711-0060-S-S-6-S-S-N
    ENCODER(Encoder)
    2.25" CUBE, INCREMENTAL, SINGLE
711-0060-S-S-6-S-S-N 数据手册
M O D E L 7 1 1 - I N C R E M E N TA L S H A F T E N CO D E R FEATURES The original industry-standard Cube Versatile housing styles Unidirectional output Resolutions available to 10,000 CPR The Model 711 Accu-Coder™ is the original, industry standard cube encoder. Designed for compatibility with most programmable controllers, electronic counters, motion controllers, and motor drives, it is ideally suited for applications that require a simple, symmetrical, unidirectional square wave output in a single channel format. Critical performance specifications for the most popular resolutions and advanced Opto-ASIC circuitry – a single chip design that eliminates many board level components – increase the reliability of an already dependable and durable encoder. With new options continually being added, the Model 711 excels in a wide variety of industrial applications. COMMON APPLICATIONS Feedback for counters, PLCs & motors, measuring for packaging, filling & material handling machines, wire winding, film extrusion MODEL 711 ORDERING GUIDE Blue type indicates price adder options. Not all configuration combinations may be available. Contact Customer Service for details. 711 711 S 0256 MODEL Unidirectional Cube (Single Channel) CYCLES PER REVOLUTION (CPR) 1-10,000 See CPR Options below for available resolutions. (1271 and above is a price adder) S O PP HV OUTPUT TYPE Pull-Up Resistor Open Collector Push-Pull Line Driver HD1 6 S SHAFT DIAMETER4 4 1/4", 0.250"5 5 5/16", 0.3125"6 6 3/8", 0.375" 8 1/2", 0.500"7 10 5/8", 0.625"7 HOUSING TYPE 2.25" Standard housing 2.25" Standard housing with IP50 felt shaft seal1 Industrial housing with IP66 shaft seal 3" x 3" x 6" Heavy Duty housing2 Heavy Duty housing with conduit connector & terminal strip Heavy Duty housing with 10 mm outer bearing2 Heavy Duty housing with ultra heavy duty bearings, 0.625" or 0.500" shaft2 HD12 Heavy Duty housing with IP66 outer shaft seal2 HD14 Heavy Duty housing with IP66 shaft seal and with conduit connector & terminal strip 5PY Standard Cube with 5PY adaptor3 EX Explosion-proof housing S S1 IND12 HD1 HD3 HD5 HD10 MODEL 711 CPR OPTIONS 0001 thru 0189* 0193 0198 0200 0205 0210 0240 0250 0256 0276 0298 0300 0305 0308 0315 0333 0336 0350 0360 0400 0480 0500 0512 0580 0597 0600 0700 0720 0800 0960 1000 1024 1200 1250 1270 1500 1800* 2000 2048 2500 3000 3600* 4096 5000 6000 7200* 8192 10,000 *Contact Customer Service for availability. Contact Customer Service for other disk resolutions. Not all disk resolutions available with all output types. S D SHAFT TYPE Single Double ended8 S S Y J K G T B N CONNECTOR TYPE9 Standard 6-pin MS 7-pin MS 5-pin M12 (12 mm)8 8-pin M12 (12 mm)8 Gland nut – 18" cable10 Solder or screw terminal11 Solder terminal with conduit box MATING CONNECTOR N No connector Y Yes NOTES: 1 Available with 0.250" shaft only. 2 Only available with 6-pin MS or Screw Terminal Connector Types. 3 Only available with 5/16", 0.3125" shaft. 4 Contact Customer Service for custom shaft lengths and diameters. 5 Standard housing only. 6 Standard or 5PY housing only. 7 HD10 housing only. 8 Not available for HD or EX housings. 9 For mating connectors, cables, and cordsets see Accessories at encoder.com. For Connector Pin Configuration Diagrams, see Technical Information or see Connector Pin Configuration Diagrams at encoder.com. 10 For non-standard cable lengths, add a forward slash (/) plus cable length expressed in feet. Example: G/6 = 6 feet of cable. For CPR > 2500. Standard cable length only. 11 Screw terminals available for HD and EX housings. Solder terminals available for S and S1 housings. Page 1 of 3 1-800-366-5412 | encoder.com | sales@encoder.com © 2021 Encoder Products Company, REV. 05/04/2021 MODEL 711 MODEL 711 SPECIFICATIONS Common to all Cube Housing Styles Electrical Input Voltage .......................4.75 to 28 VDC max for temperatures up to 85° C 4.75 to 24 VDC for temperatures between 85° C and 100° C. Input Current .......................80 mA maximum with no output load Input Ripple ........................100 mV peak-to-peak at 0 to 100 kHz Output Format .....................Incremental – Square wave with single channel Output Types .......................Open Collector – 250 mA max per channel Pull-Up – Open Collector with 1.5K ohm internal resistor, 250 mA max per channel Push-Pull – 20 mA max per channel Line Driver – 20 mA max per channel (Meets RS 422 at 5 VDC supply Max Frequency ....................1 to 2500 CPR 125 kHz 2501 to 5000 CPR 250 kHz 5001 to 10,000 CPR 500 kHz Electrical Protection.............Reverse voltage and output short circuit protected. NOTE: Sustained reverse voltage may result in permanent damage. Symmetry............................180° (±18°) electrical Rise Time .............................Less than 1 microsecond Accuracy ..............................Within 0.05° mechanical from one cycle to any other cycle, or 3 arc minutes. Mechanical Max Speed...........................6000 RPM. Higher shaft speeds achievable, contact Customer Service. Shaft Material......................303 Stainless Steel Housing ...............................Black non-corrosive finished 6063-T6 aluminum Bearings ..............................Precision ABEC ball bearings Environmental Operating Temp ...................0° to 85° C Storage Temp.......................-25° to 85° C Humidity .............................98% RH non-condensing Vibration .............................10 g @ 58 to 500 Hz Shock ..................................50 g @ 11 ms duration STANDARD CUBE HOUSING (S, S1) SPECIFICATIONS Mechanical Shaft Type............................Single or double-ended (specify choice) Radial Loading.....................15 lb maximum (0.250" diameter shaft) 40 lb maximum (0.375" diameter shaft) Axial Loading.......................10 lb maximum (0.250" diameter shaft) 30 lb maximum (0.375" diameter shaft) Starting Torque ....................0.13 oz-in typical for 0.250" shaft 0.38 oz-in typical for 0.375" shaft Moment of Inertia ...............6.5 x 10-6 oz-in-sec2 Weight ................................10 oz for standard housing STANDARD CUBE HOUSING (S, S1) Cube Housing with 1/4" Shaft (4) Cube Housing with 3/8" Shaft (6) Page 2 of 3 1-800-366-5412 | encoder.com | sales@encoder.com © 2021 Encoder Products Company, REV. 05/04/2021 MODEL 711 WAVEFORM DIAGRAM WIRING TABLE For EPC-supplied mating cables, refer to wiring table provided with cable. Function Gland Cable† Wire Color 5-pin M12 8-pin M12 Com Black 3 7 +VDC Red 1 A White A' 10-pin MS 7 pin MS 7-pin MS 6-pin MS 6-pin MS Term. HV Block O,S HV, No O,S PP Index PP HV, No Index Term. Block F F F A A,F 1 1,6 2 D D D B B 2 2 4 1 A A A C D 3 4 Brown -- 3 H C -- D -- 4 -- Case -- -- -- G G G -- -- -- -- Shield Bare -- -- -- -- -- -- -- -- -- O,S HV,PP †Standard cable is 24 AWG conductors with foil and braid shield. CUBE PIVOT MOUNTING BRACKETS 176430-01 Single Pivot Dual Wheel Single Wheel (shown with Torsion Spring) 176431-01 Double Pivot 176430-02 Spring Loaded Single Pivot 176431-02 Spring Loaded Double Pivot Encoder sold separately. Page 3 of 3 1-800-366-5412 | encoder.com | sales@encoder.com © 2021 Encoder Products Company, REV. 05/04/2021 CUBE HOUSINGS INDUSTRIAL CUBE HOUSING (IND12) This more robust unit meets requirements between Standard and Heavy Duty housings while retaining the Cube design. The Industrial 12 (IND12) model features an IP66 shaft seal. The tough, sealed aluminum housing has a wall thickness of 0.187" and offers greater protection from wash down, sprays, dust, moisture, shock, vibration, and other hazards found in industrial environments. Industrial Cube Housing (IND12) Specifications Refer to all Standard Cube Housing specifications except as follows: Mechanical Shaft Size ............................0.375" diameter Shaft Type............................Single- or double-ended shaft available Radial Loading.....................40 lb maximum Axial Loading.......................30 lb maximum Starting Torque ....................3 oz-in starting torque w/IP66 shaft seal All dimensions are in inches with a tolerance of +0.005" or +0.01" unless otherwise specified HEAVY DUTY CUBE HOUSING (HD12) The Heavy Duty housing uses a separate 0.375" diameter external shaft and bearing assembly to rotate the shaft of an internally mounted Cube Housing. This provides mechanical isolation from external loads and stress. A flexible coupling between the external shaft and the encoder protects the internal unit from axial and radial loading. The 0.250" aluminum walls protect the encoder from external shock, vibration, and the outside environment. Heavy Duty Housing Options HD1 Heavy Duty 3" x 6" housing HD3 Heavy Duty w/conduit connector (threaded for 0.500" NPT Conduit) and terminal strip HD5 Heavy Duty w/10 mm outer bearing HD12* Heavy Duty w/IP66 rated outer shaft seal HD14* Heavy Duty w/IP66 rated outer shaft seal, conduit connector (threaded for 0.500" NPT Conduit), and terminal strip *These units have an outer boss diameter of 1.000" Heavy Duty Cube Housing (HD12) Specifications Refer to all cube specifications except as follows: Mechanical Max Speed...........................6000 RPM Shaft Size ............................0.375" Rotation ..............................Either direction Radial Loading.....................40 lb maximum (50 lb for HD 5) Axial Loading.......................30 lb maximum (35 lb for HD 5) Bearings ..............................Precision ABEC ball bearings Starting Torque ....................1 oz-in; 3 oz-in w/IP66 seal Mounting ............................Tapped holes face and base Weight ................................3.25 lb Page 1 of 3 1-800-366-5412 | encoder.com | sales@encoder.com © 2021 Encoder Products Company, REV. 05/04/2021 CUBE HOUSINGS ULTRA HEAVY DUTY CUBE HOUSING (HD10) The HD10 Ultra Heavy Duty encoder is designed for use in applications with severe shaft loading conditions. The HD10 offers two shaft sizes: 0.500" and 0.625". Shaft material is 303 stainless steel. Bearings are conservatively rated at 95 lb radial and 60 lb axial shaft loading. IP66 shaft seal is standard on all units. The HD10 Ultra Heavy Duty housing uses a larger external shaft and R10 bearing assembly to rotate the shaft of an internally mounted Cube Housing. This provides mechanical isolation from external loads and stress. A flexible coupling between the external shaft and the encoder protects the internal unit from axial and radial loading. The 0.250" aluminum walls protect the encoder from external shock, vibration, and the outside environment. Ultra Heavy Duty Cube Housing (HD10) Specifications Mechanical Max Speed...........................6000 RPM Shaft Size ............................0.500" or 0.625" Rotation ..............................Either direction Radial Loading.....................95 lb operating Axial Loading.......................60 lb operating Bearings ..............................ABEC precision ball bearings Bearing Life .........................15,000 hours at rated load Starting Torque ....................3 oz-in IP66 rated Mounting ............................Tapped holes face and base Weight ................................3.85 lb All dimensions are in inches with a tolerance of +0.005” or +0.01” unless otherwise specified Page 2 of 3 1-800-366-5412 | encoder.com | sales@encoder.com © 2021 Encoder Products Company, REV. 05/04/2021 CUBE HOUSINGS EXPLOSION-PROOF HOUSING (EX) An explosion-proof housing is available for installing the Cube Series Accu-Coder™ in hazardous locations. The Cube Series encoder is mounted within the explosion-proof housing and is coupled to the 0.375" shaft assembly by a flexible shaft coupling. This decreases radial and axial loading on the internal encoder shaft and bearings to ensure long life. Electrical connection to the Accu-Coder™ is by an internal barrier terminal strip. A threaded hole for 0.500" NPT conduit is provided. Explosion-Proof Housing (EX) Specifications The explosion-proof housing is designed to meet the following: NEC Class 1, Groups C and D NEC Class 2, Groups E, F, and G UL Standard 1203 Class 1, Division 1, Groups C and D Class 2, Division 1, Groups E, F, and G CSA Standard C 22.2 No. 30-M 1986 NEMA 7 and NEMA 9 Refer to all cube specifications except as follows: Mechanical Max Speed...........................4000 RPM Radial Loading.....................30 lb operating Axial Loading.......................10 lb operating Weight ................................6 lb Finish ..................................Unpainted Aluminum CUBE SERIES OPTIONAL 5PY ADAPTOR (175443) The all aluminum optional 5PY adaptor allows any standard housing Cube Series encoder to replace DC tachometer technology. The 5PY adaptor is interchangeable with any 5PY tach generator. All dimensions are in inches with a tolerance of +0.005” or +0.01” unless otherwise specified. Order standard housing Cube Series Accu-Coder™ with 5/16” shaft and specify part #175443. Page 3 of 3 1-800-366-5412 | encoder.com | sales@encoder.com © 2021 Encoder Products Company, REV. 05/04/2021
711-0060-S-S-6-S-S-N 价格&库存
很抱歉,暂时无法提供与“711-0060-S-S-6-S-S-N”相匹配的价格&库存,您可以联系我们找货
