CC0603FRNPO0BN111
CC0603FRNPO0BN111
    YAGEO(国巨)
    贴片电容(MLCC) 0603 110pF ±1% 100V C0G(NP0)
CC0603FRNPO0BN111 数据手册
DATA SHEET SURFACE-MOUNT CERAMIC MULTILAYER CAPACITORS Mid-voltage NP0/X7R 100 V TO 630 V 0.47 pF to 2.2 µF RoHS compliant & Halogen Free Product Specification – June 11, 2021 V.24  Product specification Surface-Mount Ceramic Multilayer Capacitors Mid-voltage NP0/X7R 100 V to 630 V SCOPE ORDERING INFORMATION - GLOBAL PART NUMBER, PHYCOMP This specification describes Midvoltage NP0/X7R series chip capacitors with lead-free terminations. CTC & 12NC APPLICATIONS PCs, Hard disk, Game PCs Power supplies, Charger LCD panel ADSL, Modem FEATURES Supplied in tape on reel Nickel-barrier end termination RoHS compliant MSL class MSL 1 Halogen Free compliant 2 22 All part numbers are identified by the series, size, tolerance, TC material, packing style, voltage, process code, termination and capacitance value. YAGEO BRAND ordering code GLOBAL PART NUMBER (PREFERRED) CC XXXX X X XXX X (1) (2) (3) (4) (5) B X XXX (6) (7) (1) SIZE – INCH BASED (METRIC) 0201 (0603) / 0402 (1005) / 0603 (1608) / 0805 (2012) / 1206 (3216) / 1210 (3225) 1808 (4520) / 1812 (4532) / 2220 (5750) (2) TOLERANCE C = ± 0.25 pF D = ± 0.5 pF F = ± 1% G = ± 2% J = ± 5% K = ± 10% M = ± 20% (3) PACKING STYLE R = Paper/PE taping reel; Reel 7 inch K = Blister taping reel; Reel 7 inch P = Paper/PE taping reel; Reel 13 inch F = Blister taping reel; Reel 13 inch (4) TC MATERIAL NPO X7R (5) RATED VOLTAGE 0 = 100 V A = 200 V Y = 250 V B = 500 V Z = 630 V (6) PROCESS N = NP0 B = Class 2 MLCC (7) CAPACITANCE VALUE 2 significant digits+number of zeros The 3rd digit signifies the multiplying factor, and letter R is decimal point Example: 121 = 12 x 101 = 120 pF www.yageo.com Jun. 11, 2021 V.24 3 Product specification Surface-Mount Ceramic Multilayer Capacitors Mid-voltage NP0/X7R 22 100 V to 630 V CONSTRUCTION The capacitor consists of a rectangular block of ceramic dielectric in which a number of interleaved metal electrodes are contained. This structure gives rise to a high capacitance per unit volume. The inner electrodes are connected to the two end terminations and finally covered with a layer of plated tin (NiSn). The terminations are lead-free. A cross section of the structure is shown in Fig.1. terminations electrodes MLB457 ceramic material Fig. 1 Surface mounted multilayer ceramic capacitor construction DIMENSION OUTLINES Table 1 For outlines see fig. 2 TYPE L1 (mm) W (mm) T (MM) L2 / L3 (mm) L4 (mm) min. max. min. 0201 0.6 ± 0.03 0.3± 0.03 0.3± 0.03 0.10 0.20 0.20 0402 1.0 ± 0.05 0.5 ± 0.05 0.5 ± 0.05 0.15 0.30 0.40 0603 1.6 ± 0.10 0.8 ± 0.10 0.8 ± 0.10 0.20 0.60 0.40 2.0 ± 0.10 1.25 ± 0.10 2.0 ± 0.20 1.25 ± 0.20 0805 1206 3.2 ± 0.15 1.6 ± 0.15 3.2 ± 0.30 1.6 ± 0.20 3.2 ± 0.30 1.6 ± 0.30 3.2 ± 0.20 2.5 ± 0.20 3.2 ± 0.30 2.5 ± 0.20 4.5 ± 0.40 2.0 ± 0.30 1210 1808 W T L2 0.6 ± 0.10 0.85 ± 0.10 For dimension see Table 1 L4 L1 0.25 0.75 L3 MBB211 0.70 1.25 ± 0.20 Fig. 2 Surface mounted multilayer ceramic capacitor dimension 0.6 ± 0.10 0.85 ± 0.10 1.25 ± 0.20 0.25 0.75 1.40 0.25 0.75 1.40 0.25 0.75 2.20 0.25 0.75 2.20 0.25 0.75 3.40 1.6 ± 0.20 1.6 ± 0.30 0.85 ± 0.10 1.25 ± 0.20 1.6 ± 0.20 2.0 ± 0.20 1.25 ± 0.20 0.85 ± 0.10 1812 4.5 ± 0.40 3.2 ± 0.30 1.25 ± 0.20 1.60 ± 0.20 2020 5.7 ± 0.40 5.0 ± 0.30 0.85 ± 0.10 2.0 ± 0.20 1.25 ± 0.20 1.25 ± 0.20 1.6 1.6 ± ± 0.20 0.20 www.yageo.com Jun. 11, 2021 V.24 Product specification Surface-Mount Ceramic Multilayer Capacitors Mid-voltage NP0/X7R 100 V to 630 V 4 22 CAPACITANCE RANGE & THICKNESS FOR NP0 Table 2 Sizes from 0201 to 0805 CAP. 0201 0402 0603 0805 100V 100V 100 V 200 V 250 V 100 V 200 V 250 V 500 V 630V 0.3± 0.03 0.5± 0.05 0.8± 0.1 0.8± 0.1 0.8± 0.1 0.6± 0.1 0.6± 0.1 0.6± 0.1 0.6± 0.1 0.6± 0.1 0.22 pF 0.47 pF 0.56 pF 0.68 pF 0.82 pF 1.0 pF 1.2 pF 1.5 pF 1.8 pF 2.2 pF 2.7 pF 3.3 pF 3.9 pF 4.7 pF 5.6 pF 6.8 pF 8.2 pF 10 pF 12 pF 15 pF 18 pF 22 pF 27 pF 33 pF 39 pF 47 pF 56 pF 68 pF 82 pF 100 pF NOTE 1. Values in shaded cells indicate thickness class in mm 2. Capacitance value of non E-12 series is on request www.yageo.com Jun. 11, 2021 V.24 Product specification Surface-Mount Ceramic Multilayer Capacitors Mid-voltage NP0/X7R 100 V to 630 V 5 22 CAPACITANCE RANGE & THICKNESS FOR NP0 Table 3 Sizes from 0603 to 0805 (continued) CAP. 0402 0603 100 V 100 V 0805 200 V 250 V 100 V 200 V 250 V 500 V 630 V 0.6± 0.1 0.6± 0.1 0.6± 0.1 0.6± 0.1 0.85± 0.1 0.85± 0.1 1.25± 0.2 1.25± 0.2 120 pF 150 pF 180 pF 220 pF 270 pF 330 pF 390 pF 0.8± 0.1 0.5± 0.05 0.8± 0.1 0.6± 0.1 470 pF 0.85± 0.1 0.85± 0.1 560 pF 680 pF 820 pF 1.0 nF 1.2 nF 0.8± 0.1 1.5 nF 0.85± 0.1 1.8 nF 2.2 nF 1.25± 0.2 2.7 nF 1.25± 0.2 3.3 nF 3.9 nF 4.7 nF 1.25± 0.2 5.6 nF 6.8 nF 8.2 nF 10 nF 12 nF 15 nF 18 nF 22 nF NOTE 1. Values in shaded cells indicate thickness class in mm 2. Capacitance value of non E-12 series is on request www.yageo.com Jun. 11, 2021 V.24 Product specification Surface-Mount Ceramic Multilayer Capacitors CAPACITANCE RANGE & THICKNESS FOR NP0 Table 4 Sizes from 1206 to 1210 1206 CAP. 100 V 200 V 250 V 0.6± 0.1 0.6± 0.1 0.6± 0.1 Mid-voltage NP0/X7R 100 V to 630 V 6 22 1210 500 V 630 V 0.6± 0.1 1.25± 0.2 100 V 200 V 250 V 500 V 630 V 0.47 pF 0.56 pF 0.68 pF 0.82 pF 1.0 pF 1.2 pF 1.5 pF 1.8 pF 2.2 pF 2.7 pF 3.3 pF 3.9 pF 4.7 pF 5.6 pF 6.8 pF 8.2 pF 10 pF 12 pF 15 pF 18 pF 22 pF 27 pF 33 pF 39 pF 47 pF 56 pF 68 pF 1.25± 0.2 1.25± 0.2 1.25± 0.2 1.25± 0.2 1.25± 0.2 82 pF NOTE 1. Values in shaded cells indicate thickness class in mm 2. Capacitance value of non E-12 series is on request www.yageo.com Jun. 11, 2021 V.24 Product specification Surface-Mount Ceramic Multilayer Capacitors CAPACITANCE RANGE & THICKNESS FOR NP0 Table 5 Sizes from 1206 to 1210 (continued) CAP. 1206 100 V 200 V 250 V 500 V 0.6± 0.1 0.6± 0.1 0.6± 0.1 Mid-voltage NP0/X7R 100 V to 630 V 7 22 1210 630 V 100 V 200 V 250 V 500 V 630 V 100 pF 120 pF 150 pF 180 pF 220 pF 270 pF 330 pF 1.25± 0.2 390 pF 470 pF 560 pF 1.25± 0.2 0.6± 0.1 680 pF 1.25± 0.2 1.25± 0.2 1.25± 0.2 820 pF 1.0 nF 0.85± 0.1 1.2 nF 0.85± 0.1 0.85± 0.1 1.25± 0.2 1.5 nF 1.8 nF 1.25± 0.2 2.2 nF 2.7 nF 1.25± 0.2 1.25± 0.2 3.3 nF 3.9 nF 4.7 nF 0.85± 0.1 5.6 nF 6.8 nF 8.2 nF 10 nF 1.60± 0.2 1.25± 0.2 1.60± 0.2 12 nF 15 nF 18 nF 22 nF 1.6± 0.2 2.0± 0.2 NOTE 1. Values in shaded cells indicate thickness class in mm 2. Capacitance value of non E-12 series is on request www.yageo.com Jun. 11, 2021 V.24 Product specification Surface-Mount Ceramic Multilayer Capacitors Mid-voltage NP0/X7R 8 22 100 V to 630 V CAPACITANCE RANGE & THICKNESS FOR NP0 Table 6 Sizes 1812 1812 CAP. 100 V 200 V 250 V 500 V 630V 10 pF 12 pF 15 pF 18 pF 22 pF 27 pF 33 pF 39 pF 47 pF 56 pF 68 pF 82 pF 100 pF 120 pF 150 pF 180 pF 220 pF 270 pF 1.25± 0.2 330 pF 390 pF 470 pF 1.25± 0.2 560 pF 680 pF 820 pF 1 nF 1.2 nF 1.25± 0.2 1.5 nF 1.25± 0.2 1.8 nF 2.2 nF 2.7 nF 1.25± 0.2 3.3 nF 3.9 nF 4.7 nF 5.6 nF 6.8 nF 8.2 nF 10 nF 12 nF 15 nF 18 nF 22 nF 1.6± 0.2 NOTE 1. Values in shaded cells indicate thickness class in mm 2. Capacitance value of non E-12 series is on request www.yageo.com Jun. 11, 2021 V.24 Product specification Surface-Mount Ceramic Multilayer Capacitors Mid-voltage NP0/X7R 9 22 100 V to 630 V CAPACITANCE RANGE & THICKNESS FOR X7R Table 7 Sizes from 0402 to 0805 CAP. 0402 0603 100 V 100 V 0805 200V/250V 100 V 200 V 250 V 500 V 630 V 0.85± 0.1 0.85± 0.1 0.85± 0.1 0.85± 0.1 100 pF 150 pF 220 pF 330 pF 470 pF 680 pF 1.0 nF 0.5± 0.05 1.5 nF 0.6± 0.1 2.2 nF 3.3 nF 0.8± 0.1 0.8± 0.1 4.7 nF 6.8 nF 10 nF 15 nF 22 nF 1.25± 0.2 1.25± 0.2 0.85± 0.1 1.25± 0.2 33 nF 1.25± 0.2 47 nF 68 nF 100 nF 150 nF 1.25± 0.2 220 nF 330 nF 470 nF 1 µF NOTE 1. Values in shaded cells indicate thickness class in mm 2. Capacitance value of non E-6 series is on request 3. For special ordering code, please contact local sales force before order 4. For product with 5% tolerance, please contact local sales force before order www.yageo.com Jun. 11, 2021 V.24 Product specification Surface-Mount Ceramic Multilayer Capacitors CAPACITANCE RANGE & THICKNESS FOR X7R Table 8 Sizes from 1206 to 1210 1206 CAP. 100 V 200 V 250 V 0.85± 0.1 0.85± 0.1 500 V Mid-voltage NP0/X7R 100 V to 630 V 10 22 1210 630 V 100 V 200 V 250 V 0.85± 0.1 0.85± 0.1 500 V 630V 100 pF 150 pF 220 pF 330 pF 470 pF 680 pF 1.0 nF 1.5 nF 2.2 nF 3.3 nF 1.25± 0.2 1.25± 0.2 0.85± 0.1 4.7 nF 6.8 nF 10 nF 15 nF 1.6± 0.2 33 nF 1.25± 0.2 47 nF 1.25± 0.2 1.6± 0.2 1.6± 0.2 2.0± 0.2 68 nF 150 nF 1.25± 0.2 0.85± 0.1 22 nF 100 nF 1.25± 0.2 1.25± 0.2 1.25± 0.2 1.6± 0.2 1.6± 0.2 220 nF 1.25± 0.2 2.0± 0.2 1.25± 0.2 330 nF 470 nF 680 nF 1.6± 0.2 1 µF 2.0± 0.2 2.2 µF NOTE 1. Values in shaded cells indicate thickness class in mm 2. Capacitance value of non E-6 series is on request 3. For product with 5% tolerance, please contact local sales force before order www.yageo.com Jun. 11, 2021 V.24 Product specification Surface-Mount Ceramic Multilayer Capacitors CAPACITANCE RANGE & THICKNESS FOR X7R Table 9 Sizes from 1808 to 1812 1812 CAP. 100 V 200 V 250 V 0.85± 0.1 0.85± 0.1 500 V Mid-voltage NP0/X7R 100 V to 630 V 11 22 2020 630 V 630 V 100 pF 150 pF 220 pF 330 pF 470 pF 680 pF 1.0 nF 1.5 nF 2.2 nF 3.3 nF 4.7 nF 6.8 nF 10 nF 0.85± 0.1 1.35± 0.2 1.25± 0.2 15 nF 22 nF 33 nF 47 nF 1.6± 0.2 68 nF 1.25± 0.2 100 nF 150 nF 220 nF 1.25± 0.2 1.6± 0.2 1.25± 0.2 330 nF 2.0± 0.2 1.6± 0.2 1.6± 0.2 470 nF 680 nF 1.6± 0.2 1 µF NOTE 1. Values in shaded cells indicate thickness class in mm 2. Capacitance value of non E-6 series is on request 3. For product with 5% tolerance, please contact local sales force before order www.yageo.com Jun. 11, 2021 V.24 Product specification Surface-Mount Ceramic Multilayer Capacitors Mid-voltage NP0/X7R 100 V to 630 V 12 22 THICKNESS CLASSES AND PACKING QUANTITY Table 10 QUANTITY PER REEL SIZE CODE THICKNESS CLASSIFICATION PACKING CODE. 7 INCH 13 INCH Ø 180 MM / 7 INCH Ø 330 MM / 13 INCH TAPE WIDTH Paper Blister Paper Blister 0201 0.3 ± 0.03 mm R P 8 mm 15,000 --- 50,000 --- 0402 0.5 ± 0.05 mm R P 8 mm 10,000 --- 50,000 --- 0603 0.8 ± 0.1 mm R P 8 mm 4,000 --- 15,000 --- 0.6 ± 0.1 mm R P 8 mm 4,000 --- 20,000 --- 0.8 / 0.85 ± 0.1 mm R P 8 mm 4,000 --- 15,000 --- 1.25 ± 0.2 mm K F 8 mm --- 3,000 --- 10,000 0.6 ± 0.1 mm R P 8 mm 4,000 --- 20,000 --- 0.8 / 0.85 ± 0.1 mm R P 8 mm 4,000 --- 15,000 --- 1.00 / 1.15 ± 0.1 mm K F 8 mm --- 3,000 --- 10,000 1.25 ± 0.2 mm K F 8 mm --- 3,000 --- 10,000 1.6 ± 0.15 mm K F 8 mm --- 2,500 --- 10,000 1.6 ± 0.2 mm K F 8 mm --- 2,000 --- 8,000 0.6 / 0.7 ± 0.1 mm K F 8 mm --- 4,000 --- 15,000 0.85 ± 0.1 mm K F 8 mm --- 4,000 --- 10,000 1.15 ± 0.1 mm K F 8 mm --- 3,000 --- 10,000 1.15 ± 0.15 mm K F 8 mm --- 3,000 --- 10,000 1.25 ± 0.2 mm K 8 mm --- 3,000 --- --- 1.5 ± 0.1 mm K 8 mm --- 2,000 --- --- 1.6 / 1.9 ± 0.2 mm K 8 mm --- 2,000 --- --- 8 mm --- 2,000 1,000 --- --- 8 mm --- 1,000 500 --- --- 0805 1206 1210 2.0 ± 0.2 mm 2.5 ± 0.2 mm 1808 K K 1.15 ± 0.15 mm K 12 mm --- 3,000 --- --- 1.25 ± 0.2 mm K 12 mm --- 3,000 --- --- 1.35 ± 0.15 mm K 12 mm --- 2,000 --- --- 1.5 ± 0.1 mm K 12 mm --- 2,000 --- --- 1.6 ± 0.2 mm K 12 mm --- 2,000 --- 8,000 F 2.0 ± 0.2 mm K 12 mm --- 2,000 --- --- 0.6 / 0.85 ± 0.1 mm K 12 mm --- 2,000 --- --- 1.15 ± 0.1 mm K 12 mm --- 1,000 --- --- 1.15 ± 0.15 mm K 12 mm --- 1,000 --- --- 1.25 ± 0.2 mm K 12 mm --- 1,000 --- --- 1.35 ± 0.15 mm K 12 mm --- 1,000 --- --- 1.5 ± 0.1 mm K 12 mm --- 1,000 --- --- 1.6 ± 0.2 mm K 12 mm --- 1,000 --- --- 2.0 ± 0.2 mm K 12 mm --- 1,000 --- --- 2.5 ± 0.2 mm K 12 mm --- 500 --- --- 2.0 ± 0.2 mm K 12 mm --- 1000 --- --- 1812 2220 www.yageo.com Jun. 11, 2021 V.24 Product specification Surface-Mount Ceramic Multilayer Capacitors Mid-voltage NP0/X7R 13 22 100 V to 630 V PAPER/PE TAPE SPECIFICATION P0 D0 T P2 E F cover tape W B0 K0 A0 P1 MBG251-1 Fig. 3 Paper/PE tape Table 11 Dimensions of paper/PE tape for relevant chip size; see Fig.3 SIZE Unit: mm SYMBOL CODE A0 B0 W E F P0 (1) P1 P2 Ø D0 K0 T 0.38 ± 0.05 (0.47 / 0.55)±0.10 0201 0.39 ± 0.06 0.70 ± 0.06 8.0 ± 0.20 1.75 ± 0.1 3.50 ± 0.05 4.0 ± 0.05 2.0 ± 0.05 2.0 ± 0.05 1.55 ± 0.03 0402 0.70 ± 0.15 1.21 ± 0.12 8.0 ± 0.20 1.75 ± 0.1 3.50 ± 0.05 4.0 ± 0.05 2.0 ± 0.05 2.0 ± 0.05 1.50 +0.1 /-0 (0.75 / 0.60)±0.10 (0.85 / 0.70)±0.10 0603 1.05 ± 0.14 1.86 ± 0.13 8.0 ± 0.20 1.75 ± 0.1 3.50 ± 0.05 4.0 ± 0.10 4.0 ± 0.10 2.0 ± 0.05 1.50 +0.1 /-0 (1.05 / 0.95 / 0.75)±0.10 (1.15 / 1.05 / 0.85)±0.10 0805 1.50 ± 0.15 2.26 ± 0.20 8.0 ± 0.20 1.75 ± 0.1 3.50 ± 0.05 4.0 ± 0.10 4.0 ± 0.10 2.0 ± 0.05 1.50 +0.1 /-0 (1.05 / 0.95 / 0.75)±0.10 (1.15 / 1.05 / 0.85)±0.10 1206 1.90 ± 0.15 3.50 ± 0.20 8.0 ± 0.20 1.75 ± 0.1 3.50 ± 0.05 4.0 ± 0.10 4.0 ± 0.10 2.0 ± 0.05 1.50 +0.1 /-0 (0.95 / 0.75)±0.10 (1.05 / 0.85)± 0.10 NOTE 1. P0 pitch tolerance over any 10 pitches is 0.2 mm www.yageo.com Jun. 11, 2021 V.24 Product specification Surface-Mount Ceramic Multilayer Capacitors Mid-voltage NP0/X7R 14 22 100 V to 630 V BLISTER TAPE SPECIFICATION P0 D0 K0 P2 E F cover tape W B0 A0 T2 SCM015 D1 P1 K0: so chosen that the orientation of the component cannot change For W = 8 mm: T2 = 3.5 mm max. For W = 12 mm: T2 = 6.5 mm max. direction of unreeling Fig. 4 Blister tape Table 12 Dimensions of blister tape for relevant chip size; see Fig.4 SYMBOL SIZE A0 B0 CODE Unit: mm K0 W E F Min. Max. Min. Max. Min. Max. Ø D0 Ø D1 P0 (2) P1 P2 T2 Min. Min. Max. 0805 1.29 1.65 2.09 2.60 1.25 1.62 8.1 ± 0.20 1.75 ± 0.1 3.5 ± 0.05 1.5 +0.1/-0.0 1 +0.1/-0.0 4.0 ± 0.10 4.0 ± 0.10 2.0 ± 0.05 1.30 1.67 1206 1.65 2.12 3.30 3.75 1.22 2.15 8.1 ± 0.20 1.75 ± 0.1 3.5 ± 0.05 1.5 +0.1/-0.0 1 +0.1/-0.0 4.0 ± 0.10 4.0 ± 0.10 2.0 ± 0.05 1.27 2.20 1210 2.55 3.02 3.31 3.88 0.97 2.92 8.1 ± 0.20 1.75 ± 0.1 3.5 ± 0.05 1.5 +0.1/-0.0 1 +0.1/-0.0 4.0 ± 0.10 4.0 ± 0.10 2.0 ± 0.05 1.02 2.97 1808 2.05 2.55 4.80 5.45 1.30 2.45 12.1 ± 0.20 1.75 ± 0.1 5.5 ± 0.05 1.5 +0.1/-0.0 1.5 +0.1/-0.0 4.0 ± 0.10 4.0 ± 0.10 2.0 ± 0.05 1.35 2.50 1812 3.35 3.75 4.70 5.33 0.70 2.40 12.1 ± 0.20 1.75 ± 0.1 5.5 ± 0.05 1.5 +0.1/-0.0 1.5 +0.1/-0.0 4.0 ± 0.10 8.0 ± 0.10 2.0 ± 0.05 0.75 2.45 NOTE 1. Typical capacitor displacement in pocket 2. P0 pitch tolerance over any 10 pitches is ±0.2 mm www.yageo.com Jun. 11, 2021 V.24 Product specification Surface-Mount Ceramic Multilayer Capacitors Mid-voltage NP0/X7R 100 V to 630 V 15 22 REEL SPECIFICATION W2 C N A HBK039 W1 Fig. 5 Reel Table13 Reel dimensions; see Fig.5 TAPE WIDTH SYMBOL Unit: mm A N C W1 W2max. 8 (Ø 178 mm/7") 178 ± 1.0 60 ± 1.0 13 +0.50/-0.20 9.4 ± 1.5 14.4 8 (Ø 330 mm/13") 330 ± 1.0 100 ± 1.0 13 +0.50/-0.20 9.0 ± 0.2 14.4 12 (Ø 178 mm/7") 178 ± 1.0 60 ± 1.0 13 +0.50/-0.20 13.4 ± 1.5 18.4 P ROPERTIES OF REEL Material: polystyrene Surface resistance:
CC0603FRNPO0BN111
物料型号:国巨(YAGEO)生产的中高压多层陶瓷电容器,型号包括NP0和X7R系列,电压范围从100V到630V,电容值从0.47pF到2.2μF。
器件简介:这些电容器是表面贴装式陶瓷多层电容器,具有高电容体积比,内电极连接至两端子,外覆镀锡层,无铅且符合RoHS标准。
引脚分配:电容器由陶瓷介质块组成,内含多个交错的金属电极,两端子连接至内电极。
参数特性: - 电容公差等级:C=±0.25pF,D=±0.5pF,F=±1%,G=±2%,J=±5%,K=±10%,M=±20%。 - 温度系数材料:NPO,X7R。 - 额定电压:100V至630V。 - 包装风格:纸带或PE带卷装。
功能详解:电容器具有不同的电容值和电压等级,适用于不同的应用场景,如电源、充电器、LCD面板、ADSL、调制解调器等。
应用信息:适用于电脑、硬盘、游戏机、电源、充电器、LCD面板、ADSL、调制解调器等。
封装信息:提供多种尺寸,包括0201、0402、0603、0805、1206、1210、1808、1812、2220等,每种尺寸都有详细的尺寸和厚度规格。
电气特性:包括电容范围、电容公差、耗散因子、绝缘电阻、温度系数、工作温度范围等。
测试和要求:包括安装、视觉检查、电容测试、耗散因子测试、绝缘电阻测试、温度系数测试、耐焊接热测试、焊锡性测试、快速温度变化测试、湿热测试、耐久性测试、电压耐受测试等。
修订历史:文档记录了从2009年到2021年的多次修订,包括产品范围更新、测试方法和程序更新、新增型号、尺寸更新等。
CC0603FRNPO0BN111 价格&库存
很抱歉,暂时无法提供与“CC0603FRNPO0BN111”相匹配的价格&库存,您可以联系我们找货
