BLF3G22-30,135
BLF3G22-30,135
    AMPLEON(安谱隆)
    SOT608A
    TRANSISTOR UHF PWR LDMOS SOT608
BLF3G22-30,135 数据手册
BLF3G22-30 UHF power LDMOS transistor Rev. 2 — 1 September 2015 Product data sheet 1. Product profile 1.1 General description 30 W LDMOS power transistor for base station applications at frequencies from 2000 MHz to 2200 MHz Table 1. Typical class-AB RF performance IDq = 450 mA; Th = 25 C in a common source test circuit. Mode of operation 2-tone 2-carrier W-CDMA[1] f1 f2 VDS IDq PL(PEP) PL(AV) Gp D IMD ACPR IMD3 (MHz) (MHz) (V) (mA) (W) (W) (dB) (%) (dBc) (dBc) (dBc) 2170 2170.1 28 450 36 - 14 34 24 - - - 42[2] 38 2115 2165 28 [1] 3GPP test model 1; 64 channels with 66 % clippings [2] Measured within 10 kHz bandwidth 450 - 6 15 21 CAUTION This device is sensitive to ElectroStatic Discharge (ESD). Therefore care should be taken during transport and handling. 1.2 Features  Excellent back off linearity  Typical 2-carrier W-CDMA performance at a supply voltage of 28 V and IDq of 450 mA:  Average output power = 6 W  Gain = 15 dB  Efficiency = 21 %  ACPR = 42 dBc (at 3.84 MHz)  IMD3 = 38 dBc  Easy power control  Excellent ruggedness  High power gain  Excellent thermal stability  Designed for broadband operation (2000 MHz to 2200 MHz)  Internally matched for ease of use  ESD protection BLF3G22-30 UHF power LDMOS transistor 1.3 Applications  RF power amplifiers for W-CDMA base stations and multicarrier applications in the 2000 MHz to 2200 MHz frequency range  Broadcast drivers 2. Pinning information Table 2. Pinning Pin Description 1 drain 2 gate 3 source Simplified outline Symbol 1 1 [1] 2 3 3 2 sym112 [1] Connected to flange 3. Ordering information Table 3. Ordering information Type number BLF3G22-30 Package Name Description Version - flanged ceramic package; 2 mounting holes; 2 leads SOT608A 4. Limiting values Table 4. Limiting values In accordance with the Absolute Maximum Rating System (IEC 60134). BLF3G22-30#2 Product data sheet Symbol Parameter VDS Conditions Min Max Unit drain-source voltage - 65 V VGS gate-source voltage - 15 V ID drain current - 12 A Tstg storage temperature 65 +150 C Tj junction temperature - 200 C All information provided in this document is subject to legal disclaimers. Rev. 2 — 1 September 2015 © Ampleon The Netherlands B.V. 2015. All rights reserved. 2 of 14 BLF3G22-30 UHF power LDMOS transistor 5. Thermal characteristics Table 5. Symbol Thermal characteristics Parameter Conditions Rth(j-case) thermal resistance from junction to case [1] Typ Th = 25 C [1] Unit 1.85 K/W Thermal resistance is determined under specified RF operating conditions 6. Characteristics Table 6. Characteristics Tj = 25 C unless otherwise specified Symbol Parameter Conditions Min Typ Max Unit V(BR)DSS drain-source breakdown voltage VGS = 0 V; ID = 0.7 mA 65 - - V VGS(th) gate-source threshold voltage VDS = 10 V; ID = 70 mA 2.0 - 3.0 V IDSS drain leakage current VGS = 0 V; VDS = 26 V - - 1.5 A IDSX drain cut-off current VGS = VGS(th) + 9 V; VDS = 10 V 9 - - A IGSS gate leakage current VGS = 15 V; VDS = 0 V - - 150 nA gfs forward transconductance VDS = 10 V; ID = 3.5 A - 3 - S RDS(on) drain-source on-state resistance VGS = VGS(th) + 6 V; ID = 2.5 A - 0.3 -  Crs feedback capacitance - 1.7 - pF Max Unit VGS = 0 V; VDS = 26 V; f = 1 MHz 7. Application information Table 7. Symbol Application information Parameter Conditions Min Typ Mode of operation: Two-tone CW (100 kHz tone spacing); f = 2170 MHz; IDq = 450 mA Gp power gain PL(PEP) = 30 W - 14 - dB RLin input return loss PL(PEP) = 30 W - 15 - dB D drain efficiency PL(PEP) = 30 W - 33 - % IMD3 third order intermodulation distortion PL(PEP) = 30 W - 24 - dBc PL(PEP) < 6 W - < 50 - dBc Mode of operation: Two-tone W-CDMA; 3GPP test model 1; 1 - 64 DPCH with 66 % clipping; f1 = 2115 MHz; f2 = 2165 MHz; IDq = 450 mA Gp power gain PL(AV) = 6 W 13 15 - dB RLin input return loss PL(AV) = 6 W - 10 8 dB D drain efficiency PL(AV) = 6 W 18 21 - % IMD3 third order intermodulation distortion PL(AV) = 6 W - 38 35 dBc ACPR adjacent channel power ratio PL(AV) = 6 W - 42 38 dBc [1] BLF3G22-30#2 Product data sheet [1] Measured within 10 kHz bandwidth. All information provided in this document is subject to legal disclaimers. Rev. 2 — 1 September 2015 © Ampleon The Netherlands B.V. 2015. All rights reserved. 3 of 14 BLF3G22-30 UHF power LDMOS transistor 7.1 Ruggedness in class-AB operation The BLF3G22-30 is capable of withstanding a load mismatch corresponding to VSWR = 10 : 1 through all phases under the following conditions: VDS = 28 V; IDq = 450 mA; PL = 30 W (CW); f = 2170 MHz. 7.2 One-tone 001aag535 20 Gp (dB) 16 50 ηD (%) 40 Gp 12 30 8 20 ηD 4 0 10−1 1 10 0 102 10 PL(AV) (W) VDS = 28 V; IDq = 450 mA; Th = 25 C; f1 = 2170 MHz; f2 = 2170.1 MHz Fig 1. Power gain and drain efficiency as functions of average load power; typical values 7.3 Two-tone 001aag536 20 Gp (dB) 16 50 ηD (%) 40 Gp 12 30 8 20 10 4 ηD 0 10−1 1 0 102 10 PL(PEP) (W) VDS = 28 V; IDq = 450 mA; Th = 25 C; f1 = 2170 MHz; f2 = 2170.1 MHz Fig 2. Power gain and drain efficiency as functions of peak envelope load power; typical values BLF3G22-30#2 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 2 — 1 September 2015 © Ampleon The Netherlands B.V. 2015. All rights reserved. 4 of 14 BLF3G22-30 UHF power LDMOS transistor 001aag541 0 IMD (dBc) 001aag542 0 IMD3 (dBc) −30 −30 (1) (2) IMD3 −60 −60 (3) IMD5 IMD7 −90 10−1 1 102 10 −90 10−1 PL(PEP) (W) 1 102 10 PL(PEP) (W) VDS = 28 V; IDq = 450 mA; Th = 25 C; f1 = 2170 MHz; f2 = 2170.1 MHz VDS = 28 V; Th = 25 C; f1 = 2170 MHz; f2 = 2170.1 MHz (1) IDq = 400 mA (2) IDq = 450 mA (3) IDq = 500 mA Fig 3. Intermodulation distortion as function of peak envelope load power; typical values BLF3G22-30#2 Product data sheet Fig 4. IMD3 as function of peak envelope load power; typical values All information provided in this document is subject to legal disclaimers. Rev. 2 — 1 September 2015 © Ampleon The Netherlands B.V. 2015. All rights reserved. 5 of 14 BLF3G22-30 UHF power LDMOS transistor 7.4 Two-carrier W-CDMA Input signals: 3GPP W-CDMA, test model 1, 1-64 DPCH with 66 % clipping; peak-to-average power ratio: 8.5 dB at 0.01 % probability on CCDF; channel spacing = 10 MHz; bandwidth = 3.84 MHz. 001aag537 20 Gp (dB) 16 ηD (%) 40 Gp 001aag538 0 50 IMD3, ACPR (dBc) −20 12 30 8 20 −40 4 IMD3 10 ηD ACPR 0 26 30 0 38 42 PL(AV) (W) 34 −60 VDS = 28 V; IDq = 450 mA; Th = 25 C; f1 = 2115 MHz; f2 = 2165 MHz 26 30 34 38 42 PL(AV) (W) VDS = 28 V; IDq = 450 mA; Th = 25 C; f1 = 2115 MHz; f2 = 2165 MHz Fig 5. Power gain and drain efficiency as functions of average load power; typical values Fig 6. IMD3 and ACPR as functions of average load power; typical values. 7.5 Input impedance and load impedances measured under CW conditions 001aag539 12 001aag540 8 RL ZL (Ω) Zi (Ω) 4 Ri 8 0 4 Xi −4 XL 0 2 2.05 2.1 2.15 2.2 −8 2 2.05 f (GHz) Fig 7. Input impedance as function of frequency (series components); typical values Product data sheet 2.15 2.2 f (GHz) VDS = 28 V; IDq = 450 mA; PL = 30 W; Th  25 C BLF3G22-30#2 2.1 VDS = 28 V; IDq = 450 mA; PL = 30 W; Th  25 C Fig 8. Load impedance as function of frequency (series components); typical values All information provided in this document is subject to legal disclaimers. Rev. 2 — 1 September 2015 © Ampleon The Netherlands B.V. 2015. All rights reserved. 6 of 14 BLF3G22-30 UHF power LDMOS transistor 8. Test information L1 VDD C8 C7 L11 C6 C13 C17 C14 C19 C20 VGate R1 L6 C11 C3 input 50 Ω L2 L3 C4 C1 L4 L5 L7 L8 C5 L9 C9 L10 C10 output 50 Ω C12 C2 L12 C16 C18 C15 mld944 Fig 9. Class-AB test circuit BLF3G22-30#2 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 2 — 1 September 2015 © Ampleon The Netherlands B.V. 2015. All rights reserved. 7 of 14 BLF3G22-30 UHF power LDMOS transistor 40 mm 40 mm 60 mm BLF3G22-30 testjig input C8 BLF3G22-30 testjig output C13 R1 C17 C6 C20 C14 L1 C19 C7 C3 C4 C11 C12 C5 C1 C9 C2 C10 C15 C18 C16 BLF3G22-30 testjig input BLF3G22-30 testjig output 001aag543 Dimensions in mm. The components are situated on one side of the copper-clad Printed-Circuit Board (PCB) with Teflon dielectric (r = 2.2); thickness = 0.79 mm. The other side is unetched and serves as a ground plane. See Table 8 for list of components. Fig 10. Component layout for 2.17 GHz class-AB test circuit BLF3G22-30#2 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 2 — 1 September 2015 © Ampleon The Netherlands B.V. 2015. All rights reserved. 8 of 14 BLF3G22-30 UHF power LDMOS transistor Table 8. List of components (see Figure 9 and Figure 10) Component Description Value C1, C2, C9, C10 Tekelec variable capacitor; type 37271 0.6 pF to 4.5 pF C3, C4, C11, C12 multilayer ceramic chip capacitor [1] 6.8 pF C5 multilayer ceramic chip capacitor [1] 2.2 pF multilayer ceramic chip capacitor C6, C7, C13, C14, C15, C16 [1] 12 pF Dimensions Catalogue No. 10 F C8 tantalum capacitor C17, C18 multilayer ceramic chip capacitor C19 multilayer ceramic chip capacitor C20 electrolytic capacitor 100 F; 63 V L1 handmade; enamelled 1 mm copper wire - 2 loops; 4 mm in diameter L2 stripline [3] 50  12 mm  2.4 mm L3 stripline [3] 43  18 mm  3 mm stripline [3] 29  4 mm  5 mm L4 1.5 F [2] TDK C3225X7R1H155M 1 nF L5 stripline [3] 10  5 mm  18.4 mm L6 stripline [3] 56  34.4 mm  2 mm L7 stripline [3] 9 10 mm  20 mm stripline [3] 29  4 mm  5 mm L8 L9 stripline [3] 41  20 mm  3.2 mm L10 stripline [3] 50  5 mm  2.4 mm L11, L12 stripline [3] 17  24.5 mm  10 mm [1] American Technical Ceramics type 100A or capacitor of same quality. [2] American Technical Ceramics type 100B or capacitor of same quality. [3] The striplines are on a double copper-clad Printed-Circuit Board (PCB) with Teflon dielectric (r = 2.2); thickness = 0.79 mm. BLF3G22-30#2 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 2 — 1 September 2015 © Ampleon The Netherlands B.V. 2015. All rights reserved. 9 of 14 BLF3G22-30 UHF power LDMOS transistor 9. Package outline Flanged ceramic package; 2 mounting holes; 2 leads SOT608A D A F 3 A w2 D1 A B C U1 q w2 B H c C A B C 1 p U2 E1 w3 A E B 2 w1 A B b C Q 0 5 10 mm scale Dimensions (millimetre dimensions are derived from the original inch dimensions) Unit A b c D D1 E E1 F H p Q q U1 U2 w1 w2 w3 max 4.62 7.24 0.15 10.21 10.29 10.21 10.29 1.14 15.37 3.30 1.70 20.45 9.91 0.25 0.25 0.25 nom 15.24 min 3.76 6.99 0.10 10.01 10.03 10.01 10.03 0.89 15.11 2.92 1.45 20.19 9.65 mm sot608a_po Outline version References IEC JEDEC JEITA European projection Issue date 09-08-26 13-01-29 SOT608A Fig 11. Package outline SOT608A BLF3G22-30#2 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 2 — 1 September 2015 © Ampleon The Netherlands B.V. 2015. All rights reserved. 10 of 14 BLF3G22-30 UHF power LDMOS transistor 10. Abbreviations Table 9. Abbreviations Acronym Description 3GPP Third Generation Partnership Project CCDF Complementary Cumulative Distribution Function CW Continuous Wave DPCH Dedicated Physical CHannel LDMOS Laterally Diffused Metal Oxide Semiconductor RF Radio Frequency UHF Ultra High Frequency VSWR Voltage Standing Wave Ratio W-CDMA Wideband Code Division Multiple Access 11. Revision history Table 10. Revision history Document ID Release date Data sheet status Change notice Supersedes BLF3G22-30#2 20150901 Product data sheet - BLF3G22-30_1 Modifications: BLF3G22-30_1 BLF3G22-30#2 Product data sheet • The format of this document has been redesigned to comply with the new identity guidelines of Ampleon. • Legal texts have been adapted to the new company name where appropriate. 20070621 Product data sheet - All information provided in this document is subject to legal disclaimers. Rev. 2 — 1 September 2015 - © Ampleon The Netherlands B.V. 2015. All rights reserved. 11 of 14 BLF3G22-30 UHF power LDMOS transistor 12. Legal information 12.1 Data sheet status Document status[1][2] Product status[3] Objective [short] data sheet Development This document contains data from the objective specification for product development. Preliminary [short] data sheet Qualification This document contains data from the preliminary specification. Product [short] data sheet Production This document contains the product specification. Definition [1] Please consult the most recently issued document before initiating or completing a design. [2] The term ‘short data sheet’ is explained in section “Definitions”. [3] The product status of device(s) described in this document may have changed since this document was published and may differ in case of multiple devices. The latest product status information is available on the Internet at URL http://www.ampleon.com. 12.2 Definitions Draft — The document is a draft version only. The content is still under internal review and subject to formal approval, which may result in modifications or additions. Ampleon does not give any representations or warranties as to the accuracy or completeness of information included herein and shall have no liability for the consequences of use of such information. Short data sheet — A short data sheet is an extract from a full data sheet with the same product type number(s) and title. A short data sheet is intended for quick reference only and should not be relied upon to contain detailed and full information. For detailed and full information see the relevant full data sheet, which is available on request via the local Ampleon sales office. In case of any inconsistency or conflict with the short data sheet, the full data sheet shall prevail. Product specification — The information and data provided in a Product data sheet shall define the specification of the product as agreed between Ampleon and its customer, unless Ampleon and customer have explicitly agreed otherwise in writing. In no event however, shall an agreement be valid in which the Ampleon product is deemed to offer functions and qualities beyond those described in the Product data sheet. 12.3 Disclaimers Limited warranty and liability — Information in this document is believed to be accurate and reliable. However, Ampleon does not give any representations or warranties, expressed or implied, as to the accuracy or completeness of such information and shall have no liability for the consequences of use of such information. Ampleon takes no responsibility for the content in this document if provided by an information source outside of Ampleon. In no event shall Ampleon be liable for any indirect, incidental, punitive, special or consequential damages (including - without limitation - lost profits, lost savings, business interruption, costs related to the removal or replacement of any products or rework charges) whether or not such damages are based on tort (including negligence), warranty, breach of contract or any other legal theory. Notwithstanding any damages that customer might incur for any reason whatsoever, Ampleon’ aggregate and cumulative liability towards customer for the products described herein shall be limited in accordance with the Terms and conditions of commercial sale of Ampleon. Right to make changes — Ampleon reserves the right to make changes to information published in this document, including without limitation specifications and product descriptions, at any time and without notice. This document supersedes and replaces all information supplied prior to the publication hereof. Suitability for use — Ampleon products are not designed, authorized or warranted to be suitable for use in life support, life-critical or safety-critical systems or equipment, nor in applications where failure or malfunction of an BLF3G22-30#2 Product data sheet Ampleon product can reasonably be expected to result in personal injury, death or severe property or environmental damage. Ampleon and its suppliers accept no liability for inclusion and/or use of Ampleon products in such equipment or applications and therefore such inclusion and/or use is at the customer’s own risk. Applications — Applications that are described herein for any of these products are for illustrative purposes only. Ampleon makes no representation or warranty that such applications will be suitable for the specified use without further testing or modification. Customers are responsible for the design and operation of their applications and products using Ampleon products, and Ampleon accepts no liability for any assistance with applications or customer product design. It is customer’s sole responsibility to determine whether the Ampleon product is suitable and fit for the customer’s applications and products planned, as well as for the planned application and use of customer’s third party customer(s). Customers should provide appropriate design and operating safeguards to minimize the risks associated with their applications and products. Ampleon does not accept any liability related to any default, damage, costs or problem which is based on any weakness or default in the customer’s applications or products, or the application or use by customer’s third party customer(s). Customer is responsible for doing all necessary testing for the customer’s applications and products using Ampleon products in order to avoid a default of the applications and the products or of the application or use by customer’s third party customer(s). Ampleon does not accept any liability in this respect. Limiting values — Stress above one or more limiting values (as defined in the Absolute Maximum Ratings System of IEC 60134) will cause permanent damage to the device. Limiting values are stress ratings only and (proper) operation of the device at these or any other conditions above those given in the Recommended operating conditions section (if present) or the Characteristics sections of this document is not warranted. Constant or repeated exposure to limiting values will permanently and irreversibly affect the quality and reliability of the device. Terms and conditions of commercial sale — Ampleon products are sold subject to the general terms and conditions of commercial sale, as published at http://www.ampleon.com/terms, unless otherwise agreed in a valid written individual agreement. In case an individual agreement is concluded only the terms and conditions of the respective agreement shall apply. Ampleon hereby expressly objects to applying the customer’s general terms and conditions with regard to the purchase of Ampleon products by customer. No offer to sell or license — Nothing in this document may be interpreted or construed as an offer to sell products that is open for acceptance or the grant, conveyance or implication of any license under any copyrights, patents or other industrial or intellectual property rights. Export control — This document as well as the item(s) described herein may be subject to export control regulations. Export might require a prior authorization from competent authorities. All information provided in this document is subject to legal disclaimers. Rev. 2 — 1 September 2015 © Ampleon The Netherlands B.V. 2015. All rights reserved. 12 of 14 BLF3G22-30 UHF power LDMOS transistor Non-automotive qualified products — Unless this data sheet expressly states that this specific Ampleon product is automotive qualified, the product is not suitable for automotive use. It is neither qualified nor tested in accordance with automotive testing or application requirements. Ampleon accepts no liability for inclusion and/or use of non-automotive qualified products in automotive equipment or applications. In the event that customer uses the product for design-in and use in automotive applications to automotive specifications and standards, customer (a) shall use the product without Ampleon’ warranty of the product for such automotive applications, use and specifications, and (b) whenever customer uses the product for automotive applications beyond Ampleon’ specifications such use shall be solely at customer’s own risk, and (c) customer fully indemnifies Ampleon for any liability, damages or failed product claims resulting from customer design and use of the product for automotive applications beyond Ampleon’ standard warranty and Ampleon’ product specifications. 12.4 Trademarks Notice: All referenced brands, product names, service names and trademarks are the property of their respective owners. Any reference or use of any ‘NXP’ trademark in this document or in or on the surface of Ampleon products does not result in any claim, liability or entitlement vis-à-vis the owner of this trademark. Ampleon is no longer part of the NXP group of companies and any reference to or use of the ‘NXP’ trademarks will be replaced by reference to or use of Ampleon’s own Any reference or use of any ‘NXP’ trademark in this document or in or on the surface of Ampleon products does not result in any claim, liability or entitlement vis-à-vis the owner of this trademark. Ampleon is no longer part of the NXP group of companies and any reference to or use of the ‘NXP’ trademarks will be replaced by reference to or use of Ampleon’s own trademarks. Translations — A non-English (translated) version of a document is for reference only. The English version shall prevail in case of any discrepancy between the translated and English versions. 13. Contact information For more information, please visit: http://www.ampleon.com BLF3G22-30#2 Product data sheet For sales office addresses, please visit: http://www.ampleon.com/sales All information provided in this document is subject to legal disclaimers. Rev. 2 — 1 September 2015 © Ampleon The Netherlands B.V. 2015. All rights reserved. 13 of 14 BLF3G22-30 UHF power LDMOS transistor 14. Contents 1 1.1 1.2 1.3 2 3 4 5 6 7 7.1 7.2 7.3 7.4 7.5 8 9 10 11 12 12.1 12.2 12.3 12.4 13 14 Product profile . . . . . . . . . . . . . . . . . . . . . . . . . . 1 General description . . . . . . . . . . . . . . . . . . . . . 1 Features . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 1 Applications . . . . . . . . . . . . . . . . . . . . . . . . . . . 2 Pinning information . . . . . . . . . . . . . . . . . . . . . . 2 Ordering information . . . . . . . . . . . . . . . . . . . . . 2 Limiting values. . . . . . . . . . . . . . . . . . . . . . . . . . 2 Thermal characteristics . . . . . . . . . . . . . . . . . . 3 Characteristics . . . . . . . . . . . . . . . . . . . . . . . . . . 3 Application information. . . . . . . . . . . . . . . . . . . 3 Ruggedness in class-AB operation . . . . . . . . . 4 One-tone. . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 4 Two-tone . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 4 Two-carrier W-CDMA . . . . . . . . . . . . . . . . . . . . 6 Input impedance and load impedances  measured under CW conditions . . . . . . . . . . . . 6 Test information . . . . . . . . . . . . . . . . . . . . . . . . . 7 Package outline . . . . . . . . . . . . . . . . . . . . . . . . 10 Abbreviations . . . . . . . . . . . . . . . . . . . . . . . . . . 11 Revision history . . . . . . . . . . . . . . . . . . . . . . . . 11 Legal information. . . . . . . . . . . . . . . . . . . . . . . 12 Data sheet status . . . . . . . . . . . . . . . . . . . . . . 12 Definitions . . . . . . . . . . . . . . . . . . . . . . . . . . . . 12 Disclaimers . . . . . . . . . . . . . . . . . . . . . . . . . . . 12 Trademarks. . . . . . . . . . . . . . . . . . . . . . . . . . . 13 Contact information. . . . . . . . . . . . . . . . . . . . . 13 Contents . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 14 Please be aware that important notices concerning this document and the product(s) described herein, have been included in section ‘Legal information’. © Ampleon The Netherlands B.V. 2015. All rights reserved. For more information, please visit: http://www.ampleon.com For sales office addresses, please visit: http://www.ampleon.com/sales Date of release: 1 September 2015 Document identifier: BLF3G22-30#2
BLF3G22-30,135 价格&库存
很抱歉,暂时无法提供与“BLF3G22-30,135”相匹配的价格&库存,您可以联系我们找货
