SCM5B41-08
SCM5B41-08
    DATAFORTH(Dataforth)
    ANALOG V-INPUT MODULE WIDE BW
SCM5B41-08 数据手册
Isolated Analog Signal Conditioning Products S C M 5 B SCM5B40/41 Analog Voltage Input Modules, Wide Bandwidth Description ach S B and S B wide bandwidth voltage input module provides a single channel of analog input which is amplified, isolated, and converted to a high-level analog voltage output (Figure 1). This voltage output is logic-switch controlled, allowing these modules to share a common analog bus without the re uirement of external multiplexers. Features • Accepts Millivolt and Voltage Level Signals • High-Level Voltage Outputs The SCM5B modules are designed with a completely isolated computer side circuit which can be oated to from Power ommon, pin . This complete isolation means that no connection is re uired between I O Common and Power Common for proper operation of the output switch. If desired, the output switch can be turned on continuously by simply connecting pin , the Read nable pin, to I O ommon, pin . • 1500Vrms Transformer Isolation The input signal is processed through a wide bandwidth pre amplifier on the field side of the isolation barrier. After amplification, the input signal is chopped by a proprietary chopper circuit. Isolation is provided by transformer coupling, again using a proprietary technique to suppress transmission of common mode spikes or surges. The module is powered from +5VDC, ± 5%. • ± 0.03% Accuracy A special input circuit on the SCM5B40 and SCM5B41 modules provides protection against accidental connection of power-line voltages up to 240VAC. F i g u r e 1 : S C M 5 B 4 0 / 4 1 B l o ck • ANSI/IEEE C37.90.1 Transient Protection • Input Protected to 240VAC Continuous • 100dB CMR • 10kHz Signal Bandwidth • ± 0.01% Linearity Drift SA S ertified • CE and ATEX Compliant • Mix and Match SCM5B Types on Backpanel D ia g r a m 2 8 ©1995-2017 Dataforth Corporation, All Rights Reserved For information call 800-444-7644 ISO9001:2008-Registered QMS Specifications Typical❇ at TA Module Input Range Input Bias Current Input Resistance Normal and Ordering Information D power SCM5B40 SCM5B41 ± 10mV to ± 1V ± 0.5nA ± 1V to ± 40V ± 0.05nA Overload CMV, Input to Output Continuous Transient CMR (50Hz or 60Hz) NMR (– 3dB at 10kHz) Accuracy Linearity Stability Input Offset Output Offset Gain Noise Input, 0.1 to 10Hz Output, 100kHz Bandwidth, – 3dB Rise Time, 10 to 90% Span Settling Time, to 0.1% (1) 240Vrms max ANSI/IEEE C37.90.1 1500Vrms max ANSI/IEEE C37.90.1 100dB dB per Decade above * * * * * * H ± 0.03% Span ± 0.01% Span * ppm * ppm . rms 10mVp-p 10kHz s s * * * * * Continuous Short to Ground s at load = 0 to 2000pF * Output nable ontrol Max Logic “0” Min Logic “1” Max Logic “1” Input Current “0,1” +0.8V +2.4V +36V . A Output Range† SCM5B40-01 SCM5B40-02 SCM5B40-03 SCM5B40-04 SCM5B40-05 SCM5B40-06 SCM5B40-07(3) – 10mV to +10mV – 50mV to +50mV – 100mV to +100mV – 10mV to +10mV – 50mV to +50mV – 100mV to +100mV – 1V to +1V 1, 2 1, 2 1, 2 3, 4 3, 4 3, 4 1, 2 SCM5B41-01 SCM5B41-02 SCM5B41-03 SCM5B41-04 SCM5B41-05 SCM5B41-06 SCM5B41-07 SCM5B41-08 SCM5B41-09 SCM5B41-10 – 1V to +1V – 5V to +5V 10V to +10V – 1V to +1V – 5V to +5V 10V to +10V 20V to +20V 20V to +20V 40V to +40V 40V to +40V 1, 2 1, 2 1, 2 3, 4 3, 4 3, 4 1, 2 3, 4 1, 2 3, 4 – – – – – – Output Ranges Available * See Ordering Information Input Range † rms Output Range Output Resistance Output Protection Output Selection Time (to ± 1mV of VOUT ) Output Current Limit Output Range 1. 2. – 3. 4. – 5V to +5V 10V to +10V 0V to +5V 0V to +10V Part o u fi NONE D NONE D am e SCM5B40-01 SCM5B40-01D SCM5B40-04 SCM5B40-04D * * ± 8mA * * * * +5VDC ± 5% 30mA RTI(2) Mechanical Dimensions (h)(w)(d) 2.28” x 2.26” x 0.60” (58mm x 57mm x 15mm) * to to 0 to 95% Noncondensing ISM, Group 1 Class A ISM, Group 1 Performance A ± 0.5% Span Error Performance B * * Power Supply Voltage Power Supply Current Power Supply Sensitivity Environmental Operating Temp. Range Storage Temp. Range Relative Humidity Emissions EN61000-6-4 Radiated, Conducted Immunity EN61000-6-2 RF ESD,EFT Model thru thru thru thru thru thru Power Off Input Protection Continuous Transient S C M 5 B * * RTI(2) * * * * * * * NOTES: ❇ ontact factory or your local Dataforth sales office for maximum values. Same specification as S B . Includes linearity, hysteresis and repeatability. (2) RTI = Referenced to input. Same as S B with input resistance. Visit our website www.dataforth.com ©1995-2017 Dataforth Corporation, All Rights Reserved 2 9 ISO9001:2008-Registered QMS S C M 5 B Isolated Analog Signal Conditioning Products
SCM5B41-08 价格&库存
很抱歉,暂时无法提供与“SCM5B41-08”相匹配的价格&库存,您可以联系我们找货
