APPLICABLE STANDARD
OPERATING
TEMPERATURE RANGE
Sep.1.2022 Copyright 2022 HIROSE ELECTRIC CO., LTD. All Rights Reserved.
In case of consideration for using Automotive equipment / device which demand high reliability, kindly contact our sales window correspondents.
RATING
1
-40 C
TO
STORAGE
-10 C TO 50 C (PACKED CONDITION)
TEMPERATURE RANGE
OPERATING OR STORAGE
RELATIVE HUMIDITY 90 % MAX (NOT DEWED)
HUMIDITY RANGE
APPLICABLE CABLE
105 C
VOLTAGE
50 V
AC / DC
CURRENT
0.5 A (note 1)
t=0.3±0.05mm, GOLD PLATING
SPECIFICATIONS
ITEM
TEST METHOD
REQUIREMENTS
QT
AT
ACCORDING TO DRAWING.
50 m MAX.
100 V DC.
INCLUDING FPC,FFC BULK RESISTANCE
(L=8mm)
500 M MIN.
150 V AC FOR 1 min.
NO FLASHOVER OR BREAKDOWN.
① CONTACT RESISTANCE: 50 m MAX.
② NO DAMAGE, CRACK AND LOOSENESS
OF PARTS.
① NO ELECTRICAL DISCONTINUITY OF
1 s.
② CONTACT RESISTANCE: 50 m MAX.
③ NO DAMAGE, CRACK AND LOOSENESS
OF PARTS.
DIRECTION OF INSERTION: 0.4×n N MIN
( n : NUMBER OF CONTACTS).
② INSULATION RESISTANCE: 50 M MIN.
OF PARTS.
② INSULATION RESISTANCE: 1 M MIN.
(AT HIGH HUMIDITY)
③ INSULATION RESISTANCE: 50 M MIN.
(AT DRY)
④ NO DAMAGE, CRACK AND LOOSENESS
OF PARTS.
OF PARTS.
② NO EVIDENCE OF CORROSION WHICH
AFFECTS TO OPERATION OF
CONNECTOR.
CONSTRUCTION
GENERAL EXAMINATION VISUALLY AND BY MEASURING INSTRUMENT.
MARKING
CONFIRMED VISUALLY.
ELECTRICAL CHARACTERISTICS
CONTACT RESISTANCE 1mA(DC OR 1000Hz).
INSULATION
RESISTANCE
VOLTAGE PROOF
MECHANICAL CHARACTERISTICS
MECHANICAL
OPERATION
20 TIMES INSERTIONS AND EXTRACTIONS.
1
VIBRATION
1
SHOCK
FREQUENCY 10 TO 55 Hz, HALF AMPLITUDE
0.75 mm, FOR 10 CYCLES IN 3 AXIAL
DIRECTIONS.
2
981 m/s , DURATION OF PULSE 6 ms
AT 3 TIMES IN 3 BOTH AXIAL DIRECTIONS.
FPC RETENTION FORCE
MEASURED BY APPLICABLE FPC.
(CONNECTOR,FPC AT INITIAL CONDITION.
THICKNESS OF FPC SHALL BE t=0.30mm )
ENVIRONMENTAL CHARACTERISTICS
1
RAPID CHANGE OF
TEMPERATURE
DAMP HEAT
(STEADY STATE)
DAMP HEAT,CYCLIC
1
1
1
TEMPERATURE-40→+15TO+35→+105→+15TO+35C
TIME
30→ 2 TO 3 → 30→ 2 TO 3 min.
UNDER
5 CYCLES.
EXPOSED AT
40±2 C,
RELATIVE HUMIDITY
90 TO 95 %,
96 h.
EXPOSED AT
-10
TO
+65 C,
RELATIVE HUMIDITY 90 TO 96 %,
10 CYCLES,TOTAL
240 h.
DRY HEAT
EXPOSED AT
105±2 C,
COLD
EXPOSED AT
-40±3C,
96 h.
96 h.
CORROSION SALT MIST EXPOSED AT 35±2 C 5% SALT WATER SPRAY
FOR 96 h.
SULPHUR DIOXIDE
EXPOSED AT 40±2 C , RELATIVE HUMIDITY
[JIS C 60068-2-42] 80±5% , 25±5 ppm FOR 96 h.
HYDROGEN SULPHIDE EXPOSED AT 40±2 C , RELATIVE HUMIDITY
[JIS C 60068-2-43] 80±5% , 10 TO 15 ppm FOR 96 h.
1
COUNT
DESCRIPTION OF REVISIONS
DESIGNED
9
DIS-F-00000493
RT.IKEDA
REMARK
1
Unless otherwise specified, refer to IEC 60512 .
Note
QT:Qualification Test
FORM HD0011-2-1
AT:Assurance Test X:Applicable Test
PART NO.
CODE NO.
DATE
HS.SAKAMOTO
15.10.26
APPROVED
RI.TAKAYASU
05.04.19
CHECKED
SS.WATANABE
05.04.18
DESIGNED
HH.TSUKUMO
05.04.18
DRAWN
HH.TSUKUMO
05.04.18
DRAWING NO.
SPECIFICATION SHEET
CHECKED
ELC4-155415-02
FH28D-**S-0.5SH(05)
CL586
1
1/2
SPECIFICATIONS
1
ITEM
RESISTANCE TO
SOLDERING HEAT
SOLDERABILITY
TEST METHOD
REQUIREMENTS
1) REFLOW SOLDERING (MAX 2 CYCLES.)
NO DEFORMATION OF CASE OF
PEAK TMP 250 C MAX
EXCESSIVE LOOSENESS OF THE
REFLOW TMP OVER 230 C WITHIN 60 sec.
TERMINALS.
PRE-HEAT 150 TO 200C FOR 90 TO 120 sec.
2) SOLDERING IRONS
TMP 350 ± 10 C FOR 5± 1 sec.
SOLDERED AT SOLDER TEMPERATURE,
A NEW UNIFORM COATING OF SOLDER
235±3 C FOR IMMERSION DURATION,
SHALL COVER A MINIMUM OF 95 % OF
2±0.5 sec.
THE SURFACE BEING IMMERSED.
QT
AT
(note 1)
WHEN THE SAME VALUE OF CURRENT ARE APPLIED TO ALL CONTACTS AT THE SAME TIME IN ONCE,
SET THE CURRENT TO THE 70 % OF THE RATED CURRENT VALUE.
Note
FORM HD0011-2-2
DRAWING NO.
SPECIFICATION SHEET
PART NO.
CODE NO
ELC4-155415-02
FH28D-**S-0.5SH(05)
CL586
1
2/2
FH28D-50S-0.5SH(05) 价格&库存
很抱歉,暂时无法提供与“FH28D-50S-0.5SH(05)”相匹配的价格&库存,您可以联系我们找货
