PHKD13N03LT
Dual N-channel TrenchMOS logic level FET
Rev. 5 — 27 December 2011
Product data sheet
1. Product profile
1.1 General description
Dual logic level N-channel enhancement mode Field-Effect Transistor (FET) in a plastic
package using TrenchMOS technology. This product is designed and qualified for use in
computing, communications, consumer and industrial applications only.
1.2 Features and benefits
Low conduction losses due to low
on-state resistance
Simple gate drive required due to low
gate charge
Suitable for high frequency
applications due to fast switching
characteristics
1.3 Applications
DC-to-DC convertors
Notebook computers
Lithium-ion battery applications
Portable equipment
1.4 Quick reference data
Table 1.
Symbol
Parameter
Conditions
Min
Typ
Max
Unit
VDS
drain-source voltage
Tj ≥ 25 °C; Tj ≤ 150 °C
30
V
ID
drain current
Tsp = 25 °C; VGS = 10 V; see Figure 1;
see Figure 3
10.4
A
Ptot
total power dissipation
Tsp = 25 °C; see Figure 2
3.57
W
17
mΩ
3.9
nC
[1]
Static characteristics
RDSon
drain-source on-state resistance VGS = 10 V; ID = 8 A; Tj = 25 °C;
see Figure 9; see Figure 10
Dynamic characteristics
QGD
[1]
gate-drain charge
Single device conducting.
VGS = 5 V; ID = 5 A; VDS = 15 V;
Tj = 25 °C; see Figure 11
PHKD13N03LT
Nexperia
2. Pinning information
Table 2.
Pinning information
Pin
Symbol Description
1
S1
source1
2
G1
gate1
3
S2
source2
4
G2
gate2
5
D2
drain2
6
D2
drain2
7
D1
drain1
8
D1
drain
Simplified outline
Graphic symbol
8
5
1
4
SOT96-1 (SO8)
D2 D2
D1 D1
S1
S2
G1
G2
mbk725
3. Ordering information
Table 3.
Type number
Package
PHKD13N03LT
Name
Description
Version
SO8
plastic small outline package; 8 leads; body width 3.9 mm
SOT96-1
4. Limiting values
Table 4.
Limiting values
In accordance with the Absolute Maximum Rating System (IEC 60134).
Symbol
Parameter
Conditions
Min
Max
Unit
VDS
30
V
VDGR
drain-gate voltage
Tj ≥ 25 °C; Tj ≤ 150 °C; RGS = 20 kΩ
30
V
VGS
gate-source voltage
drain current
ID
-20
V
Tsp = 100 °C; VGS = 10 V; see Figure 1
[1]
6.6
A
see Figure 3
[1]
10.4
A
[1]
42
A
3.57
W
IDM
peak drain current
Tsp = 25 °C; pulsed; tp ≤ 10 µs; see Figure 3
Ptot
Tstg
storage temperature
-55
150
°C
Tj
junction temperature
-55
150
°C
Source-drain diode
IS
ISM
[1]
source current
Tsp = 25 °C
[1]
3.2
A
peak source current
[1]
42
A
PHKD13N03LT
Product data sheet
All information provided in this document is subject to legal disclaimers.
Nexperia B.V. 2017. All rights reserved
2 of 13
PHKD13N03LT
Nexperia
03aa25
120
03aa17
120
Ider
Pder
80
80
40
40
100
150
200
100
150
Tsp (°C)
Fig 1.
Normalized continuous drain current as a
function of solder point temperature
200
Tsp (°C)
Fig 2.
Normalized total power dissipation as a
003aag938
102
ID
(A)
tp =10 μ s
Limit RDSon = V DS / ID
100 μ s
10
1 ms
10 ms
1
DC
100 ms
10-1
10-2
10-1
Fig 3.
1
10
102
VDS (V)
Safe operating area; continuous and peak drain currents as a function of drain-source voltage
PHKD13N03LT
Product data sheet
3 of 13
PHKD13N03LT
Nexperia
5. Thermal characteristics
Table 5.
Symbol
Parameter
Conditions
Min
Typ
Max
Unit
Rth(j-sp)
thermal resistance from junction to
solder point
see Figure 4
35
K/W
Rth(j-a)
ambient
minimum footprint ; mounted on
a printed-circuit board
70
K/W
003aaa415
102
Zth(j-sp)
(K/W)
δ = 0.5
10
0.2
0.1
0.05
0.02
1
δ=
P
single pulse
tp
T
t
tp
T
10-1
10-4
Fig 4.
10-3
10-2
10-1
1
tp (s)
10
Transient thermal impedance from junction to solder point as a function of pulse duration
PHKD13N03LT
Product data sheet
4 of 13
PHKD13N03LT
Nexperia
6. Characteristics
Table 6.
Characteristics
Symbol
Parameter
Conditions
Min
Typ
Max
Unit
V(BR)DSS
drain-source breakdown
voltage
ID = 250 µA; VGS = 0 V; Tj = -55 °C
27
V
ID = 250 µA; VGS = 0 V; Tj = 25 °C
30
V
VGS(th)
gate-source threshold voltage
ID = 250 µA; VDS = VGS; Tj = -55 °C;
see Figure 8
2.2
V
ID = 250 µA; VDS = VGS; Tj = 150 °C;
see Figure 8
0.5
V
ID = 250 µA; VDS = VGS; Tj = 25 °C;
see Figure 8
1
1.5
2
V
1
µA
IDSS
drain leakage current
VDS = 24 V; VGS = 0 V; Tj = 25 °C
VDS = 24 V; VGS = 0 V; Tj = 100 °C
5
µA
IGSS
gate leakage current
VGS = 20 V; VDS = 0 V; Tj = 25 °C
100
nA
VGS = -20 V; VDS = 0 V; Tj = 25 °C
100
nA
VGS = 10 V; ID = 8 A; Tj = 150 °C;
34
mΩ
VGS = 4.5 V; ID = 7 A; Tj = 25 °C;
see Figure 9
21
26
mΩ
17
mΩ
ID = 5 A; VDS = 15 V; VGS = 5 V;
10.7
nC
2.7
nC
3.9
nC
752
pF
200
pF
130
pF
6
ns
7
ns
RDSon
resistance
QG(tot)
total gate charge
QGS
gate-source charge
QGD
gate-drain charge
Ciss
input capacitance
Coss
output capacitance
Crss
reverse transfer capacitance
td(on)
turn-on delay time
tr
rise time
td(off)
turn-off delay time
23
ns
tf
fall time
11
ns
VDS = 15 V; VGS = 0 V; f = 1 MHz;
Tj = 25 °C; see Figure 12
VDS = 15 V; RL = 10 Ω; VGS = 10 V;
RG(ext) = 6 Ω; Tj = 25 °C; ID = 1.5 A
Source-drain diode
VSD
source-drain voltage
IS = 7 A; VGS = 0 V; Tj = 25 °C;
see Figure 13
0.86
1.1
V
trr
reverse recovery time
25
ns
Qr
recovered charge
IS = 7 A; dIS/dt = -100 A/µs; VGS = 0 V;
VDS = 30 V; Tj = 25 °C
5
nC
PHKD13N03LT
Product data sheet
5 of 13
PHKD13N03LT
Nexperia
003aaa325
10
10 V 5 V
ID
(A)
003aaa326
10
VGS (V) =
3V
VDS > ID × RDSon
ID
(A)
2.8 V
8
8
2.7 V
6
6
2.6 V
4
4
2.5 V
2.4 V
2
Tj = 150 °C
2
25 °C
2.3 V
Fig 5.
0.2
0.4
0.6
0.8
1
VDS (V)
Output characteristics: drain current as a
function of drain-source voltage; typical values
3
VGS (V)
Fig 6.
003aaa426
10−1
1
Transfer characteristics: drain current as a
function of gate-source voltage; typical values
03aa33
2.5
VGS(th)
(V)
ID
(A)
10−2
2
10−3
max
1.5
typ
10−4
1
min
10−5
0.5
min
typ
max
10−6
2
3
120
VGS (V)
Fig 7.
Sub-threshold drain current as a function of
gate-source voltage
PHKD13N03LT
Product data sheet
Fig 8.
Tj (°C)
180
Gate-source threshold voltage as a function of
6 of 13
PHKD13N03LT
Nexperia
003aaa327
80
2.5 V
2.6 V
03aa27
2
2.8 V
RDSon
(mΩ)
a
60
1.5
40
1
3V
4V
5V
0.5
10 V
VGS (V) =
4
6
8
−60
10
ID (A)
Fig 9.
Drain-source on-state resistance as a function
of drain current; typical values
003aaa330
5
VGS
(V)
120
Tj (°C)
180
Fig 10. Normalized drain-source on-state resistance
factor as a function of junction temperature
003aaa328
104
C
(pF)
4
103
Ciss
3
2
Coss
Crss
102
1
10
15
10
10−1
1
10
102
QG (nC)
VDS (V)
Fig 11. Gate-source voltage as a function of gate
charge; typical values
PHKD13N03LT
Product data sheet
Fig 12. Input, output and reverse transfer capacitances
as a function of drain-source voltage; typical
values
7 of 13
PHKD13N03LT
Nexperia
003aaa329
5
IS
(A)
4
3
2
1
Tj = 25 °C
150 °C
0.4
0.6
0.8
1
VSD (V)
Fig 13. Source current as a function of source-drain voltage; typical values
PHKD13N03LT
Product data sheet
8 of 13
PHKD13N03LT
Nexperia
7. Package outline
SO8: plastic small outline package; 8 leads; body width 3.9 mm
SOT96-1
D
E
A
X
c
y
HE
v M A
Z
5
8
Q
A2
A
(A 3)
A1
pin 1 index
θ
Lp
1
L
4
e
detail X
w M
bp
5 mm
scale
DIMENSIONS (inch dimensions are derived from the original mm dimensions)
UNIT
A
max.
A1
A2
A3
bp
c
D (1)
E (2)
e
HE
L
Lp
Q
v
w
y
Z (1)
mm
1.75
0.25
0.10
1.45
1.25
0.25
0.49
0.36
0.25
0.19
5.0
4.8
4.0
3.8
1.27
6.2
5.8
1.05
1.0
0.4
0.7
0.6
0.25
0.25
0.1
0.7
0.3
inches
0.069
0.010 0.057
0.004 0.049
0.01
0.019 0.0100
0.014 0.0075
0.20
0.19
0.16
0.15
0.05
0.01
0.01
0.004
0.028
0.012
0.244
0.039 0.028
0.041
0.228
0.016 0.024
θ
8o
o
Notes
1. Plastic or metal protrusions of 0.15 mm (0.006 inch) maximum per side are not included.
2. Plastic or metal protrusions of 0.25 mm (0.01 inch) maximum per side are not included.
REFERENCES
OUTLINE
VERSION
IEC
JEDEC
SOT96-1
076E03
MS-012
JEITA
EUROPEAN
PROJECTION
ISSUE DATE
99-12-27
03-02-18
Fig 14. Package outline SOT96-1 (SO8)
PHKD13N03LT
Product data sheet
9 of 13
PHKD13N03LT
Nexperia
8. Revision history
Table 7.
Revision history
Document ID
Release date
Data sheet status
Change notice
Supersedes
PHKD13N03LT v.5
20111227
Product data sheet
PHKD13N03LT v.4
PHKD13N03LT v.3
Modifications:
PHKD13N03LT v.4
PHKD13N03LT
Product data sheet
Various changes to content.
20111122
Product data sheet
10 of 13
PHKD13N03LT
Nexperia
9. Legal information
9.1
Data sheet status
Document status [1] [2]
Product status [3]
Definition
Objective [short] data sheet
Development
This document contains data from the objective specification for product development.
Preliminary [short] data sheet
Qualification
This document contains data from the preliminary specification.
Product [short] data sheet
Production
This document contains the product specification.
[1]
Please consult the most recently issued document before initiating or completing a design.
[2]
The term 'short data sheet' is explained in section "Definitions".
[3]
The product status of device(s) described in this document may have changed since this document was published and may differ in case of multiple devices. The latest product
status information is available on the Internet at URL http://www.nexperia.com.
9.2
Definitions
Preview — The document is a preview version only. The document is still
subject to formal approval, which may result in modifications or additions.
Nexperia does not give any representations or warranties as to
the accuracy or completeness of information included herein and shall have
no liability for the consequences of use of such information.
Draft — The document is a draft version only. The content is still under
internal review and subject to formal approval, which may result in
modifications or additions. Nexperia does not give any
representations or warranties as to the accuracy or completeness of
information included herein and shall have no liability for the consequences of
Short data sheet — A short data sheet is an extract from a full data sheet
with the same product type number(s) and title. A short data sheet is intended
for quick reference only and should not be relied upon to contain detailed and
full information. For detailed and full information see the relevant full data
sheet, which is available on request via the local Nexperia sales
office. In case of any inconsistency or conflict with the short data sheet, the
full data sheet shall prevail.
Product specification — The information and data provided in a Product
data sheet shall define the specification of the product as agreed between
Nexperia and its customer, unless Nexperia and
customer have explicitly agreed otherwise in writing. In no event however,
shall an agreement be valid in which the Nexperia product is
deemed to offer functions and qualities beyond those described in the
Product data sheet.
9.3
Disclaimers
Limited warranty and liability — Information in this document is believed to
be accurate and reliable. However, Nexperia does not give any
representations or warranties, expressed or implied, as to the accuracy or
completeness of such information and shall have no liability for the
In no event shall Nexperia be liable for any indirect, incidental,
punitive, special or consequential damages (including - without limitation - lost
profits, lost savings, business interruption, costs related to the removal or
replacement of any products or rework charges) whether or not such
damages are based on tort (including negligence), warranty, breach of
contract or any other legal theory.
Notwithstanding any damages that customer might incur for any reason
whatsoever, Nexperia’s aggregate and cumulative liability towards
customer for the products described herein shall be limited in accordance
with the Terms and conditions of commercial sale of Nexperia.
PHKD13N03LT
Product data sheet
Right to make changes — Nexperia reserves the right to make
changes to information published in this document, including without
limitation specifications and product descriptions, at any time and without
notice. This document supersedes and replaces all information supplied prior
to the publication hereof.
Suitability for use — Nexperia products are not designed,
authorized or warranted to be suitable for use in life support, life-critical or
safety-critical systems or equipment, nor in applications where failure or
malfunction of a Nexperia product can reasonably be expected
to result in personal injury, death or severe property or environmental
damage. Nexperia accepts no liability for inclusion and/or use of
Nexperia products in such equipment or applications and
therefore such inclusion and/or use is at the customer’s own risk.
Quick reference data — The Quick reference data is an extract of the
product data given in the Limiting values and Characteristics sections of this
document, and as such is not complete, exhaustive or legally binding.
Applications — Applications that are described herein for any of these
products are for illustrative purposes only. Nexperia makes no
representation or warranty that such applications will be suitable for the
specified use without further testing or modification.
Customers are responsible for the design and operation of their applications
and products using Nexperia products, and Nexperia
accepts no liability for any assistance with applications or customer product
design. It is customer’s sole responsibility to determine whether the Nexperia
product is suitable and fit for the customer’s applications and
products planned, as well as for the planned application and use of
customer’s third party customer(s). Customers should provide appropriate
design and operating safeguards to minimize the risks associated with their
applications and products.
Nexperia does not accept any liability related to any default,
damage, costs or problem which is based on any weakness or default in the
customer’s applications or products, or the application or use by customer’s
third party customer(s). Customer is responsible for doing all necessary
testing for the customer’s applications and products using Nexperia
products in order to avoid a default of the applications and
the products or of the application or use by customer’s third party
customer(s). Nexperia does not accept any liability in this respect.
Limiting values — Stress above one or more limiting values (as defined in
the Absolute Maximum Ratings System of IEC 60134) will cause permanent
damage to the device. Limiting values are stress ratings only and (proper)
operation of the device at these or any other conditions above those given in
the Recommended operating conditions section (if present) or the
Characteristics sections of this document is not warranted. Constant or
repeated exposure to limiting values will permanently and irreversibly affect
the quality and reliability of the device.
11 of 13
PHKD13N03LT
Nexperia
Terms and conditions of commercial sale — Nexperia
products are sold subject to the general terms and conditions of commercial
sale, as published at http://www.nexperia.com/profile/terms, unless otherwise
agreed in a valid written individual agreement. In case an individual
agreement is concluded only the terms and conditions of the respective
agreement shall apply. Nexperia hereby expressly objects to
applying the customer’s general terms and conditions with regard to the
purchase of Nexperia products by customer.
No offer to sell or license — Nothing in this document may be interpreted or
construed as an offer to sell products that is open for acceptance or the grant,
conveyance or implication of any license under any copyrights, patents or
other industrial or intellectual property rights.
Export control — This document as well as the item(s) described herein may
be subject to export control regulations. Export might require a prior
authorization from competent authorities.
In the event that customer uses the product for design-in and use in
automotive applications to automotive specifications and standards, customer
(a) shall use the product without Nexperia’s warranty of the
product for such automotive applications, use and specifications, and (b)
whenever customer uses the product for automotive applications beyond
Nexperia’s specifications such use shall be solely at customer’s
own risk, and (c) customer fully indemnifies Nexperia for any
liability, damages or failed product claims resulting from customer design and
use of the product for automotive applications beyond Nexperia’s
standard warranty and Nexperia’s product specifications.
9.4
Trademarks
Notice: All referenced brands, product names, service names and trademarks
are the property of their respective owners.
Non-automotive qualified products — Unless this data sheet expressly
states that this specific Nexperia product is automotive qualified,
the product is not suitable for automotive use. It is neither qualified nor tested
in accordance with automotive testing or application requirements. Nexperia
non-automotive qualified products in automotive equipment or applications.
10. Contact information
For more information, please visit: http://www.nexperia.com
For sales office addresses, please send an email to: salesaddresses@nexperia.com
PHKD13N03LT
Product data sheet
12 of 13
Nexperia
PHKD13N03LT
11. Contents
1
1.1
1.2
1.3
1.4
2
3
4
5
6
7
8
9
9.1
9.2
9.3
9.4
10
Product profile . . . . . . . . . . . . . . . . . . . . . . . . . . .1
General description . . . . . . . . . . . . . . . . . . . . . .1
Features and benefits . . . . . . . . . . . . . . . . . . . . .1
Applications . . . . . . . . . . . . . . . . . . . . . . . . . . . .1
Quick reference data . . . . . . . . . . . . . . . . . . . . .1
Pinning information . . . . . . . . . . . . . . . . . . . . . . .2
Ordering information . . . . . . . . . . . . . . . . . . . . . .2
Limiting values. . . . . . . . . . . . . . . . . . . . . . . . . . .2
Thermal characteristics . . . . . . . . . . . . . . . . . . .4
Characteristics . . . . . . . . . . . . . . . . . . . . . . . . . . .5
Package outline . . . . . . . . . . . . . . . . . . . . . . . . . .9
Revision history . . . . . . . . . . . . . . . . . . . . . . . . .10
Legal information. . . . . . . . . . . . . . . . . . . . . . . . 11
Data sheet status . . . . . . . . . . . . . . . . . . . . . . . 11
Definitions . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 11
Disclaimers . . . . . . . . . . . . . . . . . . . . . . . . . . . . 11
Trademarks. . . . . . . . . . . . . . . . . . . . . . . . . . . .12
Contact information. . . . . . . . . . . . . . . . . . . . . .12
Date of release: 27 December 2011
