BLS2933-100,112
BLS2933-100,112
    AMPLEON(安谱隆)
    SOT502A
    TRANS MICRO PWR LDMOS SOT502A
BLS2933-100,112 数据手册
BLS2933-100 Microwave power LDMOS transistor Rev. 2 — 1 September 2015 Product data sheet 1. Product profile 1.1 General description 100 W LDMOS power transistor (at a supply voltage of 32 V) for S-band radar applications in the 2.9 GHz to 3.3 GHz frequency range. Table 1: Typical performance tp = 200 s;  = 12 %; Tcase = 25 C; in a class-AB production test circuit. Mode of operation class AB f VDS PL Gp D IDq (GHz) (V) (W) (dB) (%) (mA) 2.9 to 3.3 32 100 8 40 20 CAUTION This device is sensitive to ElectroStatic Discharge (ESD). Therefore care should be taken during transport and handling. 1.2 Features       Easy power control Integrated ESD protection Excellent ruggedness Excellent thermal stability Designed for broadband operation (2.9 GHz to 3.3 GHz) Internally matched for ease of use 1.3 Applications  S-band radar applications BLS2933-100 Microwave power LDMOS transistor 2. Pinning information Table 2. Pinning Pin Description 1 drain 2 gate 3 source Simplified outline Symbol 1 1 3 [1] 2 2 3 sym112 [1] connected to flange 3. Ordering information Table 3. Ordering information Type number Package Name Description Version BLS2933-100 - flanged LDMOST ceramic package; 2 mounting holes; 2 leads SOT502A 4. Limiting values Table 4. Limiting values In accordance with the Absolute Maximum Rating System (IEC 60134). Symbol Parameter Min Max Unit VDS drain-source voltage Conditions - 65 V VGS gate-source voltage - 15 V ID drain current - 12 A Tstg storage temperature 65 150 C Tj junction temperature - 200 C 5. Thermal characteristics Table 5. BLS2933-100#2 Product data sheet Thermal characteristics Symbol Parameter Conditions Zth(j-h) transient thermal impedance from Th = 25 C; junction to heatsink tp = 200 s;  = 12 % All information provided in this document is subject to legal disclaimers. Rev. 2 — 1 September 2015 Typ Unit 0.4 K/W © Ampleon The Netherlands B.V. 2015. All rights reserved. 2 of 13 BLS2933-100 Microwave power LDMOS transistor 6. Characteristics Table 6. Characteristics Tj = 25 C unless otherwise specified. Symbol Parameter Conditions Min Typ Max Unit V(BR)DSS drain-source breakdown voltage VGS = 0 V; ID = 2.1 mA 65 - - V VGS(th) gate-source threshold voltage VDS = 10 V; ID = 180 mA 2.5 3.1 3.5 V VGSq gate-source quiescent voltage VDS = 28 V; IDS = 900 mA - 3.3 4.5 V IDSS drain leakage current VGS = 0 V; VDS = 28 V - - 2 A IDSX drain cut-off current VGS = VGS(th) + 9 V; VDS = 10 V 27 30 - A IGSS gate leakage current VGS = 15 V; VDS = 0 V - - 200 nA gfs forward transconductance VDS = 10 V; ID = 10 A - 9.0 - S RDS(on) drain-source on-state resistance VGS = VGS(th) + 6 V; ID = 6 A - 0.09 -  Crs feedback capacitance VGS = 0 V; VDS = 28 V; f = 1 MHz - 2.5 - pF 7. Application information Table 7. Application information RF performance in common source class-AB circuit; Th = 25 C; tp = 200 s;  = 12 %; Zth(mb-h) = 0.15 K/W; unless otherwise specified. BLS2933-100#2 Product data sheet Symbol Parameter foper Conditions Min Typ Max Unit operating frequency 2.9 - 3.3 GHz VCC supply voltage - - 32 V tp pulse duration - 200 - s  duty cycle - 12 - % PL output power 100 - - W PL(1dB) output power at 1 dB gain compression - 120 - W Gp power gain 6 8 - dB D drain efficiency 33 40 - % Pdroop(pulse) pulse droop power - 0.1 0.5 dB tr rise time - 20 50 ns tf fall time - 6 50 ns VSWRload load voltage standing wave ratio 10 : 1 - - IRL input return loss - 10 - All information provided in this document is subject to legal disclaimers. Rev. 2 — 1 September 2015 dB © Ampleon The Netherlands B.V. 2015. All rights reserved. 3 of 13 BLS2933-100 Microwave power LDMOS transistor Table 8. f Typical impedance ZS ZL GHz   2.9 3.3  j5.6 3.5  j3.3 3.0 3.7  j5.3 3.1  j3.6 3.1 5.9  j5.8 3.3  j3.3 3.2 6.8  j3.4 3.2  j3.5 3.3 6.6  j2.7 3.1  j3.6 drain ZL gate ZS 001aaf059 Fig 1. Definition of transistor impedance 7.1 Ruggedness in class-AB operation The BLS2933-100 is capable of withstanding a load mismatch corresponding to VSWR > 10 : 1 through all phases under the following conditions: VDS = 32 V; IDq = 20 mA; PL = 100 W pulsed, tp = 200 s;  = 12 %. BLS2933-100#2 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 2 — 1 September 2015 © Ampleon The Netherlands B.V. 2015. All rights reserved. 4 of 13 BLS2933-100 Microwave power LDMOS transistor 001aaf066 10 50 ηD (%) Gp (dB) ηD 8 001aaf070 10 Gp (dB) 40 (1) (2) (3) 8 Gp (4) (5) 6 30 6 4 20 4 2 10 2 0 2.8 3.0 0 0 3.4 3.2 0 40 80 120 f (GHz) 160 PL (W) VDS = 32 V; IDq = 20 mA; tp = 200 s;  = 12 %; PL = 100 W. (1) f = 2.9 MHz. (2) f = 3.0 MHz. (3) f = 3.1 MHz. (4) f = 3.2 MHz. (5) f = 3.3 MHz. VDS = 32 V; IDq = 20 mA; tp = 200 s;  = 12 %. Fig 2. Power gain and drain efficiency as functions of frequency; typical values 001aaf071 50 (1) (2) (3) (4) (5) ηD (%) 40 Fig 3. Power gain as a function of load power; typical values 001aaf072 160 PL (W) (1) (2) (3) (4) (5) 120 30 80 20 40 10 0 0 0 40 80 120 160 0 PL (W) (1) f = 2.9 MHz. (2) f = 3.0 MHz. (2) f = 3.0 MHz. (3) f = 3.1 MHz. (3) f = 3.1 MHz. (4) f = 3.2 MHz. (4) f = 3.2 MHz. (5) f = 3.3 MHz. (5) f = 3.3 MHz. VDS = 32 V; IDq = 20 mA; tp = 200 s;  = 12 %. Fig 4. Efficiency as a function of power load; typical values Product data sheet 20 30 Pi (W) (1) f = 2.9 MHz. BLS2933-100#2 10 VDS = 32 V; IDq = 20 mA; tp = 200 s;  = 12 %. Fig 5. Load power as a function of input power; typical values All information provided in this document is subject to legal disclaimers. Rev. 2 — 1 September 2015 © Ampleon The Netherlands B.V. 2015. All rights reserved. 5 of 13 BLS2933-100 Microwave power LDMOS transistor 001aaf073 12 001aaf074 10 Gp (dB) Gp (dB) 10 (1) (2) (3) 8 (3) (2) (1) 8 6 2.8 6 3.0 3.2 4 2.8 3.4 3.0 f (GHz) 3.2 3.4 f (GHz) (1) IDq = 20 mA. (1) tp = 100 s. (2) IDq = 150 mA. (2) tp = 300 s. (3) IDq = 500 mA. (3) tp = 500 s. VDS = 32 V; IDq = 20 mA; tp = 200 s;  = 12 %; PL = 100 W. VDS = 32 V; IDq = 20 mA; tp = 100 s, 200 s and 500 s;  = 10 %; PL = 100 W. Fig 6. Power gain as a function of frequency and IDq; typical values Fig 7. Power gain as a function of frequency; typical values 001aaf081 50 ηD (%) 45 (1) (2) (3) 40 35 2.8 3.0 3.2 3.4 f (GHz) (1) tp = 100 s. (2) tp = 300 s. (3) tp = 500 s. VDS = 32 V; IDq = 20 mA;  = 10 %; PL = 100 W. Fig 8. Efficiency as a function of frequency; typical values BLS2933-100#2 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 2 — 1 September 2015 © Ampleon The Netherlands B.V. 2015. All rights reserved. 6 of 13 BLS2933-100 Microwave power LDMOS transistor 001aaf082 1.0 Zth (K/W) 0.8 0.6 0.4 (1) (2) (3) (4) (5) 0.2 0 10−5 10−4 10−3 10−2 tp (s) (1) 1 % duty cycle (2) 2 % duty cycle (3) 5 % duty cycle (4) 10 % duty cycle (5) 20 % duty cycle Fig 9. Thermal resistance as function of pulse duration and duty cycle; typical values 001aaf083 800 Pmax (W) (1) (2) (3) (4) 600 400 200 0 10−5 10−4 10−3 10−2 tp (s) Th = 70 C (1) 1 % duty cycle (2) 2 % duty cycle (3) 10 % duty cycle (4) 20 % duty cycle Fig 10. Maximum allowable dissipated power as function of pulse duration and duty cycle for reaching 200 C junction temperature BLS2933-100#2 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 2 — 1 September 2015 © Ampleon The Netherlands B.V. 2015. All rights reserved. 7 of 13 BLS2933-100 Microwave power LDMOS transistor 8. Test information C3 C2 C4 C5 C6 +Vgs +Vds C7 C8 C9 R1 C12 C11 R2 L1 C1 C10 BLS2933-100 in BLS2933-100 out 001aaf084 The components are situated on one side of the copper-clad Duroid 6006 Printed-Circuit Board (PCB). Both the input and output PCB are 40 mm  60 mm with r = 6.15 and thickness 0.64 mm. See Table 9 for list of components Fig 11. Component layout for test circuit Table 9. List of components (see Figure 11) Component Description Value C1, C2, C4, C5, multilayer ceramic chip capacitor C6, C7, C10 [1] 22 pF C3, C8, C9 multilayer ceramic chip capacitor [2] 470 pF C11 tantalum capacitor 4.7 F; 50 V Dimensions Catalogue number Kemet T491D475K050AS C12 electrolytic capacitor 220 F; 63 V R1 resistor 560  R2 metafilm resistor 49.9 ; 0.6 W L1 copper wire 1 mm diameter N1 N-connector male Suhner 13N-50-057/1 N2 N-connector female Suhner 23N-50-057/1 length of loop = 20 mm; height of loop = 10 mm [1] American Technical Ceramics type 100A or capacitor of same quality. [2] American Technical Ceramics type 100B or capacitor of same quality. BLS2933-100#2 Product data sheet SMD 0805 All information provided in this document is subject to legal disclaimers. Rev. 2 — 1 September 2015 © Ampleon The Netherlands B.V. 2015. All rights reserved. 8 of 13 BLS2933-100 Microwave power LDMOS transistor 9. Package outline Flanged ceramic package; 2 mounting holes; 2 leads SOT502A D A F 3 D1 U1 B q c C 1 H L E1 p U2 E w1 M A M B M A 2 w2 M C M b 0 5 Q 10 mm scale DIMENSIONS (millimetre dimensions are derived from the original inch dimensions) UNIT A b c mm 4.72 3.43 12.83 12.57 0.15 0.08 inches 0.186 0.135 0.505 0.006 0.495 0.003 OUTLINE VERSION E E1 F H L p Q q U1 U2 w1 w2 20.02 19.96 19.61 19.66 9.50 9.30 9.53 9.25 1.14 0.89 19.94 18.92 5.33 4.32 3.38 3.12 1.70 1.45 27.94 34.16 33.91 9.91 9.65 0.25 0.51 0.788 0.786 0.772 0.774 0.374 0.375 0.366 0.364 0.067 1.100 0.057 1.345 1.335 0.390 0.380 0.01 0.02 D D1 0.045 0.785 0.035 0.745 0.210 0.133 0.170 0.123 REFERENCES IEC JEDEC JEITA EUROPEAN PROJECTION ISSUE DATE 03-01-10 12-05-02 SOT502A Fig 12. Package outline SOT502A BLS2933-100#2 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 2 — 1 September 2015 © Ampleon The Netherlands B.V. 2015. All rights reserved. 9 of 13 BLS2933-100 Microwave power LDMOS transistor 10. Revision history Table 10. Revision history Document ID Release date Data sheet status Change notice Supersedes BLS2933-100#2 20150901 Product data sheet - BLS2933-100_1 Modifications: BLS2933-100_1 BLS2933-100#2 Product data sheet • The format of this document has been redesigned to comply with the new identity guidelines of Ampleon. • Legal texts have been adapted to the new company name where appropriate. 20060801 Product data sheet - All information provided in this document is subject to legal disclaimers. Rev. 2 — 1 September 2015 - © Ampleon The Netherlands B.V. 2015. All rights reserved. 10 of 13 BLS2933-100 Microwave power LDMOS transistor 11. Legal information 11.1 Data sheet status Document status[1][2] Product status[3] Objective [short] data sheet Development This document contains data from the objective specification for product development. Preliminary [short] data sheet Qualification This document contains data from the preliminary specification. Product [short] data sheet Production This document contains the product specification. Definition [1] Please consult the most recently issued document before initiating or completing a design. [2] The term ‘short data sheet’ is explained in section “Definitions”. [3] The product status of device(s) described in this document may have changed since this document was published and may differ in case of multiple devices. The latest product status information is available on the Internet at URL http://www.ampleon.com. 11.2 Definitions Draft — The document is a draft version only. The content is still under internal review and subject to formal approval, which may result in modifications or additions. Ampleon does not give any representations or warranties as to the accuracy or completeness of information included herein and shall have no liability for the consequences of use of such information. Short data sheet — A short data sheet is an extract from a full data sheet with the same product type number(s) and title. A short data sheet is intended for quick reference only and should not be relied upon to contain detailed and full information. For detailed and full information see the relevant full data sheet, which is available on request via the local Ampleon sales office. In case of any inconsistency or conflict with the short data sheet, the full data sheet shall prevail. Product specification — The information and data provided in a Product data sheet shall define the specification of the product as agreed between Ampleon and its customer, unless Ampleon and customer have explicitly agreed otherwise in writing. In no event however, shall an agreement be valid in which the Ampleon product is deemed to offer functions and qualities beyond those described in the Product data sheet. 11.3 Disclaimers Limited warranty and liability — Information in this document is believed to be accurate and reliable. However, Ampleon does not give any representations or warranties, expressed or implied, as to the accuracy or completeness of such information and shall have no liability for the consequences of use of such information. Ampleon takes no responsibility for the content in this document if provided by an information source outside of Ampleon. In no event shall Ampleon be liable for any indirect, incidental, punitive, special or consequential damages (including - without limitation - lost profits, lost savings, business interruption, costs related to the removal or replacement of any products or rework charges) whether or not such damages are based on tort (including negligence), warranty, breach of contract or any other legal theory. Notwithstanding any damages that customer might incur for any reason whatsoever, Ampleon’ aggregate and cumulative liability towards customer for the products described herein shall be limited in accordance with the Terms and conditions of commercial sale of Ampleon. Right to make changes — Ampleon reserves the right to make changes to information published in this document, including without limitation specifications and product descriptions, at any time and without notice. This document supersedes and replaces all information supplied prior to the publication hereof. Suitability for use — Ampleon products are not designed, authorized or warranted to be suitable for use in life support, life-critical or safety-critical systems or equipment, nor in applications where failure or malfunction of an BLS2933-100#2 Product data sheet Ampleon product can reasonably be expected to result in personal injury, death or severe property or environmental damage. Ampleon and its suppliers accept no liability for inclusion and/or use of Ampleon products in such equipment or applications and therefore such inclusion and/or use is at the customer’s own risk. Applications — Applications that are described herein for any of these products are for illustrative purposes only. Ampleon makes no representation or warranty that such applications will be suitable for the specified use without further testing or modification. Customers are responsible for the design and operation of their applications and products using Ampleon products, and Ampleon accepts no liability for any assistance with applications or customer product design. It is customer’s sole responsibility to determine whether the Ampleon product is suitable and fit for the customer’s applications and products planned, as well as for the planned application and use of customer’s third party customer(s). Customers should provide appropriate design and operating safeguards to minimize the risks associated with their applications and products. Ampleon does not accept any liability related to any default, damage, costs or problem which is based on any weakness or default in the customer’s applications or products, or the application or use by customer’s third party customer(s). Customer is responsible for doing all necessary testing for the customer’s applications and products using Ampleon products in order to avoid a default of the applications and the products or of the application or use by customer’s third party customer(s). Ampleon does not accept any liability in this respect. Limiting values — Stress above one or more limiting values (as defined in the Absolute Maximum Ratings System of IEC 60134) will cause permanent damage to the device. Limiting values are stress ratings only and (proper) operation of the device at these or any other conditions above those given in the Recommended operating conditions section (if present) or the Characteristics sections of this document is not warranted. Constant or repeated exposure to limiting values will permanently and irreversibly affect the quality and reliability of the device. Terms and conditions of commercial sale — Ampleon products are sold subject to the general terms and conditions of commercial sale, as published at http://www.ampleon.com/terms, unless otherwise agreed in a valid written individual agreement. In case an individual agreement is concluded only the terms and conditions of the respective agreement shall apply. Ampleon hereby expressly objects to applying the customer’s general terms and conditions with regard to the purchase of Ampleon products by customer. No offer to sell or license — Nothing in this document may be interpreted or construed as an offer to sell products that is open for acceptance or the grant, conveyance or implication of any license under any copyrights, patents or other industrial or intellectual property rights. Export control — This document as well as the item(s) described herein may be subject to export control regulations. Export might require a prior authorization from competent authorities. All information provided in this document is subject to legal disclaimers. Rev. 2 — 1 September 2015 © Ampleon The Netherlands B.V. 2015. All rights reserved. 11 of 13 BLS2933-100 Microwave power LDMOS transistor Non-automotive qualified products — Unless this data sheet expressly states that this specific Ampleon product is automotive qualified, the product is not suitable for automotive use. It is neither qualified nor tested in accordance with automotive testing or application requirements. Ampleon accepts no liability for inclusion and/or use of non-automotive qualified products in automotive equipment or applications. In the event that customer uses the product for design-in and use in automotive applications to automotive specifications and standards, customer (a) shall use the product without Ampleon’ warranty of the product for such automotive applications, use and specifications, and (b) whenever customer uses the product for automotive applications beyond Ampleon’ specifications such use shall be solely at customer’s own risk, and (c) customer fully indemnifies Ampleon for any liability, damages or failed product claims resulting from customer design and use of the product for automotive applications beyond Ampleon’ standard warranty and Ampleon’ product specifications. 11.4 Trademarks Notice: All referenced brands, product names, service names and trademarks are the property of their respective owners. Any reference or use of any ‘NXP’ trademark in this document or in or on the surface of Ampleon products does not result in any claim, liability or entitlement vis-à-vis the owner of this trademark. Ampleon is no longer part of the NXP group of companies and any reference to or use of the ‘NXP’ trademarks will be replaced by reference to or use of Ampleon’s own Any reference or use of any ‘NXP’ trademark in this document or in or on the surface of Ampleon products does not result in any claim, liability or entitlement vis-à-vis the owner of this trademark. Ampleon is no longer part of the NXP group of companies and any reference to or use of the ‘NXP’ trademarks will be replaced by reference to or use of Ampleon’s own trademarks. 12. Contact information For more information, please visit: http://www.ampleon.com BLS2933-100#2 Product data sheet For sales office addresses, please visit: http://www.ampleon.com/sales All information provided in this document is subject to legal disclaimers. Rev. 2 — 1 September 2015 © Ampleon The Netherlands B.V. 2015. All rights reserved. 12 of 13 BLS2933-100 Microwave power LDMOS transistor 13. Contents 1 1.1 1.2 1.3 2 3 4 5 6 7 7.1 8 9 10 11 11.1 11.2 11.3 11.4 12 13 Product profile . . . . . . . . . . . . . . . . . . . . . . . . . . 1 General description . . . . . . . . . . . . . . . . . . . . . 1 Features . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 1 Applications . . . . . . . . . . . . . . . . . . . . . . . . . . . 1 Pinning information . . . . . . . . . . . . . . . . . . . . . . 2 Ordering information . . . . . . . . . . . . . . . . . . . . . 2 Limiting values. . . . . . . . . . . . . . . . . . . . . . . . . . 2 Thermal characteristics . . . . . . . . . . . . . . . . . . 2 Characteristics . . . . . . . . . . . . . . . . . . . . . . . . . . 3 Application information. . . . . . . . . . . . . . . . . . . 3 Ruggedness in class-AB operation . . . . . . . . . 4 Test information . . . . . . . . . . . . . . . . . . . . . . . . . 8 Package outline . . . . . . . . . . . . . . . . . . . . . . . . . 9 Revision history . . . . . . . . . . . . . . . . . . . . . . . . 10 Legal information. . . . . . . . . . . . . . . . . . . . . . . 11 Data sheet status . . . . . . . . . . . . . . . . . . . . . . 11 Definitions . . . . . . . . . . . . . . . . . . . . . . . . . . . . 11 Disclaimers . . . . . . . . . . . . . . . . . . . . . . . . . . . 11 Trademarks. . . . . . . . . . . . . . . . . . . . . . . . . . . 12 Contact information. . . . . . . . . . . . . . . . . . . . . 12 Contents . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 13 Please be aware that important notices concerning this document and the product(s) described herein, have been included in section ‘Legal information’. © Ampleon The Netherlands B.V. 2015. All rights reserved. For more information, please visit: http://www.ampleon.com  For sales office addresses, please visit: http://www.ampleon.com/sales Date of release: 1 September 2015 Document identifier: BLS2933-100#2
BLS2933-100,112 价格&库存
很抱歉,暂时无法提供与“BLS2933-100,112”相匹配的价格&库存,您可以联系我们找货
