PHC2300
Complementary enhancement mode MOS transistors
Rev. 05 — 24 February 2011
Product data sheet
1. Product profile
1.1 General description
One N-channel and one P-channel enhancement mode Field-Effect Transistor (FET) in a
plastic package. This product is designed and qualified for use in computing,
communications, consumer and industrial applications only.
1.2 Features and benefits
Suitable for high frequency
applications due to fast switching
characteristics
1.3 Applications
High-speed line drivers
Relay drivers
Line transformer drivers
Universal line interface in telephone
sets
1.4 Quick reference data
Table 1.
Symbol
Parameter
Conditions
Min
Typ
Max Unit
VDS
drain-source
voltage
Tj ≥ 25 °C; Tj ≤ 150 °C;
N-channel
300
P-channel
-300 V
ID
Ptot
drain current
total power
dissipation
V
Tsp = 80 °C; N-channel
[1]
340
Tsp = 80 °C; P-channel
[1]
-235 mA
Tsp = 80 °C
[2]
1.6
W
VGS = 10 V; ID = 170 mA;
Tj = 25 °C; N-channel
6
Ω
VGS = -10 V; ID = -115 mA;
Tj = 25 °C; P-channel
17
Ω
mA
Static characteristics
RDSon
drain-source
on-state
resistance
PHC2300
Nexperia
Table 1.
Symbol
Quick reference data …continued
Parameter
Conditions
Min
Typ
Max Unit
674
pC
1385 -
pC
Dynamic characteristics
QGD
gate-drain charge VGS = -10 V; ID = -115 mA;
VDS = -50 V; Tj = 25 °C;
P-channel
VDS = 50 V; Tj = 25 °C;
N-channel
[1]
Solder point temperature is the temperature at the soldering point of the drain leads.
[2]
Maximum permissible dissipation per MOS transistor (both devices may thus be loaded up to 1.6 W at the
same time).
2. Pinning information
Table 2.
Pin
Pinning information
Symbol Description
1
S1
source1
2
G1
gate1
3
S2
source2
4
G2
gate2
5
D2
drain2
6
D2
drain2
7
D1
drain1
8
D1
drain1
Simplified outline
Graphic symbol
8
5
D1
D1
D2
D2
1
4
S1
G1
S2
G2
sym114
SOT96-1 (SO8)
3. Ordering information
Table 3.
Type number
PHC2300
PHC2300
Product data sheet
Package
Name
Description
Version
SO8
plastic small outline package; 8 leads; body width 3.9 mm
SOT96-1
All information provided in this document is subject to legal disclaimers.
Nexperia B.V. 2017. All rights reserved
2 of 14
PHC2300
Nexperia
4. Limiting values
Table 4.
Limiting values
In accordance with the Absolute Maximum Rating System (IEC 60134).
Symbol
Parameter
Conditions
Min
Max
Unit
VDS
drain-source voltage
Tj ≥ 25 °C; Tj ≤ 150 °C; N-channel
300
V
Tj ≥ 25 °C; Tj ≤ 150 °C; P-channel
-300
V
VGS
gate-source voltage
ID
drain current
peak drain current
IDM
total power dissipation
Ptot
-20
V
[1]
340
mA
[1]
-235
mA
Tsp = 25 °C; pulsed; N-channel
[2]
1.4
A
Tsp = 25 °C; pulsed; P-channel
[2]
-0.9
A
Tsp = 80 °C
[3]
1.6
W
Tamb = 25 °C
[4]
1.8
W
Tamb = 25 °C
[5]
0.9
W
Tamb = 25 °C
[6]
1.2
W
Tstg
storage temperature
-55
150
°C
Tj
junction temperature
-55
150
°C
[1]
[2]
Pulse width and duty cycle limited by maximum junction temperature.
[3]
Maximum permissible dissipation per MOS transistor (both devices may thus be loaded up to 1.6 W at the same time).
[4]
Maximum permissible dissipation per MOS transistor. Value based on a printed-circuit board with an Rth(a-tp) (ambient to tie-point) of
27.5 K/W.
[5]
Maximum permissible dissipation per MOS transistor. Value based on a printed-circuit board with an Rth(a-tp) (ambient to tie-point) of 90
K/W.
[6]
Maximum permissible dissipation if only one MOS transistor dissipates. Value based on a printed-circuit board with an Rth(a-tp) (ambient
to tie-point) of 90 K/W.
mda235
2
mda240
10
Ptot
ID
(W)
1.6
(A)
1
(1)
1.2
10−1
0.8
δ=
P
tp
T
10−2
DC
0.4
t
tp
T
10−3
80
120
Ts (°C)
160
1
10
102
VDS (V)
103
δ = 0.01; Tsp = 80 °C.
(1) RDSon limitation.
Fig 1.
Power derating curve
PHC2300
Product data sheet
Fig 2.
SOAR; N-channel
3 of 14
PHC2300
Nexperia
mgl245
−10
ID
(A)
−1
(1)
−10−1
δ=
P
−10−2
tp
T
DC
t
tp
T
−10−3
−10
−1
−102
VDS (V)
−103
Fig 3.
SOAR; P-channel
5. Thermal characteristics
Table 5.
Symbol
Parameter
Rth(j-sp)
thermal resistance from
junction to solder point
Conditions
Min
Typ
Max
Unit
43
K/W
mda244
102
(1)
(2)
(3)
Rth js
(K/W)
(4)
10
(5)
(6)
(7)
(8)
1
δ=
P
(9)
tp
T
(10)
t
tp
T
10−1
10−6
10−5
10−4
10−3
10−2
10−1
1
tp (s)
(1) δ = 1.00. (2) δ = 0.75. (3) δ = 0.5. (4) δ = 0.33. (5) δ = 0.2.
(6) δ = 0.1. (7) δ = 0.05. (8) δ = 0.02. (9) δ = 0.01. (10) δ = 0.
Fig 4.
Transient thermal resistance from junction to soldering point as a function of pulse time for N- and
P-channel; typical values
PHC2300
Product data sheet
4 of 14
PHC2300
Nexperia
6. Characteristics
Table 6.
Characteristics
Symbol
Parameter
Conditions
Min
Typ
Max
Unit
ID = -10 µA; VGS = 0 V; Tj = 25 °C;
P-channel
-300
V
ID = 10 µA; VGS = 0 V; Tj = 25 °C;
N-channel
300
V
ID = 1 mA; VDS = VGS; Tj = 25 °C;
N-channel
0.8
2
V
ID = -1 mA; VDS = VGS; Tj = 25 °C;
P-channel
-0.8
-2
V
VDS = -240 V; VGS = 0 V; Tj = 25 °C;
P-channel
-100
nA
VDS = 240 V; VGS = 0 V; Tj = 25 °C;
N-channel
100
nA
VGS = 20 V; VDS = 0 V; Tj = 25 °C;
N-channel
100
nA
VGS = -20 V; VDS = 0 V; Tj = 25 °C;
N-channel
100
nA
P-channel
100
nA
P-channel
100
nA
VGS = 10 V; ID = 170 mA; Tj = 25 °C;
N-channel
6
Ω
VGS = -10 V; ID = -115 mA; Tj = 25 °C;
P-channel
17
Ω
ID = 170 mA; VDS = 50 V; VGS = 10 V;
6240
pC
ID = -115 mA; VDS = -50 V; VGS = -10 V;
2137
pC
226
pC
68
pC
674
pC
1385
pC
VDS = 50 V; VGS = 0 V; f = 1 MHz;
102
pF
VDS = -50 V; VGS = 0 V; f = 1 MHz;
45
pF
15
pF
15
pF
V(BR)DSS
VGS(th)
IDSS
IGSS
RDSon
drain-source
breakdown voltage
gate-source threshold
voltage
drain leakage current
gate leakage current
drain-source on-state
resistance
QG(tot)
QGS
QGD
Ciss
Coss
total gate charge
gate-source charge
gate-drain charge
input capacitance
output capacitance
PHC2300
Product data sheet
5 of 14
PHC2300
Nexperia
Table 6.
Characteristics …continued
Symbol
Parameter
Conditions
Min
Typ
Max
Unit
Crss
reverse transfer
capacitance
7.3
pF
3
pF
VDS = 50 V; VGS = 10 V; ID = 170 mA;
7
12
ns
VDS = -50 V; VGS = -10 V; ID = -115 mA;
4
10
ns
VDS = 50 V; VGS = 10 V; Tj = 25 °C;
ID = 170 mA; N-channel
53
65
ns
VDS = -50 V; VGS = -10 V; Tj = 25 °C;
ID = -115 mA; P-channel
25
35
ns
turn-on time
ton
toff
turn-off time
mld841
1200
VGS = 10 V
ID
5V
VGS = −10 V
ID
(mA)
4V
(mA)
mbh441
−800
3.5 V
−600
3V
−4.5 V
800
−4.0 V
−400
400
−3.5 V
−3.0 V
2.5 V
−200
−2.5 V
−2.0 V
2V
8
VDS (V)
12
Tamb = 25 °C; tp = 80 μs; δ = 0.
Fig 5.
Product data sheet
−4
−6
−8
−10
−12
VDS (V)
Output characteristics: drain current as a
function of drain-source voltage; N-channel;
typical values
PHC2300
−2
Fig 6.
function of drain-source voltage; P-channel;
typical values
6 of 14
PHC2300
Nexperia
mld842
1200
mbh440
−800
ID
(mA)
ID
(mA)
−600
800
−400
400
−200
4
6
8
10
VGS (V)
VDS = 10 V; Tamb = 25 °C; tp = 80 μs; δ = 0.
Fig 7.
Transfer characteristics: drain current as a
function of gate-source voltage; N-channel;
typical values
mld843
200
C
(pF)
−2
−4
−6
−8
−10
VGS (V)
VDS = -10 V; Tamb = 25 °C; tp = 80 μs; δ = 0.
Fig 8.
function of gate-source voltage; P-channel;
typical values
mld844
12
50
VDS
VGS
(V)
(V)
37.5
150
8
Ciss
25
100
(1)
(2)
4
12.5
50
Coss
Crss
10
15
25
VDS (V)
3120
6240
QG (pC)
VDS = 50 V; ID = 170 mA; Tamb = 25 °C.
(1) VDS
(2) VGS
Fig 9.
Input, output and reverse transfer capacitances
as a function of drain-source voltage;
N-channel; typical values
PHC2300
Product data sheet
Fig 10. Gate-source voltage and drain-source voltage
as a function of gate charge; N-channel typical
values
7 of 14
PHC2300
Nexperia
mld845
12
50
VDS
VGS
(V)
(V)
mda239
−0.5
ISD
(A)
−0.4
37.5
8
−0.3
25
(1)
(2)
−0.2
4
12.5
2140
QG (pC)
−0.1
1070
−0.4
−0.8
VSD (V)
−1.2
VDS = -50 V; ID = -115 mA; Tamb = 25 °C.
(1) VDS
(2) VGS
Fig 11. Gate-source voltage and drain-source voltage
as a function of gate charge; P-channel typical
values
mld846
102
Fig 12. Source current as a function of source-drain
voltage; P-channel typical values
mda233
102
(1)
(2)
(3)
(4)
(5)
(1)
(2)
(3)
RDSon
RDSon
(4)
(Ω)
(Ω)
(5)
10
1
10
4
6
8
10
VGS (V)
1
−2
−4
−6
−8
−10
VGS (V)
VDS ≥ ID X RDSon; Tamb = 25 °C; tp = 300 μs; δ = 0.
(1) ID = 10 mA.
(1) ID = -10 mA.
(2) ID = 20 mA.
(2) ID = -20 mA.
(3) ID = 50 mA.
(3) ID = -50 mA.
(4) ID = 100 mA.
(4) ID = -100 mA.
(5) ID = 200 mA.
(5) ID = -200 mA.
Fig 13. Drain-source on-state resistance as a function
of gate-source voltage; N-channel typical
values
PHC2300
Product data sheet
Fig 14. Drain-source on-state resistance as a function
of gate-source voltage; P-channel typical
values
8 of 14
PHC2300
Nexperia
mda238
0.5
mld847
1.25
ISD
k
(A)
0.4
1
0.3
0.75
0.2
0.5
0.1
0.25
−50
0.4
0.6
1
0.8
VSD (V)
100
150
Tj (°C)
VDS = VGS; ID = 1 mA.
Fig 15. Source-drain current as a function of
source-drain diode voltage; N-channel; typical
values
mbh438
1.4
Fig 16. Temperature coefficient of gate-source
threshold voltage as a function temperature;
mda236
160
C
(pF)
k
1.2
120
1.0
80
Ciss
0.8
40
Coss
Crss
0.6
−75
−25
75
125
175
Tj (°C)
−5
−10
−15
−20
−25
VDS (V)
VDS = VGS; ID = -1 mA.
Fig 17. Temperature coefficient of gate-source
PHC2300
Product data sheet
Fig 18. Input, output and reverse transfer capacitances
as a function of drain-source voltage; typical
values
9 of 14
PHC2300
Nexperia
7. Package outline
SO8: plastic small outline package; 8 leads; body width 3.9 mm
SOT96-1
D
E
A
X
c
y
HE
v M A
Z
5
8
Q
A2
A
(A 3)
A1
pin 1 index
θ
Lp
1
L
4
e
detail X
w M
bp
5 mm
scale
DIMENSIONS (inch dimensions are derived from the original mm dimensions)
UNIT
A
max.
A1
A2
A3
bp
c
D (1)
E (2)
e
HE
L
Lp
Q
v
w
y
Z (1)
mm
1.75
0.25
0.10
1.45
1.25
0.25
0.49
0.36
0.25
0.19
5.0
4.8
4.0
3.8
1.27
6.2
5.8
1.05
1.0
0.4
0.7
0.6
0.25
0.25
0.1
0.7
0.3
inches
0.069
0.010 0.057
0.004 0.049
0.01
0.019 0.0100
0.014 0.0075
0.20
0.19
0.16
0.15
0.05
0.01
0.01
0.004
0.028
0.012
0.244
0.039 0.028
0.041
0.228
0.016 0.024
θ
8o
o
Notes
1. Plastic or metal protrusions of 0.15 mm (0.006 inch) maximum per side are not included.
2. Plastic or metal protrusions of 0.25 mm (0.01 inch) maximum per side are not included.
REFERENCES
OUTLINE
VERSION
IEC
JEDEC
SOT96-1
076E03
MS-012
JEITA
EUROPEAN
PROJECTION
ISSUE DATE
99-12-27
03-02-18
Fig 19. Package outline SOT96-1 (SO8)
PHC2300
Product data sheet
10 of 14
PHC2300
Nexperia
8. Revision history
Table 7.
Revision history
Document ID
Release date
Data sheet status
Change notice
Supersedes
PHC2300 v.5
20110224
Product data sheet
PHC2300 v.4
PHC2300 v.3
Modifications:
PHC2300 v.4
PHC2300
Product data sheet
Various changes to content.
20101216
Product data sheet
11 of 14
PHC2300
Nexperia
9. Legal information
9.1
Data sheet status
Document status [1] [2]
Product status [3]
Definition
Objective [short] data sheet
Development
This document contains data from the objective specification for product development.
Preliminary [short] data sheet
Qualification
This document contains data from the preliminary specification.
Product [short] data sheet
Production
This document contains the product specification.
[1]
Please consult the most recently issued document before initiating or completing a design.
[2]
The term 'short data sheet' is explained in section "Definitions".
[3]
The product status of device(s) described in this document may have changed since this document was published and may differ in case of multiple devices. The latest product
status information is available on the Internet at URL http://www.nexperia.com.
9.2
Definitions
Draft — The document is a draft version only. The content is still under
internal review and subject to formal approval, which may result in
modifications or additions. Nexperia does not give any
representations or warranties as to the accuracy or completeness of
information included herein and shall have no liability for the consequences of
use of such information.
Short data sheet — A short data sheet is an extract from a full data sheet
with the same product type number(s) and title. A short data sheet is intended
for quick reference only and should not be relied upon to contain detailed and
full information. For detailed and full information see the relevant full data
sheet, which is available on request via the local Nexperia sales
office. In case of any inconsistency or conflict with the short data sheet, the
full data sheet shall prevail.
Product specification — The information and data provided in a Product
data sheet shall define the specification of the product as agreed between
Nexperia and its customer, unless Nexperia and
customer have explicitly agreed otherwise in writing. In no event however,
shall an agreement be valid in which the Nexperia product is
deemed to offer functions and qualities beyond those described in the
Product data sheet.
9.3
Disclaimers
Limited warranty and liability — Information in this document is believed to
be accurate and reliable. However, Nexperia does not give any
representations or warranties, expressed or implied, as to the accuracy or
completeness of such information and shall have no liability for the
consequences of use of such information.
In no event shall Nexperia be liable for any indirect, incidental,
punitive, special or consequential damages (including - without limitation - lost
profits, lost savings, business interruption, costs related to the removal or
replacement of any products or rework charges) whether or not such
damages are based on tort (including negligence), warranty, breach of
contract or any other legal theory.
Suitability for use — Nexperia products are not designed,
authorized or warranted to be suitable for use in life support, life-critical or
safety-critical systems or equipment, nor in applications where failure or
malfunction of a Nexperia product can reasonably be expected
to result in personal injury, death or severe property or environmental
damage. Nexperia accepts no liability for inclusion and/or use of
Nexperia products in such equipment or applications and
therefore such inclusion and/or use is at the customer’s own risk.
Quick reference data — The Quick reference data is an extract of the
product data given in the Limiting values and Characteristics sections of this
document, and as such is not complete, exhaustive or legally binding.
Applications — Applications that are described herein for any of these
products are for illustrative purposes only. Nexperia makes no
representation or warranty that such applications will be suitable for the
specified use without further testing or modification.
Customers are responsible for the design and operation of their applications
and products using Nexperia products, and Nexperia
accepts no liability for any assistance with applications or customer product
design. It is customer’s sole responsibility to determine whether the Nexperia
product is suitable and fit for the customer’s applications and
products planned, as well as for the planned application and use of
customer’s third party customer(s). Customers should provide appropriate
design and operating safeguards to minimize the risks associated with their
applications and products.
Nexperia does not accept any liability related to any default,
damage, costs or problem which is based on any weakness or default in the
customer’s applications or products, or the application or use by customer’s
third party customer(s). Customer is responsible for doing all necessary
testing for the customer’s applications and products using Nexperia
products in order to avoid a default of the applications and
the products or of the application or use by customer’s third party
customer(s). Nexperia does not accept any liability in this respect.
Notwithstanding any damages that customer might incur for any reason
whatsoever, Nexperia’s aggregate and cumulative liability towards
customer for the products described herein shall be limited in accordance
with the Terms and conditions of commercial sale of Nexperia.
Limiting values — Stress above one or more limiting values (as defined in
the Absolute Maximum Ratings System of IEC 60134) will cause permanent
damage to the device. Limiting values are stress ratings only and (proper)
operation of the device at these or any other conditions above those given in
the Recommended operating conditions section (if present) or the
Characteristics sections of this document is not warranted. Constant or
repeated exposure to limiting values will permanently and irreversibly affect
the quality and reliability of the device.
Right to make changes — Nexperia reserves the right to make
changes to information published in this document, including without
limitation specifications and product descriptions, at any time and without
notice. This document supersedes and replaces all information supplied prior
to the publication hereof.
Terms and conditions of commercial sale — Nexperia
products are sold subject to the general terms and conditions of commercial
sale, as published at http://www.nexperia.com/profile/terms, unless otherwise
agreed in a valid written individual agreement. In case an individual
agreement is concluded only the terms and conditions of the respective
PHC2300
Product data sheet
12 of 14
PHC2300
Nexperia
agreement shall apply. Nexperia hereby expressly objects to
applying the customer’s general terms and conditions with regard to the
purchase of Nexperia products by customer.
No offer to sell or license — Nothing in this document may be interpreted or
construed as an offer to sell products that is open for acceptance or the grant,
conveyance or implication of any license under any copyrights, patents or
other industrial or intellectual property rights.
Export control — This document as well as the item(s) described herein may
be subject to export control regulations. Export might require a prior
authorization from national authorities.
product for such automotive applications, use and specifications, and (b)
whenever customer uses the product for automotive applications beyond
Nexperia’s specifications such use shall be solely at customer’s
own risk, and (c) customer fully indemnifies Nexperia for any
liability, damages or failed product claims resulting from customer design and
use of the product for automotive applications beyond Nexperia’s
standard warranty and Nexperia’s product specifications.
9.4
Trademarks
Notice: All referenced brands, product names, service names and trademarks
are the property of their respective owners.
Non-automotive qualified products — Unless this data sheet expressly
states that this specific Nexperia product is automotive qualified,
the product is not suitable for automotive use. It is neither qualified nor tested
in accordance with automotive testing or application requirements. Nexperia
non-automotive qualified products in automotive equipment or applications.
In the event that customer uses the product for design-in and use in
automotive applications to automotive specifications and standards, customer
(a) shall use the product without Nexperia’s warranty of the
10. Contact information
For more information, please visit: http://www.nexperia.com
For sales office addresses, please send an email to: salesaddresses@nexperia.com
PHC2300
Product data sheet
13 of 14
Nexperia
PHC2300
11. Contents
1
1.1
1.2
1.3
1.4
2
3
4
5
6
7
8
9
9.1
9.2
9.3
9.4
10
Product profile . . . . . . . . . . . . . . . . . . . . . . . . . . .1
General description . . . . . . . . . . . . . . . . . . . . . .1
Features and benefits . . . . . . . . . . . . . . . . . . . . .1
Applications . . . . . . . . . . . . . . . . . . . . . . . . . . . .1
Quick reference data . . . . . . . . . . . . . . . . . . . . .1
Pinning information . . . . . . . . . . . . . . . . . . . . . . .2
Ordering information . . . . . . . . . . . . . . . . . . . . . .2
Limiting values. . . . . . . . . . . . . . . . . . . . . . . . . . .3
Thermal characteristics . . . . . . . . . . . . . . . . . . .4
Characteristics . . . . . . . . . . . . . . . . . . . . . . . . . . .5
Package outline . . . . . . . . . . . . . . . . . . . . . . . . .10
Revision history . . . . . . . . . . . . . . . . . . . . . . . . . 11
Legal information. . . . . . . . . . . . . . . . . . . . . . . .12
Data sheet status . . . . . . . . . . . . . . . . . . . . . . .12
Definitions . . . . . . . . . . . . . . . . . . . . . . . . . . . . .12
Disclaimers . . . . . . . . . . . . . . . . . . . . . . . . . . . .12
Trademarks. . . . . . . . . . . . . . . . . . . . . . . . . . . .13
Contact information. . . . . . . . . . . . . . . . . . . . . .13
Date of release: 24 February 2011
