BLF242,112
BLF242,112
    AMPLEON(安谱隆)
    SOT-123A
    RF Mosfet N-Channel 28V 10mA 175MHz 16dB 5W CRFM4
BLF242,112 数据手册
BLF242 HF-VHF power MOS transistor Rev. 4 — 1 September 2015 Product data sheet IMPORTANT NOTICE Dear customer, As of December 7th, 2015 BL RF Power of NXP Semiconductors will operate as an independent company under the new trade name Ampleon, which will be used in future data sheets together with new contact details. In data sheets, where the previous Philips references is mentioned, please use the new links as shown below. http://www.philips.semiconductors.com use http://www.ampleon.com http://www.semiconductors.philips.com use http://www.ampleon.com (Internet) sales.addresses@www.semiconductors.philips.com use http://www.ampleon.com/sales The copyright notice at the bottom of each page (or elsewhere in the document, depending on the version) - © Koninklijke Philips Electronics N.V. (year). All rights reserved is replaced with: - © Ampleon B.V. (year). All rights reserved. If you have any questions related to the data sheet, please contact our nearest sales office (details via http://www.ampleon.com/sales). Thank you for your cooperation and understanding, Ampleon Philips Semiconductors Product specification HF-VHF power MOS transistor FEATURES BLF242 PIN CONFIGURATION • High power gain • Low noise handbook, halfpage • Easy power control 1 4 • Good thermal stability • Withstands full load mismatch d • Gold metallization ensures excellent reliability. g MBB072 2 DESCRIPTION Silicon N-channel enhancement mode vertical D-MOS transistor designed for professional transmitter applications in the HF/VHF frequency range. The transistor is encapsulated in a 4-lead, SOT123A flange package, with a ceramic cap. All leads are isolated from the flange. s 3 MSB057 Fig.1 Simplified outline and symbol. CAUTION This product is supplied in anti-static packing to prevent damage caused by electrostatic discharge during transport and handling. For further information, refer to Philips specs.: SNW-EQ-608, SNW-FQ-302A, and SNW-FQ-302B. PINNING - SOT123A PIN WARNING DESCRIPTION 1 drain Product and environmental safety - toxic materials 2 source 3 gate 4 source This product contains beryllium oxide. The product is entirely safe provided that the BeO disc is not damaged. All persons who handle, use or dispose of this product should be aware of its nature and of the necessary safety precautions. After use, dispose of as chemical or special waste according to the regulations applying at the location of the user. It must never be thrown out with the general or domestic waste. QUICK REFERENCE DATA RF performance at Th = 25 °C in a common source test circuit. MODE OF OPERATION CW, class-B 2003 Oct 13 f (MHz) VDS (V) PL (W) Gp (dB) ηD (%) 175 28 5 >13 typ. 16 >50 typ. 60 2 Philips Semiconductors Product specification HF-VHF power MOS transistor BLF242 LIMITING VALUES In accordance with the Absolute Maximum Rating System (IEC 60134). SYMBOL PARAMETER CONDITIONS MIN. MAX. UNIT VDS drain-source voltage − 65 V VGS gate-source voltage − ±20 V ID drain current (DC) − 1 A Ptot total power dissipation − 16 W Tstg storage temperature −65 150 °C Tj junction temperature − 200 °C Tmb ≤ 25 °C THERMAL CHARACTERISTICS SYMBOL PARAMETER CONDITIONS VALUE UNIT Rth j-mb thermal resistance from junction to mounting base Tmb = 25 °C; Ptot = 16 W 11 K/W Rth mb-h thermal resistance from mounting base to heatsink Tmb = 25 °C; Ptot = 16 W 0.3 K/W MRA918 10 MPG141 20 handbook, halfpage handbook, halfpage ID (A) Ptot (2) (W) 1 (2) (1) (1) 10 10−1 10−2 1 10 VDS (V) 0 102 0 100 Th (°C) (1) Continuous operation. (2) Short-time operation during mismatch. (1) Current is this area may be limited by RDSon. (2) Tmb = 25 °C. Fig.2 DC SOAR. 2003 Oct 13 50 Fig.3 Power derating curves. 3 150 Philips Semiconductors Product specification HF-VHF power MOS transistor BLF242 CHARACTERISTICS Tj = 25 °C unless otherwise specified. SYMBOL PARAMETER CONDITIONS MIN. TYP. MAX. UNIT V(BR)DSS drain-source breakdown voltage VGS = 0; ID = 0.1 mA 65 − − V IDSS drain-source leakage current VGS = 0; VDS = 28 V − − 10 µA IGSS gate-source leakage current VGS = ±20 V; VDS = 0 − − 1 µA VGSth gate-source threshold voltage ID = 3 mA; VDS = 10 V 2 − 4.5 V gfs forward transconductance ID = 0.3 A; VDS = 10 V 0.16 0.24 − S RDSon drain-source on-state resistance ID = 0.3 A; VGS = 1 V − 3.3 5 Ω IDSX on-state drain current VGS = 10 V; VGS = 10 V − 1.2 − A Cis input capacitance VGS = 0; VDS = 28 V; f = 1 MHz − 13 − pF Cos output capacitance VGS = 0; VDS = 28 V; f = 1 MHz − 9.4 − pF Crs feedback capacitance VGS = 0; VDS = 28 V; f = 1 MHz − 1.7 − pF VGS group indicator LIMITS (V) GROUP LIMITS (V) GROUP MIN. MAX. A 2.0 2.1 MIN. MAX. O 3.3 3.4 B 2.1 2.2 P 3.4 3.5 C 2.2 2.3 Q 3.5 3.6 D 2.3 2.4 R 3.6 3.7 E 2.4 2.5 S 3.7 3.8 F 2.5 2.6 T 3.8 3.9 G 2.6 2.7 U 3.9 4.0 H 2.7 2.8 V 4.0 4.1 J 2.8 2.9 W 4.1 4.2 K 2.9 3.0 X 4.2 4.3 L 3.0 3.1 Y 4.3 4.4 Z 4.4 4.5 M 3.1 3.2 N 3.2 3.3 2003 Oct 13 4 Philips Semiconductors Product specification HF-VHF power MOS transistor BLF242 MBB777 4 MGP142 1.5 handbook, halfpage handbook, halfpage T.C. (mV/K) ID (A) 2 1 0 0.5 –2 0 –4 0 100 200 ID (mA) 0 300 VDS = 10 V. Fig.4 5 10 VGS (V) 15 VDS = 10 V; Tj = 25 °C. Temperature coefficient of gate-source voltage as a function of drain current, typical values. Fig.5 MBB778 6 Drain current as a function of gate-source voltage, typical values. MBB776 30 handbook, halfpage handbook, halfpage RDS (on) (Ω) C (pF) 4 20 Cis Cos 2 10 0 0 0 50 100 Tj (oC) 150 0 10 20 VDS (V) 30 ID = 0.3 A; VGS = 10 V. VGS = 0; f = 1 MHz. Fig.6 Drain-source on-state resistance as a function of junction temperature, typical values. 2003 Oct 13 Fig.7 5 Input and output capacitance as functions of drain-source voltage, typical values. Philips Semiconductors Product specification HF-VHF power MOS transistor BLF242 MBB775 6 handbook, halfpage Crs (pF) 4 2 0 0 10 20 VDS (V) 30 VGS = 0; f = 1 MHz. Fig.8 Feedback capacitance as a function of drain-source voltage, typical values. APPLICATION INFORMATION FOR CLASS-B OPERATION Th = 25 °C; Rth mb-h = 0.3 K/W; unless otherwise specified. RF performance in CW operation in a common source class-B test circuit. MODE OF OPERATION CW, class-B f (MHz) VDS (V) IDQ (mA) PL (W) GP (dB) ηD (%) RGS (Ω) 175 28 10 5 >13 typ. 16 >50 typ. 60 47 Ruggedness in class-B operation The BLF242 is capable of withstanding a load mismatch corresponding to VSWR = 50 through all phases under the following conditions: VDS = 28 V; f =175 MHz at rated output power. Noise figure (see Fig.11) VDS = 28 V; ID = 0.2 A; f = 175 MHz; RGS = 47 Ω; Th = 25 °C. Input and output power matched for PL = 5 W; F = typ. 5.5 dB. 2003 Oct 13 6 Philips Semiconductors Product specification HF-VHF power MOS transistor BLF242 MGP143 MGP144 100 20 handbook, halfpage Gp (dB) 10 handbook, halfpage ηd (%) Gp PL (W) ηd 10 0 0 5 50 5 0 0 10 PL (W) 0 0.5 PIN (W) 1 Class-B operation; VDS = 28 V; IDQ = 10 mA; RGS = 47 Ω; f = 175 MHz. Class-B operation; VDS = 28 V; IDQ = 10 mA; RGS = 47 Ω; f = 175 MHz. Fig.9 Fig.10 Load power as a function of input power, typical values. Power gain and efficiency as functions of load power, typical values. L3 D.U.T. handbook, full pagewidth C1 L1 input 50 Ω L5 C6 output 50 Ω L2 C7 C2 R1 L4 C3 L6 C3 +VD R2 +VG C5 C8 C9 MGP145 f = 175 MHz. Fig.11 Test circuit for class-B operation. 2003 Oct 13 7 Philips Semiconductors Product specification HF-VHF power MOS transistor BLF242 List of components (see Fig.11) COMPONENT DESCRIPTION VALUE DIMENSIONS 4 to 40 pF CATALOGUE NO. C1, C2, C7 film dielectric trimmer C3 multilayer ceramic chip capacitor; note 1 100 pF 2222 809 08002 C4, C8 ceramic chip capacitor 100 nF 2222 852 47104 C6 film dielectric trimmer 5 to 60 pF 2222 809 08003 C9 electrolytic capacitor 2.2 µF, 40 V L1 5 turns enamelled 0.7 mm copper wire 53 nH length 5.4 mm int. dia. 3 mm leads 2 × 5 mm L2, L3 stripline; note 2 30 Ω 10 × 6 mm L4 11 turns enamelled 1 mm copper wire 500 nH length 15.5 mm int. dia. 8 mm leads 2 × 5 mm L5 5 turns enamelled 1 mm copper wire 79 nH length 9.1 mm int. dia. 5 mm leads 2 × 5 mm L6 grade 3B Ferroxcube RF choke R1 0.5 W metal film resistor 47 Ω R2 0.5 W metal film resistor 10 Ω 4312 020 36640 Notes 1. American Technical Ceramics (ATC) capacitor, type 100B or other capacitor of the same quality. 2. The striplines are on a double copper-clad printed circuit board, with epoxy fibre-glass dielectric (εr = 4.5), thickness 1⁄16 inch. 2003 Oct 13 8 Philips Semiconductors Product specification HF-VHF power MOS transistor BLF242 150 handbook, full pagewidth strap strap 70 rivet L6 +VD C5 R2 C8 C3 C4 +VG L4 R1 C1 C2 C9 L5 L1 L2 C6 L3 C7 MGP146 Dimensions in mm. The circuit and components are situated on one side of the epoxy fibre-glass board, the other side being fully metallized to serve as earth. Earth connections are made by fixing screws, copper straps and hollow rivets at the edges of the board and under the source. Fig.12 Component layout for 175 MHz class-B test circuit. 2003 Oct 13 9 Philips Semiconductors Product specification HF-VHF power MOS transistor BLF242 MGP149 MGP150 50 100 handbook, halfpage Zi (Ω) handbook, halfpage ri ZL (Ω) 30 10 RL 50 XL −10 xi −30 0 100 f (MHz) 0 200 0 100 f (MHz) 200 Class-B operation; VDS = 28 V; PL = 30 W; RGS = 47 Ω; Th = 25 °C. Class-B operation; VDS = 28 V; PL = 30 W; RGS = 47 Ω; Th = 25 °C. Fig.13 Input impedance as a function of frequency (series components), typical values. Fig.14 Load impedance as a function of frequency (series components), typical values. MGP148 20 handbook, halfpage Gp (dB) 10 0 0 100 f (MHz) 200 Class-B operation; VDS = 28 V; PL = 30 W; RGS = 47 Ω; Th = 25 °C. Fig.15 Power gain as a function of frequency, typical values. 2003 Oct 13 10 Philips Semiconductors Product specification HF-VHF power MOS transistor BLF242 BLF242 scattering parameters VDS = 28 V; ID = 10 mA; note 1 s11 f (MHz) s21 s12 s22 |s11| ∠Φ |s21| ∠Φ |s12| ∠Φ |s22| ∠Φ 5 0.99 −3.40 5.57 177.10 0.01 87.60 1.00 −2.60 10 0.98 −5.80 5.52 175.10 0.01 85.50 1.00 −5.30 20 0.99 −12.40 5.53 169.40 0.02 80.70 0.99 −10.70 30 0.98 −17.90 5.46 164.90 0.03 76.50 0.99 −16.10 40 0.97 −24.10 5.40 159.80 0.04 71.80 0.98 −21.30 50 0.96 −30.10 5.30 154.80 0.05 67.2 0.97 −26.30 60 0.95 −36.10 5.17 149.80 0.06 62.90 0.95 −31.20 70 0.93 −41.60 5.01 145.10 0.06 58.70 0.94 −35.80 80 0.92 −46.40 4.83 141.00 0.07 55.10 0.93 −40.20 90 0.91 −50.90 4.68 137.30 0.08 51.80 0.92 −44.50 100 0.90 −55.20 4.55 133.60 0.08 48.50 0.90 −48.70 125 0.87 −66.60 4.23 124.20 0.09 40.10 0.87 −58.40 150 0.84 −76.70 3.85 115.60 0.10 32.70 0.84 −66.60 175 0.82 −85.00 3.51 108.60 0.10 27.20 0.82 −74.00 200 0.81 −92.70 3.23 102.10 0.11 22.00 0.81 −80.90 250 0.78 −106.30 2.72 89.90 0.10 12.50 0.78 −92.10 300 0.78 −117.30 2.33 80.30 0.10 6.10 0.78 −101.80 350 0.77 −126.90 2.00 71.40 0.09 1.00 0.78 −109.70 400 0.78 −135.60 1.74 63.90 0.08 −1.50 0.79 −116.80 450 0.79 −143.20 1.53 56.80 0.06 −1.80 0.80 −123.00 500 0.79 −150.30 1.36 51.00 0.05 2.10 0.81 −128.80 600 0.81 −163.30 1.09 40.80 0.03 33.70 0.84 −139.00 700 0.82 −175.10 0.89 32.70 0.05 74.30 0.86 −147.90 800 0.83 173.80 0.74 26.80 0.08 87.20 0.87 −155.90 900 0.83 163.20 0.63 23.00 0.11 86.30 0.89 −162.90 1000 0.83 152.90 0.54 21.70 0.28 144.80 0.65 175.60 Note 1. For more extensive s-parameters see internet: http://www.semiconductors.philips.com/markets/communications/wirelesscommunication/broadcast. 2003 Oct 13 11 Philips Semiconductors Product specification HF-VHF power MOS transistor BLF242 PACKAGE OUTLINE Flanged ceramic package; 2 mounting holes; 4 leads SOT123A D A F D1 q C B U1 w2 M C M c H b 4 3 α A U2 p U3 w1 M A M B M 1 2 H Q 0 5 10 mm scale DIMENSIONS (millimetre dimensions are derived from the original inch dimensions) UNIT A b c D D1 F H p Q q U1 U2 U3 w1 w2 mm 7.47 6.37 5.82 5.56 0.18 0.10 9.73 9.47 9.78 9.42 2.72 2.31 20.71 19.93 3.33 3.04 4.63 4.11 18.42 24.87 24.64 6.48 6.22 9.78 9.39 0.25 0.51 inches 0.294 0.251 0.229 0.007 0.219 0.004 0.383 0.385 0.107 0.815 0.373 0.371 0.091 0.785 0.131 0.120 0.182 0.980 0.725 0.162 0.970 OUTLINE VERSION REFERENCES IEC JEDEC EIAJ EUROPEAN PROJECTION 45° ISSUE DATE 99-03-29 SOT123A 2003 Oct 13 0.255 0.385 0.010 0.020 0.245 0.370 α 12 Philips Semiconductors Product specification HF-VHF power MOS transistor BLF242 DATA SHEET STATUS LEVEL DATA SHEET STATUS(1) PRODUCT STATUS(2)(3) Development DEFINITION I Objective data II Preliminary data Qualification This data sheet contains data from the preliminary specification. Supplementary data will be published at a later date. Philips Semiconductors reserves the right to change the specification without notice, in order to improve the design and supply the best possible product. III Product data This data sheet contains data from the product specification. Philips Semiconductors reserves the right to make changes at any time in order to improve the design, manufacturing and supply. Relevant changes will be communicated via a Customer Product/Process Change Notification (CPCN). Production This data sheet contains data from the objective specification for product development. Philips Semiconductors reserves the right to change the specification in any manner without notice. Notes 1. Please consult the most recently issued data sheet before initiating or completing a design. 2. The product status of the device(s) described in this data sheet may have changed since this data sheet was published. The latest information is available on the Internet at URL http://www.semiconductors.philips.com. 3. For data sheets describing multiple type numbers, the highest-level product status determines the data sheet status. DEFINITIONS DISCLAIMERS Short-form specification  The data in a short-form specification is extracted from a full data sheet with the same type number and title. For detailed information see the relevant data sheet or data handbook. Life support applications  These products are not designed for use in life support appliances, devices, or systems where malfunction of these products can reasonably be expected to result in personal injury. Philips Semiconductors customers using or selling these products for use in such applications do so at their own risk and agree to fully indemnify Philips Semiconductors for any damages resulting from such application. Limiting values definition  Limiting values given are in accordance with the Absolute Maximum Rating System (IEC 60134). Stress above one or more of the limiting values may cause permanent damage to the device. These are stress ratings only and operation of the device at these or at any other conditions above those given in the Characteristics sections of the specification is not implied. Exposure to limiting values for extended periods may affect device reliability. Right to make changes  Philips Semiconductors reserves the right to make changes in the products including circuits, standard cells, and/or software described or contained herein in order to improve design and/or performance. When the product is in full production (status ‘Production’), relevant changes will be communicated via a Customer Product/Process Change Notification (CPCN). Philips Semiconductors assumes no responsibility or liability for the use of any of these products, conveys no licence or title under any patent, copyright, or mask work right to these products, and makes no representations or warranties that these products are free from patent, copyright, or mask work right infringement, unless otherwise specified. Application information  Applications that are described herein for any of these products are for illustrative purposes only. Philips Semiconductors make no representation or warranty that such applications will be suitable for the specified use without further testing or modification. 2003 Oct 13 13 Philips Semiconductors – a worldwide company Contact information For additional information please visit http://www.semiconductors.philips.com. Fax: +31 40 27 24825 For sales offices addresses send e-mail to: sales.addresses@www.semiconductors.philips.com. SCA75 © Koninklijke Philips Electronics N.V. 2003 All rights are reserved. Reproduction in whole or in part is prohibited without the prior written consent of the copyright owner. The information presented in this document does not form part of any quotation or contract, is believed to be accurate and reliable and may be changed without notice. No liability will be accepted by the publisher for any consequence of its use. Publication thereof does not convey nor imply any license under patent- or other industrial or intellectual property rights. Printed in The Netherlands 613524/03/pp14 Date of release: 2003 Oct 13 Document order number: 9397 750 11583
BLF242,112 价格&库存
很抱歉,暂时无法提供与“BLF242,112”相匹配的价格&库存,您可以联系我们找货
