LVI-45-250-R-01-20-S 数据手册
LV-45 Series
For use in:
Steel, Aluminum, and Paper Mills
Power Generation Steam Valves
Material Creep Measurements
Roadway/Bridge Expansion
Hydro Power Plants
LVIT Linear Position Sensor
Designed Specifically for Heavy Duty Industrial and Civil Engineering Applications
Alliance Sensors Group's LV-45 series LVIT (Linear Variable Inductance Transducer) position sensors are
specifically targeted for measuring applications requiring rugged devices, whether measuring position of steam
turbine valves, mounted in a paper mill head box or calendar roll stand, or operating outdoors fastened to a bridge
or structure.
LV-45 sensors use a contactless inductive technology that allows them to replace other technology sensors like
potentiometers and DC-LVDTs in most applications. With a simple coil design, a captive connecting rod, and a
thick-walled housing, the sensors are both shorter and more robust than their DC-LVDT counterparts while
operating over a wider temperature range. They can withstand the vibration and shock levels found in mills and
power plants, as well as the temperature and humidity found in outdoor applications. Once a sensor has been
installed, ASG’s SenSet™ range adjustment process permits a user to match the sensor’s zero and full scale
output to the workpiece’s actual range of motion.
Features:
LVIT Technology™ (Linear Variable Inductance Transducer)
Contactless operation
Excellent stroke-to-length ratio
Proprietary SenSet™ field adjustable range scaling
Specifications:
Analog I/Os: 0-5 V or 0.5-4.5 V output with 8-30 V input, 35 mA max.
0-10 V output with 12 -30 V input, 35 mA max.
4-20 mA (3-wire) output with 18-30 V input, 60 mA max. (75 C max).
Measuring Ranges: 100 mm to 450 mm (4 to 18 inches) full scale (nominal)
Linearity Error:
LVI-45-250-R-01-20-S 价格&库存
很抱歉,暂时无法提供与“LVI-45-250-R-01-20-S”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+13994.260191+1812.74613
