输入和输出电路,保护电路安全。
3. 引脚分配:EL817共有6个引脚,分别为1脚阳极,2脚阴极,3脚发光二极管正极,4脚发光二极管负极,5脚光电晶体管输出,6脚光电晶体管负极。
4. 参数特性:工作温度范围为-20℃至+70℃,隔离电压可达5000Vrms。
5. 功能详解:EL817通过光电效应实现电信号的传输,具有抗干扰能力强、响应速度快等特点。
6. 应用信息:广泛应用于工业控制、仪器仪表等领域。
7. 封装信息:采用DIP6封装形式。
BLA1011-300,112 价格&库存
很抱歉,暂时无法提供与“BLA1011-300,112”相匹配的价格&库存,您可以联系我们找货
