BLF8G20LS-260A,112
BLF8G20LS-260A,112
    AMPLEON(安谱隆)
    SOT539B
    FET RF 2CH 65V 1.88GHZ
BLF8G20LS-260A,112 数据手册
BLF8G20LS-260A Power LDMOS transistor Rev. 5 — 1 September 2015 Product data sheet 1. Product profile 1.1 General description 260 W LDMOS packaged asymmetric Doherty power transistor for base station applications at frequencies from 1805 MHz to 1880 MHz. Table 1. Typical performance Typical RF performance at Tcase = 25 C in an asymmetrical Doherty production test circuit. Test signal 1-carrier W-CDMA[1] D ACPR (dB) (%) (dBc) 15.9 45.5 29[2] f VDS PL(AV) Gp (MHz) (V) (W) 1805 to 1880 28 50 [1] VDS = 28 V; IDq = 750 mA (main); VGS(amp)peak = 0.80 V. [2] Test signal: 3GPP test model 1; 64 DPCH; PAR = 9.65 dB at 0.01% probability on CCDF per carrier. 1.2 Features and benefits           Excellent ruggedness High-efficiency Low Rth providing excellent thermal stability Designed for broadband operation (1805 MHz to 1880 MHz) Asymmetric design to achieve optimum efficiency across the band Lower output capacitance for improved performance in Doherty applications Designed for low memory effects providing excellent digital pre-distortion capability Internally matched for ease of use Integrated ESD protection Compliant to Directive 2002/95/EC, regarding Restriction of Hazardous Substances (RoHS) 1.3 Applications  RF power amplifiers for W-CDMA base stations and GSM multi carrier applications in the 1805 MHz to 1880 MHz frequency range BLF8G20LS-260A Power LDMOS transistor 2. Pinning information Table 2. Pinning Pin Description 1 drain1 (main) 2 drain2 (peak) 3 gate1 (main) 4 gate2 (peak) 5 Simplified outline 1 Graphic symbol 2 1 5 3 3 4 5 4 [1] source 2 sym117 [1] Connected to flange. 3. Ordering information Table 3. Ordering information Type number Package BLF8G20LS-260A Name Description Version - SOT539B earless flanged balanced ceramic package; 4 leads 4. Limiting values Table 4. Limiting values In accordance with the Absolute Maximum Rating System (IEC 60134). Symbol Parameter VDS Min Max Unit drain-source voltage - 65 V VGS(amp)main main amplifier gate-source voltage 0.5 +13 V VGS(amp)peak peak amplifier gate-source voltage 0.5 +13 V Tstg storage temperature 65 +150 C - 225 C Typ Unit PL = 50 W 0.36 K/W PL = 200 W 0.29 K/W [1] junction temperature Tj [1] Conditions Continuous use at maximum temperature will affect reliability. 5. Thermal characteristics Table 5. Thermal characteristics Symbol Parameter Rth(j-c) BLF8G20LS-260A#5 Product data sheet Conditions thermal resistance from junction to case VDS = 28 V; IDq = 750 mA (main); VGS(amp)peak = 0.80 V; Tcase = 80 C All information provided in this document is subject to legal disclaimers. Rev. 5 — 1 September 2015 © Ampleon The Netherlands B.V. 2015. All rights reserved. 2 of 15 BLF8G20LS-260A Power LDMOS transistor 6. Characteristics Table 6. DC characteristics Tj = 25 C unless otherwise specified. Symbol Parameter Conditions Min Typ Max Unit Main device VGS = 0 V; ID = 1.44 mA 65 - - V VGS(th) V(BR)DSS drain-source breakdown voltage gate-source threshold voltage VDS = 10 V; ID = 144 mA 1.5 1.9 2.3 V VGSq gate-source quiescent voltage VDS = 28 V; ID = 750 mA 1.7 2.1 2.5 V IDSS drain leakage current VGS = 0 V; VDS = 28 V - - 2.8 A IDSX drain cut-off current VGS = VGS(th) + 3.75 V; VDS = 10 V - 27 - A IGSS gate leakage current VGS = 11 V; VDS = 0 V - - 280 nA gfs forward transconductance VDS = 10 V; ID = 5.04 A - 9.70 - S RDS(on) drain-source on-state resistance VGS = VGS(th) + 3.75 V; ID = 5.04 A - 102 166 m VGS = 0 V; ID = 2.2 mA 65 - - V Peak device V(BR)DSS drain-source breakdown voltage VGS(th) gate-source threshold voltage VDS = 10 V; ID = 220 mA 1.5 1.9 2.3 V VGSq gate-source quiescent voltage VDS = 28 V; ID = 1200 mA 1.7 2.1 2.5 V IDSS drain leakage current VGS = 0 V; VDS = 28 V - - 2.8 A IDSX drain cut-off current VGS = VGS(th) + 3.75 V; VDS = 10 V - 41 - A IGSS gate leakage current VGS = 11 V; VDS = 0 V - - 280 nA gfs forward transconductance VDS = 10 V; ID = 7.70 A - 14.9 - S RDS(on) drain-source on-state resistance VGS = VGS(th) + 3.75 V; ID = 7.7 A - 66 m 112 Table 7. RF characteristics Test signal: 1-carrier W-CDMA; PAR = 9.65 dB at 0.01 % probability on the CCDF; 3GPP test model 1; 1 - 64 DPCH; f1 = 1810 MHz; f2 = 1875 MHz; RF performance at VDS = 28 V; IDq = 750 mA (main); VGS(amp)peak = 0.80 V; Tcase = 25 C; unless otherwise specified; in an asymmetrical Doherty production test circuit at 1805 MHz to 1880 MHz. Symbol Parameter Conditions Min Typ Max Unit Gp power gain PL(AV) = 50 W 14.7 15.9 - dB RLin input return loss PL(AV) = 50 W - 11 7 dB D drain efficiency PL(AV) = 50 W 40 45.5 - % ACPR adjacent channel power ratio PL(AV) = 50 W - 29 24 dBc Table 8. RF characteristics Test signal: 1-carrier W-CDMA; PAR = 9.65 dB at 0.01 % probability on the CCDF; 3GPP test model 1; 1 - 64 DPCH; f = 1877.5 MHz; RF performance at VDS = 28 V; IDq = 750 mA (main); VGS(amp)peak = 0.80 V; Tcase = 25 C; unless otherwise specified; in an asymmetrical Doherty production test circuit at 1805 MHz to 1880 MHz. Symbol Parameter BLF8G20LS-260A#5 Product data sheet Min Typ Max Unit PARO output peak-to-average ratio PL(AV) = 60 W Conditions 6.4 7.0 - dB PL(M) peak output power 257 300 - W All information provided in this document is subject to legal disclaimers. Rev. 5 — 1 September 2015 © Ampleon The Netherlands B.V. 2015. All rights reserved. 3 of 15 BLF8G20LS-260A Power LDMOS transistor 7. Test information 7.1 Ruggedness in Doherty operation The BLF8G20LS-260A is capable of withstanding a load mismatch corresponding to a VSWR = 10 : 1 through all phases under the following conditions: VDS = 28 V; IDq = 750 mA (main); VGS(amp)peak = 0.80 V; PL = 200 W (CW); f = 1805 MHz to 1880 MHz. 7.2 Impedance information Table 9. Typical impedance of main device Measured load-pull data of main device; IDq = 750 mA (main); VDS = 28 V. f ZS[1] ZL[1] PL[2] D[2] Gp[2] (MHz) () () (W) (%) (dB) Maximum power load 1810 1.0  j3.7 1.4  j4.1 172 56.3 15.1 1840 1.0  j3.9 1.4  j3.9 167 55.9 15.1 1880 1.1  j4.0 1.4  j3.6 162 57.4 15.3 Maximum drain efficiency load 1810 1.0  j3.7 2.6  j2.4 114 67 17.5 1840 1.0  j3.9 2.4 j2.8 126 66 17.3 1880 1.1  j4.0 2.3  j2.7 120 66 17.6 [1] ZS and ZL defined in Figure 1. [2] at 3 dB gain compression. Table 10. Typical impedance of peak device Measured load-pull data of peak device; IDq = 1200 mA (peak); VDS = 28 V. f ZS[1] ZL[1] PL[2] D[2] Gp[2] (MHz) () () (W) (%) (dB) Maximum power load BLF8G20LS-260A#5 Product data sheet 1810 0.8  j3.7 1.8  j4.5 240 54 15.3 1840 0.7  j3.9 1.8  j4.3 238 56 15.4 1880 0.7  j4.0 1.7  j4.0 233 57 15.8 All information provided in this document is subject to legal disclaimers. Rev. 5 — 1 September 2015 © Ampleon The Netherlands B.V. 2015. All rights reserved. 4 of 15 BLF8G20LS-260A Power LDMOS transistor Table 10. Typical impedance of peak device …continued Measured load-pull data of peak device; IDq = 1200 mA (peak); VDS = 28 V. f ZS[1] ZL[1] PL[2] D[2] Gp[2] (MHz) () () (W) (%) (dB) Maximum drain efficiency load 1810 0.8  j3.7 2.6  j2.6 176 67 18.1 1840 0.7  j3.9 2.4  j2.4 162 66 18.3 1880 0.7  j4.0 2.3  j2.5 163 65 18.4 [1] ZS and ZL defined in Figure 1. [2] at 3 dB gain compression. drain ZL gate ZS 001aaf059 Fig 1. Definition of transistor impedance 7.3 Recommended impedances for Doherty design Table 11. Typical impedance of main device at 1 : 1 load Measured load-pull data of main device; IDq = 750 mA (main); VDS = 28 V. f ZS[1] ZL[1] PL[2] D[3] Gp[3] (MHz) () () (dBm) (%) (dB) 1810 1.0  j3.7 1.4  j4.1 52.38 33.8 18.0 1840 1.0  j3.9 1.4  j3.8 52.23 34.3 18.1 1880 1.1  j4.0 1.3  j3.6 52.08 35.0 18.3 [1] ZS and ZL defined in Figure 1. [2] at 3 dB gain compression. [3] at PL(AV) = 47 dBm. Table 12. Typical impedance of main device at 1 : 2.5 load Measured load-pull data of main device; IDq = 750 mA (main); VDS = 28 V. BLF8G20LS-260A#5 Product data sheet f ZS[1] ZL[1] PL[2] D[3] Gp[3] (MHz) () () (dBm) (%) (dB) 1810 1.0  j3.7 2.4  j2.6 50.83 47.3 20.2 1840 1.0  j3.9 2.8  j3.0 50.47 50.2 20.8 1880 1.1  j4.0 3.1  j2.7 50.25 50.9 21.2 [1] ZS and ZL defined in Figure 1. [2] at 3 dB gain compression. [3] at PL(AV) = 47 dBm. All information provided in this document is subject to legal disclaimers. Rev. 5 — 1 September 2015 © Ampleon The Netherlands B.V. 2015. All rights reserved. 5 of 15 BLF8G20LS-260A Power LDMOS transistor Table 13. Typical impedance of peak device at 1 : 1 load Measured load-pull data of peak device; IDq = 1200 mA (peak); VDS = 28 V. ZS[1] f ZL[1] D[2] PL[2] Gp[2] (MHz) () () (dBm) (%) (dB) 1810 0.8  j3.7 2.2  j4.3 53.70 59.1 16.1 1840 0.7  j3.9 2.1  j4.0 53.69 61.2 16.3 1880 0.7  j4.0 2.1  j3.7 53.43 62.0 16.8 [1] ZS and ZL defined in Figure 1. [2] at 3 dB gain compression. Table 14. Off-state impedances of peak device f Zoff (MHz) () 1810 0.5  j0.1 1840 0.4 + j0.5 1880 0.4 + j4.0 7.4 Test circuit 40 mm 40 mm R17 C1 C11 L5 R28 C17 L3 C16 C18 C19 + C20 - C21 C13 C14 C22 R30 C31 80 mm C30 X1 C32 R27 C10 C23 C15 C24 C2 C12 L6 R18 C26 C29 C27 + R29 C28 - L4 aaa-004804 Printed-Circuit Board (PCB): Rogers RO4350; thickness = 0.508 mm. See Table 15 for list of components. Fig 2. BLF8G20LS-260A#5 Product data sheet Component layout for test circuit All information provided in this document is subject to legal disclaimers. Rev. 5 — 1 September 2015 © Ampleon The Netherlands B.V. 2015. All rights reserved. 6 of 15 BLF8G20LS-260A Power LDMOS transistor Table 15. List of components For test circuit, see Figure 2. Component Description Value C1, C2, C18, C29 multilayer ceramic chip capacitor Remarks 1 F Murata C11, C12, C14, C15, C16, multilayer ceramic chip capacitor C22, C23, C25, C31 30 pF ATC100B C13 0.5 pF ATC800B multilayer ceramic chip capacitor C17, C26 multilayer ceramic chip capacitor 100 nF Murata C19, C27, C30, C32 multilayer ceramic chip capacitor 10 F Murata C20, C28 electrolytic capacitor 2200 F Panasonic C21 multilayer ceramic chip capacitor 0.3 pF ATC800B C24 multilayer ceramic chip capacitor 1.2 pF ATC800B R17, R18 resistor 5.1  SMD1206 R27 resistor 50  EMC R28, R29 resistor 9.1  Vishay Dale R30 resistor 5.6  SMD1206 L3, L4 ferrite bead - Fair Rite 2743019447 L5, L6 inductor 12 nH Coilcraft X1 hybrid coupler - Anaren X3C19P1-03S 7.5 Graphical data 7.5.1 CW pulsed aaa-004802 17 60 ηD Gp (dB) 16 ηD (%) Gp (dB) 16 15 40 15 14 30 14 20 13 10 12 13 11 0 50 100 150 200 250 300 PL (W) 0 350 40 (1) (2) (3) 30 10 11 0 38 VDS = 28 V; IDq = 746 mA; VGS(amp)peak = 0.80 V. 42 (2) f = 1842.5 MHz (2) f = 1842.5 MHz (3) f = 1880 MHz (3) f = 1880 MHz BLF8G20LS-260A#5 Product data sheet 46 50 54 PL (dBm) 58 VDS = 28 V; IDq = 746 mA; VGS(amp)peak = 0.80 V. (1) f = 1805 MHz Power gain and drain efficiency as function of output power; typical values 20 Gp (1) f = 1805 MHz Fig 3. ηD (%) 50 Gp 12 60 ηD 50 (1) (2) (3) aaa-004805 17 Fig 4. Power gain and drain efficiency as function of output power; typical values All information provided in this document is subject to legal disclaimers. Rev. 5 — 1 September 2015 © Ampleon The Netherlands B.V. 2015. All rights reserved. 7 of 15 BLF8G20LS-260A Power LDMOS transistor aaa-004806 -2 RLin (dB) -6 -10 (1) (2) -14 (3) -18 38 42 46 50 54 PL (dBm) 58 VDS = 28 V; IDq = 746 mA; VGS(amp)peak = 0.80 V. (1) f = 1805 MHz (2) f = 1842.5 MHz (3) f = 1880 MHz Fig 5. Input return loss as a function of output power; typical values 7.5.2 2-Carrier W-CDMA 2-carrier W-CDMA; PAR = 7.5 dB per carrier at 0.01 % probability on the CCDF; 3GPP test model with 64 DPCH (46 % clipping). aaa-004807 17 Gp (dB) 60 ηD (%) Gp aaa-004808 17 60 Gp (dB) ηD (%) Gp 15 (1) (2) (3) 13 ηD 11 50 15 50 40 13 40 30 11 30 (1) (2) (3) ηD 9 0 20 40 60 80 100 120 PL (W) 20 140 9 20 38 VDS = 28 V; IDq = 746 mA; VGS(amp)peak = 0.80 V. 40 42 (1) f = 1805 MHz (2) f = 1842.5 MHz (2) f = 1842.5 MHz (3) f = 1877.5 MHz (3) f = 1880 MHz Power gain and drain efficiency as function of output power; typical values BLF8G20LS-260A#5 Product data sheet 46 48 50 PL (dBm) 52 VDS = 28 V; IDq = 746 mA; VGS(amp)peak = 0.80 V. (1) f = 1807.5 MHz Fig 6. 44 Fig 7. Power gain and drain efficiency as function of output power; typical values All information provided in this document is subject to legal disclaimers. Rev. 5 — 1 September 2015 © Ampleon The Netherlands B.V. 2015. All rights reserved. 8 of 15 BLF8G20LS-260A Power LDMOS transistor aaa-004809 0 aaa-007000 -10 ACPR5M (dBc) RLin (dB) -4 -20 -8 -30 (1) (2) (3) ACPR5M -10 ACPR10M (dBc) -20 -30 ACPR10M (1) (2) -12 (1) (2) (3) -40 -40 (3) -16 -50 38 40 42 44 46 48 50 52 PL (dBm) 54 0 VDS = 28 V; IDq = 746 mA; VGS(amp)peak = 0.80 V. 20 40 80 100 120 PL (W) -50 140 VDS = 28 V; IDq = 746 mA; VGS(amp)peak = 0.80 V. (1) f = 1807.5 MHz (1) f = 1807.5 MHz (2) f = 1842.5 MHz (2) f = 1842.5 MHz (3) f = 1877.5 MHz (3) f = 1877.5 MHz Fig 8. 60 Input return loss as a function of output power; typical values Fig 9. Adjacent channel power ratio (5 MHz) and Adjacent channel power ratio (10 MHz) as function of output power; typical values 7.5.3 1-Carrier W-CDMA 1-carrier W-CDMA; PAR = 9.65 dB per carrier at 0.01 % probability on the CCDF; 3GPP test model with 64 DPCH (no clipping). aaa-006997 17 Gp (dB) 60 ηD (%) Gp 15 (2) (2) (1) (1) 13 9 0 50 -20 40 -30 30 -40 20 120 -50 (1) (2) ηD 11 aaa-006998 -10 ACPR5M (dBc) 20 40 60 80 100 PL (W) VDS = 28 V; IDq = 746 mA; VGS(amp)peak = 0.80 V. 0 20 (1) f = 1810 MHz (2) f = 1875 MHz (2) f = 1875 MHz BLF8G20LS-260A#5 Product data sheet 60 80 100 PL (W) 120 VDS = 28 V; IDq = 746 mA; VGS(amp)peak = 0.80 V. (1) f = 1810 MHz Fig 10. Power gain and drain efficiency as function of output power; typical values 40 Fig 11. Adjacent channel power ratio (5 MHz) as a function of output power; typical values All information provided in this document is subject to legal disclaimers. Rev. 5 — 1 September 2015 © Ampleon The Netherlands B.V. 2015. All rights reserved. 9 of 15 BLF8G20LS-260A Power LDMOS transistor aaa-006999 0 RLin (dB) -4 -8 (1) (2) -12 -16 0 20 40 60 80 100 PL (W) 120 VDS = 28 V; IDq = 746 mA; VGS(amp)peak = 0.80 V. (1) f = 1810 MHz (2) f = 1875 MHz Fig 12. Input return loss as a function of output power; typical values BLF8G20LS-260A#5 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 5 — 1 September 2015 © Ampleon The Netherlands B.V. 2015. All rights reserved. 10 of 15 BLF8G20LS-260A Power LDMOS transistor 8. Package outline Earless flanged balanced ceramic package; 4 leads SOT539B D A F 5 D1 D U1 H1 w2 1 c D 2 E1 U2 H E L 3 4 w3 b Q e 0 5 10 mm scale Dimensions Unit(1) w2 w3 0.25 0.25 max 0.185 0.465 0.007 1.242 1.241 0.374 0.375 0.069 0.674 1.005 0.137 0.089 1.275 0.405 inches nom 0.01 0.54 min 0.165 0.455 0.004 1.218 1.219 0.366 0.365 0.059 0.634 0.995 0.117 0.079 1.265 0.395 0.01 mm max nom min A b 4.7 11.81 c D D1 0.18 31.55 31.52 E E1 9.5 9.53 e F H H1 L Q U1 U2 1.75 17.12 25.53 3.48 2.26 32.39 10.29 1.50 16.10 25.27 2.97 2.01 32.13 10.03 13.72 4.2 11.56 0.10 30.94 30.96 9.3 9.27 Note 1. millimeter dimensions are derived from the original inch dimensions. Outline version References IEC JEDEC JEITA sot539b_po European projection Issue date 12-05-02 13-05-24 SOT539B Fig 13. Package outline SOT539B BLF8G20LS-260A#5 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 5 — 1 September 2015 © Ampleon The Netherlands B.V. 2015. All rights reserved. 11 of 15 BLF8G20LS-260A Power LDMOS transistor 9. Handling information CAUTION This device is sensitive to ElectroStatic Discharge (ESD). Observe precautions for handling electrostatic sensitive devices. Such precautions are described in the ANSI/ESD S20.20, IEC/ST 61340-5, JESD625-A or equivalent standards. 10. Abbreviations Table 16. Abbreviations Acronym Description 3GPP Third Generation Partnership Project CCDF Complementary Cumulative Distribution Function CW Continuous Wave DPCH Dedicated Physical CHannel ESD ElectroStatic Discharge GSM Global System for Mobile communications LDMOS Laterally Diffused Metal-Oxide Semiconductor PAR Peak-to-Average Ratio SMD Surface Mounted Device VSWR Voltage Standing Wave Ratio W-CDMA Wideband Code Division Multiple Access 11. Revision history Table 17. Revision history Document ID Release date Data sheet status BLF8G20LS-260A#5 20150901 Product data sheet Modifications: Change notice Supersedes BLF8G20LS-260A v.4 • The format of this document has been redesigned to comply with the new identity guidelines of Ampleon. • Legal texts have been adapted to the new company name where appropriate. BLF8G20LS-260A v.4 20130712 Product data sheet - BLF8G20LS-260A v.3 BLF8G20LS-260A v.3 20130501 Product data sheet - BLF8G20LS-260A v.2 BLF8G20LS-260A v.2 20121109 Preliminary data sheet - BLF8G20LS-260A v.1 BLF8G20LS-260A v.1 20120913 Objective data sheet - - BLF8G20LS-260A#5 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 5 — 1 September 2015 © Ampleon The Netherlands B.V. 2015. All rights reserved. 12 of 15 BLF8G20LS-260A Power LDMOS transistor 12. Legal information 12.1 Data sheet status Document status[1][2] Product status[3] Definition Objective [short] data sheet Development This document contains data from the objective specification for product development. Preliminary [short] data sheet Qualification This document contains data from the preliminary specification. Product [short] data sheet Production This document contains the product specification. [1] Please consult the most recently issued document before initiating or completing a design. [2] The term ‘short data sheet’ is explained in section “Definitions”. [3] The product status of device(s) described in this document may have changed since this document was published and may differ in case of multiple devices. The latest product status information is available on the Internet at URL http://www.ampleon.com. 12.2 Definitions Draft — The document is a draft version only. The content is still under internal review and subject to formal approval, which may result in modifications or additions. Ampleon does not give any representations or warranties as to the accuracy or completeness of information included herein and shall have no liability for the consequences of use of such information. Short data sheet — A short data sheet is an extract from a full data sheet with the same product type number(s) and title. A short data sheet is intended for quick reference only and should not be relied upon to contain detailed and full information. For detailed and full information see the relevant full data sheet, which is available on request via the local Ampleon sales office. In case of any inconsistency or conflict with the short data sheet, the full data sheet shall prevail. Product specification — The information and data provided in a Product data sheet shall define the specification of the product as agreed between Ampleon and its customer, unless Ampleon and customer have explicitly agreed otherwise in writing. In no event however, shall an agreement be valid in which the Ampleon product is deemed to offer functions and qualities beyond those described in the Product data sheet. 12.3 Disclaimers Limited warranty and liability — Information in this document is believed to be accurate and reliable. However, Ampleon does not give any representations or warranties, expressed or implied, as to the accuracy or completeness of such information and shall have no liability for the consequences of use of such information. Ampleon takes no responsibility for the content in this document if provided by an information source outside of Ampleon. In no event shall Ampleon be liable for any indirect, incidental, punitive, special or consequential damages (including - without limitation - lost profits, lost savings, business interruption, costs related to the removal or replacement of any products or rework charges) whether or not such damages are based on tort (including negligence), warranty, breach of contract or any other legal theory. Notwithstanding any damages that customer might incur for any reason whatsoever, Ampleon’ aggregate and cumulative liability towards customer for the products described herein shall be limited in accordance with the Terms and conditions of commercial sale of Ampleon. Right to make changes — Ampleon reserves the right to make changes to information published in this document, including without limitation specifications and product descriptions, at any time and without notice. This document supersedes and replaces all information supplied prior to the publication hereof. Suitability for use — Ampleon products are not designed, authorized or warranted to be suitable for use in life support, life-critical or safety-critical systems or equipment, nor in applications where failure or malfunction of an BLF8G20LS-260A#5 Product data sheet Ampleon product can reasonably be expected to result in personal injury, death or severe property or environmental damage. Ampleon and its suppliers accept no liability for inclusion and/or use of Ampleon products in such equipment or applications and therefore such inclusion and/or use is at the customer’s own risk. Applications — Applications that are described herein for any of these products are for illustrative purposes only. Ampleon makes no representation or warranty that such applications will be suitable for the specified use without further testing or modification. Customers are responsible for the design and operation of their applications and products using Ampleon products, and Ampleon accepts no liability for any assistance with applications or customer product design. It is customer’s sole responsibility to determine whether the Ampleon product is suitable and fit for the customer’s applications and products planned, as well as for the planned application and use of customer’s third party customer(s). Customers should provide appropriate design and operating safeguards to minimize the risks associated with their applications and products. Ampleon does not accept any liability related to any default, damage, costs or problem which is based on any weakness or default in the customer’s applications or products, or the application or use by customer’s third party customer(s). Customer is responsible for doing all necessary testing for the customer’s applications and products using Ampleon products in order to avoid a default of the applications and the products or of the application or use by customer’s third party customer(s). Ampleon does not accept any liability in this respect. Limiting values — Stress above one or more limiting values (as defined in the Absolute Maximum Ratings System of IEC 60134) will cause permanent damage to the device. Limiting values are stress ratings only and (proper) operation of the device at these or any other conditions above those given in the Recommended operating conditions section (if present) or the Characteristics sections of this document is not warranted. Constant or repeated exposure to limiting values will permanently and irreversibly affect the quality and reliability of the device. Terms and conditions of commercial sale — Ampleon products are sold subject to the general terms and conditions of commercial sale, as published at http://www.ampleon.com/terms, unless otherwise agreed in a valid written individual agreement. In case an individual agreement is concluded only the terms and conditions of the respective agreement shall apply. Ampleon hereby expressly objects to applying the customer’s general terms and conditions with regard to the purchase of Ampleon products by customer. No offer to sell or license — Nothing in this document may be interpreted or construed as an offer to sell products that is open for acceptance or the grant, conveyance or implication of any license under any copyrights, patents or other industrial or intellectual property rights. Export control — This document as well as the item(s) described herein may be subject to export control regulations. Export might require a prior authorization from competent authorities. All information provided in this document is subject to legal disclaimers. Rev. 5 — 1 September 2015 © Ampleon The Netherlands B.V. 2015. All rights reserved. 13 of 15 BLF8G20LS-260A Power LDMOS transistor Non-automotive qualified products — Unless this data sheet expressly states that this specific Ampleon product is automotive qualified, the product is not suitable for automotive use. It is neither qualified nor tested in accordance with automotive testing or application requirements. Ampleon accepts no liability for inclusion and/or use of non-automotive qualified products in automotive equipment or applications. In the event that customer uses the product for design-in and use in automotive applications to automotive specifications and standards, customer (a) shall use the product without Ampleon’ warranty of the product for such automotive applications, use and specifications, and (b) whenever customer uses the product for automotive applications beyond Ampleon’ specifications such use shall be solely at customer’s own risk, and (c) customer fully indemnifies Ampleon for any liability, damages or failed product claims resulting from customer design and use of the product for automotive applications beyond Ampleon’ standard warranty and Ampleon’ product specifications. 12.4 Trademarks Notice: All referenced brands, product names, service names and trademarks are the property of their respective owners. Any reference or use of any ‘NXP’ trademark in this document or in or on the surface of Ampleon products does not result in any claim, liability or entitlement vis-à-vis the owner of this trademark. Ampleon is no longer part of the NXP group of companies and any reference to or use of the ‘NXP’ trademarks will be replaced by reference to or use of Ampleon’s own Any reference or use of any ‘NXP’ trademark in this document or in or on the surface of Ampleon products does not result in any claim, liability or entitlement vis-à-vis the owner of this trademark. Ampleon is no longer part of the NXP group of companies and any reference to or use of the ‘NXP’ trademarks will be replaced by reference to or use of Ampleon’s own trademarks. Translations — A non-English (translated) version of a document is for reference only. The English version shall prevail in case of any discrepancy between the translated and English versions. 13. Contact information For more information, please visit: http://www.ampleon.com BLF8G20LS-260A#5 Product data sheet For sales office addresses, please visit: http://www.ampleon.com/sales All information provided in this document is subject to legal disclaimers. Rev. 5 — 1 September 2015 © Ampleon The Netherlands B.V. 2015. All rights reserved. 14 of 15 BLF8G20LS-260A Power LDMOS transistor 14. Contents 1 1.1 1.2 1.3 2 3 4 5 6 7 7.1 7.2 7.3 7.4 7.5 7.5.1 7.5.2 7.5.3 8 9 10 11 12 12.1 12.2 12.3 12.4 13 14 Product profile . . . . . . . . . . . . . . . . . . . . . . . . . . 1 General description . . . . . . . . . . . . . . . . . . . . . 1 Features and benefits. . . . . . . . . . . . . . . . . . . . 1 Applications . . . . . . . . . . . . . . . . . . . . . . . . . . . 1 Pinning information . . . . . . . . . . . . . . . . . . . . . . 2 Ordering information . . . . . . . . . . . . . . . . . . . . . 2 Limiting values. . . . . . . . . . . . . . . . . . . . . . . . . . 2 Thermal characteristics . . . . . . . . . . . . . . . . . . 2 Characteristics . . . . . . . . . . . . . . . . . . . . . . . . . . 3 Test information . . . . . . . . . . . . . . . . . . . . . . . . . 4 Ruggedness in Doherty operation . . . . . . . . . . 4 Impedance information . . . . . . . . . . . . . . . . . . . 4 Recommended impedances for Doherty design 5 Test circuit. . . . . . . . . . . . . . . . . . . . . . . . . . . . . 6 Graphical data . . . . . . . . . . . . . . . . . . . . . . . . . 7 CW pulsed . . . . . . . . . . . . . . . . . . . . . . . . . . . . 7 2-Carrier W-CDMA . . . . . . . . . . . . . . . . . . . . . . 8 1-Carrier W-CDMA . . . . . . . . . . . . . . . . . . . . . . 9 Package outline . . . . . . . . . . . . . . . . . . . . . . . . 11 Handling information. . . . . . . . . . . . . . . . . . . . 12 Abbreviations . . . . . . . . . . . . . . . . . . . . . . . . . . 12 Revision history . . . . . . . . . . . . . . . . . . . . . . . . 12 Legal information. . . . . . . . . . . . . . . . . . . . . . . 13 Data sheet status . . . . . . . . . . . . . . . . . . . . . . 13 Definitions . . . . . . . . . . . . . . . . . . . . . . . . . . . . 13 Disclaimers . . . . . . . . . . . . . . . . . . . . . . . . . . . 13 Trademarks. . . . . . . . . . . . . . . . . . . . . . . . . . . 14 Contact information. . . . . . . . . . . . . . . . . . . . . 14 Contents . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 15 Please be aware that important notices concerning this document and the product(s) described herein, have been included in section ‘Legal information’. © Ampleon The Netherlands B.V. 2015. All rights reserved. For more information, please visit: http://www.ampleon.com For sales office addresses, please visit: http://www.ampleon.com/sales Date of release: 1 September 2015 Document identifier: BLF8G20LS-260A#5
BLF8G20LS-260A,112 价格&库存
很抱歉,暂时无法提供与“BLF8G20LS-260A,112”相匹配的价格&库存,您可以联系我们找货
