CCD-WRRF223Z202K0AE
CCD-WRRF223Z202K0AE
    TRIGON(三弦)
    插件
    贴片电容(MLCC) 径向 22nF -20~+80% 2KV Y5V
CCD-WRRF223Z202K0AE 数据手册
CCD-W Series Ceramic Disc Capacitors (Class 2 high voltage low D.F. ceramic dielectric capacitors) TRIGON COMPONENTS Body Diameter (mm) FEATURES     Relative Standards: IEC 384-9: 1988 (Fixed capacitors of ceramic dielectric, class 2) GB/T 5698-1966 (Fixed capacitors of ceramic dielectric, class 2) GB 9322-88 (Fixed class 2 high voltage ceramic dielectric capacitors) RoHS Compliant 05 06 07 08 09 10 11 12 13 14 15 D max. 5.5 6.5 7.5 8.5 9.5 10.5 11.5 12.5 13.5 14.5 15.5 CODE 16 17 18 19 20 21 22 D max. 16.5 17.5 18.5 19.5 20.5 21.5 22.5 CODE EE FF GG HH II JJ KK LL MM NN OO D max. 5.0 6.0 7.0 8.0 9.0 10.0 11.0 12.0 13.0 14.0 15.0 CODE PP QQ RR SS TT UU VV D max. 16.0 17.0 18.0 19.0 20.0 21.0 22.0 APPLICATION ● Electronic Control Gear (Ballast) ● Television ● Power Supply,High Voltage Circuit etc ORDERING CODE CCD – W 10 E 222 K 102 L 5 1 (1) (2) (3) (4) (5) (6) (7) (8) (9) (10) (1) Ceramic Disc Capacitor (1) Class 2 high voltage ceramic dielectric capacitors (2) Diameter Code (3) Temp. Characteristics:B, E, F (4) Capacitance Code. (5) Tolerance Code:K, M, Z (6) Rated Voltage Code (7) Lead Style. Ref To Configuration (8) Lead Spacing Code. Refer To (CCD-Ord) document (10) Package & Lead Length. Please Refer To Complete Ordering Code Document(CCD-Ord)For More Ordering Option. Rev. A5 Sheet 1 of 13 Capacitor ● High Voltage,Low D.F, High Stable,High Reliability ● Coated with flame-retardant epoxy resin CODE CCD-W Series Ceramic Disc Capacitors (Class 2 high voltage low D.F. ceramic dielectric capacitors) TRIGON COMPONENTS Configuration: Capacitor Rev. A5 Sheet 2 of 13 CCD-W Series Ceramic Disc Capacitors (Class 2 high voltage low B.D.F. ceramic dielectric capacitors) TRIGON COMPONENTS MARKING: BODY DIAMETER(mm) MARKING ITEM EXAMPLE a:Norminal Capacitors b:Rated Voltage B(Y5P) Capacitor a:Norminal Capacitors b:Capacitance Tolerance:K,M,Z c:Rated Voltage:actual value E(Y5U) F(Y5V) 1. 2. 3. 4. 5. a:Norminal Capacitors b:Capacitance Tolerance:K,M ,Z c:Rated Voltage d:Temperature Characteristic: E(Y5U),F(Y5V) e:Manufactuer·s Trade Mark Mark Color: Black or Nearly Color Nominal Capacitance: 3 Digital Code Capacitance Tolerance: Marked With Code Rated Voltage: Actual Value Manufacturers Identification :Marked With TCP CAPACITANCE VS TEMPERATURE CURVE: Rev. A5 Sheet 3 of 13 CCD-W Series Ceramic Disc Capacitors (Class 2 high voltage low B.D.F. ceramic dielectric capacitors) TRIGON COMPONENTS CAPACITANCE, VOLTAGE, DIAMETER & THICKNESS DISTRIBUTION DIAGRAM Voltage 2KVDC 3KVDC E(Y5U) F(Y5V) B(Y5P) E(Y5U) F(Y5V) B(Y5P) E(Y5U) F(Y5V) ±10% ±20% +80%~-20% ±10% ±20% +80%~-20% ±10% ±20% +80%~-20% Thickness 4.0 max 4.0 max 4.0 max 5.0 max 5.0 max 5.0 max 6.0 max 6.0 max 6.0 max Cap. pF DIA (max) Pin Pitch DIA (max) Pin Pitch DIA (max) Pin Pitch DIA (max) Pin Pitch DIA (max) Pin Pitch DIA (max) Pin Pitch DIA (max) Pin Pitch DIA (max) Pin Pitch DIA (max) Pin Pitch 100 7.0 / 5.0 NA NA 7.0 / 5.0 NA NA 8.0 / 7.5 NA NA 120 7.0 / 5.0 NA NA 7.0 / 5.0 NA NA 8.0 / 7.5 NA NA 150 7.0 / 5.0 NA NA 7.0 / 5.0 NA NA 8.0 / 7.5 NA NA 180 7.0 / 5.0 NA NA 7.0 / 5.0 NA NA 8.0 / 7.5 NA NA 220 7.0 / 5.0 NA NA 7.0 / 5.0 NA NA 8.0 / 7.5 NA NA 270 7.0 / 5.0 NA NA 7.0 / 5.0 NA NA 8.0 / 7.5 NA NA 330 7.0 / 5.0 NA NA 7.0 / 5.0 NA NA 8.0 / 7.5 NA NA 390 7.0 / 5.0 NA NA 7.0 / 5.0 NA NA 8.0 / 7.5 NA NA 470 7.0 / 5.0 NA NA 7.0 / 5.0 NA NA 8.0 / 7.5 NA NA 560 7.0 / 5.0 NA NA 8.0 / 5.0 NA NA 8.0 / 7.5 NA NA 680 7.0 / 5.0 NA NA 8.0 / 5.0 NA NA 9.0 / 7.5 NA NA 820 7.0 / 5.0 NA NA 8.0 / 5.0 NA NA 10.0 / 7.5 NA NA 1000 7.0 / 5.0 7.0 / 5.0 NA 9.0 / 5.0 7.0 / 7.5 7.0 / 5.0 11.0 / 7.5 8.0 / 7.5 8.0 / 7.5 1200 7.0 / 5.0 7.0 / 5.0 NA 9.0 / 5.0 7.0 / 5.0 7.0 / 5.0 11.0 / 7.5 9.0 / 7.5 8.0 / 7.5 8.0 / 5.0 7.0 / 5.0 NA 10.0 / 5.0 8.0 / 5.0 7.0 / 5.0 12.0 / 7.5 9.0 / 7.5 8.0 / 7.5 9.0 / 5.0 7.0 / 5.0 NA 11.0 / 5.0 8.0 / 5.0 7.0 / 5.0 13.0 / 7.5 9.0 / 7.5 8.0 / 7.5 2200 9.0 / 5.0 7.0 / 5.0 NA 11.0 / 5.0 8.0 / 5.0 7.0 / 5.0 14.0 / 7.5 10.0 / 7.5 8.0 / 7.5 2700 10.0 / 5.0 8.0 / 5.0 NA 13.0 / 7.5 10.0 / 7.5 8.0 / 5.0 15.0 / 7.5 10.0 / 7.5 9.0 / 7.5 3300 11.0 / 5.0 8.0 / 5.0 7.0 / 5.0 14.5 / 7.5 10.0 / 7.5 8.0 / 5.0 17.0 / 10.0 11.0 / 7.5 9.0 / 7.5 3900 12.0 / 7.5 9.0 / 5.0 8.0 / 5.0 15.0 / 7.5 11.0 / 7.5 9.0 / 5.0 18.0 / 10.0 12.0 / 7.5 11.0 / 7.5 4700 13.0 / 7.5 10.0 / 5.0 8.0 / 5.0 17.0 / 7.5 11.0 / 7.5 10.0 / 5.0 19.0 / 10.0 13.0 / 7.5 11.0 / 7.5 5600 14.0 / 7.5 10.0 / 5.0 8.0 / 5.0 NA 13.0 / 7.5 10.0 / 7.5 NA 15.0 / 7.5 12.0 / 7.5 6800 15.0 / 7.5 11.0 / 5.0 9.0 / 5.0 NA 13.0 / 7.5 11.0 / 7.5 NA 16.0 / 10.0 12.0 / 10.0 8200 17.0 / 7.5 12.0 / 7.5 10.0 / 5.0 NA 13.0 / 7.5 13.0 / 7.5 NA 18.0 / 10.0 14.0 / 10.0 10000 18.0 / 7.5 12.0 / 7.5 10.0 / 5.0 NA 16.0 / 7.5 13.0 / 7.5 NA 19.0 / 10.0 15.0 / 10.0 15000 NA 15.0 / 7.5 NA NA NA 15.0 / 7.5 NA NA 18.0 / 10.0 22000 NA 18.0 / 7.5 14.0 / 7.5 NA NA 18.0 / 10.0 NA NA 21.0 / 10.0 33000 NA NA 17.0 / 7.5 NA NA NA NA NA NA 1500 1800 Operating Temperature Range: -25 to +125°C. D.F Char. D,E: 2.5% max. Char. F: 5.0% max. Rev. A5 Sheet 4 of 13 Capacitor B(Y5P) Temp. Char. - 1KVDC CCD-W Series Ceramic Disc Capacitors (Class 2 high voltage low B.D.F. ceramic dielectric capacitors) TRIGON COMPONENTS CAPACITANCE, VOLTAGE, DIAMETER & THICKNESS DISTRIBUTION DIAGRAM Voltage Temp. Char. 4KVDC B(Y5P) E(Y5U) F(Y5V) B(Y5P) 6KVDC E(Y5U) F(Y5V) B(Y5P) E(Y5U) F(Y5V) ±20% +80%~-20% ±10% ±20% +80%~-20% ±10% +80%~-20% +80%~-20% 6.0 max 6.0 max 6.0 max 7.0 max 7.0 max 7.0 max 8.0 max 8.0 max 8.0 max Cap. pF DIA (max) Pin Pitch DIA (max) Pin Pitch DIA (max) Pin Pitch DIA (max) Pin Pitch DIA (max) Pin Pitch DIA (max) Pin Pitch DIA (max) Pin Pitch DIA (max) Pin Pitch DIA (max) Pin Pitch 100 8.0 / 10.0 NA NA 8.0 / 10.0 NA NA 8.0 / 10.0 NA NA 150 8.0 / 10.0 NA NA 8.0 / 10.0 NA NA 8.0 / 10.0 NA NA 220 8.0 / 10.0 NA NA 8.0 / 10.0 NA NA 9.0 / 10.0 NA NA 330 8.0 / 10.0 NA NA 8.0 / 10.0 NA NA 9.0 / 10.0 NA NA 470 9.0 / 10.0 NA NA 9.0 / 10.0 NA NA 9.0 / 10.0 NA NA 680 10.0 / 10.0 NA NA 10.0 / 10.0 NA NA 11.0 / 10.0 NA NA 12.0 / 10.0 9.0 / 10.0 8.0 / 10.0 13.0 / 10.0 9.0 / 10.0 8.0 / 10.0 13.0 / 10.0 9.0 / 10.0 8.0 / 10.0 NA 11.0 / 10.0 8.5 / 10.0 NA 10.0 / 10.0 8.0 / 10.0 NA 10.0 / 10.0 9.0 / 10.0 NA 12.0 / 10.0 9.0 / 10.0 NA 11.0 / 10.0 9.0 / 10.0 NA 12.0 / 10.0 10.0 / 10.0 3300 NA 14.0 / 10.0 11.0 / 10.0 NA 13.0 / 10.0 11.0 / 10.0 NA 13.0 / 10.0 11.0 / 10.0 4700 NA 17.0 / 10.0 12.0 / 10.0 NA 16.0 / 10.0 13.0 / 10.0 NA 17.0 / 10.0 13.0 / 10.0 NA NA 17.0 / 10.0 NA NA 18.0 / 10.0 NA NA 20.0 / 10.0 1500 2200 10000 Voltage 8KVDC B(Y5V) E(Y5U) F(Y5V) ±10% +80%~-20% +80%~-20% 8.0 max DIA (max) Pin Pitch 8.0 max DIA (max) Pin Pitch 8.0 max DIA (max) Pin Pitch 100 9.0 / 10.0 NA NA 150 9.0 / 10.0 NA NA 220 9.0 / 10.0 NA NA 330 10.0 / 10.0 NA NA 470 11.0 / 10.0 NA NA 680 13.0 / 10.0 NA NA 1000 15.0 / 10.0 11.0 / 10.0 9.0 / 10.0 1500 NA 13.0 / 10.0 10.0 / 10.0 2200 NA 15.0 / 10.0 12.0 / 10.0 3300 NA 18.0 / 10.0 14.0 / 10.0 4700 NA 22.0 / 10.0 16.0 / 10.0 10000 NA NA 23.0 / 10.0 Temp. Char. Thickness Cap. pF Operating Temperature Range: -25 to +125°C. D.F Char. D,E: 2.5% max. Char. F: 5.0% max. Rev. A5 Sheet 5 of 13 Capacitor ±10% Thickness 1000 - 5KVDC CCD-W Series Ceramic Disc Capacitors (Class 2 high voltage low B.D.F. ceramic dielectric capacitors) TRIGON COMPONENTS CAPACITANCE, VOLTAGE, DIAMETER & THICKNESS DISTRIBUTION DIAGRAM Voltage 1KVDC 2KVDC 3KVDC X/(X7R) X/(X7R) X/(X7R ±10% ±10% ±10% Cap. pF 4.0 max DIA (max) Pin Pitch 4.0 max DIA (max) Pin Pitch 6.0 max DIA (max) Pin Pitch 100 7.0 / 5.0 7.0 / 5.0 8.0 / 7.5 7.0 / 5.0 7.0 / 5.0 8.0 / 7.5 7.0 / 5.0 7.0 / 5.0 8.0 / 7.5 7.0 / 5.0 7.0 / 5.0 8.0 / 7.5 220 7.0 / 5.0 7.0 / 5.0 8.0 / 7.5 270 7.0 / 5.0 7.0 / 5.0 8.0 / 7.5 330 7.0 / 5.0 7.0 / 5.0 8.0 / 7.5 7.0 / 5.0 7.0 / 5.0 8.0 / 7.5 7.0 / 5.0 7.0 / 5.0 8.0 / 7.5 7.0 / 5.0 8.0 / 5.0 9.0 / 7.5 7.0 / 5.0 8.0 / 5.0 9.0 / 7.5 7.0 / 5.0 8.0 / 5.0 10.0 / 7.5 7.0 / 5.0 9.0 / 5.0 11.0 / 7.5 7.0 / 5.0 9.0 / 5.0 11.0 / 7.5 8.0 / 5.0 10.0 / 5.0 12.0 / 7.5 9.0 / 5.0 11.0 / 5.0 13.0 / 7.5 2200 9.0 / 5.0 11.0 / 5.0 14.0 / 7.5 2700 10.0 / 5.0 13.0 / 7.5 15.0 / 7.5 3300 11.0 / 5.0 13.0 / 7.5 17.0 / 10.0 3900 12.0 / 7.5 15.0 / 7.5 18.0 / 10.0 4700 13.0 / 7.5 17.0 / 7.5 19.0 / 10.0 5600 14.0 / 7.5 NA NA 6800 15.0 / 7.5 NA NA 8200 17.0 / 7.5 NA NA 10000 18.0 / 7.5 NA NA Temp. Char. Thickness 120 150 180 390 470 560 680 820 1000 1200 1500 1800 Trigon Components reserves the rights for revising the content of this catalog without further notification. Rev. A5 Sheet 6 of 13 CCD-W Series Ceramic Disc Capacitors (Class 2 high voltage low B.D.F. ceramic dielectric capacitors) TRIGON COMPONENTS SPECIFICATION AND TEST METHOD Test condition Test and measurement shall be made at the standard condition, (Temperature 15 to 35℃, relative humidity 45 to 75% and atmospheric pressure 860-1060 hpa), unless otherwise specified herein If doubt occurred on the value of measurement, and remeasurement was requested by customer capacitors shall be measured at the reference condition(Temperature 20±2° relative humidity 60 to 70% and atmospheric pressure 860-1060 hpa), unless otherwise specified herein Performance Item Specification Testing Method 1 Operating Temperature Range -25 to +125°C ------ 2 Appearance and Dimensions 3 Marking To be easily legible. Between Lead Wires Strength Body Insulation Insulation Resistance (I.R.) Between Lead Wires 6 Capacitance 7 Dissipation Factor (D.F.) Temperature Characteristic No failure. The capacitor is placed in the container with metal balls of diameter 1mm so that each lead wire, short circuited, is kept about 2mm off the balls as shown in the figure, and DC Voltage of 1.3kV is applied for 1 to 5 s between capacitor lead wires and small metals. (Charge/Discharge current ≤50mA.) C*1≤ 0.02uF:10000MΩ Min C*1〉0.02uF:7500.MΩ Min Within specified tolerance. Char. D,E: 2.5% max. Char. F: 5.0% max. Bending Rev. A5 The capacitance shall be measured at 20 ±2 with 1±0.2KHz and AC1±0.1V(r.m.s) The dissipation factor shall be measured at 20±2 with 1±0.2KHz and AC 1±0.1V(r.m.s) The capacitance measurement shall be made at each step specified in Table 1 2 3 4 5 20±2 -25±3 20±2 85±2 20±2 Pull Strength of Lead The insulation resistance shall be measured with DC500±50V within 60±5 s of charging Pre-treatment: Capacitor shall be stored at 85±2℃ for 1h then placed at*room condition for 24±2h before measurements. Step Temp. (℃) 9 The capacitor shall be inspected by naked eyes. The capacitor shall not be damage when DC voltage of 150% the rated voltage is applied between the lead wires for 1 to 5 s. (Charge/Discharge current ≤50mA.) Char. B: within ±10% Char. E: within +20/-50% Char. F : within +30/-80% 8 The capacitor shall be inspected by naked eyes for Visible evidence of defect. Dimensions shall be measured with slide calipers. No failure. Dielectric 4 5 No marked defect on appearance from and dimensions are within specified range. Lead wire shall not cut off. Capacitor shall not be broken. As a figure, fix the body of capacitor, apply a tensile Weight gradually to each lead wire in the radial direction of capacitor up to10N(5N for lead diameter ¢0.5mm),and keep it for 10±1S Each lead wire shall be subjected to 5N(2.5N for lead diameter¢ 0.5mm) weight and then a 90 deg bend, at the point of egress, in one direction, return to original position, and then a 90 deg bend in the opposite direction at the rate of one bend in 2 to 3S. Sheet 7 of 13 Capacitor No CCD-W Series Ceramic Disc Capacitors (Class 2 high voltage Low B.D.F. ceramic dielectric capacitors) TRIGON COMPONENTS Appearance 10 Vibration Resistance Capacitance D.F. 11 Solderability of Leads Appearance 13 14 Soldering Effect Humidity (Under Steady State) Humidity Loading Dielectric Strength (Between Lead Wires) Appearance Capacitance change D.F. Life No marked defect. Capacitance change Char. B : within ±10% Char. E : within ±20% Char. F : within ±30% D.F. Char. B, E: 5% max Char. F: 7.5% max I.R. 500MΩ min Capacitance change Appearance Capacitance change D.F. I.R. Dielectric Strength (Between Lead Wires) Rev. A5 Char. B : within ±10% Char. E : within ±20% Char. F : within ±30% Char. B, E: 5% max Char. F: 7.5% max Appearance I.R. 16 No marked defect. 1000MΩ min D.F. Temperature D.F. and Immersion Cycle Per item 4. I.R. Appearance 15 Char. B : within ±5% Char. E : within ±15% Char. F : within ±20% No marked defect. Char. E : within ±10% Char. E : within ±20% Char. F : within ±30% Char. B, E: 4.5% max Char. F: 7.5% max The capacitor shall firmly be soldered to the supporting lead wire and vibration which is 10 to 55Hz in the vibration frequency range, 1.5mm in total amplitude, and about 1min. In the rate of vibration change from 10Hz to 55Hz and back to 10Hz is applied for a total of 6 h; 2 h each in 3 mutually perpendicular directions. The lead wire of a capacitor shall be dipped into a ethanol solution of 25 wt% rosin and then into molten solder of 235±5℃ for 2±0.5s In both cases the depth of dipping is up to about 1.5 to 2mm from the root of lead wires. The lead wire shall be immersed into the melted solder of 350±10℃ or 260±5℃ up to about 1.5 to 2.0mm from the main body for 3.5±0.5s (10±1s for 260±5℃) Pre-treatment : Capacitor shall be stored at 85±2℃ for 1h then placed at room condition for 24±2h before initial measurements. Post-treatment : Capacitor shall be stored for 4to24h at room condition. Set the capacitor for 500+24/-0h at 40±2℃ in 90to 95% relative Humidity Pre-treatment : Capacitor shall be stored at 8±2℃ for 1h then placed At room condition for 24±2h before initial measurements. Post-treatment : Capacitor shall be stored for 1to 2h at room condition. Apply the rated voltage for 500 +24/-0 at 40±2℃ in 90 to 95% relative Humidity(Charge/Discharge current ≤50mA) Pre-treatment : Capacitor shall be stored at 85±2℃ for 1h then placed At room condition for 24±2h before initial measurements. Post-treatment : Capacitor shall be stored at 85±2℃ for 1h,then placed at*room condition for 24±2h. Apply a DC voltage 150% of the rated voltage for1000 +48/-0h at 85± 2 ℃ and relative humidity of 50% max.. (Charge/Discharge current 500mA) Pre-treatment : Capacitor shall be stored at 85±2℃ for 1h then placed At room condition for 24±2h before initial measurements. Post-treatment : Capacitor shall be stored at 85±2℃for 1h then placed At room condition for 24±2h. 2000MΩ min No marked defect. Char. B : within ±20% Char. E : within ±20% Char. F : within ±30% Char. B, E: 4.0% max Char. F: 7.5% max 2000MΩ min Per item 4. The capacitor shall be subjected to 5 temperature cycles. The consecutively to 2 immersion cycles。 Step Temperature(℃) Time 1 -25℃±3 30 Min 2 Room Temp 3 Min 3 +85℃±3 30 Min 4 Room Temp 3 Min Step Temperature(℃) Time 1 +65℃+5/-0 2 0±3 15 Min 15 Min Immersio n Water Clean Water Salt Water Cycle time: 5 cycle Cycle time: 5 cycle Pre-treatment : Capacitor shall be stored at 105±2℃ for 1h then placed At room condition for 24±2h before initial measurements. Post-treatment : Capacitor shall be stored for 4 to24h at room condition. Sheet 8 of 13 Capacitor 12 Capacitance Change No marked defect. Within specified tolerance. Char. B, E: 2.5% max Char. F: 5.0% max Lead wire shall be soldered with uniformly coated on the axial direction over 3/4 of the circumferential direction. No marked defect SOLDERING PROFILE Ceramic Disc Capacitors (Class 2 high voltage Low D.F. ceramic dielectric capacitors) TRIGON COMPONENTS Rev. A5 Sheet 9 of 13 CCD-W Series Ceramic Disc Capacitors (Class 2 high voltage low B.D.F. ceramic dielectric capacitors) TRIGON COMPONENTS TAPING SPECIFICATION Capacitor Item Code Dimension Pitch of component P Pitch of sprocket hole P0 Lead spacing F Length from hole center to component center P2 Length from hole center to lead P1 Body diameter D Deviation along tape, left or right △S 0±2.0 Carrier tape width W 18.0±0.5 Position of sprocket hole W1 9.0±0.5 Lead distance between reference and bottom planes 12.7/25.4 12.7±0.3 5.0±1.0/7.5±1.0/10.0±1.0 6.35±1.3/12.7±1.3 3.85±0.7/2.6±0.7/8.95±1.0/7.7±1.0 See the individual product specification H 20.0±1.5 Diameter of sprocket hole ∮D0 4.0±0.2 Total thickness, tape and lead wire ∮d 0.55±0.3 Lead diameter t1 0.55±0.3 Total tape thickness t2 2.0 max. Body thickness T See the individual product specification Portion to cut in case of defect L 11.0 max. Hold down tape width W0 10±2 Hold down tape position W2 1.5±1.5 Coating extension on lead Deviation across tape Rev. A5 e △h1 △h2 Up to the end of crimp 2.0 max. Sheet 10 of 13 CCD-W Series Ceramic Disc Capacitors (Class 2 high voltage low B.D.F. ceramic dielectric capacitors) TRIGON COMPONENTS Capacitor Item Pitch of component P Pitch of sprocket hole P0 Lead spacing F Length from hole center to component center P2 Length from hole center to lead P1 Body diameter D Deviation along tape, left or right △S Dimension 15.0/30.0 15.0±0.3 5.0±1.0/7.5±1.0/10.0±1.0 7.35±1.3/15.0±1.3 5.0±0.7/3.75±0.7/11.25±0.7/10.0±1.0 See the individual product specification 0±2.0 Carrier tape width W 18.0±0.5 Position of sprocket hole W1 9.0±0.5 H 20.0±1.5 Lead distance between reference and bottom planes Diameter of sprocket hole ∮D0 4.0±0.2 Total thickness, tape and lead wire ∮d 0.55±0.05 Lead diameter t1 0.6±0.3 Total tape thickness t2 2.0 max. Body thickness T See the individual product specification Portion to cut in case of defect L 11.0 max. Hold down tape width W0 10.0±2 Hold down tape position W2 1.5±1.5 Coating extension on lead Deviation across tape Rev. A5 Code e Up to the end of crimp △h1 △h2 2.0 max. Sheet 11 of 13 CCD-W Series Ceramic Disc Capacitors (Class 2 high voltage Low D.F. ceramic dielectric capacitors) TRIGON COMPONENTS PACKAGING STYLES Taping:Reel Packaging Capacitor Capacitor Taping:Ammo Box Bulk: Polyethylene Bag Rev. A5 Sheet 12 of 13 CCD-W Series Ceramic Disc Capacitors (Class 2 high voltage low B.D.F. ceramic dielectric capacitors) TRIGON COMPONENTS PACKAGING QUANTITY Bulk(at standards specification) Body Diameter 4.5 to 9.0 mm : 1000 pcs Body Diameter 10 mm over : 500 pcs Taping Pitch : 12.7/25.4 mm Body Diameter 4.5 to 8.0 mm : 1500 pcs./Box Body Diameter 9.0 mm over : 1000 pcs./Box LABEL AND TRANSPORTB Rev. A5 Sheet 13 of 13 Capacitor Capacitors shall be packaged prior to shipment so as to prevent damage during transportation and storage. Shipping carton contains the following information on the label
CCD-WRRF223Z202K0AE 价格&库存
很抱歉,暂时无法提供与“CCD-WRRF223Z202K0AE”相匹配的价格&库存,您可以联系我们找货
