8B47J-01
8B47J-01
    DATAFORTH(Dataforth)
    LINEARIZED THERMOCOUPLE MODULE
8B47J-01 数据手册
SensorLex® 8BIsolated IsolatedAnalog AnalogSignal SignalConditioning ConditioningProducts Products S C 8MB 5 B 8B47 Linearized Thermocouple Input Modules Description 8B modules are an optimal solution for monitoring real-world process signals and providing high-level signals to a data acquisition system. Each B module isolates, filters, amplifies, and lineari es a single channel of temperature input from a thermocouple and provides an analog voltage output (Figure 1). Features • Interfaces to Types J, K, and T Thermocouples • Linearizes Thermocouple Signal Lineari ation is accomplished using a four brea point piecewise linear approximation. • High-Level Voltage Outputs The 8B47 can interface to industry standard thermocouple types J, K, and T and has an output signal of 0 to +5V. Each module is coldunction compensated to correct for parasitic thermocouples formed by the thermocouple wire and screw terminals on the mounting bac panel. pscale open thermocouple detect is provided by an internal pull up resistor. • ANSI/IEEE C37.90.1 Transient Protection Signal filtering is accomplished with a pole filter optimi ed for time and frequency response which provides 70dB of normal-mode rejection at H . One pole of this filter is on the field side of the isolation barrier for anti-aliasing, and the other two are on the system side. A special input circuit on the 8B47 module provides protection against accidental connection of power-line voltages up to 240VAC. Clamp circuits on the I/O and power terminals protect against harmful transients. • 1500Vrms Isolation • Input Protection to 240VAC Continuous • 120dB CMR • 70dB NMR at 60Hz Low Drift with Ambient Temperature Accurate • CE Compliant • ATEX Compliance Pending • Mix and Match Module Types on Backpanel The modules are designed for installation in Class I, Division 2 hazardous locations and have a high level of immunity to environmental noise. F i g u r e 1 : 8 B 4 7 B l o ck D ia g r a m 1 3 0 ©1995-2017 Dataforth Corporation, All Rights Reserved For information call 800-444-7644 ISO9001:2008-Registered QMS to • C-UL-US Listed 8 B SensorLex® 8B Isolated Analog Signal Conditioning Products Typical❇ at TA Module Input Range Input Bias Current Input Resistance Normal Power Off Overload Input Protection Continuous(1) Transient CMV, Input to Output Transient, Input to Output CMR (50Hz or 60Hz) NMR and D power Ordering Information 8B47 Model – 0.1V to +0.5V – 25nA TC Type‡ Output Range Input Range 8B47J-01 J to F to 8B47J-02 J to F to F 240VAC ANSI/IEEE C37.90.1 8B47J-03 J 1500Vrms max ANSI/IEEE C37.90.1 120dB 70dB at 60Hz to F to F 8B47J-12 J to F to F Accuracy Stability Offset Gain Noise Output, 100kHz Bandwidth, – 3dB Response Time, 90% Span See Ordering Information 8B47K-04 K ppm ppm to F to F 8B47K-05 K to F to 8B47K-13 K Output Range Output Protection Transient Cold Junction Compensation Accuracy, Accuracy, to Open Input Response Open Input Detection Time 0V to +5V Continuous Short to Ground ANSI/IEEE C37.90.1 to F to F 8B47K-14 K to F to F 8B47T-06 T to F to F 8B47T-07 T to F to F Power Supply Voltage Power Supply Current Power Supply Sensitivity Mechanical Dimensions (h)(w)(d) Environmental Operating Temperature Range Storage Temperature Range Relative Humidity Emissions EN61000-6-4 Radiated, Conducted Immunity EN61000-6-2 RF ESD, EFT rms 3Hz 150ms . . Upscale
8B47J-01 价格&库存
很抱歉,暂时无法提供与“8B47J-01”相匹配的价格&库存,您可以联系我们找货
8B47J-01
库存:14
