8B45-05
8B45-05
    DATAFORTH(Dataforth)
    FREQUENCY INPUT MODULE
8B45-05 数据手册
SensorLex® 8BIsolated IsolatedAnalog AnalogSignal SignalConditioning ConditioningProducts Products 8B45 Frequency Input Modules Description 8B modules are an optimal solution for monitoring real-world process signals and providing high-level signals to a data acquisition system. Each 8B45 module isolates and conditions a frequency input signal and provides an analog voltage output (Figure 1). The fre uency input signal can be either a TTL level or ero crossing with as little as ± 100mV amplitude. Input circuitry for each signal type has built in hysteresis to prevent spurious noise from corrupting the module output. TTL signals are applied to the + and – terminals while zero crossing signals are applied to the +EXC and – terminals. Reference the bloc diagram below. A excitation is available for use with magnetic pic up or contact closure type sensors. The excitation is available on the terminal with return on the – terminal. A special input circuit on the 8B45 module provides protection against accidental connection of power-line voltages up to 240VAC. Clamp circuits on the I/O and power terminals protect against harmful transients. Features • Accepts Frequency Input Signals 0 to 100kHz • TTL or Zero-Crossing Signal Inputs • High-Level Voltage Outputs • 1500Vrms Isolation • ANSI/IEEE C37.90.1 Transient Protection • Input Protection to 240VAC Continuous • 100dB CMR • ± 0.05% Accuracy • ± 0.02% Linearity Low Drift with Ambient Temperature • C-UL-US Listed Isolation is provided by optical coupling to suppress transmission of common mode spikes or surges. The module is powered from +5VDC, ± 5%. • CE Compliant The modules are designed for installation in Class I, Division 2 hazardous locations and have a high level of immunity to environmental noise. • Mix and Match Module Types on Backpanel F i g u r e 1 : 8 B 4 5 B l o ck • ATEX Compliance Pending D ia g r a m 1 2 8 ©1995-2017 Dataforth Corporation, All Rights Reserved For information call 800-444-7644 ISO9001:2008-Registered QMS S C 8MB 5 B SensorLex® 8B Isolated Analog Signal Conditioning Products Module Input Range Input Threshold Minimum Input Maximum Input Minimum Pulse Width TTL Input Low TTL Input High Input Hysteresis Zero Crossing TTL Input Resistance Normal Power Off Overload Input Protection Continuous(1) Transient Excitation CMV, Input to Output Continuous Transient CMR (50 or 60Hz) Accuracy(2) Linearity Stability Offset Gain Noise Output Ripple Response Time (0 to 90%) 8B45-01, -02, -03 8B45-04, -05, -06 8B45-07, -08 Output Range Output Protection Transient Power Supply Voltage Power Supply Current Power Supply Sensitivity Mechanical Dimensions (h)(w)(d) Environmental Operating Temp. Range Storage Temp. Range Relative Humidity Emissions EN61000-6-4 Radiated, Conducted Immunity EN61000-6-2 RF ESD,EFT Typical❇ at TA and D power Ordering Information 8B45 0Hz to 100kHz Zero Crossing 100mVp-p 350Vp-p TTL, 170Vp-p Zero Crossing s 0.8V max 2.4V min ± 50mV 1.5V Model Input Range 8B45-01 8B45-02 8B45-03 8B45-04 8B45-05 8B45-06 8B45-07 8B45-08 0Hz to 500Hz 0Hz to 1kHz 0Hz to 2.5kHz 0Hz to 5kHz 0Hz to 10kHz 0Hz to 25kHz 0Hz to 50kHz 0Hz to 100kHz Output Range 0V to +5V 0V to +5V 0V to +5V 0V to +5V 0V to +5V 0V to +5V 0V to +5V 0V to +5V 8 B Specifications 8 B 240Vrms max ANSI/IEEE C37.90.1 +5V at 8mA max 1500Vrms max ANSI/IEEE C37.90.1 100dB ± 0.05% Span ± 0.02% Span ppm ppm 2 % span 160ms, 80ms, 35ms 16ms, 8.5ms, 3.4ms 1.6ms, 0.8ms 0 to +5V Continuous Short to Ground ANSI/IEEE C37.90.1 +5VDC ± 5% 45mA ± 75ppm/% 1.11” x 1.65” x 0.40” (28.1mm x 41.9mm x 10.2mm) to to 0 to 95% Noncondensing ISM, Group 1 Class A ISM, Group 1 Performance A ± 0.5% Span Error Performance B NOTES: ❇ ontact factory or your local Dataforth sales office for maximum values. A between Input terminal and Input, , or terminals. A between Input and or terminals. A between and terminals. Includes linearity, hysteresis and repeatability. Installation Notes: . This uipment is Suitable for se in lass I, Division , Groups A, B, , D, or Non-Hazardous Locations Only. . ARNING xplosion Ha ard Substitution of Any omponents ay Impair Suitability for lass I, Division . 3.) WARNING - Explosion Hazard - Do Not Disconnect Equipment Unless Power Has Been Switched Off or The Area is nown to be Non Ha ardous. Visit our website www.dataforth.com ©1995-2017 Dataforth Corporation, All Rights Reserved 1 2 9 ISO9001:2008-Registered QMS
8B45-05 价格&库存
很抱歉,暂时无法提供与“8B45-05”相匹配的价格&库存,您可以联系我们找货
8B45-05
