SCM5B42-01
SCM5B42-01
    DATAFORTH(Dataforth)
    2-WIRE TRANSMITTER INTERFACE MOD
SCM5B42-01 数据手册
Isolated Analog Signal Conditioning Products SCM5B42 2-Wire Transmitter Interface Modules Description Each SCM5B42 2-wire transmitter interface module provides a single channel which accepts a 4 to 20mA process current input and provides a standard +1 to +5V or +2 to +10V output signal (Figure 1). An isolated +20VDC regulated power supply is provided to power the current transmitter. This allows a wire loop powered transmitter to be directly connected to the SCM5B42 without requiring an external power supply. The regulated supply will provide a nominal +20VDC at a loop current of 4mA to 20mA. The S B will provide a isolation barrier for non isolated wire field transmitters. It can also be used when additional isolation is re uired between an isolated wire transmitter and the input stage of the control room computer. The voltage output is logic switch controlled, which allows these modules to share a common analog bus without the re uirement of external multiplexers. The SCM5B modules are designed with a completely isolated computer side circuit which can be oated to from Power ommon, pin . This complete isolation means that no connection is re uired between I O Common and Power Common for proper operation of the output switch. If desired, the output switch can be turned on continuously by simply connecting pin , the Read nable pin, to I O ommon, pin . A precision current conversion resistor is supplied with the module. Soc ets are provided on the S PB bac panels to allow installation of this resistor. xtra resistors are available under part number S R . All field inputs are fully protected from accidental connection of power-line voltages up to 240VAC. The module has a 3dB bandwidth of H . Signal filtering is accomplished with a six pole filter, with two poles on the field side of the isolation barrier, and the other four on the computer side. F i g u r e 1 : S C M 5 B 4 2 B l o ck Features • Isolated +20VDC Current Loop Supply • Provides Isolation for Non-Isolated 2-Wire Transmitters • High-Level Voltage Output +1V to +5V or +2V to +10V • 1500Vrms Transformer Isolation • ANSI/IEEE C37.90.1 Transient Protection • Input Protected to 240VAC Continuous • 100dB CMR • 100Hz Signal Bandwidth • ± 0.03% Accuracy • ± 0.005% Linearity SA S ertified • CE and ATEX Compliant • Mix and Match SCM5B Types on Backpanel D ia g r a m 3 0 ©1995-2017 Dataforth Corporation, All Rights Reserved For information call 800-444-7644 ISO9001:2008-Registered QMS S C M 5 B Specifications Typical❇ at TA Module and Ordering Information D power SCM5B42 Input Range Input Resistor Value Accuracy Stability Loop Supply Voltage Isolated Excitation Protection Continuous Transient Input Protection Continuous Transient CMV, Input to Output Continuous Transient CMR (50 or 60Hz) NMR (– 3dB at 100Hz) Accuracy Linearity Stability Input Offset Output Offset Gain Noise Input, 0.1 to 10Hz Output, 100kHz Bandwidth, – 3dB Response Time, 90% Span (1) Output Range Output Resistance Output Protection Output Selection Time (to ± 1mV of VOUT) Output Current Limit Output nable ontrol Max Logic “0” Min Logic “1” Max Logic “1” Input Current “0,1” Power Supply Voltage Power Supply Current 4mA to 20mA . ± 0.1% ppm Nominal 20V at 4mA to 20mA Model Input Range Output Range SCM5B42-01 SCM5B42-02 4mA to 20mA 4mA to 20mA +1V to +5V +2V to +10V 240Vrms max ANSI/IEEE C37.90.1 240Vrms max ANSI/IEEE C37.90.1 1500Vrms max ANSI/IEEE C37.90.1 100dB dB per Decade above H ± 0.03% Span ± 0.005% Span ppm of Reading 10nArms rms 100Hz 4mS +1V to +5V or +2V to +10V Continuous Short to Ground s at load = 0 to 2000pF +8mA +0.8V +2.4V +36V . A Power Supply Sensitivity +5VDC ± 5% 180mA at Transmitter Load of 20mA 100mA at Transmitter Load of 4mA RTI(2) Mechanical Dimensions (h)(w)(d) 2.28” x 2.26” x 0.60” (58mm x 57mm x 15mm) Environmental Operating Temp. Range Storage Temp. Range Relative Humidity Emissions EN61000-6-4 Radiated, Conducted Immunity EN61000-6-2 RF ESD,EFT S C M 5 B to to 0 to 95% Noncondensing ISM, Group 1 Class A ISM, Group 1 Performance A ± 0.5% Span Error Performance B NOTES: ❇ ontact factory or your local Dataforth sales office for maximum values. Includes linearity, hysteresis and repeatability. Does not include S R accuracy. (2) RTI = Referenced to input. Visit our website www.dataforth.com ©1995-2017 Dataforth Corporation, All Rights Reserved 3 1 ISO9001:2008-Registered QMS S C M 5 B Isolated Analog Signal Conditioning Products
SCM5B42-01
物料型号:SCM5B42 器件简介:SCM5B42系列模块允许2线制环路供电变送器直接连接,提供4到20mA的过程电流输入,并提供标准+1到+5V或+2到+10V的输出信号。它还提供了隔离的+20VDC稳压电源来供电变送器,无需外部电源。SCM5B42提供了1500V的隔离屏障,适用于非隔离的2线制现场变送器,也可以用于需要在隔离的2线制变送器和控制室计算机输入级之间增加隔离的情况。
引脚分配:文档中提到了多个引脚,包括用于连接的Power Common、I/O Common、Read-Enable等,具体的引脚分配和功能需要查看文档的详细电路图。
参数特性:SCM5B42模块具有高精度的2002电流转换电阻器,100Hz的信号带宽,±0.03%的精度,±0.005%的线性度,以及满足ANSI/IEEE C37.90.1标准的瞬态保护。
功能详解:模块设计有完全隔离的计算机公共端和电源公共端,确保输出开关的正确操作。输出开关可以通过逻辑控制信号进行控制,允许这些模块在不需要外部多路复用器的情况下共享一个公共的模拟总线。
应用信息:SCM5B42适用于需要精确信号转换和隔离的应用场合,例如工业自动化和过程控制。
封装信息:SCM5B42的尺寸为2.28x2.26x0.60英寸(58mmx57mmx15mm),并且模块的机械尺寸和环境工作温度范围也在文档中给出。
SCM5B42-01 价格&库存
很抱歉,暂时无法提供与“SCM5B42-01”相匹配的价格&库存,您可以联系我们找货
