8B36-01
8B36-01
    DATAFORTH(Dataforth)
    POTENTIOMETER INPUT MODULE
8B36-01 数据手册
SensorLex® 8BIsolated IsolatedAnalog AnalogSignal SignalConditioning ConditioningProducts Products S C 8MB 5 B 8B36 Potentiometer Input Modules Description 8B modules are an optimal solution for monitoring real-world process signals and providing high-level signals to a data acquisition system. ach B input module isolates, filters, and amplifies a single channel of potentiometer input and provides an analog voltage output (Figure 1). Features Interfaces to Potentiometers up to , • High-Level Voltage Output xcitation for the potentiometer is provided by using two matched current sources. When using a 3-wire connection, this method allows equal currents to ow through the sensor leads, canceling the effects of lead resistances.The excitation currents are small (equal to or less than 0.25mA) which minimizes self-heating of the potentiometer. • 1500Vrms Isolation • ANSI/IEEE C37.90.1 Transient Protection • Input Protection to 240VAC Continuous • 120dB CMR Signal filtering is accomplished with a pole filter optimi ed for time and frequency response which provides 70dB of normal-mode rejection at H . One pole of this filter is on the field side of the isolation barrier for anti-aliasing, and the other two are on the system side. • 70dB NMR at 60Hz • ± 0.05% Accuracy • ± 0.02% Linearity A special input circuit on the 8B36 module provides protection against accidental connection of power-line voltages up to 240VAC. Clamp circuits on the I/O and power terminals protect against harmful transients. Low Drift with Ambient Temperature • C-UL-US Listed • CE Compliant The modules are designed for installation in Class I, Division 2 hazardous locations and have a high level of immunity to environmental noise. • ATEX Compliance Pending • Mix and Match Module Types on Backpanel Isolation Barrier –EXC 3-wire 2-wire Slidewire Potentiometer – Jn (1) – +EXC +EXC 3 Surge Suppression and Protection LPF 6 7 +V 2 VOUT COM –V Computer-Side Power 4 + + Iso-Chopper™ Amplifier Pat. Pending LPF 1 NC CJCn Backpanel Terminal Block –V´ –V´ +V´ –V´ (1) CJC Enable Jumper. Remains Installed for 8B36. F i g u r e 1 : 8 B 3 6 B l o ck 5 Isolated Field-Side Power D ia g r a m 1 1 4 ©1995-2017 Dataforth Corporation, All Rights Reserved For information call 800-444-7644 ISO9001:2008-Registered QMS Power Oscillator 7 +5VDC COM SensorLex® 8B Isolated Analog Signal Conditioning Products Specifications Typical❇ at TA and D power Ordering Information Module 8B36 Model Input Range Input Resistance Normal Power Off Overload Input Protection Continuous(1) Transient to 8B36-01 8B36-02 8B36-03 8B36-04 Sensor Excitation Current Lead Resistance Effect CMV, Input to Output Transient, Input to Output CMR (50 or 60Hz) NMR . mA , . mA . , . 0V to +5V 0V to +5V 0V to +5V 0V to +5V 8 B 1500Vrms max ANSI/IEEE C37.90.1 120dB 70dB at 60Hz Output Range Output Protection Transient Open Input Response Open Input Detection Time 0V to +5V Continuous Short to Ground ANSI/IEEE C37.90.1 Downscale 1s Environmental Operating Temperature Range Storage Temperature Range Relative Humidity Emissions EN61000-6-4 Radiated, Conducted Immunity EN61000-6-2 RF ESD, EFT to to to to Output Range , Sensor Sensor , Sensor Sensor ± 0.05% Span ± 0.02% Span Mechanical Dimensions (h)(w)(d) Input Range 240VAC ANSI/IEEE C37.90.1 Accuracy(2) Linearity Stability Offset Gain Noise Output, 100kHz Bandwidth, – 3dB Response Time, 90% Span Power Supply Voltage Power Supply Current Power Supply Sensitivity 8 B ppm ppm rms 3Hz 150ms +5VDC ± 5% 25mA ± 75ppm/% 1.11” x 1.65” x 0.40” (28.1mm x 41.9mm x 10.2mm) to to 0 to 95% Noncondensing ISM, Group 1 Class A ISM, Group 1 Performance A ± 0.5% Span Error Performance B NOTES: ❇ ontact factory or your local Dataforth sales office for maximum values. A between Input terminal and Input, , or terminals. A between Input and or terminals. A between and terminals. Includes linearity, hysteresis and repeatability. Installation Notes: . This uipment is Suitable for se in lass I, Division , Groups A, B, , D, or Non-Hazardous Locations Only. . ARNING xplosion Ha ard Substitution of Any omponents ay Impair Suitability for lass I, Division . 3.) WARNING - Explosion Hazard - Do Not Disconnect Equipment Unless Power Has Been Switched Off or The Area is nown to be Non Ha ardous. Visit our website www.dataforth.com ©1995-2017 Dataforth Corporation, All Rights Reserved 1 1 5 ISO9001:2008-Registered QMS
8B36-01 价格&库存
很抱歉,暂时无法提供与“8B36-01”相匹配的价格&库存,您可以联系我们找货
