IX61G-A-10P
IX61G-A-10P
    HRS(广濑)
    SMD
    RJ11/RJ45连接器 卧贴
IX61G-A-10P 数据手册
IX Series Sep.1.2022 Copyright 2022 HIROSE ELECTRIC CO., LTD. All Rights Reserved. IEC Standard Compliant Next-Generation Ethernet Connector for Industrial Equipment Product page https://www.hirose.com/product/en/products/IX/ Special features page https://www.hirose.com/product/en/pr/ix_industrial/ May 2021 ⑤ IX Series/IEC Standard Compliant Next-Generation Ethernet Connector for Industrial Equipment Advance with ix Industrial TM Sep.1.2022 Copyright 2022 HIROSE ELECTRIC CO., LTD. All Rights Reserved. Overview ・Multi- purpose, compact I/ O connector for industrial machinery. ・IEC Standard IEC 61076- 3- 124 complaint ・Compact, robust and supports high speeds ・High EMC resistance Features 1. Contributes to Size Reduction 75% The ix IndustrialTM offers a size reduction of 75% compared to conventional RJ45 modular solutions. The reduced mounting space enables a high degree of board design freedom. The ix IndustrialTM also supports 10mm pitch parallel mounting. Compact size RJ45 reduced size compared to RJ45 ix Industrial TM 2. Single Action Lock Design Click Locking is completed simply by inserting the plug into the receptacle. The audio click indicates mating completion. The lock can be released easily by pushing on the plug buttons while pulling out. Single Action Lock for Easy Operation Clear Tactile Click Prevents Incomplete Mating 2 IX Series/IEC Standard Compliant Next-Generation Ethernet Connector for Industrial Equipment 3. Robust design resistant to prying The PCB- mounted receptacle shell is designed to minimize the influence of prying forces from the plug side on the mated surface. Additionally, the through- holes prevent peeling of the mounted portion of the contact. Stainless steel is used to enhance the mechanical strength of the metal parts. Sep.1.2022 Copyright 2022 HIROSE ELECTRIC CO., LTD. All Rights Reserved. 4. High EMC Resistance The optimized shielding design guarantees high EMC resistance for secure data transmission. 5. High Speed Transmission Supports Cat. 5e ( 1Gbps) and Cat. 6A( 10Gbps) high speed Ethernet performance 6. THR ( Through- Hole Mounting) Compatible The receptacle shell is mounted in the throughholes for enhanced PCB mounting strength. THR mounting enables simultaneous reflow mounting with the signal contact SMT, for reduced board mounting time. 3 IX Series/IEC Standard Compliant Next-Generation Ethernet Connector for Industrial Equipment Product Specifications Rated Current Rated Voltage All Pins 4 Pins : Pin No.1, 2, 6 and 7 Operating Temperature (Note 1) -40 to +85℃ 1.5A 3A Storage Temperature Range -30 to +60℃ 50V AC / 60V DC Sep.1.2022 Copyright 2022 HIROSE ELECTRIC CO., LTD. All Rights Reserved. Item Specification Conditions Contact Resistance Signal : 30m Ω Max. (Note 2) Shield : 100m Ω Max. (Note 2) Measured at 100mA Insulation Resistance 500M Ω Min. Measured at 500V DC Withstanding Voltage No flashover or breakdown Voltage of 500V DC applied for 1 min. Mating Durability Signal : 80m Ω Max. (Note 2) Shield : 100m Ω Max. (Note 2) 5,000 insertion/extraction cycles Vibration Resistance No electrical discontinuity of 1μ s Min. No damage, crack or loosened parts 10 to 500Hz, Half Amplitude 0.35mm, Acceleration of 50m/s2. Shock Resistance No electrical discontinuity of 1μ s Min. No damage, crack or loosened parts 300m/s2, 11ms Duration, 3 Axis in Both Directions, 3 Times Each Fretting Corrosion Resistance No electrical discontinuity of 1μ s Min. No damage, crack or loosened parts 490m/s2, 30 times/min, 1000 times Note 1 : Includes temperature rise due to current flow. Note 2 : Conductor resistance of the cable is not included. Materials / Finish ● Receptacle Component Materials Color/Finish Remarks Insulator Liquid Crystal Polymer Gray UL94V-0 Contact Copper Alloy Partially Gold Plated - Shielding Plate Stainless Steel - - Shell Stainless Steel Tin Plated - Polyamide Resin Black UL94V-0 Suction Cap ● Plug Component Material Color/Finish Remarks Contact Copper Alloy Partially Gold Plated - Insulator Polyamide Resin Black, Dark Gray UL94V-0 Shielding Plate Stainless Steel - - Insulator Case Polyamide Resin Black UL94V-0 Polycarbonate Resin Transparent, Transparent Yellow, Transparent Blue UL94V-0 Shield Case Stainless Steel Nickel Plated - Shield Shell Stainless Steel Nickel Plated - Cover Case Polycarbonate Resin Dark Gray UL94V-0 Guide 4 IX Series/IEC Standard Compliant Next-Generation Ethernet Connector for Industrial Equipment Product Number Structure Refer to the chart below when determining the product specifications from the product number. Please select from the product numbers listed in this catalog when placing orders. ■ Receptacle IX 61 G - A - 10 P (##) Sep.1.2022 Copyright 2022 HIROSE ELECTRIC CO., LTD. All Rights Reserved. ❶ ❷ ❸ ❹ ❺ ❻ ❾ ❶ Series Name IX Series ❹ Mating Key ❷ Mounting/ Assembly Method 61 : Upright Right Angle SMT 60 : Right Angle SMT 80 : Vertical SMT ❺ Maximum Number 10 : 10pos. of Usable 8 : 8pos. Positions ❻ Contact Gender P : Male Contact S : Female Contact ❾ Plating Specifications Blank : Gold Plated (01) : Palladium-Nickel Plated+Gold Plated ❸ Gigabit Ethernet Support G A : Type A B : Type B ■ Plug IX 40 G - A - 10 S - CV (7.0) (##) ❶ ❷ ❸ ❹ ❺ ❻ ❼ ❽ ❾ ❶ Series Name IX Series ❺ Maximum Number 10 : 10pos. of Usable 8 (Note) : 8pos. Positions ❷ Mounting/ Assembly Method 40 : Hand Solder 30 : IDC (26 to 28 AWG, Insulator Outer Diameter φ 0.95 to 1.05) 31 : IDC (24 to 25 AWG, Insulator Outer Diameter φ 1.1 to 1.25) 32 : IDC (22 AWG, Insulator Outer Diameter φ 1.4 to 1.6) ❻ Contact Gender P : Male Contact S : Female Contact ❼ Plug Cover Cabling Direction CV : Straight CVL1 : Downward Cabling CVL2 : Upward Cabling ❸ Gigabit Ethernet Support G ❽ Applicable Cable Diameter (7.0) : Sheath Outer Diameter φ 6.3 to 7.2 ❹ Mating Key A : Type A B : Type B ❾ Plating Specifications Blank : Gold Plated (01) : Palladium-Nickel Plated+Gold Plated Note : Contacts No.3 and 8 do not have a hole to pass the wire through the IDC guide. 5 IX Series/IEC Standard Compliant Next-Generation Ethernet Connector for Industrial Equipment Connector Mating Combination Diagram ●Receptacle ●Plug Sep.1.2022 Copyright 2022 HIROSE ELECTRIC CO., LTD. All Rights Reserved. Upward Right Angle Straight IX30G-#-10S-CV(7.0)(##) IX31G-#-10S-CV(7.0)(##) IX32G-#-8S-CV(7.0)(##) IX40G-#-10S-CV(7.0)(##) IX61G-#-10P(##) Right Angle Right Angle, Downward Cabling IX30G-#-10S-CVL1(7.0)(##) IX31G-#-10S-CVL1(7.0)(##) IX32G-#-8S-CVL1(7.0)(##) IX40G-#-10S-CVL1(7.0)(##) IX60G-#-10P(##) Vertical Right Angle, Upward Cabling IX30G-#-10S-CVL2(7.0) (##) IX31G-#-10S-CVL2(7.0) (##) IX32G-#-8S-CVL2(7.0) (##) IX40G-#-10S-CVL2(7.0) (##) IX80G-#-10P(##) Note : Please use the same mating key (Type A, B) for both the plug and receptacle. 6 IX Series/IEC Standard Compliant Next-Generation Ethernet Connector for Industrial Equipment Receptacle Upward Right Angle Contact No.1 Contact No.10 Mating Key Design Type A 0.4 0.4 1.5 Contact No.10 HRS No. 0.4 1.0 1.5 2.75 5.75 1.9 9.75 3.05 10×0.25 3.75 4.75 5.75 6.75 Contact Area Plating Purchase Unit IX61G-A-10P CL0251-0021-0-00 Gold Plated 0.2μ m IX61G-A-10P(01) CL0251-0021-0-01 Palladium-Nickel Plated 0.75μ m + Gold Plated 0.05μ m IX61G-B-10P CL0251-0026-0-00 Gold plated 0.2μ m IX61G-B-10P(01) CL0251-0026-0-01 Palladium-Nickel Plated 0.75μ m + Gold Plated 0.05μ m Right Angle 400pcs per reel Mating Key Design Type A Type B 9.4 (10.0) Contact No.10 Contact Contact Contact Contact No.5 No.10 No.6 No.1 6 Contact No.1 0.4 0.4 2.75 Contact No.5 9 10.4 1.5 11.65 1.5 3.15 4.15 5.15 6.15 7.15 10×0.25 8.0 8.9 2.4 1.5 0.9 5.7 Contact No.6 4.05 4.2 2×φ1.2 0.4 3.5 Sep.1.2022 Copyright 2022 HIROSE ELECTRIC CO., LTD. All Rights Reserved. 5.8 (6.2) 8.4 (8.8) 1.5 Contact No.1 Part No. (10.0) Contact No.6 9.4 Contact No.5 Type B Part No. HRS No. Contact Area Plating IX60G-A-10P CL0251-0016-0-00 Gold Plated 0.2μ m IX60G-A-10P(01) CL0251-0016-0-01 Palladium-Nickel Plated 0.75μ m + Gold Plated 0.05μ m IX60G-B-10P CL0251-0017-0-00 Gold Plated 0.2μ m IX60G-B-10P(01) CL0251-0017-0-01 Palladium-Nickel Plated 0.75μ m + Gold Plated 0.05μ m 7 Purchase Unit 550pcs per reel IX Series/IEC Standard Compliant Next-Generation Ethernet Connector for Industrial Equipment Vertical Mating Key Design Type A Type B 2×1.4 Sep.1.2022 Copyright 2022 HIROSE ELECTRIC CO., LTD. All Rights Reserved. Contact No.6 (R0.2) φ1.2 Contact No.6 3.075 Contact No.10 10×0.25(Lead Width) 0.25(Lead) Assembled Product Overview (7.1) (5.7) Contact No.1 7.8(Lead) Contact No.5 1.2 Contact No.10 0.25 2.0 0.25(Lead) 2.1 7.8 2×0.6 Contact No.5 3×R0.5 4.0(Lead) 2.0(Lead) 1.5 1.5 (C 0. 3) 0.25 Contact No.1 C1 9.0 3.5 0.4 1.75 6.6 5 (R0.2) 11 4.8 4.0 2.0 Suction Area Suction Cap 2.0(Lead) 4.0(Lead) 4.0 5.5 10.0 0.4 9.0 Part No. HRS No. Contact Area Plating IX80G-A-10P CL0251-0018-0-00 Gold Plated 0.2μ m IX80G-A-10P(01) CL0251-0018-0-01 Palladium-Nickel Plated 0.75μ m + Gold Plated 0.05μ m IX80G-B-10P CL0251-0019-0-00 Gold Plated 0.2μ m IX80G-B-10P(01) CL0251-0019-0-01 Palladium-Nickel Plated 0.75μ m + Gold Plated 0.05μ m Note : This product is delivered with a cap for Pick & Place mounting. Please remove the cap before use. 8 Purchase Unit 450pcs per reel IX Series/IEC Standard Compliant Next-Generation Ethernet Connector for Industrial Equipment Plug Contact No.10 Contact No.6 9.2 (φ 7. 2) Straight Contact No.1 Contact No.5 17.5 Mating Key Design Type A Type B Sep.1.2022 Copyright 2022 HIROSE ELECTRIC CO., LTD. All Rights Reserved. 22.9 5.7 16.3 16.3 Part No. HRS No. Contact Area Plating IX40G-A-10S-CV(7.0) CL0251-0022-0-00 Gold Plated 0.2μ m IX40G-A-10S-CV(7.0)(01) CL0251-0022-0-01 Palladium-Nickel Plated 0.75μ m + Gold Plated 0.05μ m IX40G-B-10S-CV(7.0) CL0251-0032-0-00 Gold Plated 0.2μ m IX40G-B-10S-CV(7.0)(01) CL0251-0032-0-01 Palladium-Nickel Plated 0.75μ m + Gold Plated 0.05μ m IX30G-A-10S-CV(7.0) CL0251-0020-0-00 Gold Plated 0.2μ m IX30G-A-10S-CV(7.0)(01) CL0251-0020-0-01 Palladium-Nickel Plated 0.75μ m + Gold Plated 0.05μ m IX30G-B-10S-CV(7.0) CL0251-0025-0-00 Gold Plated 0.2μ m IX30G-B-10S-CV(7.0)(01) CL0251-0025-0-01 Palladium-Nickel Plated 0.75μ m + Gold Plated 0.05μ m IX31G-A-10S-CV(7.0) CL0251-0023-0-00 Gold Plated 0.2μ m IX31G-A-10S-CV(7.0)(01) CL0251-0023-0-01 Palladium-Nickel Plated 0.75μ m + Gold Plated 0.05μ m IX31G-B-10S-CV(7.0) CL0251-0024-0-00 Gold Plated 0.2μ m IX31G-B-10S-CV(7.0)(01) CL0251-0024-0-01 Palladium-Nickel Plated 0.75μ m + Gold Plated 0.05μ m IX32G-A-8S-CV(7.0) (Note) CL0251-0042-0-00 Gold Plated 0.2μ m IX32G-A-8S-CV(7.0)(01) (Note) CL0251-0042-0-01 Palladium-Nickel Plated 0.75μ m + Gold Plated 0.05μ m IX32G-B-8S-CV(7.0) (Note) CL0251-0043-0-00 Gold Plated 0.2μ m IX32G-B-8S-CV(7.0)(01) (Note) CL0251-0043-0-01 Palladium-Nickel Plated 0.75μ m + Gold Plated 0.05μ m Note : Cable assembly for IX32G is possible up to 8 positions. Contacts No. 3 and 8 do not have a hole to pass the wire though the IDC guide. 9 Purchase Unit 100pcs per tray IX Series/IEC Standard Compliant Next-Generation Ethernet Connector for Industrial Equipment Right Angle, Downward Cabling Contact No.6 9.2 (φ 7. 2) Contact No.10 Contact No.1 5.7 16.3 14.4 8.75 24.0 13.5 Sep.1.2022 Copyright 2022 HIROSE ELECTRIC CO., LTD. All Rights Reserved. Contact No.5 Mating Key Design Type A Part No. HRS No. Type B Contact Area Plating IX30G-A-10S-CVL1(7.0) CL0251-0063-0-00 Gold Plated 0.2μ m IX30G-A-10S-CVL1(7.0)(01) CL0251-0063-0-01 Palladium-Nickel Plated 0.75μ m+ Gold Plated 0.05μ m IX30G-B-10S-CVL1(7.0) CL0251-0064-0-00 Gold Plated 0.2μ m IX30G-B-10S-CVL1(7.0)(01) CL0251-0064-0-01 Palladium-Nickel Plated 0.75μ m+ Gold Plated 0.05μ m IX31G-A-10S-CVL1(7.0) CL0251-0067-0-00 Gold Plated 0.2μ m IX31G-A-10S-CVL1(7.0)(01) CL0251-0067-0-01 Palladium-Nickel Plated 0.75μ m+ Gold Plated 0.05μ m IX31G-B-10S-CVL1(7.0) CL0251-0068-0-00 Gold Plated 0.2μ m IX31G-B-10S-CVL1(7.0)(01) CL0251-0068-0-01 Palladium-Nickel Plated 0.75μ m+ Gold Plated 0.05μ m IX32G-A-8S-CVL1(7.0) CL0251-0071-0-00 Gold Plated 0.2μ m IX32G-A-8S-CVL1(7.0)(01) CL0251-0071-0-01 Palladium-Nickel Plated 0.75μ m+ Gold Plated 0.05μ m IX32G-B-8S-CVL1(7.0) CL0251-0072-0-00 Gold Plated 0.2μ m IX32G-B-8S-CVL1(7.0)(01) CL0251-0072-0-01 Palladium-Nickel Plated 0.75μ m+ Gold Plated 0.05μ m IX40G-A-10S-CVL1(7.0) CL0251-0075-0-00 Gold Plated 0.2μ m IX40G-A-10S-CVL1(7.0)(01) CL0251-0075-0-01 Palladium-Nickel Plated 0.75μ m+ Gold Plated 0.05μ m IX40G-B-10S-CVL1(7.0) CL0251-0076-0-00 Gold Plated 0.2μ m IX40G-B-10S-CVL1(7.0)(01) CL0251-0076-0-01 Palladium-Nickel Plated 0.75μ m+ Gold Plated 0.05μ m 10 Purchase Unit 100pcs per tray IX Series/IEC Standard Compliant Next-Generation Ethernet Connector for Industrial Equipment Right Angle, Upward Cabling Contact No.6 Contact No.1 Contact No.5 9.2 2) 7. (φ Contact No.10 16.3 13.5 5.7 14.4 24 Sep.1.2022 Copyright 2022 HIROSE ELECTRIC CO., LTD. All Rights Reserved. 8.75 Mating Key Design Type A Part No. HRS No. Type B Contact Area Plating IX30G-A-10S-CVL2(7.0) CL0251-0065-0-00 Gold Plated 0.2μ m IX30G-A-10S-CVL2(7.0)(01) CL0251-0065-0-01 Palladium-Nickel Plated 0.75μ m + Gold Plated 0.05μ m IX30G-B-10S-CVL2(7.0) CL0251-0066-0-00 Gold Plated 0.2μ m IX30G-B-10S-CVL2(7.0)(01) CL0251-0066-0-01 Palladium-Nickel Plated 0.75μ m + Gold Plated 0.05μ m IX31G-A-10S-CVL2(7.0) CL0251-0069-0-00 Gold Plated 0.2μ m IX31G-A-10S-CVL2(7.0)(01) CL0251-0069-0-01 Palladium-Nickel Plated 0.75μ m + Gold Plated 0.05μ m IX31G-B-10S-CVL2(7.0) CL0251-0070-0-00 Gold Plated 0.2μ m IX31G-B-10S-CVL2(7.0)(01) CL0251-0070-0-01 Palladium-Nickel Plated 0.75μ m + Gold Plated 0.05μ m IX32G-A-8S-CVL2(7.0) CL0251-0073-0-00 Gold Plated 0.2μ m IX32G-A-8S-CVL2(7.0)(01) CL0251-0073-0-01 Palladium-Nickel Plated 0.75μ m + Gold Plated 0.05μ m IX32G-B-8S-CVL2(7.0) CL0251-0074-0-00 Gold Plated 0.2μ m IX32G-B-8S-CVL2(7.0)(01) CL0251-0074-0-01 Palladium-Nickel Plated 0.75μ m + Gold Plated 0.05μ m IX40G-A-10S-CVL2(7.0) CL0251-0077-0-00 Gold Plated 0.2μ m IX40G-A-10S-CVL2(7.0)(01) CL0251-0077-0-01 Palladium-Nickel Plated 0.75μ m + Gold Plated 0.05μ m IX40G-B-10S-CVL2(7.0) CL0251-0078-0-00 Gold Plated 0.2μ m IX40G-B-10S-CVL2(7.0)(01) CL0251-0078-0-01 Palladium-Nickel Plated 0.75μ m + Gold Plated 0.05μ m 11 Purchase Unit 100pcs per tray IX Series/IEC Standard Compliant Next-Generation Ethernet Connector for Industrial Equipment Recommended Land Pattern Dimensions ● IX61G-#-10P Recommended Metal Mask Pattern (t=0.15) Reference Board Mounting Dimensions (From Mounting Side) (t=1.6) 6.0 5.8 7.2 8.4 9.8 5.75 7.5 4×1.4 (LAND) Pattern Prohibited Area Note : Dimension tolerances not listed are ±0.02. ● IX60G-#-10P Recommended Metal Mask Pattern (t=0.15) Reference Board Mounting Dimensions (From Mounting Side) (t=1.6) 7.15 7.15 6.15 6.15 5.15 3.15 Contact No.5 5.15 10×0.19 3.15 Contact No.6 Contact No.10 10.4 10.6 12.0 Edge of PCB 8.0 9.4 15.0 16.4 Pattern Prohibited Area Note : Dimension tolerances not listed are ±0.05. Note : Dimension tolerances not listed are ±0.02. 12 3.4 6.8 2.0 2.5 4×3.05 (LAND) 9.0 (TH) 4×1.6 (LAND) +0.1 0 4.2 +0.1 0 4×2.45 4×1.0 (TH) 1.2 4.05 16×R0.3 4.45 2.4 16×R0.6 6.4 2×φ1.45 (HOLE) 3.8 2.5 2.4 4.15 10×0.3 (LAND) 0.4 4.15 Mating Position 3.35 4.0 4.5 5.0 2.5 4.4 7.0 11.4 14.0 4×0.8±0.1 0(TH) Note : Dimension tolerances not listed are ±0.05. Edge of PCB 1.0 5.75 7.5 Edge of PCB 1.2±0.1 0(HOLE) Contact No.1 1.95 4×2.7 (LAND) 1.9 2.5 2.95 16×R0.3 4×R0.5 Mating Position 10×0.19 16×R0.6 0 5.45-0.1 7.05±0.1 0 (9.75) 4×2.1±0.10 (TH) 10×0.3 (LAND) Contact No.10 3.35 1.95 4×R0.3 5.75 4.75 3.75 2.75 1.6 Edge of PCB (8.9) Sep.1.2022 Copyright 2022 HIROSE ELECTRIC CO., LTD. All Rights Reserved. 6.75 0.8±0.1 0(TH) 0.6±0.10(TH) 2.0(LAND) 1.4 +0.1 0(TH) 4×R0.6 Contact No.1 6.75 5.75 4.75 3.75 2.75 2.0(LAND) IX Series/IEC Standard Compliant Next-Generation Ethernet Connector for Industrial Equipment ● IX80G-#-10P Reference Board Mounting Dimensions (From Mounting Side) (t=1.6) Recommended Metal Mask Pattern (t=0.15) 9.0 11.0 4.0 4.0 2.0 4.0 0.25 2.0 10×0.6(LAND) Contact No.1 0.25 Contact No.5 10×0.5 2×1.4(LAND) Pattern Prohibited Area 2×0.8(TH) 4.37 2.1±0.05 2×1.9(TH) 4.37 Contact No.6 2×2.5(LAND) φ1.35(HOLE) Mounting Area Contact No.10 2.69 2.5 2.69 4.8 2.45 8×R0.3(TH) 2.45 4.4 4.4 Sep.1.2022 Copyright 2022 HIROSE ELECTRIC CO., LTD. All Rights Reserved. 7.8 8×R0.6(LAND) 0.25 2.0 3.075±0.05 4.0 0.25 2.0 4.0 7.5 11.0 Note : Dimension tolerances not listed are ±0.02. Note : Dimension tolerances not listed are ±0.05. 13 IX Series/IEC Standard Compliant Next-Generation Ethernet Connector for Industrial Equipment Panel Mounting Dimensions Diagram ● IX61G-#-10P Mated Condition Reference Panel Cut-out Dimensions Note : Dimensions are for reference. Housing Panel IX##G-#-#S-CV(7.0) 7.0 10.2 4×R1 IX61G-#-10P PCB Mounting Side (2.0) (0.55) (9.75) IX60G-#-10P Mated Condition Reference Panel Cut-out Dimensions Housing Panel Note : Dimensions are for reference. IX#G-#-#S-CV(7.0) IX60G-#-10P 11.0 4xR1 PCB Mounting Side 1.3 PCB 6.1 ● (2.0) (0.55) (8.9) ● IX80G-#-10P Mated Condition Reference Panel Cut-out Dimensions Note : Dimensions are for reference. IX##G-#-#S-CV(7.0) PCB (2.0) Housing Panel IX80G-#-10P 8×R0.3 4×R1 6.2 (0.55) 6.0 14 7.8 11.0 (9.0) Sep.1.2022 Copyright 2022 HIROSE ELECTRIC CO., LTD. All Rights Reserved. 0.8 PCB IX Series/IEC Standard Compliant Next-Generation Ethernet Connector for Industrial Equipment Cable Assembly Tools Part No. HRS No. Applicable Connector HT803/IXG-8/10S-63-72 CL0902-2218-0-00 IX##G-#-##S-CV(7.0) HT803/IXG-10S-CVL-70 CL0902-2223-0-00 IX##G-#-##S-CVL1(7.0) IX##G-#-##S-CVL2(7.0) Adapter for Cabling Certification Testing Sep.1.2022 Copyright 2022 HIROSE ELECTRIC CO., LTD. All Rights Reserved. This adapter requires the DSX CableAnalyzerTM from Fluke Networks for use. Part No. HRS No. DSX-CHA-5-IX-S CL0251-1001-0-00 (Note) DSX CableAnalyzerTM is a registered trademark of Fluke Networks. Applicable Cables List A list of applicable cables is available on the Hirose website. ( https: / / www. hirose. com/ product/ en/ pr/ ix_ industrial/ applicable_ cable_ list/ ) While Taking into Consideration Specifications mentioned in this catalog are reference values. When considering to order or use this product, please confirm the Drawing and Product Specifications sheets. Use an appropriate cable when using the connector in combination with cables. If considering usage of a non- specified cable, please contact your sales representative. If assembly process is done by jigs & tools which are not identified by Hirose, assurance will not be given. If considering usage for below mentioned applications, please contact your sales representative. In cases where the application will demand a high level of reliability, such as automotive, medical instruments, public infrastructure, aerospace/ defense etc. Hirose must review before assurance of reliability can be given. 2-6-3,Nakagawa Chuoh,Tsuzuki-Ku,Yokohama-Shi 224-8540,JAPAN        https://www.hirose.com ※ The contents of this catalog are current as of date of 5/ 2021. Contents are subject to change without notice for the purpose of improvements. 15
IX61G-A-10P 价格&库存
很抱歉,暂时无法提供与“IX61G-A-10P”相匹配的价格&库存,您可以联系我们找货
