CCD-109B561KK02
CCD-109B561KK02
    TRIGON(三弦)
    插件
    贴片电容(MLCC) 径向 560pF ±10% 250V X5P
CCD-109B561KK02 数据手册
CCD Series Safety Standard Recognized Ceramic Capacitors TRIGON COMPONENTS Configuration Capacitor FEATURES • Complying with IEC60384-14 4th Edition • Class X1Y1 and Class X1Y2 • Dielectric Strength: AC2600V (r.m.s) for X1Y2 and AC4000V (r.m.s) for X1Y1 • High Reliability • Coated With Flame-Retardant Epoxy Resin (Conforming to UL94V-0 Standard) • RoHS Compliant APPLICATIONS • Ideal for use as X/Y capacitor for AC Line Filter and Primary/Secondary Coupling on Switching Power Supplies and AC adapters • Across-The-Line • Antenna-Coupling • Line-By-Pass ORDERING CODE CCD - 1 09 B 101 K H 7 2 (1) (1) (2) (3) (4) (5) (6) (7) (8) (9) (2) (3) (4) (5) (6) (7) (8) (9) Ceramic Disc Capacitor Class Type Diameter Code Ceramic Dielectric Capacitance Code Tolerance Code Lead Style Lead Spacing Lead Length or Taping ※ Please refer to Ordering Code document CCD_Safety–Order for more ordering options. Approval Standard and Recognized Number Approval Agency VDE/ENEC10 CSA UL Rev. B4 Number 40040454 40046396 40040445 40046520 222903 E197459 X1/Y1 CCD-1 CCD-1 CCD-1 X1/Y2 CCD-2 CCD-2 CCD-2 Sheet 1 of 12 CCD Series Safety Standard Recognized Ceramic Capacitors TRIGON COMPONENTS Specification Characteristics Class X1, Y1 Class X1, Y2 100pF to 4700pF 5.1pF to 10000pF Operating Temperature Range -40°C to 125°C Y5P, Y5V, Y5U: -40°C to 125°C COG, X7R: -55°C to 125°C SL: +40°C to +125°C Rated Voltage X1: 760/400VAC, Y1: 500/250VAC X1: 440/400VAC, Y2: 300/250VAC Dielectric Withstanding Voltage 4000VAC for 1 minute 2600VAC for 1 minute Within the specified tolerance Y5P, Y5U, Y5V, X7R measured at 1KHz ± 20% COG measured at 1MHz ± 20% Both are 1 Vrms, 25°C Capacitance Tanδ ≦ 2.5% for char. Y5P, Y5U, Y5V, X7R measured at 1KHz ± 20% COG measured at 1MHz ± 20% Both are 1 Vrms, 25°C, Quality Factor ≧ 600 for char. Dissipation Factor (tan δ) 10,000 M min. at 500VDC Insulation Resistance Class X1, Y1 Part Number Temp. Char. Cap.(pF) Cap. Tol. D (Max. mm) CCD-107S100J□□□ 10 7.0 CCD-107S150J□□□ 15 7.0 CCD-107S200J□□□ 20 7.0 CCD-107S220J□□□ S (SL) 22 ± 5% 7.0 CCD-107S330J□□□ 33 7.0 CCD-108S470J□□□ 47 8.0 CCD-109S680J□□□ 68 9.0 CCD-109B101KK0□ 100 CCD-109B151KK0□ 150 CCD-109B221KK0□ 220 CCD-109B331KK0□ CCD-109B471KK0□ CCD-109B561K□□□ B (Y5P) ± 10% 10 5 Φd (mm) 9.0 ± 10% 8 10 560 CCD-110B821K□□□ 820 CCD-110B681KK0□ 680 CCD-111B102K□□□ 1000 Rev. B4 T (Max. mm) 0.55±0.1 330 470 F (mm) 10.0 5 11.0 Sheet 2 of 12 Capacitor Capacitance Range CCD Series Safety Standard Recognized Ceramic Capacitors TRIGON COMPONENTS Part Number E (Y5U) + 20% -55% Y5V Cap.(p F) 1000 1500 2200 3300 3900 4700 1000 1500 2200 3300 4700 Cap. Tol. ± 20% ± 20% D (Max. mm) F (mm) 9.0 11.0 12.0 14.0 15.0 16.0 7.0 8.0 9.0 10.0 12.0 10 D (Max. mm) F (mm) T (Max. mm) Φd (mm) 8 0.55±0.1 Capacitor CCD-109E102MK0□ CCD-111E152MK0□ CCD-112E222MK0□ CCD-114E332MK0□ CCD115E392MK0□ CCD-116E472MK0□ CCD-107F102K□□□ CCD-108F152K□□□ CCD-109F222K□□□ CCD-110F332K□□□ CCD-112F472K□□□ Temp. Char. 5.5 Class X1, Y2 Part Number CCD-208C100JK□□ CCD-208B5R1CK□□ CCD-208B100KK□□ CCD-208B150KK□□ CCD-208B180KK□□ CCD-208B220KK□□ CCD-208B101K□□□ CCD-208B151K□□□ CCD-208B221K□□□ CCD-208B331K□□□ CCD-208B471K□□□ CCD-209B561K□□□ CCD-209B681K□□□ CCD-209B821K□□□ CCD-210B102K□□□ CCD-207S150J□□□ CCD-207S200J□□□ CCD-207S220J□□□ CCD-207S330J□□□ CCD-207S470J□□□ CCD-208S680J□□□ CCD-208E102M□□□ CCD-209E152M□□□ CCD-210E222M□□□ CCD-211E252M□□□ CCD-212E332M□□□ CCD-213E392M□□□ CCD-214E472M□□□ CCD-208F102M□□□ CCD-208F152M□□□ CCD-209F222M□□□ CCD-210F332M□□□ CCD-211F392M□□□ CCD-212F472M□□□ CCD-216F103M□□□ Rev. B4 Temp. Char. Cap. (pF) C(COG) 10 5.1 10 15 18 22 100 150 220 330 470 560 680 820 1000 15 20 22 33 47 68 1000 1500 2200 2500 3300 3900 4700 1000 1500 2200 3300 3900 4700 10000 B (Y5P) ±10% S (SL) E (Y5U) +20% -55% F (Y5V) +30% -80% Cap. Tol. T (Max. mm) Φd (mm) ±5% 7 8.0 7.5 ±0.25pF ±10% 8 9.0 10.0 ±5% ±20% 7.0 8.0 8.0 9.0 10.0 11.0 12.0 13.0 14.0 8.0 5.0 / 7.5 7.5 5 8 7.5 5 7.5 0.55±0.1 8 9.0 ±20% 10.0 11.0 12.0 16.0 10 Sheet 3 of 12 CCD Series Safety Standard Recognized Ceramic Capacitors TRIGON COMPONENTS Typical characteristic curves £ º Z(Impedance) vs. frequency SL,Y5P,Y5U,Y5V Typical characteristic curves 100 20 10 SL SL Y5P Inpedance(%) -10 Y5P -20 -30 -40 Y5U -50 Y5U 10 Capacitor Cap.Change (%) 0 1 100pF(B) 220pF(B) 470pF(B) 1000pF(E) 2200pF(E) 47000pF(E) 10000pF(F) -60 -70 -80 Y5V Y5V -90 0.1 -100 -40 -20 0 20 40 60 80 100 1 10 100 1000 Frequency (MHz) Temp.(¡ã C) Note: Above data are just for reference not asurred ones. Leakage current characteristics (Type X1 Y 1: 0~4000Vac): X1 Y1 X1 Y1 AC Valtage:60Hz Temp.:25¡ã C AC Valtage:60Hz Temp.:25¡ã C 1000pF(B) 2.2 6.0 680pF(B) 1.8 1.6 1.4 1.2 1.0 470pF(B) 330pF(B) 0.8 0.6 0.4 0.2 220pF(B) 150pF(B) 100pF(B) 0 500 1000 1500 2000 2500 3000 3500 4000 Voltage(Vrms) 4700pF(E) 5.0 560pF(B) Current (mA) Current (mA) 2.0 4.0 3300pF(E) 3.0 2200pF(E) 2.0 1500pF(E) 1000pF(E) 1.0 0 500 1000 1500 2000 2500 3000 3500 4000 Voltage(Vrms) Note: Above data are just for reference not asurred ones. Rev. B4 Sheet 4 of 12 CCD Series Safety Standard Recognized Ceramic Capacitors TRIGON COMPONENTS Typical characteristic curves £ º Z(Impedance) vs. frequency SL,Y5P,Y5U,Y5V Typical characteristic curves 100 20 10 SL 0 Cap.Change (%) Y5P -20 -30 -40 Y5U Y5U -50 10 Capacitor -10 Inpedance(%) SL Y5P 1 100pF(B) 220pF(B) 470pF(B) 1000pF(E) 2200pF(E) 47000pF(E) 10000pF(F) -60 -70 -80 Y5V Y5V -90 -100 -40 0.1 -20 0 20 40 60 80 10 1 100 1000 100 Frequency (MHz) Temp.(¡ã C) Note: Above data are just for reference not asurred ones. Leakage current characteristics (Type X1 Y2: 0~2600Vac): X1 Y2 X1 Y2 AC Valtage:60Hz Temp.:25¡ã C AC Valtage:60Hz Temp.:25¡ã C 10000pF(E) 6.0 5.0 2.0 1.8 1.6 1.4 1.2 1.0 1000pF(B) 820pF(B) 680pF(B) 560pF(B) 470pF(B) 0.8 330pF(B) 0.6 0.4 0.2 Current (mA) Current (mA) 2.2 4700pF(E) 4.0 3.0 3300pF(E) 2.0 2200pF(E) 1500pF(E) 220pF(B) 150pF(B) 100pF(B) 0 500 1000 1500 2000 2500 3000 Voltage(Vrms) 1.0 1000pF(E) 0 500 1000 1500 2000 2500 3000 Voltage(Vrms) Note: Above data are just for reference not asurred ones. Rev. B4 Sheet 5 of 12 CCD Series Safety Standard Recognized Ceramic Capacitors TRIGON COMPONENTS Packing Information Capacitor Straight Inside Kink Item Symbol Pitch of component Feed hole pitch Lead to lead distance Feed hole center to lead Hold center to component center Body diameter Body thickness Lead-wire diameter Component alignment F-R Tape width Hold-down tape width Hold position Hold-down tape position Height of component from tape center Lead wire clinch Component height Lead wire protrusion Feed hole diameter Total tape thickness Maximum thickness of tape and wire P P0 F P1 P2 D T D h W W0 W1 W2 H H0 H1 ∫ D0 T1 T2 Specification (mm) 5T1/5R1 12.7 12.7 5+0.8/-0.2 3.85 6.35 11Max. 5.0 0.6 7T1/7R1 12.7 12.7 7.5±1.0 8.95 11Max. 7T5/7R5 15 15 7.5±1.0 3.75 11
CCD-109B561KK02 价格&库存
很抱歉,暂时无法提供与“CCD-109B561KK02”相匹配的价格&库存,您可以联系我们找货
