8B33-02
8B33-02
    DATAFORTH(Dataforth)
    ISOLATED TRUE RMS INPUT MODULE
8B33-02 数据手册
SensorLex® 8BIsolated IsolatedAnalog AnalogSignal SignalConditioning ConditioningProducts Products S C 8MB 5 B 8B33 Isolated True RMS Input Modules Description Each 8B33 True RMS input module provides a single channel of AC input which is converted to its True R S D value, filtered, isolated, amplified, and converted to a standard process voltage output (Figure 1). The field voltage or current input signal is processed through a pre amplifier and R S converter on the field side of the isolation barrier. The converted D signal is then chopped by a proprietary chopper circuit and transferred across the transformer isolation barrier, suppressing transmission of common mode spikes and surges. The computer side circuitry reconstructs, filters, and converts the signal to an industry standard output of 0 to 5VDC. Special input circuits provide protection against accidental connection of power line voltages up to A and against transient events defined by ANSI I . . . Features • Interfaces to RMS Voltage (0-300V) or RMS Current (0-1A) • Designed for Standard Operation with Frequencies of 45Hz to 1000Hz (Extended Range to 10kHz) ompatible with Standard urrent and Potential Transformers • Industry Standard Output of 0 to 5VDC . Factory alibrated Accuracy • 1500Vrms Transformer Isolation • Input Overload Protected to 350Vrms Max (Peak AC & DC) or 2Arms Continuous WARNING: The SensorLex 8B33 interfaces to ha ardous voltages and should only be wired by ualified personnel or licensed electricians. • 120dB CMR • ANSI/IEEE C37.90.1 Transient Protection • C-UL-US Listed • CE Compliant • ATEX Compliance Pending • Mix and Match Module Types on Backpanel Pre-Amp Conversion AC Source Iso-Chopper™ Amplifier Pat. Pending * I * Current Input Models Only F i g u r e 1 : 8 B 3 3 B l o ck D ia g r a m 1 0 8 ©1995-2017 Dataforth Corporation, All Rights Reserved For information call 800-444-7644 ISO9001:2008-Registered QMS SensorLex® 8B Isolated Analog Signal Conditioning Products Typical❇ at TA Module Input Signal Range Standard Frequency Range Extended Frequency Range Impedance Coupling Protection (1) Continuous (– 01 thru – 05) Continuous (– 06) Transient (– 01 thru – 05) Transient (– 06) Output Signal Range Voltage Limit Protection Ripple and Noise Accuracy (5-100% Span)(3) (4) Sinusoid 50/60Hz 45Hz to 1kHz 1kHz to 10kHz Non-Sinusoid Crest Factor = 1 Crest Factor = 2 Crest Factor = 3 Crest Factor = 4 Vs. Temperature Isolation (Common Mode) Input to Output, Input to Power Continuous Transient CMR (50Hz to 60Hz) Response Time, 90% Span Supply Voltage Current Sensitivity Mechanical Dimensions (h)(w)(d) Environmental Operating Temperature Range Storage Temperature Range Relative Humidity Emissions EN61000-6-4 Radiated, Conducted Immunity EN61000-6-2 RF ESD, EFT, Surge, Voltage Dips and D power Ordering Information 8B33 100mV to 300Vrms, 0 to 1Arms 45Hz to 1000Hz 1kHz to 10kHz , , , . AC Model Input Range 8B33-01 8B33-02 8B33-03 8B33-04 8B33-05 8B33-06 0mV to 100mV 0V to 1V 0V to 10V 0V to 150V 0V to 300V 0A to 1A Output Range 0V to +5V 0V to +5V 0V to +5V 0V to +5V 0V to +5V 0V to +5V 8 B Specifications 8 B 350Vrms 2Arms ANSI/IEEE C37.90.1 See note 2 0V to 5V ± 9V Continuous Short to Ground 0.0375% Span rms ± 0.25% Span ± 0.625% Span ± 1.375% Span, ± 3.25% Span(-06) ± 0.25% Span ± 0.325% Span ± 0.475% Span ± 0.7% Span ± 100ppm/º C 1500Vrms max ANSI/IEEE C37.90.1 120dB
8B33-02 价格&库存
很抱歉,暂时无法提供与“8B33-02”相匹配的价格&库存,您可以联系我们找货
