LRSE-18-050-A-00-10-A 数据手册
For use in:
Mil/Aero Test Stands
LRS-18 Series
Packaging Equipment
Robotic Arms
Factory Automation Systems
Spring-Loaded LVIT Linear Position Sensor
Long Lasting, Contactless, Inductive Sensors
The LRS-18 series of LVIT (Linear Variable Inductance Transducer) spring-loaded position sensors by
Alliance Sensors Group are contactless devices designed for dimensional or position measuring
applications in factory automation and in various industrial and commercial applications, such as:
automotive testing, mil/aero test stands, robotic arms, and packaging equipment. An ideal solution for when
the sensing element cannot be attached to the object being measured. LRS-18s are offered in full scale
ranges from 0.5 to 4.0 inches (12.5 to 100 mm) with excellent resolution and high stroke-to-length ratios.
Maximum tip force on the item being measured is 1 pound.
LRS-18 sensors have a 0.75 inch (19 mm) diameter aluminum or stainless steel body with an M18 x 1
thread and come with two hex jam nuts for easy installation in place of an 18 mm analog prox sensor. These
sensors use a 0.25 inch diameter probe equipped with an AGD No. 9 contact tip, and are offered with either
an axial cable or a connector. Operating from a variety of DC voltages. These sensors are available with a
choice of four analog outputs and they all include ASG’s proprietary SenSet™ field recalibration feature.
Features:
Spring-loaded LVIT Technology™ (Linear Variable Inductance Transducer)
Ranges from 0.5 to 4.0 inches (12.5 to 100 mm)
Contactless operation prevents internal wearout from dithering or rapid cycling
Excellent stroke-to-length ratio
Proprietary SenSet™ field adjustable range scaling
Specifications:
Analog I/Os: 0-5 V or 0.5-4.5 V output with 8 -30 V input, 35 mA max.
0-10 V DC output with 12-30 V input, 35 mA max.
4-20 mA (3-wire) output with 18-30 V input, 60 mA max (75 C max).
Measuring Ranges: 12.5-100 mm (0.5 to 4 inches) Full Scale (nominal)
Linearity Error: ± 0.15% of FSO typical, ± 0.25% of FSO max
Resolution: 0.025% of FSO
Operating Temperature: -20 to 85 C (-40 to 105 C extended temperature range)
Temperature Coefficient: ≤0.015% of FS/deg C
Vibration: 5-20 Hz, 0.5 inch p-p; 20-2000 Hz, 4.2 g p-p
Shock: 1000 g, 11 msec.
Terminations: IEC IP-67
Humidity: 95% RH, non-condensing
All specifications are subject to change without notice.
© Alliance Sensors Group, 2021
V6.0 Rev. 92021
LRS-18 Series
I/O Function
Wiring Table
Cable Color
M12 Pin
Unit Length Table
+DC Power input
Ground
Analog output
Current output
Red
Black
Green
Green
1
2
3
4
E
D
SenSet™
White
5
B
PT02-10 Pin
Nominal Range ‘A’
Inches [mm]
Body Length “B”
Inches [mm]
Spring Rate
Lbf/in [kgf/cm]
Max. Force
Lbf [kgf]
0.5 [12.7]
1.0 [25]
2.0 [50]
3.0 [75]
4.0 [100]
3.50 [88.9]
4.00 [101.6]
5.08 [129.0]
6.16 [156.5]
7.25 [184.1]
0.75 [0.134]
0.75 [0.134]
0.43 [0.077]
0.30 [0.054]
0.23 [0.041]
0.9 [0.41]
0.9 [0.41]
1.0 [0.45]
1.0 [0.45]
1.0 [0.45]
A
Ordering Information:
Series
Output
Type
Housing
Thread
Range,
Metric
Termination
Direction
Termination
Output
Housing Material
LRS
X-
XX-
XXX-
X-
XX-
XX-
X-
E- Voltage
18- M18
013- 12.7 mm
A- Axial
I- Current
00- 1 m cable
05- 0.5 to 4.5 VDC
A- Aluminum
025- 25 mm
01- 5-pin M12
06- 4.5 to 0.5 VDC
S- 300 Series SS
050- 50 mm
02 6-pin PT02
10- 0 to 10 VDC
075- 75 mm
00- 3 m cable
11- 10 to 0 VDC
100- 100 mm
20- 4 to 20 mA
21- 20 to 4 mA
50- 0 to 5 VDC
51- 5 to 0 VDC
102 Commerce Drive, Unit 8
Moorestown, New Jersey 08057 USA
Ph: 856-727-0250
www.alliancesensors.com
info@alliancesensors.com
V6.0 Rev. 92021
LRSE-18-050-A-00-10-A 价格&库存
很抱歉,暂时无法提供与“LRSE-18-050-A-00-10-A”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+4360.522451+566.85381
