SO
8
PHP225
Dual P-channel intermediate level FET
Rev. 04 — 17 March 2011
Product data sheet
1. Product profile
1.1 General description
Dual intermediate level P-channel enhancement mode Field-Effect Transistor (FET) in a
plastic package using vertical D-MOS technology. This product is designed and qualified
for use in computing, communications, consumer and industrial applications only.
1.2 Features and benefits
Low conduction losses due to low
on-state resistance
Suitable for high frequency
applications due to fast switching
characteristics
1.3 Applications
Motor and actuator drivers
Synchronized rectification
Power management
1.4 Quick reference data
Table 1.
Symbol
Parameter
Conditions
Min
Typ
Max Unit
VDS
drain-source voltage
Tj ≥ 25 °C; Tj ≤ 150 °C
-30
V
ID
drain current
Tsp ≤ 80 °C
-2.3
A
2
W
VGS = -10 V; ID = -1 A;
Tj = 25 °C
0.22 0.25 Ω
VGS = -10 V; ID = -2.3 A;
VDS = -15 V; Tj = 25 °C
3
total power dissipation
Ptot
Tsp = 80 °C
[1]
Static characteristics
RDSon
drain-source on-state
resistance
Dynamic characteristics
QGD
[1]
gate-drain charge
nC
Maximum permissible dissipation per MOS transistor. Both devices may be loaded up to 2 W at the same
time.
PHP225
NXP Semiconductors
2. Pinning information
Table 2.
Pinning information
Pin
Symbol Description
1
S1
source1
2
G1
gate1
3
S2
source2
4
G2
gate2
5
D2
drain2
6
D2
drain2
7
D1
drain1
8
D1
drain1
Simplified outline
Graphic symbol
8
5
D1
D1
D2
D2
1
4
S1
G1
S2
G2
SOT96-1 (SO8)
sym115
3. Ordering information
Table 3.
Type number
PHP225
PHP225
Product data sheet
Package
Name
Description
Version
SO8
plastic small outline package; 8 leads; body width 3.9 mm
SOT96-1
All information provided in this document is subject to legal disclaimers.
© NXP B.V. 2011. All rights reserved.
2 of 12
PHP225
NXP Semiconductors
4. Limiting values
Table 4.
Limiting values
In accordance with the Absolute Maximum Rating System (IEC 60134).
Symbol
Parameter
Conditions
Min
Max
Unit
VDS
-30
V
VGS
gate-source voltage
V
VGSO
gate-source voltage
open drain
-20
V
ID
drain current
Tsp ≤ 80 °C
-2.3
A
Tsp = 25 °C; pulsed
[1]
-10
A
Tamb = 25 °C
[2]
1
W
Tsp = 80 °C
[3]
2
W
Tamb = 25 °C
[4]
1.3
W
[5]
2
W
peak drain current
IDM
Ptot
Tstg
storage temperature
-65
150
°C
Tj
junction temperature
150
°C
-1.25
A
-5
A
Source-drain diode
source current
IS
peak source current
ISM
Tsp ≤ 80 °C
Tsp = 25 °C; pulsed
[1]
[1]
Pulse width and duty cycle limited by maximum junction temperature.
[2]
Maximum permissible dissipation per MOS transistor. Device mounted on printed-circuit board with a thermal resistance from ambient to
tie-point of 90 K/W.
[3]
Maximum permissible dissipation per MOS transistor. Both devices may be loaded up to 2 W at the same time.
[4]
Maximum permissible dissipation if only one MOS transistor dissipates. Device mounted on printed-circuit board with a thermal
resistance from ambient to tie-point of 90 K/W.
[5]
tie-point of 27.5 K/W.
PHP225
Product data sheet
3 of 12
PHP225
NXP Semiconductors
mlb836
2.5
mbe155
−102
Ptot
(W)
2.0
ID
(A)
−10
tp =
(1)
10 μs
1.5
−1
1 ms
1.0
δ=
P
−10−1
tp
T
DC
0.1 s
0.5
t
tp
−10−2 −1
−10
150
Ts (°C)
T
200
−1
−10
VDS (V)
−102
δ = 0.01
Ts = 80 °C.
(1) RDSon limitation.
Fig 1.
Power derating curve
Fig 2.
SOAR; P-channel
5. Thermal characteristics
Table 5.
Symbol
Parameter
Conditions
Min
Typ
Max
Unit
Rth(j-sp)
thermal resistance from junction to
solder point
see Figure 3
35
K/W
mbe153
102
δ=
0.75
0.5
0.33
Rth j-s
(K/W)
10
0.2
0.1
0.05
1
δ=
P
0.02
tp
T
0.01
t
tp
T
10−1
10−6
10−5
10−4
10−3
10−2
10−1
1
tp (s)
Fig 3.
Transient thermal resistance from junction to soldering point as a function of pulse time; typical values.
PHP225
Product data sheet
4 of 12
PHP225
NXP Semiconductors
6. Characteristics
Table 6.
Characteristics
Symbol
Parameter
Conditions
Min
Typ
Max
Unit
V(BR)DSS
drain-source breakdown
voltage
ID = -10 µA; VGS = 0 V; Tj = 25 °C
-30
V
VGS(th)
gate-source threshold
voltage
ID = -1 mA; VDS = VGS; Tj = 25 °C
-1
-2.8
V
IDSS
drain leakage current
VDS = -24 V; VGS = 0 V; Tj = 25 °C
-100
nA
IGSS
gate leakage current
VGS = 20 V; VDS = 0 V; Tj = 25 °C
100
nA
VGS = -20 V; VDS = 0 V; Tj = 25 °C
100
nA
VGS = -10 V; ID = -1 A; Tj = 25 °C
0.22
0.25
Ω
VGS = -4.5 V; ID = -0.5 A; Tj = 25 °C
0.33
0.4
Ω
RDSon
IDSon
resistance
on-state drain current
VDS = -1 V; VGS = -10 V
-2.3
A
VDS = -5 V; VGS = -4.5 V
-1
A
ID = -2.3 A; VDS = -15 V; VGS = -10 V;
Tj = 25 °C
10
25
nC
QG(tot)
total gate charge
QGS
gate-source charge
QGD
gate-drain charge
Ciss
input capacitance
Coss
output capacitance
Crss
reverse transfer
capacitance
gfs
transfer conductance
toff
turn-off time
ton
turn-on time
1
nC
3
nC
250
pF
140
pF
50
pF
VDS = -20 V; ID = -1 A; Tj = 25 °C
1
2
S
VDS = -20 V; VGS = -10 V; RG(ext) = 4.7 Ω;
RL = 20 Ω; Tj = 25 °C; ID = -1 A
50
140
ns
ns
VDS = -20 V; VGS = 0 V; f = 1 MHz;
Tj = 25 °C
Source-drain diode
VSD
source-drain voltage
IS = -1.25 A; VGS = 0 V; Tj = 25 °C
-1.6
V
trr
reverse recovery time
IS = -1.25 A; dIS/dt = 100 A/µs;
VGS = 0 V; VDS = 25 V; Tj = 25 °C
150
200
ns
PHP225
Product data sheet
5 of 12
PHP225
NXP Semiconductors
mbe144
600
mbe154
−10
VGS =
−10 V
ID
(A)
−8
C
(pF)
−6 V
−7.5 V
400
−5 V
−6
−4.5 V
Ciss
−4
200
−4 V
Coss
−3.5 V
−2
Crss
−10
Fig 4.
−20
−3 V
VDS (V)
Capacitance as a function of drain-source
voltage; P-channel; typical values
mbe157
−10
−30
Fig 5.
−6
−6
−4
−4
−2
−2
Fig 6.
−2
−4
−6
VGS (V)
PHP225
Product data sheet
−6
−8
mbe145
−8
Transfer characteristics: drain current as a
function of gate-source voltage; P-channel;
typical values
−4
−10
VGS
(V)
−8
−2
Output characteristics: drain current as a
function of drain-source voltage; P-channel;
typical values
ID
(A)
−8
−2.5 V
−10
−12
VDS (V)
Fig 7.
−2
−4
−6
−8
−10
Qg (nC)
Gate-source voltage as a function of gate
charge; P-channel; typical values
6 of 12
PHP225
NXP Semiconductors
mda165
104
mbe138
1.2
k
1.1
RDSon
(mΩ)
(1) (2)(3) (4) (5)
1.0
103
0.9
0.8
0.7
102
−2
−4
0.6
−10
−8
VGS (V)
−6
−50
100
Tj (°C)
150
-VDS ≥ -ID x RDSon; Tj = 25 °C.
(1) ID = -0.1 A.
(2) ID = -0.5 A.
Typical VGSth at ID = 1 mA; VDS = VGS = VGSth.
(3) ID = -1 A.
(4) ID = -2.3 A.
(5) ID= -4.5 A.
Fig 8.
Drain-source on-state resistance as a function
of drain current; typical values
mbe146
1.8
k
1.6
Temperature coefficient of gate-source
threshold voltage
mbe156
−6
IS
(A)
(1)
(2)
1.4
Fig 9.
−4
1.2
(1)
(2)
(3)
−2
1.0
0.8
0.6
−50
100
Tj (°C)
150
−0.5
−1
−1.5
VSD (V)
−2
Typical RDSon at:
(1) ID = -1 A; VGS = -10 V.
(2) ID = -0.5 A; VGS = -4.5 V.
Fig 10. Temperature coefficient of drain-source
on-state resistance; P-channel
PHP225
Product data sheet
Fig 11. Source current as a function of source-drain
voltage
7 of 12
PHP225
NXP Semiconductors
7. Package outline
SO8: plastic small outline package; 8 leads; body width 3.9 mm
SOT96-1
D
E
A
X
c
y
HE
v M A
Z
5
8
Q
A2
A
(A 3)
A1
pin 1 index
θ
Lp
1
L
4
e
detail X
w M
bp
5 mm
scale
DIMENSIONS (inch dimensions are derived from the original mm dimensions)
UNIT
A
max.
A1
A2
A3
bp
c
D (1)
E (2)
e
HE
L
Lp
Q
v
w
y
Z (1)
mm
1.75
0.25
0.10
1.45
1.25
0.25
0.49
0.36
0.25
0.19
5.0
4.8
4.0
3.8
1.27
6.2
5.8
1.05
1.0
0.4
0.7
0.6
0.25
0.25
0.1
0.7
0.3
0.069
0.010 0.057
0.004 0.049
0.01
0.019 0.0100
0.014 0.0075
0.20
0.19
0.16
0.15
0.05
0.01
0.01
0.004
0.028
0.012
inches
0.244
0.039 0.028
0.041
0.228
0.016 0.024
θ
o
8
o
Notes
1. Plastic or metal protrusions of 0.15 mm (0.006 inch) maximum per side are not included.
2. Plastic or metal protrusions of 0.25 mm (0.01 inch) maximum per side are not included.
REFERENCES
OUTLINE
VERSION
IEC
JEDEC
SOT96-1
076E03
MS-012
JEITA
EUROPEAN
PROJECTION
ISSUE DATE
99-12-27
03-02-18
Fig 12. Package outline SOT96-1 (SO8)
PHP225
Product data sheet
8 of 12
PHP225
NXP Semiconductors
8. Revision history
Table 7.
Revision history
Document ID
Release date
Data sheet status
Change notice
Supersedes
PHP225 v.4
20110317
Product data sheet
PHP225 v.3
PHP225 v.2
Modifications:
PHP225 v.3
PHP225
Product data sheet
Various changes to content.
20110104
Product data sheet
9 of 12
PHP225
NXP Semiconductors
9. Legal information
9.1
Data sheet status
Document status [1] [2]
Product status [3]
Definition
Objective [short] data sheet
Development
This document contains data from the objective specification for product development.
Preliminary [short] data sheet
Qualification
This document contains data from the preliminary specification.
Product [short] data sheet
Production
This document contains the product specification.
[1]
Please consult the most recently issued document before initiating or completing a design.
[2]
The term 'short data sheet' is explained in section "Definitions".
[3]
The product status of device(s) described in this document may have changed since this document was published and may differ in case of multiple devices. The latest product
status information is available on the Internet at URL http://www.nxp.com.
9.2
Definitions
Draft — The document is a draft version only. The content is still under
internal review and subject to formal approval, which may result in
modifications or additions. NXP Semiconductors does not give any
representations or warranties as to the accuracy or completeness of
information included herein and shall have no liability for the consequences of
use of such information.
Short data sheet — A short data sheet is an extract from a full data sheet
with the same product type number(s) and title. A short data sheet is intended
for quick reference only and should not be relied upon to contain detailed and
full information. For detailed and full information see the relevant full data
sheet, which is available on request via the local NXP Semiconductors sales
office. In case of any inconsistency or conflict with the short data sheet, the
full data sheet shall prevail.
Product specification — The information and data provided in a Product
data sheet shall define the specification of the product as agreed between
NXP Semiconductors and its customer, unless NXP Semiconductors and
customer have explicitly agreed otherwise in writing. In no event however,
shall an agreement be valid in which the NXP Semiconductors product is
deemed to offer functions and qualities beyond those described in the
Product data sheet.
9.3
Disclaimers
Limited warranty and liability — Information in this document is believed to
be accurate and reliable. However, NXP Semiconductors does not give any
representations or warranties, expressed or implied, as to the accuracy or
completeness of such information and shall have no liability for the
consequences of use of such information.
In no event shall NXP Semiconductors be liable for any indirect, incidental,
punitive, special or consequential damages (including - without limitation - lost
profits, lost savings, business interruption, costs related to the removal or
replacement of any products or rework charges) whether or not such
damages are based on tort (including negligence), warranty, breach of
contract or any other legal theory.
Suitability for use — NXP Semiconductors products are not designed,
authorized or warranted to be suitable for use in life support, life-critical or
safety-critical systems or equipment, nor in applications where failure or
malfunction of an NXP Semiconductors product can reasonably be expected
to result in personal injury, death or severe property or environmental
damage. NXP Semiconductors accepts no liability for inclusion and/or use of
NXP Semiconductors products in such equipment or applications and
therefore such inclusion and/or use is at the customer’s own risk.
Quick reference data — The Quick reference data is an extract of the
product data given in the Limiting values and Characteristics sections of this
document, and as such is not complete, exhaustive or legally binding.
Applications — Applications that are described herein for any of these
products are for illustrative purposes only. NXP Semiconductors makes no
representation or warranty that such applications will be suitable for the
specified use without further testing or modification.
Customers are responsible for the design and operation of their applications
and products using NXP Semiconductors products, and NXP Semiconductors
accepts no liability for any assistance with applications or customer product
design. It is customer’s sole responsibility to determine whether the NXP
Semiconductors product is suitable and fit for the customer’s applications and
products planned, as well as for the planned application and use of
customer’s third party customer(s). Customers should provide appropriate
design and operating safeguards to minimize the risks associated with their
applications and products.
NXP Semiconductors does not accept any liability related to any default,
damage, costs or problem which is based on any weakness or default in the
customer’s applications or products, or the application or use by customer’s
third party customer(s). Customer is responsible for doing all necessary
testing for the customer’s applications and products using NXP
Semiconductors products in order to avoid a default of the applications and
the products or of the application or use by customer’s third party
customer(s). NXP does not accept any liability in this respect.
Notwithstanding any damages that customer might incur for any reason
whatsoever, NXP Semiconductors’ aggregate and cumulative liability towards
customer for the products described herein shall be limited in accordance
with the Terms and conditions of commercial sale of NXP Semiconductors.
Limiting values — Stress above one or more limiting values (as defined in
the Absolute Maximum Ratings System of IEC 60134) will cause permanent
damage to the device. Limiting values are stress ratings only and (proper)
operation of the device at these or any other conditions above those given in
the Recommended operating conditions section (if present) or the
Characteristics sections of this document is not warranted. Constant or
repeated exposure to limiting values will permanently and irreversibly affect
the quality and reliability of the device.
Right to make changes — NXP Semiconductors reserves the right to make
changes to information published in this document, including without
limitation specifications and product descriptions, at any time and without
notice. This document supersedes and replaces all information supplied prior
to the publication hereof.
Terms and conditions of commercial sale — NXP Semiconductors
products are sold subject to the general terms and conditions of commercial
sale, as published at http://www.nxp.com/profile/terms, unless otherwise
agreed in a valid written individual agreement. In case an individual
agreement is concluded only the terms and conditions of the respective
PHP225
Product data sheet
10 of 12
PHP225
NXP Semiconductors
agreement shall apply. NXP Semiconductors hereby expressly objects to
applying the customer’s general terms and conditions with regard to the
purchase of NXP Semiconductors products by customer.
No offer to sell or license — Nothing in this document may be interpreted or
construed as an offer to sell products that is open for acceptance or the grant,
conveyance or implication of any license under any copyrights, patents or
other industrial or intellectual property rights.
Export control — This document as well as the item(s) described herein may
be subject to export control regulations. Export might require a prior
authorization from national authorities.
Non-automotive qualified products — Unless this data sheet expressly
states that this specific NXP Semiconductors product is automotive qualified,
the product is not suitable for automotive use. It is neither qualified nor tested
in accordance with automotive testing or application requirements. NXP
non-automotive qualified products in automotive equipment or applications.
In the event that customer uses the product for design-in and use in
automotive applications to automotive specifications and standards, customer
(a) shall use the product without NXP Semiconductors’ warranty of the
product for such automotive applications, use and specifications, and (b)
whenever customer uses the product for automotive applications beyond
NXP Semiconductors’ specifications such use shall be solely at customer’s
own risk, and (c) customer fully indemnifies NXP Semiconductors for any
liability, damages or failed product claims resulting from customer design and
use of the product for automotive applications beyond NXP Semiconductors’
standard warranty and NXP Semiconductors’ product specifications.
9.4
Trademarks
Notice: All referenced brands, product names, service names and trademarks
are the property of their respective owners.
Adelante, Bitport, Bitsound, CoolFlux, CoReUse, DESFire, EZ-HV,
FabKey, GreenChip, HiPerSmart, HITAG, I²C-bus logo, ICODE, I-CODE,
ITEC, Labelution, MIFARE, MIFARE Plus, MIFARE Ultralight, MoReUse,
QLPAK, Silicon Tuner, SiliconMAX, SmartXA, STARplug, TOPFET,
TrenchMOS, TriMedia and UCODE — are trademarks of NXP B.V.
HD Radio and HD Radio logo — are trademarks of iBiquity Digital
Corporation.
10. Contact information
For more information, please visit: http://www.nxp.com
For sales office addresses, please send an email to: salesaddresses@nxp.com
PHP225
Product data sheet
11 of 12
PHP225
NXP Semiconductors
11. Contents
1
1.1
1.2
1.3
1.4
2
3
4
5
6
7
8
9
9.1
9.2
9.3
9.4
10
Product profile . . . . . . . . . . . . . . . . . . . . . . . . . . .1
General description . . . . . . . . . . . . . . . . . . . . . .1
Features and benefits . . . . . . . . . . . . . . . . . . . . .1
Applications . . . . . . . . . . . . . . . . . . . . . . . . . . . .1
Quick reference data . . . . . . . . . . . . . . . . . . . . .1
Pinning information . . . . . . . . . . . . . . . . . . . . . . .2
Ordering information . . . . . . . . . . . . . . . . . . . . . .2
Limiting values. . . . . . . . . . . . . . . . . . . . . . . . . . .3
Thermal characteristics . . . . . . . . . . . . . . . . . . .4
Characteristics . . . . . . . . . . . . . . . . . . . . . . . . . . .5
Package outline . . . . . . . . . . . . . . . . . . . . . . . . . .8
Revision history . . . . . . . . . . . . . . . . . . . . . . . . . .9
Legal information. . . . . . . . . . . . . . . . . . . . . . . .10
Data sheet status . . . . . . . . . . . . . . . . . . . . . . .10
Definitions . . . . . . . . . . . . . . . . . . . . . . . . . . . . .10
Disclaimers . . . . . . . . . . . . . . . . . . . . . . . . . . . .10
Trademarks. . . . . . . . . . . . . . . . . . . . . . . . . . . . 11
Contact information. . . . . . . . . . . . . . . . . . . . . . 11
Please be aware that important notices concerning this document and the product(s)
described herein, have been included in section ‘Legal information’.
© NXP B.V. 2011.
Date of release: 17 March 2011
Document identifier: PHP225
