BLM7G24S-30BGY
BLM7G24S-30BGY
    AMPLEON(安谱隆)
    SOT-1212-1
    FET RF 65V 2.17GHZ 16HSOP
BLM7G24S-30BGY 数据手册
BLM7G24S-30BG LDMOS 2-stage power MMIC Rev. 3 — 1 September 2015 Product data sheet 1. Product profile 1.1 General description The BLM7G24S-30BG is a 2-stage power MMIC using Ampleon’s state of the art Gen7 LDMOS technology. This device is perfectly suited as general purpose driver in the frequency range from 2100 MHz to 2400 MHz. Available in gull wing. Table 1. Application performance Typical RF performance at Tcase = 25 C; IDq1 = 75 mA; IDq2 = 233 mA. Test signal: 3GPP test model 1; 64 DPCH; clipping at 46 %; PAR = 8.4 dB at 0.01% probability on CCDF per carrier; carrier spacing = 5 MHz; unless otherwise specified in a class-AB application circuit. f VDS PL(AV) Gp D ACPR (MHz) (V) (W) (dB) (%) (dBc) 2-carrier W-CDMA 2140 28 1.6 31.5 11.3 43 2-carrier W-CDMA 2350 28 1.6 29.3 10.7 42 Test signal 1.2 Features and benefits          Integrated temperature compensated bias Biasing of individual stages is externally accessible Integrated current sense Integrated ESD protection Excellent thermal stability High power gain On-chip matching for ease of use (input matched to 50 ; output partially matched) Designed for broadband operation (frequency 2100 MHz to 2400 MHz) Compliant to Directive 2002/95/EC, regarding Restriction of Hazardous Substances (RoHS) 1.3 Applications RF power MMIC for W-CDMA base stations in the 2100 MHz to 2400 MHz frequency range. BLM7G24S-30BG LDMOS 2-stage power MMIC 2. Pinning information 2.1 Pinning pin 1 index VDS(A1) VGSS(A2) VDSS(A2) RF_IN_A VGSS(A1) VDSS(A1) n.c. n.c. n.c. n.c. n.c. n.c. n.c. n.c. 1 2 3 4 5 6 7 16 RF_OUT_A / VDS(A2) 8 9 10 11 12 13 14 15 n.c. aaa-009675 Transparent top view The exposed backside of the package is the ground terminal of the device. Fig 1. Pin configuration 2.2 Pin description Table 2. BLM7G24S-30BG#3 Product data sheet Pin description Symbol Pin Description VDS(A1) 1 drain-source voltage of stage A1 VGSS(A2) 2 gate sense FET and gate source voltage of stage A2 VDSS(A2) 3 drain sense FET source voltage of stage A2 RF_IN_A 4 RF input path A VGSS(A1) 5 gate sense FET and gate source voltage of stage A1 VDSS(A1) 6 drain sense FET source voltage of stage A1 n.c. 7 not connected n.c. 8 not connected n.c. 9 not connected n.c. 10 not connected n.c. 11 not connected n.c. 12 not connected n.c. 13 not connected n.c. 14 not connected All information provided in this document is subject to legal disclaimers. Rev. 3 — 1 September 2015 © Ampleon The Netherlands B.V. 2015. All rights reserved. 2 of 19 BLM7G24S-30BG LDMOS 2-stage power MMIC Table 2. Pin description …continued Symbol Pin Description n.c. 15 not connected RF_OUT_A/VDS(A2) 16 RF output path A / drain source voltage of stage A2 GND flange RF ground 3. Ordering information Table 3. Ordering information Type number Package BLM7G24S-30BG Name Description Version HSOP16 plastic, heatsink small outline package; 16 leads SOT1212-2 4. Block diagram VDS(A1) RF_IN_A VGSS(A1) VDSS(A1) VGSS(A2) VDSS(A2) RF_OUT_A / VDS(A2) TEMPERATURE COMPENSATED BIAS n.c. n.c. n.c. n.c. n.c. n.c. n.c. aaa-009676 Fig 2. Block diagram of BLM7G24S-30BG 5. Limiting values Table 4. Limiting values In accordance with the Absolute Maximum Rating System (IEC 60134). Symbol Parameter VDS Product data sheet Min Max Unit drain-source voltage - 65 V VGS gate-source voltage 0.5 +13 V VGS(sense) sense gate-source voltage 0.5 +9 V Tstg storage temperature 65 +150 C - 225 C - 150 C Tj junction temperature Tcase case temperature [1] BLM7G24S-30BG#3 Conditions [1] Continuous use at maximum temperature will affect the MTTF. All information provided in this document is subject to legal disclaimers. Rev. 3 — 1 September 2015 © Ampleon The Netherlands B.V. 2015. All rights reserved. 3 of 19 BLM7G24S-30BG LDMOS 2-stage power MMIC 6. Thermal characteristics Table 5. Thermal characteristics Measured for total device. Symbol Parameter Rth(j-c) [1] Conditions thermal resistance from junction to case Value Unit final stage; Tcase = 90 C; PL = 1.6 W [1] 2.2 K/W driver stage; Tcase = 90 C; PL = 1.6 W [1] 6.4 K/W When operated with a CW signal. 7. Characteristics Table 6. DC characteristics Tcase = 25 C unless otherwise specified. Symbol Parameter Conditions Min Typ Max Unit 65 - - V Final stage V(BR)DSS drain-source breakdown voltage VGS = 0 V; ID = 0.422 mA VGS(th) gate-source threshold voltage VDS = 10 V; ID = 42 mA 1.5 1.9 2.3 V VGSq gate-source quiescent voltage VDS = 28 V; ID = 253 mA 1.7 2.1 2.5 V IDSS drain leakage current VGS = 0 V; VDS = 28 V - - 1.4 A IDSX drain cut-off current VGS = VGS(th) + 3.75 V; VDS = 10 V - 7.8 - A IGSS gate leakage current VGS = 11 V; VDS = 0 V - - 140 nA VDS = 10 V; ID = 1478 mA gfs forward transconductance - 2.85 - S RDS(on) drain-source on-state resistance VGS = VGS(th) + 3.75 V; ID = 1.48 A - 350 - m IDq quiescent drain current 208 233 257 mA main transistor: VDS = 28 V sense transistor: ID = 7 mA; VDS = 28 V Driver stage V(BR)DSS drain-source breakdown voltage VGS = 0 V; ID = 0.116 mA 65 - - V VGS(th) gate-source threshold voltage VDS = 10 V; ID = 11.6 mA 1.5 1.9 2.3 V VGSq gate-source quiescent voltage VDS = 28 V; ID = 69.6 mA 1.7 2.1 2.5 V IDSS drain leakage current VGS = 0 V; VDS = 28 V - - 1.4 A IDSX drain cut-off current VGS = VGS(th) + 3.75 V; VDS = 10 V - 2.2 - A IGSS gate leakage current VGS = 11 V; VDS = 0 V - - 140 nA gfs forward transconductance VDS = 10 V; ID = 406 mA - 0.8 - S RDS(on) drain-source on-state resistance VGS = VGS(th) + 3.75 V; ID = 0.4 A - 2350 - m IDq quiescent drain current 67 75 mA main transistor: VDS = 28 V 83 sense transistor: ID = 7 mA; VDS = 28 V BLM7G24S-30BG#3 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 3 — 1 September 2015 © Ampleon The Netherlands B.V. 2015. All rights reserved. 4 of 19 BLM7G24S-30BG LDMOS 2-stage power MMIC Table 7. RF Characteristics Typical RF performance at Tcase = 25 C; VDS = 28 V; IDq1 = 75 mA; IDq2 = 233 mA. Test signal: 2-carrier W-CDMA; 3GPP test model 1; 64 DPCH; clipping at 46 %; PAR = 8.4 dB at 0.01% probability on CCDF per carrier; carrier spacing = 5 MHz; f1 = 2112.5 MHz; f2 = 2117.5 MHz; f3 = 2162.5 MHz; f4 = 2167.5 MHz; unless otherwise specified measured in a class-AB production circuit. Symbol Parameter Conditions Min Typ Max Unit Gp power gain PL(AV) = 1.6 W 29.5 31.5 33.5 dB D drain efficiency PL(AV) = 1.6 W 10 11.3 - % RLin input return loss PL(AV) = 1.6 W - 17 10 dB ACPR adjacent channel power ratio PL(AV) = 1.6 W - 43 40 dBc 8. Application information 8.1 Circuit information for application circuit (2.1 GHz to 2.2 GHz) Table 8. List of components For test circuit see Figure 3. BLM7G24S-30BG#3 Product data sheet Component Description Value C1, C4, C100, C200 capacitor 10 F Remarks C2, C5, C6, capacitor 1 F C3, C7, C10 capacitor 8.2 pF [1] C8 capacitor 1.6 pF [1] C9 capacitor 0.4 pF [1] C11 electrolytic capacitor 470 F C101, C201 capacitor 100 nF C102, C103, C105, C202, C203, C205 capacitor 12 pF C104, C204 capacitor 4.7 F [2] C21, C22, C23, C24, C25, C26, C27, C28, capacitor C29, C30, C31, C300, C301, C302, C303, C304, C305, C400, C401, C402, C403, C404, C405 - D100, D200 IC: LM4051 - D300, D400 IC - not mounted P100 potentiometer - do not populate P400 potentiometer - not mounted Q100, Q200 IC - LM7341 Q300, Q400 IC - not mounted R1 ferrite bead - R100, R200 resistor 4.7  R101, R108, R110, R208 resistor 0 R102 resistor 360  1% tolerance R103 resistor 330  1% tolerance R104, R203 resistor 68 k R105 resistor 10 k All information provided in this document is subject to legal disclaimers. Rev. 3 — 1 September 2015 not mounted © Ampleon The Netherlands B.V. 2015. All rights reserved. 5 of 19 BLM7G24S-30BG LDMOS 2-stage power MMIC Table 8. List of components …continued For test circuit see Figure 3. Component Description Value R106, R205 resistor 820  R107, R206 resistor 47  R109, R209 resistor 300 k R201 resistor 180  1% tolerance R202 resistor 3.6 k 1% tolerance R204 resistor 9.1 k R207 resistor 1 k R21, R300, R301, R302, R303, R304, R305, resistor R306, R307, R308, R309, R400, R401, R402, R403, R404, R405, R406, R407, R408, R409 BLM7G24S-30BG#3 Product data sheet [1] American Technical Ceramics type 100B or capacitor of same quality. [2] American Technical Ceramics type 100A or capacitor of same quality. All information provided in this document is subject to legal disclaimers. Rev. 3 — 1 September 2015 - Remarks not mounted © Ampleon The Netherlands B.V. 2015. All rights reserved. 6 of 19 xxxxxxxxxxxxxxxxxxxxx xxxxxxxxxxxxxxxxxxxxxxxxxx xxxxxxx x x x xxxxxxxxxxxxxxxxxxxxxxxxxxxxxx xxxxxxxxxxxxxxxxxxx xx xx xxxxx xxxxxxxxxxxxxxxxxxxxxxxxxxx xxxxxxxxxxxxxxxxxxx xxxxxx xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx xxxxxxxxxxxx x x xxxxxxxxxxxxxxxxxxxxx xxxxxxxxxxxxxxxxxxxxxxxxxxxxxx xxxxx xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx xxxxxxxx xxxxxxxxxxxxxxxxxxxxxxxxx xxxxxxxxxxxxxxxxxxxx xxx BLM7G24S-30BG#3 Product data sheet Vbias(A2) VDS(A1) R1 Vds-A2 GND GND R100 VGSS(A2) P100 C1 R101 C101 C201 C202 R110 VGSS(A1) R201 C103 R202 C205 C203 C303 C305 R304 R305 C28 C403 15 R408 R303 14 C301 C302 VDSS(B2) R406 R410 VGSS(B1) BLM7G22S-60PBG 2110-2170 MHz RO4350 / 30 mil R208 R308 R207 C204 R206 R307 C304 R306 Q300 16 R108 R205 R204 C8 1 Rev. 3 — 1 September 2015 All information provided in this document is subject to legal disclaimers. R107 C105 Q200 R203 C200 VDSS(A1) GND VDSS(B1) R309 C300 D300 C405 R404 R407 C404 R105 R409 C26 C400 C10 C104 R104 R106 R301 R302 C9 C7 C6 D100 D200 R300 C11 R105 R209 Vbias(A1) C4 C3 Q100 VDSS(A2) Vbias(B1) C5 R109 R102 C100 R200 C2 C102 R103 C27 C30 D400 C23 R402 C401 R403 C29 Q400 C24 C402 C31 C25 R401 R400 P400 GND R21 Vbias(B2) VDS(B1) VGSS(B2) Vds-B2 aaa-004523 Printed-Circuit Board (PCB): Rogers 4350; thickness = 0.762 mm. See Table 8 for a list of components. Fig 3. Component layout for class-AB application circuit with auto-bias (a halve section of the BLM7G22S-60PBG [section A] is used for characterization) LDMOS 2-stage power MMIC 7 of 19 © Ampleon The Netherlands B.V. 2015. All rights reserved. C21 GND BLM7G24S-30BG C22 BLM7G24S-30BG LDMOS 2-stage power MMIC 8.2 Performance curves (2.1 GHz to 2.2 GHz) Performance curves are measured in a class-AB dedicated application circuit with auto-bias from 2.1 GHz to 2.2 GHz, see Table 8 and Figure 3. 8.2.1 W-CDMA aaa-004511 35 15 Gp (dB) ηD (%) 33 13 -42 11 -44 29 9 -46 27 7 -48 31 Gp ηD 25 2050 2100 2150 2200 f (MHz) 5 2250 -50 2050 Tcase = 25 C; VDS = 28 V; PL(AV) = 1.6 W; IDq1 = 75 mA; IDq2 = 233 mA; carrier spacing = 5 MHz. Fig 4. Power gain and drain efficiency as function of frequency; typical values aaa-004513 34 2100 2150 2200 f (MHz) Fig 5. Adjacent channel power ratio as a function of frequency; typical values aaa-004514 0 ηD (%) 2250 Tcase = 25 C; VDS = 28 V; PL(AV) = 1.6 W; IDq1 = 75 mA; IDq2 = 233 mA; carrier spacing = 5 MHz. 40 Gp (dB) aaa-004512 -40 ACPR (dBc) ACPR (dBc) -10 32 30 Gp -20 30 20 -30 ηD 28 10 -40 26 0 0 2 4 6 8 10 12 PL (W) -50 14 0 Tcase = 25 C; VDS = 28 V; f = 2140 MHz; IDq1 = 75 mA; IDq2 = 233 mA; carrier spacing = 5 MHz. Fig 6. Power gain and drain efficiency as a function of output power; typical values BLM7G24S-30BG#3 Product data sheet 2 4 6 8 10 12 PL (W) 14 Tcase = 25 C; VDS = 28 V; f = 2140 MHz; IDq1 = 75 mA; IDq2 = 233 mA; carrier spacing = 5 MHz. Fig 7. Adjacent channel power ratio as a function of output power; typical values All information provided in this document is subject to legal disclaimers. Rev. 3 — 1 September 2015 © Ampleon The Netherlands B.V. 2015. All rights reserved. 8 of 19 BLM7G24S-30BG LDMOS 2-stage power MMIC aaa-005989 250 IDq (mA) aaa-005990 35 Gp (dB) IDq2 200 Gp (1) ηD (%) 33 32 (1) (2) (3) (2) 150 31 100 29 40 ηD 24 16 (3) IDq1 50 27 0 -40 8 25 -20 0 20 40 60 80 100 Tcase (°C) 120 0 0 2 4 6 8 10 PL (W) 12 VDS = 28 V; f = 2140 MHz; IDq1 = 75 mA; IDq2 = 233 mA; carrier spacing = 5 MHz. (1) Tcase = 30 C (2) Tcase = +25 C (3) Tcase = +100 C Fig 8. Quiescent drain current as a function of case temperature; typical values Fig 9. Power gain and drain efficiency as function of output power; typical values 8.2.2 1-Tone pulsed CW aaa-005991 32 Gp (dB) aaa-005992 35 Gp (dB) (1) 31 33 30 31 29 29 (2) (3) (3) 28 27 (2) (1) 27 25 0 5 10 15 20 25 30 35 PL (W) 40 Tcase = 25 C; VDS = 28 V; PL(AV) = 1.6 W; f = 2140 MHz; IDq1 = 75 mA; IDq2 = 233 mA;  = 10 %; tp = 100 s. 0 5 10 (1) Tcase = 30 C (2) VDD = 28 V (2) Tcase = +25 C (3) VDD = 32 V (3) Tcase = +100 C BLM7G24S-30BG#3 Product data sheet 20 25 30 35 PL (W) 40 VDS = 28 V; PL(AV) = 1.6 W; f = 2140 MHz; IDq1 = 75 mA; IDq2 = 233 mA;  = 10 %; tp = 100 s. (1) VDD = 24 V Fig 10. Power gain as a function of output power; typical values 15 Fig 11. Power gain as a function of output power; typical values All information provided in this document is subject to legal disclaimers. Rev. 3 — 1 September 2015 © Ampleon The Netherlands B.V. 2015. All rights reserved. 9 of 19 BLM7G24S-30BG LDMOS 2-stage power MMIC 8.2.3 2-Tone CW aaa-005993 -5 IMD (dBc) -25 -45 -65 IMD3 IMD5 IMD7 -85 10-1 1 10 PL(PEP) (W) 102 Tcase = 25 C; VDS = 28 V; fc = 2140 MHz; IDq1 = 75 mA; IDq2 = 233 mA; tone spacing = 100 kHz. Fig 12. Intermodulation distortion as a function of peak envelope power load power; typical values BLM7G24S-30BG#3 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 3 — 1 September 2015 © Ampleon The Netherlands B.V. 2015. All rights reserved. 10 of 19 BLM7G24S-30BG LDMOS 2-stage power MMIC 8.3 Performance curves (2.3 GHz to 2.4 GHz) Performance curves are measured in a class-AB dedicated application circuit with auto-bias from 2.3 GHz to 2.4 GHz. 8.3.1 2-Carrier W-CDMA aaa-009678 31 Gp (dB) 30.5 aaa-009679 -20 ACPR (dBc) -26 30 -32 29.5 -38 (1) (2) (3) 29 (1) (2) (3) -44 28.5 28 -50 24 28 32 36 40 44 PL (dBm) 48 VDS = 28 V; IDq1 = 220 mA; IDq2 = 75 mA; carrier spacing = 5MHz. 24 28.8 (1) f = 2300 MHz (2) f = 2350 MHz (2) f = 2350 MHz (3) f = 2400 MHz (3) f = 2400 MHz BLM7G24S-30BG#3 Product data sheet 38.4 43.2 PL (dBm) 48 VDS = 28 V; IDq1 = 220 mA; IDq2 = 75 mA; carrier spacing = 5MHz. (1) f = 2300 MHz Fig 13. Power gain as a function of output power; typical values 33.6 Fig 14. Adjacent channel power ratio as a function of output power; typical values All information provided in this document is subject to legal disclaimers. Rev. 3 — 1 September 2015 © Ampleon The Netherlands B.V. 2015. All rights reserved. 11 of 19 BLM7G24S-30BG LDMOS 2-stage power MMIC aaa-009680 35 ηD (%) 30 25 (3) (2) (1) 20 15 10 5 28 32 36 40 44 PL (dBm) 48 VDS = 28 V; IDq1 = 220 mA; IDq2 = 75 mA; carrier spacing = 5MHz. (1) f = 2300 MHz (2) f = 2350 MHz (3) f = 2400 MHz Fig 15. Drain efficiency as a function of output power; typical values 8.3.2 Pulsed CW aaa-009681 32 Gp (dB) aaa-009682 60 ηD (%) 31 50 30 40 (1) (2) (3) 29 (3) (2) (1) 30 28 20 27 10 26 0 24 28 32 36 40 44 PL (dBm) 48 VDS = 28 V; IDq1 = 220 mA; IDq2 = 75 mA;  = 10 %; tp = 100 s. 24 28 (1) f = 2300 MHz (2) f = 2350 MHz (2) f = 2350 MHz (3) f = 2400 MHz (3) f = 2400 MHz BLM7G24S-30BG#3 Product data sheet 36 40 44 PL (dBm) 48 VDS = 28 V; IDq1 = 220 mA; IDq2 = 75 mA;  = 10 %; tp = 100 s. (1) f = 2300 MHz Fig 16. Power gain as a function of output power; typical values 32 Fig 17. Efficiency as a function of output power; typical values All information provided in this document is subject to legal disclaimers. Rev. 3 — 1 September 2015 © Ampleon The Netherlands B.V. 2015. All rights reserved. 12 of 19 BLM7G24S-30BG LDMOS 2-stage power MMIC 8.4 Application without auto-bias VDS(A1) VGSS(A2) VDSS(A2) 1 2 3 4 RF_IN_A VGSS(A1) VDSS(A1) n.c. n.c. n.c. n.c. n.c. n.c. n.c. n.c. 16 RF_OUT_A / VDS(A2) 15 n.c. 5 6 7 8 9 10 11 12 13 14 aaa-009677 Connect pins 2 and 3; connect pins 5 and 6 at board level. The exposed backside of the package is the ground terminal of the device. Fig 18. Non auto-bias application 9. Test information 9.1 Ruggedness The BLM7G24S-30BG is capable of withstanding a load mismatch corresponding to VSWR = 10 : 1 through all phases under the following conditions: VDS = 28 V; IDq1 = 75 mA; IDq2 = 233 mA; PL = 27 W (W-CDMA); f = 2140 MHz. 9.2 Impedance information Table 9. Typical impedance Measured load-pull data. Typical values per section unless otherwise specified. BLM7G24S-30BG#3 Product data sheet f ZS [1] ZL [1] (MHz) () () 2080 55.62 + j18.89 15.89  j2.28 2110 55.61 + j19.04 14.74  j2.59 2140 55.60 + j19.12 13.56  j2.75 2170 55.57 + j19.25 12.38  j2.75 2200 55.53 + j19.39 11.20  j2.61 2230 55.48 + j19.55 10.05  j2.34 2300 34.51 + j41.45 7.06  j6.36 All information provided in this document is subject to legal disclaimers. Rev. 3 — 1 September 2015 © Ampleon The Netherlands B.V. 2015. All rights reserved. 13 of 19 BLM7G24S-30BG LDMOS 2-stage power MMIC Table 9. Typical impedance …continued Measured load-pull data. Typical values per section unless otherwise specified. f ZS [1] ZL [1] (MHz) () () 2350 29.26 + j36.91 6.35  j6.24 2400 22.86 + j32.52 5.65  j6.15 [1] ZS and ZL defined in Figure 19. drain ZL gate ZS 001aaf059 Fig 19. Definition of transistor impedance 9.3 Performance curves aaa-005994 60 ηD (%) 48 36 24 12 0 40 42 44 46 48 PL(1dB) (dBm) 50 Tcase = 25 C; VDS = 28 V; PL(AV) = 1.6 W; f = 2140 MHz; IDq1 = 75 mA; IDq2 = 233 mA;  = 10 %; tp = 100 s. Fig 20. One-tone pulsed CW drain efficiency at 1 dB gain compression as function of output power at 1 dB gain compression; typical values BLM7G24S-30BG#3 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 3 — 1 September 2015 © Ampleon The Netherlands B.V. 2015. All rights reserved. 14 of 19 BLM7G24S-30BG LDMOS 2-stage power MMIC 10. Package outline HSOP16: plastic, heatsink small outline package; 16 leads SOT1212-2 E X E3 A D c B D3 y v HE A D1 D2 e1 b1(2x) w 16 B (8x) METAL PROTRUSIONS (SOURCE) 15 e6 e5 (2x) (2x) Q E2 E1 A A2 (A3) A1 A4 pin 1 index θ 1 H 14 Lp detail X e2 e (12x) b (14x) w B e3 (2x) e4 (2x) HE 0 10 mm scale Dimensions (mm are the original dimensions) Unit mm max nom min A 3.9 A1 A2 A3 A4 b b1 c D(1) D1 D2 D3 E(1) Lp Q v w E1 E2 E3 e e1 e2 e3 e4 e5 θ 7° 3° 0° e6 0.2 3.65 0.06 0.40 5.55 0.27 20.62 19.00 16.05 20.44 10.01 8.18 5.89 9.83 0.1 3.60 0.35 0 0.35 5.50 0.22 20.57 18.95 16.00 20.39 9.96 8.13 5.84 9.78 1.0 7.45 1.5 8.45 9.55 2.97 4.07 -0.02 0.30 5.45 0.17 20.52 18.90 15.95 20.34 9.91 8.08 5.79 9.73 0 3.55 Note 1. Package body dimensions “D'' and `'E'' do not include mold and metal protrusions. Allowable protrusion is 0.25 mm per side. 2. Lead width dimensions `'b'' and `'b1'' do not include dambar protrusions. Allowable dambar protrusion is 0.25 mm in total per lead. 3. Dimension A4 is measured with respect to bottom of the heatsink DATUM H. Positive value means that the bottom of the heatsink is higher than the bottom of the lead. Outline version y 13.5 1.10 2.07 0.1 13.2 0.95 2.02 0.25 0.25 12.9 0.80 1.97 References IEC JEDEC JEITA European projection sot1212-2_po Issue date 15-01-14 15-06-09 SOT1212-2 Fig 21. Package outline SOT1212-2 (HSOP16) BLM7G24S-30BG#3 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 3 — 1 September 2015 © Ampleon The Netherlands B.V. 2015. All rights reserved. 15 of 19 BLM7G24S-30BG LDMOS 2-stage power MMIC 11. Handling information CAUTION This device is sensitive to ElectroStatic Discharge (ESD). Observe precautions for handling electrostatic sensitive devices. Such precautions are described in the ANSI/ESD S20.20, IEC/ST 61340-5, JESD625-A or equivalent standards. 12. Abbreviations Table 10. Abbreviations Acronym Description 3GPP 3rd Generation Partnership Project CCDF Complementary Cumulative Distribution Function CW Continuous Waveform DPCH Dedicated Physical CHannel ESD ElectroStatic Discharge FET Field-Effect Transistor Gen7 Seventh-Generation LDMOS Laterally Diffused Metal Oxide Semiconductor MMIC Monolithic Microwave Integrated Circuit MTTF Mean Time To Failure PAR Peak-to-Average Ratio VSWR Voltage Standing Wave Ratio W-CDMA Wideband Code Division Multiple Access 13. Revision history Table 11. Revision history Document ID Release date Data sheet status BLM7G24S-30BG#3 20150901 Modifications: Change notice Product data sheet Supersedes BLM7G24S-30BG v.2 • The format of this document has been redesigned to comply with the new identity guidelines of Ampleon. • Legal texts have been adapted to the new company name where appropriate. BLM7G24S-30BG v.2 20150701 Product data sheet - BLM7G24S-30BG v.1 BLM7G24S-30BG v.1 20131104 Product data sheet - - BLM7G24S-30BG#3 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 3 — 1 September 2015 © Ampleon The Netherlands B.V. 2015. All rights reserved. 16 of 19 BLM7G24S-30BG LDMOS 2-stage power MMIC 14. Legal information 14.1 Data sheet status Document status[1][2] Product status[3] Definition Objective [short] data sheet Development This document contains data from the objective specification for product development. Preliminary [short] data sheet Qualification This document contains data from the preliminary specification. Product [short] data sheet Production This document contains the product specification. [1] Please consult the most recently issued document before initiating or completing a design. [2] The term ‘short data sheet’ is explained in section “Definitions”. [3] The product status of device(s) described in this document may have changed since this document was published and may differ in case of multiple devices. The latest product status information is available on the Internet at URL http://www.ampleon.com. 14.2 Definitions Draft — The document is a draft version only. The content is still under internal review and subject to formal approval, which may result in modifications or additions. Ampleon does not give any representations or warranties as to the accuracy or completeness of information included herein and shall have no liability for the consequences of use of such information. Short data sheet — A short data sheet is an extract from a full data sheet with the same product type number(s) and title. A short data sheet is intended for quick reference only and should not be relied upon to contain detailed and full information. For detailed and full information see the relevant full data sheet, which is available on request via the local Ampleon sales office. In case of any inconsistency or conflict with the short data sheet, the full data sheet shall prevail. Product specification — The information and data provided in a Product data sheet shall define the specification of the product as agreed between Ampleon and its customer, unless Ampleon and customer have explicitly agreed otherwise in writing. In no event however, shall an agreement be valid in which the Ampleon product is deemed to offer functions and qualities beyond those described in the Product data sheet. 14.3 Disclaimers Limited warranty and liability — Information in this document is believed to be accurate and reliable. However, Ampleon does not give any representations or warranties, expressed or implied, as to the accuracy or completeness of such information and shall have no liability for the consequences of use of such information. Ampleon takes no responsibility for the content in this document if provided by an information source outside of Ampleon. In no event shall Ampleon be liable for any indirect, incidental, punitive, special or consequential damages (including - without limitation - lost profits, lost savings, business interruption, costs related to the removal or replacement of any products or rework charges) whether or not such damages are based on tort (including negligence), warranty, breach of contract or any other legal theory. Notwithstanding any damages that customer might incur for any reason whatsoever, Ampleon’ aggregate and cumulative liability towards customer for the products described herein shall be limited in accordance with the Terms and conditions of commercial sale of Ampleon. Right to make changes — Ampleon reserves the right to make changes to information published in this document, including without limitation specifications and product descriptions, at any time and without notice. This document supersedes and replaces all information supplied prior to the publication hereof. Suitability for use — Ampleon products are not designed, authorized or warranted to be suitable for use in life support, life-critical or safety-critical systems or equipment, nor in applications where failure or malfunction of an BLM7G24S-30BG#3 Product data sheet Ampleon product can reasonably be expected to result in personal injury, death or severe property or environmental damage. Ampleon and its suppliers accept no liability for inclusion and/or use of Ampleon products in such equipment or applications and therefore such inclusion and/or use is at the customer’s own risk. Applications — Applications that are described herein for any of these products are for illustrative purposes only. Ampleon makes no representation or warranty that such applications will be suitable for the specified use without further testing or modification. Customers are responsible for the design and operation of their applications and products using Ampleon products, and Ampleon accepts no liability for any assistance with applications or customer product design. It is customer’s sole responsibility to determine whether the Ampleon product is suitable and fit for the customer’s applications and products planned, as well as for the planned application and use of customer’s third party customer(s). Customers should provide appropriate design and operating safeguards to minimize the risks associated with their applications and products. Ampleon does not accept any liability related to any default, damage, costs or problem which is based on any weakness or default in the customer’s applications or products, or the application or use by customer’s third party customer(s). Customer is responsible for doing all necessary testing for the customer’s applications and products using Ampleon products in order to avoid a default of the applications and the products or of the application or use by customer’s third party customer(s). Ampleon does not accept any liability in this respect. Limiting values — Stress above one or more limiting values (as defined in the Absolute Maximum Ratings System of IEC 60134) will cause permanent damage to the device. Limiting values are stress ratings only and (proper) operation of the device at these or any other conditions above those given in the Recommended operating conditions section (if present) or the Characteristics sections of this document is not warranted. Constant or repeated exposure to limiting values will permanently and irreversibly affect the quality and reliability of the device. Terms and conditions of commercial sale — Ampleon products are sold subject to the general terms and conditions of commercial sale, as published at http://www.ampleon.com/terms, unless otherwise agreed in a valid written individual agreement. In case an individual agreement is concluded only the terms and conditions of the respective agreement shall apply. Ampleon hereby expressly objects to applying the customer’s general terms and conditions with regard to the purchase of Ampleon products by customer. No offer to sell or license — Nothing in this document may be interpreted or construed as an offer to sell products that is open for acceptance or the grant, conveyance or implication of any license under any copyrights, patents or other industrial or intellectual property rights. Export control — This document as well as the item(s) described herein may be subject to export control regulations. Export might require a prior authorization from competent authorities. All information provided in this document is subject to legal disclaimers. Rev. 3 — 1 September 2015 © Ampleon The Netherlands B.V. 2015. All rights reserved. 17 of 19 BLM7G24S-30BG LDMOS 2-stage power MMIC Non-automotive qualified products — Unless this data sheet expressly states that this specific Ampleon product is automotive qualified, the product is not suitable for automotive use. It is neither qualified nor tested in accordance with automotive testing or application requirements. Ampleon accepts no liability for inclusion and/or use of non-automotive qualified products in automotive equipment or applications. In the event that customer uses the product for design-in and use in automotive applications to automotive specifications and standards, customer (a) shall use the product without Ampleon’ warranty of the product for such automotive applications, use and specifications, and (b) whenever customer uses the product for automotive applications beyond Ampleon’ specifications such use shall be solely at customer’s own risk, and (c) customer fully indemnifies Ampleon for any liability, damages or failed product claims resulting from customer design and use of the product for automotive applications beyond Ampleon’ standard warranty and Ampleon’ product specifications. 14.4 Trademarks Notice: All referenced brands, product names, service names and trademarks are the property of their respective owners. Any reference or use of any ‘NXP’ trademark in this document or in or on the surface of Ampleon products does not result in any claim, liability or entitlement vis-à-vis the owner of this trademark. Ampleon is no longer part of the NXP group of companies and any reference to or use of the ‘NXP’ trademarks will be replaced by reference to or use of Ampleon’s own Any reference or use of any ‘NXP’ trademark in this document or in or on the surface of Ampleon products does not result in any claim, liability or entitlement vis-à-vis the owner of this trademark. Ampleon is no longer part of the NXP group of companies and any reference to or use of the ‘NXP’ trademarks will be replaced by reference to or use of Ampleon’s own trademarks. Translations — A non-English (translated) version of a document is for reference only. The English version shall prevail in case of any discrepancy between the translated and English versions. 15. Contact information For more information, please visit: http://www.ampleon.com BLM7G24S-30BG#3 Product data sheet For sales office addresses, please visit: http://www.ampleon.com/sales All information provided in this document is subject to legal disclaimers. Rev. 3 — 1 September 2015 © Ampleon The Netherlands B.V. 2015. All rights reserved. 18 of 19 BLM7G24S-30BG LDMOS 2-stage power MMIC 16. Contents 1 1.1 1.2 1.3 2 2.1 2.2 3 4 5 6 7 8 8.1 8.2 8.2.1 8.2.2 8.2.3 8.3 8.3.1 8.3.2 8.4 9 9.1 9.2 9.3 10 11 12 13 14 14.1 14.2 14.3 14.4 15 16 Product profile . . . . . . . . . . . . . . . . . . . . . . . . . . 1 General description . . . . . . . . . . . . . . . . . . . . . 1 Features and benefits. . . . . . . . . . . . . . . . . . . . 1 Applications . . . . . . . . . . . . . . . . . . . . . . . . . . . 1 Pinning information . . . . . . . . . . . . . . . . . . . . . . 2 Pinning . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 2 Pin description . . . . . . . . . . . . . . . . . . . . . . . . . 2 Ordering information . . . . . . . . . . . . . . . . . . . . . 3 Block diagram . . . . . . . . . . . . . . . . . . . . . . . . . . 3 Limiting values. . . . . . . . . . . . . . . . . . . . . . . . . . 3 Thermal characteristics . . . . . . . . . . . . . . . . . . 4 Characteristics . . . . . . . . . . . . . . . . . . . . . . . . . . 4 Application information. . . . . . . . . . . . . . . . . . . 5 Circuit information for application circuit (2.1 GHz to 2.2 GHz) . . . . . . . . . . . . . . . . . . . . 5 Performance curves (2.1 GHz to 2.2 GHz). . . . 8 W-CDMA. . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 8 1-Tone pulsed CW . . . . . . . . . . . . . . . . . . . . . . 9 2-Tone CW . . . . . . . . . . . . . . . . . . . . . . . . . . . 10 Performance curves (2.3 GHz to 2.4 GHz). . . 11 2-Carrier W-CDMA . . . . . . . . . . . . . . . . . . . . . 11 Pulsed CW . . . . . . . . . . . . . . . . . . . . . . . . . . . 12 Application without auto-bias . . . . . . . . . . . . . 13 Test information . . . . . . . . . . . . . . . . . . . . . . . . 13 Ruggedness . . . . . . . . . . . . . . . . . . . . . . . . . . 13 Impedance information . . . . . . . . . . . . . . . . . . 13 Performance curves . . . . . . . . . . . . . . . . . . . . 14 Package outline . . . . . . . . . . . . . . . . . . . . . . . . 15 Handling information. . . . . . . . . . . . . . . . . . . . 16 Abbreviations . . . . . . . . . . . . . . . . . . . . . . . . . . 16 Revision history . . . . . . . . . . . . . . . . . . . . . . . . 16 Legal information. . . . . . . . . . . . . . . . . . . . . . . 17 Data sheet status . . . . . . . . . . . . . . . . . . . . . . 17 Definitions . . . . . . . . . . . . . . . . . . . . . . . . . . . . 17 Disclaimers . . . . . . . . . . . . . . . . . . . . . . . . . . . 17 Trademarks. . . . . . . . . . . . . . . . . . . . . . . . . . . 18 Contact information. . . . . . . . . . . . . . . . . . . . . 18 Contents . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 19 Please be aware that important notices concerning this document and the product(s) described herein, have been included in section ‘Legal information’. © Ampleon The Netherlands B.V. 2015. All rights reserved. For more information, please visit: http://www.ampleon.com For sales office addresses, please visit: http://www.ampleon.com/sales Date of release: 1 September 2015 Document identifier: BLM7G24S-30BG#3
BLM7G24S-30BGY 价格&库存
很抱歉,暂时无法提供与“BLM7G24S-30BGY”相匹配的价格&库存,您可以联系我们找货
