BLF6G20-180RN,112
BLF6G20-180RN,112
    AMPLEON(安谱隆)
    SOT502A
    TRANSISTOR PWR LDMOS SOT502A
BLF6G20-180RN,112 数据手册
BLF6G20-180RN; BLF6G20LS-180RN Power LDMOS transistor Rev. 2 — 1 September 2015 Product data sheet 1. Product profile 1.1 General description 180 W LDMOS power transistor for base station applications at frequencies from 1800 MHz to 2000 MHz. Table 1. Typical performance Typical RF performance at Tcase = 25 C in a class-AB production test circuit. Mode of operation 2-carrier WCDMA [1] f VDS PL(AV) Gp D IMD3 ACPR (MHz) (V) (W) (dB) (%) (dBc) (dBc) 1930 to 1990 30 40 17.2 27 38[1] 41[1] Test signal: 3GPP; test model 1; 64 DPCH; PAR = 7 dB at 0.01 % probability on CCDF per carrier; carrier spacing 10 MHz. CAUTION This device is sensitive to ElectroStatic Discharge (ESD). Therefore care should be taken during transport and handling. 1.2 Features  Typical 2-carrier WCDMA performance at frequencies of 1930 MHz and 1990 MHz, a supply voltage of 30 V and an IDq of 1400 mA:  Average output power = 40 W  Power gain = 17.2 dB  Efficiency = 27 %  IMD3 = 41 dBc  ACPR = 38 dBc  Easy power control  Integrated ESD protection  Enhanced ruggedness  High efficiency  Excellent thermal stability  Designed for broadband operation (1800 MHz to 2000 MHz)  Internally matched for ease of use BLF6G20(LS)-180RN Power LDMOS transistor  Compliant to Directive 2002/95/EC, regarding Restriction of Hazardous Substances (RoHS) 1.3 Applications  RF power amplifiers for GSM, GSM EDGE, W-CDMA and CDMA base stations and multi carrier applications in the 1800 MHz to 2000 MHz frequency range 2. Pinning information Table 2. Pinning Pin Description Simplified outline Graphic symbol BLF6G20-180RN (SOT502A) 1 drain 2 gate 3 source 1 1 3 [1] 2 2 3 sym112 BLF6G20LS-180RN (SOT502B) 1 drain 2 gate 3 source 1 1 3 [1] 2 2 3 sym112 [1] Connected to flange. 3. Ordering information Table 3. Ordering information Type number Package BLF6G20-180RN - Name Description BLF6G20LS-180RN - Version flanged LDMOST ceramic package; 2 mounting holes; 2 leads SOT502A earless flanged LDMOST ceramic package; 2 leads SOT502B 4. Limiting values Table 4. Limiting values In accordance with the Absolute Maximum Rating System (IEC 60134). BLF6G20-180RN_20LS-180RN#2 Product data sheet Symbol Parameter VDS Conditions Min Max Unit drain-source voltage - 65 V VGS gate-source voltage 0.5 +13 V ID drain current - 49 A Tstg storage temperature 65 +150 C Tj junction temperature - 225 C All information provided in this document is subject to legal disclaimers. Rev. 2 — 1 September 2015 © Ampleon The Netherlands B.V. 2015. All rights reserved. 2 of 13 BLF6G20(LS)-180RN Power LDMOS transistor 5. Thermal characteristics Table 5. Thermal characteristics Symbol Parameter Conditions Type Typ Unit Rth(j-case) thermal resistance from junction to case Tcase = 80 C; PL = 40 W BLF6G20-180RN 0.50 K/W BLF6G20LS-180RN 0.37 K/W 6. Characteristics Table 6. Characteristics Tj = 25 C unless otherwise specified. Symbol Parameter Conditions Min Typ Max Unit V(BR)DSS drain-source breakdown voltage VGS = 0 V; ID = 0.9 mA 65 - - V VGS(th) gate-source threshold voltage VDS = 10 V; ID = 270 mA 1.4 2.0 2.4 V VGSq gate-source quiescent voltage VDS = 28 V; ID = 1.62 A 1.5 2.0 2.5 V IDSS drain leakage current VGS = 0 V; VDS = 28 V - - 5 A IDSX drain cut-off current VGS = VGS(th) + 3.75 V; VDS = 10 V 40 45 - A IGSS gate leakage current VGS = 13 V; VDS = 0 V - - 450 nA gfs forward transconductance VDS = 10 V; ID = 13.5 A - 19.5 - S RDS(on) drain-source on-state resistance VGS = VGS(th) + 3.75 V; ID = 9.45 A - 0.06 -  Crs feedback capacitance VGS = 0 V; VDS = 30 V; f = 1 MHz - 3.3 - pF 7. Application information Table 7. Application information Mode of operation: 2-carrier WCDMA; PAR = 7 dB at 0.01 % probability on the CCDF; f1 = 1932.5 MHz; f2 = 1942.5 MHz; f3 = 1977.5 MHz; f4 = 1987.5 MHz; RF performance at VDS = 30 V; IDq = 1400 mA; Tcase = 25 C; unless otherwise specified; in a class-AB production test circuit. Symbol Parameter PL(AV) average output power Conditions Gp power gain RLin input return loss Min Typ Max Unit - 40 - W PL(AV) = 40 W 16.3 17.2 - dB PL(AV) = 40 W - 15 10 dB D drain efficiency PL(AV) = 40 W 24 27 - % IMD3 third order intermodulation distortion PL(AV) = 40 W - 38 35 dBc ACPR adjacent channel power ratio PL(AV) = 40 W - 41 39 dBc 7.1 Ruggedness in class-AB operation The BLF6G20-180RN and BLF6G20LS-180RN are capable of withstanding a load mismatch corresponding to VSWR = 10 : 1 through all phases under the following conditions: VDS = 30 V; IDq = 1400 mA; PL = 180 W (CW); f = 1990 MHz. BLF6G20-180RN_20LS-180RN#2 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 2 — 1 September 2015 © Ampleon The Netherlands B.V. 2015. All rights reserved. 3 of 13 BLF6G20(LS)-180RN Power LDMOS transistor 7.2 One-tone CW 001aai651 19 50 ηD (%) Gp (dB) 18 40 Gp 30 17 ηD 16 20 15 10 14 0 60 10 180 120 PL (W) VDS = 30 V; IDq = 1400 mA; f = 1960 MHz. Fig 1. One-tone CW power gain and drain efficiency as function of load power; typical values 7.3 Two-tone CW 001aai652 19 50 ηD (%) Gp (dB) 40 18 Gp 001aai653 −20 IMD (dBc) IMD3 −30 30 17 IMD5 −40 ηD 20 16 IMD7 −50 10 15 14 0 60 10 180 120 −60 0 PL(PEP) (W) Product data sheet 180 VDS = 30 V; IDq = 1400 mA; f = 1960 MHz. Two-tone CW power gain and drain efficiency as function of peak envelope load power; typical values BLF6G20-180RN_20LS-180RN#2 120 PL(PEP) (W) VDS = 30 V; IDq = 1400 mA; f = 1960 MHz. Fig 2. 60 Fig 3. Two-tone CW intermodulation distortion as a function of peak envelope load power; typical values All information provided in this document is subject to legal disclaimers. Rev. 2 — 1 September 2015 © Ampleon The Netherlands B.V. 2015. All rights reserved. 4 of 13 BLF6G20(LS)-180RN Power LDMOS transistor 7.4 2-carrier W-CDMA 001aai654 19 ηD (%) Gp (dB) 18 001aai655 −30 IMD, ACPR (dBc) −35 40 IMD3 30 −40 Gp −45 17 ACPR 20 ηD −50 16 −55 10 0 20 40 60 0 20 40 60 PL(AV) (W) PL(AV) (W) VDS = 30 V; IDq = 1400 mA; f = 1960 MHz (5 MHz); carrier spacing 10 MHz. Fig 4. VDS = 30 V; IDq = 1400 mA; f = 1960 MHz (5 MHz); carrier spacing 10 MHz. 2-carrier W-CDMA power gain and drain efficiency as function of average load power; typical values Fig 5. 2-carrier W-CDMA adjacent channel power ratio and third order intermodulation distortion as function of average load power; typical values 8. Test information VDD R2 VGG C25 C8 C11 C7 R1 C6 C9 C2 C16 C17 C18 C21 C23 C5 C1 input C12 C13 C4 C14 output C3 C10 C15 C19 C20 C22 C24 001aai656 The drawing is not to scale. Fig 6. BLF6G20-180RN_20LS-180RN#2 Product data sheet Test circuit for operation at 2000 MHz All information provided in this document is subject to legal disclaimers. Rev. 2 — 1 September 2015 © Ampleon The Netherlands B.V. 2015. All rights reserved. 5 of 13 BLF6G20(LS)-180RN Power LDMOS transistor R2 C11 C17 C21 C8 C7 C6 C5 C25 C9 C16 C18 C23 R1 C2 C4 C12 C1 C3 C13 C14 C15 C20 C24 C19 C22 C10 001aai657 The striplines are on a double copper-clad Taconic RF35 Printed-Circuit Board (PCB) with r = 3.5 and thickness = 0.76 mm. See Table 8 for list of components. The drawing is not to scale. Fig 7. Component layout Table 8. List of components (see Figure 6 and Figure 7) The Printed-Circuit Board (PCB) used is a double copper-clad Taconic RF35 with r = 3.5 and thickness = 0.76 mm. Component Description Value C1 multilayer ceramic chip capacitor 1.9 pF [1] ATC 100B or capacitor of same quality 2.0 pF [1] ATC 100B or capacitor of same quality 0.6 pF [1] ATC 100B or capacitor of same quality ATC 100B or capacitor of same quality ATC 100B or capacitor of same quality C2 C3 multilayer ceramic chip capacitor multilayer ceramic chip capacitor Remarks C4 multilayer ceramic chip capacitor 1.8 pF [1] C5, C12, C15, C16 multilayer ceramic chip capacitor 11 pF [1] C6, C7, C17, C18, C19, C20 multilayer ceramic chip capacitor 220 nF C8 multilayer ceramic chip capacitor 100 nF C9, C10 multilayer ceramic chip capacitor 12 pF C11 multilayer ceramic chip capacitor 10 F C13 multilayer ceramic chip capacitor ATC 100B or capacitor of same quality 1.0 pF [1] ATC 100B or capacitor of same quality [1] ATC 100B or capacitor of same quality multilayer ceramic chip capacitor 0.3 pF C21, C22 multilayer ceramic chip capacitor 1.5 F C23, C24 multilayer ceramic chip capacitor 10 F; 50 V C25 electrolytic capacitor 220 F; 63 V Product data sheet Vishay or capacitor of same quality [1] C14 BLF6G20-180RN_20LS-180RN#2 Vishay or capacitor of same quality TDK or capacitor of same quality All information provided in this document is subject to legal disclaimers. Rev. 2 — 1 September 2015 © Ampleon The Netherlands B.V. 2015. All rights reserved. 6 of 13 BLF6G20(LS)-180RN Power LDMOS transistor Table 8. List of components (see Figure 6 and Figure 7) …continued The Printed-Circuit Board (PCB) used is a double copper-clad Taconic RF35 with r = 3.5 and thickness = 0.76 mm. Component Description Value Remarks L1 ferrite SMD bead - Ferroxcube BDS 3/3/4.6-4S2 or equivalent R1 SMD resistor 2.7  R2 SMD resistor 6.8  [1] Solder vertically. BLF6G20-180RN_20LS-180RN#2 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 2 — 1 September 2015 © Ampleon The Netherlands B.V. 2015. All rights reserved. 7 of 13 BLF6G20(LS)-180RN Power LDMOS transistor 9. Package outline Flanged ceramic package; 2 mounting holes; 2 leads SOT502A D A F 3 D1 U1 B q c C 1 H L E1 p U2 E w1 M A M B M A 2 w2 M C M b 0 5 Q 10 mm scale DIMENSIONS (millimetre dimensions are derived from the original inch dimensions) UNIT A b c mm 4.72 3.43 12.83 12.57 0.15 0.08 inches 0.186 0.135 0.505 0.006 0.495 0.003 OUTLINE VERSION E E1 F H L p Q q U1 U2 w1 w2 20.02 19.96 19.61 19.66 9.50 9.30 9.53 9.25 1.14 0.89 19.94 18.92 5.33 4.32 3.38 3.12 1.70 1.45 27.94 34.16 33.91 9.91 9.65 0.25 0.51 0.788 0.786 0.772 0.774 0.374 0.375 0.366 0.364 0.067 1.100 0.057 1.345 1.335 0.390 0.380 0.01 0.02 D D1 0.045 0.785 0.035 0.745 0.210 0.133 0.170 0.123 REFERENCES IEC JEDEC JEITA ISSUE DATE 03-01-10 12-05-02 SOT502A Fig 8. EUROPEAN PROJECTION Package outline SOT502A BLF6G20-180RN_20LS-180RN#2 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 2 — 1 September 2015 © Ampleon The Netherlands B.V. 2015. All rights reserved. 8 of 13 BLF6G20(LS)-180RN Power LDMOS transistor Earless flanged ceramic package; 2 leads SOT502B D A F 3 D D1 c U1 1 L H E1 U2 E 2 w2 M D M b 0 5 Q 10 mm scale DIMENSIONS (millimetre dimensions are derived from the original inch dimensions) UNIT A b c mm 4.72 3.43 12.83 12.57 0.15 0.08 inches 0.186 0.135 0.505 0.006 0.495 0.003 OUTLINE VERSION E E1 F H L Q U1 U2 w2 20.02 19.96 19.61 19.66 9.50 9.30 9.53 9.25 1.14 0.89 19.94 18.92 5.33 4.32 1.70 1.45 20.70 20.45 9.91 9.65 0.25 0.788 0.786 0.772 0.774 0.374 0.375 0.366 0.364 0.045 0.785 0.035 0.745 0.210 0.170 0.067 0.815 0.057 0.805 D D1 REFERENCES IEC JEDEC JEITA EUROPEAN PROJECTION ISSUE DATE 07-05-09 12-05-02 SOT502B Fig 9. 0.390 0.010 0.380 Package outline SOT502B BLF6G20-180RN_20LS-180RN#2 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 2 — 1 September 2015 © Ampleon The Netherlands B.V. 2015. All rights reserved. 9 of 13 BLF6G20(LS)-180RN Power LDMOS transistor 10. Abbreviations Table 9. Abbreviations Acronym Description 3GPP Third Generation Partnership Project CCDF Complementary Cumulative Distribution Function CDMA Code Division Multiple Access CW Continuous Wave DPCH Dedicated Physical CHannel EDGE Enhanced Data rates for GSM Evolution GSM Global System for Mobile communications LDMOS Laterally Diffused Metal Oxide Semiconductor LDMOST Laterally Diffused Metal-Oxide Semiconductor Transistor PAR Peak-to-Average power Ratio PDPCH transmission Power of the Dedicated Physical CHannel RF Radio Frequency VSWR Voltage Standing Wave Ratio W-CDMA Wideband Code Division Multiple Access 11. Revision history Table 10. Revision history Document ID Release date Data sheet status Change notice Supersedes BLF6G20-180RN_20LS-180RN#2 20150901 Modifications: BLF6G20-180RN_20LS-180RN_1 BLF6G20-180RN_20LS-180RN#2 Product data sheet Product data sheet - BLF6G20-180RN_20LS-180RN _1 • The format of this document has been redesigned to comply with the new identity guidelines of Ampleon. • Legal texts have been adapted to the new company name where appropriate. 20081117 Product data sheet - All information provided in this document is subject to legal disclaimers. Rev. 2 — 1 September 2015 - © Ampleon The Netherlands B.V. 2015. All rights reserved. 10 of 13 BLF6G20(LS)-180RN Power LDMOS transistor 12. Legal information 12.1 Data sheet status Document status[1][2] Product status[3] Objective [short] data sheet Development This document contains data from the objective specification for product development. Preliminary [short] data sheet Qualification This document contains data from the preliminary specification. Product [short] data sheet Production This document contains the product specification. Definition [1] Please consult the most recently issued document before initiating or completing a design. [2] The term ‘short data sheet’ is explained in section “Definitions”. [3] The product status of device(s) described in this document may have changed since this document was published and may differ in case of multiple devices. The latest product status information is available on the Internet at URL http://www.ampleon.com. 12.2 Definitions Draft — The document is a draft version only. The content is still under internal review and subject to formal approval, which may result in modifications or additions. Ampleon does not give any representations or warranties as to the accuracy or completeness of information included herein and shall have no liability for the consequences of use of such information. Short data sheet — A short data sheet is an extract from a full data sheet with the same product type number(s) and title. A short data sheet is intended for quick reference only and should not be relied upon to contain detailed and full information. For detailed and full information see the relevant full data sheet, which is available on request via the local Ampleon sales office. In case of any inconsistency or conflict with the short data sheet, the full data sheet shall prevail. Product specification — The information and data provided in a Product data sheet shall define the specification of the product as agreed between Ampleon and its customer, unless Ampleon and customer have explicitly agreed otherwise in writing. In no event however, shall an agreement be valid in which the Ampleon product is deemed to offer functions and qualities beyond those described in the Product data sheet. 12.3 Disclaimers Limited warranty and liability — Information in this document is believed to be accurate and reliable. However, Ampleon does not give any representations or warranties, expressed or implied, as to the accuracy or completeness of such information and shall have no liability for the consequences of use of such information. Ampleon takes no responsibility for the content in this document if provided by an information source outside of Ampleon. In no event shall Ampleon be liable for any indirect, incidental, punitive, special or consequential damages (including - without limitation - lost profits, lost savings, business interruption, costs related to the removal or replacement of any products or rework charges) whether or not such damages are based on tort (including negligence), warranty, breach of contract or any other legal theory. Notwithstanding any damages that customer might incur for any reason whatsoever, Ampleon’ aggregate and cumulative liability towards customer for the products described herein shall be limited in accordance with the Terms and conditions of commercial sale of Ampleon. Right to make changes — Ampleon reserves the right to make changes to information published in this document, including without limitation specifications and product descriptions, at any time and without notice. This document supersedes and replaces all information supplied prior to the publication hereof. Suitability for use — Ampleon products are not designed, authorized or warranted to be suitable for use in life support, life-critical or safety-critical systems or equipment, nor in applications where failure or malfunction of an BLF6G20-180RN_20LS-180RN#2 Product data sheet Ampleon product can reasonably be expected to result in personal injury, death or severe property or environmental damage. Ampleon and its suppliers accept no liability for inclusion and/or use of Ampleon products in such equipment or applications and therefore such inclusion and/or use is at the customer’s own risk. Applications — Applications that are described herein for any of these products are for illustrative purposes only. Ampleon makes no representation or warranty that such applications will be suitable for the specified use without further testing or modification. Customers are responsible for the design and operation of their applications and products using Ampleon products, and Ampleon accepts no liability for any assistance with applications or customer product design. It is customer’s sole responsibility to determine whether the Ampleon product is suitable and fit for the customer’s applications and products planned, as well as for the planned application and use of customer’s third party customer(s). Customers should provide appropriate design and operating safeguards to minimize the risks associated with their applications and products. Ampleon does not accept any liability related to any default, damage, costs or problem which is based on any weakness or default in the customer’s applications or products, or the application or use by customer’s third party customer(s). Customer is responsible for doing all necessary testing for the customer’s applications and products using Ampleon products in order to avoid a default of the applications and the products or of the application or use by customer’s third party customer(s). Ampleon does not accept any liability in this respect. Limiting values — Stress above one or more limiting values (as defined in the Absolute Maximum Ratings System of IEC 60134) will cause permanent damage to the device. Limiting values are stress ratings only and (proper) operation of the device at these or any other conditions above those given in the Recommended operating conditions section (if present) or the Characteristics sections of this document is not warranted. Constant or repeated exposure to limiting values will permanently and irreversibly affect the quality and reliability of the device. Terms and conditions of commercial sale — Ampleon products are sold subject to the general terms and conditions of commercial sale, as published at http://www.ampleon.com/terms, unless otherwise agreed in a valid written individual agreement. In case an individual agreement is concluded only the terms and conditions of the respective agreement shall apply. Ampleon hereby expressly objects to applying the customer’s general terms and conditions with regard to the purchase of Ampleon products by customer. No offer to sell or license — Nothing in this document may be interpreted or construed as an offer to sell products that is open for acceptance or the grant, conveyance or implication of any license under any copyrights, patents or other industrial or intellectual property rights. Export control — This document as well as the item(s) described herein may be subject to export control regulations. Export might require a prior authorization from competent authorities. All information provided in this document is subject to legal disclaimers. Rev. 2 — 1 September 2015 © Ampleon The Netherlands B.V. 2015. All rights reserved. 11 of 13 BLF6G20(LS)-180RN Power LDMOS transistor Non-automotive qualified products — Unless this data sheet expressly states that this specific Ampleon product is automotive qualified, the product is not suitable for automotive use. It is neither qualified nor tested in accordance with automotive testing or application requirements. Ampleon accepts no liability for inclusion and/or use of non-automotive qualified products in automotive equipment or applications. In the event that customer uses the product for design-in and use in automotive applications to automotive specifications and standards, customer (a) shall use the product without Ampleon’ warranty of the product for such automotive applications, use and specifications, and (b) whenever customer uses the product for automotive applications beyond Ampleon’ specifications such use shall be solely at customer’s own risk, and (c) customer fully indemnifies Ampleon for any liability, damages or failed product claims resulting from customer design and use of the product for automotive applications beyond Ampleon’ standard warranty and Ampleon’ product specifications. 12.4 Trademarks Notice: All referenced brands, product names, service names and trademarks are the property of their respective owners. Any reference or use of any ‘NXP’ trademark in this document or in or on the surface of Ampleon products does not result in any claim, liability or entitlement vis-à-vis the owner of this trademark. Ampleon is no longer part of the NXP group of companies and any reference to or use of the ‘NXP’ trademarks will be replaced by reference to or use of Ampleon’s own Any reference or use of any ‘NXP’ trademark in this document or in or on the surface of Ampleon products does not result in any claim, liability or entitlement vis-à-vis the owner of this trademark. Ampleon is no longer part of the NXP group of companies and any reference to or use of the ‘NXP’ trademarks will be replaced by reference to or use of Ampleon’s own trademarks. Translations — A non-English (translated) version of a document is for reference only. The English version shall prevail in case of any discrepancy between the translated and English versions. 13. Contact information For more information, please visit: http://www.ampleon.com BLF6G20-180RN_20LS-180RN#2 Product data sheet For sales office addresses, please visit: http://www.ampleon.com/sales All information provided in this document is subject to legal disclaimers. Rev. 2 — 1 September 2015 © Ampleon The Netherlands B.V. 2015. All rights reserved. 12 of 13 BLF6G20(LS)-180RN Power LDMOS transistor 14. Contents 1 1.1 1.2 1.3 2 3 4 5 6 7 7.1 7.2 7.3 7.4 8 9 10 11 12 12.1 12.2 12.3 12.4 13 14 Product profile . . . . . . . . . . . . . . . . . . . . . . . . . . 1 General description . . . . . . . . . . . . . . . . . . . . . 1 Features . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 1 Applications . . . . . . . . . . . . . . . . . . . . . . . . . . . 2 Pinning information . . . . . . . . . . . . . . . . . . . . . . 2 Ordering information . . . . . . . . . . . . . . . . . . . . . 2 Limiting values. . . . . . . . . . . . . . . . . . . . . . . . . . 2 Thermal characteristics . . . . . . . . . . . . . . . . . . 3 Characteristics . . . . . . . . . . . . . . . . . . . . . . . . . . 3 Application information. . . . . . . . . . . . . . . . . . . 3 Ruggedness in class-AB operation . . . . . . . . . 3 One-tone CW . . . . . . . . . . . . . . . . . . . . . . . . . . 4 Two-tone CW . . . . . . . . . . . . . . . . . . . . . . . . . . 4 2-carrier W-CDMA . . . . . . . . . . . . . . . . . . . . . . 5 Test information . . . . . . . . . . . . . . . . . . . . . . . . . 5 Package outline . . . . . . . . . . . . . . . . . . . . . . . . . 8 Abbreviations . . . . . . . . . . . . . . . . . . . . . . . . . . 10 Revision history . . . . . . . . . . . . . . . . . . . . . . . . 10 Legal information. . . . . . . . . . . . . . . . . . . . . . . 11 Data sheet status . . . . . . . . . . . . . . . . . . . . . . 11 Definitions . . . . . . . . . . . . . . . . . . . . . . . . . . . . 11 Disclaimers . . . . . . . . . . . . . . . . . . . . . . . . . . . 11 Trademarks. . . . . . . . . . . . . . . . . . . . . . . . . . . 12 Contact information. . . . . . . . . . . . . . . . . . . . . 12 Contents . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 13 Please be aware that important notices concerning this document and the product(s) described herein, have been included in section ‘Legal information’. © Ampleon The Netherlands B.V. 2015. All rights reserved. For more information, please visit: http://www.ampleon.com For sales office addresses, please visit: http://www.ampleon.com/sales Date of release: 1 September 2015 Document identifier: BLF6G20-180RN_20LS-180RN#2
BLF6G20-180RN,112 价格&库存
很抱歉,暂时无法提供与“BLF6G20-180RN,112”相匹配的价格&库存,您可以联系我们找货
