PHC21025,118
PHC21025,118
    NEXPERIA(安世)
    SO-8
    MOSFET N/P-CH 30V SOT96-1
PHC21025,118 数据手册
PHC21025 Complementary intermediate level FET Rev. 04 — 17 March 2011 Product data sheet 1. Product profile 1.1 General description Intermediate level N-channel and P-channel complementary pair enhancement mode Field-Effect Transistor (FET) in a plastic package using vertical D-MOS technology. This product is designed and qualified for use in computing, communications, consumer and industrial applications only. 1.2 Features and benefits „ Low conduction losses due to low on-state resistance „ Suitable for high frequency applications due to fast switching characteristics 1.3 Applications „ Motor and actuator drivers „ Synchronized rectification „ Power management 1.4 Quick reference data Table 1. Quick reference data Symbol Parameter Conditions Min Typ Max Unit VDS drain-source voltage Tj ≥ 25 °C; Tj ≤ 150 °C; N-channel - - 30 V Tj ≥ 25 °C; Tj ≤ 150 °C; P-channel - - -30 V Tsp ≤ 80 °C; P-channel - - -2.3 A - - 3.5 A - - 1 W VGS = -10 V; ID = -1 A; Tj = 25 °C; P-channel; see Figure 16; see Figure 19 - 0.22 0.25 Ω VGS = 10 V; ID = 2.2 A; Tj = 25 °C; N-channel; see Figure 15; see Figure 18 - 0.08 0.1 ID drain current Tsp ≤ 80 °C; N-channel Ptot total power dissipation Tamb = 25 °C [1] Static characteristics RDSon drain-source on-state resistance Ω PHC21025 Nexperia Complementary intermediate level FET Table 1. Symbol Quick reference data …continued Parameter Conditions Min Typ Max Unit VGS = -10 V; ID = -2.3 A; VDS = -15 V; Tj = 25 °C; P-channel; see Figure 12 - 3 - nC VGS = 10 V; ID = 2.3 A; VDS = 15 V; Tj = 25 °C; N-channel; see Figure 11 - 2.5 - nC Dynamic characteristics QGD [1] gate-drain charge Maximum permissible dissipation per MOS transistor. Device mounted on printed-circuit board with a thermal resistance from ambient to solder point of 90 K/W. 2. Pinning information Table 2. Pinning information Pin Symbol Description 1 S1 source1 2 G1 gate1 3 S2 source2 4 G2 gate2 5 D2 drain2 6 D2 drain2 7 D1 drain1 8 D1 drain1 Simplified outline Graphic symbol 8 5 D1 D1 D2 D2 1 4 S1 G1 S2 G2 sym114 SOT96-1 (SO8) 3. Ordering information Table 3. Ordering information Type number PHC21025 PHC21025 Product data sheet Package Name Description Version SO8 plastic small outline package; 8 leads; body width 3.9 mm SOT96-1 All information provided in this document is subject to legal disclaimers. Rev. 04 — 17 March 2011 © Nexperia B.V. 2017. All rights reserved 2 of 16 PHC21025 Nexperia Complementary intermediate level FET 4. Limiting values Table 4. Limiting values In accordance with the Absolute Maximum Rating System (IEC 60134). Symbol Parameter Conditions Min Max Unit VDS drain-source voltage Tj ≥ 25 °C; Tj ≤ 150 °C; N-channel - 30 V Tj ≥ 25 °C; Tj ≤ 150 °C; P-channel - -30 V VGS gate-source voltage - - V VGSO gate-source voltage open drain -20 20 V ID drain current Tsp ≤ 80 °C; P-channel - -2.3 A Tsp ≤ 80 °C; N-channel peak drain current IDM Ptot total power dissipation - 3.5 A Tsp = 25 °C; pulsed; N-channel; see Figure 2 [1] - 14 A Tsp = 25 °C; pulsed; P-channel; see Figure 3 [1] - -10 A Tamb = 25 °C [2] - 1 W Tsp = 80 °C; see Figure 1 [3] - 2 W Tamb = 25 °C [4] - 1.3 W [5] - 2 W Tstg storage temperature -65 150 °C Tj junction temperature - 150 °C - -1.25 A Source-drain diode IS source current ISM peak source current Tsp ≤ 80 °C; P-channel Tsp ≤ 80 °C; N-channel - 1.5 A Tsp = 25 °C; pulsed; P-channel [6] - -5 A Tsp = 25 °C; pulsed; N-channel [6] - 6 A [1] Pulse width and duty cycle limited by maximum junction temperature. [2] Maximum permissible dissipation per MOS transistor. Device mounted on printed-circuit board with a thermal resistance from ambient to solder point of 90 K/W. [3] Maximum permissible dissipation per MOS transistor. Both devices may be loaded up to 2 W at the same time. [4] Maximum permissible dissipation if only one MOS transistor dissipates. Device mounted on printed-circuit board with thermal resistance from ambient to solder point of 90 K/W. [5] Maximum permissible dissipation per MOS transistor. Device mounted on printed-circuit board with a Thermal resistance from ambient to solder point of 27.5 K/W. [6] Pulse width and duty cycle limited by maximum junction temperature. PHC21025 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 04 — 17 March 2011 © Nexperia B.V. 2017. All rights reserved 3 of 16 PHC21025 Nexperia Complementary intermediate level FET mlb836 2.5 mlb833 102 Ptot (W) 2.0 ID (A) (1) 10 tp = 10μs 1.5 1 1 ms 1.0 δ= P tp T 10−1 0.5 0 50 100 150 Ts (°C) T 10−2 10−1 200 0.1 s t tp 0 DC 1 10 VDS (V) 102 δ = 0.01. Ts = 80 °C. (1) RDSon limitation. Fig 1. Power derating curve Fig 2. SOAR; N-channel mbe155 −102 ID (A) −10 tp = (1) 10 μs −1 1 ms δ= P −10−1 DC 0.1 s t tp −10−2 tp T T −10−1 −1 −10 VDS (V) −102 δ = 0.01 Ts = 80 °C. (1) RDSon limitation. Fig 3. SOAR; P-channel PHC21025 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 04 — 17 March 2011 © Nexperia B.V. 2017. All rights reserved 4 of 16 PHC21025 Nexperia Complementary intermediate level FET 5. Thermal characteristics Table 5. Thermal characteristics Symbol Parameter Conditions Rth(j-sp) thermal resistance from junction to solder point Min Typ Max Unit - - 35 K/W mbe152 102 δ= 0.75 0.5 0.33 Rth j-s (K/W) 10 0.2 0.1 0.05 1 δ= P 0.02 tp T 0.01 0 t tp T 10−1 10−6 10−5 10−4 10−3 10−2 10−1 1 tp (s) Fig 4. Transient thermal impedance from junction to solder point as a function of pulse duration PHC21025 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 04 — 17 March 2011 © Nexperia B.V. 2017. All rights reserved 5 of 16 PHC21025 Nexperia Complementary intermediate level FET 6. Characteristics Table 6. Characteristics Symbol Parameter Conditions Min Typ Max Unit ID = -10 µA; VGS = 0 V; Tj = 25 °C; P-channel -30 - - V ID = 10 µA; VGS = 0 V; Tj = 25 °C; N-channel 30 - - V ID = -1 mA; VDS = VGS; Tj = 25 °C; P-channel; see Figure 17 -1 - -2.8 V ID = 1 mA; VDS = VGS; Tj = 25 °C; N-channel; see Figure 17 1 - 2.8 V VDS = -24 V; VGS = 0 V; Tj = 25 °C; P-channel - - -100 nA VDS = 24 V; VGS = 0 V; Tj = 25 °C; N-channel - - 100 nA VGS = 20 V; VDS = 0 V; Tj = 25 °C; N-channel - - 100 nA VGS = 20 V; VDS = 0 V; Tj = 25 °C; P-channel - - 100 nA VGS = -20 V; VDS = 0 V; Tj = 25 °C; P-channel - - 100 nA VGS = -20 V; VDS = 0 V; Tj = 25 °C; N-channel - - 100 nA VGS = -10 V; ID = -1 A; Tj = 25 °C; P-channel; see Figure 16; see Figure 19 - 0.22 0.25 Ω VGS = 10 V; ID = 2.2 A; Tj = 25 °C; N-channel; see Figure 15; see Figure 18 - 0.08 0.1 Ω VGS = -4.5 V; ID = -0.5 A; Tj = 25 °C; P-channel; see Figure 16; see Figure 19 - 0.33 0.4 Ω VGS = 4.5 V; ID = 1 A; N-channel; see Figure 15; see Figure 18 - 0.11 0.2 Ω VDS = 5 V; VGS = 4.5 V; N-channel 2 - - A VDS = -5 V; VGS = -4.5 V; P-channel -1 - - A VDS = -1 V; VGS = -10 V; P-channel -2.3 - - A VDS = 1 V; VGS = 10 V; N-channel 3.5 - - A ID = 2.3 A; VDS = 15 V; VGS = 10 V; Tj = 25 °C; N-channel; see Figure 11 - 10 30 nC ID = -2.3 A; VDS = -15 V; VGS = -10 V; Tj = 25 °C; P-channel; see Figure 12 - 10 25 nC Static characteristics V(BR)DSS VGS(th) IDSS IGSS RDSon IDSon drain-source breakdown voltage gate-source threshold voltage drain leakage current gate leakage current drain-source on-state resistance on-state drain current Dynamic characteristics QG(tot) total gate charge PHC21025 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 04 — 17 March 2011 © Nexperia B.V. 2017. All rights reserved 6 of 16 PHC21025 Nexperia Complementary intermediate level FET Table 6. Characteristics …continued Symbol Parameter Conditions Min Typ Max Unit QGS gate-source charge ID = 2.3 A; VDS = 15 V; VGS = 10 V; Tj = 25 °C; N-channel; see Figure 11 - 1 - nC ID = -2.3 A; VDS = -15 V; VGS = -10 V; Tj = 25 °C; P-channel; see Figure 12 - 1 - nC ID = -2.3 A; VDS = -15 V; VGS = -10 V; Tj = 25 °C; P-channel; see Figure 12 - 3 - nC ID = 2.3 A; VDS = 15 V; VGS = 10 V; Tj = 25 °C; N-channel; see Figure 11 - 2.5 - nC VDS = 20 V; VGS = 0 V; f = 1 MHz; Tj = 25 °C; N-channel; see Figure 5 - 250 - pF VDS = -20 V; VGS = 0 V; f = 1 MHz; Tj = 25 °C; P-channel; see Figure 6 - 250 - pF VDS = 20 V; VGS = 0 V; f = 1 MHz; Tj = 25 °C; N-channel; see Figure 5 - 140 - pF VDS = -20 V; VGS = 0 V; f = 1 MHz; Tj = 25 °C; P-channel; see Figure 6 - 140 - pF VDS = 20 V; VGS = 0 V; f = 1 MHz; Tj = 25 °C; N-channel; see Figure 5 - 50 - pF VDS = -20 V; VGS = 0 V; f = 1 MHz; Tj = 25 °C; P-channel; see Figure 6 - 50 - pF VDS = -20 V; ID = -1 A; Tj = 25 °C; P-channel 1 2 - S VDS = 20 V; ID = 2.2 A; Tj = 25 °C; N-channel 2 4.5 - S VDS = 20 V; VGS = 10 V; RG(ext) = 4.7 Ω; ID = 1 A; RL = 20 Ω; Tj = 25 °C; N-channel - 25 140 ns QGD Ciss Coss Crss gfs gate-drain charge input capacitance output capacitance reverse transfer capacitance transfer conductance toff turn-off time ton turn-on time VDS = -20 V; VGS = -10 V; RG(ext) = 4.7 Ω; ID = -1 A; RL = 20 Ω; Tj = 25 °C; P-channel - 50 140 ns - 20 80 ns VDS = 20 V; VGS = 10 V; RG(ext) = 4.7 Ω; ID = 1 A; RL = 20 Ω; Tj = 25 °C; N-channel - 15 40 ns IS = 1.25 A; VGS = 0 V; Tj = 25 °C; N-channel; see Figure 13 - - 1.2 V IS = -1.25 A; VGS = 0 V; Tj = 25 °C; P-channel; see Figure 14 - - -1.6 V IS = -1.25 A; dIS/dt = 100 A/µs; VGS = 0 V; VDS = -25 V; Tj = 25 °C; P-channel - 150 200 ns IS = 1.25 A; dIS/dt = -100 A/µs; VGS = 0 V; VDS = 25 V; Tj = 25 °C; N-channel - 35 100 ns Source-drain diode VSD trr source-drain voltage reverse recovery time PHC21025 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 04 — 17 March 2011 © Nexperia B.V. 2017. All rights reserved 7 of 16 PHC21025 Nexperia Complementary intermediate level FET mbe137 600 C (pF) mbe144 600 C (pF) 400 400 Ciss Ciss 200 200 Coss Coss Crss Crss 0 0 0 Fig 5. 10 20 VDS (V) Capacitance as a function of drain-source voltage; N-channel; typical values mbe142 16 VGS = 10 V 6 V ID (A) −10 0 30 Fig 6. −20 VDS (V) −30 Capacitance as a function of drain-source voltage; P-channel; typical values mbe154 −10 VGS = −10 V ID (A) −8 −6 V −7.5 V 12 5V −5 V −6 8 4.5 V −4.5 V −4 4V −4 V 4 −3.5 V −2 3.5 V −3 V 3V 0 0 0 Fig 7. 2 4 6 8 10 12 VDS (V) Output characteristics: drain current as a function of drain-source voltage; N-channel; typical values PHC21025 Product data sheet Fig 8. 0 −2 −4 −6 −2.5 V −10 −12 VDS (V) −8 Output characteristics: drain current as a function of drain-source voltage; P-channel; typical values All information provided in this document is subject to legal disclaimers. Rev. 04 — 17 March 2011 © Nexperia B.V. 2017. All rights reserved 8 of 16 PHC21025 Nexperia Complementary intermediate level FET mbe141 16 mbe157 −10 ID (A) −8 ID (A) 12 −6 8 −4 4 −2 0 0 0 Fig 9. 2 4 6 VGS (V) Transfer characteristics: drain current as a function of gate-source voltage; N-channel; typical values mbe136 10 6 −6 4 −4 2 −2 4 6 8 0 QG (nC) Fig 11. Gate-source voltage as a function of gate charge; N-channel; typical values PHC21025 Product data sheet VGS (V) −8 mbe145 0 2 −6 −10 VGS (V) −8 0 −4 Fig 10. Transfer characteristics: drain current as a function of gate-source voltage; P-channel; typical values VGS (V) 8 0 −2 0 8 −2 −4 −6 −8 −10 Qg (nC) Fig 12. Gate-source voltage as a function of gate charge; P-channel; typical values All information provided in this document is subject to legal disclaimers. Rev. 04 — 17 March 2011 © Nexperia B.V. 2017. All rights reserved 9 of 16 PHC21025 Nexperia Complementary intermediate level FET mbe159 6 mbe158 −6 IS (A) IS (A) −4 4 (1) (2) (3) (1) (2) (3) −2 2 0 0 0 0.5 1 VSD (V) 1.5 −0.5 0 VGD = 0. VGD = 0. (1) Tj = 150 °C. (1) Tj = 150 °C. (2) Tj = 25 °C. (2) Tj = 25 °C. (3) Tj = -55 °C. (3) Tj = -55 °C. Fig 13. Source current as a function of source-drain voltage; N-channel; typical values mda217 104 −1 −1.5 VSD (V) −2 Fig 14. Source current as a function of source-drain voltage; P-channel; typical values mda165 104 RDSon (mΩ) RDSon (1)(2)(3)(4)(5) (6) (mΩ) (1) (2)(3) (4) (5) 103 103 102 10 0 2 4 6 8 10 VGS (V) 102 0 −2 −4 −10 −8 VGS (V) −6 VDS ≥ ID x RDSon; Tj = 25 °C. -VDS ≥ -ID x RDSon; Tj = 25 °C. (1) ID = 0.1 A. (1) ID = -0.1 A. (2) ID = 0.5 A. (2) ID = -0.5 A. (3) ID = 1 A. (3) ID = -1 A. (4) ID = 2.2 A. (4) ID = -2.3 A. (5) ID = 3.5 A. (5) ID= -4.5 A. (6) ID = 7 A. Fig 15. Drain-source on-state resistance as a function of drain current; N-channel; typical values PHC21025 Product data sheet Fig 16. Drain-source on-state resistance as a function of drain current; typical values All information provided in this document is subject to legal disclaimers. Rev. 04 — 17 March 2011 © Nexperia B.V. 2017. All rights reserved 10 of 16 PHC21025 Nexperia Complementary intermediate level FET mbe138 1.2 mbe139 1.8 k k 1.1 1.6 1.0 1.4 (1) (2) 0.9 1.2 0.8 1.0 0.7 0.8 0.6 −50 0 50 100 Tj (°C) 0.6 −50 150 0 50 100 Tj (°C) 150 Typical RDSon at: Typical VGSth at ID = 1 mA; VDS = VGS = VGSth. (1) ID = 2.2 A; VGS = 10 V. (2) ID = 1 A; VGS = 4.5 V. Fig 17. Temperature coefficient of gate-source threshold voltage Fig 18. Temperature coefficient of drain-source on-state resistance; N-channel mbe146 1.8 k 1.6 (1) (2) 1.4 1.2 1.0 0.8 0.6 −50 0 50 100 Tj (°C) 150 Typical RDSon at: (1) ID = -1 A; VGS = -10 V. (2) ID = -0.5 A; VGS = -4.5 V. Fig 19. Temperature coefficient of drain-source on-state resistance; P-channel PHC21025 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 04 — 17 March 2011 © Nexperia B.V. 2017. All rights reserved 11 of 16 PHC21025 Nexperia Complementary intermediate level FET 7. Package outline SO8: plastic small outline package; 8 leads; body width 3.9 mm SOT96-1 D E A X c y HE v M A Z 5 8 Q A2 A (A 3) A1 pin 1 index θ Lp 1 L 4 e detail X w M bp 0 2.5 5 mm scale DIMENSIONS (inch dimensions are derived from the original mm dimensions) UNIT A max. A1 A2 A3 bp c D (1) E (2) e HE L Lp Q v w y Z (1) mm 1.75 0.25 0.10 1.45 1.25 0.25 0.49 0.36 0.25 0.19 5.0 4.8 4.0 3.8 1.27 6.2 5.8 1.05 1.0 0.4 0.7 0.6 0.25 0.25 0.1 0.7 0.3 inches 0.069 0.010 0.057 0.004 0.049 0.01 0.019 0.0100 0.014 0.0075 0.20 0.19 0.16 0.15 0.05 0.01 0.01 0.004 0.028 0.012 0.244 0.039 0.028 0.041 0.228 0.016 0.024 θ 8o o 0 Notes 1. Plastic or metal protrusions of 0.15 mm (0.006 inch) maximum per side are not included. 2. Plastic or metal protrusions of 0.25 mm (0.01 inch) maximum per side are not included. REFERENCES OUTLINE VERSION IEC JEDEC SOT96-1 076E03 MS-012 JEITA EUROPEAN PROJECTION ISSUE DATE 99-12-27 03-02-18 Fig 20. Package outline SOT96-1 (SO8) PHC21025 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 04 — 17 March 2011 © Nexperia B.V. 2017. All rights reserved 12 of 16 PHC21025 Nexperia Complementary intermediate level FET 8. Revision history Table 7. Revision history Document ID Release date Data sheet status Change notice Supersedes PHC21025 v.4 20110317 Product data sheet - PHC21025 v.3 - PHC21025 v.2 Modifications: PHC21025 v.3 PHC21025 Product data sheet • Various changes to content. 20101217 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 04 — 17 March 2011 © Nexperia B.V. 2017. All rights reserved 13 of 16 PHC21025 Nexperia Complementary intermediate level FET 9. Legal information 9.1 Data sheet status Document status [1] [2] Product status [3] Definition Objective [short] data sheet Development This document contains data from the objective specification for product development. Preliminary [short] data sheet Qualification This document contains data from the preliminary specification. Product [short] data sheet Production This document contains the product specification. [1] Please consult the most recently issued document before initiating or completing a design. [2] The term 'short data sheet' is explained in section "Definitions". [3] The product status of device(s) described in this document may have changed since this document was published and may differ in case of multiple devices. The latest product status information is available on the Internet at URL http://www.nexperia.com. 9.2 Definitions Draft — The document is a draft version only. The content is still under internal review and subject to formal approval, which may result in modifications or additions. Nexperia does not give any representations or warranties as to the accuracy or completeness of information included herein and shall have no liability for the consequences of use of such information. Short data sheet — A short data sheet is an extract from a full data sheet with the same product type number(s) and title. A short data sheet is intended for quick reference only and should not be relied upon to contain detailed and full information. For detailed and full information see the relevant full data sheet, which is available on request via the local Nexperia sales office. In case of any inconsistency or conflict with the short data sheet, the full data sheet shall prevail. Product specification — The information and data provided in a Product data sheet shall define the specification of the product as agreed between Nexperia and its customer, unless Nexperia and customer have explicitly agreed otherwise in writing. In no event however, shall an agreement be valid in which the Nexperia product is deemed to offer functions and qualities beyond those described in the Product data sheet. 9.3 Disclaimers Limited warranty and liability — Information in this document is believed to be accurate and reliable. However, Nexperia does not give any representations or warranties, expressed or implied, as to the accuracy or completeness of such information and shall have no liability for the consequences of use of such information. In no event shall Nexperia be liable for any indirect, incidental, punitive, special or consequential damages (including - without limitation - lost profits, lost savings, business interruption, costs related to the removal or replacement of any products or rework charges) whether or not such damages are based on tort (including negligence), warranty, breach of contract or any other legal theory. Suitability for use — Nexperia products are not designed, authorized or warranted to be suitable for use in life support, life-critical or safety-critical systems or equipment, nor in applications where failure or malfunction of a Nexperia product can reasonably be expected to result in personal injury, death or severe property or environmental damage. Nexperia accepts no liability for inclusion and/or use of Nexperia products in such equipment or applications and therefore such inclusion and/or use is at the customer’s own risk. Quick reference data — The Quick reference data is an extract of the product data given in the Limiting values and Characteristics sections of this document, and as such is not complete, exhaustive or legally binding. Applications — Applications that are described herein for any of these products are for illustrative purposes only. Nexperia makes no representation or warranty that such applications will be suitable for the specified use without further testing or modification. Customers are responsible for the design and operation of their applications and products using Nexperia products, and Nexperia accepts no liability for any assistance with applications or customer product design. It is customer’s sole responsibility to determine whether the Nexperia product is suitable and fit for the customer’s applications and products planned, as well as for the planned application and use of customer’s third party customer(s). Customers should provide appropriate design and operating safeguards to minimize the risks associated with their applications and products. Nexperia does not accept any liability related to any default, damage, costs or problem which is based on any weakness or default in the customer’s applications or products, or the application or use by customer’s third party customer(s). Customer is responsible for doing all necessary testing for the customer’s applications and products using Nexperia products in order to avoid a default of the applications and the products or of the application or use by customer’s third party customer(s). Nexperia does not accept any liability in this respect. Notwithstanding any damages that customer might incur for any reason whatsoever, Nexperia’s aggregate and cumulative liability towards customer for the products described herein shall be limited in accordance with the Terms and conditions of commercial sale of Nexperia. Limiting values — Stress above one or more limiting values (as defined in the Absolute Maximum Ratings System of IEC 60134) will cause permanent damage to the device. Limiting values are stress ratings only and (proper) operation of the device at these or any other conditions above those given in the Recommended operating conditions section (if present) or the Characteristics sections of this document is not warranted. Constant or repeated exposure to limiting values will permanently and irreversibly affect the quality and reliability of the device. Right to make changes — Nexperia reserves the right to make changes to information published in this document, including without limitation specifications and product descriptions, at any time and without notice. This document supersedes and replaces all information supplied prior to the publication hereof. Terms and conditions of commercial sale — Nexperia products are sold subject to the general terms and conditions of commercial sale, as published at http://www.nexperia.com/profile/terms, unless otherwise agreed in a valid written individual agreement. In case an individual agreement is concluded only the terms and conditions of the respective PHC21025 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 04 — 17 March 2011 © Nexperia B.V. 2017. All rights reserved 14 of 16 PHC21025 Nexperia Complementary intermediate level FET agreement shall apply. Nexperia hereby expressly objects to applying the customer’s general terms and conditions with regard to the purchase of Nexperia products by customer. No offer to sell or license — Nothing in this document may be interpreted or construed as an offer to sell products that is open for acceptance or the grant, conveyance or implication of any license under any copyrights, patents or other industrial or intellectual property rights. Export control — This document as well as the item(s) described herein may be subject to export control regulations. Export might require a prior authorization from national authorities. product for such automotive applications, use and specifications, and (b) whenever customer uses the product for automotive applications beyond Nexperia’s specifications such use shall be solely at customer’s own risk, and (c) customer fully indemnifies Nexperia for any liability, damages or failed product claims resulting from customer design and use of the product for automotive applications beyond Nexperia’s standard warranty and Nexperia’s product specifications. 9.4 Trademarks Notice: All referenced brands, product names, service names and trademarks are the property of their respective owners. Non-automotive qualified products — Unless this data sheet expressly states that this specific Nexperia product is automotive qualified, the product is not suitable for automotive use. It is neither qualified nor tested in accordance with automotive testing or application requirements. Nexperia accepts no liability for inclusion and/or use of non-automotive qualified products in automotive equipment or applications. In the event that customer uses the product for design-in and use in automotive applications to automotive specifications and standards, customer (a) shall use the product without Nexperia’s warranty of the 10. Contact information For more information, please visit: http://www.nexperia.com For sales office addresses, please send an email to: salesaddresses@nexperia.com PHC21025 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 04 — 17 March 2011 © Nexperia B.V. 2017. All rights reserved 15 of 16 Nexperia PHC21025 Complementary intermediate level FET 11. Contents 1 1.1 1.2 1.3 1.4 2 3 4 5 6 7 8 9 9.1 9.2 9.3 9.4 10 © Product profile . . . . . . . . . . . . . . . . . . . . . . . . . . .1 General description . . . . . . . . . . . . . . . . . . . . . .1 Features and benefits . . . . . . . . . . . . . . . . . . . . .1 Applications . . . . . . . . . . . . . . . . . . . . . . . . . . . .1 Quick reference data . . . . . . . . . . . . . . . . . . . . .1 Pinning information . . . . . . . . . . . . . . . . . . . . . . .2 Ordering information . . . . . . . . . . . . . . . . . . . . . .2 Limiting values. . . . . . . . . . . . . . . . . . . . . . . . . . .3 Thermal characteristics . . . . . . . . . . . . . . . . . . .5 Characteristics . . . . . . . . . . . . . . . . . . . . . . . . . . .6 Package outline . . . . . . . . . . . . . . . . . . . . . . . . .12 Revision history . . . . . . . . . . . . . . . . . . . . . . . . .13 Legal information. . . . . . . . . . . . . . . . . . . . . . . .14 Data sheet status . . . . . . . . . . . . . . . . . . . . . . .14 Definitions . . . . . . . . . . . . . . . . . . . . . . . . . . . . .14 Disclaimers . . . . . . . . . . . . . . . . . . . . . . . . . . . .14 Trademarks. . . . . . . . . . . . . . . . . . . . . . . . . . . .15 Contact information. . . . . . . . . . . . . . . . . . . . . .15 Nexperia B.V. 2017. All rights reserved For more information, please visit: http://www.nexperia.com For sales office addresses, please send an email to: salesaddresses@nexperia.com Date of release: 17 March 2011
PHC21025,118 价格&库存
很抱歉,暂时无法提供与“PHC21025,118”相匹配的价格&库存,您可以联系我们找货
PHC21025,118
    库存:15846
