Additional Resources:
Product Page
3D Model
date
08/05/2022
page 1 of 10
SERIES: AMT21 | DESCRIPTION: MODULAR ABSOLUTE ENCODER
FEATURES
• high speed protocol for fast low latency position data
• patented capacitive ASIC technology
• low power consumption
• 12 or 14-bit absolute position with multi-turn capability
• 3.3 V half-duplex RS485 - high speed 2 Mbps or adjustable data rate
• settable zero position
• configuration and programming via AMT Viewpoint™ software
• compact modular package with locking hub for ease of installation
• radial and axial cable connections
• -40 ~ 105°C operating temperature
ELECTRICAL
parameter
conditions/description
min
power supply
VDD
3.8
start-up time1
current consumption
Note:
with unloaded output
typ
max
5
5.5
units
V
200
ms
16
mA
1. Encoder must be stationary during start-up.
ABSOLUTE POSITION CHARACTERISTICS
parameter
resolution
12 or 14-bit
min
accuracy
absolute zero position
settable via AMT Viewpoint™ GUI or RS485 (single-turn
versions only)
multi-turn
multi-turn and single-turn versions available
turns counter2
signed binary number
absolute position update rate
12-bit
14-bit
Notes:
typ
max
units
0.2
degrees
14
bits
25
100
µs
µs
2. Multi-turn encoders only.
MECHANICAL
parameter
min
motor shaft length
max
9
motor shaft tolerance
mm
15.7
axial play
12-bit position resolution
14-bit position resolution
cuidevices.com
units
mm
NOM +0/-0.015
weight
rotational speed at each resolution
typ
g
±0.3
mm
8,000
4,000
RPM
RPM
Product Page
3D Model
CUI DEVICES | SERIES: AMT21 | DESCRIPTION: MODULAR ABSOLUTE ENCODER
date 08/05/2022 | page 2 of 10
ENVIRONMENTAL
parameter
min
typ
-40
humidity
non-condensing
vibration
10~500 Hz, 5 minute sweep, 2 hours on each XYZ
shock
3 pulses, 6 ms, 3 on each XYZ
RoHS
yes
REACH
EC 1907/2006
max
units
105
°C
85
5
G
200
G
max
units
RS485 INTERFACE – 2 MBPS DATA RATE (A,B,C,D OPTIONS)
parameter
min
protocol
RS485 balanced digital multi-port interface
data rate
8 data bits, no parity, 1 stop bit, asynchronous
transceiver
Texas Instruments SN65HVD75
turnaround time
time before encoder responds with position
3
driver differential output voltage
magnitude
load resistance = 54 Ω
1.5
typ
2
Mbps
µs
2
3.3
V
typ
max
units
RS485 INTERFACE – ADJUSTABLE DATA RATE (E,F,G,H OPTIONS)
parameter
protocol
data rate3,4
115,200; 38,400; 19,200; 9,600
transceiver
Texas Instruments SN65HVD72
turnaround time
115,200 bps
38,400 bps
19,200 bps
9,600 bps
magnitude
Notes:
min
bps
µs
µs
µs
µs
10.8
30
56
110
1.5
2
3.3
V
3. Data rate configured with AMT ViewpointTM
4. Default data rate on kits is 115,200 bps.
Checksum
The AMT21 encoder uses a checksum calculation for detecting transmission errors. The upper two bits of every response from the
encoder are check bits. Those values are shown in the examples below as K1 and K0. The check bits are odd parity; K1 for the odd bits
in the response, and K0 for the even bits in the response. These check bits are not part of the position, but are used to verify its validity.
The remaining lower 14 bits are the useful data. Here is an example of how to calculate the checkbits for a 16-bit response, from a 14-bit
encoder.
Full response: 0x61AB
14-bit position: 0x21AB (8619 decimal)
Checkbit Formula
Odd: K1 = !(H5^H3^H1^L7^L5^L3^L1)
Even: K0 = !(H4^H2^H0^L6^L4^L2^L0)
From the above response 0x61AB:
Odd: 0 = !(1^0^0^1^1^1^1) = correct
Even: 1 = !(0^0^1^0^0^0^1) = correct
cuidevices.com
Product Page
3D Model
date 08/05/2022 | page 3 of 10
RS485 INTERFACE (CONTINUED)
Addressing
The AMT21 encoder supports multiple encoders on the RS485 bus. This is accomplished by giving each encoder a unique node address.
This node address is 8 bits long but the low two bits must be 0. Therefore, the encoder can have any single byte value that is divisible by 4
which allows up to 64 encoders to share the bus.
By default, the node address is 0x54. Node addresses configurable via AMT ViewpointTM or set at factory for specific configuration upon
request.
Available RS485 Node Addresses (HEX)
00
60
80
A0
C0
04
24
44
64
08
28
48
68
0C
2C
4C
6C
8C
10
30
50
70
90
14
34
54*
74
94
B4
E0
84
A4
C4
E4
88
A8
C8
E8
AC
CC
EC
B0
D0
F0
D4
F4
18
38
58
78
98
B8
D8
F8
1C
3C
5C
7C
9C
BC
DC
FC
*Default address
The node address serves also as the read position command which is why it will be referred to it as the base command. When the encoder
sees a command on the RS485 it reads the first 6 bits to determine if it should be listening. If it sees its address, then it interprets the low
two bits for the command.
Low two bits
Hex
00
0x00
Read position
Command
01
0x01
Read turns counter (multi-turn encoders only)
10
0x02
Indicates extended command
11
0x03
Reserved
For simplicity the user can abstract away the various bits and simply implement multiple commands in their system. For example:
Byte
Command
0x54
Read position
0x55
0x56
Begin extended command
Extended Commands
There are some commands that require two bytes to be received before the encoder will enact them. This includes resets and zero saves.
This prevents collisions and allows the encoder to be fully functional while sharing the bus with other encoders.
Note that there are no responses to these instructions, and once received the encoder initiates an immediate reset. The user’s system
should expect to wait until the encoder is powered back up to send any follow up commands. Power on time is listed in the electrical
section above.
To send an extended command the user will send the value (0x56 by default) followed by the .
Extended Commands
Function
0x5E
Set zero position (Single turn encoders only)
0x75
Reset encoder
cuidevices.com
Product Page
3D Model
date 08/05/2022 | page 4 of 10
RS485 INTERFACE EXAMPLES
Single character commands
Read Position:
The read position command is the same as the node address which has a default value of 0x54 is sent and the response is received with
the low byte first. After removing the checksum the result is 0x39E4. For a 14-bit encoder nothing else is required, the position is 14820
in decimal. However if this is a 12-bit encoder, the position must be shifted to the right 2 bits to throw away the low bits of the response.
Therefore the position would be 3705 in decimal.
Read Turns (multi-turn encoders only):
The turns counter command is . By default the turns counter command is 0x55. The encoder responds with the low
byte first and includes check bits same as the read position command. The resulting number is a signed 14 bit number. The response above
is showing 1 turn.
Extended commands
Set Zero Position (single turn encoders only):
The zero set command is followed by . By default we send 0x56 and then 0x5E. The encoder zero’s the
position and immediately resets.
Encoder Reset:
The reset command is followed by . By default the command to reset the encoder is 0x56 0x75. The
encoder performs and immediate reset.
cuidevices.com
Product Page
3D Model
date 08/05/2022 | page 5 of 10
PART NUMBER KEY
For customers that prefer a specific AMT21 configuration, please reference the custom configuration key below.
AMT21 X X - X - XX - XXXX - X
Base Number
Mounting Base:
S = Standard
W= Wide
RS485 Node Address:
54 = Default node address
XX = *Node address options
Orientation:
2 = Radial
3 = Axial
Absolute Resolution:
A = 12-bit single-turn, 2 Mbps data rate
B = 14-bit single-turn, 2 Mbps data rate
C = 12-bit multi-turn, 2 Mbps data rate
D = 14-bit multi-turn, 2 Mbps data rate
E = 12-bit single-turn, adj data rate
F = 14-bit single-turn, adj data rate
G = 12-bit multi-turn, adj data rate
H = 14-bit multi-turn, adj data rate
Bore Diameter:
2000 = 2 mm
3000 = 3 mm
3175 = 3.175 mm (1/8”)
4000 = 4 mm
4760 = 4.76 mm (3/16”)
5000 = 5 mm
6000 = 6 mm
6350 = 6.35 mm (1/4”)
8000 = 8 mm
Data Rate:
F1 = 2 Mbps (A,B,C,D resolutions only)
A1 = 115,200 bps (E,F,G,H resolutions only)
A2 = 38,400 bps (E,F,G,H resolutions only)
A3 = 19,200 bps (E,F,G,H resolutions only)
A4 = 9,600 bps (E,F,G,H resolutions only)
*Reference RS485 Interface Addressing section on page 3 for help selecting node address.
AMT21-V KITS
In order to provide maximum flexibility for our customers, the AMT21 series is provided in kit form standard. This allows the user to implement the encoder into a range of
applications using one sku#, reducing engineering and inventory costs.
SLEEVES
ORDERING GUIDE
AMT21XX-V
Orientation:
2 = Radial
3 = Axial
2mm
3mm
1/8 inch
(3.175mm)
4mm
3/16 inch
(4.76mm)
5mm
6mm
1/4 inch
(6.35mm)
8mm
Light Sky
Blue
Orange
Purple
Gray
Yellow
Green
Red
Snow
Blue
BASE
WIDE
BASE
cuidevices.com
TOP
COVER
SHAFT
ADAPTER
TOOL A
TOOL C
Product Page
3D Model
date 08/05/2022 | page 6 of 10
ENCODER INTERFACE
PINOUT CONNECTOR
Function
1
+5 V
2
B
3
A
4
GND
51
MODE
61
MCLR
AMT212
AMT213
Mating Connector2:
Molex 502578-0600
Notes:
1. Pins 5 and 6 are used for configuration only and should be left disconnected for RS485.
2. Compatible with prototype cable AMT-06C-1-036 and programming cable AMT-06C-1-036-USB.
cuidevices.com
Product Page
3D Model
date 08/05/2022 | page 7 of 10
MECHANICAL DRAWING
AMT212
units: mm
tolerance: ±0.1
10.30 0.406
R15.49 0.610
15.30 0.602
15.33 0.604
39.94 1.573
28.58 1.125
11.70 0.461
AMT213
units: mm
tolerance: ±0.1
10.30 0.406
R15.49 0.610
15.30 0.602
15.33 0.604
39.06 1.538
28.58 1.125
12.60 0.496
cuidevices.com
Product Page
3D Model
date 08/05/2022 | page 8 of 10
MECHANICAL DRAWING (CONTINUED)
MOUNTING HOLE PATTERNS
STANDARD BASE
units: mm[inch]
tolerance: ±0.1
22.00 0.866
21.55 0.848
20.90 0.823
12.60[0.496]
R1.05 0.041
DETAIL A
SCALE 4 : 1
2.00 0.079
(4 PLCS)
2.95 0.116
(2 PLCS)
16.00 0.630
0.275 0.011
A (3 PLCS)
1.70 0.067
(2 PLCS)
19.05 0.750
25.40 1.000
WIDE BASE
units: mm[inch]
tolerance: ±0.1
32.44 1.277
3.00 0.118
(2 PLCS)
2.96
2.87 X 2.96
(2 PLCS)
A
2.87
0.09
DETAIL A
SCALE 4 : 1
46.02 1.812
cuidevices.com
Product Page
3D Model
date 08/05/2022 | page 9 of 10
ASSEMBLY PROCEDURE
STEP 1
STEP 2
STEP 3
Align Tool C with
flange on Base
1. Insert Tool A as a spacer that defines the distance to
the mounting surface.
2. Slide appropriate sized Sleeve over shaft all the way down to Tool A.
3. Slide Shaft Adaptor over Sleeve.
4. Use Tool C to press Shaft Adaptor over Sleeve (ensure Shaft Adapter
and Tool C spline alignment) until flush with Tool A.
STEP 4
1. Remove Tools A and C.
2. Place Base on motor, with Tool C used as a centering tool.
STEP 5
1. Snap the Top Cover onto the Base, carefully observing that the
teeth of the Shaft Adaptor align with the grooves in the hub. *
1. Fasten the Base on the motor (Tool C may need to be
rotated to allow for some mounting configurations).
2. Remove Tool C.
* We recommend no more than three cycles of mounting and
removal of the AMT top cover base. Multiple cycles of mounting
and removing the top cover can cause base fatigue over time and
affect encoder performance.
cuidevices.com
1. Align Tool C with flange on Base.
2. Slide Base and Tool C onto motor, centering onto
the Shaft Adapter.
STEP 6
1. Make sure the snaps are fully engaged by pressing
on the Hub with the reverse side of Tool C.
2. When assembly is finished, the Shaft Adaptor, Sleeve
and Rotor Hub should all be flush with the Motor
Shaft rotating freely.
Product Page
3D Model
date 08/05/2022 | page 10 of 10
REVISION HISTORY
rev.
description
date
1.0
initial release
02/20/2018
1.01
added serial interface details
05/15/2018
1.02
added multi-turn serial interface details
06/29/2018
1.03
updated RS485 interface details
06/26/2019
1.04
added adjustable data rate options
08/22/2019
1.05
brand update
11/21/2019
1.06
added motor shaft tolerance details, updated start-up details
09/10/2021
1.07
logo, datasheet style update
08/05/2022
The revision history provided is for informational purposes only and is believed to be accurate.
CUI Devices offers a one (1) year limited warranty. Complete warranty information is listed on our website.
CUI Devices reserves the right to make changes to the product at any time without notice. Information provided by CUI Devices is believed to be accurate
and reliable. However, no responsibility is assumed by CUI Devices for its use, nor for any infringements of patents or other rights of third parties which may
result from its use.
CUI Devices products are not authorized or warranted for use as critical components in equipment that requires an extremely high level of reliability. A
critical component is any component of a life support device or system whose failure to perform can be reasonably expected to cause the failure of the life
support device or system, or to affect its safety or effectiveness.
cuidevices.com
